Руководство Недодув турбины двигателя AFN
serghuk написал(а):
объясните пожалуйста почему при сбросе газа,когда эбу подает сигнал на сброс давления наддува фактически происходит скачок давления.
Видимо управление пытается что то сделать ,но не может мгновенно.а тут причин может быть несколько :)
seric ниже.
,51.58,3906,850.0,560.0,4.8,50.86,515.0,989.4,1326.0,30.6,51.22,3969,1081.2,1315.8,37.5
,52.66,3738,850.0,645.0,4.8,51.94,590.0,989.4,1581.0,0.0,52.30,3822,1081.2,1662.6,35.5
,53.74,3549,645.0,670.0,4.8,53.02,655.0,989.4,1785.0,0.0,53.38,3612,1071.0,1815.6,33.1
,54.82,3381,330.0,685.0,4.8,54.10,680.0,989.4,1836.0,0.0,54.46,3444,1060.8,1836.0,32.3
,55.90,3192,315.0,670.0,4.8,55.18,680.0,989.4,1815.6,0.0,55.54,3255,1050.6,1795.2,32.3
,56.98,3024,305.0,660.0,4.8,56.26,675.0,989.4,1764.6,0.0,56.62,3087,1050.6,1744.2,32.3
,58.06,2877,295.0,665.0,4.8,57.34,665.0,989.4,1703.4,0.0,57.70,2940,1040.4,1693.2,32.3
,59.14,2730,285.0,675.0,4.8,58.42,665.0,989.4,1672.8,0.0,58.78,2793,1030.2,1662.6,32.3
,60.22,2583,275.0,685.0,4.8,59.50,675.0,989.4,1662.6,0.0,59.86,2646,1020.0,1662.6,32.3
,61.30,2457,265.0,680.0,4.8,60.58,680.0,989.4,1642.2,0.0,60.94,2520,1020.0,1642.2,32.3
,62.38,2331,260.0,670.0,4.8,61.66,675.0,989.4,1611.6,0.0,62.02,2373,1009.8,1601.4,32.3
,63.46,2226,255.0,655.0,4.8,62.74,670.0,989.4,1560.6,0.0,63.10,2268,1009.8,1550.4,32.3
,64.54,2100,250.0,630.0,4.8,63.82,640.0,989.4,1509.6,0.0,64.18,2142,999.6,1499.4,32.3
,65.62,2016,250.0,610.0,4.8,64.90,635.0,989.4,1468.8,0.0,65.26,2058,999.6,1448.4,32.3
,66.70,1911,250.0,585.0,4.8,65.98,605.0,989.4,1417.8,0.0,66.34,1953,999.6,1397.4,32.3
,67.78,1827,250.0,555.0,4.8,67.06,580.0,989.4,1366.8,0.0,67.42,1848,999.6,1356.6,31.9
,68.86,1722,250.0,540.0,4.8,68.14,555.0,989.4,1315.8,0.0,68.50,1764,999.6,1305.6,31.1
,69.94,1617,250.0,525.0,4.8,69.22,530.0,989.4,1275.0,0.0,69.58,1659,999.6,1254.6,30.7
,71.02,1134,250.0,520.0,4.8,70.30,510.0,989.4,1234.2,0.0,70.66,1575,999.6,1224.0,29.9
,72.10,882,260.0,255.0,62.2,71.38,370.0,989.4,1173.0,0.0,71.74,924,999.6,1122.0,19.9
,73.18,903,260.0,245.0,57.0,72.45,235.0,989.4,1060.8,0.0,72.82,903,999.6,1040.4,19.9
,74.26,903,260.0,250.0,56.6,73.54,265.0,989.4,1020.0,0.0,73.90,903,999.6,1020.0,19.9
,75.33,903,260.0,260.0,56.2,74.62,260.0,989.4,1020.0,0.0,74.98,903,999.6,1009.8,19.9
Эти логи откуда ? А в общем неважно ... обычная езда накатом.
Посмотрите, пожалуйста, AXG, задержка на газ после переключения передачи при разгоне. Лог разгона на 3-й.
Заехал с диагностом на 3-й передаче с холостых на прогретом двигателе:
Saturday,30,April,2011,12:32:36
074 906 018 AJ ,,2.5l R5 EDC G000SG 3908,
,Group A:,'004,,,,Group B:,'008,,,,Group C:,'010
,,Engine Speed,Inj. Timing,Inj. Timing,Inj. Timing,,Engine Speed,Inj. Quantity,Inj. Quantity,Inj. Quantity,,Air Mass,Atmospheric,Intake Manifold,Accelerator pedal
,TIME,,Calculated,Actual,Valve D. Cycle,TIME,,Driver Request,Torque Limitation,Smoke Limitation,TIME,Actual,Pressure,Pressure,Position
MARKER,STAMP, /мин, °BTDC, °BTDC, %,STAMP, /мин, мг/R, мг/R, мг/R,STAMP, мг/R, мБар, мБар,%
,0.63,1367,5.1,7.3,49.0,1.07,1489,12.8,36.8,26.0,1.51,505.0,989.4,1275.0,14.9
,1.89,1489,0.4,2.0,21.1,2.26,1489,1.8,37.0,26.2,2.61,445.0,989.4,1203.6,11.4
,2.99,1326,0.4,0.0,50.6,3.38,877,0.0,28.0,25.8,3.79,305.0,989.4,1111.8,0.0
,4.17,857,0.9,3.1,19.9,4.52,836,1.4,28.0,22.4,4.92,225.0,989.4,1040.4,5.9
,5.29,836,2.2,3.3,19.9,5.64,857,9.4,28.0,21.8,6.05,355.0,989.4,1020.0,8.2
,6.41,877,5.3,3.5,33.5,6.79,898,14.2,28.0,25.2,7.22,465.0,989.4,1040.4,13.3
,7.61,918,0.9,3.5,19.9,8.01,979,33.6,28.0,25.4,8.47,435.0,989.4,1060.8,100.0
,8.87,1020,13.6,12.8,79.3,9.30,1081,35.0,29.2,26.0,9.79,445.0,989.4,1142.4,100.0
,10.24,1204,13.2,13.0,78.1,10.66,1265,37.6,32.4,26.2,11.17,465.0,989.4,1285.2,100.0
,11.54,1408,11.9,12.3,71.3,11.95,1469,41.0,36.4,30.8,12.31,570.0,989.4,1468.8,100.0
,12.66,1591,11.2,11.4,68.1,12.99,1673,44.0,40.6,38.8,13.41,725.0,989.4,1754.4,100.0
,13.78,1836,9.2,10.1,63.4,14.15,1918,46.2,43.0,43.4,14.56,845.0,989.4,2060.4,100.0
,14.93,2142,7.9,7.9,64.1,15.29,2224,47.2,43.0,44.8,15.72,880.0,989.4,1989.0,100.0
,16.08,2448,8.6,8.6,64.1,16.47,2530,47.0,43.0,45.8,16.88,905.0,989.4,2070.6,100.0
,17.27,2734,10.1,9.5,69.7,17.65,2836,46.8,43.0,45.8,18.08,920.0,989.4,1989.0,100.0
,18.47,3040,11.7,12.5,69.7,18.87,3142,46.4,43.0,45.8,19.34,950.0,989.4,2070.6,100.0
,19.78,3346,13.6,14.1,75.3,20.23,3448,46.0,43.0,45.6,20.75,940.0,989.4,2080.8,100.0
,21.22,3672,16.1,15.2,76.5,21.66,3794,45.4,43.0,45.4,22.05,890.0,989.4,2050.2,100.0
,22.41,3958,17.8,18.0,84.9,22.75,4019,45.2,42.8,45.0,23.11,905.0,989.4,2050.2,100.0
,23.47,4162,18.0,18.5,83.7,23.86,4223,44.8,39.6,44.8,24.27,820.0,989.4,1968.6,100.0
,24.65,4345,18.0,17.8,79.7,25.01,4386,44.4,32.2,40.0,25.44,770.0,989.4,1836.0,100.0
,25.80,4488,9.0,17.4,67.3,26.18,3774,0.0,43.0,17.2,26.58,430.0,989.4,1132.2,9.8
,26.97,3101,3.3,6.8,19.9,27.35,2999,8.2,43.0,21.4,27.77,510.0,989.4,1326.0,0.0
,28.18,2958,2.2,0.0,63.4,28.60,2938,0.0,43.0,26.2,29.07,505.0,989.4,1295.4,0.0
логи отсюда http://my-files.ru/hpoq0r не накатом а на включеной третей скорости после разгона с полностью отпущенной педалью.
Прочитайте 2 пост этой темы и сделайте все правильно.
ozzzy24 написал(а):
Скидываю логи и прошу посмотреть что не так. У меня плохой разгон на низких оборотах, нет тяги.
Прочитайте 2 пост этой темы и перепишите логи своих заездов.
Расход воздуха равномерно занижен по факту, отсюда ограничения по дымности в 008 гр. Там по расчётному топлива должно быть в районе 60 мг
Вчера заехал ещё раз, теперь уже правильно, вот логи
Воскресенье,20,Апрель,2014,20:45:48:46766,AVTO Версия: Адаптер VAG 12.12.0,Дата версии: 20140801
074 906 018 AJ,,2.5l R5 EDC G000SG 3908,
,Group A:,'003,,,,Group B:,'010,,,,Group C:,'011
,,Об/мин,Масс.расх/ Rev.,Масс.расх/ Rev.,Нагрузка,,Масс.расх/ Rev.,Абс. давление,Абс. давление,Нагрузка,,Об/мин,Абс. давление,Абс. давление,Нагрузка
,TIME,,,,,TIME,,,,,TIME,,,,
Marker,STAMP, /min, mg/str, mg/str, %,STAMP, mg/str, mbar, mbar, %,STAMP, /min, mbar, mbar, %
,0.00,796,345.0,375.0,57.4,0.34,345.0,999.6,1040.4,7.5,0.71,796,1111.8,1040.4,29.9
,1.02,816,335.0,340.0,58.6,1.37,330.0,999.6,1030.2,7.8,1.70,816,1122.0,1030.2,29.9
,2.05,836,395.0,340.0,60.2,2.40,435.0,999.6,1030.2,16.1,2.72,857,1142.4,1040.4,29.9
,3.09,898,935.0,480.0,4.8,3.42,490.0,999.6,1081.2,100.0,3.75,959,1244.4,1101.6,29.9
,4.11,1020,980.0,490.0,4.8,4.44,485.0,999.6,1152.6,100.0,4.79,1102,1366.8,1183.2,29.9
,5.12,1142,980.0,545.0,4.8,5.46,570.0,999.6,1254.6,100.0,5.79,1244,1489.2,1305.6,22.3
,6.13,1306,980.0,620.0,4.8,6.49,610.0,999.6,1417.8,100.0,6.82,1428,1632.0,1489.2,25.5
,7.17,1408,705.0,540.0,46.2,7.51,500.0,999.6,1244.4,0.0,7.86,1408,1081.2,1142.4,29.9
,8.22,1367,700.0,465.0,24.7,8.54,470.0,999.6,1060.8,0.0,8.89,1306,1081.2,1050.6,29.9
,9.22,1224,700.0,440.0,24.7,9.58,445.0,999.6,1040.4,0.0,9.94,1142,1060.8,1040.4,29.9
,10.26,1102,700.0,440.0,24.7,10.60,445.0,999.6,1040.4,0.0,10.92,1020,1060.8,1040.4,29.9
,11.27,1000,700.0,440.0,24.7,11.60,465.0,999.6,1040.4,0.0,11.93,877,1060.8,1040.4,29.9
,12.29,857,650.0,470.0,24.7,12.62,475.0,999.6,1040.4,0.0,12.99,796,1050.6,1040.4,29.9
,13.32,775,340.0,465.0,24.7,13.67,470.0,999.6,1030.2,0.0,14.00,734,1091.4,1040.4,33.1
,14.33,734,320.0,330.0,60.6,14.69,495.0,999.6,1030.2,0.0,15.02,714,1101.6,1030.2,35.9
,15.37,714,590.0,465.0,24.7,15.70,480.0,999.6,1030.2,0.0,16.05,755,1111.8,1040.4,32.3
,16.40,755,980.0,485.0,4.8,16.72,480.0,999.6,1060.8,100.0,17.09,836,1152.6,1071.0,29.9
,17.40,898,980.0,475.0,4.8,17.75,475.0,999.6,1101.6,100.0,18.10,979,1264.8,1122.0,29.9
,18.42,1000,980.0,485.0,4.8,18.77,500.0,999.6,1152.6,100.0,19.10,1102,1356.6,1173.0,29.9
,19.44,1142,980.0,535.0,4.8,19.79,550.0,999.6,1244.4,100.0,20.12,1265,1499.4,1295.4,22.3
,20.47,1306,980.0,600.0,4.8,20.80,660.0,999.6,1407.6,100.0,21.14,1448,1672.8,1479.0,25.9
,21.49,1510,980.0,735.0,4.8,21.83,780.0,999.6,1672.8,100.0,22.19,1673,1876.8,1785.0,37.9
,22.52,1754,980.0,880.0,4.8,22.87,920.0,999.6,2029.8,100.0,23.20,1938,1989.0,2162.4,59.8
,23.56,2040,980.0,980.0,4.8,23.90,785.0,999.6,1876.8,100.0,24.22,2224,2019.6,1713.6,37.5
,24.59,2326,980.0,775.0,4.8,24.90,840.0,999.6,1744.2,100.0,25.25,2489,2029.8,1836.0,39.0
,25.59,2591,980.0,925.0,4.8,25.92,995.0,999.6,2080.8,100.0,26.29,2795,2040.0,2172.6,53.0
,26.62,2876,980.0,1015.0,4.8,26.95,980.0,999.6,2142.0,100.0,27.29,3060,2040.0,2070.6,51.4
,27.62,3142,980.0,945.0,4.8,27.97,930.0,999.6,2050.2,100.0,28.30,3325,2040.0,2060.4,53.0
,28.64,3407,980.0,945.0,4.8,28.98,930.0,999.6,2070.6,100.0,29.32,3570,2040.0,2060.4,55.0
,29.67,3672,980.0,905.0,4.8,30.00,495.0,999.6,1591.2,0.0,30.34,3611,1122.0,1142.4,35.5
,30.71,3570,700.0,400.0,24.7,31.04,395.0,999.6,999.6,0.0,31.39,3509,1122.0,989.4,35.1
,31.73,3468,700.0,390.0,24.7,32.08,425.0,999.6,999.6,0.0,32.45,3407,1122.0,1009.8,34.7
,32.78,3346,700.0,410.0,24.7,33.12,430.0,999.6,1030.2,0.0,33.47,3284,1122.0,1050.6,34.7
,33.80,3244,700.0,460.0,24.7,34.17,465.0,999.6,1091.4,0.0,34.50,3182,1122.0,1122.0,34.7
,34.85,3142,700.0,500.0,24.7,35.19,500.0,999.6,1162.8,0.0,35.52,3080,1122.0,1183.2,34.7
,35.88,3040,700.0,525.0,24.7,36.20,540.0,999.6,1224.0,0.0,36.56,2958,1122.0,1244.4,34.7
,36.90,2917,700.0,545.0,24.7,37.25,550.0,999.6,1264.8,0.0,37.58,2856,1122.0,1275.0,34.7
,37.92,2836,700.0,560.0,24.7,38.26,550.0,999.6,1275.0,0.0,38.58,2754,1122.0,1275.0,34.7
,38.95,2713,700.0,555.0,24.7,39.27,550.0,999.6,1264.8,0.0,39.62,2652,1122.0,1264.8,33.9
,39.97,2611,700.0,540.0,24.7,40.29,565.0,999.6,1264.8,0.0,40.66,2550,1122.0,1254.6,33.1
,41.00,2509,700.0,545.0,24.7,41.32,545.0,999.6,1244.4,0.0,41.68,2448,1122.0,1244.4,32.3
,41.99,2428,700.0,545.0,24.7,42.34,545.0,999.6,1244.4,0.0,42.68,2366,1122.0,1244.4,31.9
,43.00,2346,700.0,545.0,24.7,43.36,560.0,999.6,1234.2,0.0,43.71,2285,1122.0,1234.2,31.5
,44.05,2264,700.0,545.0,24.7,44.39,550.0,999.6,1234.2,0.0,44.71,2203,1122.0,1234.2,31.5
,45.06,2162,700.0,550.0,24.7,45.39,555.0,999.6,1224.0,0.0,45.74,2101,1111.8,1224.0,31.1
,46.09,2081,700.0,550.0,24.7,46.40,545.0,999.6,1224.0,0.0,46.76,2040,1111.8,1213.8,31.1
,47.09,1999,700.0,545.0,24.7,47.46,535.0,999.6,1203.6,0.0,47.81,1938,1101.6,1193.4,30.7
,48.14,1918,700.0,545.0,24.7,48.48,540.0,999.6,1193.4,0.0,48.81,1877,1101.6,1183.2,30.7
,49.16,1836,700.0,535.0,24.7,49.51,525.0,999.6,1173.0,0.0,49.84,1795,1101.6,1162.8,30.7
,50.20,1754,700.0,525.0,24.7,50.54,520.0,999.6,1162.8,0.0,50.87,1714,1101.6,1152.6,30.3
,51.24,1673,700.0,520.0,24.7,51.58,530.0,999.6,1142.4,0.0,51.92,1612,1091.4,1142.4,30.3
,52.26,1591,700.0,515.0,24.7,52.63,500.0,999.6,1132.2,0.0,52.96,1530,1091.4,1122.0,29.9
,53.29,1530,700.0,500.0,24.7,53.64,495.0,999.6,1111.8,0.0,53.97,1448,1091.4,1111.8,29.9
,54.32,1448,700.0,485.0,24.7,54.68,495.0,999.6,1101.6,0.0,54.99,1367,1081.2,1091.4,29.9
,55.34,1367,700.0,480.0,24.7,55.67,480.0,999.6,1091.4,0.0,56.01,1306,1081.2,1081.2,29.9
,56.35,1265,700.0,480.0,24.7,56.67,460.0,999.6,1081.2,0.0,57.04,1224,1071.0,1071.0,29.9
,57.37,1183,700.0,480.0,24.7,57.72,455.0,999.6,1071.0,0.0,58.06,1142,1071.0,1060.8,29.9
,58.39,1102,700.0,455.0,24.7,58.76,455.0,999.6,1060.8,0.0,59.09,1040,1060.8,1050.6,29.9
,59.46,1020,700.0,460.0,24.7,59.79,465.0,999.6,1050.6,0.0,60.12,959,1050.6,1050.6,29.9
,60.48,918,700.0,465.0,24.7,60.79,475.0,999.6,1040.4,0.0,61.14,877,1050.6,1040.4,29.9
,61.47,816,575.0,495.0,24.7,61.80,475.0,999.6,1040.4,0.0,62.16,775,1060.8,1040.4,29.9
,62.49,775,220.0,470.0,43.0,62.84,365.0,999.6,1040.4,0.0,63.20,734,1091.4,1030.2,34.3
,63.51,734,430.0,480.0,4.8,63.86,485.0,999.6,1030.2,0.0,64.20,755,1101.6,1040.4,30.7
,64.52,775,220.0,275.0,70.9,64.88,215.0,999.6,1030.2,0.0,65.21,775,1101.6,1020.0,29.9
progrommist, в чём, по Вашему может быть дело? Расходомер?
И ещё вылазит переодически ошибка 17656 регулирование опережения впрыска, диапазон регулирование p1248 - 35-10
Добрый день. Упала тяга на низких оборотах. Прошу помочь.
,,Engine speed,MAF (specified),MAF (actual),EGR duty cycle,,Mass Air Flow,Barometric,Manifold ,Position,,Engine speed,Specified MAP,Actual MAP,Duty cycle
,TIME,861-945,240-340,240-340,4-84,TIME,,Pressure,Pressure,Throttle,TIME,,,,Boost Valvle
MARKER,STAMP, /мин, мг/R, мг/R, %,STAMP, мг/R, мБар, мБар,%,STAMP, /мин, мБар, мБар, %
,1.10,924,260.0,512.1,49.8,0.03,512.1,989.4,989.4,0.0,0.57,924,928.2,989.4,91.6
,2.76,945,360.0,518.7,19.9,1.66,525.4,979.2,989.4,20.8,2.22,882,1295.4,1020.0,54.2
,4.36,1533,270.0,548.6,49.8,3.29,515.4,989.4,1020.0,0.0,3.80,924,928.2,999.6,58.6
,6.02,1659,850.0,718.2,4.8,4.92,542.0,989.4,1040.4,21.2,5.45,1575,1795.2,1091.4,35.9
,7.68,2079,850.0,788.0,4.8,6.56,784.7,979.2,1489.2,100.0,7.12,1932,1876.8,1560.6,34.7
,9.10,2457,850.0,791.4,4.8,8.20,788.0,989.4,1570.8,100.0,8.73,2331,1856.4,1570.8,35.1
,10.20,2709,850.0,768.1,4.8,9.46,784.7,979.2,1581.0,100.0,9.83,2625,1836.0,1570.8,34.7
,11.31,2940,850.0,748.1,4.8,10.55,758.1,979.2,1570.8,100.0,10.94,2877,1836.0,1570.8,34.7
,12.41,3171,850.0,744.8,4.8,11.68,754.8,979.2,1581.0,100.0,12.04,3087,1836.0,1591.2,34.7
,13.64,3402,850.0,734.8,4.8,12.83,738.2,989.4,1581.0,100.0,13.26,3318,1825.8,1581.0,34.7
,14.75,3612,850.0,721.5,4.8,14.01,734.8,989.4,1581.0,100.0,14.38,3549,1825.8,1570.8,34.7
,16.09,3801,850.0,714.9,4.8,15.10,731.5,989.4,1581.0,100.0,15.57,3738,1815.6,1591.2,34.7
,17.77,4053,850.0,691.6,4.8,16.64,708.2,989.4,1591.2,98.8,17.20,3969,1795.2,1591.2,34.7
,19.42,3906,850.0,515.4,4.8,18.32,522.0,989.4,1417.8,0.0,18.86,3990,1142.4,1305.6,63.8
,21.08,3675,850.0,515.4,4.8,19.96,515.4,989.4,1275.0,0.0,20.52,3759,1111.8,1275.0,91.2
,22.72,3465,315.0,515.4,4.8,21.62,515.4,989.4,1244.4,0.0,22.18,3528,1091.4,1234.2,91.6
,24.36,3255,255.0,515.4,4.8,23.26,515.4,989.4,1224.0,0.0,23.80,3318,1081.2,1213.8,91.2
,26.00,3066,255.0,515.4,4.8,24.91,518.7,989.4,1203.6,0.0,25.46,3129,1071.0,1193.4,91.6
,27.30,2898,250.0,518.7,4.8,26.54,515.4,989.4,1183.2,0.0,26.92,2961,1060.8,1183.2,91.2
,28.44,2793,250.0,528.7,4.8,27.69,518.7,989.4,1173.0,0.0,28.06,2814,1050.6,1173.0,91.6
,29.60,2667,245.0,538.6,4.8,28.83,532.0,989.4,1162.8,0.0,29.21,2709,1050.6,1152.6,91.2
,30.87,2541,245.0,545.3,4.8,29.99,538.6,989.4,1152.6,0.0,30.48,2583,1040.4,1142.4,91.2
,32.26,2415,245.0,545.3,4.8,31.36,548.6,989.4,1142.4,0.0,31.72,2457,1030.2,1142.4,91.6
,33.43,2310,245.0,555.3,4.8,32.72,548.6,989.4,1132.2,0.0,33.08,2352,1020.0,1132.2,91.6
,34.55,2205,245.0,545.3,4.8,33.79,555.3,989.4,1122.0,0.0,34.15,2247,1020.0,1122.0,91.2
,36.16,2079,245.0,552.0,4.8,35.06,548.6,989.4,1111.8,0.0,35.61,2142,1009.8,1101.6,91.6
,37.81,1953,245.0,545.3,4.8,36.72,545.3,989.4,1091.4,0.0,37.27,1995,999.6,1091.4,91.2
,39.48,1827,245.0,538.6,4.8,38.37,542.0,979.2,1091.4,0.0,38.92,1869,989.4,1081.2,91.6
,41.15,1701,245.0,545.3,4.8,40.04,545.3,989.4,1071.0,0.0,40.59,1743,979.2,1071.0,90.8
Всем привет, давно не заходил.
Гляньте плиз логи, сажевый вырезан + чип, но знакомый говорит как-то слабо едет.... :rolleyes:
http://gfile.ru/a4PPy
Я с чипами не особо :confused:
seric написал(а):
Проверяйте метки и впрыск .
Данные сюда, https://vwts.ru/forum/index.php?showtopic=142169
+1. Тут запрос наддува с низов, видимо ограничен фатальной ошибкой по синхронизации. Топливо дозируется по аварийной карте, кстати по этой портянке, занижение по воздуху незначительно.
Ваш знакомый прав на 100%.
Если все трубочки проверены по схеме и без пробоин, то можно снимать турбину на чистку геометрии.
Я вначале тоже так подумал, но потом посмотрел график чипонутого движка (BMP) и засомневался... я про наличие "острых вершин"
http://www.gerritspeek.nl/fotos/vag-com_log_bmp-b.jpg
Да и к тому же на 1200-1300об клапан №75 отрабатывает более чем на 90%, точно так же как в моих логах.. :unsure:
Вот ваши "анализы". Очень смахивает на голандские. Кстати, запрос по воздуху там не вычисляли.
Я может вначале неправильно выразился, но логи не мои, а знакомого.
Мне просто стало интересно, потому как у самого такой движок только без чипа и с сажевым еще.
На сколько больше воздуха должно быть с чипом?
