2 dya а как пробить по вин что с ним делали в германии ??? я смог найти только это
VIN-number WVWZZZ1JZXW255478
Sales type 1J12E4
Model year 1999
Model GOLF
Model Designatio GOLF/VAR./4MOT. A4 98>0
Engine code AKQ
Transmission code DUW
finaldrive ident 5S
Interior trim cod EL
Roof color T3
Exterior color T3
Расшифровка кодов комплектации
Код Опция
5MA decorative inserts
2G7 filler neck module 1 with insert
4X1 side airbag front
9Q1 multi-function indicator/trip computer
8T0 without cruise control system (CCS)
4AF foamed film and fabric door and side panel trim
3L3 manual height adjustment for front seats
1JA rear shock absorption, basic design 1
1C1 antifreeze up to -25 degree celsius tolerance up to -30 degree C
9Y0 without outdoor temperature gage
0F2 fuel system for carburetor gasoline engine
9J0 without supertone system and tone sequence control
4Q1 flame retardent materials
5N6 folding grab handles at roof frame soft fold-away
4B1 protective side molding
L0L left-hand drive vehicle
8M1 rear window wiper and washer system with intermittent control
8TC rear fog light for driving on the right
2W0 fuel filler cap
7P0 without lumbar support in front and rear seats
7A0 without CD changer/CD player
1Z0 initial standard fuel filling
Q1A standard front seats
B01 type approval Germany
G0C 5-speed manual transmission
0UA without special color trim
0FA standard manufacturing sequence
6KG radiator grille
4J1 floor tray, extension center console
0N5 standard rear axle
9JB smoking version, ashtray front and rear
3M0 without special measures
7X0 without park distance control
8F2 side turn signal lights
2WA without additional tires
2P0 without trunk sill protection
B0A component parts set without country-specific design requirement
7AB electronic alarm system with vehicle immobilization device (for RoW)
1D0 without towing attachment
6SC tufted trunk floor covering
0NB nameplate set in base trim
4R0 mechanical window regulator
1S7 tool kit and aluminum jack
0G3 gearshift linkage
3U1 foldable trunk cover
1KK disc brakes, rear
7Q0 without navigation device
8N4 windshield wiper intermittent control with potentiometer (four speeds)
7B0 without socket
H5W all-weather tires 175/80 R 14 H
1SA without additional engine guard
6E0 without center armrest front
9D0 without preparation for two-way radio installation
4K3 radio remote controlled central locking operated from inside and safe securing
7QA without CD ROM
3FE electric slide/tilt sunroof with sun screen/sunblind
1T0 w/o first aid kit and warning triangle
6M0 without tie down straps/net/pocket
2B2 additional exterior noise suppression
1E1 activated carbon canister
E0A no special edition
T1Q components for base engine, unit 036.D
9L0 without engine compartment lighting
5A2 comfort trunk lining
4KC side and rear windows tinted
N4C fabric seat covering
6EJ additional body cover on sill, without wheel arch
C6D steel wheels 6J x 14 offset 38
8GD alternator 90A
6U0 without additional seals outside
1LQ front disc brakes with integrated adapter
9T0 without heated washer nozzles
0A2 four doors
9E1 luggage compartment lighting
8W0 without washer fluid level indicator
4L2 dipping breakaway inside rear view mirror
4SD left vanity mirror illuminated
3GA without cargo area
2JB standard bumpers
3NW rear seat bench/backrest, split folding with center armrest
J1L battery 280 A (60 Ah)
2C5 axial and vertical adjustable steering column
6FE body-colored outer rear view mirror housings and tailgate grab strip
9M0 without auxiliary/parking heater
9TB additional warning lights (door area)
4E0 tailgate/trunk lid unlocking from outside
1EX special identification plate for EC
8WA without front fog light
3H0 without backrest release for front seats
1MP steering wheel for airbag system
C06 operating permit, alteration 6
0AM front stabilizer
1N1 power steering
U0C instrument insert with tachometer clock and km/h speedometer
9U0 without brake pad wear indicator
9F0 without sound combination for rotating emergency light and radio antenna preparation
6NH comfort molding roof liner unsplit roof cutout rear (radio antenna)
8X0 without headlight washer system
4TD right vanity mirror illuminated
3P1 bracket for first aid kit and warning triangle
4M5 cup holder
7L0 without inertia benefit system/ deceleration fuel cut-off/idle stop valve
2D1 complete cd enhancing underbody panel
1G2 steel spare wheel with original equipment tires
1NC full wheel covers
5C0 without special body measures
4U0 without luggage nets/pockets on backrests
0BC rear stabilizer
9FA without automatic transmission indicator light
8Q1 headlight-range adjustment
8AS radio "alpha Europa"
7E0 w/o heat accumulator/auxiliary heating
6W1 license plate bracket front (large)
1GA front shock absorption, basic design 1
5K0 without paint preservative
8Y0 single-tone horn
3Q1 rear headrests
4UE airbag f. driver a. front seat passenger
3B0 without additional child seat anchor
8QE key for locking system with remote control
2E0 base chassis
2LB fuel tank with special material treatment (fluorination)
U20 suspension range 119
F0A no special purpose vehicle, standard equipment
1H0 without proportioning valve
6P1 license plate bracket rear (ECE)
6A0 without fire extinguisher
5RQ outer right rear view mirror: convex
0RA without ignition/starter switch locking system
5D1 carrier frequency 433.92 MHz
K8G hatchback
0CE vehicle class differentiation 1J0
3Y0 without roll-up sun screen
0YZ without determination of weight categoryfor rear axle
MB6 4-cyl. gasoline engine 1.4 L/55 kW 16V with multi-point injection, EU 3D base engine is T1Q
1WA transmission shaft w/ 90mm in diameter
3J7 articulated and height-adjustable headrests for front seats
6PA plastic hand brake lever handle
0KA without stickers and badges
9W0 w/o car phone preparation/installation
8K0 without special low beam mode
8JS twin headlamp for left-hand drive with clear lens
3C1 static lap belt, center rear
8CC speedometer sensor without seal (electronic speedometer sensor)
4GF windshield, tinted
8Z5 engine cooling system, type 1
8RE four loudspeakers (passive)
5SL outer left rear view mirror: non-spherical
1X0 front wheel drive
1PA standard wheel bolts
6XB outer rear view mirrors: manually adjustable from inside
A8C comfort equipment
S8M model year change calendar week 32/98
1AC anti-lock brake system (ABS)
0L0 mechanical throttle actuation
6Q4 comfort gearshift knob/handle
0SB labels/plates in German
4W0 without cassette and CD storage unit
9P0 without seat belt warning light
9A0 without taxi alarm system
3YQ door pockets without insert mats
8S2 one reading light front, two reading lights rear
3CA without partition
V0A tires w/o specification of tire brand
6QA rear seat catch
4P0 rear floor panel module, type 1
4A0 without seat heater
9AB manually controlled air conditioning
3S0 without roof rails/roof load rack
8SA taillight assemblies, standard design
QG0 without service interval prolongation
8L3 roof antenna
3ZG 3-point seat belts, outer rear with height adjustment
2V5 fresh air intake system with activated charcoal canister
6R1 leatherette gearshift boot
0TA without floor mats
Нераспознанные коды
PT1 PTB P06 RAA PH1
авто пригнали 2 года назад пригонял знакомый лично для жены
а по поводу движки как я понял проблема только в поедании масла и не продуманной вентиляции картерных газов поедание меня не напрягает и на сколько я знаю в это авто масло не доливают от замены до замены )))) просто нравится комплект и цена очень для меня вкусная ))))
2 estimator
я не говорю что это очень дорого мне в принципе важно состояние движка и систем типа АБС кондея усилителя руля кузов в последнею очередь так как я его смотрел сам меня все устраивает, были два удара в зад и в перед не большие на сколько я понял резину не жрет стекла все родные кроме лобового было поменнено здесь 2 года назад попал камень и до сих пор не трещинки как я понимаю соответственно сильного лобового бокового удара не было раз оно не треснуло за 2 года значит стойки ровные )))
