Снял лог разгона, не знаю правильно ли, не судите строго....
данные ниже
Суббота,08,Сентябрь,2018,11:57:42:10463,ВАСЯ Версия: диагност 11.11.2,Версия данных: 20120130
03G 906 016 HS,,R4 2.0L EDC G000SG 9673,
,Group A:,'001,,,,Group B:,'010,,,,Group C:,'011
,,Engine Speed,Injection Quantity,Injection Duration,Coolant,,Mass Air Flow,Atmospheric,Boost Pressure,Accel. Pedal Pos.,,Engine Speed,Boost Pressure,Boost Pressure,Charge Pressure
,TIME,(G28),,(specified),Temperature (G62),TIME,(actual),Pressure,(actual),Sensor 1 (G79),TIME,(G28),(specified),(actual),Control Duty Cycle
Marker,STAMP, /min, мг/ул,°KW,°C,STAMP, мг/ул, mbar, mbar, %,STAMP, /min, mbar, mbar, %
,0.26,882,4.1,7.1,86.4,0.42,285.0,958.8,958.8,0.0,0.10,882,1020.0,958.8,77.7
,0.74,882,3.8,7.1,86.4,0.89,315.0,958.8,958.8,0.0,0.56,882,1020.0,958.8,77.7
,1.20,882,4.1,7.1,86.4,1.38,310.0,958.8,958.8,0.0,1.05,882,1020.0,958.8,77.7
,1.69,1323,22.5,10.2,86.4,1.84,415.0,958.8,948.6,25.1,1.53,987,1203.6,958.8,80.5
,2.17,1764,12.1,8.7,86.4,2.33,410.0,958.8,1060.8,28.2,2.02,1764,1326.0,989.4,60.4
,2.66,1680,18.1,9.7,86.4,2.81,475.0,958.8,1142.4,26.3,2.48,1701,1458.6,1091.4,60.4
,3.12,1617,20.9,10.2,86.4,3.30,520.0,958.8,1203.6,25.9,2.97,1617,1530.0,1173.0,60.4
,3.61,1554,23.1,10.7,86.4,3.76,560.0,958.8,1254.6,24.7,3.45,1596,1530.0,1234.2,60.4
,4.08,1596,25.0,11.7,86.4,4.24,610.0,958.8,1326.0,36.1,3.93,1491,1570.8,1275.0,75.4
,4.57,1932,25.8,11.7,86.4,4.72,600.0,958.8,1458.6,49.4,4.39,1827,1774.8,1366.8,70.6
,5.03,2247,23.9,10.2,86.4,5.21,715.0,958.8,1530.0,66.7,4.88,2079,1642.2,1509.6,60.4
,5.52,2583,21.7,9.7,86.4,5.67,605.0,958.8,1723.8,64.3,5.36,2478,1744.2,1662.6,46.6
,6.00,2856,12.9,4.1,86.4,6.16,600.0,958.8,1662.6,0.0,5.85,2793,1642.2,1764.6,34.3
,6.49,2352,1.6,1.0,86.4,6.63,535.0,958.8,1336.2,40.0,6.31,2583,1040.4,1468.8,58.0
,6.94,2163,37.9,15.3,86.4,7.12,995.0,958.8,1581.0,72.2,6.79,2205,2284.8,1336.2,74.6
,7.43,2058,49.7,19.9,86.4,7.58,1055.0,958.8,1978.8,82.7,7.27,2016,2499.0,1713.6,67.5
,7.91,2415,51.3,21.9,86.4,8.07,1275.0,958.8,2529.6,63.1,7.76,2289,2499.0,2162.4,39.1
,8.40,2730,40.6,18.4,86.4,8.55,1250.0,958.8,2601.0,58.0,8.22,2625,2397.0,2601.0,30.4
,8.86,3045,39.0,17.9,86.4,9.04,1080.0,958.8,2295.0,57.3,8.71,2919,2295.0,2519.4,27.2
,9.35,3297,32.7,14.8,86.4,9.50,1005.0,958.8,2142.0,49.0,9.19,3213,2203.2,2244.0,33.5
,9.83,3339,7.1,-1.0,86.4,9.99,640.0,958.8,1662.6,0.0,9.68,3423,1846.2,2070.6,21.3
,10.31,2625,0.0,0.0,86.4,10.47,600.0,958.8,1295.4,9.4,10.14,2919,1040.4,1468.8,50.5
,10.77,2289,11.3,6.6,86.4,10.95,455.0,958.8,1254.6,32.2,10.62,2289,1285.2,1285.2,60.4
,11.26,2331,33.5,14.3,86.4,11.41,870.0,958.8,1509.6,68.2,11.10,2373,2162.4,1264.8,73.8
,11.74,2478,52.7,22.9,86.4,11.90,1275.0,958.8,2274.6,67.1,11.59,2415,2499.0,1734.0,56.4
,12.23,2625,50.0,22.4,86.4,12.38,1275.0,958.8,2601.0,61.6,12.05,2562,2499.0,2560.2,29.2
,12.69,2772,42.5,19.4,86.4,12.87,1220.0,958.8,2539.8,56.9,12.54,2709,2386.8,2601.0,27.6
,13.17,2898,40.9,18.9,86.4,13.33,1175.0,958.8,2437.8,56.1,13.02,2856,2335.8,2499.0,30.8
,13.65,3024,39.0,17.9,87.3,13.81,1125.0,958.8,2356.2,55.7,13.50,2961,2295.0,2407.2,31.6
,14.14,3108,26.6,11.2,87.3,14.29,865.0,958.8,2182.8,0.0,13.96,3087,2254.2,2325.6,31.2
,14.60,2541,0.3,0.0,87.3,14.78,645.0,958.8,1448.4,0.0,14.45,2793,1040.4,1785.0,53.3
,15.09,2121,12.1,7.1,87.3,15.24,525.0,958.8,1275.0,37.3,14.93,2037,1101.6,1377.0,60.4
,15.57,2352,37.1,15.8,87.3,15.73,985.0,958.8,1693.2,60.8,15.42,2352,2213.4,1336.2,73.8
,16.06,2415,43.6,18.9,87.3,16.21,1270.0,958.8,2407.2,49.4,15.88,2394,2448.0,1948.2,46.9
,16.52,2457,29.1,13.3,87.3,16.70,760.0,958.8,2080.8,43.9,16.37,2436,2080.8,2539.8,16.2
,17.00,2520,33.8,15.3,87.3,17.15,1095.0,958.8,2070.6,47.1,16.85,2499,2152.2,1897.2,60.8
,17.48,2562,34.6,15.8,87.3,17.64,1200.0,958.8,2346.0,44.3,17.34,2541,2244.0,2172.6,43.0
,17.97,2604,25.5,11.7,87.3,18.12,810.0,958.8,2091.0,31.4,17.79,2604,2070.6,2376.6,24.5
,18.43,2625,23.3,10.2,87.3,18.61,820.0,958.8,1540.2,43.9,18.28,2604,1550.4,1774.8,31.2
,18.92,2667,27.7,12.2,87.3,19.07,1115.0,958.8,2111.4,38.0,18.76,2646,2029.8,1723.8,47.3
,19.40,2667,21.1,9.2,87.3,19.56,675.0,958.8,1652.4,29.4,19.25,2667,1744.2,2121.6,15.0
,19.89,2688,12.4,5.1,87.3,20.03,620.0,958.8,1428.0,15.3,19.71,2688,1479.0,1550.4,46.6
,20.34,2667,1.9,0.0,87.3,20.52,520.0,958.8,1285.2,6.7,20.19,2646,1111.8,1377.0,56.8
,20.83,2625,1.1,0.0,87.3,20.98,465.0,958.8,1193.4,6.3,20.67,2646,1081.2,1244.4,57.2
,21.31,2604,1.1,0.0,87.3,21.47,430.0,958.8,1142.4,8.6,21.16,2604,1071.0,1173.0,57.6
,21.80,2562,2.2,0.5,87.3,21.95,420.0,958.8,1122.0,8.2,21.62,2583,1111.8,1132.2,58.4
,22.26,2541,1.4,0.5,87.3,22.63,405.0,958.8,1101.6,0.4,22.11,2541,1091.4,1111.8,59.2
,22.87,1995,0.0,3.6,86.4,23.05,525.0,958.8,1122.0,0.0,22.71,2226,1040.4,1091.4,60.4
,23.35,1386,0.0,5.6,86.4,23.68,450.0,958.8,1071.0,0.0,23.19,1596,1030.2,1111.8,60.4
,23.99,819,5.5,7.7,86.4,24.14,390.0,958.8,1030.2,0.0,23.83,861,1030.2,1060.8,78.1
,24.47,882,4.1,7.1,86.4,24.63,355.0,958.8,1009.8,0.0,24.32,882,1030.2,1020.0,78.1
,24.96,861,4.1,7.7,86.4,25.11,340.0,958.8,999.6,0.0,24.78,882,1020.0,999.6,77.7
,25.42,861,4.1,7.1,86.4,25.60,330.0,958.8,979.2,0.0,25.27,861,1030.2,989.4,78.5
,25.91,861,3.8,7.7,86.4,26.06,340.0,958.8,979.2,0.0,25.75,861,1030.2,979.2,78.5
,26.39,861,4.4,7.1,86.4,26.54,335.0,958.8,979.2,0.0,26.24,861,1030.2,979.2,78.9
,26.87,861,4.7,7.7,86.4,27.02,330.0,958.8,969.0,0.0,26.69,861,1030.2,969.0,78.5
,27.34,840,4.9,7.1,86.4,27.51,345.0,958.8,969.0,0.0,27.18,840,1030.2,969.0,79.3
,27.83,882,3.8,7.7,86.4,27.99,335.0,958.8,969.0,0.0,27.68,861,1030.2,969.0,78.5
,28.31,882,3.8,7.1,85.5,28.47,330.0,958.8,969.0,0.0,28.16,861,1030.2,969.0,78.5
,28.81,882,3.6,7.7,85.5,28.97,320.0,958.8,969.0,0.0,28.63,861,1030.2,969.0,78.9
,29.27,882,3.8,7.1,85.5,29.45,330.0,958.8,969.0,0.0,29.13,861,1030.2,969.0,78.5
,29.76,861,4.4,7.7,85.5,29.92,330.0,958.8,969.0,0.0,29.60,882,1030.2,969.0,78.5
,30.25,861,4.4,7.1,85.5,30.40,340.0,958.8,969.0,0.0,30.09,861,1030.2,969.0,78.5
,30.73,861,4.7,7.7,85.5,30.88,330.0,958.8,969.0,0.0,30.55,861,1030.2,969.0,78.5
,31.19,882,4.1,7.1,85.5,31.37,330.0,958.8,969.0,0.0,31.04,882,1030.2,969.0,78.1
,31.68,861,4.9,7.7,85.5,31.83,330.0,958.8,969.0,0.0,31.52,882,1030.2,969.0,78.5
,32.16,861,4.1,7.1,85.5,32.32,335.0,958.8,969.0,0.0,32.01,882,1030.2,969.0,78.5
,32.65,882,3.8,7.7,85.5,32.80,330.0,958.8,969.0,0.0,32.47,882,1030.2,969.0,78.1
,33.10,882,3.8,7.1,84.6,33.28,315.0,958.8,969.0,0.0,32.95,882,1030.2,969.0,77.7
,33.59,861,4.7,7.7,84.6,33.74,320.0,958.8,969.0,0.0,33.43,861,1030.2,969.0,78.5
,34.07,882,4.1,7.1,84.6,34.23,330.0,958.8,969.0,0.0,33.92,882,1030.2,969.0,78.1
,34.56,882,3.8,7.7,84.6,34.71,325.0,958.8,969.0,0.0,34.38,882,1030.2,969.0,78.1
,35.02,882,4.4,7.1,84.6,35.20,320.0,958.8,969.0,0.0,34.87,882,1020.0,969.0,77.7
,35.51,882,4.1,7.7,84.6,35.66,335.0,958.8,969.0,0.0,35.35,861,1030.2,969.0,78.9
,35.98,882,3.8,7.1,84.6,36.14,320.0,958.8,969.0,0.0,35.84,882,1030.2,969.0,78.1
,36.47,882,3.8,7.7,84.6,36.62,315.0,958.8,969.0,0.0,36.29,882,1030.2,969.0,78.5
,36.93,882,4.4,7.1,84.6,37.11,320.0,958.8,969.0,0.0,36.78,861,1030.2,969.0,78.5
,37.42,882,4.4,7.7,84.6,37.57,320.0,958.8,969.0,0.0,37.26,861,1030.2,969.0,78.5
,37.90,882,4.1,7.1,84.6,38.06,320.0,958.8,969.0,0.0,37.75,882,1030.2,969.0,78.1
,38.39,882,3.8,7.1,84.6,38.54,315.0,958.8,969.0,0.0,38.21,861,1030.2,969.0,78.5
,38.85,882,4.1,7.1,84.6,39.03,305.0,958.8,969.0,0.0,38.70,882,1030.2,969.0,78.1
,39.33,861,4.1,7.7,84.6,39.48,325.0,958.8,969.0,0.0,39.18,882,1030.2,969.0,78.1
,39.81,882,3.3,7.1,84.6,39.97,300.0,958.8,969.0,0.0,39.66,882,1030.2,969.0,78.5
,40.30,882,3.6,7.1,84.6,40.45,315.0,958.8,969.0,0.0,40.12,882,1030.2,969.0,78.1
,40.76,861,4.1,7.1,84.6,40.94,305.0,958.8,969.0,0.0,40.61,882,1030.2,969.0,78.1
,41.25,861,4.7,7.7,83.7,41.40,300.0,958.8,969.0,0.0,41.09,861,1030.2,969.0,78.1
,41.73,861,4.1,7.1,83.7,41.89,300.0,958.8,969.0,0.0,41.58,861,1030.2,969.0,78.1
,42.22,882,3.8,7.1,83.7,42.36,315.0,958.8,969.0,0.0,42.04,882,1030.2,969.0,78.5
,42.67,882,4.1,7.1,83.7,42.85,300.0,958.8,969.0,0.0,42.53,882,1030.2,969.0,78.1
,43.16,861,4.4,7.7,83.7,43.31,315.0,958.8,969.0,0.0,43.00,861,1030.2,969.0,78.5
,43.64,882,4.1,7.1,83.7,43.80,305.0,958.8,969.0,0.0,43.49,882,1030.2,969.0,78.1
,44.13,882,3.8,7.1,83.7,44.28,310.0,958.8,969.0,0.0,43.95,882,1030.2,969.0,78.1
,44.59,861,4.4,7.7,83.7,44.77,300.0,958.8,969.0,0.0,44.44,882,1030.2,969.0,78.1
,45.08,945,14.0,8.2,83.7,45.23,380.0,958.8,958.8,10.2,44.92,840,1030.2,969.0,78.9
,45.55,1911,7.1,7.1,83.7,45.71,305.0,958.8,979.2,16.1,45.40,1617,1152.6,969.0,60.4
,46.04,2604,6.6,2.0,83.7,46.19,370.0,958.8,1050.6,19.6,45.86,2352,1224.0,999.6,60.4
,46.50,2877,17.8,6.6,83.7,46.68,610.0,958.8,1264.8,54.9,46.35,2919,1428.0,1091.4,58.8
,46.99,3066,42.5,19.9,83.7,47.14,1220.0,958.8,2111.4,62.4,46.83,2982,2386.8,1458.6,63.1
,47.47,3297,35.1,16.3,83.7,47.63,1050.0,958.8,2356.2,23.1,47.32,3234,2274.6,2397.0,19.3
,47.96,3066,0.5,-1.0,82.8,48.11,655.0,958.8,1468.8,0.0,47.78,3234,1050.6,2040.0,46.2
,48.42,2268,7.4,4.6,82.8,48.60,635.0,958.8,1295.4,41.2,48.27,2520,1040.4,1366.8,59.6
,48.90,2289,39.0,15.8,82.8,49.05,1010.0,958.8,1723.8,78.4,48.75,2247,2397.0,1366.8,74.2
,49.38,2415,62.0,26.0,82.8,49.54,1275.0,958.8,2509.2,74.9,49.23,2373,2499.0,1948.2,42.2
,49.87,2604,55.7,25.0,82.8,50.02,1235.0,958.8,2590.8,66.3,49.69,2541,2499.0,2601.0,26.4
,50.33,2751,48.6,22.4,82.8,50.51,1165.0,958.8,2346.0,64.7,50.18,2688,2478.6,2478.6,37.9
,50.82,2898,47.2,21.9,82.8,50.97,1175.0,958.8,2335.8,64.3,50.66,2835,2448.0,2325.6,40.2
,51.30,3024,46.7,21.9,82.8,51.46,1180.0,958.8,2366.4,63.9,51.15,3003,2427.6,2346.0,38.7
,51.78,3150,44.2,20.9,82.8,51.93,1160.0,958.8,2376.6,61.6,51.61,3108,2397.0,2376.6,37.1
,52.24,3255,40.4,19.4,81.9,52.42,1125.0,958.8,2335.8,52.9,52.09,3234,2325.6,2366.4,33.9
,52.73,3045,0.0,-1.0,81.9,52.88,685.0,958.8,1662.6,0.0,52.57,3129,1152.6,2305.2,46.9
,53.21,2457,15.1,6.6,81.9,53.37,760.0,958.8,1417.8,49.8,53.05,2457,1071.0,1499.4,60.4
,53.70,2499,48.0,21.4,81.0,53.85,1275.0,958.8,2162.4,69.8,53.52,2478,2417.4,1591.2,65.9
,54.16,2562,55.2,24.5,81.0,54.34,1275.0,958.8,2601.0,69.8,54.01,2520,2499.0,2468.4,27.2
,54.65,2625,51.1,22.9,81.0,54.80,1205.0,958.8,2519.4,64.3,54.49,2604,2499.0,2601.0,30.4
,55.12,2688,49.4,22.4,81.0,55.29,1170.0,958.8,2386.8,68.6,54.98,2667,2468.4,2458.2,39.1
,55.61,2772,52.7,24.0,80.1,55.76,1215.0,958.8,2448.0,68.2,55.44,2751,2499.0,2397.0,36.3
,56.07,2835,51.6,24.0,80.1,56.25,1210.0,958.8,2478.6,66.7,55.93,2814,2499.0,2458.2,35.1
,56.56,2898,46.7,21.9,80.1,56.71,1175.0,958.8,2448.0,59.6,56.40,2877,2437.8,2478.6,36.3
,57.04,2961,41.7,19.4,80.1,57.20,1130.0,958.8,2356.2,57.6,56.89,2940,2346.0,2417.4,35.5
,57.53,3003,40.4,18.9,79.2,57.68,1095.0,958.8,2295.0,51.4,57.35,2982,2325.6,2335.8,36.3
,57.99,3045,35.4,15.8,79.2,58.17,1050.0,958.8,2193.0,52.5,57.84,3045,2203.2,2264.4,35.9
,58.47,2940,0.0,-0.5,79.2,58.62,685.0,958.8,1754.4,0.0,58.32,3066,2060.4,2182.8,13.0
,58.95,2163,0.0,2.0,79.2,59.11,570.0,958.8,1397.4,4.7,58.80,2394,1040.4,1570.8,60.4
,59.44,2394,19.5,8.7,79.2,59.59,725.0,958.8,1305.6,44.7,59.26,1890,1336.2,1326.0,60.4
,59.90,2310,42.5,17.3,78.3,60.08,1100.0,958.8,1948.2,74.1,59.75,2310,2376.6,1499.4,73.0
,60.39,2352,59.3,24.0,78.3,60.54,1275.0,958.8,2601.0,69.8,60.23,2352,2499.0,2213.4,33.9
,60.87,2394,51.9,21.9,78.3,61.03,1145.0,958.8,2550.0,62.7,60.72,2373,2499.0,2601.0,29.6
,61.36,2415,45.8,19.9,78.3,61.51,1070.0,958.8,2346.0,54.1,61.18,2415,2458.2,2468.4,41.4
,61.81,2457,40.1,17.9,78.3,61.98,1045.0,958.8,2223.6,49.0,61.67,2436,2366.4,2284.8,46.6
,62.30,2457,32.9,15.3,78.3,62.45,975.0,958.8,2121.6,33.7,62.14,2457,2274.6,2193.0,45.8
,62.78,2373,0.5,1.0,77.4,62.94,630.0,958.8,1601.4,0.0,62.63,2436,1234.2,2040.0,4.7
,63.27,1680,0.0,5.1,77.4,63.42,515.0,958.8,1326.0,0.0,63.09,1911,1030.2,1499.4,60.4
,63.73,1092,0.0,5.6,77.4,63.90,450.0,958.8,1162.8,0.0,63.58,1302,1030.2,1264.8,60.4
,64.22,882,5.2,7.7,77.4,64.37,435.0,958.8,1091.4,0.0,64.06,882,1030.2,1132.2,78.5
,64.70,903,3.8,7.1,77.4,64.86,435.0,958.8,1050.6,0.0,64.55,924,1030.2,1071.0,77.7
,65.18,882,4.4,7.1,77.4,65.33,425.0,958.8,1030.2,0.0,65.00,903,1020.0,1040.4,77.7
,65.64,882,3.8,7.7,77.4,65.82,425.0,958.8,1020.0,0.0,65.49,882,1020.0,1030.2,77.7
,66.13,882,3.8,7.1,77.4,66.28,405.0,958.8,1009.8,0.0,65.97,882,1030.2,1009.8,78.1
,66.61,882,4.4,7.7,77.4,66.77,395.0,958.8,999.6,0.0,66.46,882,1030.2,1009.8,78.5
,67.10,882,4.7,7.1,77.4,67.25,390.0,958.8,999.6,0.0,66.92,882,1030.2,999.6,78.5
,67.56,861,4.7,7.7,77.4,67.73,375.0,958.8,989.4,0.0,67.41,882,1030.2,999.6,78.1
,68.04,882,4.4,7.1,77.4,68.19,365.0,958.8,989.4,0.0,67.88,882,1030.2,989.4,78.5
,68.52,882,3.8,7.7,76.5,68.68,375.0,958.8,989.4,0.0,68.37,882,1030.2,989.4,78.5
,69.01,882,3.8,7.1,76.5,69.16,365.0,958.8,979.2,0.0,68.83,882,1030.2,989.4,78.1
,69.47,882,4.1,7.7,76.5,69.65,355.0,958.8,979.2,0.0,69.32,882,1030.2,979.2,78.1
,69.96,882,4.1,7.1,76.5,70.11,345.0,958.8,979.2,0.0,69.80,882,1030.2,979.2,78.1
,70.44,882,4.1,7.7,76.5,70.60,370.0,958.8,979.2,0.0,70.29,882,1030.2,979.2,78.1
,70.93,861,4.4,7.1,76.5,71.08,345.0,958.8,979.2,0.0,70.75,882,1030.2,979.2,78.5
,71.39,882,4.1,7.7,76.5,71.56,360.0,958.8,979.2,0.0,71.23,882,1030.2,979.2,78.5
,71.87,882,4.1,7.1,76.5,72.02,355.0,958.8,979.2,0.0,71.71,861,1030.2,979.2,78.9
,72.35,882,4.1,7.7,76.5,72.51,345.0,958.8,969.0,0.0,72.20,882,1030.2,979.2,78.5
,72.84,882,4.1,7.1,76.5,72.99,350.0,958.8,969.0,0.0,72.66,861,1030.2,969.0,78.9
,73.30,882,3.6,7.7,76.5,73.48,345.0,958.8,969.0,0.0,73.15,882,1030.2,969.0,78.5
,73.79,882,4.1,7.1,76.5,73.94,345.0,958.8,969.0,0.0,73.63,882,1030.2,969.0,78.9
,74.26,882,4.4,7.1,76.5,74.42,330.0,958.8,969.0,0.0,74.10,882,1030.2,969.0,78.1
,74.75,882,4.1,7.1,76.5,74.90,340.0,958.8,969.0,0.0,74.57,882,1030.2,969.0,78.1
,75.21,882,3.8,7.1,76.5,75.39,335.0,958.8,969.0,0.0,75.06,882,1030.2,969.0,78.5
,75.70,882,4.1,7.1,76.5,75.85,330.0,958.8,969.0,0.0,75.54,882,1030.2,969.0,78.1
,76.18,882,4.7,7.7,77.4,76.34,350.0,958.8,969.0,0.0,76.03,882,1030.2,969.0,78.5
,76.66,861,4.7,7.7,77.4,76.82,325.0,958.8,969.0,0.0,76.49,882,1030.2,969.0,78.1
,77.13,882,4.4,7.1,77.4,77.31,330.0,958.8,969.0,0.0,76.98,882,1030.2,969.0,78.1
,77.62,882,4.4,7.7,77.4,77.76,330.0,958.8,969.0,0.0,77.46,882,1030.2,969.0,78.1
,78.09,882,4.4,7.1,77.4,78.25,330.0,958.8,969.0,0.0,77.94,882,1030.2,969.0,78.5
,78.58,882,4.4,7.7,77.4,78.73,325.0,958.8,969.0,0.0,78.40,882,1030.2,969.0,78.5
,79.04,882,4.7,7.1,77.4,79.22,330.0,958.8,969.0,0.0,78.89,882,1030.2,969.0,78.5
,79.53,861,4.7,7.7,77.4,79.68,335.0,958.8,969.0,0.0,79.37,882,1030.2,969.0,78.1
,80.01,882,4.4,7.1,77.4,80.17,320.0,958.8,969.0,0.0,79.86,882,1030.2,969.0,78.5
,80.50,882,3.8,7.7,77.4,80.65,330.0,958.8,969.0,0.0,80.32,882,1030.2,969.0,78.5
,80.96,882,4.1,7.1,77.4,81.13,325.0,958.8,969.0,0.0,80.81,882,1030.2,969.0,78.5
,81.44,882,4.4,7.7,77.4,81.59,330.0,958.8,969.0,0.0,81.28,882,1030.2,969.0,78.5
,81.92,882,4.7,7.1,77.4,82.08,300.0,958.8,969.0,0.0,81.77,882,1030.2,969.0,78.1
,82.41,861,5.2,7.7,77.4,82.56,330.0,958.8,969.0,0.0,82.23,861,1030.2,969.0,78.5
,82.87,861,4.9,7.1,77.4,83.05,315.0,958.8,969.0,0.0,82.72,861,1030.2,969.0,78.9
,83.36,861,4.4,7.7,77.4,83.51,320.0,958.8,969.0,0.0,83.20,882,1030.2,969.0,78.5
,83.84,882,3.6,7.1,77.4,84.00,295.0,958.8,969.0,0.0,83.69,882,1030.2,969.0,78.1
,84.33,882,4.1,7.7,77.4,84.47,320.0,958.8,969.0,0.0,84.14,882,1030.2,969.0,78.1
,84.78,882,4.4,7.1,77.4,84.96,315.0,958.8,969.0,0.0,84.63,882,1030.2,969.0,78.1
,85.27,882,4.1,7.7,78.3,85.42,315.0,958.8,969.0,0.0,85.11,882,1030.2,969.0,78.5
,85.75,861,4.4,7.1,78.3,85.91,315.0,958.8,969.0,0.0,85.60,882,1030.2,969.0,78.1
,86.24,882,4.1,7.1,78.3,86.39,310.0,958.8,969.0,0.0,86.06,861,1030.2,969.0,78.5
,86.70,882,4.1,7.1,78.3,86.88,325.0,958.8,969.0,0.0,86.55,882,1030.2,969.0,78.9
,87.19,861,4.4,7.7,78.3,87.33,310.0,958.8,969.0,0.0,87.03,861,1030.2,969.0,78.9
,87.66,882,4.1,7.1,78.3,87.81,310.0,958.8,969.0,0.0,87.51,882,1030.2,969.0,78.5
