ten70 написал(а):Ага, чипанули догреватель...![]()
DEH написал(а):Internal Control Module Memory Error
Possible Causes
Wiring from/to Control Module faulty
Voltage Supply and/or Ground Supply faulty
Control Module Housing leaky
Possible Solutions
Check/Clean Wiring from/to Control Module
Check Voltage Supply and Ground Supply including the Main Supply/Connections at the Battery
Replace Control Module
Special Notes
This fault is NOT to be ignored when found in a major and/or critical system (Airbag, ABS etc.). If you try to clear this fault, VCDS may tell you that there is an unexpected result or that the controller refused the command. This is normal since this specific fault can generally not be cleared.
When stored in other unimportant systems (Radio etc.) the general suggestion is to ignore it unless you notice functional limitations. Within the warranty period dealers are usually required to replace such control modules, but there have been a couple of cases with similar codes where these are getting ignored due to flaws in the control module software. If in doubt please refer to technical bulletins and similar documents provided by the vehicle manufacturer.
When found in Audi Airbag Generation 6 & 7 (see Audi TPI 1308401):
A Problem with the Acceleration Sensor may result in the Airbag Control Module storing this Fault Code. Replace the Airbag Control Module and both Acceleration Sensors.
When found in Audi Airbag Generation 8:
Due to low Voltage the Control Module does not complete it's Self Test successfully. Replace Airbag Control Module and install a low Voltage Protection Relay to ensure future mishaps won't cause this again. UPDATE The Protection Relay may not be available anymore, though the Parts Catalog lists updated Control Modules now.
When found in certain older TDI Engine Control Modules (ECM) which have a vacuum line going to them:
Check/Repair the Vacuum Line before and inside the ECM.
ten70 написал(а):Чем тебе помочь, денег дать на новый блок или сразу на новую машину?![]()
ten70 написал(а):А сам подумать не пробовал, поиском на форуме воспользоваться, чтобы на свои вопросы ответить?
На форуме вся информация есть.
Jevgenij007 написал(а):конкретно по этому вопросу нету знаешь где искать? ткни носом
небольшое дополнение
Address 18: Aux. Heat Labels: None
Control Module Part Number: 7M3 815 071 C
ten70 написал(а):Что конкретного тебе надо?
Это кто выкладывал?
ten70 написал(а):Что это за блок?![]()
Jevgenij007 написал(а):а ти что не знаешь что за Control Module под номером 7M3 815 071 C ??? я думал тут специ съедят которые просвещают чайников а тут похоже наоборот
WRH2E написал(а):Автор! Ты,как и многие,не одинок в своей лени.Торопишьса как голый на "блю.А ты сначала научись пользоваться Поиском,кнопка есть такая.Не путать с Новым поиском.Сразу обнаружишь несколько тем по твоей проблеме секунд за 15.
А всех тыкать носом уже руки устали.
А форум нужен прежде всего чтобы его читали,а не сопли ударами размазывали об него.
