Из
официальной документации,
последней доступной актуализации, из ERWIN на конец 2019г. :
VW Passat 1988 ➤ 6-Cyl. injection engine Mechanics
Engine:
AAA - Edition 04.1994
Engine oil specifications:
Use engine oil to VW standard 500 00 or 501 01. Only in exceptional cases: Multi-grade or single-grade oils corresponding to API-SF or SG.
VW Passat 1994 ➤ 4-cyl. fuel injection engine (2-valve), Mechanics
Engine:
AAM, ABS, 2E, ADY, ADZ - Edition 10.1993
Use engine oil to VW standard 500 00 or 501 01. Only in exceptional cases: Multi-grade oils corresponding to API-SF or SG.
VW Passat 1994 ➤ 4-Cyl. diesel engine, Mech.
Engine:
AAZ, AFN, 1Z, AHU - Edition 08.1994
Only use engine oil conforming to VW standard 50500.
VW Passat 1994 ➤ 6-cyl. fuel injection engine Mechanics
Engine:
AAA, ABV - Edition 08.1997
VW Passat 1994 ➤ 4-Cyl. fuel injection engine (4-valve), Mechanics
Engine:
ABF - Edition 04.1994
VW Passat 1994 ➤ 4-cyl. fuel injection engine (cross-flow cylinder head)
Engine:
AEK, AFT - Edition 08.1994
Maintenance - Edition 08.2006
VW Passat 1994 ➤
VW Passat Variant 1994 ➤
2.1.1 VW engine oil standards
VW PASSAT B4 | VW ENGINE OIL STANDARDS |
PETROL ENGINES | |
6-cylinder and 4-cylinder engines | VW 500 00, VW 502 00,
VW 504 001 or VW 501 01 |
DIESEL ENGINES | |
4-cylinder engines | VW 505 00, VW 500 00
VW 507 00* or VW 501 01 |
* Combination product: VW 504 00/507 00
Как видно последние изменения вносились в 2006 году и все...
Новее и официальней информации по Пассатам Б3 и Б4 нет.
