Всем привет.
Выкладываю лог.
Saturday,03,November,2012,13:16:53:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 1K0
Scan: 01 03 08 09 10 15 16 17 18 19 1C 22 25 42 44 46 52 53 56 62
72
VIN: WVGZZZ5NZ9W029395 Mileage: 113830km/70730miles
01-Engine -- Status: Malfunction 0010
18-Aux. Heat -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 GT HW: 03L 906 022 G
Component: R4 2,0L EDC 0000SG 3028
Revision: 13H01--- Serial number: VWX7Z0H63NM1GP
Coding: 0000172
Shop #: WSC 24230 943 72146
VCID: 7DFBE72D24EA4F1
2 Faults Found:
008214 - Intake Manifold Flap Position Sensor (Bank 1)
P2016 - 000 - Short to Ground - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 5
Mileage: 112470 km
Time Indication: 0
Date: 2000.00.00
Time: 11:53:09
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Lambda: 11.8 %
Lambda: 4.7 %
Voltage: 0.228 V
Bin. Bits: 00000000
008213 - Intake Manifold Flap Position Sensor (Bank 1)
P2015 - 000 - Implausible Signal - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100000
Fault Priority: 2
Mileage: 112514 km
Time Indication: 0
Date: 2000.00.00
Time: 08:33:15
Freeze Frame:
RPM: 1817 /min
Speed: 78.0 km/h
Load: 27.8 %
Lambda: 11.8 %
Lambda: 4.7 %
Voltage: 0.228 V
Bin. Bits: 00000000
Readiness: 1 2 0 0 0
Address 18: Aux. Heat Labels: Redir Fail!
Part No: 5K0 963 272 E
Component: Standheizer 042 4709
Revision: 00042000 Serial number: 09021534000000
Coding: 0011012
VCID: 32610411AD34409
1 Fault Found:
01406 - No Flame
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 3
Reset counter: 11
Mileage: 113686 km
Time Indication: 0
Freeze Frame:
Start
Temperature: 24.0°C
Temperature: 23.0°C
Voltage: 14.24 V
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0205
Revision: 00020000 Serial number: 00000000000000
Coding: 81800A0052830C7F3F04840570084FCEF0FC00
Shop #: WSC 01324 785 00200
VCID: 830F11D5C20EB91
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 1K8 951 171
Component: DWA-Sensor 001 0104
1 Fault Found:
01135 - Interior Monitoring Sensors
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 42
Time Indication: 0
End ---------------------------------------------------------------------
Знаю что блок впускных заслонок не работает. Но есть еще и короткое замыкание. Это предохранитель?
DWA-Sensor - это датчик контроля объема салона на сигнализации?
