illusionist49 написал(а):
А температура катализатора не определяется ни каким датчиком на бензиновом двигателе, блок управления не знает такого показателя
Все, приехали
VCDS Label File Template for Gasoline Engines v0.3.9
; Copyright © 2009-2011 Ross-Tech, LLC
; Audi A3 (8P) / VW Caddy (2K) / VW Golf V (1K) / VW Touran (1T)
; Seat Leon (1P) / Seat Altea (5P) / Skoda Octavia II (1Z)
; Component: J623 - Engine (#01) - BGU/BSE/BSF
; P/N: 06A-906-033-???
; includes measuring blocks, basic setting, readiness, coding, coding-II and adaptation
; This file is part of a label file package,
; make sure you have all of the following files.
; 06-01.LBL
; 06A-906-033-BGU.LBL (1.6l MPI @ 102 HP - BGU/BSE/BSF)
; created on 21/Nov/2010 by Sebastian Stange (Sebastian@Ross-Tech.com)
; last modificationon on 29/Aug/2011
; requires VCDS 10.6.4 or newer
001,4,Basic Setting,Requirements,xxxxxxx1 = Coolant Temperature above 80 °C\nxxxxxx1x = Engine Speed below 2000 RPM\nxxxxx1xx = Throttle Valve closed\nxxxx1xxx = Lambda Control OK\nxxx1xxxx = Idle Switch closed\nxx1xxxxx = Air Conditioning Compressor OFF\nx1xxxxxx = Catalytic Converter above 380 °C\n1xxxxxxx = No Diagnostic Trouble Codes (DTCs) detected by On Board Diagnostic (OBD)
; xxxxxxx1 = Coolant Temperature above 80 °C
; xxxxxx1x = Engine Speed below 2000 RPM
; xxxxx1xx = Throttle Valve closed
; xxxx1xxx = Lambda Control OK
; xxx1xxxx = Idle Switch closed
; xx1xxxxx = Air Conditioning Compressor OFF
; 1xxxxxxx = No Diagnostic Trouble Codes (DTCs) detected by On Board
Diagnostic (OBD)
034,2,Catalytic Converter,Bank 1 Temp.
043,2,Catalytic Converter,Bank 1 Temp.
Температура определяется по сопротивлению подогревателя.
Второй зонд тоже корректирует смесь по остаточному кислороду после катализатора.
Похоже бесполезный разговор
