Admin
Admin
Создатель сайта
Команда форума
Россия, Москва
VW Tiguan 2.0 DBGC 2018, VW Touran 1.6 BSE 2008
Fuse holder B -SB-, from August 2020
Fitting location of fuse holder B -SB-, from August 2020
1 - Fuse holder B -SB-
Fuse colours for J-Case fuse:
50 A - red
40 A - green
30 A - pink
Fuse colours for ATO flat fuse:
40 A - orange
30 A - light green
25 A - natural (white)
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
Fuse assignment for fuse holder B -SB-, from August 2020
SlotCurrent flow diagram designationNominal valueFunction / componentTerminal
SB1Fuse 1 on fuse holder B -SB1-400 APower steering control unit -J500-30
SB2Fuse 2 on fuse holder B -SB2-7.5 AABS control unit -J104-
Main relay -J271- 2)
Terminal 30 voltage supply relay -J317- 1)
Engine/motor control unit -J623-
30
SB3Fuse 3 on fuse holder B -SB3--not assigned-
SB4Fuse 4 on fuse holder B -SB4-15 AFront left headlight -MX1-30
SB5Fuse 5 on fuse holder B -SB5-15 AFront right headlight -MX2-30
SB6Fuse 6 on fuse holder B -SB6--not assigned-
SB7Fuse 7 on fuse holder B -SB7-30 AGearbox oil cooling pump -V478- 3)30
SB8Fuse 8 on fuse holder B -SB8-40 ABrake servo -NX6-30
SB9Fuse 9 on fuse holder B -SB9-15 AHorn relay -J413-30
SB10Fuse 10 on fuse holder B -SB10-30 AWiper motor relay 1 -J368-
Wiper motor relay 2 -J369-
- Windscreen wiper motor -V-
30
SB11Fuse 11 on fuse holder B -SB11--not assigned-
SB12Fuse 12 on fuse holder B -SB12-15 AMechatronic unit for dual clutch gearbox -J743- 3)30
SB13Fuse 13 on fuse holder B -SB13-25 AABS control unit -J104-30
SB14Fuse 14 on fuse holder B -SB14-20 AAuxiliary heater control unit -J364-3)30
SB15Fuse 15 on fuse holder B -SB15-40 AABS control unit -J104-30
SB16Fuse 16 on fuse holder B -SB16--not assigned-
SB17Fuse 17 on fuse holder B -SB17-40 AAuxiliary air heater element -Z35-1)87
SB18Fuse 18 on fuse holder B -SB18-40 AAuxiliary air heater element -Z35-1)87
SB19Fuse 19 on fuse holder B -SB19--not assigned-
SB20Fuse 20 on fuse holder B -SB20--not assigned-
SB21Fuse 21 on fuse holder B -SB21-7.5 AEngine/motor control unit -J623-50
SB22Fuse 22 on fuse holder B -SB22-30 AStarter -B-50
SB23Fuse 23 on fuse holder B -SB23-15 AEngine/motor control unit -J623-87
SB24Fuse 24 on fuse holder B -SB24-7.5 A
10 A
Oil level and oil temperature sender -G266- 2)
Activated charcoal filter solenoid valve 2 -N115-2)
Camshaft control valve 1 -N205- 2)
Exhaust camshaft control valve 1 -N318- 2)
Valve for oil pressure control -N428- 2)
Inlet cam actuator for cylinder 2 -N583- 2)
Exhaust cam actuator for cylinder 2 -N587- 2)
Inlet cam actuator for cylinder 3 -N591- 2)
Exhaust cam actuator for cylinder 3 -N595- 2)
Radiator fan -VX57- 2)
Oil level and oil temperature sender -G266- 1)
Automatic glow period control unit -J179- 1)
Control unit for reducing agent heater -J891- 1)
Relay for reducing agent metering system -J963- 1)
Fuel pressure regulating valve -N276- 1)
Radiator fan -VX57- 1)
87
SB25Fuse 25 on fuse holder B -SB25-7.5 AExhaust cam actuator for cylinder 2 -N587-87
SB26Fuse 26 on fuse holder B -SB26-10 A
10 A
Heater element for crankcase breather -N79- 1)
Valve for oil pressure control -N428- 1)
Coolant valve for cylinder head -N489- 1)
Piston cooling jet control valve -N522- 1)
Coolant pump for high-temperature circuit -V467- 1)
Charge air cooling pump -V188- 2)
87
SB27Fuse 27 on fuse holder B -SB27-10 A 2)
15 A 1)
Lambda probe 1 after catalytic converter -GX7- 2)
Lambda probe 1 before catalytic converter -GX10- 2)
Particulate sensor -G784-1)
NOx sender 3 -G932- 1)
Lambda probe 1 before catalytic converter -GX10- 1)
Control unit for NOx sender -J583-1)
Control unit for NOx sender 2 -J881- 1)
SB28Fuse 28 on fuse holder B -SB28-20 AIgnition coil 1 with output stage -N70- 2)
Ignition coil 2 with output stage -N127- 2)
Ignition coil 3 with output stage -N291- 2)
Ignition coil 4 with output stage -N292- 2)
87
SB29Fuse 29 on fuse holder B -SB29-15 A 2)
20 A 1)
Fuel pump control unit -J538-87
SB30Fuse 30 on fuse holder B -SB30--not assigned-
SB31Fuse 31 on fuse holder B -SB31--not assigned-
SB32Fuse 32 on fuse holder B -SB32--not assigned-
1) For models with diesel engine
2) For models with petrol engine
3) According to equipment
Fuse holder C -SC-, from August 2020
Fitting location of fuse holder C -SC-, left-hand drive models, from August 2020
Note: For left-hand drive models
1 - Fuse holder C -SC
50 A - red
40 A - green
30 A - pink
40 A - orange
30 A - light green
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
Fuse colours, for mini fuses:
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
Fuse assignment for fuse holder C -SC-, from August 2020
Note: The fuse SC40 is supplied via terminal 15 from the factory and can be supplied via terminal 30 by reconnecting.
If a consumer is connected to the electric socket or to the cigarette lighter, ensure that the consumer is disconnected from the voltage supply when the engine is switched off to prevent the drive battery being discharged.
SC1Fuse 1 on fuse holder C -SC1--not assigned-
SC2Fuse 2 on fuse holder C -SC2-30 ARear fresh air blower control unit -J391-30
SC3Fuse 3 on fuse holder C -SC3-25 ATrailer detector control unit -J345-30
SC4Fuse 4 on fuse holder C -SC4-30 AControl unit for reducing agent heater -J891- 1)30
SC5Fuse 5 on fuse holder C -SC5-25 AParking lock sender -G747-30
SC6Fuse 6 on fuse holder C -SC6-30 AOnboard supply control unit -J519-30
SC7Fuse 7 on fuse holder C -SC7-30 AHeater and air conditioning controls -EX21-30
SC8Fuse 8 on fuse holder C -SC8-25 AMultifunction unit control unit -J501-30
SC9Fuse 9 on fuse holder C -SC9-30 ADriver door control unit -J386- 2)
Front passenger door control unit -J387- 3)
30
SC10Fuse 10 on fuse holder C -SC10-25 AMultifunction unit control unit -J501-30
SC11Fuse 11 on fuse holder C -SC11-15 ATrailer detector control unit -J345- 4)30
SC12Fuse 12 on fuse holder C -SC12-40 AOnboard supply control unit -J519-30
SC13Fuse 13 on fuse holder C -SC13-40 AOnboard supply control unit -J519-30
SC14Fuse 14 on fuse holder C -SC14-40 AVoltage converter -A19-30
SC15Fuse 15 on fuse holder C -SC15--not assigned-
SC16Fuse 16 on fuse holder C -SC16-7.5 AAirbag control unit -J234-
Control unit for wireless connection of seat occupied sensors -J1247-
30
SC17Fuse 17 on fuse holder C -SC17-10 ARelay for reducing agent metering system -J963- 1)
- Delivery unit for reducing agent metering system -GX19- 1)
- Reducing agent tank -VX85- 1)
30
SC18Fuse 18 on fuse holder C -SC18-10 ASteering column lock control element -N360-
Interface for entry and start system -J965-
Control unit 2 for break-in protection -J1192-
Control unit 3 for break-in protection -J1193-
Control unit 4 for break-in protection -J1194-
Control unit 5 for break-in protection -J1195-
30
SC19Fuse 19 on fuse holder C -SC19-7.5 ADash panel insert -KX2-
Navigation system interface -R94-
30
SC20Fuse 20 on fuse holder C -SC20-7.5 AStorage compartment with interface for mobile telephone -R265-
Transmission and reception stabilisation control unit -R308-
USB connection 1 -U41-
30
SC21Fuse 21 on fuse holder C -SC21-7.5 AInterior light relay -J602-
Blind Spot Monitor control unit -J1086-
Blind Spot Monitor control unit 2 -J1087-
Rear overhead view camera -R246-
30
SC22Fuse 22 on fuse holder C -SC22--not assigned-
SC23Fuse 23 on fuse holder C -SC23-15 AContact strip in left B-pillar -F571-30
SC24Fuse 24 on fuse holder C -SC24-15 AAll-wheel drive control unit -J492--
SC25Fuse 25 on fuse holder C -SC25-25 AMultifunction unit control unit -J501-30
SC26Fuse 26 on fuse holder C -SC26-30 AFront passenger door control unit -J387-30
SC27Fuse 27 on fuse holder C -SC27-25 AMultifunction unit control unit -J501-30
SC28Fuse 28 on fuse holder C -SC28--not assigned-
SC29Fuse 29 on fuse holder C -SC29-15 ATrailer detector control unit -J345- 4)30
SC30Fuse 30 on fuse holder C -SC30-20 AControl unit 1 for information electronics -J794-30
SC31Fuse 31 on fuse holder C -SC31-25 ATrailer detector control unit -J345- 4)30
SC32Fuse 32 on fuse holder C -SC32-15 ARear lid control unit -J605-30
SC33Fuse 33 on fuse holder C -SC33-15 AContact strip in right B-pillar -F572-30
SC34Fuse 34 on fuse holder C -SC34--not assigned-
SC35Fuse 35 on fuse holder C -SC35-40 AOnboard supply control unit -J519-30
SC36Fuse 36 on fuse holder C -SC36-40 AFresh air blower control unit -J126-30
SC37Fuse 37 on fuse holder C -SC37--not assigned-
SC38Fuse 38 on fuse holder C -SC38--not assigned-
SC39Fuse 39 on fuse holder C -SC39--not assigned-
SC40Fuse 40 on fuse holder C -SC40-7.5 AAlarm horn -H12-30
SC41Fuse 41 on fuse holder C -SC41-7.5 AData bus diagnostic interface -J533-30
SC42Fuse 42 on fuse holder C -SC42-7.5 ASelector mechanism -EX2-
Selector lever position display -Y6-
30
SC43Fuse 43 on fuse holder C -SC43-10 AHeater and air conditioning controls -EX21-
Vehicle interior temperature sensor -G1090-
Heated rear window relay -J9-
Tyre Pressure Monitoring System control unit -J502-
Remote control receiver for auxiliary coolant heater -R149-
30
SC44Fuse 44 on fuse holder C -SC44-7.5 AElectromechanical parking brake button -E538-
Operating unit 1 for driver and convenience functions -E791-
Operating unit for lighting -EX59-
Anti-theft alarm sensor -G578-
Air humidity, rain and light sensor -G823-front interior light -WX1-
30
SC45Fuse 45 on fuse holder C -SC45-7.5 ASteering column electronics control unit -J527-30
SC46Fuse 46 on fuse holder C -SC46-7.5 ADisplay unit for front information display and operating unit control unit -J685-30
SC47Fuse 47 on fuse holder C -SC47--not assigned-
SC48Fuse 48 on fuse holder C -SC48-7.5 AUSB charging socket 1 -U37- 4)15
SC49Fuse 49 on fuse holder C -SC49--not assigned-
SC50Fuse 50 on fuse holder C -SC50--not assigned-
SC51Fuse 51 on fuse holder C -SC51--not assigned-
SC52Fuse 52 on fuse holder C -SC52-20 A12 V socket -U5- 4)
12 V socket 3 -U19- 4)
12 V socket 4 -U20- 4)
15
SC53Fuse 53 on fuse holder C -SC53--not assigned-
SC54Fuse 54 on fuse holder C -SC54--not assigned-
SC55Fuse 55 on fuse holder C -SC55--not assigned-
SC56Fuse 56 on fuse holder C -SC56--not assigned-
SC57Fuse 57 on fuse holder C -SC57--not assigned-
SC58Fuse 58 on fuse holder C -SC58-7.5 AAdaptive cruise control unit -J428- 4)
Parking aid control unit -J446- 4)
Front camera for driver assist systems -R242- 4)
15
SC59Fuse 59 on fuse holder C -SC59-7.5 AElectromechanical parking brake button -E538-
Reversing light switch -F4- 4)
Pressure sender for refrigerant circuit -G805-
Relay for power sockets -J807-
15
SC60Fuse 60 on fuse holder C -SC60-7.5 ADiagnostic connection -U31-15
SC61Fuse 61 on fuse holder C -SC61-7.5 AClutch position sender -G476- 4)
Starter relay 1 -J906-
Starter relay 2 -J907-
15
SC62Fuse 62 on fuse holder C -SC62--not assigned-
SC63Fuse 63 on fuse holder C -SC63--not assigned-
SC64Fuse 64 on fuse holder C -SC64--not assigned-
SC65Fuse 65 on fuse holder C -SC65--not assigned-
SC66Fuse 66 on fuse holder C -SC66-15 ARear window wiper motor -V12-15
SC67Fuse 67 on fuse holder C -SC67-30 AHeated rear window -Z1-30
2) For left-hand drive models
3) For right-hand drive models
4) According to equipment
Individual fuses on fuse holder C -SC-, from August 2020
Fitting location of individual fuses, left-hand drive models, from August 2020
A - Thermal fuse 1 -S361-
B - Thermal fuse 2 -S362-
1 - Holder
2 - Fuse carrier 1 -ST1-
3 - Fuse carrier 2 -ST2-
Fuse assignment for single fuses, from August 2020
AThermal fuse 1 -S361-15 AFront left lumbar support adjustment switch -E752-30
BThermal fuse 2 -S362-15 AFront right lumbar support adjustment switch -E753-30
Individual TAXI fuses, from August 2020
Note: For model VW Caddy with TAXI equipment
Fitting location of individual TAXI fuses, from August 2020
A - Fuse 1 on fuse carrier 4 -S397-
B - Fuse 2 on fuse carrier 4 -S398-
C - Fuse 3 on fuse carrier 4 -S399-
D - Fuse 4 on fuse carrier 4 -S400-
1 - Holder
2 - Holder
3 - Fuse carrier 3 -ST3-
4 - Fuse carrier 4 -ST4-
Fuse assignment of individual TAXI fuses, from August 2020
AFuse 1 on fuse carrier 4 -S397--not assigned-
BFuse 2 on fuse carrier 4 -S398--not assigned-
CFuse 3 on fuse carrier 4 -S399--not assigned-
DFuse 4 on fuse carrier 4 -S400-10 ATaximeter -G41-
Mirror taximeter -G511-
Two-way radio -R8-
30
Connection and distribution box 2 -SX2-, from August 2020
Fitting location of connection and distribution box 2 -SX2-, from August 2020
A - Fuse 1 (30), in battery fuse holder -S162-
1 - Connection and distribution box 2 -SX2-
Fuse assignment of connection and distribution box 2 -SX2-, from August 2020
A Fuse 1 (30), in battery fuse holder -S162- 400 A Starter -B
Alternator with voltage regulator -CX1-
30
Connection and distribution box 1 -SX1-, from August 2020
Fitting location of connection and distribution box 1 -SX1-, from August 2020
Note: The fuse strip (multifuse) must be replaced as a complete unit.
1 - Connection and distribution box 1 -SX1-
Multifuse strip fuse
Fuse assignment of connection and distribution box 1 -SX1-, from August 2020
SA1 Fuse 1 on fuse holder A -SA1- 150 A Fuse holder B -SB- 30
SA2 Fuse 2 on fuse holder A -SA2- 50 A 1)
100 A 2)
Radiator fan -VX57- 30
SA3 Fuse 3 on fuse holder A -SA3- 200 A not assigned 30
508508 Threaded connection (30), on E-box - Connection and distribution box 2 -SX2-
- Battery -A-
30
SA4 Fuse 4 on fuse holder A -SA4- 125 A Fuse holder C -SC- 30
SA5 Fuse 5 on fuse holder A -SA5- 125 A Fuse holder C -SC- 30
1) For models with single radiator fan -VX57-
2) For models with dual radiator fan -VX57-
Relays on fuse holder B -SB-, from August 2020
R1 - Main relay -J271-
R1 - Terminal 30 voltage supply relay -J317-
R2 - High heat output relay -J360-
R3 - Horn relay -J413-
R4 - Starter relay 1 -J906-
R5 - Starter relay 2 -J907-
R6 - not assigned
Relays on fuse holder C -SC-, left-hand drive models, from August 2020
R1 - Relay for power sockets -J807-
R2 - Terminal 15 voltage supply relay -J329-
R3 - Heated rear window relay -J9-
Relays on relay and fuse carrier 1 -SR1-, from August 2020
A - Fuse holder B -SBR7 - Automatic glow period control unit -J179-
R8 - Low heat output relay -J359-
For models with auxiliary air heater element -Z35-
R9 - Heated windscreen relay -J47-
R10 - Heated windscreen relay 2 -J611-
R11 - Wiper motor relay 1 -J368-
R12 - Wiper motor relay 2 -J369-
1 - Relay and fuse carrier 1 -SR1-
2 - Relay and fuse carrier 2 -SR2-
3 - Relay and fuse carrier 3 -SR3
Relay on fuse holder C -SC-, from August 2020
Relay on fuse holder C -SC-, left-hand drive vehicle, from August 2020
R4 - Relay for reducing agent metering system -J963-
R5 - not assigned
R6 - not assigned
1 - Fuse and relay carrier -SR
Relay for sliding doors
Left sliding door relay
1 - Left sliding door relay -J1269-
2 - Relay holder
