Immobilizer III Immobilizer Swapping (Kessy)
From Ross-Tech Wiki
Jump to: navigation, search
This procedure details how to change the instrument cluster on VW/Audi/Seat/Skoda vehicles with Immobilizer III, where the immobilizer control module is integrated in instrument cluster. See the separate instructions for models where the immobilizer control module is integrated in a separate control module or where the immobilizer control module is integrated in Instrument Cluster.
Contents
[show]
* 1 Determining IMMO-ID & VIN (ECU)
* 2 Determining IMMO-ID & VIN (Kessy)
* 3 Kessy Control Module Swapping
[Select]
[01 - Engine]
[Meas. Blocks - 08]
Select Block 081.
[Go!]
The first 17-digit string is the VIN. The second 14-digit string in the Immo-ID..
[Done, Go Back]
[Close Controller, Go Back - 06]
[Select]
[05 - Acc/Start Auth.]
[Meas. Blocks - 08]
Select Block 081.
[Go!]
[Done, Go Back]
Prerequisites:
* The NEW module is installed in the car.
* ORIGINAL Electric Steering Lock is still installed.
o If the ORIGINAL Electric Steering Lock has been replaced, perform Electric Steering Lock Adaptation first.
* Battery voltage at least 12.0 V. We strongly recommend the use of a battery charger.
* Make sure to have BOTH PIN's, from the OLD (ORIGINAL) and the NEW (USED) control module.
* Put the first Key into the ignition Lock, but do NOT switch ON the ignition.
* Press and Hold the Brake Pedal for 20 Seconds to wake up the Diagnostic Databus.
[Select]
[Meas. Blocks - 08]
Select Block 024.
[Go!]
Make sure the shown lock times in field 1, 2, 3 and 4 are 0 (each field represents a time in minutes).
* If the lock times are NOT 0:
o Do NOT switch off the ignition!
o Allow the car to sit for AT LEAST the number of minutes that were indicated by the fields 1-4.
[Done, Go Back]
[Sec. Access - 16]
For the following procedure, use the PIN of the NEW (USED) control module.
There are 2 possibilities how to enter a PIN, choose the one that applies for you.
* 4-digit PIN
o Enter zero followed by the 4-digit PIN. For example, if your PIN is 1234, enter 01234.
* 7-digit PIN
o [Use 7-digit PIN/SKC]
o Enter the 7-digit PIN, Date on which the PIN was generated by the dealer, along with the Workshop Code (WSC) and the Importer number of the dealer that generated the code.
o [OK]
o
VAG-COM will validate the data you have entered and return you to the Login screen, where the Login Code will show as "XXXXX".
[Do it!]
[Adaptation - 10]
Enter 050 in "Channel Number".
[Read]
For the following procedure, use the PIN of the OLD (ORIGINAL) control module.
* 4-digit PIN
* 7-digit PIN
o [OK]
o VAG-COM will validate the data you have entered and return you to the Login screen, where the Login Code will show as "XXXXX".
[Test]
[Save]
[Done, Go Back]
After a successful adaptation a lock time will automatically being set.
[Meas. Blocks - 08]
Select Block 024.
[Go!]
Make sure the shown lock times in field 4 is 0 (a field represents a time in minutes).
* If the lock time is NOT 0:
o Allow the car to sit for AT LEAST the number of minutes that were indicated by field 4.
[Done, Go Back]
* Switch OFF the ignition and let the car sit for ~1 minute, then switch ON the ignition again.
* Verify that the NEW (USED) control module now shows the VIN/IMMO-ID of the vehicle now.
* Proceed with Key Matching now.
