03G-906-016-BKE написал(а):;
; VCDS Label File
; Copyright й 2008 Ross-Tech, LLC
; Audi A4 (8E)
; Component: J248 - Engine (#01) - BKE/BRB 1.9l TDI-PD 85kW/115HP
; P/N: 03G-906-016-???
; includes measuring blocks, basis setting, coding, coding-ii,
; adaptation and security access
; This file is part of a redirection package,
; make sure you have all of the following files.
; 03-01.LBL
; 03G-906-016-BKE.LBL (1.9l TDI @ 115 HP - BKE/BRB)
; created on 17/Nov/2007 by Sebastian Stange (Sebastian@Ross-Tech.com)
; last modification on 19/Nov/2008
; requires VCDS 805.0 or newer
; measuring blocks & basic setting
001,0,Injection Quantity
001,1,Engine Speed,(G28),Specification (Idle): 860...940 RPM\nSpecification (Full Load): 2800...3200 RPM
001,2,Injection Quantity,,Specification (Idle): 3.0...9.0 mg/Str.\nSpecification (Full Load): 40.0...55.0 mg/Str.
001,3,Injection Duration,(specified),Specification (Idle): 3.0...9.0 ░CF\nSpecification (Full Load): 17.0...26.0 ░CF
001,4,Coolant,Temperature (G62),Range: -40.5...+135.0 ░C\nSpecification (Warm): 80.0...110.0 ░C
002,0,Idle Speed
002,1,Engine Speed,(G28),Specification (Idle): 860...940 RPM\nSpecification (Full Load): 2800...3200 RPM
002,2,Accel. Pedal Pos.,Sensor 1 (G79),Range: 0.0...100.0 %\nSpecification (Idle): 0.0 %\nSpecification (Full Load): 100.0 %
002,3,Operation Status,,See Label File
; xxxxxxx1 = Climate Control ON
; xxxx1xxx = Idle Switch closed
; xxx1xxxx = Kick-Down (only Automatic Transmission)
; x1xxxxxx = Idle Speed raised
002,4,Coolant,Temperature (G62),Range: -40.5...+135.0 ░C\nSpecification (Warm): 80.0...110.0 ░C
003,0,Exhaust Gas Recirculation (EGR)
003,1,Engine Speed,(G28),Specification (Idle): 860...940 RPM\nSpecification (Full Load): 2800...3200 RPM
003,2,Exhaust Gas,Recirculat. (spec.),Specification (Idle): 200.0...280.0 mg/Str.\nSpecification (Full Load): 750.0...1200.0 mg/Str.
003,3,Exhaust Gas,Recirculat. (actual),Specification (Idle): 180.0...300.0 mg/Str.\nSpecification (Full Load): 800.0...1100.0 mg/Hub
003,4,Exhaust Gas,Recirc. Duty Cycle,Specification (Idle): 20.0...90.0 %\nSpecification (Full Load): 90.0...100.0 %
B003,0,Exhaust Gas Recirculation (EGR)
; Ignition ON, Engine ON (Idling)
; Activate Basic Setting
; Press and Hold both Brake Pedal and Gas Pedal
; Exhaust Gas Recirculation (EGR) is alternately switched on and off
; The Deviation between "EGR ON" and "EGR OFF" must at least be 100.0 mg/Str.
B003,1,Engine Speed,(G28),Specification (Idle): 860...940 RPM\nSpecification (Basic Setting): 1350...1450 RPM
B003,2,Exhaust Gas,Recirculat. (spec.)
B003,3,Exhaust Gas,Recirculat. (actual),Specification (inactive): 410.0...650.0 mg/Str.\nSpecification (active): 100.0...400.0 mg/Str.\nDeviation (active/inactive): min. 100.0 mg/Str.
B003,4,Exhaust Gas,Recirc. Duty Cycle,Specification (inactive): 0.0...10.0 %\nSpecification (active): 19.0...40.0 %
004,0,Pump-Jet Valves
004,1,Engine Speed,(G28),Specification (Idle): 860...940 RPM\nSpecification (Full Load): 2800...3200 RPM
004,2,Injection Start,(specified),Specification (Idle): 4.0 ░v.OT ... 2.0 ░n.OT\nSpecification (Full Load): 13.0...25.0 ░v.OT
004,3,Injection Duration,(specified),Specification (Idle): 3.0...9.0 ░CF\nSpecification (Full Load): 17.0...26.0 ░CF
004,4,Torsion Value,,Specification: -3...+3 ░CF
005,0,Start Conditions (last Engine Start)
005,1,Engine Speed,(G28),Specification (Idle): 860...940 RPM\nSpecification (Full Load): 2800...3200 RPM
005,2,Start Injection,Quantity,Specification: 7.0...19.0 mg/Str.
005,3,Start,Synchronisation,See Label File
; Interim Values are the Sum of the individual Values.
; 001 = Self Synchronisation Camshaft active
; 002 = Self Synchronisation Crankshaft active
; 004 = Engine running
; 008 = Engine Synchronisation validated
; 016 = Engine Synchronisation successful
; 032 = Self Synchronisation Camshaft-Sensor successful
; 064 = Self Synchronisation Crankshaft-Sensor successful
; 128 = First valid Tooth recognized
005,4,Coolant,Temperature (G62),Range: -40.5...+135.0 ░C\nSpecification (Warm): 80.0...110.0 ░C
006,0,Cruise Control System (CCS)
006,1,Vehicle Speed,(actual)
006,2,Pedal Monitoring,,See Label File
; xxxxxxx1 = Brake Light Switch operated
; xxxxxx1x = Brake Pedal Switch operated
; xxxxx1xx = Clutch Pedal Switch operated
; xxxx1xxx = CCS enabled
; xxx1xxxx = ACC enabled
; xx1xxxxx = Main Switch
; 00xxxxxx = ACC/CCS Mode not active
; 10xxxxxx = Status override
; 01xxxxxx = ACC/GRA active
; 11xxxxxx = ACC blocked
006,3,Accel. Pedal Pos.,Sensor 1 (G79),Range: 0.0...100.0 %
006,4,Switch Monitoring,,See Label File
; xxxxxxx? = Stuck ON
; xxxxxx?x = Pressed OFF
; xxxxx?xx = Decelerate (-)
; xxxx?xxx = Accelerate (+)
; xxx?xxxx = Set (SET)
; xx?xxxxx = Resume (RESET)
; ?xxxxxxx = Stuck ON (Hardware)
007,0,Temperatures
007,1,Fuel Temperature,(G81),Specification (Cold): ca. Ambient Temperature
007,3,Intake Air,Temperature (G72),Specification (Cold): ca. Ambient Temperature
007,4,Coolant,Temperature (G62),Range: -40.5...+135.0 ░C\nSpecification (Cold): ca. Ambient Temperature
008,0,Injection Quantity Limitation I (Torque Limitation)
008,1,Engine Speed,(G28),Specification (Idle): 860...940 RPM\nSpecification (Full Load): 2800...3200 RPM
008,2,Torque Request,(Driver),Specification (Idle): -5.0...0.0 Nm\nSpecification (Full Load): 270.0...340.0 Nm
008,3,Torque Limitation,,Specification (Idle): 100.0...200.0 Nm\nSpecification (Full Load): 270.0...320.0 Nm
008,4,Smoke Limitation,,Specification (Idle): 100.0...200.0 Nm\nSpecification (Full Load): 270.0...320.0 Nm
009,0,Injection Quantity Limitation II (Torque Limitation)
009,1,Engine Speed,(G28),Specification (Idle): 860...940 RPM\nSpecification (Full Load): 2800...3200 RPM
009,2,Torque Request,(Cruise Control)
009,3,Transmission,Limitiation
009,4,Torque Restriction
010,0,Charge Pressure Control
010,1,Mass Air Flow,(actual),Specification (Idle): 180.0...300.0 mg/Str.\nSpecification (Full Load): 800.0...1100.0 mg/Str.
010,2,Atmospheric,Pressure,Specification: 900.0...1100.0 mbar
010,3,Boost Pressure,(actual),Specification (Idle): 900.0...1150.0 mbar\nSpecification (Full Load): 1850.0...2300.0 mbar
010,4,Accel. Pedal Pos.,Sensor 1 (G79),Specification (Idle): 0.0 %\nSpecification (Full Load): 100.0 %
011,0,Charge Pressure Control
011,1,Engine Speed,(G28),Specification (Idle): 860...940 RPM\nSpecification (Full Load): 2800...3200 RPM
011,2,Boost Pressure,(specified),Specification (Idle): 900.0...1150.0 mbar\nSpecification (Full Load): 1900.0...2200.0 mbar
011,3,Boost Pressure,(actual),Specification (Idle): 900.0...1150.0 mbar\nSpecification (Full Load): 1850.0...2300.0 mbar
011,4,Charge Pressure,Control Duty Cycle,Specification (Idle): 40.0...90.0 %\nSpecification (Full Load): 20.0...80.0 %
B011,0,Charge Pressure Control
; Charge Pressure Control is alternately switched on and off
; The Deviation between "active" and "inactive" must at least be 80.0 mbar
B011,1,Engine Speed,(G28),Specification (Idle): 860...940 RPM
B011,2,Charge Pressure,Control Status,Range: ON/OFF
B011,3,Boost Pressure,(actual),Deviation (active/inactive): min. 80.0 mbar
B011,4,Charge Pressure,Control Duty Cycle,Specification (inactive): 0.0...10.0 %\nSpecification (active): 90.0...100.0 %
012,0,Glow Plugs
012,1,Glow Status,,See Label File
; 00000000 = Waiting for Coolant Temperature
; 00000001 = Waiting for ECO Start Request
; 00010000 = Pre-Glow
; 01010000 = No Pre-Glow
; 10110000 = Post-Glow
; 11000000 = No Post-Glow
; 11110000 = Interim Glow
; 00110000 = Readiness Glowing
; 01110000 = Glow Start
; 10110001 = Waiting for Post-Glow
; 11010000 = No Post-Glow
; 11110001 = Waiting for Interim Glow
; 11111111 = Glowing OFF
012,2,Pre-Glow Period
012,3,Supply Voltage,(Terminal 30),Specification: 13.0...15.0 V
012,4,Coolant,Temperature (G62),Range: -40.5...+135.0 ░C\nSpecification (Warm): 80.0...110.0 ░C
013,0,Idle Stabilization (Injection Quantity Deviation)
013,1,Injection Quantity,Deviation Cyl. 1,Specification (Idle): -2.8...+2.8 mg/Str.
013,2,Injection Quantity,Deviation Cyl. 2,Specification (Idle): -2.8...+2.8 mg/Str.
013,3,Injection Quantity,Deviation Cyl. 3,Specification (Idle): -2.8...+2.8 mg/Str.
013,4,Injection Quantity,Deviation Cyl. 4,Specification (Idle): -2.8...+2.8 mg/Str.
015,0,Fuel Consumption
015,1,Engine Speed,(G28),Specification (Idle): 860...940 RPM\nSpecification (Full Load): 2800...3200 RPM
015,2,Engine Torque,,Specification (Idle): 25.0...60.0 Nm
015,3,Fuel Consumption
015,4,Torque Request,(Driver),Specification (Idle): -5.0...0.0 Nm
016,0,Auxiliary Heating
016,1,Generator Load,,Specification: 5.0...95.0 %
016,2,Auxiliary Heating,Shut-Off Conditions,See Label File
; xxxxxxx1 = Coolant Temparature above 80.0 ░C
; xxxxxx1x = Generator Malfunction
; xxxxx1xx = Battery Voltage too Low
; xxxx1xxx = Engine Speed too Low
; xxx1xxxx = Start Delay active
; xx1xxxxx = System Malfunction [Coolant Temp. Sensor (G62) OR Intake Air Temp. Sensor (G72) FAULTY]
; 1xxxxxxx = Ambient Temperature above 5.0 ░C
016,3,Heating Element,Activation,1x - Relay for Coolant Preheat. (High Output - J360) activated\nx1 - Relay for Coolant Preheat. (Low Output - J359) activated
016,4,Supply Voltage,(Terminal 30),Specification: 13.0...15.0 V
017,0,Readiness Code (EOBD)
017,1,CARB,Mode 01 DATA A,See Label File
; x---0000 = No Fault Codes stored
; 0---xxxx = MIL OFF
; 1---xxxx = MIL ON
017,2,CARB,Mode 01 DATA B,See Label File
; -xxx-xx1 = Activation Misfire Recognition OIN
; -xxx-x1x = Activation Fuel Supply System ON
; -xxx-1xx = Activation Comprehensive Components ON
; -xxx-xxx = EOBD-Test Misfire Recognition finished
; -x0x-xxx = EOBD-Test Fuel Supply System finished
; -0xx-xxx = EOBD-Test Comprehensive Components finished
017,3,CARB,Mode 01 DATA C,See Label File
; xx1----- = Activation Oxygen/Lambda Sensor ON
; x1x----- = Activation Oxygen/Lambda Sensor Heating ON
; 1xx----- = Activation Exhaust Gas Recirculation (EGR) ON
017,4,CARB,Mode 01 DATA D,See Label File
; xx0----- = EOBD-Test Oxygen/Lambda Sensor finished
; x0x----- = EOBD-Test Oxygen/Lambda Sensor Heating finished
; 0xx----- = EOBD-Test Exhaust Gas Recirculation (EGR) finished
018,0,Injector Status
; 000 = No Faults detected
; 002 = Control while Starting
; 004 = Small Injection Quantity or Injector faulty
; 008 = Maximum Current reached
; 016 = Begin of Injection Period (BIP) out of Specification
; 032 = Samples too low
; 064 = Conversion Error
; 128 = Begin of Injection Period (BIP) not possible
018,1,Injector Status,Cylinder 1,Specification: 0 (See Label File)
018,2,Injector Status,Cylinder 2,Specification: 0 (See Label File)
018,3,Injector Status,Cylinder 3,Specification: 0 (See Label File)
018,4,Injector Status,Cylinder 4,Specification: 0 (See Label File)
020,0,Injection Quantity Limitation (from ABS)
020,1,Engine Speed,(G28),Specification (Idle): 860...940 RPM\nSpecification (Full Load): 2800...3200 RPM
020,2,Engine Torque
020,3,ASR Limitation
020,4,MSR Limitation
021,0,CAN-Databus Status (Powertrain)
021,1,Engine Electronics
021,2,Transmission,Electronics
021,3,Brake Electronics
021,4,Brake Electronics,(ESP)
022,0,Shut-Off Status
022,1,Shut-Off Status,Cruise Control
022,2,Switch Monitoring,Cruise Control,See Label File
; 000 = Neutral
; 001 = OFF (Switched)
; 002 = OFF (Tipped)
; 003 = SET (CCS ON)
; 004 = Tip Down
; 005 = Deceleration (-)
; 006 = RESUME/RESET
; 007 = Tip Up
; 008 = Acceleration (+)
022,3,Shut-Off Status,Charge Pressure,See Label File
; 001 = Cold Start
; 002 = System Malfunction
; 004 = Control Deviation
; 016 = Diagnostic Interference
022,4,Shut-Off Status,Climate Control,See Label File
; 001 = Launch Condition
; 002 = Shut-Off: Launch Condition
; 004 = Acceleration Condition
; 008 = Shut-Off: Acceleration Condition
; 016 = Shut-Off: Start Condition
; 032 = System Malfunction recognized
; 064 = Shut-Off: System Malfunction recognized
; 128 = Shut-Off: Idle Speed too Low
023,0,Injector Switch Time Deviation
023,1,Switch Time Deviat.,Cylinder 1,Specification: -100.0...+100.0 ms
023,2,Switch Time Deviat.,Cylinder 2,Specification: -100.0...+100.0 ms
023,3,Switch Time Deviat.,Cylinder 3,Specification: -100.0...+100.0 ms
023,4,Switch Time Deviat.,Cylinder 4,Specification: -100.0...+100.0 ms
025,1,Engine Speed,(G28),Specification (Idle): 810...940 RPM\nSpecification (Full Load): 2800...3200 RPM
026,0,Checksum
026,1,Checksum
028,0,Accelerator Pedal Position Sensor
028,1,Accel. Pedal Pos.,Sensor 1 (G79),0 % = 0.60...0.91 V\n100 % = 3.80...4.94 V
028,2,Accel. Pedal Pos.,Sensor 2 (G185),0 % = 0.30...0.45 V\n100 % = 1.90...2.58 V
028,3,Operation Status,,See Label File
028,4,Accel. Pedal Pos.,Sensor 1 (G79),Range: 0.0...100.0 %\nSpecification (Idle): 0.0 %\nSpecification (Full Load): 99.0...100.0 %
029,0,Temperature and Oil Level Sensor (TOG)
029,1,Oil Temperature
029,2,Oil Level
041,0,Exhaust Gas Recirculation (EGR) && Intake Manifold Flap
041,1,Position (Spec.),Intake Flap
041,2,Position (Spec.),EGR-Actuator
041,3,Position (Act.),EGR-Actuator
041,4,Exhaust Gas,Recirc. Duty Cycle
042,0,Exhaust Gas Recirculation (EGR) && Intake Manifold Flap
042,1,Offset Correction,EGR-Actuator,See Label File
; Mileage dependant Correction Value which switches with
; increasing Mileage towards 0 (per 10.000 km about 1.0 %).
: Specification ( 0 km): -16.0 % with ▒3.0 % Tolerance
; Specification (40.000 km): -12.0 % with ▒3.0 % Tolerance
; Specification (80.000 km): -8.0 % with ▒3.0 % Tolerance
042,2,EGR-Actuator,Adaption
042,3,Position (Act.),Intake Flap
042,4,Position (Act.),EGR-Actuator
051,0,Engine Speed Recognition
051,1,Engine Speed
051,2,Camshaft Speed,,Specification: Engine Speed/2 = ▒50 U/min
051,3,Start,Synchronisation,See Label File
; 000 = Basic Initialisiation
; 001 = Counter Reset
; 002 = Engine Standstill OR Malfunction
; 003 = Transition States
; 004 = Plausibility Phase
; 005 = Plausibility Phase
; 006 = Plausibility Phase
; 008 = Plausibility Phase
; 016 = Phase Determination
; 028 = Redundant Start
; 032 = Synchronisation Phase
; 033 = System Positioning
; 048 = Sequential Counter activated
; 064 = System waiting for Engine Standstill
; 128 = Dynamic Plausibility
051,4,Shut-Off Status,Injection Sequence
055,1,Control Module,Coding,General Malfunction Status
055,2,Control Module,Coding
055,3,Malfunction Path,EEPROM
055,4,Malfunction Path,Communication
056,1,Malfunction Path,Voltage (MIN)
056,2,Malfunction Path,Voltage (MAX)
056,3,Malfunction Path,Shut-Off Status
056,4,Reset Status
062,0,Engine Cooling (Temperatures)
062,1,Coolant Temperat.,Engine Output,Specification: min. 75.0 ░C
062,2,Coolant Temperat.,Cooler Output,Specification: min. 75.0 ░C
062,3,Ambient,Temperature,Specification: -30.0...+50.0 ░C
062,4,Intake Air,Temperature,Specification: 5.0...80.0 ░C
063,0,Engine Cooling (Climate Control)
063,1,Refrigerant,Pressure,Specification (A/C OFF): 0.00...8.00 bar\nSpecification (A/C ON): 5.00...30.00 bar
063,2,Load Torque,,Specification (A/C OFF): 0 Nm\nSpecification (A/C ON): 2...10 Nm
063,3,Cooling Request
063,4,Shut-Off Status,Climate Control,See Label File
064,0,Engine Cooling
064,1,Coolant,Temperature (G62),Range: -40.5...+135.0 ░C\nSpecification (Warm): 80.0...110.0 ░C
064,2,Coolant Temperat.,Cooler Output,Specification: min. 75.0 ░C
064,3,Coolant Fan 1,Duty Cycle,Specification (Coolant Fan OFF): 8.0...9.0 %\nSpecification (Coolant Fan ON): 10.0...100.0 %
080,0,Advanced Control Module Identification I
081,0,Advanced Control Module Identification II
081,1,Vehicle Ident.,Number (VIN)
082,0,Advanced Control Module Identification III
086,0,EOBD
087,0,EOBD
089,0,EOBD
090,0,EOBD/OBD-2 Exhaust Gas Recirculation (EGR) I
090,1,Engine Speed,(G28),Specification (Idle): 860...940 RPM\nSpecification (Full Load): 2800...3200 RPM
090,2,Injection Quantity,,Specification (Idle): 3.0...9.0 mg/Str.\nSpecification (Full Load): 40.0...55.0 mg/Str.
090,3,Exhaust Gas,Recirculat. (spec.),Specification (Idle): 200.0...280.0 mg/Str.\nSpecification (Full Load): 750.0...1200.0 mg/Str.
090,4,Status,Control Deviation
125,0,CAN-Databus Communication (Powertrain)
125,1,Transmission,,Range: Transm. 1/Transm. 0
125,2,Brake Electronics,,(J104),Range: ABS 1/ABS 0\nSpecification: ABS 1
125,3,Instrument Cluster,(J285),Range: Instruments 1/Instruments 0\nSpecification: Instruments 1
125,4,Airbag,(J234),Wertebereich: Airbag 1/Airbag 0\nSpecification: Airbag 1
126,0,CAN-Databus Communication (Powertrain)
126,1,Climate Control,(J255),Range: A/C 1/A/C 0
127,0,CAN-Databus Communication (Powertrain)
127,4,Steering Wheel,Electronics (J527),Range: St. Wheel 1/St. Wheel 0
225,0,CAN-Databus Timeout (Powertrain)
225,1,Transmission
225,2,Brake Electronics,,(J104)
225,3,Instrument Cluster,(J285)
225,4,Airbag,(J234)
226,0,CAN-Databus Timeout (Powertrain)
226,1,Climate Control,(J255)
227,0,CAN-Databus Timeout (Powertrain)
227,4,Steering Wheel,Electronics (J527)
; Coding
C00,Engine Control Unit (J248/J623) Coding
C01,00?0xxx: Configuration I
C02,0 = Standard (Aux. Heater not installed)
C03,2 = Aux. Heater installed
C04,00x0?xx: Powertrain
C05,0 = Front-Wheel-Drive (FWD)
C06,1 = All-Wheel-Drive (AWD)
C07,00x0x?x: CAN-Databus
C08,+1 = Anti-Lock Braking System (ABS)
C09,+2 = Airbags
C10,+4 = Climate Control (Climatronic)
C11,00x0xx?: Transmission
C12,1 = 5-Speed Manual Transmission
C13,2 = 6-Speed Manual Transmission
; Coding-II
L00,Engine Control Unit (J248/J623) Coding-II
L01,11463 = Cruise Control Activation
L02,16167 = Cruise Control Deactivation
; Adaptation
A050,0,Immobilizer (Vehicle Data learning)
A050,1,Status
A050,5,Immobilizer (Vehicle Data learning)
A050,6,Please enter the Immobilizer PIN/SKC of the Instrument Cluster (OLD PIN/SKC).
A050,7,After that the Learning Process is being initiated the new Engine Control
A050,8,Module adopts the Vehicle-Identification-Number (VIN) and Immobilizer
A050,9,Identification (IMMO-ID) of the Vehicle (from the OLD Instrument Cluster).
A050,10,Once the Adaptation is done switch the Ignition OFF for about 2 Minutes.
A091,0,Immobilizer Status
A091,5,Immobilizer Status (Read Only)
A091,6,0 = Immobilizer not matched (NEW)
A091,7,1 = Immobilizer disabled
A091,8,4 = Immobilizer matched (System OK)
; Security Access
S00,Engine Control Unit (J248/J623) Security Access
S01,Prior to adapting a new USED Engine Control Unit the
S02,Vehicle specific PIN/SKC (IMMO-Login) of the new USED
S03,Engine Control Unit has to be used to enable the adaptation.
S04,You'll find the PIN/SKC on the Key Tag of the additional
S05,Key (of the Donor Car) or you can acquire it through your
S06,responsible Distribution Center or Importer.
BVVIT написал(а):... найти 01j927156.lbl ...
; VCDS Label File
; Copyright © 2007-2011 Ross-Tech, LLC
; Seat Ibiza (6L) / Skoda Fabia (6Y) / VW Polo (9N)
; Component: J104 - Brake Electronics (#03) - Bosch 5.7 ABS/EDS
; P/N: 6Q0-907-37?-???
; includes measuring blocks, basic setting, coding and misc
; This file is part of a label file package,
; 6Q-03.LBL
; 6R-03.LBL
; 6Q0-907-37x-ABS.LBL (ABS/EDS 5.7)
; 6Q0-907-37x-ABS2.LBL (ABS/EDS MK60)
; 6Q0-907-37x-ASR.LBL (ABS/EDS/ASR 5.7)
; 6Q0-907-37x-ESP.LBL (ABS/EDS/ASR/ESP 5.7)
; 6R0-907-37x-ABS.LBL (ABS/EDS 8.0)
; 6R0-907-37x-ASR.LBL (ABS/EDS/ASR 8.0)
; 6R0-907-37x-ESP.LBL (ABS/EDS/ASR/ESP 8.0)
; created on 22/Oct/2007 by Sebastian Stange (sebastian@ross-tech.com)
; last modification on 20/Jun/2011
; requires VCDS 10.6.4 or newer
001,0,Wheel Speed
001,1,Wheel Speed,Front Left,Display Range: 0.0...255.0 km/h
001,2,Wheel Speed,Front Right,Display Range: 0.0...255.0 km/h
001,3,Wheel Speed,Rear Left,Display Range: 0.0...255.0 km/h
001,4,Wheel Speed,Rear Right,Display Range: 0.0...255.0 km/h
002,0,Status Bits
002,1,Brake Light Switch,,Display Range: 0/1
002,2,Return Flow Pump,,Display Range: 0/1
002,3,Solenoid Valve,Relay,Display Range: 0/1
B010,0,Brake System Bleeding
B010,1,System Status,,
B010,2,,,
B010,3,,,
B010,4,,,
; coding
C00,Brake Electronics (J104/Bosch 5.7 ABS) Coding
C01,00044 with Manual Transmission
C02,00045 with Automatic Transmission
; misc
SN,ABS/EDS Bosch 5.7
; VCDS Label File
; Copyright © 2011 Ross-Tech, LLC
; Skoda Fabia (6Y) / VW Polo (9N)
; Component: J104 - Brake Electronics (#03) - MK60 ABS
; 6Q-03.LBL
; 6R-03.LBL
; created on 22/Oct/2007 by Sebastian Stange (Sebastian@Ross-Tech.com)
; last modification on 08/Dec/2011
; requires VCDS 11.11.1 or newer
; measuring blocks
001,0,Current Wheel Speed
001,1,Speed Sensor,Front Left (G47),Range: 0.0...255.0 km/h
001,2,Speed Sensor,Front Right (G45),Range: 0.0...255.0 km/h
001,3,Speed Sensor,Rear Left (G46),Range: 0.0...255.0 km/h
001,4,Speed Sensor,Rear Right (G44),Range: 0.0...255.0 km/h
002,0,Starting Wheel Speed
002,1,Speed Sensor,Front Left (G47),Specification: 0.0...254.0 km/h (255.0 km/h = standing)
002,2,Speed Sensor,Front Right (G45),Specification: 0.0...254.0 km/h (255.0 km/h = standing)
002,3,Speed Sensor,Rear Left (G46),Specification: 0.0...254.0 km/h (255.0 km/h = standing)
002,4,Speed Sensor,Rear Right (G44),Specification: 0.0...254.0 km/h (255.0 km/h = standing)
003,0,Switches and Warning Lights
003,1,Brake Light,Switch (F),Range: Not Oper./Operated
003,2,Brake System,Warning L. (K118),Range: ON/OFF
003,3,ABS,Warning L. (K47),Range: ON/OFF
011,0,Speed Encoder Errors (Front Left)
012,0,Speed Encoder Errors (Front Right)
013,0,Speed Encoder Errors (Rear Left)
014,0,Speed Encoder Errors (Rear Right)
125,0,CAN-Databus Powertrain (Communication)
125,1,Engine Control,Module (ECM),Range: Engine 1/Engine 0\nSpecification: Engine 1
125,4,Transmission,Control Module,Range: Transm. 1/Transm. 0\nSpecification: Transm. 1
225,0,CAN-Databus Powertrain (Timeout)
225,1,Engine Control,Module (ECM)
225,4,Transmission,Control Module
; VCDS Label File
; Component: J104 - Brake Electronics (#03) - Bosch 5.7 ABS/ASR/EDS
; 6Q-03.LBL
; 6R-03.LBL
001,0,Wheel Speed
002,0,Status Bits
003,0,Traction Control (ASR)
003,1,Engine Speed
003,2,Engine Torque,,0.0 % = Schubphase\n20.0...30.0 % = Idle\n100.0 % = Maximum Torque
003,3,ASR-Button,,0 = Not Oper.\n1 = Operated
004,0,Electronic Differential Lock (EDL)
004,1,Standing,Time
004,2,EDL-Shut Off,Over Temp.,0 = EDL during the last 20 start cycles not deactivated\n1 = EDL during the last 20 start cycles deactivated
B010,2,,,
B010,3,,,
B010,4,,,
; coding
C00,Brake Electronics (J104/Bosch 5.7 ABS/ASR) Coding
C01,00060 = AME/AQW/ATZ with Manual Transmission
C02,00124 = AMF/AUA/BKY/BBY/BBZ with Manual Transmission
C03,00125 = AMF/AUA/BKY/BBY with Automatic Transmission
C04,00188 = ATD/ASZ/AMF/AZL/BBX/BJX/BKV/BLT/AXR with Manual Transmission
; misc
SN,ABS/ASR Bosch 5.7
; VCDS Label File
; Component: J104 - Brake Electronics (#03) - Bosch 5.7 ABS/ASR/EDS/ESP
; Includes measuring blocks, basic setting, login, coding and misc
; This File is part of a Label File Package,
; make sure you have all of the following Files.
; 6Q-03.LBL
; 6R-03.LBL
001,0,Wheel Speed
001,1,Wheel Speed,Front Left,Display Range: 0...255 km/h
001,2,Wheel Speed,Front Right,Display Range: 0...255 km/h
001,3,Wheel Speed,Rear Left,Display Range: 0...255 km/h
001,4,Wheel Speed,Rear Right,Display Range: 0...255 km/h
B001,0,Steering Angel Sensor (G85) Alignment
B001,1,Steering Angel,Sensor (G85),
B001,2,Alignment,,
B001,3,Alignment,Status,Specification: OK
B001,4,,,
002,0,Switches && Buttons
002,1,Brake Test Switch,,Display Range: 0/operated
002,2,Brake Light Switch,,Display Range: 0/operated
002,3,Parking Brake,Button,Display Range: 0/operated
002,4,ESP-Passive,Button,Display Range: 0/operated
003,0,Engine Data
003,1,Engine Speed
003,2,Engine Torque
003,3,Engine Torque,(loss)
003,4,Throttle Valve Angle
B003,0,System Function Test Activation
B003,1,Status,,
B003,2,,,
B003,3,,,
B003,4,,,
004,0,Standing Time && EDL-T Flag
004,1,Standing Time
004,2,EDL-T Flag,,Display Range: ON/OFF\nSpecification: OFF
005,1,Steering Angle,Sensor (G85),Display Range: -720.0...+720.0 °\nTolerance: +/- 5.0 °
005,2,Turn Rate,,Display Range: -69.0...+69.0 °/s
005,3,Brake Pressure,,Display Range: -41.0...+292.0 bar\n\n-41.0 bar = short to ground\n290 bar = short to plus
005,4,Lateral,Acceleration,Display Range: -25.0...+25.0 m/sІ
006,1,Voltage Supply,(Terminal 30),Specification: 9.8...17.4 V
006,2,Valve Relay,,Display Range: ON/OFF\nSpecification: ON
006,3,Return Flow Pump,Status,Display Range: ON/OFF\nSpecification (Ignition ON/Engine OFF): OFF
006,4,Workshop Code
B010,1,Status,,
B010,2,,,
B010,3,,,
B010,4,,,
125,1,Steering Angle,Sensor,Specification: Steer. ang. 1
125,2,Automatic,Transmission,Specification: Transm. 1
125,3,Engine,,Specification: Engine 1
125,4,Instrument Cluster,,Specification: Instruments 1
; login
L00,Brake Electronics (J104) Login
L01,40168 = Basic Setting Enabling
; coding
C00,Brake Electronics (J104/Bosch 5.7 ABS/ASR/ESP) Coding
C01,Refer to the Factory Repair Manual for Coding Details.
C02,
C03,If a Factory Repair Manual is not available or does not
C04,contain Coding Information please contact Ross-Tech or
C05,your local VCDS Reseller/Distributor for Assistance.
C06,
C07,http://www.ross-tech.com/contact.html
; misc
SN,ABS/ASR/ESP Bosch 5.7
; VCDS Label File
; Copyright © 2005-2012 Ross-Tech, LLC
; VW Golf/Jetta (1J/9M)
; Component: J234 - Airbag (#15) - VW5/VW51/VW61
; P/N: 6Q0-909-605-??? / 1C0-909-60?-???
; includes measuring blocks, adaptation and misc
; 6Q-15.LBL
; 6Q0-909-605-VW5.LBL (VW5/VW51/VW61)
; 6Q0-909-605-VW52.LBL (VW52)
; created by Steve Tomasic (steve_tomasic@hotmail.com)
; updated on 09/Oct/2005 by Sebastian Stange (sebastian@ross-tech.com)
; last modificationon on 02/Feb/2012
; requires VCDS 11.2.2 or newer
; measuring blocks
001,0,Ignitiers I (Front Airbags Stage 1 && Front Belt Tensioners)
001,1,Airbag (Stage 1),Driver Side,Specification: Correct\nDisplay Range: Correct/Signal too Low/Signal too High/Short to Ground/Short to Plus/Not Installed
001,2,Airbag (Stage 1),Passenger Side,Specification: Correct\nDisplay Range: Correct/Signal too Low/Signal too High/Short to Ground/Short to Plus/Not Installed
001,3,Belt Tensioner,Front Driver Side,Specification: Correct\nDisplay Range: Correct/Signal too Low/Signal too High/Short to Ground/Short to Plus/Not Installed
001,4,Belt Tensioner,Front Pass. Side,Specification: Correct\nDisplay Range: Correct/Signal too Low/Signal too High/Short to Ground/Short to Plus/Not Installed
002,0,Ignitiers II (Rear Belt Tensioners)
002,1,Belt Tensioner,Rear Driver Side,Specification: Correct\nDisplay Range: Correct/Signal too Low/Signal too High/Short to Ground/Short to Plus/Not Installed
002,2,Belt Tensioner,Rear Pass. Side,Specification: Correct\nDisplay Range: Correct/Signal too Low/Signal too High/Short to Ground/Short to Plus/Not Installed
003,0,Voltage && Seat. Occupation && Belt Inquiry I (Front)
003,1,Voltage Supply,,Specification: Correct
003,2,Occupied Seat,Sensor Pass. Side,Display Range: child/child seat/light adult/heavy adult/occupied/not occupied/not installed
003,3,Belt Inquiry,Front Driver Side,Specification: Not Installed/Belt Yes/Belt No\nDisplay Range: Signal too Low/Signal too High/Short to Ground/Short to Plus/Not Installed/Belt Yes/Belt No
003,4,Belt Inquiry,Front Pass. Side,Specification: Not Installed/Belt Yes/Belt No\nDisplay Range: Signal too Low/Signal too High/Short to Ground/Short to Plus/Not Installed/Belt Yes/Belt No
004,0,Belt Inquiry II (Rear)
004,1,Belt Inquiry,Rear Driver Side,Specification: Not Installed/Belt Yes/Belt No\nDisplay Range: Signal too Low/Signal too High/Short to Ground/Short to Plus/Not Installed/Belt Yes/Belt No
004,2,Belt Inquiry,Rear Pass. Side,Specification: Not Installed/Belt Yes/Belt No\nDisplay Range: Signal too Low/Signal too High/Short to Ground/Short to Plus/Not Installed/Belt Yes/Belt No
005,0,Igniters III (Side Airbags)
005,1,Side Airbag,Front Driver Side,Specification: Correct\nDisplay Range: Correct/Signal too Low/Signal too High/Short to Ground/Short to Plus/Not Installed
005,2,Side Airbag,Front Pass. Side,Specification: Correct\nDisplay Range: Correct/Signal too Low/Signal too High/Short to Ground/Short to Plus/Not Installed
005,3,Side Airbag,Rear Driver Side,Specification: Correct\nDisplay Range: Correct/Signal too Low/Signal too High/Short to Ground/Short to Plus/Not Installed
005,4,Side Airbag,Rear Pass. Side,Specification: Correct\nDisplay Range: Correct/Signal too Low/Signal too High/Short to Ground/Short to Plus/Not Installed
006,0,Seat Occupation (Rear)
006,1,Seat Occupation,Rear Driver Side,Display Range: Not Installed
006,2,Seat Occupation,Rear Pass. Side,Display Range: Not Installed
007,0,Igniters IV (Head Airbags)
007,1,Head-Level Airbag,Driver Side,Specification: Correct\nDisplay Range: Correct/Signal too Low/Signal too High/Short to Ground/Short to Plus/Not Installed
007,2,Head-Level Airbag,Passenger Side,Specification: Correct\nDisplay Range: Correct/Signal too Low/Signal too High/Short to Ground/Short to Plus/Not Installed
008,0,Crash Sensor I (Version)
008,1,Driver Side,Front
008,2,Passenger Side,Front
008,3,Driver Side,Rear
008,4,Passenger Side,Rear
009,0,Crash Sensor I (Identification)
009,1,Driver Side,Front
009,2,Passenger Side,Front
009,3,Driver Side,Rear
009,4,Passenger Side,Rear
010,0,Key Switch
010,1,Passenger,Airbag Status,Display Range: ON/OFF
010,2,Key Switch,Logic Contact 1,Display Range: too small/to Ground/to B+/on/off/not installed
010,3,Key Switch,Logic Contact 2,Display Range: too small/to Ground/to B+/on/off/not installed
; adaptation
A001,0,Front Passenger Airbag Deactivation
A001,1,Front Passenger,Airbag
A001,2,Current Status
A001,5,Front Passenger Airbag Deactivation
A001,6,0 = Airbag Enabled
A001,7,1 = Airbag Disabled
A001,8,
A001,9,Note: Refer to Service Manual!
A002,0,Front Driver Airbag Deactivation
A002,1,Front Driver,Airbag
A002,2,Current Status
A002,5,Front Driver Airbag Deactivation
A002,6,0 = Airbag Enabled
A002,7,1 = Airbag Disabled
A002,8,
A002,9,Note: Refer to Service Manual!
A003,0,Front Passenger Side Airbag Deactivation
A003,1,Front Passenger,Side Airbag
A003,2,Current Status
A003,5,Front Passenger Side Airbag Deactivation
A003,6,0 = Airbag Enabled
A003,7,1 = Airbag Disabled
A003,8,
A003,9,Note: Refer to Service Manual!
A004,0,Front Driver Side Airbag Deactivation
A004,1,Front Driver,Side Airbag
A004,2,Current Status
A004,5,Front Driver Side Airbag Deactivation
A004,6,0 = Airbag Enabled
A004,7,1 = Airbag Disabled
A004,8,
A004,9,Note: Refer to Service Manual!
A005,0,Front Passenger Belt Tensioner Deactivation
A005,1,Front Passenger,Belt Tensioner
A005,2,Current Status
A005,5,Front Passenger Belt Tensioner Deactivation
A005,6,0 = Belt Tensioner Enabled
A005,7,1 = Belt Tensioner Disabled
A005,8,
A005,9,Note: Refer to Service Manual!
A006,0,Front Driver Belt Tensioner Deactivation
A006,1,Front Driver,Belt Tensioner
A006,2,Current Status
A006,5,Front Driver Belt Tensioner Deactivation
A006,6,0 = Belt Tensioner Enabled
A006,7,1 = Belt Tensioner Disabled
A006,8,
A006,9,Note: Refer to Service Manual!
A007,0,Front Passenger Head Airbag Deactivation
A007,1,Front Passenger,Head Airbag
A007,2,Current Status
A007,5,Front Passenger Head Airbag Deactivation
A007,6,0 = Airbag Enabled
A007,7,1 = Airbag Disabled
A007,8,
A007,9,Note: Refer to Service Manual!
A008,0,Front Driver Head Airbag Deactivation
A008,1,Front Driver,Head Airbag
A008,2,Current Status
A008,5,Front Driver Head Airbag Deactivation
A008,6,0 = Airbag Enabled
A008,7,1 = Airbag Disabled
A008,8,
A008,9,Note: Refer to Service Manual!
A009,0,Rear Passenger Side Airbag Deactivation
A009,1,Rear Passenger,Side Airbag
A009,2,Current Status
A009,5,Rear Passenger Side Airbag Deactivation
A009,6,0 = Airbag Enabled
A009,7,1 = Airbag Disabled
A009,8,
A009,9,Note: Refer to Service Manual!
A010,0,Rear Driver Side Airbag Deactivation
A010,1,Rear Driver,Side Airbag
A010,2,Current Status
A010,5,Rear Driver Side Airbag Deactivation
A010,6,0 = Airbag Enabled
A010,7,1 = Airbag Disabled
A010,8,
A010,9,Note: Refer to Service Manual!
A011,0,Rear Passenger Belt Tensioner Deactivation
A011,1,Rear Passenger,Belt Tensioner
A011,2,Current Status
A011,5,Rear Passenger Belt Tensioner Deactivation
A011,6,0 = Belt Tensioner Enabled
A011,7,1 = Belt Tensioner Disabled
A011,8,
A011,9,Note: Refer to Service Manual!
A012,0,Rear Driver Belt Tensioner Deactivation
A012,1,Rear Driver,Belt Tensioner
A012,2,Current Status
A012,5,Rear Driver Belt Tensioner Deactivation
A012,6,0 = Belt Tensioner Enabled
A012,7,1 = Belt Tensioner Disabled
A012,8,
A012,9,Note: Refer to Service Manual!
A013,0,Passenger Seat Occupation Recognition Sensor Deactivation
A013,1,Passenger Seat,Recognition Sensor
A013,2,Current Status
A013,5,Passenger Seat Occupation Recognition Sensor Deactivation
A013,6,0 = Sensor Enabled
A013,7,1 = Sensor Disabled
A013,8,
A013,9,Note: Refer to Service Manual!
A014,0,Battery Separating Deactivation
A014,1,Battery Separating
A014,2,Current Status
A014,5,Battery Separating Deactivation
A014,6,0 = Battery Separating Enabled (Standard)
A014,7,1 = Battery Separating Disabled
A014,8,
A014,9,Note: Refer to Service Manual!
; misc
I,
; VCDS Label File
; VW Caddy (2K)
; Component: J234 - Airbag (#15) - VW52
; 6Q-15.LBL
; 6Q0-909-605-VW5.LBL (VW5)
; created on 10/Oct/2005 by Sebastian Stange (sebastian@ross-tech.com)
; last modification on 02/Feb/2012
; measuring blocks
001,0,Ignitiers I (Front Airbags && Front Belt Tensioners)
001,1,Airbag,Driver Side,Specification: Correct\nDisplay Range: Correct/Signal too Low/Signal too High/Short to Ground/Short to Plus/Not Installed
001,2,Airbag,Passenger Side,Specification: Correct\nDisplay Range: Correct/Signal too Low/Signal too High/Short to Ground/Short to Plus/Not Installed
010,0,Key Switch
125,1,Instrument Cluster,,Specification: Instruments 1
225,0,CAN-Databus Powertrain (TimeOut)
225,1,Instrument Cluster
; adaptation
A001,8,
A002,8,
A005,8,
A006,8,
; misc
I,
; VAG-COM Labeldatei
; Ford Galaxy (7M) / Seat Alhambra (7M) / VW Sharan (7M)
; Komponente: J446 - Einparkhilfe (#76)
; T/N: 7M3 919 283
; beinhaltet Messwertgruppen, Codierung und Anpassung
; erstellt am 13.10.2004 von Sebastian Stange (sebastian@ross-tech.com)
; letzte Дnderung: 08.08.2005
; benцtigt VAG-COM 402.3 oder neuer
; Messwertgruppen Informationen
001,0,Abstand der einzelnen Sensoren (255cm = kein Hindernis erkannt)
001,1,vorn,links,Wertebereich: 0...255 cm
001,2,vorn,links mitte,Wertebereich: 0...255 cm
001,3,vorn,rechts mitte,Wertebereich: 0...255 cm
001,4,vorn,rechts,Wertebereich: 0...255 cm
002,0,Abstand der einzelnen Sensoren (255cm = kein Hindernis erkannt)
002,1,hinten,links,Wertebereich: 0...255 cm
002,2,hinten,links mitte,Wertebereich: 0...255 cm
002,3,hinten,rechts mitte,Wertebereich: 0...255 cm
002,4,hinten,rechts,Wertebereich: 0...255 cm
003,1,kьrzester,Abstand vorn,Wertebereich: 0...255 cm
003,2,kьrzester,Abstand hinten,Wertebereich: 0...255 cm
003,3,Geschwindigkeit,[km/h],Wertebereich: 0...255 km/h
003,4,Versorgungs-,spannung,Sollwert: [ca. Batteriespannung]
004,1,Schaltzustand,Warnsummer,Wertebereich: Ton aus/Ton ein
004,2,Schaltzustand,Rьckwдrtsgang,Wertebereich: Rьckw. ja/Rьckw. nein
004,3,Zustand,Anhдngerkupplung,Wertebereich: Anh. ja/Anh. nein/nicht verbaut
004,4,Status,Heckklappe
005,1,Kontrollampe,Einparkhilfe,Wertebereich: LED aus/LED ein
005,2,Schalter,Einparkhilfe,Wertebereich Tast. aus/Tast. ein
006,0,Ausschwingzeit der Sensoren (vorn)
006,1,vorn,links,Wertebereich: 0.97...1.02 ms
006,2,vorn,links mitte,Wertebereich: 0.97...1.02 ms
006,3,vorn,rechts mitte,Wertebereich: 0.97...1.02 ms
006,4,vorn,rechts,Wertebereich: 0.97...1.02 ms
007,0,Ausschwingzeit der Sensoren (hinten)
007,1,hinten,links,Wertebereich: 0.97...1.02 ms
007,2,hinten,links mitte,Wertebereich: 0.97...1.02 ms
007,3,hinten,rechts mitte,Wertebereich: 0.97...1.02 ms
007,4,hinten,rechts,Wertebereich: 0.97...1.02 ms
080,0,Erweiterte Steuergerдt Identifikation I
; Codierungs Informationen
C0,J446 - Einparkhilfe
C1,0?xxx: 0 = Schaltgetriebe / 1 = Automatikgetriebe
C2,0x?xx: Einschaltsignalton (0 = aus / 1 = ein)
C3,0xx?x: Fahrzeugtyp (1 = Sharan)
C4,0xxx?: Karosserievariante (7 = Sharan)
; Anpassungs Informationen
A01,0,Lautstдrke (hinten)
A01,5,Lautstдrke-Warnsummer (hinten)
A01,6,Die Laustдrke lдsst sich von 2 bis 7 einstellen
A01,7,der Wert kann direkt Wдhrend der Eingabe ьberprьft
A01,8,werden indem dabei der Rьckwдrtsgang eingelegt wird.
A02,0,Frequenz (hinten)
A02,5,Frequenz-Warnsummer (hinten)
A02,6,Die Frequenz lдsst sich von 0 bis 4 einstellen
A02,7,der Wert kann direkt Wдhrend der Eingabe ьberprьft
A02,8,werden indem dabei der Rьckwдrtsgang eingelegt wird
A02,9,
A02,10,Wertebereich:
A02,11,0 = 500 Hz / 1 = 666 Hz / 2 = 800 Hz
A02,12,3 = 1000 Hz / 4 = 2000 Hz
A03,0,Lautstдrke (vorn)
A03,5,Lautstдrke-Warnsummer vorn
A03,6,Die Laustдrke lдsst sich von 2 bis 7 einstellen
A03,7,der Wert kann direkt Wдhrend der Eingabe ьberprьft
A03,8,werden indem dabei der Rьckwдrtsgang eingelegt wird.
A04,0,Frequenz (vorn)
A04,5,Frequenz-Warnsummer (vorn)
A04,6,Die Frequenz lдsst sich von 0 bis 4 einstellen
A04,7,der Wert kann direkt Wдhrend der Eingabe ьberprьft
A04,8,werden indem dabei der Rьckwдrtsgang eingelegt wird
A04,9,
A04,10,Wertebereich:
A04,11,0 = 500 Hz / 1 = 666 Hz / 2 = 800 Hz
A04,12,3 = 1000 Hz / 4 = 2000 Hz
; Seat Alhambra (7M) / VW Sharan (7M)
; Bauteil: J104 - Bremsenelektronik (#03) - MK25 ABS/EDS/ASR/ESP FWD
; T/N: 7M3-907-37?-???
; beinhaltet Messwertblцcke, Grundeinstellung und Login
; 1J-03.LBL
; 7M-03.LBL
; 1J0-907-37x-ABS.LBL (MK20 ABS)
; 1J0-907-37x-ESP-F.LBL (MK20 ESP FWD)
; 1J0-907-37x-ESP-A.LBL (MK20 ESP AWD)
; 7M3-907-37x-ABS.LBL (MK25 ABS)
; 7M3-907-37x-ESP-F.LBL (MK25 ESP FWD)
; 7M3-907-37x-ESP-A.LBL (MK25 ESP AWD)
; erstellt am 09.10.2007 von Sebastian Stange (Sebastian@Ross-Tech.com)
; letzte Дnderung: 09.10.2007
; benцtigt VAG-COM 405.0 oder neuer
; Messwertblцcke & Grundeinstellung
001,0,Radgeschwindigkeit
001,1,Drehzahlfьhler,vorn links (G47),Wertebereich: 0.0...255.0 km/h
001,2,Drehzahlfьhler,vorn rechts (G45),Wertebereich: 0.0...255.0 km/h
001,3,Drehzahlfьhler,hinten links (G46),Wertebereich: 0.0...255.0 km/h
001,4,Drehzahlfьhler,hinten rechts (G44),Wertebereich: 0.0...255.0 km/h
002,0,Startgeschwindigkeit
002,1,Drehzahlfьhler,vorn links (G47),Wertebereich: 0.0...254.0 km/h (255.0 km/h = Stand/kein Messwert)
002,2,Drehzahlfьhler,vorn rechts (G45),Wertebereich: 0.0...254.0 km/h (255.0 km/h = Stand/kein Messwert)
002,3,Drehzahlfьhler,hinten links (G46),Wertebereich: 0.0...254.0 km/h (255.0 km/h = Stand/kein Messwert)
002,4,Drehzahlfьhler,hinten rechts (G44),Wertebereich: 0.0...254.0 km/h (255.0 km/h = Stand/kein Messwert)
003,0,Schalter und Kontrollampen
003,1,Bremslicht-,schalter (F),Wertebereich: unbetдtigt/betдtigt
003,2,Kontrollampe,Bremsenanlage,Wertebereich: aus/ein
003,3,Kontrollampe,ABS,Wertebereich: aus/ein
003,4,Kontrollampe,ASR/ESP,Wertebereich: aus/ein
004,0,Lenkwinkel / Querbeschleunigung / Drehrate
004,1,Lenkwinkel (G85),,Sollwert (Geradeausfahrt): ± 4.5 °
004,2,Querbeschleu-,nigung (G200),Sollwert (Stand): ± 1.5 m/sІ
004,3,Drehrate (G202),,Sollwert (Stand): ± 2.5 °/sІ
005,0,Bremsdruck
005,1,Geber fьr,Bremdruck (G201),Sollwert (Bremse nicht getreten): ± 7 bar
007,0,Pedalweg
007,1,Pedalweg,(unkorrigiert),
007,2,Pedalweg,(Offset korrigiert)
007,3,Pedalweg,(Offset)
011,0,Zahnradfehler/Teilungsfehler (vorne links)
012,0,Zahnradfehler/Teilungsfehler (vorne rechts)
013,0,Zahnradfehler/Teilungsfehler (hinten links)
014,0,Zahnradfehler/Teilungsfehler (hinten rechts)
B040,0,Abschaltung Geber fьr Lдngsbeschleunigung (G251)
B060,0,Nullabgleich Geber fьr Lenkwinkel (G85)
B063,0,Nullabgleich Geber fьr Querbeschleunigung (G200)
B066,0,Nullabgleich Geber 1 fьr Bremsdruck (G201)
B069,0,Nullabgleich Geber fьr Lдngsbeschleunigung (G251)
125,0,CAN-Datenbus Antrieb (Kommunikation)
125,1,Motorelektronik
125,2,Lenkwinkelsensor
125,3,Allradelektronik
125,4,Getriebelektronik
225,0,CAN-Datenbus Antrieb (TimeOut)
225,1,Motorelektronik
225,2,Lenkwinkelsensor
225,3,Allradelektronik
225,4,Getriebelektronik
; Login/Codierung 2
L00,Bremsenelektronik (J104) Login/Codierung 2
L01,40168 = Freischaltung Grundeinstellung
