03C-906-056-BAG.lbl написал(а):;
; VCDS Label File
; Copyright й 2010+ Ross-Tech, LLC
; Audi A3 (8P) / VW Golf (1K) / VW Touran (1T)
; Component: J623 - Engine (#01) - BAG/BLF/BLP
; P/N: 03C-906-056-???
; includes measuring blocks, basic setting, readiness, coding, coding-II and adaptation
; This file is part of a label file package,
; make sure you have all of the following files.
; 03-01.LBL
; 03C-906-056-BAG.LBL (1.6l SR @ 115 HP - BAG/BLF/BLP)
; created on 21/Nov/2010 by Sebastian Stange (Sebastian@Ross-Tech.com)
; last modificationon on 29/Aug/2011
; requires VCDS 10.6 or newer
; measuring blocks & basic setting
001,0,General
001,1,Engine Speed,(G28),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM
001,2,Coolant,Temperature (G62),Range: -48.0...+143.0 ░C\nSpecification (Warm): 80.0...115.0 ░C
001,3,Lambda Control,Bank 1,Range: -25.0...+25.0 %\nSpecification: -10.0...+10.0 %
001,4,Basic Setting,Requirements,xxxxxxx1 = Coolant Temperature above 80 ░C\nxxxxxx1x = Engine Speed below 2000 RPM\nxxxxx1xx = Throttle Valve closed\nxxxx1xxx = Lambda Control OK\nxxx1xxxx = Idle Switch closed\nxx1xxxxx = Air Conditioning Compressor OFF\nx1xxxxxx = Catalytic Converter above 380 ░C\n1xxxxxxx = No Diagnostic Trouble Codes (DTCs) detected by On Board Diagnostic (OBD)
; xxxxxxx1 = Coolant Temperature above 80 ░C
; xxxxxx1x = Engine Speed below 2000 RPM
; xxxxx1xx = Throttle Valve closed
; xxxx1xxx = Lambda Control OK
; xxx1xxxx = Idle Switch closed
; xx1xxxxx = Air Conditioning Compressor OFF
; x1xxxxxx = Catalytic Converter above 380 ░C
; 1xxxxxxx = No Diagnostic Trouble Codes (DTCs) detected by On Board Diagnostic (OBD)
002,0,General
002,1,Engine Speed,(G28),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM
002,2,Engine Load,,Range: 0.0...100.0 %
002,3,Injection Timing,,Range: 0.0...20.0 ms
002,4,Intake Manifold,Pressure (G71)Specififcation (Engine OFF): ~Athmospheric Pressure
003,0,General
003,1,Engine Speed,(G28),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM
003,2,Intake Manifold,Pressure (G71),Specififcation (Engine OFF): ~Athmospheric Pressure
003,3,Throttle Valve Angle,,Range: 0.0...100.0 %
003,4,Ignition,Timing Angle,Range: -20.0...+50.0 ░BTDC
004,0,General
004,1,Engine Speed,(G28),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM
004,2,Battery Voltage,(Terminal 30),Specification: 11.0...15.0 V
004,3,Coolant,Temperature (G62),Range: -40.5...+135.0 ░C\nSpecification (Warm): 80.0...115.0 ░C
004,4,Intake Air,Temperature (G42),Range: -40.5...+135.0 ░C\nSpecification (Warm): < +80.0 ░C (max. +115.0 ░C)
005,0,General
005,1,Engine Speed,(G28),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM
005,2,Engine Load,,Range: 0.0...100.0 %
005,3,Vehicle Speed,,Range: 0.0...300.0 km/h
005,4,Load Status,,Range: Idle/Partial Throttle/Wide Open Throttle (WOT)/Enrichment/Deceleration
006,0,General
006,1,Engine Speed,(G28),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM
006,2,Engine Load,,Range: 0.0...100.0 %
006,3,Intake Air,Temperature (G42),Range: -40.5...+135.0 ░C\nSpecification (Warm): < +80.0 ░C (max. +115.0 ░C)
006,4,Altitude,Correction Factor,Range: -50.0...+20.0 %\n\n0.0 % = 0 m\n-50.0 % = 5000 m\n+20.0 % = -2000 m
007,0,General
007,1,Engine Speed,(G28),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM
007,2,Engine Load,,Range: 0.0...100.0 %
007,3,Coolant,Temperature (G62),Range: -40.5...+135.0 ░C\nSpecification (Warm): 80.0...115.0 ░C
007,4,Operating Mode,,x00xxxx? = Homogenous (Lambda = 1)\nx00xxx?x = Homogenous (Lean)\nx00xx?xx = Homogenous/Stratified\nx00x?xxx = Stratified\nx00?xxxx = Stratified (CAT Heating)\n?00xxxxx = Knock Protection
008,0,General (Brake System - Automatic Transmission only)
008,1,Brake Pedal,Status,Range: Operated/Not Oper.
008,2,Battery Voltage,(Terminal 30),Specification: 11.0...15.0 V
008,3,Intake Manifold,Pressure (G71)Specififcation (Engine OFF): ~Athmospheric Pressure
008,4,Brake Booster,Pressure
009,0,Service Interval Extension
009,1,Oil Level
009,2,Oil Warning,Threshold
009,3,Fuel Consumption,Signal
009,4,Fuel Consumption,Equivalent
010,0,Ignition
010,1,Engine Speed,(G28),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM
010,2,Engine Load,,Range: 0.0...100.0 %
010,3,Throttle Valve Angle,,Range: 0.0...100.0 %
010,4,Ignition,Timing Angle,Range: -20.0...+50.0 ░BTDC
011,0,Iginition
011,1,Engine Speed,(G28),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM
011,2,Coolant,Temperature (G62),Range: -48.0...+143.0 ░C\nSpecification (Warm): 80.0...115.0 ░C
011,3,Intake Air,Temperature (G42),Range: -48.0...+143.0 ░C\nSpecification (Warm): < +80.0 ░C (max. +115.0 ░C)
011,4,Ignition,Timing Angle,Range: -20.0...+50.0 ░BTDC
014,0,Ignition (Misfire Recognition - Total)
014,1,Engine Speed,(G28),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM
014,2,Engine Load,,Range: 0.0...100.0 %
014,3,Misfire Counter,,Specification: 0
014,4,Misfire,Recognition,Range: Disabled/Enabled
015,0,Ignition (Misfire Recognition - Cylinder 1-3)
015,1,Misfire Counter,Cylinder 1,Specification: 0
015,2,Misfire Counter,Cylinder 2,Specification: 0
015,3,Misfire Counter,Cylinder 3,Specification: 0
015,4,Misfire,Recognition,Range: Active/Disabled
016,0,Ignition (Misfire Recognition - Cylinder 4-6)
016,1,Misfire Counter,Cylinder 4,Specification: 0
016,4,Misfire,Recognition,Range: Active/Disabled
018,0,Ignition (Misfire Recognition - RPM/Load Barriers)
018,1,Lower,RPM Barrier
018,2,Upper,RPM Barrier
018,3,Lower,Load Barrier,Range: 0.0...100.0 %
018,4,Upper,Load Barrier,Range: 0.0...100.0 %
020,0,Ignition (Timing Retardation Cylinder 1-4)
020,1,Timing Retardation,Cylinder 1
020,2,Timing Retardation,Cylinder 2
020,3,Timing Retardation,Cylinder 3
020,4,Timing Retardation,Cylinder 4
022,0,Ignition (Timing Retardation Cylinder 1 && 2)
022,1,Engine Speed,(G28),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM
022,2,Engine Load,,Range: 0.0...100.0 %
022,3,Timing Retardation,Cylinder 1
022,4,Timing Retardation,Cylinder 2
023,0,Ignition (Timing Retardation Cylinder 3 && 4)
023,1,Engine Speed,(G28),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM
023,2,Engine Load,,Range: 0.0...100.0 %
023,3,Timing Retardation,Cylinder 3
023,4,Timing Retardation,Cylinder 4
026,0,Ignition (Knock Control Cylinder 1-4)
026,1,Knock Sensor,Voltage Cylinder 1,Range: 0.0...40.0 V
026,2,Knock Sensor,Voltage Cylinder 2,Range: 0.0...40.0 V
026,3,Knock Sensor,Voltage Cylinder 3,Range: 0.0...40.0 V
026,4,Knock Sensor,Voltage Cylinder 4,Range: 0.0...40.0 V
028,0,Ignition (Knock Sensor Test)
028,1,Engine Speed,(G28),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM
028,2,Engine Load,,Range: 0.0...100.0 %
028,3,Coolant,Temperature (G62),Range: -48.0...+143.0 ░C\nSpecification (Warm): 80.0...115.0 ░C
028,4,Knock Sensor,Test Result,Range: Test ON/Test OFF/Sys. OK/Sys. not OK\nSpecification: Sys. OK
B028,0,Ignition (Knock Sensor Test - Short Trip)
; Firmly press Brake Pedal and Throttle Pedal at once
; Engine Speed increases to 2000 RPM automatically > Field 4 = Test ON
; Wait until Field 4 shows "Sys. OK"
B028,1,Engine Speed,(G28),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM\nSpecification (Basic Setting): ~2200 RPM
B028,2,Engine Load,,Range: 0.0...100.0 %
B028,3,Coolant,Temperature (G62),Range: -48.0...+143.0 ░C\nSpecification (Warm): 80.0...115.0 ░C
B028,4,Knock Sensor,Test Result,Range: Test ON/Test OFF/Sys. OK/Sys. not OK\nSpecification: Sys. OK
030,0,Lambda Control (Sensor Status)
030,1,Bank 1,Sensor 1,1xxxx = Lambda Sensor Control Cyl. 1 active\nx1xxx = Catalytic Converter Venting active\nxx1xx = Lambda Sensor Heating on\nxxx1x = Lambda Sensor ready\nxxxx1 = Lambda Control active
030,2,Bank 1,Sensor 2,1xxx = Lambda Control (P-Portion) active\nx1xx = Lambda Sensor Heating on\nxx1x = Lambda Sensor ready\nxxx1 = Lambda Control (I-Portion) active
031,0,Lambda Control (Lambda Sensor Voltages)
031,1,Lambda Control,Bank 1 (actual)
031,2,Lambda Control,Bank 1 (specified)
032,0,Lambda Control (Mixture Adaptation)
032,1,Adaptation (Idle),Bank 1 Sensor 1,Range: -25.0...+25.0 %\nSpecification: -10.0...+10.0 %
032,2,Adaptation (Partial),Bank 1 Sensor 1,Range: -25.0...+25.0 %\nSpecification: -10.0...+10.0 %
033,0,Lambda Control
033,1,Lambda Control,Bank 1 Sensor 1,Range: -25.0...+25.0 %\nSpecification: -10.0...+10.0 %
033,2,Sensor Voltage,Bank 1 Sensor 1,Range: 0.0...5.0 V
034,0,Lambda Control (Aging Check: Bank 1 Sensor 1)
034,1,Engine Speed,(G28),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM
034,2,Catalytic Converter,Bank 1 Temp.
034,3,Periodic Time,Bank 1 Sensor 1
034,4,Result,Lambda Aging,Range: Test ON/Test OFF/B1-S1 not OK/B1-S1 OK\nSpecification: Test OFF
B034,0,Lambda Control (Aging Check: Bank 1 Sensor 1)
; "Activate" Basic Setting
; Engine Speed increases automatically > Field 4 = Test ON
; Wait until Field 4 shows "B1-S1 OK"
B034,1,Engine Speed,(G28),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM\nSpecification (Basic Setting): ~2200 RPM
B034,2,Catalytic Converter,Bank 1 Temp.
B034,3,Periodic Time,Bank 1 Sensor 1
B034,4,Result,Lambda Aging,Range: Test ON/Test OFF/B1-S1 not OK/B1-S1 OK\nSpecification: B1-S1 OK
036,0,Lambda Control (Sensor Readiness - After Catalyst)
036,1,Sensor Voltage,Bank 1 Sensor 2,Range: 0.0...1.0 V
036,2,Result,Lambda Availability,Range: Test ON/Test OFF/B1-S2 not OK/B1-S2 OK\nSpecification: Test OFF
B036,0,Lambda Control (Sensor Readiness - After Catalyst)
; Wait until Field 4 shows "B1-S2 OK"
B036,1,Sensor Voltage,Bank 1 Sensor 2,Range: 0.0...1.0 V
B036,2,Result,Lambda Availability,Range: Test ON/Test OFF/B1-S2 not OK/B1-S2 OK\nSpecification: B1-S2 OK
037,0,Lambda Control (Delta Lambda Bank 1)
037,1,Engine Load,,Range: 0.0...100.0 %
037,2,Sensor Voltage,Bank 1 Sensor 2,Range: 0.0...1.0 V
037,3,Adjustment,Bank 1 Sensor 2
037,4,Result,Delta Lambda B1,Range: Test ON/Test OFF/B1-S1 OK/B1-S1 n.OK\nSpecification: Test OFF
B037,0,Lambda Control (Delta Lambda Bank 1)
B037,1,Engine Load,,Range: 0.0...100.0 %
B037,2,Sensor Voltage,Bank 1 Sensor 2,Range: 0.0...1.0 V
B037,3,Adjustment,Bank 1 Sensor 2
B037,4,Result,Delta Lambda B1,Range: Test ON/Test OFF/B1-S1 OK/B1-S1 n.OK\nSpecification: B1-S1 OK
041,0,Lambda Control (Lambda Sensor Heating Bank 1)
041,1,Resistance,Bank 1 Sensor 1,Range: 0.0...500.0 Ohms
041,2,Heater Condition,Bank 1 Sensor 1,Range: Htg. S1 OFF/Htg. S1 ON
041,3,Resistance,Bank 1 Sensor 2,Range: 0.0...0.5 kOhms
041,4,Heater Condition,Bank 1 Sensor 2,Range: Htg. S2 OFF/Htg. S2 ON
043,0,Lambda Control (Aging Check: Bank 1 Sensor 2)
043,1,Engine Speed,(G28),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM
043,2,Catalytic Converter,Bank 1 Temp.
043,3,Lambda Voltage,Bank 1 Sensor 2,Range: 0.0...1.0 V
043,4,Lambda Sensor,Aging Test B1S2,Range: Test ON/Test OFF/B1-S2 OK/B1-S2 n.OK\nSpecification: Test OFF
B043,0,Lambda Control (Aging Check: Bank 1 Sensor 2)
B043,1,Engine Speed,(G28),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM\nSpecification (Basic Setting): ~2200 RPM
B043,2,Catalytic Converter,Bank 1 Temp.
B043,3,Lambda Voltage,Bank 1 Sensor 2,Range: 0.0...1.0 V
B043,4,Lambda Sensor,Aging Test B1S2,Range: Test ON/Test OFF/B1-S2 OK/B1-S2 n.OK\nSpecification: B1-S2 OK
046,0,Lambda Control (Catalytic Conversion Test Bank 1)
046,1,Engine Speed,(G28),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM
046,2,Catalytic Converter,Bank 1 Temp.
046,3,Catalytic,Conversion Bank 1
046,4,Cat. Conversion,Test Bank 1,Range: Test ON/Test OFF/CatB1 OK/CatB1 n.OK\nSpecification: CatB1 OK
B046,0,Lambda Control (Catalytic Conversion Test Bank 1)
; Short Trips 034/035/036/037/038/039/043/044 must be OK
; Wait until Field 4 shows "CatB1 OK"
B046,1,Engine Speed,(G28),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM\nSpecification (Basic Setting): ~2200 RPM
B046,2,Catalytic Converter,Bank 1 Temp.
B046,3,Catalytic,Conversion Bank 1
B046,4,Cat. Conversion,Test Bank 1,Range: Test ON/Test OFF/CatB1 OK/CatB1 n.OK\nSpecification: CatB1 OK
048,0,Lambda Control (Catalytic Converter Thermal Diagnosis Bank 1)
048,1,Operating Mode,,x00xxxx? = Homogenous (Lambda = 1)\nx00xxx?x = Homogenous (Lean)\nx00xx?xx = Homogenous/Stratified\nx00x?xxx = Stratified\nx00?xxxx = Stratified (CAT Heating)\n?00xxxxx = Knock Protection
048,2,Number of,Test Steps
048,3,Exothermal,Temp. Increase
048,4,Cat. Conv. Thermal,Test Bank 1,Range: Test ON/Test OFF/Sys. OK/Sys. not OK\nSpecification: Sys. OK
B048,0,Lambda Control (Catalytic Converter Thermal Diagnosis Bank 1)
B048,1,Operating Mode,,x00xxxx? = Homogenous (Lambda = 1)\nx00xxx?x = Homogenous (Lean)\nx00xx?xx = Homogenous/Stratified\nx00x?xxx = Stratified\nx00?xxxx = Stratified (CAT Heating)\n?00xxxxx = Knock Protection
B048,2,Number of,Test Steps
B048,3,Exothermal,Temp. Increase
B048,4,Cat. Conv. Thermal,Test Bank 1,Range: Test ON/Test OFF/Sys. OK/Sys. not OK\nSpecification: Sys. OK
050,0,Idle Speed Stabilization
050,1,Engine Speed,(actual),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM
050,2,Engine Speed,(specified),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM
050,3,A/C Readiness,,Range: A/C-Low / A/C-High
050,4,A/C Compressor,,Range: Compr.OFF/Compr.ON
051,0,Idle Speed Stabilization (Gear shifts)
051,1,Engine Speed,(actual),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM
051,2,Engine Speed,(specified),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM
051,3,Selected Gear,,P or N = 0\nGear = 1 - 6\nR = 7
051,4,Battery Voltage,(Terminal 30),Specification: 11.0...15.0 V
052,0,Idle Speed Stabilization (Window Heating)
052,1,Engine Speed,(actual),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM
052,2,Engine Speed,(specified),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM
052,3,A/C Readiness,,Range: A/C-Low / A/C-High
053,0,Idle Speed Stabilization (Generator Load)
053,1,Engine Speed,(actual),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM
053,2,Engine Speed,(specified),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM
053,3,Battery Voltage,(Terminal 30),Specification: 11.0...15.0 V
053,4,Generator Load,,Range: 0.0...100.0 %
054,0,Idle Speed Stabilization
054,1,Engine Speed,(G28),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM
054,2,Load Status,,Range: Idle/Partial Throttle/Wide Open Throttle (WOT)/Enrichment/Deceleration
054,3,Accel. Pedal Pos.,Sensor 1 (G79),Range: 0.0...100.0 %
054,4,Throttle Valve Angle,,Range: 0.0...100.0 %
055,0,Idle Speed Stabilization
055,1,Engine Speed,(G28),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM
055,2,Idle Regulator
055,3,Idle Stabilization,Self-Adaptation
055,4,Operating,Condition,x0xxx? = A/C Compressor\nx0xx?x = Gear engaged\nx0x?xx = A/C Readiness\nx0?xxx = Rear Window Heater\n?0xxxx = Front Window Heater
056,0,Idle Speed Stabilization
056,1,Engine Speed,(actual),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM
056,2,Engine Speed,(specified),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM
056,3,Idle Regulator
056,4,Operating,Condition,x0xxx? = A/C Compressor\nx0xx?x = Gear engaged\nx0x?xx = A/C Readiness\nx0?xxx = Rear Window Heater\n?0xxxx = Front Window Heater
057,0,Idle Speed Stabilization (Air Condition)
057,1,Engine Speed,(actual),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM
057,2,Engine Speed,(specified),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM
057,3,A/C Compressor,,Range: Compr.OFF/Compr.ON
057,4,A/C Refrigerant,Pressure,Range: 0.0...40.0 bar
060,0,Electronic Throttle (Throttle Body Alignment)
060,1,Throttle Valve,Sensor 1 (G187),Range: 0.0...100.0 %\nSpecification: 3.0...93.0 %
060,2,Throttle Valve,Sensor 2 (G188),Range: 0.0...100.0 %\nSpecification: 97.0...3.0 %
060,3,Throttle Valve,Steps Counter,Range: 0...8\nSpecification: 8
060,4,Throttle Body,Alignment Status,Range: ADP RUN/ADP. O.K./ADP ERROR\nSpecification: ADP. O.K.
B060,0,Throttle Body Alignment
; Wait until Field 4 shows "ADP OK"
B060,1,Throttle Valve,Sensor 1 (G187),Range: 0.0...100.0 %\nSpecification: 3.0...93.0 %
B060,2,Throttle Valve,Sensor 2 (G188),Range: 0.0...100.0 %\nSpecification: 97.0...3.0 %
B060,3,Throttle Adaptation,Steps Counter,Range: 0...8\nSpecification: 8
B060,4,Throttle Body,Alignment Status,Range: ADP RUN/ADP OK/ADP ERROR\nSpecification: ADP OK
061,0,Electronic Throttle
061,1,Engine Speed,(G28),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM
061,2,Battery Voltage,(Terminal 30),Specification: 11.0...15.0 V
061,3,Throttle Valve Angle,,Range: 0.0...100.0 %\nSpecification (Idle): X.X...X.X %
061,4,Operating,Condition,x0xxx? = A/C Compressor\nx0xx?x = Gear engaged\nx0x?xx = A/C Readiness\nx0?xxx = Rear Window Heater\n?0xxxx = Front Window Heater
062,0,Electronic Throttle (Sensor Values)
062,1,Throttle Valve,Sensor 1 (G187),Range: 0.0...100.0 %\nSpecification: 3.0...93.0 %
062,2,Throttle Valve,Sensor 2 (G188),Range: 0.0...100.0 %\nSpecification: 97.0...3.0 %
062,3,Accel. Pedal Pos.,Sensor 1 (G79),Range: 0.0...100.0 %\nSpecification: 12.0...97.0 %
062,4,Accel. Pedal Pos.,Sensor 2 (G185),Range: 0.0...100.0 %\nSpecification: 4.0...49.0 %
063,0,Electronic Throttle (Kick-Down Alignment)
063,1,Accel. Pedal Pos.,Sensor 1 (G79),Range: 0.0...100.0 %\nSpecification: 12.0...97.0 %\nSpecification (Kick-Down): 79.0...94.0 %
063,2,Kick-Down,Alignment Value,Range: 0.0...100.0 %\nSpecification: 79.0...94.0 %
063,3,Kick-Down,Switch,Range: Kick Down
063,4,Kick-Down,Alignment Status,Range: ADP RUN/ADP OK/ADP ERROR\nSpecification: ADP OK
B063,0,Kick-Down Alignment (Automatic Transmission only)
; Press the Accelerator Pedal down to the floor
B063,1,Throttle Position,Sensor (G79),Range: 0.0...100.0 %\nSpecification: 12.0...97.0 %\nSpecification (Kick-Down): 79.0...94.0 %
B063,2,Kick-Down,Alignment Value,Range: 0.0...100.0 %\nSpecification: 79.0...94.0 %
B063,3,Kick-Down,Switch,Range: Kick Down
B063,4,Kick-Down,Alignment Status,Range: ADP RUN/ADP OK/ADP ERROR\nSpecification: ADP OK
064,0,Electronic Throttle (Sensor Adaption Values)
064,1,Lower Adaptation,Sensor 1 (G187),Specification: 0.4...0.6 V
064,2,Lower Adaptation,Sensor 2 (G188),Specification: 4.0...5.0 V
064,3,Emergency Air Gap,Sensor 1 (G187),Specification: 0.5...1.0 V
064,4,Emergency Air Gap,Sensor 2 (G188),Specification: 4.0...5.0 V
065,0,Electronic Throttle
; Relevant for Production Purposes only
065,1,Throttle Valve,Sensor 1 (G187),Range: 0.0...100.0 %\nSpecification: 3.0...93.0 %\nSpecification (Idle): XX.0...XX.0 %
065,2,Throttle Valve,Sensor 2 (G188),Range: 0.0...100.0 %\nSpecification: 97.0...3.0 %\nSpecification (Idle): XX.0...XX.0 %
065,3,Throttle Valve,Steps Counter,Range: 0...8\nSpecification: 8
065,4,Throttle Body,Alignment Status,Range: ADP RUN/ADP. O.K./ADP ERROR\nSpecification: ADP. O.K.
066,0,Electronic Throttle (Cruise Control System)
066,1,Vehicle Speed,(current)
066,2,Switch Positions I,,xxxxxxx? = Brake Light Switch\nxxxxxx?x = Brake Pedal Switch\nxxxxx?xx = Clutch Pedal Switch\nxxxx?xxx = CCS (Cruise Control System) enabled\nxxx?xxxx = ACC (Adaptive Cruise Control) available\nxx?xxxxx = Main Switch engaged\n??xxxxxx = CCS Status
066,3,Vehicle Speed,(specified)
066,4,Switch Positions II,,x0xxxxx? = CCS ON (CAN)\nx0xxxx?x = SET (CCS ON)\nx0xxx?xx = Deceleration (-)\nx0xx?xxx = Acceleration (+)\nx0x?xxxx = SET\nx0?xxxxx = RESUME/RESET\n?0xxxxxx = CCS ON (Hardware Pin)
070,0,Emission Reduction (EVAP Valve Test)
070,1,Evap. Emissions,Sol. Valve (Open),Range: 0.0...100.0 %
070,2,Lambda Control,,Range: -25.0...+25.0 %
070,3,Evap. Emissions,Sol. Valve (Flow)
070,4,EVAP Valve,Test,Range: Test ON/Test OFF/TEV OK/TEV not OK\nSpecification: Test OFF
B070,0,Emission Reduction (EVAP Valve Test)
; Wait until Field 4 shows "TEV OK"
B070,1,Evap. Emissions,Sol. Valve (Open),Range: 0.0...100.0 %
B070,2,Lambda Control,,Range: -25.0...+25.0 %
B070,3,Evap. Emissions,Sol. Valve (Flow)
B070,4,EVAP Valve,Test,Range: Test ON/Test OFF/TEV OK/TEV not OK\nSpecification: TEV OK
074,0,Emission Reduction (Exhaust Gas Recirculation)
074,1,Potentiometer (G212),Zero Position
074,3,Potentiometer (G212),Actual Position
074,4,Potentiometer (G212),Status
B074,0,Exhaust Gas Recirculation (EGR) Valve Alignment
B074,1,Potentiometer (G212),Zero Position
B074,3,Potentiometer (G212),Actual Position
B074,4,Potentiometer (G212),Status,Range: ADP RUN/ADP. O.K./ADP ERROR\nSpecification: ADP. O.K.
075,0,Emission Reduction (Exhaust Gas Recirculation)
;075,1,
;2.3 %,Lambda
075,2,Exh. Gas Recirc,Correction Factor
075,3,Air Mass from,Exh. Gas Recirc.
076,0,Emission Reduction (Exhaust Gas Recirculation)
076,1,Engine Speed,(G28),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM
076,2,Intake Manifold,Pressure (G71),Specififcation (Engine OFF): ~Athmospheric Pressure
076,3,Potentiometer (G212),Opening Angle
076,4,Potentiometer (G212),Duty Cycle
080,0,Advanced Control Module Identification I
080,1,Advanced,Identification I
081,0,Advanced Control Module Identification II
081,1,Vehicle Ident.,Number (VIN)
081,2,Immobilizer,Ident. (IMMO-ID)
082,0,Advanced Control Module Identification III
082,1,Advanced,Identification III
083,0,Advanced Control Module Identification IV
083,1,Primary Vehicle,Ident. Number (VIN)
084,0,Advanced Control Module Identification V
084,1,Advanced,Identification V
086,0,Readiness Code I
086,1,Readiness Bits,,xxxxxxx? = Catalyst(s)\nxxxxxx?x = Catalyst Heating\nxxxxx?xx = EVAP System\nxxxx?xxx = Secondary Air Injection System\nxxx?xxxx = Climate Control\nxx?xxxxx = Oxygen Sensor(s)\nx?xxxxxx = Oxygen Sensor Heating\n?xxxxxxx = Exhaust Gas Recirculation (EGR)\n\n0 = completed\n1 = not completed
086,2,Cycle Flags I,,xxxxxxx? = Catalyst Bank 1\nxxxxxx?x = Catalyst Bank 2\nxxxxx?xx = Leak Diagnostic Pump\nxxxx?xxx = EVAP Valve\nxxx?xxxx = Oxygen Sensor Heater Bank 1 Sensor 1\nxx?xxxxx = Oxygen Sensor Heater Bank 1 Sensor 2\nx?xxxxxx = Oxygen Sensor Heater Bank 2 Sensor 1\n?xxxxxxx = Oxygen Sensor Heater Bank 2 Sensor 2\n\n0 = completed\n1 = not completed
086,3,Cycle Flags II,(Part 1),0xxxxxx? = Bank 1 Sensor 1 elec.\n0xxxxx?x = Bank 1 Sensor 2 elec.\n0xxxx?xx = Bank 1 Sensor 1 (Delta-Lambda Shift)\n0xxx?xxx = Bank 1 Sensor 2 (Sensor Aging)\n0xx?xxxx = Bank 1 Sensor 1 (Period Duration)\n0x?xxxxx = Secondary Air Injection Bank 1\n0?0xxxxx = Secondary Air Injection Bank 2\n\n0 = completed\n1 = not completed
086,4,Cycle Flags II,(Part 2),0xxxxxx? = Bank 2 Sensor 1 elec.\n0xxxxx?x = Bank 2 Sensor 2 elec.\n0xxxx?xx = Bank 2 Sensor 1 (Delta-Lambda Shift)\n0xxx?xxx = Bank 2 Sensor 2 (Sensor Aging)\n0xx?xxxx = Bank 2 Sensor 1 (Period Duration)\n0x?xxxxx = Secondary Air Injection Bank 1\n0?xxxxxx = Secondary Air Injection Bank 2\n\n0 = completed\n1 = not completed
087,0,Readiness and Error Bits
087,1,Readiness Bits,,xxxxxxx? = Catalyst(s)\nxxxxxx?x = Catalyst Heating\nxxxxx?xx = EVAP System\nxxxx?xxx = Secondary Air Injection System\nxxx?xxxx = Climate Control\nxx?xxxxx = Oxygen Sensor(s)\nx?xxxxxx = Oxygen Sensor Heating\n?xxxxxxx = Exhaust Gas Recirculation (EGR)\n\n0 = completed\n1 = not completed
087,2,Error Flags I,,xxxxxxx? = Catalyst Bank 1\nxxxxxx?x = Catalyst Bank 2\nxxxxx?xx = Leak Diagnostic Pump\nxxxx?xxx = EVAP Valve\nxxx?xxxx = Oxygen Sensor Heater Bank 1 Sensor 1\nxx?xxxxx = Oxygen Sensor Heater Bank 1 Sensor 2\nx?xxxxxx = Oxygen Sensor Heater Bank 2 Sensor 1\n?xxxxxxx = Oxygen Sensor Heater Bank 2 Sensor 2\n\n0 = completed\n1 = not completed
087,3,Error Flags II,(Part 1),0xxxxxx? = Bank 1 Sensor 1 elec.\n0xxxxx?x = Bank 1 Sensor 2 elec.\n0xxxx?xx = Bank 1 Sensor 1 (Delta-Lambda Shift)\n0xxx?xxx = Bank 1 Sensor 2 (Sensor Aging)\n0xx?xxxx = Bank 1 Sensor 1 (Period Duration)\n0x?xxxxx = Secondary Air Injection Bank 1\n0?0xxxxx = Secondary Air Injection Bank 2\n\n0 = completed\n1 = not completed
087,4,Error Flags II,(Part 2),0xxxxxx? = Bank 2 Sensor 1 elec.\n0xxxxx?x = Bank 2 Sensor 2 elec.\n0xxxx?xx = Bank 2 Sensor 1 (Delta-Lambda Shift)\n0xxx?xxx = Bank 2 Sensor 2 (Sensor Aging)\n0xx?xxxx = Bank 2 Sensor 1 (Period Duration)\n0x?xxxxx = Secondary Air Injection Bank 1\n0?xxxxxx = Secondary Air Injection Bank 2\n\n0 = completed\n1 = not completed
088,0,Cycle Flags
088,1,Cycle Flags I,,xxxxxxx? = Exhaust Camshaft Bank 2\nxxxxxx?x = Exhaust Camshaft Bank 1\nxxxxx?xx = Intake Camshaft Bank 2\nxxxx?xxx = Intake Camshaft Bank 1\nxxx?xxxx = Knock Sensor 4\nxx?xxxxx = Knock Sensor 3\nx?xxxxxx = Knock Sensor 2\n?xxxxxxx = Knock Sensor 1\n\n0 = completed\n1 = not completed
088,2,Cycle Flags II,,xxxxxxx? = Brake Light Switch\nxxxxxx?x = Clutch Pedal Switch\nxxxxx?xx = Idle Speed Control\nxxxx?xxx = Speed Signal\nxxx?xxxx = Idle Switch\nxx?xxxxx = Coolant Temperature Sensor\nx?xxxxxx = Throttle Valve Potentiometer\n?xxxxxxx = Mass Air Flow Sensor\n\n0 = completed\n1 = not completed
088,3,Cycle Flags III,,xxx0x?00 = Intake Air Temperature Sensor\nxxx0?x00 = Thermostat (only USA)\nxx?0xx00 = Cruise Control Lever\nx?x0xx00 = Oxygen Sensor Control - Adaptation Bank 2\n?xx0xx00 = Oxygen Sensor Control - Adaptation Bank 1\n\n0 = completed\n1 = not completed
089,0,On-Board-Diagnostics (OBD)
089,1,Distance Driven,with MIL on
089,2,Tank Condition,,Range: OK/too low
090,0,Camshaft Adjustment (Intake)
090,1,Engine Speed,(G28),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM
090,2,Cam. Adjustment,Intake Status,Range: Cam Ctrl. ON/Cam Ctrl. OFF
090,3,Cam. Adjustment,Intake B1 (act.)
091,0,Camshaft Adjustment (Bank 1 Intake)
091,1,Engine Speed,(G28),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM
091,2,Cam. Adjustment,Intake Bank 1,Range: 0.0...100.0 %
091,3,Cam. Adjustment,Intake B1 (spec.)
091,4,Cam. Adjustment,Intake B1 (act.)
;093,1,
;114,Count
094,0,Camshaft Adjustment (Intake)
094,1,Cam. Adjustment,Intake B1 (act.)
094,3,Cam. Adj. Test,Bank 1 Intake,Range: Test ON/Test OFF/Syst. OK/Syst. not OK\nSpecification: Syst. not OK
B094,0,Camshaft Adjustment (Intake)
B094,1,Cam. Adjustment,Intake B1 (act.)
B094,3,Cam. Adj. Test,Bank 1 Intake,Range: Test ON/Test OFF/Syst. OK/Syst. not OK\nSpecification: Syst. not OK
099,0,Lambda Control Shut-Off
099,1,Engine Speed,(G28),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM
099,2,Coolant,Temperature (G62),Range: -40.5...+135.0 ░C\nSpecification (Warm): 80.0...115.0 ░C
099,3,Lambda Control,,Range: -25.0...+25.0 %\nSpecification: -10.0...+10.0 %
099,4,Lambda Control,Status,Range: O2-Reg.OFF/O2-Reg.ON
B099,0,Lambda Control Shut-Off
; Wait until Field 4 shows "O2-Reg.OFF"
B099,1,Engine Speed,(G28),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM
B099,2,Coolant,Temperature (G62),Range: -40.5...+135.0 ░C\nSpecification (Warm): 80.0...115.0 ░C
B099,3,Lambda Control,,Range: -25.0...+25.0 %\nSpecification: -10.0...+10.0 %
B099,4,Lambda Control,Status,Range: O2-Reg.OFF/O2-Reg.ON
100,0,Readiness Code
100,1,Readiness Bits,,xxxxxxx? = Catalytic Converter\nxxxxxx?x = Catalytic Converter Heater\nxxxxx?xx = Activated Charcoal System\nxxxx?xxx = Secondary Air Injection (AIR) System\nxxx?xxxx = A/C System\nxx?xxxxx = Oxygen Sensors\nx?xxxxxx = Oxygen Sensor Heating\n?xxxxxxx = Exhaust Gas Recirculation (EGR)
100,2,Coolant,Temperature (G62),Range: -40.5...+135.0 ░C\nSpecification (Warm): 80.0...115.0 ░C
100,3,Time since,Engine Start
100,4,OBD-Status,,xxxx00x? = Warm-Up Cycle not possible\nxxxx00?x = Warm-Up Cycle ended\nxxx?00xx = Malfunction detected (min. 1 Fault)\nxx?x00xx = Trip complete\nx?xx00xx = Driving Cycle detected\n?xxx00xx = MIL ON
101,0,Fuel Injection
101,1,Engine Speed,(G28),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM
101,2,Engine Load,,Range: 0.0...100.0 %
101,3,Injection Timing,,Range: 0.0...20.0 ms
101,4,Intake Manifold,Pressure (G71),Specififcation (Engine OFF): ~Athmospheric Pressure
102,0,Fuel Injection
102,1,Engine Speed,(G28),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM
102,2,Coolant,Temperature (G62),Range: -40.5...+135.0 ░C\nSpecification (Warm): 80.0...115.0 ░C
102,3,Intake Air,Temperature (G42),Range: -40.5...+135.0 ░C\nSpecification (Warm): < +80.0 ░C (max. +115.0 ░C)
102,4,Injection Timing,,Range: 0.0...20.0 ms
103,0,Fuel Injection (Fuel Pump Adaptation)
103,1,Current,Fuel Pressure
103,2,Fuel Pressure,Regulator
103,3,Adaptation Value,elect. Fuel Pump
103,4,Fuel Pump Adapt.,Status,Range: ADP RUN/ADP OK/ADP ERROR\nSpecification: Test OFF
B103,0,Fuel Injection (Fuel Pump Adaptation)
B103,1,Current,Fuel Pressure
B103,2,Fuel Pressure,Regulator
B103,3,Adaptation Value,elect. Fuel Pump
B103,4,Fuel Pump Adapt.,Status,Range: ADP RUN/ADP OK/ADP ERROR\nSpecification: ADP OK
104,0,Fuel Injection (Start Adaption Values)
104,2,Temperature,Adaptation Factor 1
104,3,Temperature,Adaptation Factor 2
104,4,Temperature,Adaptation Factor 3
105,0,Fuel Injection (Cylinder Shut-Off)
105,1,Engine Speed,(G28),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM
105,2,Engine Load,,Range: 0.0...100.0 %
105,3,Coolant,Temperature (G62),Range: -40.5...+135.0 ░C\nSpecification (Warm): 80.0...115.0 ░C
105,4,Status,Cylinder Shut-Off,Range: ON/OFF
106,0,Fuel Injection (Fuel Supply System)
106,1,Fuel Rail,Pressure (actual)
106,2,Electric Fuel,Pump 1/2,Range: ON/OFF
106,4,Fuel Pump,Shut-Off Time
107,0,Fuel Injection (Fuel Supply System)
107,1,Engine Speed,(G28),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM
107,2,Lambda Control,Bank 1,Range: -25.0...+25.0 %\nSpecification: -10.0...+10.0 %
107,4,Result,Lambda Control,Range: Test ON/Test OFF/Syst. OK/Syst. n.OK\nSpecification: Test OFF
B107,0,Fuel Injection (Fuel Supply System)
; Wait until Field 4 shows "Syst. OK"
B107,1,Engine Speed,(G28),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM
B107,2,Lambda Control,Bank 1,Range: -25.0...+25.0 %\nSpecification: -10.0...+10.0 %
B107,4,Result,Lambda Control,Range: Test ON/Test OFF/Syst. OK/Syst. n.OK\nSpecification: Syst. OK
110,0,Load Registration (Load/Full Throttle Enrichment)
110,1,Engine Speed,(G28),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM
110,2,Coolant,Temperature (G62),Range: -40.5...+135.0 ░C\nSpecification (Warm): 80.0...115.0 ░C
110,3,Injection Timing,,Range: 0.0...20.0 ms
110,4,Throttle Valve Angle,,Range: 0.0...100.0 %
112,0,Exhaust Gas Temperature
112,1,Exhaust Gas,Temperature Bank 1
112,2,Enrichment Factor,Sensor Bank 1
113,0,Load Registration (Load/Full Throttle Enrichment)
113,1,Engine Speed,(G28),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM
113,2,Engine Load,,Range: 0.0...100.0 %
113,3,Throttle Valve Angle,,Range: 0.0...100.0 %
113,4,Athmospheric,Pressure,Range: 500.0...1200.0 mbar\nSpecification (Error): ~1020.0 mbar
120,0,Traction Control (ASR)
120,1,Engine Speed,(G28),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM
120,2,Torque specified,by ASR,Range: 0.0...230.0 Nm
120,3,Engine Torque,(actual),Range: 0.0...230.0 Nm
120,4,Traction Control,Status,Specification: ASR OFF/ASR ON
122,0,Transmission
122,1,Engine Speed,(G28),Range: 0...5700 RPM\nSpecification (Idle): 630...730 RPM
122,2,Torque specified,by ASR,Range: 0.0...230.0 Nm
122,3,Engine Torque,(actual),Range: 0.0...230.0 Nm
122,4,Transmission,Status,Range: Torque red./No tor.red.
125,0,CAN-Databus Communication (Powertrain)
125,1,Transmission,Electronics (J217),Range: Transm. 1/Transm. 0\nSpecification: Transm. 1
125,2,Brake Electronics,(J104),Range: ABS 1/ABS 0\nSpecification: ABS 1
125,3,Instrument Cluster,(J285),Range: Instruments 1/Instruments 0\nSpecification: Instruments 1
126,0,CAN-Databus Communication (Powertrain)
126,2,Steering Angle,Sensor (G85),Range: Steer. ang. 1/Steer. ang. 0\nSpecification: Steer. ang. 1
126,3,Airbag,(J234),Range: Airbag 1/Airbag 0\nSpecification: Airbag 1
126,4,Central,Electronics (J519),Range: Cent Elec 1/Cent Elec 0\nSpecification: Cent Elec 1
129,0,CAN-Databus Communication (Powertrain)
129,2,CAN-Gateway,(J533),Range: Gateway 1/Gateway 0\nSpecification: Gateway 1
129,3,Oil Temp./Level,Sensor (G266),Range: Oil Level 1/Oil Level 0\nSpecification: Oil Level 1
130,0,Engine Cooling (Map Cooling)
130,1,Engine Outlet,Temperature
130,2,Radiator Outlet,Temperature
130,3,Thermostat,Duty Cycle,Range: 0.0...100.0 %
130,4,Map Cooling, System Test,Range: Test ON/Test OFF/Syst. OK/Syst. n.OK\nSpecification: Test OFF
B130,0,Engine Cooling (Map Cooling)
B130,1,Engine Outlet,Temperature
B130,2,Radiator Outlet,Temperature
B130,3,Thermostat,Duty Cycle,Range: 0.0...100.0 %
B130,4,Map Cooling, System Test,Range: Test ON/Test OFF/Syst. OK/Syst. n.OK\nSpecification: Test OFF
131,0,Engine Cooling (Map Cooling)
131,1,Engine Outlet,Temperature (act.)
131,3,Radiator Outlet,Temperature
132,0,Engine Cooling (Map Cooling)
132,1,Radiator Outlet,Temperature
132,2,Temp. Difference,Radiator/Engine
132,4,Cooling Status,,x0xxxxx? = No Malfunction in System\nx0xxxx?x = Thermostat Actuation active\nx0xxx?xx = Fan Control active\nx0xx?xxx = Control Deviation (0 = above specified Temp. / 1 = below specified Temp)\nx0x?xxxx = Fan Stage 2 active\nx0?xxxxx = Fan Stage 1 active\n?0xxxxxx = Hot Climate Country coded
134,0,Engine Cooling (Temperatures)
134,1,Oil Temperature
134,2,Ambient,Temperature
134,3,Intake Air,Temperature (G42),Range: -40.5...+135.0 ░C\nSpecification (Warm): < +80.0 ░C (max. +115.0 ░C)
134,4,Engine Outlet,Temperature
135,0,Engine Cooling (Fan Activation)
135,1,Radiator Outlet,Temperature
135,2,Fan 1 Activation,Duty Cycle,Range: 0.0...100.0 %
136,0,Engine Cooling (Fan Activation)
136,4,Fan After Run,,Range: ON/OFF
137,0,Engine Cooling (Air Condition Requirements)
137,1,A/C Readiness,,Range: A/C-Low / A/C-High
137,2,A/C Compressor,,Range: Compr.OFF/Compr.ON
137,3,A/C Refrigerant,Pressure,Range: 0.0...40.0 bar
137,4,Fan Request,from A/C-System,Range: 0.0...100.0 %
140,0,Fuel Supply System (Quantity Control Valve)
140,1,Quantity Valve,closing Angle
140,2,Fuel Rail,Pressure (spec.)
140,3,Fuel Rail,Pressure (actual)
141,0,Fuel Supply System
141,1,Fuel Rail,Pressure Control
141,2,Fuel Rail,Pressure Control
141,4,Fuel Pressure,Control Status
142,0,Fuel Supply System (Intake Runner Flap Adaptation: Bank 1)
142,1,Runner Flap B1,Position (act.)
142,2,Runner Flap B1,Position (spec.)
142,3,Runner Flap B1,Position Offset
142,4,Runner Flap B1,Adaptation,Range: ADP RUN/ADP OK/ADP ERROR\nSpecification: ADP OK
B142,0,Fuel Supply System (Intake Runner Flap Adaptation: Bank 1)
B142,1,Runner Flap B1,Position (act.)
B142,2,Runner Flap B1,Position (spec.)
B142,3,Runner Flap B1,Position Offset
B142,4,Runner Flap B1,Adaptation,Range: ADP RUN/ADP OK/ADP ERROR\nSpecification: ADP OK
145,0,Exhaust Gas Temperature Sensor
145,1,Exhaust Gas,Temperature (calc.)
145,2,Exhaust Gas,Temp. Bank 1
145,3,Exhaust Gas,Temp. Bank 2
145,4,EGR Temp. Sensor,Test Status,Range: Test ON/Test OFF/Syst. OK/Syst. not OK\nSpecification: Test OFF
B145,0,Exhaust Gas Temperature Sensor Test
B145,1,Exhaust Gas,Temperature (calc.)
B145,2,Exhaust Gas,Temp. Bank 1
B145,3,Exhaust Gas,Temp. Bank 2
B145,4,EGR Temp. Sensor,Test Status,Range: Test ON/Test OFF/Syst. OK/Syst. not OK\nSpecification: Syst. OK
146,0,NOx Storage Catalyst Bank 1
146,1,Exhaust Gas,Mass Flow
146,2,NOx Cat. Bank 1,Temp. (calc.)
146,3,Storage Catalyst,Bank 1 Factor
146,4,NOx Cat. Bank 1,Test Status,Range: Test ON/Test OFF/Syst. OK/Syst. not OK\nSpecification: Test OFF
B146,0,NOx Storage Catalyst Bank 1
B146,1,Exhaust Gas,Mass Flow
B146,2,NOx Cat. Bank 1,Temp. (calc.)
B146,3,Storage Catalyst,Bank 1 Factor
B146,4,NOx Cat. Bank 1,Test Status,Range: Test ON/Test OFF/Syst. OK/Syst. not OK\nSpecification: Syst. OK
148,0,Desulphurisation NOx Storage Catalyst Bank 1
148,1,Vehicle Speed,,Range: 0.0...300.0 km/h
148,2,NOx Cat. Bank 1,Temp. (calc.)
148,3,Lambda Control,Bank 1 (actual)
148,4,NOx Cat. Bank 1,Test Status,Range: Test ON/Test OFF/Syst. OK/Syst. not OK\nSpecification: Test OFF
B148,0,Desulphurisation NOx Storage Catalyst Bank 1
B148,1,Vehicle Speed,,Range: 0.0...300.0 km/h
B148,2,NOx Cat. Bank 1,Temp. (calc.)
B148,3,Lambda Control,Bank 1 (actual)
B148,4,NOx Cat. Bank 1,Test Status,Range: Test ON/Test OFF/Syst. OK/Syst. not OK\nSpecification: Syst. OK
150,0,NOx Sensor
150,1,Operating Mode,,x00xxxx? = Homogenous (Lambda = 1)\nx00xxx?x = Homogenous (Lean)\nx00xx?xx = Homogenous/Stratified\nx00x?xxx = Stratified\nx00?xxxx = Stratified (CAT Heating)\n?00xxxxx = Knock Protection
150,2,NOx Cat. Bank 1,Temp. (calc.)
150,3,NOx Sensor,Voltage
150,4,Lambda Control,Bank 1 (actual)
151,0,NOx Sensor Heating
151,1,NOx Sensor,Supply Voltage,Specification: 11.0...15.0 V
151,2,NOx Sensor,Heating Resistance
151,3,NOx Sensor,Heating Status
152,0,NOx Sensor Offset
152,1,Lambda Control,Bank 1 (actual)
152,2,NOx Sensor,(actual)
152,3,NOx Sensor,Offset
152,4,NOx Sensor,,Test Status,Range: Test ON/Test OFF/Syst. OK/Syst. not OK\nSpecification: Test OFF
B152,0,NOx Sensor Offset
B152,1,Lambda Control,Bank 1 (actual)
B152,2,NOx Sensor,(actual)
B152,3,NOx Sensor,Offset
B152,4,NOx Sensor,,Test Status,Range: Test ON/Test OFF/Syst. OK/Syst. not OK\nSpecification: Syst. OK
166,0,Lambda Control (Lambda Sensor Plausibility)
166,1,Lambda Control,Bank 1 (actual)
166,2,Sensor Voltage,Bank 1 Sensor 1,Range: 0.0...5.0 V
166,3,Integral Mass,Air Flow
166,4,Plausibility,Test B1-S1,Range: Test ON/Test OFF/B1-S1 OK/B1-S1 n.OK\nSpecification: B1-S1 OK
167,0,Lambda Control (Lambda Sensor Overrun Compensation)
167,1,Oxygen Content
167,2,Diagnosis,Overrun Counter
167,3,Lambda Sensor,Correction Value
167,4,Overrun Compensation,Test Status,,Range: Test ON/Test OFF/Syst. OK/Syst. not OK\nSpecification: Test OFF
236,1,Low Fuel Pressure,(specification)
238,0,Fuel Injection (Fuel Pump Adaptation)
238,1,Low Fuel Pressure,(actual),Range: 0...6000 mbar
238,2,Fuel Pressure,Regulator
238,3,Adaptation Value,Fuel Pump
238,4,Fuel Pump Adapt.,Status,Range: ADP RUN/ADP OK/ADP ERROR\nSpecification: Test OFF
B238,0,Fuel Injection (Fuel Pump Adaptation)
B238,1,Low Fuel Pressure,(actual),Range: 0...6000 mbar
B238,2,Fuel Pressure,Regulator
B238,3,Adaptation Value,Fuel Pump
B238,4,Fuel Pump Adapt.,Status,Range: ADP RUN/ADP OK/ADP ERROR\nSpecification: ADP OK
; coding
C00,Engine Control Unit (J623) Coding
C01,000?xxx: Cooling Fan Control
C02,0 = 1 Continously Fan with 170 ccm│ Compressor installed
; Check fo 2-pin Coolant Temperature Sensor (G83)
; 170 ccm│ Compressor, 1K0-820-859-E or M
C03,1 = 2 Continously Fans installed
C04,2 = Cooling Fan Control via Thermal Switch
; Check for 3-pin Thermal Switch (F18)
C05,3 = 1 Continously Fan with 140 ccm│ Compressor installed
; 140 ccm│ Compressor,, 1K0-820-859-J oder N
C06,0000?xx: Powertrain
C07,0 = Front-Wheel-Drive (FWD)
C08,1 = All-Wheel-Drive (AWD)
C09,0000x?x: CAN-Databus
C10,+1 = Anti-Lock Braking System (ABS)
C11,+2 = Airbags
C12,+4 = Climate Control (Climatronic)
C13,0000xx?: Transmission
C14,1 = 5-Speed Manual Transmission
C15,2 = 6-Speed Manual Transmission
C16,5 = 6-Speed Automatic Transmission
; login/coding-ii
L00,Engine (J623) Coding-2
L01,11463 = Cruise Control System (CCS) Activation
L02,16167 = Cruise Control System (CCS) Deactivation
; adaptation
A000,0,Reset Learned Values
A000,5,Reset Learned Values
A000,6,To Reset the learned Values Save this Adaptation Channel.
A001,0,Idle Speed Adjustment
A001,1,Engine Speed,(actual)
A001,2,Engine Speed,(specified)
A001,3,A/C Readiness,,Range: A/C-Low / A/C-High
A001,4,A/C Compressor,,Range: Compr.OFF/Compr.ON
A050,0,Immobilizer (Vehicle Data learning)
A050,1,Status
A050,5,Immobilizer (Vehicle Data learning)
A050,6,Please enter the Immobilizer PIN/SKC of the Instrument Cluster (OLD PIN/SKC).
A050,7,After that the Learning Process is being initiated the new Engine Control
A050,8,Module adopts the Vehicle-Identification-Number (VIN) and Immobilizer
A050,9,Identification (IMMO-ID) of the Vehicle (from the OLD Instrument Cluster).
A050,10,Once the Adaptation is done switch the Ignition OFF for about 2 Minutes.
A091,0,Immobilizer Status
A091,5,Immobilizer Status (Read Only)
A091,6,0 = Immobilizer not matched (NEW)
A091,7,1 = Immobilizer disabled
A091,8,4 = Immobilizer matched (System OK)
; misc
O,03C-906-056-BAG
SN,MED 9.5.10
Jebb написал(а):... с лейбл файлом двигателя Polo 1.2 AZQ ...
03E-906-033-AZQ.lbl... так же и для BME написал(а):;
; VAG-COM Labeldatei
; Seat Cordoba/Ibiza (6L) / VW Polo (9N)
; Komponente: Motor (#01) - AZQ/BME
; T/N: 03E-906-033-???
; beinhaltet Messwertgruppen, Codierung und Login
; This file is part of a redirection package,
; 03-01.LBL
; 03E-906-033-AZQ.LBL (1.2l E @ 64 HP - AZQ/BME)
; erstellt am 03.10.2005 von Sebastian Stange (Sebastian@Ross-Tech.com)
; letzte Дnderung: 30.06.2006
; benцtigt mindestens VAG-COM 405.0 oder hцher
; Messwertgruppen Informationen
001,0,Allgemein
001,1,Motordrehzahl,(G28),Sollwert (Leerlauf): 640...900 U/min
001,2,Kьhlmittel-,temperatur (G62),Wertebereich: -40.5...+135.0 °C \nSollwert (betriebswarm): 80.0...110.0 °C
001,3,Lambdaregelung,Bank 1,Sollwert: -10.0...+10.0 %
001,4,Bedingungen fьr,Grundeinstellung,Wertebereich: 1 = erfьllt / 0 = nicht erfьllt\nSollwert: 11111111
; xxxxxxx? = Kьhlmitteltemperatur ьber 80.0 °C
; xxxxxx?x = Motordrehzahl unter 2000 U/min
; xxxxx?xx = Drosselklappe geschlossen
; xxxx?xxx = Lambdaregelung i.O.
; xxx?xxxx = Leerlaufschalter geschlossen
; xx?xxxxx = Klimakompressor aus
; x?xxxxxx = Katalysatortemperatur erreicht
; ?xxxxxxx = KEINE Fehler erkannt
002,0,Allgemein
002,1,Motordrehzahl,(G28),Sollwert (Leerlauf): 640...900 U/min
002,2,Motorlast,,Sollwert (Leerlauf): 16.0...26.0 %
002,3,mittlere,Einspritzzeit
002,4,Saugrohrdruck,(G71)
003,0,Allgemein
003,1,Motordrehzahl,(G28),Sollwert (Leerlauf): 640...900 U/min
003,2,Saugrohrdruck,(G71)
003,3,Drosselklappen-,winkel
003,4,Zьndwinkel
004,0,Allgemein
004,1,Motordrehzahl,(G28),Sollwert (Leerlauf): 640...900 U/min
004,2,Versorgungs-,spannung,Sollwert: 12.0...15.0 V
004,3,Kьhlmittel-,temperatur (G62),Wertebereich: -40.5...+135.0 °C \nSollwert (betriebswarm): 80.0...110.0 °C
004,4,Ansaugluft-,temperatur (G42),Wertebereich: -40.5...+135.0 °C \nSollwert (betriebswarm): < +80.0 °C (max. 110.0 °C)\nSensordefekt: +20.0 °C (Ersatzwert)
005,0,Allgemein
005,1,Motordrehzahl,(G28),Sollwert (Leerlauf): 640...900 U/min
005,2,Motorlast,,Sollwert (Leerlauf): 16.0...26.0 %
005,3,Geschwindigkeit
005,4,Betriebszustand,,Wertebereich: Leerlauf/Teillast/Anreich./Schub/Vollast\nSollwert: Leerlauf
006,0,Allgemein
006,1,Motordrehzahl,(G28),Sollwert (Leerlauf): 640...900 U/min
006,2,Motorlast,,Sollwert (Leerlauf): 16.0...26.0 %
006,3,Ansaugluft-,temperatur (G42),Wertebereich: -40.5...+135.0 °C \nSollwert (betriebswarm): < +80.0 °C (max. 110.0 °C)\nSensordefekt: +20.0 °C (Ersatzwert)
006,4,Hцhenkorrektur-,faktor,Wertebereich: -50.0...+20.0 %\n\n0.0 % = 0 m\n-50.0 % = 5000 m\n+20.0 % = -2000 m
008,0,Bremskraftverstдrker (Grundeinstellung)
008,1,Bremslichtschalter,,Wertebereich: unbetдtigt/betдtigt
008,2,Ansteuerung,Pumpe,Wertebereich: Pumpe AUS/Pumpe EIN
008,3,Bremsdruck
008,4,Ergebnis,,Wertebereich: Test AUS/Test EIN/Syst. i.O./Syst. n.i.O.\nSollwert: Syst. i.O.
010,0,Zьndung
010,1,Motordrehzahl,(G28),Sollwert (Leerlauf): 640...900 U/min
010,2,Motorlast,,Sollwert (Leerlauf): 16.0...26.0 %
010,3,Drosselklappen-,winkel
010,4,Zьndwinkel
011,0,Zьndung
011,1,Motordrehzahl,(G28),Sollwert (Leerlauf): 640...900 U/min
011,2,Kьhlmittel-,temperatur (G62),Wertebereich: -40.5...+135.0 °C \nSollwert (betriebswarm): 80.0...110.0 °C
011,3,Ansaugluft-,temperatur (G42),Wertebereich: -40.5...+135.0 °C \nSollwert (betriebswarm): < +80.0 °C (max. 110.0 °C)\nSensordefekt: +20.0 °C (Ersatzwert)
011,4,Zьndwinkel
012,0,Zьndung (Stellung Nockenwelle zur Kurbelwelle)
012,1,Motordrehzahl,(G28),(G28),Sollwert (Leerlauf): 640...900 U/min
012,2,Motorlast,,Sollwert (Leerlauf): 16.0...26.0 %
012,3,Kurbelwellenzahn,(low > high),Nr. des Kurbelwellenzahns bei Nockenwellenflankenwechsel
012,4,Kurbelwellenzahn,(high > low),Nr. des Kurbelwellenzahns bei Nockenwellenflankenwechsel
014,0,Aussetzererkennung
014,1,Motordrehzahl,(G28),(G28),Sollwert (Leerlauf): 640...900 U/min
014,2,Motorlast,,Sollwert (Leerlauf): 16.0...26.0 %
014,3,Aussetzer,Summenzдhler
014,4,Aussetzer-,erkennung,Wertebereich: aktiviert/gesperrt\nSollwert: aktiviert
015,0,Aussetzererkennung (Zylinder 1 - 3)
015,1,Aussetzer,Zylinder 1
015,2,Aussetzer,Zylinder 2
015,3,Aussetzer,Zylinder 3
015,4,Aussetzer-,erkennung,Wertebereich: aktiviert/gesperrt\nSollwert: aktiviert
018,0,Last-/Drehzahlfenster Aussetzererkennung
018,1,untere,Drehzahlschwelle
018,2,obere,Drehzahlschwelle
018,3,untere,Lastschwelle
018,4,obere,Lastschwelle
020,0,Klopfregelung (Zylinder 1 - 3)
020,1,Zьndwinkelrьck-,nahme Zylinder 1
020,2,Zьndwinkelrьck-,nahme Zylinder 2
020,3,Zьndwinkelrьck-,nahme Zylinder 3
022,0,Klopfregelung (Zylinder 1 && 2)
022,1,Motordrehzahl,(G28),Sollwert (Leerlauf): 640...900 U/min
022,2,Motorlast,,Sollwert (Leerlauf): 16.0...26.0 %
022,3,Zьndwinkelrьck-,nahme Zylinder 1
022,4,Zьndwinkelrьck-,nahme Zylinder 2
023,0,Klopfregelung (Zylinder 3)
023,1,Motordrehzahl,(G28),Sollwert (Leerlauf): 640...900 U/min
023,2,Motorlast,,Sollwert (Leerlauf): 16.0...26.0 %
023,3,Zьndwinkelrьck-,nahme Zylinder 3
026,0,Klopfregelung
026,1,Klopfsensor-,spannung Zyl. 1
026,2,Klopfsensor-,spannung Zyl. 2
026,3,Klopfsensor-,spannung Zyl. 3
028,0,Zьndung (Grundeinstellung: Klopfsensorprьfung)
028,1,Motordrehzahl,(G28),Sollwert (Leerlauf): 640...900 U/min
028,2,Motorlast,,Sollwert (Leerlauf): 16.0...26.0 %
028,3,Kьhlmittel-,temperatur (G62),Wertebereich: -40.5...+135.0 °C \nSollwert (betriebswarm): 80.0...110.0 °C
028,4,Klopfsensor-,prьfung,Wertebereich: Test EIN/Test AUS/Syst. i.O./Syst. n.i.O.\nSollwert: Syst. i.O.
030,0,Lambdaregelung
030,1,Bank 1 Sonde 1
; 1xx = Lambdasondenheizung ein
; x1x = Lambdasonde betriebsbereit
; xx1 = Lambdaregelung aktiv
030,2,Bank 1 Sonde 2
; xx1 = Lambdaregelung (I-Anteil) aktiv
031,0,Lambdaregelung (Lambdsonden Spannung)
031,1,Sondenspannung,Bank 1 Sonde 1
031,2,Sondenspannung,Bank 1 Sonde 2
032,0,Lambdaregelung (Lernwerte)
032,1,Bank 1 Sonde 1,Leerlauf (additiv)
032,2,Bank 1 Sonde 1,Teillast (multipl.)
033,0,Lambdaregelung
033,1,Lambdaregelung,Bank 1,Sollwert: -10.0...+10.0 %
033,2,Spannung,Bank 1 Sonde 1,Sollwert: 1.8...2.2 V
034,0,Lambdasonden-Alterungsprьfung Bank 1 vor Katalysator (Grundeinstellung)
034,1,Motordrehzahl,(G28),Sollwert (Leerlauf): 640...900 U/min
034,2,Katalysator-,temperatur Bank 1
034,3,Dynamikfaktor,Bank 1
034,4,Ergebnis,,Wertebereich: Test EIN/Test AUS/B1-S1 i.O./B1-S1 n.i.O.\nSollwert: B1-S1 i.O.
036,0,Lambdasonden-Betriebsbereitschaft (Grundeinstellung)
036,1,Spannung,Bank 1 Sonde 2
036,2,Ergebnis,,Wertebereich: Test EIN/Test AUS/B1-S2 i.O./B1-S2 n.i.O.
037,0,Lambdasonden-Alterungsprьfung Bank 1 nach Katalysator (Grundeinstellung)
037,1,Motorlast,,Sollwert (Leerlauf): 16.0...26.0 %
037,2,Spannung,Bank 1 Sonde 2
037,3,Lambdakorrektur-,wert (Bank 1)
037,4,Ergebnis,,Wertebereich: Test EIN/Test AUS/B1-S1 i.O./B1-S1 n.i.O.\nSollwert: B1-S1 i.O.
041,0,Lambdasondenheizung Bank 1
041,2,Zustand,Bank 1 Sonde 1,Wertebereich: Hzg.vK.ein/Hzg.vK.aus
041,3,Widerstand,Bank 1 Sonde 2
041,4,Zustand,Bank 1 Sonde 2,Wertebereich: Hzg.nK.ein/Hzg.nK.aus
043,0,Lambdasonden-Alterungsprьfung Bank 1 nach Katalysator (Grundeinstellung)
043,1,Motordrehzahl,(G28),Sollwert (Leerlauf): 640...900 U/min
043,2,Katalysator-,temperatur Bank 1
043,3,Sondenspannung,Bank 1 Sonde 1
043,4,Ergebnis,,Wertebereich: Test EIN/Test AUS/B1-S1 i.O./B1-S1 n.i.O.\nSollwert: B1-S1 i.O.
046,0,Katalysator Bank 1 Konvertierungsprьfung
046,1,Motordrehzahl,(G28),Sollwert (Leerlauf): 640...900 U/min
046,2,Katalysator-,temperatur Bank 1
046,3,MeЯwert,Katalysator
046,4,Ergebnis,,Wertebereich: Test EIN/Test AUS/Kat B1 i.O./Kat B1 n.i.O.\nSollwert: Kat B1 i.O.
050,0,Drehzahlregelung
050,1,Motordrehzahl,(Istwert)
050,2,Motordrehzahl,(Sollwert)
050,3,Klimaanforderung,,Wertebereich: AC-Low/AC-High
050,4,Klimakompressor,,Wertebereich: Kompr. ein/Kompr. aus
051,0,Drehzahlregelung (Schalteingriffe)
051,1,Motordrehzahl,(Istwert)
051,2,Motordrehzahl,(Sollwert)
051,3,Fahrstufe,(nur Automatik),Wertebereich: P/N = 0 / Gang = 1...6 / R = 7\nSollwert: 0
051,4,Versorgungs-,spannung,Sollwert: 12.0...15.0 V
053,0,Drehzahlregelung (Generatorlast)
053,1,Motordrehzahl,(Istwert)
053,2,Motordrehzahl,(Sollwert)
053,3,Versorgungs-,spannung,Sollwert: 12.0...15.0 V
053,4,Generatorlast,,Wertebereich: 0.0...100.0 %
054,0,Drehzahlregelung (Leerlaufsteller/-schalter)
054,1,Motordrehzahl,(G28),Sollwert (Leerlauf): 640...900 U/min
054,2,Betriebszustand,,Wertebereich: Leerlauf/Teillast/Anreich./Schub/Vollast\nSollwert: Leerlauf
054,3,Geber 1 (G79),Gaspedalstellung,Wertebereich: 0.0...100.0 %\nSollwert (Leerlauf): 10.0...20.0 %
054,4,Drosselklappen-,winkel (G187),Wertebereich: 0.0...100.0 %\nSollwert (Leerlauf): 5.0...20.0 %
055,0,Drehzahlregelung (Leerlaufstabilisierung)
055,1,Motordrehzahl,(G28),Sollwert (Leerlauf): 640...900 U/min
055,2,Leerlaufregler,(Drehmoment)
055,3,Leerlaufregler,(Verlustmoment)
055,4,Betriebszustдnde
; xxxx1 = Klimakompressor EIN
; xxx1x = Fahrstufe eingelegt
; xx1xx = Klimabereitschaft EIN
; x1xxx = Heckscheibenheizung EIN
; 1xxxx = Lenkung am Anschlag
056,0,Leerlaufstabilisierung
056,1,Motordrehzahl,(Istwert)
056,2,Motordrehzahl,(Sollwert)
056,3,Leerlaufregler,(Drehmoment)
056,4,Betriebszustдnde
057,0,Leerlaufstabilisierung (Klimakompressor)
057,1,Motordrehzahl,(Istwert)
057,2,Motordrehzahl,(Sollwert)
057,3,Klimakompressor,,Wertebereich: Kompr. ein/Kompr. aus
057,4,Tastverhдltnis,Druckaufnehmer,Drehmoment Klimakompressor
060,0,Drehzahlregelung (Grundeinstellung: Drosselklappensteuereinheit)
060,1,Drosselklappen-,winkel (G187),Wertebereich: 0.0...100.0 %\nSollwert (Leerlauf): 5.0...20.0 %
060,2,Drosselklappen-,winkel (G188),Wertebereich: 0.0...100.0 %\nSollwert (Leerlauf): 80.0...100.0 %
060,3,Lernschrittzдhler
060,4,Anpassungs-,zustand,Wertebereich: ADP lдuft/ADP i.O./ERROR\nSollwert: ADP i.O.
061,0,Drehzahlregelung (E-Gas System)
061,1,Motordrehzahl,(G28),Sollwert (Leerlauf): 640...900 U/min
061,2,Versorgungs-,spannung,Sollwert: 12.0...15.0 V
061,3,Drosselklappen-,winkel
061,4,Betriebszustдnde
062,0,Drehzahlregelung (E-Gas System)
062,1,Drosselklappen-,winkel (G187),Wertebereich: 0.0...100.0 %\nSollwert (Leerlauf): 5.0...20.0 %
062,2,Drosselklappen-,winkel (G188),Wertebereich: 0.0...100.0 %\nSollwert (Leerlauf): 80.0...100.0 %
062,3,Geber 1 (G79),Gaspedalstellung,Wertebereich: 0.0...100.0 %\nSollwert (Leerlauf): 10.0...20.0 %
062,4,Geber 2 (G185),Gaspedalstellung,Wertebereich: 0.0...100.0 %\nSollwert (Leerlauf): 5.0...15.0 %
063,0,Gasbetдtigung (Grundeinstellung: Kick-Down Adaption - nur Automatik)
063,1,Gaspedalstellung,(G79),Wertebereich: 0.0...100.0 %
063,2,Kick-Down,Lernwert (G79),Wertebereich: 0.0...100.0 %
063,3,Schalter,,Wertebereich: Kick-Down
063,4,Ergebnis,,Wertebereich: Betдtigt/ADP lдuft/ADP i.O./ERROR\nSollwert: ADP i.O.
064,0,Drosselklappenpotiadaptionswerte
064,1,Potentiometer 1,untere Adaption
064,2,Potentiometer 2,untere Adaption
064,3,Notluftspalt,Potentiometer 1
064,4,Notluftspalt,Potentiometer 2
066,0,Geschwindigkeitsregelanlage (GRA)
066,1,Geschwindigkeit,(Istwert)
066,2,Schalterstellung,(Bremse/Kupplung)
; 00xxxxxx - ADR/GRA nicht aktiv (steht auch fьr nicht verbaut)
; 01xxxxxx - ADR/GRA im Regelbetrieb
; 10xxxxxx - Zustand "ьbersteuert", Fahrer gibt mehr "Gas" als GRA-Regler
; 11xxxxxx - ADR nicht freigegeben
; xx?xxxxx = Hauptschalter getastet
; xxx?xxxx = Automatische Distanzregelung (0 = inaktiv / 1 = aktiv)
; xxxx?xxx = Geschwindigkeitsregelanlage (0 = inaktiv / 1 = aktiv)
; xxxxx?xx = Kupplungspedalschalter (0 = unbetдtigt / 1 = betдtigt)
; xxxxxx?x = Bremspedalschalter (0 = unbetдtigt / 1 = betдtigt)
; xxxxxxx? = Bremslichtschalter (0 = unbetдtigt / 1 = betдtigt)
066,3,Geschwindigkeit,(Sollwert)
066,4,Schalterstellung,(Bedienhebel)
; x0xxxxx? = GRA Status (Ein/Aus - Raster)
; x0xxxx?x = GRA Status (Ein/Aus - Speicher)
; x0xxx?xx = Verzцgern (-)
; x0xx?xxx = Beschleunigen (+)
; x0x?xxxx = Setzen (SET)
; x0?xxxxx = Wiederaufnahme (RESET)
; ?0xxxxxx = Hauptschalter (GRA)
070,0,Abgasreduzierung (Grundeinstellung: Tankentlьftung)
070,1,Цffnungsgrad,(TE-Ventil),Wertebereich: 0...100 %\nSollwert: 0.0...30.0 %
070,2,Lambdaregler,Diagnosewert
070,3,Langzeit,TEV-Gьte
070,4,Diagnosezustand,,Wertebreich: Test AUS/Test EIN/TEV i.O./TEV n.i.O.\nSollwert: TEV i.O.
073,0,Abgasrьckfьhrung (AGR)
073,1,Motordrehzahl,(G28),Sollwert (Leerlauf): 640...900 U/min
073,2,AGR-Poti,Цffnungsrate,Sollwert: 0...30 %
073,3,AGR,Ventilhubdifferenz,Sollwert: -25...+0 %
073,4,Ergebnis
074,0,Abgasreduzierung (Grundeinstellung: Ventil fьr Abgasrьckfьhrung)
074,1,Nullposition
074,2,maximaler,Anschlag
074,3,Potentiom. (G212),Abgasrьckfьhrung
074,4,Ergebnis,,Wertebereich: ADP lдuft/ADP i.O./ERROR
086,0,Ready- und Zyklusbits
086,1,Ready-Bits,,Wertebereich: 0 = abgeschlossen / 1 = nicht abgeschlossen
; xxxxxxx? = Katalysator(en)
; xxxxxx?x = Katalysatorheizung
; xxxxx?xx = Tankentlьftung
; xxxx?xxx = Sekundдrluftsystem
; xxx?xxxx = Klimaanlage
; xx?xxxxx = Lambdasonde(n)
; x?xxxxxx = Lambdasondenheizung
; ?xxxxxxx = Abgasrьckfьhrung
086,2,Zyklus-Flags I
; xxxxxxx? = Katalysator Bank 1 & Bank 3
; xxxxxx?x = Katalysator Bank 2 & Bank 4
; xxxxx?xx = Leckdiagnosepumpe
; xxxx?xxx = Tankentlьftungsventil
; xxx?xxxx = Lambdasondenheizung Bank 1 Sonde 1
; xx?xxxxx = Lambdasondenheizung Bank 1 Sonde 2
; x?xxxxxx = Lambdasondenheizung Bank 2 Sonde 1
; ?xxxxxxx = Lambdasondenheizung Bank 2 Sonde 2
086,3,Zyklus-Flags II
; 0xxxxxx? = Bank 1 Sonde 1 el.
; 0xxxxx?x = Bank 1 Sonde 2 el.
; 0xxxx?xx = Bank 1 Sonde 1 (Delta-Lambda Verschiebung)
; 0xxx?xxx = Bank 1 Sonde 2 (Sondenalterung)
; 0xx?xxxx = Bank 1 Sonde 1 (Periodendauer)
; 0x?xxxxx = Sekundдrluftsystem Bank 1
; 0?xxxxxx = Sekundдrluftsystem Bank 2
086,4,Zyklus-Flags III
; 000xxxx? = Bank 2 Sonde 1 el.
; 000xxx?x = Bank 2 Sonde 2 el.
; 000xx?xx = Bank 2 Sonde 1 (Delta-Lambda Verschiebung)
; 000x?xxx = Bank 2 Sonde 2 (Sondenalterung)
; 000?xxxx = Bank 2 Sonde 1 (Periodendauer)
087,0,Ready- und Errorbits
087,1,Ready-Bits,,Wertebereich: 0 = abgeschlossen / 1 = nicht abgeschlossen
087,2,Error-Flags I
087,3,Error-Flags II
087,4,Error-Flags III
088,0,Zyklus-Flags
088,1,Zyklus-Flags I,,Wertebereich: 0 = abgeschlossen / 1 = nicht abgeschlossen
; xxxxxxx? = Auslass-NW Bank 2
; xxxxxx?x = Auslass-NW Bank 1
; xxxxx?xx = Einlass-NW Bank 2
; xxxx?xxx = Einlass-NW Bank 1
; xxx?xxxx = Klopfsensor 4
; xx?xxxxx = Klopfsensor 3
; x?xxxxxx = Klopfsensor 2
; ?xxxxxxx = Klopfsensor 1
088,2,Zyklus-Flags II,,Wertebereich: 0 = abgeschlossen / 1 = nicht abgeschlossen
; xxxxxx?x = Kupplungsschalter
; xxxxx?xx = Leerlaufregelung
; xxxx?xxx = Geschwindigkeitssignal
; xx?xxxxx = Kьhlmitteltemperatursensor
; x?xxxxxx = Drosselklappenpotentiometer
; ?xxxxxxx = Luftmassenmesser
088,3,Zyklus-Flags III,,Wertebereich: 0 = abgeschlossen / 1 = nicht abgeschlossen
;xxxx?000 = Thermostat (nur USA)
;xxx?x000 = Ladedruckregelung
;xx?xx000 = GRA-Bedienhebel
;x?xxx000 = Lambda-Adaption B2 (Summe aus TRA und FRA)
;?xxxx000 = Lambda-Adaption B1 (Summe aus TRA und FRA)
089,0,On-Board-Diagnose (OBD)
089,1,Gefahrene km,mit MIL,Sollwert: 0 km
089,2,Leertankinfo,,Wertebereich: i.O./zu klein
099,0,Lambdaregelung (Grundeinstellung)
099,1,Motordrehzahl,(G28)
099,2,Kьhlmittel-,temperatur (G62),Wertebereich: -40.5...+135.0 °C \nSollwert (betriebswarm): 80.0...110.0 °C
099,3,Lambdaregelwert
099,4,Lambdaregelung,Status,Wertebereich: EIN/AUS
100,0,Readinesscode
100,1,Readinesscode,,Wertebereich: 0 = abgeschlossen / 1 = nicht abgeschlossen\nSollwert: 00000000
100,2,Kьhlmittel-,temperatur (G62),Wertebereich: -40.5...+135.0 °C \nSollwert (betriebswarm): 80.0...110.0 °C
100,3,Zeit seit,Motorstart
100,4,OBD-Status,,siehe Labelfile
; xxxx--x1 - KEIN Aufwдrmzyklus erkannt
; xxxx--1x - Aufwдrmzyklus erkannt
; xxx1--xx - mind. 1 Fehler erkannt
; xx1x--xx - Kurztrip komplett
; x1xx--xx - Kurztrip erkannt
; 1xxx--xx - MIL EIN
101,0,Einspritzung
101,1,Motordrehzahl,(G28),Sollwert (Leerlauf): 640...900 U/min
101,2,Motorlast,,Sollwert (Leerlauf): 16.0...26.0 %
101,3,mittlere,Einspritzzeit
101,4,Saugrohrdruck,(G71)
102,0,Einspritzung
102,1,Motordrehzahl,(G28),Sollwert (Leerlauf): 640...900 U/min
102,2,Kьhlmittel-,temperatur,Sollwert: 80.0...115.0 °C
102,3,Ansaugluft-,temperatur,Sollwert: -38.0...80.0 °C
102,4,mittlere,Einspritzzeit
104,0,Startfaktoren (Adaptionswerte)
104,1,Motortemperatur,beim Start
104,2,Temperatur-,adaptionsfaktor 1
104,3,Temperatur-,adaptionsfaktor 2
104,4,Temperatur-,adaptionsfaktor 3
105,0,Zylinderabschaltung
105,1,Motordrehzahl,(G28),Sollwert (Leerlauf): 640...900 U/min
105,2,Motorlast,,Sollwert (Leerlauf): 16.0...26.0 %
105,3,Kьhlmittel-,temperatur,Sollwert: 80.0...115.0 °C
105,4,Status,Abschaltung,Wertebereich: Ein/Aus
107,0,Lambdaregelung (Grundeinstellung)
107,1,Motordrehzahl,(G28),Sollwert (Leerlauf): 640...900 U/min
107,2,Lambdaregler,Bank 1,gemittelter Wert
107,4,Ergebnis,,Wertebereich: Test ein/Test aus/Syst.i.O./Syst.n.i.O.
120,0,Antriebs-Schlupf-Regelung (ASR)
120,1,Motordrehzahl,(G28),Sollwert (Leerlauf): 640...900 U/min
120,2,Sollmoment,ASR
120,3,Motormoment
120,4,Status,,Wertebereich: ASR aktiv/ASR n. aktiv
122,0,Getriebe
122,1,Motordrehzahl,(G28),Sollwert (Leerlauf): 640...900 U/min
122,2,Sollmoment,Getriebe
122,3,Motormoment
122,4,Status,,Wertebereich: Motoreingriff/kein Eingriff
125,0,CAN-Datenbus Antrieb (Kommunikation)
125,3,Kombiinstrument,,Sollwert: Kombi 1\nWertebereich: Kombi 1/Kombi 0
126,0,CAN-Datenbus Antrieb (Kommunikation)
126,3,Airbagsystem,,Sollwert: Airbag 1\nWertebereich: Airbag 1/Airbag 0
126,4,Bordnetz-,elektronik,Sollwert: Elektr. ZE 1\nWertebereich: Elektr. ZE 1/Elektr. ZE 0
; Codierungs Informationen
C00,Motorelektronik (J361) Codierung
C01,000?x: CAN-Datenbus Teilnehmer
C02,+1 = ABS
C03,+2 = Airbag
C04,+4 = Klimaanlage
C05,
C06,000x?: Getriebevariante
C07,1 = 5-Gang Schaltgetriebe
; Login Informationen
L00,Motorelektronik (J361) Login
L01,11463 = Aktivierung der Geschwindigkeitsregelanlage (GRA)
L02,16167 = Deaktivierung der Geschwindigkeitsregelanlage (GRA)
Jebb написал(а):...необходимо скопировать в блокнот, сохранить в папку c LABLE файлами с расширением .LBL и все?...
Jebb написал(а):1. что за расширение такое .clb и будет ли VCDS-light зарегистрированная с ним работать?...
2. если нет, то может ли кто поделиться файлом 6Q0-423-156.lbl? желательно на английском...
6Q0-423-156.lbl (EN) написал(а):;
; VCDS Label File
; Seat Ibiza (6L) / Skoda Fabia (6Y) / Skoda Fabia/Roomster (5J) / VW Polo (9N)
; Component: J500 - Steering Aid (#44)
; P/N: 6Q0-423-156-???
; created on 13/Apr/2008 by Sebastian Stange (Sebastian@Ross-Tech.com)
; last modification: 13/Apr/2008
; requires VCDS 803.0 or newer
; measuring block
001,0,Electrical System
001,1,Voltage,(Terminal 30)
001,2,Pump Motor,Voltage
001,3,Control Module,Temperature
001,4,Pump Motor,Status,Range: ON/OFF
002,0,Steering
002,1,Steer. Aid Sensor,Angular Velocity
002,2,Pump Motor Speed,(specified)
002,3,Pump Motor Speed,(actual)
002,4,Pump Motor,Voltage
003,0,Vehicle
003,1,Vehicle Speed
003,2,Vehicle,Engine Speed
003,3,Pump Motor,Status,Range: ON/OFF
003,4,Steering Aid,Sensor (G250)
004,1,Power Steering,Activation Time
004,2,Power Steering,Activation Counter
004,3,Steer. Aid Sensor,Reference Voltage
004,4,Voltage,(Terminal 15)
Address 25: Immobilizer Labels: None
Controller: Bit teA dre sst
Component: e 17 eingeben
VCID: CEEF6D3B19CF
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 33: OBD-II Labels: None
Controller: OBD-II/EOBD, Protocol Keyword: $0808
VCID: 6EAF4DBB398F
Address 3F: Unknown Address: 3F Labels: None
Controller:
No fault code found.
Jebb написал(а):1 в measuring blocks группа 000 недоступна, в чем может быть проблема?
2Address 25: Immobilizer
Component: e 17 eingeben... что сие может означать?
3. ...для данного адреса лейбл файла не существует, я правильно понимаю?
4 Address 3F - что за контроллер? ...
Jebb написал(а):2 надеялся покавыряться в имобилайзере, посмотреть есть ли какие-нибудь полезные данные по привязке ключа - машина дасталась с одним ключом...
