Вин
Дата выпуска: 02.06.1998
Модельный год: 1999
Код и номер двигателя: AKL 337879
Код КПП: DLP
Комбинация цветов интерьера: KL
Комбинация цветов кузова: Z4
Цвет крыши: Z4
Комплектация автомобиля (код и наименование):
0A2 four doors
0AM front stabilizer
0BC rear stabilizer
0CE vehicle class differentiation 1J0
0F2 fuel system for carburetor gasoline engine
0FK Bratislava manufacturing sequence
0G3 gearshift linkage
0KA without stickers and badges
0L0 mechanical throttle actuation
0N1 standard rear axle
0QE nameplate set "1.6"
0RA without ignition/starter switch locking system
0SB labels/plates in German
0TQ front and rear floor mats (polypropylene)
0UA without special color trim
0YZ without determination of weight categoryfor rear axle
1AC anti-lock brake system (ABS)
1C1 antifreeze up to -25 degree celsius tolerance up to -30 degree C
1D0 without towing attachment
1E1 activated carbon canister
1EX special identification plate for EC
1G2 steel spare wheel with original equipment tires
1GA front shock absorption, basic design 1
1H0 without proportioning valve
1JA rear shock absorption, basic design 1
1KK disc brakes, rear
1LQ front disc brakes with integrated adapter
1MP steering wheel for airbag system
1N1 power steering
1NC full wheel covers
1PA standard wheel bolts
1S7 tool kit and aluminum jack
1SA without additional engine guard
1T0 w/o first aid kit and warning triangle
1WB transmission shaft w/100mm in diameter
1X0 front wheel drive
1Z0 initial standard fuel filling
2B5 additional exterior noise suppression
2C5 axial and vertical adjustable steering column
2D1 complete cd enhancing underbody panel
2E0 base chassis
2G7 filler neck module 1 with insert
2JB standard bumpers
2LB fuel tank with special material treatment (fluorination)
2P0 without trunk sill protection
2V5 fresh air intake system with activated charcoal canister
2W0 fuel filler cap
2WA without additional tires
3B0 without additional child seat anchor
3C1 static lap belt, center rear
3CA without partition
3FA without roof insert (standard roof)
3GA without cargo area
3H0 without backrest release for front seats
3J7 articulated and height-adjustable headrests for front seats
3L3 manual height adjustment for front seats
3M0 without special measures
3NW rear seat bench/backrest, split folding with center armrest
3P1 bracket for first aid kit and warning triangle
3Q1 rear headrests
3S0 without roof rails/roof load rack
3U1 foldable trunk cover
3Y0 without roll-up sun screen
3YR door pockets with insert mats
3ZG 3-point seat belts, outer rear with height adjustment
4A0 without seat heater
4AR foamed film and circular-knit door and side panel trim
4B1 protective side molding
4E0 tailgate/trunk lid unlocking from outside
4F1 central locking system
4GF windshield, tinted
4J1 floor tray, extension center console
4KC side and rear windows tinted
4L2 dipping breakaway inside rear view mirror
4M6 cup holder
4P0 rear floor panel module, type 1
4Q1 flame retardent materials
4R4 power windows with comfort operation andcircuit breaker
4SD left vanity mirror illuminated
4TD right vanity mirror illuminated
4U1 luggage nets/pockets on backrests
4UE airbag f. driver a. front seat passenger
4W0 without cassette and CD storage unit
4X1 side airbag front
5A7 comfort trunk lining with service lid
5C0 without special body measures
5D0 without carrier frequency
5K0 without paint preservative
5MA decorative inserts
5N6 folding grab handles at roof frame soft fold-away
5RQ outer right rear view mirror: convex
5SL outer left rear view mirror: non-spherical
6A0 without fire extinguisher
6E3 center armrest front
6EJ additional body cover on sill, without wheel arch
6FE body-colored outer rear view mirror housings and tailgate grab strip
6KG radiator grille
6M0 without tie down straps/net/pocket
6NH comfort molding roof liner unsplit roof cutout rear (radio antenna)
6P1 license plate bracket rear (ECE)
6PA plastic hand brake lever handle
6Q4 comfort gearshift knob/handle
6QA rear seat catch
6R1 leatherette gearshift boot
6SC tufted trunk floor covering
6U0 without additional seals outside
6W1 license plate bracket front (large)
6XD outer rear view mirrors: powered, heated
7A0 without CD changer/CD player
7AA electronic vehicle immobilization device
7B2 12-volt socket in luggage boot
7E0 w/o heat accumulator/auxiliary heating
7L0 without inertia benefit system/deceleration fuel cut-off/idle stop valve
7P0 without lumbar support in front and rear seats
7Q0 without navigation device
7QA without CD ROM
7X0 without park distance control
8AD radio "gamma"
8CC speedometer sensor without seal (electronic speedometer sensor)
8F2 side turn signal lights
8GD alternator 90A
8JS twin headlamp for left-hand drive with clear lens
8K0 without special low beam mode
8L3 roof antenna
8M1 rear window wiper and washer system with intermittent control
8N4 windshield wiper intermittent control with potentiometer (four speeds)
8Q1 headlight-range adjustment
8QC key with light
8RM eight loudspeakers (passive)
8S2 one reading light front, two reading lights rear
8SA taillight assemblies, standard design
8T0 without cruise control system (CCS)
8TC rear fog light for driving on the right
8W0 without washer fluid level indicator
8WA without front fog light
8X0 without headlight washer system
8Y1 two-tone horn
8Z5 engine cooling system, type 1
9A0 without taxi alarm system
9AB manually controlled air conditioning
9D0 without preparation for two-way radio installation
9E1 luggage compartment lighting
9F0 without sound combination for rotating emergency light and radio antenna preparation
9FA without automatic transmission indicator light
9J0 without supertone system and tone sequence control
9JB smoking version, ashtray front and rear
9L0 without engine compartment lighting
9M0 without auxiliary/parking heater
9P0 without seat belt warning light
9Q0 without multi-function indicator/on-board computer
9T0 without heated washer nozzles
9TB additional warning lights (door area)
9U0 without brake pad wear indicator
9W0 w/o car phone preparation/installation
9Y0 without outdoor temperature gage
A8C comfort equipment
B01 type approval Germany
B0A component parts set without country-specific design requirement
C04 operating permit, alteration 4
C6D steel wheels 6J x 14 offset 38
E0A no special edition
F0A no special purpose vehicle, standard equipment
G0C 5-speed manual transmission
H1T tires 175/80 R 14 88H
J1L battery 280 A (60 Ah)
K8G hatchback
L0L left-hand drive vehicle
ME8 4-cylinder gasoline engine 1.6 L/74 kW with multi-point injection, EU 3D base engine is T6H
N0U cut pile seat covering
PH1
PTB
Q2J comfort front seats
QG0 without service interval prolongation
RCA
S0T pre-production series/SOP next MY
SS6 control of body paint coating in Brussels plant for Bratislava plant
T6H components for base engine, unit 06A.F (aluminum)
U0C instrument insert with tachometer clock and km/h speedometer
U21 suspension range 120
V0A tires w/o specification of tire brand
W02
_________________________
саня голь4
>>>Менять всю ситему АВС глупо, нужно провести детальную диагностику и выявить вышедшие из строя узлы их и менять. Если у вас в Казахстане так ремонтируют Фольцы
Дык в том то и дело, что пока только "спец" этот сказал, и то, нам он не сказал стоимость! видимо зассал вообще говорить чего. А узнали мы о двух косых, от знакомого который нас ему привёл. Причём разговор о том, что к нему загоняли 4 гольфа уже был, и наш знакомый сказал, что тот гольф который был у него (типа наш) убитый. Судя по тому, что я в своей жизни передвигался на разных машинах и на шестисотых и на копейках в качестве пассажира, и отличить убитую машину, от нормальной уж грубо сумею и сам. А нам он ВООБЩЕ ничего толком не сумел внятно без соплежуйства сказать. Либо чувак боится, либо с гольфами 4-мы дел вообще не имел и просто НИ ХРЕНА не знает. Зато вчера с пафосом выдал, мол гольф 4 машина в обслуге дорогая, типа свежая. Что расходится с тем, что пишут тут реальные владельцы, да дороже чем третий в обслуге, но не фатально.
Насчёт АБС вот именно, что пока я без СЦ заключения о ремонте не могу с увереностью сказать, что меняют они только всё сразу. Может напишут про датчки или настройку или ещё что. Это утверждал этот самый "спец", мол только меняют полностью. Завтра по идее выяснится это будет должно.
>>>Машину эту уже смотрели в сервисе, кто-то отказался наводит на мысли
Машину как я понял смотрел владелец который и обменял с доплатой на бумера 730 нашего продавца, которому по "легенде" в тот момент были нужны деньги. Так ли это было или по другому не суть важно. Важно то, что так называемый спец завис как масдай и ни туды и не сюда, молчит как партизан. Наш знакомый сам офигел, как говорит ничего не сказал, совсем ничего.
>>> Машина вам очень нравицца и возможно вы ее возмете, что вам скажет Фольцовский сервис за 50 енотов, оч интересно.
Само собой нравится, наверно километров 60 я на ней сегодня проехал в качестве пассажира. И уж само собой если центр упрёт на именно 2 штуки за АБС я буду торговаться с продавцом до упора.
>>>Мнение жены нужно слушать только по отношению к цвету авто, и только когда вы стоите в салоне и выбираете новую машину
Как раз жена и настаивает на том, что бы если АБС будет стоить нам 2000 скидывать стоимость авто на эти две штуки
Я если честно, при таком раскладе мог бы повестись и не особо торговаться. Поэтому супруга и будет душить продавца. Я торговаться не умею :-( И вообще, при чём тут жена, если мы завтра машину в сертифицированый сервис гоним. Да и жёны разные бывают
