seric написал(а):
Проверяйте тандемный насос и кольца НФ.
Данные гр 05\1 до запуска мотора огласите ( двиг. теплый/ горячий )
Почитайте эту тему
https://vwts.ru/forum/index.php?showtopic=120438
в этой теме разговор о том что стартер крутит долго, у меня не долго, мотор схватывает с 1-2х оборотов и глохнет.
я сделал ЛОГ пятой группы
Суббота,12,Январь,2013,12:26:17
038 906 019 AT,,1.9l R4 EDC 0000SG 1575,
,Group A:,'005,,,,Group B:, Не запущено,,,,Group C:, Не запущено
,,Engine speed,Start inj,Start synchro.,Coolant temp,,,,,,,,,,
,TIME,rpm,quantity,,°C,TIME,,,,,TIME,,,,
Marker,STAMP, /min, мг/ул,,°C,STAMP,,,,,STAMP,,,,
,0.51,0,0.0,0.0,56.7,,,,,,,,,,
,1.05,0,0.0,0.0,56.7,,,,,,,,,,
,1.47,0,19.5,0.0,56.7,,,,,,,,,,
,1.84,231,19.5,1.0,55.8,,,,,,,,,,
,2.20,609,16.2,1.0,55.8,,,,,,,,,,
,2.57,609,15.9,1.0,55.8,,,,,,,,,,
,2.94,567,16.5,1.0,55.8,,,,,,,,,,
,3.30,525,0.0,1.0,55.8,,,,,,,,,,
,3.66,147,0.0,0.0,55.8,,,,,,,,,,
,4.02,0,0.0,0.0,55.8,,,,,,,,,,
,4.38,0,22.0,0.0,55.8,,,,,,,,,,
,4.74,0,23.6,0.0,55.8,,,,,,,,,,
,5.11,0,25.0,0.0,55.8,,,,,,,,,,
,25.59,0,0.0,0.0,56.7,,,,,,,,,,
ЗАГЛОХ-запуск через 15 сек
,26.07,0,0.0,0.0,56.7,,,,,,,,,,
,26.60,0,0.0,0.0,55.8,,,,,,,,,,
,27.14,504,18.1,1.0,55.8,,,,,,,,,,
,27.68,588,16.2,1.0,55.8,,,,,,,,,,
,28.22,525,16.7,1.0,55.8,,,,,,,,,,
,28.76,315,0.0,1.0,55.8,,,,,,,,,,
,29.31,63,0.0,0.0,55.8,,,,,,,,,,
,45.37,0,0.0,0.0,57.6,,,,,,,,,,
ЗАГЛОХ-запуск через 25 сек
,45.89,0,0.0,0.0,57.6,,,,,,,,,,
,46.44,0,0.0,0.0,56.7,,,,,,,,,,
,47.00,210,19.5,0.0,56.7,,,,,,,,,,
,47.54,630,15.9,1.0,56.7,,,,,,,,,,
,48.09,588,16.2,1.0,56.7,,,,,,,,,,
,48.45,567,0.0,1.0,56.7,,,,,,,,,,
,48.82,378,0.0,0.0,56.7,,,,,,,,,,
,49.19,126,0.0,0.0,56.7,,,,,,,,,,
,49.56,0,22.2,0.0,56.7,,,,,,,,,,
,49.92,0,23.9,0.0,56.7,,,,,,,,,,
,63.17,0,0.0,0.0,57.6,,,,,,,,,,
,63.52,0,0.0,0.0,57.6,,,,,,,,,,
ЗАГЛОХ-запуск через 60 сек
,63.89,0,0.0,0.0,57.6,,,,,,,,,,
,64.27,0,0.0,0.0,57.6,,,,,,,,,,
,64.64,0,0.0,0.0,57.6,,,,,,,,,,
,65.08,0,0.0,0.0,57.6,,,,,,,,,,
,65.57,210,19.5,1.0,57.6,,,,,,,,,,
,65.93,567,16.7,1.0,57.6,,,,,,,,,,
,66.28,609,15.9,1.0,57.6,,,,,,,,,,
,66.63,546,16.7,1.0,56.7,,,,,,,,,,
,67.00,672,0.0,1.0,56.7,,,,,,,,,,
,67.37,357,0.0,0.0,56.7,,,,,,,,,,
,67.73,84,0.0,0.0,56.7,,,,,,,,,,
,68.09,84,22.2,0.0,56.7,,,,,,,,,,
,68.45,84,23.6,0.0,56.7,,,,,,,,,,
,68.82,0,25.3,0.0,56.7,,,,,,,,,,
,69.19,0,26.6,0.0,56.7,,,,,,,,,,
Захлох - запуск через 45 сек примерно
Суббота,12,Январь,2013,12:28:24
,0.01,0,0.0,0.0,54.9,,,,,,,,,,
,0.55,0,0.0,0.0,54.9,,,,,,,,,,
,1.09,0,0.0,0.0,54.9,,,,,,,,,,
,1.64,0,0.0,0.0,54.9,,,,,,,,,,
,2.00,0,19.5,0.0,54.9,,,,,,,,,,
,2.36,588,16.5,1.0,54.9,,,,,,,,,,
,2.72,588,16.5,1.0,54.9,,,,,,,,,,
,3.08,609,16.5,1.0,54.9,,,,,,,,,,
,3.44,735,14.8,1.0,54.9,,,,,,,,,,
,3.80,945,12.6,1.0,54.9,,,,,,,,,,
,4.16,966,12.6,1.0,54.9,,,,,,,,,,
,4.52,924,12.6,1.0,54.9,,,,,,,,,,
,4.88,882,12.6,1.0,54.9,,,,,,,,,,
,5.24,882,12.6,1.0,54.9,,,,,,,,,,
,5.61,903,12.6,1.0,54.9,,,,,,,,,,
,5.97,903,12.6,1.0,54.9,,,,,,,,,,
,6.33,903,12.6,1.0,54.9,,,,,,,,,,
ЗАВЕЛСЯ-непонятно мне
Заглушил
Опять запуск через 30сек
Суббота,12,Январь,2013,12:29:52
,1.64,210,19.5,1.0,54.9,,,,,,,,,,
,2.18,672,15.4,1.0,54.9,,,,,,,,,,
,2.66,966,12.6,1.0,54.9,,,,,,,,,,
,3.02,945,12.6,1.0,54.9,,,,,,,,,,
,3.38,924,12.6,1.0,54.9,,,,,,,,,,
,3.74,903,12.6,1.0,54.9,,,,,,,,,,
,4.10,903,12.6,1.0,54.9,,,,,,,,,,
,4.47,903,12.6,1.0,54.9,,,,,,,,,,
Заглушил
Суббота,12,Январь,2013,12:32:34
,0.02,0,0.0,0.0,59.4,,,,,,,,,,
,0.36,0,0.0,0.0,59.4,,,,,,,,,,
,0.72,0,0.0,0.0,59.4,,,,,,,,,,
,1.08,0,0.0,0.0,59.4,,,,,,,,,,
,1.44,0,19.2,0.0,59.4,,,,,,,,,,
,1.80,588,16.2,1.0,59.4,,,,,,,,,,
,2.16,798,14.0,1.0,59.4,,,,,,,,,,
,2.52,966,12.4,1.0,59.4,,,,,,,,,,
,2.88,966,12.4,1.0,59.4,,,,,,,,,,
,3.24,882,12.4,1.0,59.4,,,,,,,,,,
,3.61,903,12.4,1.0,59.4,,,,,,,,,,
,3.97,882,12.4,1.0,59.4,,,,,,,,,,
,4.33,903,12.4,1.0,59.4,,,,,,,,,,
,4.69,903,12.4,1.0,59.4,,,,,,,,,,
,5.07,903,12.4,1.0,59.4,,,,,,,,,,
Заглушил
Опять запуск через 15сек
,235.15,0,0.0,0.0,66.6,,,,,,,,,,
,235.51,0,0.0,0.0,66.6,,,,,,,,,,
,235.88,0,0.0,0.0,66.6,,,,,,,,,,
,236.25,0,18.7,0.0,66.6,,,,,,,,,,
,236.61,525,16.5,1.0,66.6,,,,,,,,,,
,236.97,567,15.9,1.0,66.6,,,,,,,,,,
,237.33,609,15.4,1.0,66.6,,,,,,,,,,
,237.70,588,15.6,1.0,66.6,,,,,,,,,,
,238.06,378,0.0,0.0,66.6,,,,,,,,,,
,238.42,147,0.0,0.0,66.6,,,,,,,,,,
,238.78,0,20.9,0.0,65.7,,,,,,,,,,
,239.14,0,22.2,0.0,65.7,,,,,,,,,,
,239.51,0,23.6,0.0,65.7,,,,,,,,,,
,239.87,0,25.3,0.0,65.7,,,,,,,,,,
,240.23,0,26.6,0.0,65.7,,,,,,,,,,
,240.57,0,28.0,0.0,66.6,,,,,,,,,,
,240.93,0,29.4,0.0,66.6,,,,,,,,,,
,241.28,0,30.7,0.0,66.6,,,,,,,,,,
,241.62,0,32.1,0.0,66.6,,,,,,,,,,
,241.97,0,33.5,0.0,66.6,,,,,,,,,,
,242.34,0,34.9,0.0,66.6,,,,,,,,,,
,242.70,0,36.5,0.0,66.6,,,,,,,,,,
,243.09,0,37.9,0.0,66.6,,,,,,,,,,
,243.56,0,39.3,0.0,66.6,,,,,,,,,,
,244.10,0,41.2,0.0,66.6,,,,,,,,,,
,244.65,0,43.4,0.0,66.6,,,,,,,,,,
,245.20,0,45.6,0.0,66.6,,,,,,,,,,
,245.74,0,47.8,0.0,66.6,,,,,,,,,,
,246.29,0,50.0,0.0,66.6,,,,,,,,,,
,246.83,0,18.7,0.0,66.6,,,,,,,,,,
,247.38,0,18.7,0.0,66.6,,,,,,,,,,
,247.93,0,18.7,0.0,66.6,,,,,,,,,,
после того как заглох показания во втором окне поднимаются
Заводим
,263.36,0,0.0,0.0,64.8,,,,,,,,,,
,263.72,0,0.0,0.0,64.8,,,,,,,,,,
,264.09,0,0.0,0.0,64.8,,,,,,,,,,
,264.45,231,18.9,0.0,64.8,,,,,,,,,,
,264.81,567,16.2,1.0,64.8,,,,,,,,,,
,265.18,546,16.2,1.0,64.8,,,,,,,,,,
,265.54,567,15.9,1.0,64.8,,,,,,,,,,
,265.90,567,0.0,1.0,64.8,,,,,,,,,,
,266.26,336,0.0,0.0,64.8,,,,,,,,,,
,266.63,63,0.0,0.0,64.8,,,,,,,,,,
,267.00,63,21.1,0.0,64.8,,,,,,,,,,
,267.36,63,22.5,0.0,64.8,,,,,,,,,,
,284.76,0,0.0,0.0,65.7,,,,,,,,,,
,285.12,0,0.0,0.0,65.7,,,,,,,,,,
,285.55,0,0.0,0.0,65.7,,,,,,,,,,
,286.03,0,0.0,0.0,65.7,,,,,,,,,,
,286.59,189,18.9,0.0,65.7,,,,,,,,,,
,287.14,504,16.5,1.0,65.7,,,,,,,,,,
,287.68,567,15.9,1.0,64.8,,,,,,,,,,
,288.22,441,0.0,1.0,64.8,,,,,,,,,,
,288.76,84,0.0,0.0,64.8,,,,,,,,,,
,289.30,84,21.7,0.0,64.8,,,,,,,,,,
,289.85,0,24.2,0.0,64.8,,,,,,,,,,
И глохнет и глохнет, СТАРТЕР не при чем, АКУМ живее всех живых
Потери мощности не ощущаю, Топлива в масле нет, на запах по крайней мере
Давайте еще сниму логи чего либо) или может что то как то проверить надо!
