ten70
Оракул
- AD1 R-Line TDI
Да ничего с этой ошибкой не сделать.
Скорее всего она возникает из-за несовпадения теста чексуммы в епромке .
Проще говоря программа ЭБУ двигателя повреждена, возможно кривым чиптюнингом.
bit of a stab in the dark from the mk 4 list 01177 - Replace Motronic Engine Control Module (ECM) -J220
that the engine ECU, with not much info on those codes but could be an internal check sum error, does car drive ok??
It doesn't have two names, it has two "Failure Types".
The first part of the code is 01177, which identifies the failed component, "Engine Control Unit".
The second part of the code in the first instance is 65-10, which tells the failure type, "Unauthorized, Intermittent", in the second instance (where you neglected to give the full numbers) it was probably 37-00 "Faulty".
-Uwe-
