Tatar24 написал(а):Посмотрите, пожалуйста на двигатель AKN: 3B1 907 401 B
tlc написал(а):Hello,
Display groups for 2.0l 4V TDI (BMN/BUY) in A3
as at 18.12.06
001 Injection quantity
Coolant temperature min. 75°C:
1) Engine speed
At idle: 790 ... 810 rpm
At full throttle: 2800 ... 3200 rpm
2) Injection quantity
At idle: 3.0 ... 10.0 mg/stroke
At full throttle: 45 ... 75 mg/stroke
3) Specified duration of delivery
At idle: 2 ... 9 °CA
At full throttle: 20 ... 30 °CA
4) Coolant temperature
Less than 75°C: => Warm up engine
002 Idling speed
1) Engine speed
2) Accelerator pedal position
At idle: 0 %
At full throttle: 99...100 %
3) Operational status
XXXX XXX1 AC ON
Less than 75°C => Warm up engine
003 Exhaust gas recirculation
1) Engine speed
2) Specified exhaust gas recirculation
At idle: 180 ... 350 mg/stroke
At full throttle: 900 ... 1300 mg/stroke
3) Actual exhaust gas recirculation
4) EGR actuator activation
At idle: 15...65 %
At full throttle: 0 %
Exhaust gas recirculation shuts off after approx. 2 min
To activate: Press accelerator n > 1500 rpm
004 Activation of pump/nozzle unit piezo valves
1) Engine speed
2) Specified commencement of injection
At idle: 4.2 °b.TDC ... 5.2 ° aft.TDC
At full throttle: 13 ... 25 °b.TDC
4) Rotation angle
Idle/full throttle: -6 ... 6 °CA
005 Starting conditions
Stored from last engine start
1) Engine speed
790 ... 810 rpm
2) Starting torque
0 Nm
3) Start synchronisation
001 Self-synchronisation camshaft active
002 Self-synchronisation crankshaft active
004 Engine running
008 Engine synchronisation validated
016 Engine synchronisation completed successfully
032 Self-synchronisation camshaft sensor successful
064 Self-synchronisation crankshaft sensor successful
128 First valid cog detected
Interim values may also be displayed,
composed of sums of the above single values.
[°C]
006 Switch settings
1) Current road speed
At least 40 - 80 km/h (at full throttle)
2) Pedal monitoring
X X X X X X X 1 Brake light switch pressed
X X X X X X 1 X Brake pedal switch pressed(redundant)
X X X X X 1 X X Clutch pedal switch pressed
X X X X 1 X X X CCS enabled
X X X 1 X X X X ACC enabled
X X 1 X X X X X Main switch pressed
0 0 X X X X X X ACC/CCS mode inactive
1 0 X X X X X X State overspill
0 1 X X X X X X ACC/CCS in control range
1 1 X X X X X X ACC/CCS not enabled
3) Accelerator pedal position
4) CCS switch settings
X - X X X X X 1 Locked ON
X - X X X X 1 X Touched OFF
X - X X X 1 X X Touch-Down, reduce
X - X X 1 X X X Touch-Up, increase
X - X 1 X X X X Set
X - 1 X X X X X Resume
1 - X X X X X X Locked ON from hardware
007 Temperature senders
1) Fuel temperature
Down to 95 °C
2) Vacant
3) Intake air temperature (intake manifold temperature)
5 ... 80 °C
[°C]
008 Limiting torque 1
1) Engine speed
2) Requested torque (accelerator pedal)
At idle: -5 ... 0 Nm
At full throttle: 350 ... 450 Nm
3) Torque limitation
At idle: 150 ... 300 Nm
At full throttle: 350 ... 400 Nm
4) Smoke limitation
At idle: 100 ... 230 Nm
At full throttle: >= Torque limitation (see zone 3)
010 Air quantities
1) Intake air mass
At full throttle: 900 ... 1400 mg/stroke
2) Ambient air pressure (altitude and weather dependent)
900 ... 1100 mbar
3) Actual charge pressure (altitude and weather dependent)
At idle: 900 ... 1150 mbar
At full throttle: 2000 ... 2800 mbar
4) Accelerator pedal position
At idle: 0 %
011 Charge pressure control
1) Engine speed
2) Specified charge pressure
At full throttle: 2100 ... 2400 mbar
At full throttle: 2000 ... 2500 mbar
4) Charge pressure limitation duty cycle
At idle: 40...95 %
At full throttle: 15...95 %
012 Preheating system
1) Glow status
0 0 0 0 0 0 0 0 Init. phase or run-on active
0 0 0 0 0 0 0 1 Waiting for ECO start request
0 0 0 1 0 0 0 0 Glow period
0 1 0 1 0 0 0 0 No glow
1 0 1 1 0 0 0 0 After-glow
1 1 0 0 0 0 0 0 No start glow
1 1 1 1 0 0 0 0 Intermediate glow
0 0 1 1 0 0 0 0 Readiness glow
0 1 1 1 0 0 0 0 Start glow
1 0 1 1 0 0 0 1 Waiting for after-glow
1 1 0 1 0 0 0 0 No after-glow
1 1 1 1 0 0 0 1 Waiting for intermediate glow
1 1 1 1 1 1 1 1 No glow
2) Glow period
3)Vehicle voltage
10 ... 15 V
[°C]
013 Smooth running control
Measured values at idle, coolant temperature min. 75°C:
1) Cylinder 1 injection quantity variation
2) Cylinder 2 injection quantity variation
3) Cylinder 3 injection quantity variation
4) Cylinder 4 injection quantity variation
Injection quantity Permissible limits for
from MVB 01/2 Idle smooth control injection quantity cyl.1-4
[mg/stroke] [mg/stroke]
5 -1.90...1,90
5,5 -2.09...2,09
6 -2.28...2,28
6,5 -2.47...2,47
7 -2.66...2,66
7,5 -2.85...2,85
8 -3.04...3,04
8,5 -3.23...3,23
9 -3.42...3,42
9,5 -3.61...3,61
10 -3.80...3,80
015 Fuel consumption
1) Engine speed
2) Engine torque
At idle: 25 ... 60 Nm
3) Fuel consumption
[ltr/h]
4) Required injection quantity (accelerator pedal)
[Nm]
016 Additional heater
1) Alternator load
5...100 %
2) Vacant
3) Vacant
4)Vehicle voltage
10 ... 15 V
017 Readiness code (EOBD)
1) CARB mode 01 DATA A
X - - - 0 0 0 0 No fault messages stored
0 - - - X X X X MIL lamp OFF
1 - - - X X X X MIL lamp ON
2) CARB mode 01 DATA B
- X X X - X X 1 Activation misfire detection (1 = present)
- X X X - X 1 X Activation fuel system (1 = present)
- X X X - 1 X X Activation complete system (1 = present)
- X X 0 - X X X EOBD test misfire detection completed *)
- X 0 X - X X X EOBD test fuel system completed
- 0 X X - X X X EOBD test overall system completed
3) CARB mode 01 DATA C
X X 1 - - - - - Activation lambda probe (1 = present)
X 1 X - - - - - Activation lambda probe heating (1 = present)
1 X X - - - - - Activation EGR (1 = present)
4) CARB mode 01 DATA D
X X 0 - - - - - EOBD test lambda probe completed *)
X 0 X - - - - - EOBD test lambda probe heating completed *)
0 X X - - - - - EOBD test EGR completed
*) Depending on equipment spec
018 Status of piezo valves
1) Cylinder 1
2) Cylinder 2
3) Cylinder 3
4) Cylinder 4
Key - cylinders 1 to 4:
000 Fault-free control
002 Closed-loop control at start
004 Small injection quantity or piezo valve off
008 Energy limits reached
016 Valve closing time (BIP) implausible
032 Piezo capacity implausible
064 Piezo energy implausible
128 No closing time identification (BIP) possible
(poss. electrical fault in measuring channel)
023 Switching times of piezo valves
1) Cylinder 1
2) Cylinder 2
3) Cylinder 3
4) Cylinder 4
Values, cylinders 1 to 4: 0.18 ... 0.25 ms
028 Pedal sender
1) Accelerator pedal sender 1
Accelerator pos.: 0 % A 0.27 ... 0.89 V
100 % A 3.30 ... 4.74 V
2) Accelerator pedal sender 2
Accelerator pos.: 0 % A 0.14 ... 0.44 V
100 % A 1.65 ... 2.56 V
XXXX XXX1 AC ON4) Accelerator pedal position
At idle: 0 %
040 Lambda probe lambda value
1) Engine speed
At idle: 3 ... 10 mg/stroke
3) Status lambda probe heater
XXXX XX01 Lambda probe heater not heating, or heating at reduced output
XXXX XX10 Enable lambda probe heater
4)Lambda actual
041 Electric EGR actuator 1
1) Specified position regulating flap
90...98 %
2) Specified position EGR actuatorr
15...65 %
3) Actual position EGR actuatorr
15...65 %
4) Duty cycle EGR actuatorr
042 Electric EGR actuator / intake manifold flap
1) Learned value EGR actuator (closed)
0.6 ... 1.2 V
2) Status EGR actuator adaption
0000 0000
3) Position regulating flap
90...98 %
4) Position EGR actuator
15...65 %
043 Charge pressure actuator
1) Duty cycle charge pressure actuator
70...98 %
2) Position charge pressure actuator
80...98 %
3) Vacant
4) Vacant
044 Variable intake manifold / EGR cooler 2
1) Engine speed
2) Intake air mass
3) Status EGR cooler
0 EGR cooler active/on
1 EGR cooler not active/off
4) Intake manifold flap valve duty cycle
046 Electric regulating flap 1 (intake manifold flap)
90...98 %
2) Charge pressure control specification
90...98 %
90...98 %
4) Duty cycle regulating flap
047 Electric regulating flap 2 (intake manifold flap)
1) Learned value regulating flap (closed)
0.4 ... 0.6 V
2) Learned value regulating flap (open)
No data
3) Duty cycle regulating flap
4) Position regulating flap
90...98 %
051 Speed recording
1) Engine speed
[rpm]
2) Camshaft speed
Engine speed/2 rpm +-50
000 Basic initialisation
001 Reset counter
002 Engine standstill or fault
003 Transitional states
004 Plausibility check phase
005 Plausibility check phase
006 Plausibility check phase
008 Plausibility check phase
016 Phase definition
028 Redundant start
032 Synchronisation phase
033 System positioning
048 Calculation sequences activated
064 System waiting for engine standstill
128 Dynamic plausibility check
4) Injection sequence shut-off status
No data
062 Engine cooling 3
1) Coolant temperature
[°C]
2) Coolant - radiator outlet
<= Channel 1 (coolant temperature)
3) Ambient temperature
-20 ... 50 °C
4) Intake air temperature (intake manifold temperature)
5 ... 80 °C
063 Engine cooling 4
1) AC compressor refrigerant pressure
AC OFF: 3 ... 8 bar
AC ON: 5 ... 30 bar
2) AC compressor load torque
AC OFF: 0 Nm
AC ON: -30 ... -5 Nm
3) Coolant requirement
4) AC compressor shut-off status
001 Vehicle starting off
002 OFF because starting off
004 Vehicle accelerating
008 OFF because accelerating
016 Shut-off because starting
064 Engine cooling 5
[°C]
3) Fan 1 duty cycle
Radiator fan OFF: 9...11 %
Radiator fan ON: 11...100 %
4) Vacant
067 Particulate filter exhaust gas values 1
Condition: v=const 50-60km/h,3rd gear, n<=3000 rpm
A Values valid only during regeneration
1) Temperature upstream of turbocharger
> 690°C (after 10 seconds)
2) Temperature before particulate filter
> 400°C (reached only 30 s after regeneration start)
3) Pressure difference over particulate filter
No data
4) Offset differential pressure in overrun
No data
068 Particulate filter exhaust gas values 2
1) Charge coefficient
< 40% (at 40% regeneration starts)
2) Ash mass
max. 60 g *)
3) Ash learned value
No data
4) Vacant
*) After replacing filter set axle mass with VAG tester to 0
069 Particulate filter regeneration status 1
1) Regeneration status 1
XXXX XXX1 Interruption of regeneration by overrun, high
torque request or fast speed
change
2) Vacant
3) Vacant
4) Regeneration status 4
XXXX XXX1 Normal thermal regeneration
XXXX XX1X Enhanced thermal regeneration
070 Particulate filter regeneration status 1
1) Regeneration status 4
2) Total regeneration time (since last successful regeneration)
3) Regeneration counter (number of failed regenerations)
max.4
4) Status successful regeneration
071 Particulate filter post-injection
1) Engine speed
<= 3000 rpm
2) Post-injection quantity
> 10 mg/stroke
3) Commencement of delivery, post-injection
[° bef./aft. TDC]
4) Duration of delivery, post-injection
°CA
073 Particulate filter vehicle data
1) Consumption since last regeneration
[l]
2) Distance since last regeneration
[km]
3) Time since last regeneration
[h]
4) Vacant
074 Particulate filter exhaust gas values 3
1) Engine speed
[rpm]
2) Temperature upstream of turbocharger
> 690°C
3) Lambda value
1,0-2,0
4) Vacant
075 Particulate filter emission values 4
Engine idling, 20 seconds after cold start
at room temperature
> 100°C
100°C > T > 60°C
3) Charge coefficient
< 40% (as from 40% regeneration starts when driving)
4) Temperature after particulate filter
60°C > T > 20°C
090 EOBD exhaust gas recirculation 1
Condition: Engine idling,v=0km/h,no gear engaged.
Handbrake applied
1) Engine speed
[rpm]
3 ... 9 mg/stroke
3) Specified exhaust gas recirculation
200 ... 380 mg/stroke
4) Status EGR control deviation
0000 0000
091 EOBD exhaust gas recirculation 2
Handbrake applied
1) EGR actuator permissible positive control deviation
128
2) EGR actuator permissible negative control deviation
-128
3) Air mass specification
Idle: 180...300
4) Control deviation
125 CAN bus communication 1
1) Gearbox control unit
2) ABS control unit
3) Dash panel insert control unit
4) Airbag control unit
Each 1 bit: 0 = inactive
1 = active
--- = not fitted
126 CAN bus communication 2
1) Air conditioner control unit
2) Vacant
3) Onboard power supply control unit
4) ACC control unit
1 = active
--- = not fitted
127 CAN bus communication 3
1) Four-wheel drive control unit
2) Adaptive suspension control unit
3) Vacant
4) Steering column module control unit
1 = active
--- = not fitted
128 CAN bus communication 4
1) Gateway control unit
2) Battery energy management control unit
3) Vacant
4) Vacant
1 = active
--- = not fitted
Coding table for engine control unit
The code word is composed as follows:
Additional functions
0 0 0 0 X X X : With ESI;
0 0 5 0 X X X : Without ESI;
ESI = Extended service intervals
Drive
0 0 X 0 0 X X : Front-wheel drive
0 0 X 0 1 X X : Four-wheel drive
Air conditioner
0 0 X 0 X 3 X : Without air conditioner
0 0 X 0 X 7 X : With automatic air conditioner
Gearbox
0 0 X 0 X X 2 : 6-speed manual gearbox
0 0 X 0 X X 8 : Automatic gearbox (DSG)
Coding example:
0 0 0 0 0 7 8 : Vehicle with ESI; with front-wheel drive; with automatic AC
and automatic gearbox (DSG)
Basic setting for 2.0L TDI in A3
KNote:
To start the "Basic setting" function from Guided
Fault Finding:
1) Press mode button
2) Choose "Vehicle self-diagnosis" menu option
3) Choose "01-Engine electronics I" menu option
4) Select "04-Basic setting" and then the
number of the display group (e.g. 003 for exhaust gas recirculation)
003 Basic setting: Exhaust gas recirculation
1) Start engine
2) Start basic setting
3) Engine speed idling
4) To start the basic setting the
brake pedal and accelerator must be
pressed simultaneously!
KNote:
The exhaust gas recirculation is now switched
on and off intermittently.
Specifications with "EGR not active":
Engine speed: 1450 ... 1550 rpm
Position EGR
positioner : -2 ... 2 %
Air mass: 400 ... 600 mg/stroke
Specificed position EGR
Specifications with "EGR active":
Position EGR
positioner : 30 ... 50 %
Air mass: 180 ... 390 mg/stroke
Record air mass values for TVH1 and TVH2 and
form difference. Difference must be at least 100 mg per stroke.
011 Basic setting: Turbocharger
1) Start engine
KNote:
The turbocharger is now activated alternatingly at duty cycles
of -2 ... 2 % and 85 ... 95 %.
In this, the difference in the value 3 (actual charge pressure)
between CPC n.active and CPC active must be at least 80 mbar.
The engine speed is automatically increased.
035 Basic setting: Fuel supply pump
(not available in all vehicles)
1) Ignition ON
KNote:
The electric fuel pump is then switched
ON/OFF intermittently. The noise of the pump may be perceptible
by touching the tank or may be quietly audible.
(IMPORTANT! There must be no open fuel supply lines!)
063 Basic setting: Adapting kickdown point
(only for vehicles with automatic gearbox)
1) Ignition ON
3) Follow the instructions:
- First leave accelerator pedal in rest position (accelerator pedal)
- then press down accelerator pedal fully (press accelerator pedal)
4) Wait for status ADP.OK to be displayed, then
adaption is OK
5) Value is only stored in engine control unit after
approx. 5 seconds ignition OFF. (Ignition must not be
switched on again during this time!!!)
"03G-906-018-BMN.lbl" написал(а):;
; VAG-COM Labeldatei
; Audi A3 (8P) / Seat Altea/Toledo (5P) / Seat Leon (1P) / Skoda Octavia II (1Z)
; VW Golf V (1K) / VW Passat (3C) / VW Touran (1T)
; Bauteil: J623 - Motorelektronik (#01) - BMN/BMR/BUY/BUZ 2.0l TDI-PPD
; T/N: 03G-906-018-???
; beinhaltet Messwertblöcke, Grundeinstellung, Codierung, Codierung-II und Anpassung
; This file is part of a redirection package,
; make sure you have all of the following files.
; 03-01.LBL
; 03G-906-018-BMN.LBL (2.0l TDI @ 170 HP - BMN/BMR/BUY/BUZ)
; erstellt am 10.08.2006 von Sebastian Stange (Sebastian@Ross-Tech.com)
; letzte Änderung: 22.06.2007
; benötigt mindestens VAG-COM 602.3 oder höher
; Messwertblöcke & Grundeinstellung
001,0,Einspritzmenge
001,1,Motordrehzahl,(G28),Sollwert (Leerlauf): 790...810 U/min\nSollwert (Volllast): 2800...3200 U/min
001,2,Einspritzmenge,,Sollwert (Leerlauf): 3.0...10.0 mg/Hub\nSollwert (Volllast): 45.0...75.0 mg/Hub
001,3,Förderdauer,(Sollwert),Sollwert (Leerlauf): 2.0...9.0 °KW\nSollwert (Volllast): 20.0...30.0 °KW
001,4,Kühlmittel-,temperatur (G62),Sollwert (Warm): 80.0...110.0 °C
002,0,Leerlaufdrehzahl
002,1,Motordrehzahl,(G28),Sollwert (Leerlauf): 790...810 U/min\nSollwert (Volllast): 2800...3200 U/min
002,2,Gaspedalstellung,,Sollwert (Leerlauf): 0.0 %\nSollwert (Volllast): 99.0...100.0 %
002,3,Betriebszustand,,Siehe Labeldatei
; xxxxxxx1 = Klimaanlage EIN
; xxxx1xxx = Leerlaufschalter geschlossen
; xxx1xxxx = Kick-Down (nur Automatik)
; x1xxxxxx = Erhöhter Leerlauf
002,4,Kühlmittel-,temperatur (G62),Sollwert (Warm): 80.0...110.0 °C
003,0,Abgasrückführung
003,1,Motordrehzahl,(G28),Sollwert (Leerlauf): 790...810 U/min\nSollwert (Volllast): 2800...3200 U/min
003,2,Abgasrückführung,(Sollwert),Sollwert (Leerlauf): 200.0...350.0 mg/Hub\nSollwert (Volllast): 900.0...1300.0 mg/Hub
003,3,Abgasrückführung,(Istwert),Sollwert (Leerlauf): 180.0...350.0 mg/Hub\nSollwert (Volllast): 900.0...1300.0 mg/Hub
003,4,Ansteuerung,Abgasrückführung,Sollwert (Leerlauf): 20.0...70.0 %\nSollwert (Volllast): 0.0 %
B003,0,Abgasrückführung
; Zündung EIN, Motor EIN (im Leerlauf)
; Grundeinstellung aktivieren
; Bremspedal und Gaspedal gleichzeitig betätigen
; Abgasrückführung wird abwechselnd ein- und ausgeschaltet
; Differenz zwischen "AGR aktiv" und "AGR inaktiv" muss mindestens 100.0 mg/Hub betragen
B003,1,Motordrehzahl,(G28),Sollwert (Leerlauf): 790...810 U/min\nSollwert (Grundeinstellung): 1450...1550 U/min
B003,2,Abgasrückführung,(Sollwert)
B003,3,Abgasrückführung,(Istwert),Sollwert (AGR inaktiv): 400.0...600.0 mg/Hub\nSollwert (AGR aktiv): 180.0...390.0 mg/Hub\nDifferenz (AGR aktiv/inaktiv): min. 100.0 mg/Hub
B003,4,Ansteuerung,Abgasrückführung,Sollwert (AGR inaktiv): -2.0...2.0 %\nSollwert (AGR aktiv): 30.0...50.0 %
004,0,Ansteuerung Pumpe-Düse Ventile
004,1,Motordrehzahl,(G28),Sollwert (Leerlauf): 790...810 U/min\nSollwert (Volllast): 2800...3200 U/min
004,2,Förderbeginn,(Sollwert),Sollwert (Leerlauf): 4.2 °v.OT ... 5.2 °n.OT\nSollwert (Volllast): 5.0...18.0 °v.OT
004,3,Förderdauer,(Sollwert),Sollwert (Leerlauf): 2.0...9.0 °KW\nSollwert (Volllast): 20.0...30.0 °KW
004,4,Verdrehwinkel,,Sollwert: -6...+6 °KW
005,0,Startverhältnisse (letzter Motorstart)
005,1,Motordrehzahl,(G28),Sollwert (Leerlauf): 790...810 U/min\nSollwert (Volllast): 2800...3200 U/min
005,2,Startmoment,,Sollwert: 0 Nm
005,3,Start-,synchronisation,Siehe Labeldatei
; Zwischenwerte ergeben sich aus der Summe der Einzelwerte
; 001 = Selbstsynchronisation Nockenwelle aktiv
; 002 = Selbstsynchronisation Kurbelwelle aktiv
; 004 = Motor läuft
; 008 = Motorsynchronisation validiert
; 016 = Motorsynchronisation erfolgreich abgeschlossen
; 032 = Selbstsynchronisation Kurbelwellen-Sensor erfolgreich
; 064 = Selbstsynchronisation Nockenwellen-Sensor erfolgreich
; 128 = Erster gültiger Zahn erkannt
005,4,Kühlmittel-,temperatur (G62),Sollwert (Warm): 80.0...110.0 °C
006,0,Geschwindigkeitsregelanlage (GRA)
006,1,Geschwindigkeit,(Istwert)
006,2,Pedalüberwachung,,Siehe Labeldatei
; xxxxxxx1 = Bremslichtschalter betätigt
; xxxxxx1x = Bremspedalschalter betätigt
; xxxxx1xx = Kupplungspedalschalter betätigt
; xxxx1xxx = GRA freigeschaltet
; xxx1xxxx = ACC freigeschaltet
; xx1xxxxx = Haupttaster
; 00xxxxxx = ACC/GRA Modus nicht aktiv
; 10xxxxxx = Zustand übertreten
; 01xxxxxx = ACC/GRA im Regelbereich
; 11xxxxxx = ACC nicht freigeschaltet
006,3,Gaspedalstellung
006,4,Schalterstellung,,Siehe Labeldatei
; xxxxxxx? = Gerastet EIN
; xxxxxx?x = Getastet AUS
; xxxxx?xx = Verzögern (-)
; xxxx?xxx = Beschleunigen (+)
; xxx?xxxx = Setzen (SET)
; xx?xxxxx = Wiederaufnahme (RESET)
; ?xxxxxxx = Gerastet EIN (Hardware)
007,0,Temperaturen
007,1,Kraftstoff-,temperatur (G81),Sollwert: ca. Umgebungstemperatur
007,3,Saugrohr-,temperatur (G42),Sollwert: ca. Umgebungstemperatur
007,4,Kühlmittel-,temperatur (G62),Sollwert: ca. Umgebungstemperatur
008,0,Einspritzmengenbegrenzung I (Drehmomentbegrenzung)
008,1,Motordrehzahl,(G28),Sollwert (Leerlauf): 790...810 U/min\nSollwert (Volllast): 2800...3200 U/min
008,2,Fahrerwunsch-,moment,Sollwert (Leerlauf): -5.0...0.0 Nm\nSollwert (Volllast): 350.0...450.0 Nm
008,3,Drehmoment-,begrenzung,Sollwert (Leerlauf): 150.0...300.0 Nm\nSollwert (Volllast): 350.0...400.0 Nm
008,4,Rauchbegrenzung,,Sollwert (Leerlauf): 100.0...230.0 Nm\nSollwert (Volllast): 350.0...400.0 Nm
009,0,Einspritzmengenbegrenzung II (Drehmomentbegrenzung)
009,1,Motordrehzahl,(G28),Sollwert (Leerlauf): 790...810 U/min\nSollwert (Volllast): 2800...3200 U/min
009,2,Geschwindigkeits-,regelanlage
009,3,Getriebeeingriffs-,moment
009,4,Begrenzungs-,moment
010,0,Luftgrössen
010,1,Luftmasse,(Istwert),Sollwert (Leerlauf): 180.0...350.0 mg/Hub\nSollwert (Volllast): 900.0...1400.0 mg/Hub
010,2,Umgebungs-,Luftdruck,Sollwert: 900.0...1100.0 mbar
010,3,Ladedruck,(Istwert),Sollwert (Leerlauf): 900.0...1150.0 mbar\nSollwert (Volllast): 2000.0...2800.0 mbar
010,4,Gaspedalstellung,,Sollwert (Leerlauf): 0.0 %\nSollwert (Volllast): 99.0...100.0 %
011,0,Ladedruckregelung
011,1,Motordrehzahl,(G28),Sollwert (Leerlauf): 790...810 U/min\nSollwert (Volllast): 2800...3200 U/min
011,2,Ladedruck,(Sollwert),Sollwert (Leerlauf): 900.0...1150.0 mbar\nSollwert (Volllast): 2100.0...2400.0 mbar
011,3,Ladedruck,(Istwert),Sollwert (Leerlauf): 900.0...1150.0 mbar\nSollwert (Volllast): 2000.0...2500.0 mbar
011,4,Ansteuerung,Ladedruckregelung,Sollwert (Leerlauf): 40.0...95.0 %\nSollwert (Volllast): 15.0...95.0 %
B011,0,Ladedruckregelung
; Ladedruckregelung wird abwechselnd ein- und ausgeschaltet
; Differenz zwischen "LDR aktiv" und "LDR inaktiv" muss mindestens 80.0 mbar betragen
B011,1,Motordrehzahl,(G28),Sollwert (Leerlauf): 790...810 U/min
B011,2,Status,Ladedruckregelung,Wertebereich: Ein/Aus
B011,3,Ladedruck,(Istwert),Differenz (LDR aktiv/inaktiv): mind. 80.0 mbar
B011,4,Ansteuerung,Ladedruckregelung,Sollwert (LDR inaktiv): -2.0...+2.0 %\nSollwert (LDR aktiv): 85.0...95.0 %
012,0,Vorglühanlage
012,1,Glühstatus,,Siehe Labeldatei
; 00000000 = Warten auf Kühlmitteltemperatur
; 00000001 = Warten auf ECO Startanforderung
; 00010000 = Vorglühen
; 01010000 = Kein Vorglühen
; 10110000 = Nachglühen
; 11000000 = Kein Startglühen
; 11110000 = Zwischenglühen
; 00110000 = Bereitschaftsglühen
; 01110000 = Startglühen
; 10110001 = Warten auf Nachglühen
; 11010000 = Kein Nachglühen
; 11110001 = Warten auf Zwischenglühen
; 11111111 = Kein Glühen
012,2,Vorglühzeit
012,3,Versorgungs-,spannung,Sollwert: 13.0...15.0 V
012,4,Kühlmittel-,temperatur (G62),Sollwert: 80.0...110.0 °C
013,0,Leerlaufruheregelung (Einspritzmengenabweichung)
; Einspritzmenge Einspritzmengenabweichung
; (siehe MWB 001.2)
; 5.0 mg/Hub -1.90...1.90 mg/Hub
; 5.5 mg/Hub -2.09...2.09 mg/Hub
; 6.0 mg/Hub -2.28...2.28 mg/Hub
; 6.5 mg/Hub -2.47...2.47 mg/Hub
; 7.0 mg/Hub -2.66...2.66 mg/Hub
; 7.5 mg/Hub -2.85...2.85 mg/Hub
; 8.0 mg/Hub -3.04...3.04 mg/Hub
; 8.5 mg/Hub -3.23...3.23 mg/Hub
; 9.0 mg/Hub -3.42...3.42 mg/Hub
; 9.5 mg/Hub -3.61...3.61 mg/Hub
; 10.0 mg/Hub -3.80...3.80 mg/Hub
013,1,Zylinder 1,,Siehe Labeldatei
013,2,Zylinder 2,,Siehe Labeldatei
013,3,Zylinder 3,,Siehe Labeldatei
013,4,Zylinder 4,,Siehe Labeldatei
015,0,Kraftstoffverbrauch
015,1,Motordrehzahl,(G28),Sollwert (Leerlauf): 790...810 U/min\nSollwert (Volllast): 2800...3200 U/min
015,2,Motormoment,,Sollwert (Leerlauf): 25.0...60.0 Nm
015,3,Kraftstoffverbrauch
015,4,Einspritzmenge,(Fahrerwunsch)
016,0,Zusatzheizung
016,1,Generatorlast,,Sollwert: 5.0...100.0 %
016,4,Versorgungs-,spannung,Sollwert: 13.0...15.0 V
017,0,Readiness Code (EOBD)
017,1,CARB,Mode 01 DATA A,Siehe Labeldatei
; x---0000 = Keine Fehlermeldungen gespeichert
; 0---xxxx = MIL-Lampe AUS
; 1---xxxx = MIL-Lampe EIN
017,2,CARB,Mode 01 DATA B,Siehe Labeldatei
; -xxx-xx1 = Aktivierung Zündaussetzererkennung EIN
; -xxx-x1x = Aktivierung Kraftstoffanlage EIN
; -xxx-1xx = Aktivierung Gesamtsystem EIN
; -xxx-xxx = EOBD-Test Zündaussetzererkennung abgeschlossen
; -x0x-xxx = EOBD-Test Kraftstoffanlage abgeschlossen
; -0xx-xxx = EOBD-Test Gesamtsystem abgeschlossen
017,3,CARB,Mode 01 DATA C,Siehe Labeldatei
; xx1----- = Aktivierung Lambdasonde EIN
; x1x----- = Aktivierung Lambdasondenheizung EIN
; 1xx----- = Aktivierung Abgasrückführung EIN
017,4,CARB,Mode 01 DATA D,Siehe Labeldatei
; xx0----- = EOBD-Test Lambdasonde abgeschlossen
; x0x----- = EOBD-Test Lambdasondenheizung abgeschlossen
; 0xx----- = EOBD-Test Abgasrückführung abgeschlossen
018,0,Status Piezoventile
; 000 = Fehlerfreie Regelung
; 002 = Steuerung bei Start
; 004 = Kleine Einspritzmenge oder Piezoventil AUS
; 008 = Energiegrenzen erreicht
; 016 = Ventilschließzeit (BIP) unplausibel
; 032 = Piezokapazität unplausibel
; 064 = Piezoenergie unplausibel
; 128 = Keine Schließzeitidentifikation (BIP) möglich > Elektrischer Fehler
018,1,Zylinder 1,,Siehe Labeldatei
018,2,Zylinder 2,,Siehe Labeldatei
018,3,Zylinder 3,,Siehe Labeldatei
018,4,Zylinder 4,,Siehe Labeldatei
020,0,Mengeneingriff (ABS über CAN)
020,1,Motordrehzahl,(G28),Sollwert (Leerlauf): 790...810 U/min\nSollwert (Volllast): 2800...3200 U/min
020,2,Motormoment
020,3,ASR-Eingriff
020,4,MSR-Eingriff
021,0,CAN-Datenbus Status (Antrieb)
021,1,Motorelektronik
021,2,Getriebeelektronik
021,3,Bremsenelektronik
021,4,Bremsenelektronik,(ESP)
022,0,Abschaltstatus
022,1,Abschaltstatus,(GRA)
022,2,Schalterstellung,(GRA),Siehe Labeldatei
; 000 = Neutral
; 001 = Gerastet AUS
; 002 = Getastet AUS
; 003 = Setzen (SET)
; 004 = Tip Down
; 005 = Verzögern (-)
; 006 = Wiederaufnahme (RESET)
; 007 = Tip Up
; 008 = Beschleunigen (+)
022,3,Abschaltstatus,Ladedruckregelung,Siehe Labeldatei
; 001 = Kaltstart
; 002 = Systemfehler
; 004 = Regelabweichung
; 016 = Diagnoseeingriff
022,4,Abschaltstatus,Klimaanlage,Siehe Labeldatei
; 001 = Anfahrzustand
; 002 = Abschaltung: Anfahrzustand
; 004 = Beschleunigungszustand
; 008 = Abschaltung: Beschleunigungszustand
; 016 = Abschaltung: Startvorgang
; 032 = Systemfehler erkannt
; 064 = Abschaltung: Systemfehler
; 128 = Abschaltung: Unterschreitung Leerlaufdrehzahl
023,0,Schaltzeiten
023,1,Zylinder 1,,Sollwert: 0.18...0.25 ms
023,2,Zylinder 2,,Sollwert: 0.18...0.25 ms
023,3,Zylinder 3,,Sollwert: 0.18...0.25 ms
023,4,Zylinder 4,,Sollwert: 0.18...0.25 ms
025,1,Motordrehzahl,(G28),Sollwert (Leerlauf): 790...810 U/min\nSollwert (Volllast): 2800...3200 U/min
025,2,Status,Klemme 50,Wertebereich: ein/aus
025,3,Status,Motor,Wertebereich: Motor Ein/Motor Aus
025,4,Startabbruch-,bedingungen
026,0,Checksumme
026,1,Checksumme
027,0,Geschwindigkeitsbegrenzung
027,3,Geschwindigkeit
027,4,Geschwindigkeits-,begrenzung
028,0,Pedalwertgeber
028,1,Pedalwert-,geber 1,0 % = 0.60...0.91 V\n100 % = 3.80...4.94 V
028,2,Pedalwert-,geber 2,0 % = 0.30...0.45 V\n100 % = 1.90...2.58 V
028,3,Betriebszustand,,Siehe Labeldatei
028,4,Gaspedalstellung,,Wertebereich: 0.0...100.0 %\nSollwert (Leerlauf): 0.0 %\nSollwert (Volllast): 99.0...100.0 %
029,0,Motoröl
029,1,Öltemperatur
029,2,Ölniveauschwelle
029,3,Verschleißindex
029,4,Rußindex
030,0,Lambdaregelung
030,1,Lambdasonden,Abgleichswert
030,2,Offsetspannung,Sauerstoffsignal
030,3,Sauerstoff-,konzentration
030,4,Status Abgleich,Sauerstoffsignal
031,0,Lambdaregelung
031,1,Summe Luft-,massendurchsatz
031,2,Ansteuerung,Sondenheizung
031,3,Temeratur-,signalspannung
031,4,Sauerstoff-,signalspannung
032,0,Lambdaregelung
032,1,Summe Luft-,massendurchsatz
032,2,Außentemperatur
032,3,Luftdruck,Lambdasonde
032,4,Sauerstoff-,signalspannung
033,0,Lambdaregelung
033,1,Motordrehzahl,(G28),Sollwert (Leerlauf): 790...810 U/min\nSollwert (Volllast): 2800...3200 U/min
033,2,Abgas-,temperatur
033,3,Abgas-,gegendruck
033,4,Abgas-,massenstrom
034,0,Lambdaregelung
034,1,O²-Signal
034,2,Lambdasonden-,elektronik
034,3,Lambdasonden-,plausibilisierung
034,4,Lambdasonden-,diagnose
040,0,Lambdasonden
040,1,Motordrehzahl,(G28),Sollwert (Leerlauf): 790...810 U/min\nSollwert (Volllast): 2800...3200 U/min
040,2,Einspritzmenge,,Sollwert (Leerlauf): 3.0...10.0 mg/Hub\nSollwert (Volllast): 45.0...75.0 mg/Hub
040,3,Status,Sondenheizung
; xxxxxx01 = Lambdasondenheizung nicht bzw. mit reduzierter Leistung aktiv
; xxxxxx10 = Lambdasondenheizung freigegeben
040,4,Lambda,(Istwert)
041,0,Abgasrückführung && Saugrohrklappe
041,1,Position (Soll),Saugrohrklappe,Sollwert (Leerlauf): 90.0...98.0 %
041,2,Position (Soll),AGR-Steller,Sollwert (Leerlauf): 15.0...65.0 %
041,3,Position (Ist),AGR-Steller,Sollwert (Leerlauf): 15.0...65.0 %
041,4,Tastverhältnis,Abgasrückführung
042,0,Abgasrückführung && Saugrohrklappe
042,1,Lernwert (geschl.),AGR-Steller,Sollwert: 0.6...1.2 V
042,2,AGR-Steller,Adaption
042,3,Position (Ist),Saugrohrklappe,Sollwert (Leerlauf): 90.0...98.0 %
042,4,Position (Ist),AGR-Steller,Sollwert (Leerlauf): 15.0...65.0 %
043,0,Ladedrucksteller
043,1,Tastverhältnis,Ladedrucksteller,Sollwert: 70.0...98.0 %
043,2,Position,Ladedrucksteller,Sollwert: 80.0...98.0 %
044,0,Schaltsaugrohr && Kühler für Abgasrückführung
044,1,Motordrehzahl,(G28),Sollwert (Leerlauf): 790...810 U/min\nSollwert (Volllast): 2800...3200 U/min
044,2,Luftmasse,(Istwert),Sollwert (Leerlauf): 180.0...350.0 mg/Hub\nSollwert (Volllast): 900.0...1400.0 mg/Hub
044,3,Kühler für,Abgasrückführung,0 = aktiv\n1 = nicht aktiv
044,4,Ventil für,Saugrohrklappe
045,2,Druck,Einlassvolumen
045,3,Luftmasse,(Istwert)
045,4,Ladedruck,(Istwert),Sollwert (Leerlauf): 900.0...1150.0 mbar\nSollwert (Volllast): 2000.0...2500.0 mbar
046,0,Saugrohrklappe I
046,1,Position (Soll),Saugrohrklappe,Sollwert: 90.0...98.0 %
046,2,Lageregler,,Sollwert: 90.0...98.0 %
046,3,Position (Ist),Saugrohrklappe,Sollwert: 90.0...98.0 %
046,4,Tastverhältnis,Saugrohrklappe
047,0,Saugrohrklappe II
047,1,Lernwert (geschl.),Saugrohrklappe,Sollwert: 0.4...0.6 V
047,2,Lernwert (offen),Saugrohrklappe
047,3,Tastverhältnis,Saugrohrklappe
047,4,Position (Ist),Saugrohrklappe,Sollwert: 90.0...98.0 %
051,0,Drehzahlerfassung
051,1,Motordrehzahl
051,2,Nockenwellen-,drehzahl,Sollwert: Motordrehzahl/2 = ±50 U/min
051,3,Start-,synchronisation,Siehe Labeldatei
; 000 = Grundinitialisierung
; 001 = Rücksetzen des Zählers
; 002 = Motorstillstand oder Fehlerfall
; 003 = Übergangszustände
; 004 = Plausibilisierungsphase
; 005 = Plausibilisierungsphase
; 006 = Plausibilisierungsphase
; 008 = Plausibilisierungsphase
; 016 = Phasenbestimmung
; 028 = Redundanter Start
; 032 = Synchronisationsphase
; 033 = Positionierung des Systems
; 048 = Berechnungssequenzen aktiviert
; 064 = System wartet auf Motorstillstand
; 128 = Dynamische Plausibilisierung
051,4,Abschaltstatus,Einspritzsequenz
062,0,Motorkühlung (Temperaturen)
062,1,Kühlmitteltemp.,Motoraustritt,Sollwert: mind. 75.0 °C
062,2,Kühlmitteltemp.,Kühleraustritt,Sollwert: mind. 75.0 °C
062,3,Umgebungs-,temperatur,Sollwert: -30.0...+50.0 °C
062,4,Saugrohr-,temperatur,Sollwert: 5.0...80.0 °C
063,0,Motorkühlung (Klimaanlage)
063,1,Kältemitteldruck,,Sollwert (Klima AUS): 0.00...8.00 bar\nSollwert (Klima EIN): 5.00...30.00 bar
063,2,Lastmoment,,Sollwert (Klima AUS): 0 Nm\nSollwert (Klima EIN): 2...10 Nm
063,3,Kühlbedarf
063,4,Abschaltstatus,Klimaanlage,Siehe Labeldatei
064,0,Motorkühlung
064,1,Kühlmittel-,temperatur (G62),Sollwert (Warm): 80.0...110.0 °C
064,2,Kühlmitteltemp.,Kühleraustritt,Sollwert: mind. 75.0 °C
064,3,Ansteuerung,Kühlerlüfter 1,Sollwert (Kühlerlüfter AUS): 9.0...11.0 %\nSollwert (Kühlerlüfter EIN): 11.0...100.0 %
067,0,Partikelfilter (Abgaswerte I)
; Nur während der Regeneration gültig!
; Umgebungsbedingungen: 50-60 km/h / 3. Gang / Drehzahl <= 3000 U/min
067,1,Temperatur vor,Abgasturbolader,Sollwert (10 s nach Regenerationsstart): mind. 690.0 °C
067,2,Temperatur vor,Partikelfilter,Sollwert (30 s nach Regenerationsstart): mind. 400.0 °C
067,3,Druckdifferenz,Partikelfilter
067,4,Offset,Differenzdruck
068,0,Partikelfilter (Abgaswerte II)
068,1,Beladungs-,koeffizient,Sollwert: max. 40.0 %\n\nAb 40.0 % beginnt die Regeneration im Fahrbetrieb.
068,2,Aschemasse,,Sollwert: max. 150.0 g
068,3,Aschelernwert
069,0,Partikelfilter (Regenerationsstatus I)
069,1,Status 1,Regeneration,Siehe Labeldatei
; xxxxxxx1 = Regenerationsunterbrechung (durch Schub, Drehmomentanforderung, Geschw.-Änderung)
069,4,Status 4,Regeneration,Siehe Labeldatei
; xxxxxxx1 = normale thermische Regeneration
; xxxxxx1x = verschärfte thermische Regeneration
070,0,Partikelfilter (Regenerationsstatus II)
070,1,Status 4,Regeneration,Siehe Labeldatei
070,2,Regenerations-,zeit
070,3,Erfolglose,Regenerationen,Sollwert: max. 4
070,4,Erfolreiche,Regenerationen
071,0,Partikelfilter (Nacheinspritzung)
071,1,Motordrehzahl,(G28),Sollwert (Leerlauf): 790...810 U/min\nSollwert (Volllast): 2800...3200 U/min
071,2,Nach-,einspritzmenge,Sollwert: mind. 10.0 mg/Hub
071,3,Förderbeginn,(Nacheinspritz.)
071,4,Förderdauer,(Nacheinspritz.)
073,0,Partikelfilter (Fahrzeugdaten)
073,1,Verbrauch seit,Regeneration
073,2,Strecke seit,Regeneration
073,3,Zeit seit,Regeneration
074,0,Partikelfilter (Abgaswerte III)
074,1,Motordrehzahl,(G28),Sollwert (Leerlauf): 790...810 U/min\nSollwert (Volllast): 2800...3200 U/min
074,2,Temperatur vor,Abgasturbolader,Sollwert (10 s nach Regenerationsstart): mind. 690.0 °C
074,3,Lambdawert,,Wertebereich: 1.000...2.0000
074,4,Einspritzmengen-,offset
075,0,Partikelfilter (Abgaswerte IV)
075,1,Temperatur vor,Abgasturbolader,Sollwert (20 s nach Kaltstart): mind. 100.0 °C
075,2,Temperatur vor,Partikelfilter,Sollwert (20 s nach Kaltstart): 60.0...100.0 °C
075,3,Beladungs-,koeffizient,Sollwert: max. 40.0 %\n\nAb 40.0 % beginnt die Regeneration im Fahrbetrieb.
075,4,Temperatur nach,Partikelfilter,Sollwert: 20.0...60.0 °C
080,0,Erweiterte Steuergerät Identifikation I
081,0,Erweiterte Steuergerät Identifikation II
081,1,Fahrzeug-Ident.,Nummer (FIN)
081,2,Wegfahrsperren,Ident-Nr. (WFS-ID)
082,0,Erweiterte Steuergerät Identifikation III
086,0,EOBD
087,0,EOBD
089,0,EOBD
090,0,EOBD Abgasrückführung I
090,1,Motordrehzahl,(G28),Sollwert (Leerlauf): 790...810 U/min\nSollwert (Volllast): 2800...3200 U/min
090,2,Einspritzmenge,,Sollwert (Leerlauf): 3.0...10.0 mg/Hub\nSollwert (Volllast): 45.0...75.0 mg/Hub
090,3,Abgasrückführung,(Sollwert),Sollwert (Leerlauf): 200.0...350.0 mg/Hub\nSollwert (Volllast): 900.0...1300.0 mg/Hub
090,4,Status,Regelabweichung
091,0,EOBD Abgasrückführung II
110,0,Startersteuerung I
110,1,Status,Klemme 50,Wertebereich: ein/aus
111,0,Startersteuerung II
111,2,Abschalt-,bedingungen
; xxxxxxx1 = Relais Fehler
; xxxxxx1x = P/N bzw. Interlock Signal
111,3,Abschalt-,bedingungen
; xxxxxxx1 = Startabwurfdrehzahl erreicht
; xxxxxx1x = Fahrgeschwindigkeitsschwelle
; xxxxx1xx = Maximale Startzeit glühabhängig
; xxxx1xxx = Maximale Startzeit
; xxx1xxxx = Klemme 15
; xx1xxxxx = Klemme 15 Sperre
; x1xxxxxx = Klemme 50 und 50-Rück
; 1xxxxxxx = Einspurfehlererkennung
111,4,Versorgungs-,spannung,Sollwert: 13.0...15.0 V
125,0,CAN-Datenbus Kommunikation (Antrieb)
125,1,Getriebe,Wertebereich: Getriebe 1/Getriebe 0
125,2,Bremsen,(J104),Wertebereich: ABS 1/ABS 0\nSollwert: ABS 1
125,3,Kombiinstrument,(J285),Wertebereich: Kombi 1/Kombi 0\nSollwert: Kombi 1
125,4,Airbag,(J234),Wertebereich: Airbag 1/Airbag 0\nSollwert: Airbag 1
126,0,CAN-Datenbus Kommunikation (Antrieb)
126,1,Klimaanlage,(J255),Wertebereich: Klima 1/Klima 0
126,3,Bordnetz,(J519),Wertebereich: Elektr. ZE 1/Elektr. ZE 0\nSollwert: Elektr. ZE 1
127,0,CAN-Datenbus Kommunikation (Antrieb)
127,3,Lenksäulen-,elektronik (J527),Wertebereich: El.Zündschl 1/El.Zündschl 0\nSollwert: El.Zündschl 1
128,0,CAN-Datenbus Kommunikation (Antrieb)
128,1,CAN-Gateway,(J533),Wertebereich: Gateway 1/Gateway 0\nSollwert: Gateway 1
; Codierung
C00,Motorelektronik (J623) Codierung
C01,00?0xxx: Zusatzfunktionen
C02,0 = Wartungsintervallverlängerung (WIV) aktiv
C03,5 = Wartungsintervallverlängerung (WIV) inaktiv
C04,
C05,00x0?xx: Antrieb
C06,0 = Frontantrieb
C07,1 = Allradantrieb
C08,
C09,00x0x?x: CAN-Datenbus
C10,+1 = Anti-Blockier-System (ABS)
C11,+2 = Airbag
C12,+4 = Klimaanlage
C13,
C14,00x0xx?: Getriebe
C15,2 = 6-Gang Schaltgetriebe
C16,8 = Direktschaltgetriebe (DSG/02E)
; Codierung-II
L00,Motorelektronik (J623) Codierung-II
L01,11463 = Aktivierung Geschwindigkeitsregelanlage (GRA)
L02,16167 = Deaktivierung Geschwindigkeitsregelanlage (GRA)
L03,21295 = Partikelfilter Notregeneration starten
L04,30605 = Anpassung Abgasdrucksensor (G450) starten
; Anpassung
A001,0,Startmomentabgleich
A001,1,Motordrehzahl,(G28)
A001,2,Startmenge
A001,3,Start-,synchronisation
A001,4,Kühlmittel-,temperatur (G62)
A002,0,Momentenbegrenzung
A002,1,Motordrehzahl,(G28)
A002,2,Begrenzungs-,moment
A002,3,Drehmoment-,begrenzung
A002,4,Rauchbegrenzung
A003,0,Generatorlastabgleich
A003,1,Motordrehzahl,(G28)
A003,2,
;0.0 Nm
A003,3,Motormoment
A003,4,Generatorlast
A004,0,Servopumpenlastabgleich
A005,0,Abgasrückführung
A005,1,Motordrehzahl,(G28)
A005,2,Abgasrückführung,(Sollwert)
A005,3,Abgasrückführung,(Istwert)
A005,4,Ansteuerung,Abgasrückführung
A006,0,Leerlaufdrehzahl
A006,1,Motordrehzahl,(G28)
A006,2,Leerlaufdrehzahl,(Sollwert)
A006,3,Betriebszustand
A006,4,Gaspedalstellung
A007,0,Höchstgeschwindigkeitsbegrenzung
A007,1,Motordrehzahl,(G28)
A007,2,Geschwindigkeit,(Begrenzung)
A007,3,Geschwindigkeit,(Istwert)
A007,5,Höchstgeschwindigkeitsbegrenzung
A007,6,Dert Wert der Höchstgeschwindigkeitsbegrenzung lässt sich nur einmalig und
A007,7,nur nach unten ändern. Danach lässt er sich NICHT mehr nach oben verändern!
A007,8,
A007,9,Benutzen Sie diesen Anpassungskanal nur wenn Sie sich WIRKLICH sicher sind!
A008,0,Kühlmitteltemperaturabgleich
A008,1,Motordrehzahl,(G28)
A008,2,Vorglühzeit
A008,3,Kühlmittel-,temperatur (G62)
A008,4,Glühstatus
A008,5,Kühlmitteltemperaturabgleich
A008,6,Veränderung der Vorglühzeit in
A008,7,Abhängigkeit der Kühlmitteltemperatur.
A009,0,Klimakompressormomentenabgleich
A009,1,Motordrehzahl,(G28)
A009,2,
;0.0 Nm
A009,3,Motormoment
A009,4,Abschaltstatus,Klimaanlage
A012,0,Aschemasseabgleich
A012,1,Motordrehzahl,(G28)
A012,2,Aschemasse
A012,3,Verbrauch seit,Regeneration
A012,4,Strecke seit,Regeneration
A012,5,Aschemasseabgleich
A012,6,Nach dem Tausch des Partikelfilters muss ein Aschemasseabgleich durchgeführt werden und der Wert
A012,7,in diesem Anpassungskanal muss zurück auf "0" (Null) gesetzt werden.
A012,8,
A012,9,Nach dem Tausch des Motorsteuergerätes muss der Aschemasswert aus dem alten Motorsteuergerät übernommen werden.
A012,10,Sollte dies nicht möglich sein berechnen Sie den Wert wie folgt (entnehmen Sie den Durschnittsverbrauch dem
A012,11,Kombiinstrument oder nehmen Sie als Wert ca. 7 l an):
A012,12,Aschemasse = Laufleistung (km) * Durchschnittsverbrauch (liter) * Aschekoeffizient (0,004569 g / liter)
A050,0,Wegfahrsperre (Fahrzeugdaten lernen)
A050,1,Status
A050,5,Wegfahrsperre (Fahrzeugdaten lernen)
A050,6,Geben Sie den WFS-Login des Kombiinstrumentes (ALTER WFS-Login) ein.
A050,7,Danach wird der Lernprozess angestoßen und das neue Motorsteuergerät
A050,8,übernimmt Fahrzeug-Identifizierungs-Nummer (FIN) und Wegfahrsperren
A050,9,Identifikation (WFS-ID) des Fahrzeuges (vom Kombiinstrument).
A050,10,Schalten Sie nach der Anpassung die Zündung für 2 Minuten AUS.
A082,0,Injektor (Zylinder 1)
A082,1,Motordrehzahl,(G28)
A082,5,Injektor (Zylinder 1)
A082,6,Nach dem Wechsel eines Injektors muss dieser an das Motorsteuergerät
A082,7,angepasst werden. Um Fahrverhaltensmängel auszuschließen darf dies
A082,8,nur bei Erneuerung eines Injektors geschehen!
A082,9,
A082,10,Zum Anpassen des neuen Inkektors speichern Sie den Wert "0".
A083,0,Injektor (Zylinder 2)
A083,1,Motordrehzahl,(G28)
A083,5,Injektor (Zylinder 2)
A083,6,Nach dem Wechsel eines Injektors muss dieser an das Motorsteuergerät
A083,7,angepasst werden. Um Fahrverhaltensmängel auszuschließen darf dies
A083,8,nur bei Erneuerung eines Injektors geschehen!
A083,9,
A083,10,Zum Anpassen des neuen Inkektors speichern Sie den Wert "0".
A084,0,Injektor (Zylinder 3)
A084,1,Motordrehzahl,(G28)
A084,5,Injektor (Zylinder 3)
A084,6,Nach dem Wechsel eines Injektors muss dieser an das Motorsteuergerät
A084,7,angepasst werden. Um Fahrverhaltensmängel auszuschließen darf dies
A084,8,nur bei Erneuerung eines Injektors geschehen!
A084,9,
A084,10,Zum Anpassen des neuen Inkektors speichern Sie den Wert "0".
A085,0,Injektor (Zylinder 4)
A085,1,Motordrehzahl,(G28)
A085,5,Injektor (Zylinder 4)
A085,6,Nach dem Wechsel eines Injektors muss dieser an das Motorsteuergerät
A085,7,angepasst werden. Um Fahrverhaltensmängel auszuschließen darf dies
A085,8,nur bei Erneuerung eines Injektors geschehen!
A085,9,
A085,10,Zum Anpassen des neuen Injektors speichern Sie den Wert "0".
A091,0,Wegfahrsperren Status
A091,5,Wegfahrsperren Status
A091,6,0 = Wegfahrsperre nicht angepasst (NEU)
A091,7,1 = Wegfahrsperre abgeschaltet/deaktiviert
A091,8,4 = Wegfahrsperre angepasst (System i.O.)
ARF написал(а):а лейбл для ABF 037 906 024 F не подкинете?
