Thursday,04,July,2013,19:37:26:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 3C0
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 53 55 56 62 72 76
VIN: WVWZZZ3CZ8P078272 Mileage: 173340km/107708miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: Sporadic communication error 1000
08-Auto HVAC -- Status: Cannot be reached 1100
09-Cent. Elect. -- Status: Cannot be reached 1100
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Cannot be reached 1100
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: Cannot be reached 1100
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Cannot be reached 1100
52-Door Elect, Pass. -- Status: Cannot be reached 1100
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: Malfunction 1010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: Cannot be reached 1100
76-Park Assist -- Status: Cannot be reached 1100
Address 01: Engine Labels: 03G-906-018-BKP.clb
Part No SW: 03G 906 018 FG HW: 03G 906 018 FG
Component: R4 2.0l PPD1.5 G 0907
Revision: --H55--- Serial number: VWZCZ000000000
Coding: 0000078
Shop #: WSC 00028 028 00001
VCID: 6FE7CD657E862D1
5 Faults Found:
005714 - Please check DTC Memory of Transmission Controller
P1652 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 19
Reset counter: 40
Mileage: 173343 km
Time Indication: 0
Date: 2013.07.01
Time: 05:45:15
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
0.00 %
Voltage: 11.75 V
Bin. Bits: 00000001
Bin. Bits: 00000000
005685 - Powertrain Data Bus
P1635 - 009 - Missing Message from A/C Controller
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 16
Reset counter: 40
Mileage: 173343 km
Time Indication: 0
Date: 2013.07.01
Time: 05:45:16
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
0.00 %
Voltage: 11.75 V
Bin. Bits: 00000000
Bin. Bits: 00000000
005785 - Powertrain Data Bus
P1699 - 009 - Missing Message from Steering Wheel Electronics
Freeze Frame:
Fault Priority: 0
Fault Frequency: 16
Reset counter: 40
Mileage: 173343 km
Time Indication: 0
Date: 2013.07.01
Time: 05:45:16
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
0.00 %
Voltage: 11.75 V
Bin. Bits: 01000010
Bin. Bits: 00000000
049472 - Body Control Module (Central Electric)
U0140 - 009 - No Communications
Freeze Frame:
Fault Priority: 0
Fault Frequency: 11
Reset counter: 40
Mileage: 173343 km
Time Indication: 0
Date: 2013.07.01
Time: 05:45:17
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
0.00 %
Voltage: 11.75 V
Bin. Bits: 00000100
Torque: 1016.0 Nm
005488 - Engine Start Blocked by Immobilizer
P1570 - 008 -
Freeze Frame:
Fault Status: 11101000
Fault Priority: 4
Fault Frequency: 9
Reset counter: 40
Mileage: 173343 km
Time Indication: 0
Date: 2013.07.01
Time: 05:48:47
Freeze Frame:
RPM: 960 /min
Torque: 40.0 Nm
Speed: 0.0 km/h
0.00 %
Voltage: 11.75 V
Bin. Bits: 00011001
Bin. Bits: 00000000
Readiness: N/A
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 050 D HW: 02E 927 770 AE
Component: GSG DSG 081 1404
Revision: 09908010 Serial number: 00000705140015
Coding: 0000020
Shop #: WSC 04940 001 00001
VCID: 132FA195326EA91
2 Faults Found:
18036 - Powertrain Data Bus
P1628 - 000 - Missing Message from Steering Angle Sensor - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Reset counter: 40
Mileage: 173343 km
Time Indication: 0
Date: 2013.07.01
Time: 06:53:12
18275 - Powertrain Data Bus
P1867 - 000 - Missing Message from Steering Wheel (J527)
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Reset counter: 40
Mileage: 173343 km
Time Indication: 0
Date: 2013.07.01
Time: 06:53:12
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 D HW: 3C0 614 109 D
Component: J104 C4 440 V2 0003
Revision: --020--- Serial number: 00000776610042
Coding: 0000270
VCID: 1F47FDA5CEA6FD1
2 Faults Found:
00474 - Control Module for Immobilizer
004 - No Signal/Communication
Freeze Frame:
Fault Priority: 3
Fault Frequency: 9
Reset counter: 123
Mileage: 173343 km
Time Indication: 0
Date: 2013.07.01
Time: 06:53:15
Freeze Frame:
Speed: 0.0 km/h
Hex Value: 0x0000
Voltage: 11.50 V
Bin. Bits: 00011111
Count: 215
00778 - Steering Angle Sensor (G85)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Priority: 3
Fault Frequency: 9
Reset counter: 123
Mileage: 173343 km
Time Indication: 0
Date: 2013.07.01
Time: 06:53:15
Address 08: Auto HVAC
Cannot be reached
Address 09: Cent. Elect.
Cannot be reached
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
Component: J234__002 VW10 HI 1815
Revision: 19013000 Serial number: 0039DPQA5HP4
Coding: 0012338
VCID: 3B7F29357A7E811
No fault code found.
Address 16: Steering wheel
Cannot be reached
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 871 E HW: 3C0 920 871 E
Component: KOMBIINSTRUMENT VD1 1216
Revision: V0002000 Serial number: 00000000000000
Coding: 0007105
Shop #: WSC 02743 943 63898
VCID: 2649E84191FC2C9
2 Faults Found:
01336 - Data Bus for Comfort System
Freeze Frame:
Fault Priority: 2
Fault Frequency: 9
Reset counter: 123
Mileage: 173343 km
Time Indication: 0
Date: 2013.07.01
Time: 06:59:19
01771 - Control Module for Headlight Range (J431)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 163
Mileage: 173343 km
Time Indication: 0
Date: 2013.07.01
Time: 00:11:30
Address 19: CAN Gateway Labels: 3C0-907-530.lbl
Part No SW: 3C0 907 530 E HW: 3C0 907 951
Component: J533__Gateway H10 0080
Revision: H10 Serial number: 1200P07B28011E
Coding: FD817F0E0002021002
VCID: 234FF155E2CED91
4 Faults Found:
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 1
Fault Frequency: 1
Reset counter: 123
Mileage: 173343 km
Time Indication: 0
Date: 2013.07.01
Time: 06:53:12
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 163
Mileage: 173343 km
Time Indication: 0
Date: 2013.07.01
Time: 06:53:13
Freeze Frame:
Fault Status: 01110100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 123
Mileage: 173343 km
Time Indication: 0
Date: 2013.07.01
Time: 06:53:29
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 163
Mileage: 173343 km
Time Indication: 0
Date: 2013.07.01
Time: 00:11:31
Address 25: Immobilizer
Cannot be reached
Address 42: Door Elect, Driver
Cannot be reached
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.136 H08 1901
VCID: 356B3F0D5C5A571
2 Faults Found:
000 - -
Address 46: Central Conv.
Cannot be reached
Address 52: Door Elect, Pass.
Cannot be reached
Address 53: Parking Brake
Cannot be reached
Address 55: Xenon Range Labels: 5M0-907-357-V2.lbl
Part No SW: 5M0 907 357 B HW: 5M0 907 357 B
Component: AFS-Steuergeraet X024
Revision: 00H01000 Serial number:
Coding: 2311169
VCID: 336F0115522E491
Subsystem 1 - Part No: 7L6 941 329 A
Component: AFS-Lst.-Modul l 0002
Coding: 00000035
Subsystem 2 - Part No: 7L6 941 329 A
Component: AFS-Lst.-Modul r 0002
Coding: 00000035
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 163
Mileage: 173343 km
Time Indication: 0
Date: 2013.07.01
Time: 06:53:12
Freeze Frame:
Voltage: 11.64 V
Speed: 0.0 km/h
ABS 1
01328 - Convenience System Data Bus
013 - Check DTC Memory - MIL ON
Freeze Frame:
Fault Status: 11101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 123
Mileage: 173343 km
Time Indication: 0
Date: 2013.07.01
Time: 00:44:21
Freeze Frame:
Voltage: 11.36 V
Speed: 0.0 km/h
ABS 1
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left
Cannot be reached
Address 72: Door, Rear Right
Cannot be reached
Address 76: Park Assist
Cannot be reached
End ---------------------------------------------------------------------
