EVILAUDI
- Автомобиль
- Audi TTRS 2018
- Двигатель
- 2.5
- Коробка передач
- DQ500
I installed a wavetrac front LSD in my TTRS DSG. About 500 miles after install I received the P176B error. I disassembled the mech and inspected oil tube rubber seals and solenoid screens. Nothing was damaged. I then inspected and changed both the filter and fluid just to be safe. The code remained but after clearing a couple times it went away for about 500 miles. Is there any way to identify if this is a mech issue or a physical transmission issue? The car has less than 12,000 miles so it's unlikely the clutch.
If anyone has seen this problem before I would appreciate any help you can provide. I don't want to buy a new mech only to find out that there is a problem inside the box.
