свежий лог
я так понимаю чтобы прочитать нужно разделить на группы по 3
подскажите если чтото не так делаю
Sunday,16,June,2019,16:10:15
038 906 012 F,, 1.9l R4 EDC 0000SG 3331,
,Group A:,'003,,,,Group B:,'010,,,,Group C:,'011
,,Engine speed,MAF (specified),MAF (actual),EGR duty cycle,,MAF Sensor,Atmos. Pressure,Manifold Pressure,Throttle,,Engine speed,Specified MAP,Actual MAP,D.cycle MAP v.
,TIME,870-950 rpm,230-370 mg/H,230-370 mg/H,40-75%,TIME,230-370 mg/H,Sensor-f96-,MAP sensor-G71-,%Throttle,TIME,rpm,1850-1950 mbar,1700-2080 mbar,45-95%
Marker,STAMP, /min, mg/str, mg/str, %,STAMP, mg/str, mbar, mbar, %,STAMP, /min, mbar, mbar, %
,0.02,861,365.0,455.0,84.5,0.36,455.0,999.6,1009.8,9.0,0.72,693,1224.0,1030.2,68.1
,1.07,819,850.0,420.0,4.8,1.41,455.0,989.4,1030.2,0.0,1.73,1029,1111.8,1030.2,68.1
,2.05,924,395.0,430.0,19.9,2.40,475.0,989.4,1030.2,0.0,2.76,861,1152.6,1030.2,68.1
,3.12,924,430.0,455.0,22.3,3.48,450.0,989.4,1030.2,12.5,3.84,966,1213.8,1040.4,68.1
,4.20,1008,625.0,470.0,19.9,4.56,480.0,989.4,1060.8,20.0,4.92,1071,1193.4,1060.8,68.1
,5.27,1113,520.0,485.0,19.9,5.61,470.0,999.6,1060.8,27.5,5.93,1197,1203.6,1071.0,68.1
,6.28,1197,385.0,480.0,31.1,6.64,475.0,989.4,1060.8,26.7,7.00,1260,1203.6,1060.8,68.1
,7.36,1302,375.0,470.0,59.4,7.72,470.0,989.4,1060.8,25.1,8.08,1323,1213.8,1071.0,68.1
,8.44,1302,245.0,440.0,84.5,8.80,465.0,989.4,1040.4,0.0,9.16,1302,969.0,1040.4,68.1
,9.47,1281,245.0,450.0,84.5,9.79,445.0,999.6,1030.2,0.0,10.12,1260,958.8,1020.0,68.1
,10.48,1197,240.0,465.0,84.5,10.84,455.0,989.4,1020.0,0.0,11.20,987,948.6,1020.0,68.1
,11.56,945,255.0,465.0,84.5,11.92,455.0,989.4,1009.8,0.0,12.28,924,948.6,1009.8,68.1
,12.64,924,245.0,440.0,84.5,13.00,460.0,989.4,999.6,0.0,13.34,903,1152.6,1009.8,68.1
,13.67,924,405.0,460.0,76.5,13.99,450.0,989.4,1020.0,10.2,14.33,924,1152.6,1020.0,68.1
,14.68,987,365.0,470.0,84.5,15.04,445.0,989.4,1020.0,15.3,15.40,1050,1336.2,1030.2,68.1
,15.76,1071,780.0,460.0,4.8,16.12,470.0,989.4,1071.0,63.1,16.48,1176,1499.4,1081.2,68.1
,16.84,1218,850.0,495.0,4.8,17.19,525.0,989.4,1122.0,76.5,17.51,1323,1632.0,1142.4,68.1
,17.83,1365,850.0,525.0,4.8,18.18,525.0,989.4,1183.2,100.0,18.54,1470,1785.0,1193.4,68.1
,18.90,1554,805.0,550.0,4.8,19.26,555.0,999.6,1244.4,100.0,19.62,1659,1876.8,1275.0,68.1
,19.98,1722,800.0,590.0,4.8,20.34,605.0,999.6,1346.4,100.0,20.68,1848,1917.6,1387.2,68.1
,21.01,1932,795.0,655.0,4.8,21.33,660.0,999.6,1458.6,100.0,21.65,2016,1907.4,1479.0,68.1
,21.98,2058,795.0,690.0,4.8,22.33,710.0,989.4,1540.2,100.0,22.70,2163,1907.4,1560.6,68.1
,23.06,2226,800.0,730.0,4.8,23.42,730.0,999.6,1611.6,100.0,23.78,2331,1897.2,1632.0,68.1
,24.14,2394,795.0,755.0,4.8,24.49,760.0,989.4,1662.6,100.0,24.81,2478,1876.8,1672.8,68.1
,25.13,2520,795.0,770.0,4.8,25.45,770.0,999.6,1693.2,100.0,25.77,2583,1876.8,1693.2,68.1
,26.13,2646,795.0,755.0,4.8,26.50,760.0,989.4,1693.2,100.0,26.86,2730,1876.8,1703.4,68.1
,27.22,2751,800.0,770.0,4.8,27.58,755.0,989.4,1713.6,100.0,27.94,2835,1876.8,1723.8,68.1
,28.29,2898,800.0,755.0,4.8,28.61,750.0,999.6,1734.0,100.0,28.95,2961,1866.6,1734.0,68.1
,29.27,2982,805.0,755.0,4.8,29.61,760.0,989.4,1744.2,100.0,29.94,3045,1866.6,1754.4,68.1
,30.30,3066,805.0,750.0,4.8,30.66,750.0,989.4,1764.6,100.0,31.02,3150,1866.6,1774.8,68.1
,31.38,3171,810.0,750.0,4.8,31.74,735.0,989.4,1774.8,100.0,32.10,3255,1866.6,1774.8,68.1
,32.44,3255,810.0,735.0,4.8,32.76,730.0,989.4,1774.8,100.0,33.09,3318,1866.6,1785.0,68.1
,33.41,3339,815.0,735.0,4.8,33.75,740.0,989.4,1785.0,100.0,34.09,3381,1866.6,1795.2,68.1
,34.46,3402,815.0,730.0,4.8,34.82,740.0,999.6,1795.2,100.0,35.18,3465,1856.4,1805.4,68.1
,35.54,3465,820.0,740.0,4.8,35.90,735.0,989.4,1805.4,100.0,36.25,3528,1856.4,1815.6,68.1
,36.57,3549,835.0,725.0,4.8,36.89,730.0,989.4,1815.6,100.0,37.23,3570,1856.4,1815.6,68.1
,37.55,3591,840.0,725.0,4.8,37.90,725.0,989.4,1825.8,100.0,38.26,3612,1815.6,1815.6,68.1
,38.64,3633,850.0,720.0,4.8,39.00,730.0,989.4,1825.8,100.0,39.36,3675,1764.6,1825.8,68.1
,39.72,3696,850.0,715.0,4.8,40.08,715.0,989.4,1825.8,100.0,40.44,3717,1713.6,1825.8,68.1
,40.77,3717,850.0,715.0,4.8,41.09,725.0,989.4,1825.8,100.0,41.41,3759,1703.4,1836.0,68.1
,41.73,3759,850.0,715.0,4.8,42.08,725.0,989.4,1836.0,100.0,42.44,3780,1683.0,1836.0,68.1
,42.80,3822,850.0,710.0,4.8,43.16,550.0,989.4,1632.0,0.0,43.52,3591,1020.0,1417.8,68.1
,43.88,2940,300.0,525.0,19.9,44.26,520.0,989.4,1244.4,0.0,44.61,1722,907.8,1183.2,68.1
2,44.94,1281,245.0,475.0,84.5,45.25,435.0,989.4,1101.6,0.0,45.57,1029,856.8,1060.8,68.1
6,45.90,987,250.0,435.0,84.5,46.26,455.0,999.6,1030.2,0.0,46.62,903,856.8,1020.0,68.1
,46.98,903,255.0,450.0,84.5,47.34,445.0,989.4,1009.8,0.0,47.69,903,867.0,1009.8,68.1
9,48.02,903,255.0,445.0,84.5,48.36,425.0,989.4,1009.8,0.0,48.70,903,867.0,1009.8,68.1
11,49.03,903,255.0,430.0,84.5,49.35,435.0,989.4,1009.8,0.0,49.70,903,877.2,1009.8,68.1
,50.06,903,255.0,440.0,84.5,50.42,445.0,989.4,999.6,0.0,50.78,903,877.2,1009.8,68.1
12,51.14,903,255.0,435.0,84.5,51.50,435.0,989.4,1009.8,0.0,51.86,903,887.4,999.6,68.1
18,52.22,903,260.0,435.0,84.5,52.58,425.0,989.4,1009.8,0.0,52.92,903,897.6,1009.8,68.1
