Admin
Создатель сайта
Команда форума
- Россия, Москва
Доки конечно не читаем...
Для кого делаю...
https://vwts.ru/page10
Volkswagen Golf 3 / Jetta 3: Sunroof, servicing (eng.) Электролюк, обслуживание и ремонт.
Так вода на стойке будет несколько минут. Потом высохнет
Water drain hoses, cleaning
1 - Front water drain hoses
2 - Water drain valve
The front water drain hoses -1- are routed through the A-pillars and terminate between door and A-pillar. Cleaning is done from the sunroof panel opening.
Note:
For cleaning, a locally manufactured tool made from a speedometer inner cable, approx. 2300 mm (7.5 ft.) long is recommended.
1 - Rear water drain hose
2 - Grommet for water drain hose
3 - Water drain valve (USA only)
Rear water drain hoses:
The rear water drain hoses -2- are routed in the C-pillars and terminate at the side behind the bumper cover. Cleaning is done from the lower end of the hose. To do this, the bumper must be removed.
Note:
