    182,8 КБ · Просмотры: 236
Помогите нужна схема вакуумных трубок гольф4 1.9 тди мотор 90 лошадей AGR
Вечер добрый. Помогите найти схему вакуумных трубок на шаран 1.9 тди AUY.
Движ замена. Сейчас вот так.
    197,3 КБ · Просмотры: 177
Engine code AUY
1 Vacuum unit for intake manifold change-over
2 Air filter
3 Solenoid valve for charge pressure control (N75)
4 Change-over valve for intake manifold flap (N239)
5 Exhaust gas recirculation valve (N18)
6 To exhaust gas turbocharger
7 Non-return valve
White connection to charge pressure control solenoid valve item 3, change-over valve for intake manifold flap item 4 and to vacuum reservoir
8 Pressure unit
For charge pressure control
Integral part of turbocharger cannot be replaced
9 Exhaust gas recirculation valve (mechanical)
With intake manifold flap
10 Vacuum connection
Between tandem pump and brake servo
11 Vacuum reservoir
Vacuum hose schematic diagram
Engine codes AGR, AHF, ALH, ASV
1 - Exhaust gas recirculation valve
2 - Exhaust gas recirculation valve -N18-
3 - Non-return valve
4 - From brake servo
5 - Air cleaner
6 - Vacuum pump
4-cylinder diesel engine (1.9 l engine)
Engine AVQ BKC BRU BLS BXE BXF BXJ
Vehicles with particulate filter
1 - Turbocharger
2 - Connecting pipe air filter/turbocharger
Note installation position.
4 - To brake servo
5 - Charge pressure control solenoid valve -N75-
6 - Air filter
7 - Cylinder head/cylinder block
8 - Intake manifold
9 - Bypass flap
For exhaust gas recirculation cooler.
10 - Cooler
For exhaust gas recirculation.
11 - Exhaust gas recirculation valve -N18-
12 - Exhaust gas recirculation cooler change-over valve -N345-
13 - Non-return valve
14 - Vacuum unit
Turbocharger
Vehicles without particulate filter
1 - Solenoid valve block
Vacuum hose schematic diagram on solenoid valve block
2 - Non-return valve
3 - To brake servo
4 - Connecting pipe air filter/turbocharger
5 - Air filter
6 - Intake manifold
8 - Vacuum reservoir
9 - Bypass flap
10 - Cooler
12 - Turbocharger
Saulius . Да. А что есть проблемы в этом. Просто мой не найти. Нашел, что они одинаковые только турба другая. Хочу потом еще чипануть.
Так я не понял, хочешь только голый мотор поменять, или со всем обвесом (турба, впускной коллектор, форсунки, приёмная труба до турбы, выпускная труба с катализатором) от AUY? Тогда можно и просто комп моторный от шарана с AUY махнуть, там даже привязывать пин-кодами ничего не требуется.
@Saulius может есть схема на sharan 2002 auy 1.9 tdi но у меня 2 ресивера
Всём привет, тема большая, схем тьма, есть ли у кого данные как подключить хорошо вакумные трубки на моторе ALH с удалённым ЕГР. Если пришлёте фото, будет вообще супер. За ранее спасибо.
Здравствуйте уважаемые.
Может у кого нибудь есть схема вакуумной магистрали мотора AWX?
Спасибо большое ?
Спасибо большое ?
Схема для AWX такая же, как для AVF, AVB. На второй странице этой темы найдёшь.
  • Спасибо!
Реакции: Ass
Безумно благодарен ?
Добрый день, не могу найти схему вакуумный магистралей на двигатель cbd. 140 л.с. Стоить на гольф 5.
Походу, двигло у тебя CBDC (81 кВт), и ставился он на Golf-6, так как на 5-ом гольфе не нашёл двигла с буквами CBCD.
А магистрали ниже:
  • V.ru-RU.K00590223.wi__64819950.pdf
    101 КБ · Просмотры: 129
