на всякий случай VIN - TMBBE41U5Y2383940
Saturday,18,April,2015,14:41:18:65217
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
Mileage: 235050km-146053mi   Repair Order:
Chassis Type: 1U - Skoda Octavia (1997 > 2011)
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 56 76
   Mileage: 235050km/146053miles
Address 01: Engine        Labels: 06A-906-018-AQY.lbl
   Part No: 06A 906 018 N
   Component: 2,0l R4/2V  MOTR HS V03
   Coding: 00000
   Shop #: WSC 00054
   VCID: 2D5B11F4E7EFFF760F5-4A9C
2 Faults Found:
01115 - -
            35-00 - -
16524 - Oxygen (Lambda) Sensor B1 S2
            P0140 - 35-00 - No Activity
Readiness: 0000 0000
Address 03: ABS Brakes        Labels: 1J0-907-37x-ABS.lbl
   Part No: 1J0 907 379 Q
   Component: ABS/EDS 20 IE CAN  0001
   Coding: 13504
   Shop #: WSC 31480
   VCID: 3F875BBC3D837DE6AD9-4A3A
No fault code found.
Address 08: Auto HVAC        Labels: 1Ux-907-044.lbl
   Part No: 1U1 907 044 A
   Component: CLIMATRONIC     C 0.7.0
   Coding: 01000
   Shop #: WSC 31480
   VCID: 30650880F0DD929E243-50E6
Address 15: Airbags        Labels: 1J0-909-60x-VW3.lbl
   Part No: 1J0 909 603 AS
   Component: AIRBAG VW3 -        V04
   Coding: 16723
   Shop #: WSC 31480
   VCID: 7AF1EAA8662198CEDA7-4A3A
Address 17: Instruments        Labels: 1Ux-919-xxx-17.lbl
   Part No: 1U1 919 034 B
   Component: A4-KOMBIINSTR. VDO V01
   Coding: 00142
   Shop #: WSC 31480
   VCID: 336F078C01CBA986591-5072
   Subsystem 1 - Part No: IMMO
   Component: IDENTNR: SKZ7Z0Y0452933
   IMMO-IDENTNR: SKZ7Z0Y0452933
Address 46: Central Conv.        Labels: 1J0-959-799.lbl
   Part No: 1J0 959 799 AH
   Component: 5H Zentral-SG Komf. 0001
   Coding: 04096
   Shop #: WSC 31480
   VCID: 840D145094E55E3E30B-49D8
   Subsystem 1 - Part No: 1U4959801B
   Component: 5H Tхrsteuerger. FS0002r
   Subsystem 2 - Part No: 1U4959802B
   Component: 5H Tхrsteuerger. BF0002r
   Subsystem 3 - Part No: 1U0959811B
   Component: 5H Tхrsteuerger. HL0002r
   Subsystem 4 - Part No: 1U0959812B
   Component: 5H Tхrsteuerger. HR0002r
1 Fault Found:
00912 - Window Regulator Switch; Front Left (E40)
            27-10 - Implausible Signal - Intermittent
End   ---------------------------------------------------------------------
Address 01: DTCs cleared
