ten70
Оракул
- AD1 R-Line TDI
Внешний вид приборной панели с MFA+, поддерживает мультируль с кнопками управления II типа (на фото):
Возможности в кодировании приборной панели:
Базовые установки, контроль параметров:
Адаптация приборной панели...
Описание от Росстеча:
Coding
* 00??x0x: Options
o +01 = Brake Pad Warning
o +02 = Seatbelt Warning
o +04 = Washer Fluid Warning
o +16 = Sedan (only VW Jetta)
* 00xx?0x: Country
o 1 = Europe (EU)
o 2 = USA (US)
o 3 = Canada (CDN)
o 4 = Great Britain (GB)
o 5 = Japan (JP)
o 6 = Saudi Arabia (SA)
o 7 = Australia (AUS)
* 00xxx0?: Distance Impulse Number
o 1 = 22188
o 2 = 22076
o 3 = 21960
o 4 = 21848
o 5 = 22304
o 6 = 22420
o 7 = 22532
Security Access
* 13861 = Adaptation Enabling
Adaptation
Channel 002: Service Reminder
* 0 = Service NOT Due
* 1 = Service Due
To reset the service reminder save 0 as new value.
Channe 003: Consumption Correction
* Standard Value: 100 %
* Display Range: 85...115 %
* Increments: 1 %
New Adaptation Value = Old Adaptation Value * Calculated Consumption / Old Display Value
Channel 004: Language
* 1 = German
* 2 = English
* 3 = French
* 4 = Italian
* 5 = Spanish
* 6 = Portuguese
* 7 = No Text
* 8 = Czech
Channel 009: Mileage/Odometer
* Increments: 1 = 10 km or 1 = 10 mi
The distance can only be changed once before the current value is not over 100 km/62 mi. After changing the value can be corrected within the next 5 km/3 mi of driving.
Channel 022: Production Mode
Channel 030: Fuel Gauge Adaptation
* Standard: 100
* Range: 120...136
* Increments: 1 Ohm
Channel 035: Speed Threshold
This value represents the speed threshold of the dynamic oil pressure system. The threshold can be raised in increments of 250 RPM.
Channel 038: Oil Minimum Detection
With this function the oil-minimum-warning at low oil level can be deactivated or activated.
Channel 039: Oil Level Sensor Adaptation
Determines if the TOG Sensor is installed or not.
Channel 040: Mileage since Service
* Increments: 1 = 100 km
Channel 041: Time since Service
* Increments: 1 = 1 day(s)
Channel 042: Minimum Distance to Service
* Increments: 1 = 1000 km
Channel 043: Maximum Distance to Service
Channel 044: Maximum Time to Service
* 365 = fixed Service Intervals (w/o Longlife)
* 730 = flexible Service Intervals (with Longlife)
Channel 045: Oil Quality
* 1 = fixed Service Intervals (w/o Longlife)
* 2 = flexible Service Intervals (with Longlife)
Channel 046: Total Consumption
Channel 047: Soot Entry
Channel 048: Thermal Load
Channel 049: Minimum Time to Service
