здраствуйте,вот в чем проблема,заменили РВ и машина стала тупить и глохнуть при попытке тронуться,как это вылечить и в чем будет ошибка?помогите пожалуйсто.и как правильно записать лог для диагностики моей проблемы.писал при движении на 3 й передаче при 3000 об.
Friday,22,March,2013,13:35:55
038 906 019 LQ ,,1.9l R4 EDC G001SG 1594,
Marker,Group A:, Not Running,,,,Group B:,'001,,,,Group C:,'010
,,,,,,,,,,,,,Engine speed,Injected quantity,Spec. Inj. duration,Coolant temp,,MAF,Atmos. pressure,Intake air press.,Throttle
,TIME,,,,,,,,,,,TIME,820-900,3.0-11.0,5-7 °Ck.,80-110°C,TIME,850-1050,sensor -f96-,2000-2200,100%
MARKER,STAMP,,,,,,,,,,,STAMP, /мин, мг/R, CF,°C,STAMP, мг/R, мБар, мБар,%
,,,,,,0.00,1596,21.1,9.2,77.4,0.36,543.9,989.4,1173.0,58.4
,,,,,,0.72,2142,31.6,11.7,77.4,1.09,588.0,989.4,1499.4,0.0
,,,,,,1.44,1659,0.0,-2.6,77.4,1.80,509.6,989.4,1234.2,86.3
,,,,,,2.18,1491,27.2,10.2,77.4,2.53,588.0,989.4,1285.2,100.0
,,,,,,2.87,1743,36.2,13.3,77.4,3.19,754.6,989.4,1570.8,100.0
,,,,,,3.53,2079,48.9,17.9,77.4,3.87,872.2,989.4,2050.2,100.0
,,,,,,4.21,2562,51.9,21.9,77.4,4.53,984.9,989.4,2182.8,85.5
,,,,,,4.87,2709,0.0,1.5,77.4,5.22,671.3,989.4,1713.6,0.0
,,,,,,5.57,1932,53.8,18.4,77.4,5.91,896.7,989.4,2029.8,71.8
,,,,,,6.25,2079,42.3,16.8,77.4,6.60,754.6,989.4,1795.2,0.0
,,,,,,6.96,2226,32.1,13.3,77.4,7.29,705.6,989.4,1632.0,0.0
,,,,,,7.63,2310,28.0,11.7,77.4,7.95,705.6,989.4,1611.6,0.0
,,,,,,8.27,2394,27.7,11.7,77.4,8.61,730.1,989.4,1652.4,0.0
,,,,,,8.93,2499,27.5,11.7,77.4,9.27,759.5,989.4,1734.0,0.0
,,,,,,9.61,2562,27.5,11.7,77.4,9.96,774.2,989.4,1795.2,0.0
,,,,,,10.30,2667,27.5,11.7,77.4,10.68,788.9,989.4,1815.6,0.0
,,,,,,11.04,2751,27.5,12.2,77.4,11.40,793.8,989.4,1836.0,0.0
,,,,,,11.76,2835,28.0,12.2,77.4,12.12,784.0,989.4,1815.6,0.0
,,,,,,12.48,2919,28.0,12.2,77.4,12.84,779.1,989.4,1774.8,0.0
,,,,,,13.20,3003,28.3,12.2,77.4,13.56,769.3,989.4,1774.8,0.0
,,,,,,13.92,3087,22.0,9.2,77.4,14.28,681.1,989.4,1601.4,0.0
,,,,,,14.64,3108,15.9,5.1,77.4,15.00,612.5,989.4,1448.4,0.0
,,,,,,15.36,3108,11.3,3.1,77.4,15.72,563.5,989.4,1315.8,0.0
,,,,,,16.05,3108,8.0,1.5,77.4,16.37,548.8,989.4,1254.6,0.0
,,,,,,16.71,3066,6.9,1.0,77.4,17.05,568.4,989.4,1305.6,0.0
,,,,,,17.37,3045,5.2,0.5,77.4,17.71,573.3,989.4,1326.0,0.0
,,,,,,18.05,3024,4.4,0.0,77.4,18.39,583.1,989.4,1346.4,0.0
,,,,,,18.71,2982,4.1,0.0,77.4,19.05,588.0,989.4,1366.8,0.0
,,,,,,19.37,2940,5.8,1.0,77.4,19.69,588.0,989.4,1366.8,0.0
,,,,,,20.03,2919,4.9,0.5,77.4,20.35,578.2,989.4,1356.6,0.0
,,,,,,20.67,2898,5.5,0.5,77.4,21.01,578.2,989.4,1346.4,0.0
,,,,,,21.33,2856,7.1,1.5,77.4,21.68,803.6,989.4,1560.6,0.0
,,,,,,22.04,2940,28.0,12.2,77.4,22.40,739.9,989.4,1683.0,0.0
,,,,,,22.76,3003,25.0,10.7,77.4,23.12,690.9,989.4,1632.0,0.0
,,,,,,23.48,3066,16.5,5.1,77.4,23.86,612.5,989.4,1448.4,0.0
,,,,,,24.22,3066,10.2,2.6,77.4,24.58,553.7,989.4,1295.4,0.0
,,,,,,24.94,3045,7.4,1.0,77.4,25.27,558.6,989.4,1264.8,0.0
,,,,,,25.59,3024,8.0,1.0,77.4,25.93,573.3,989.4,1315.8,0.0
,,,,,,26.25,3003,9.1,2.0,77.4,26.59,597.8,989.4,1366.8,0.0
,,,,,,26.93,2982,9.3,2.0,77.4,27.28,602.7,989.4,1397.4,0.0
,,,,,,27.63,2982,9.3,2.0,77.4,27.99,607.6,989.4,1397.4,0.0
,,,,,,28.36,2982,10.2,2.0,77.4,28.72,578.2,989.4,1356.6,0.0
,,,,,,29.08,2961,10.2,2.6,77.4,29.44,568.4,989.4,1285.2,0.0
,,,,,,29.78,2961,10.4,2.6,77.4,30.11,568.4,989.4,1295.4,0.0
,,,,,,30.43,2961,10.4,2.6,77.4,30.77,568.4,989.4,1305.6,0.0
,,,,,,31.11,2961,10.4,2.6,77.4,31.45,568.4,989.4,1295.4,0.0
,,,,,,31.77,2961,10.4,2.6,77.4,32.11,568.4,989.4,1295.4,0.0
,,,,,,32.45,2961,10.4,2.6,77.4,32.77,563.5,989.4,1295.4,0.0
,,,,,,33.11,2961,10.2,2.6,77.4,33.47,563.5,989.4,1285.2,0.0
,,,,,,33.84,2961,9.9,2.6,77.4,34.22,558.6,989.4,1275.0,0.0
,,,,,,34.58,2982,9.3,2.0,77.4,34.96,553.7,989.4,1264.8,0.0
,,,,,,35.32,2982,8.8,2.0,77.4,35.68,548.8,989.4,1254.6,0.0
,,,,,,36.04,2961,8.0,1.5,77.4,36.40,573.3,989.4,1305.6,0.0
,,,,,,36.76,2961,8.0,1.5,77.4,37.12,583.1,989.4,1346.4,0.0
,,,,,,37.48,2961,8.5,1.5,77.4,37.84,597.8,989.4,1377.0,0.0
,,,,,,38.20,2961,9.1,2.0,77.4,38.56,607.6,989.4,1397.4,0.0
,,,,,,38.91,2940,9.3,2.0,77.4,39.25,607.6,989.4,1397.4,0.0
,,,,,,39.59,2940,9.1,2.0,77.4,39.91,607.6,989.4,1397.4,0.0
,,,,,,40.25,2940,9.1,2.0,77.4,40.57,607.6,989.4,1397.4,0.0
,,,,,,40.91,2940,9.3,2.0,77.4,41.25,607.6,989.4,1397.4,0.0
,,,,,,41.57,2940,9.6,2.6,77.4,41.89,602.7,989.4,1407.6,0.0
,,,,,,42.23,2940,9.6,2.0,77.4,42.55,612.5,989.4,1407.6,0.0
,,,,,,42.89,2940,9.6,2.0,77.4,43.23,612.5,989.4,1407.6,0.0
,,,,,,43.55,2940,9.9,2.0,77.4,43.87,612.5,989.4,1407.6,0.0
,,,,,,44.19,2940,9.6,2.0,77.4,44.51,607.6,989.4,1407.6,0.0
,,,,,,44.85,2940,9.6,2.6,77.4,45.18,612.5,989.4,1407.6,0.0
,,,,,,45.54,2940,9.6,2.0,77.4,45.90,607.6,989.4,1407.6,0.0
,,,,,,46.24,2940,9.3,2.0,77.4,46.62,612.5,989.4,1407.6,0.0
,,,,,,46.98,2940,9.1,2.0,77.4,47.34,612.5,989.4,1407.6,0.0
,,,,,,47.70,2940,9.6,2.0,77.4,48.06,607.6,989.4,1407.6,0.0
,,,,,,48.39,2940,9.6,2.0,77.4,48.74,612.5,989.4,1407.6,0.0
,,,,,,49.09,2940,10.2,2.6,77.4,49.45,588.0,989.4,1377.0,0.0
,,,,,,49.82,2940,9.9,2.6,77.4,50.18,558.6,989.4,1285.2,0.0
,,,,,,50.54,2919,10.2,2.6,77.4,50.90,558.6,989.4,1285.2,0.0
