Не читаются большинство контроллеров VAG COM нужно добраться до блока комфорта,поменять настрой
Я делал на своеи Шкоде суперб 2004 и там Vag com работаеть нармальна не каких проблем все блокы показывает без проблем еслы сан код показываеть цыфрами а там остоетца расшыфровать толька код и все проблиема
Ищи или покупай CAN. Самый дешевый 4000 руб
; VAG-COM Label File
; VW Touareg (7L)
; Component: J533 - CAN-Gateway (#19)
; P/N: 6N0-909-901-???
; includes measuring, coding and long coding
; created by Davin Swanson
; modified on 14/Mar/2004 by Sebastian Stange (Sebastian@Ross-Tech.com)
; modified on 30/Aug/2005 by Michael Moore (Moore@Ross-Tech.com)
; last modification: 18/Oct/2007
; requires VAG-COM 708.0 / LCode 709.0 or newer
; measuring blocks
001,0,*The first 9 blocks do not show error messages, but they do not show data either.
002,0,*The first block known to have data in it is block 80
080,0,Manufacturer work number and identification
; Date of manufacture
; Manufacturer changing status
; Manufacturer test stand no.
; Running manufacturer no.
; e.g. BPA = Bosch factory Ansbach
081,0,*This block not available. Next Available block is 125.
125,0,CAN-BUS Status (1 = OK / 0 = not OK)
125,1,Engine
125,2,Automatic, Transmission
125,3,ABS,Brake System
125,4,
126,0,CAN-BUS Status (1 = OK / 0 = not OK)
126,1,Steering, Angle
126,2,Airbag
126,3,
126,4,
127,0,CAN-BUS Status (1 = OK / 0 = not OK)
127,1,
127,2,AWD,
127,3,
127,4,
128,0,CAN-BUS Status (1 = OK / 0 = not OK)
128,1,Battery,Management
128,2,Electrical,Ignition Lock 1
128,3,Level control
129,0,Undocumented
130,0,CAN-BUS Status (1 = OK / 0 = not OK)
130,1,Comfort Can Bus,Mode,
130,2,Central,Convenience
130,3,Driver,Door
130,4,Passenger,Door
131,0,CAN-BUS Status (1 = OK / 0 = not OK)
131,1,Rear Right,Door
131,2,Rear Left,Door
131,3,Driver Seat,Memory
131,4,Electrical,Load Control
132,0,CAN-BUS Status (1 = OK / 0 = not OK)
132,1,
132,2,Steering,Wheel Electronics
132,3,Air Conditioning
132,4,Tire Pressure,Monitoring
133,0,CAN-BUS Status (1 = OK / 0 = not OK)
133,1,Roof,Electronics
133,2,Pax Seat,Memory
133,3,Rear Seat,Memory
133,4,Park Distance,Control
134,0,CAN-BUS Status (1 = OK / 0 = not OK)
134,1,
134,2,Electrical,Ignition Lock 1
134,3,Wiper Control,Module
134,4,
135,0,CAN-BUS Status (1 = OK / 0 = not OK)
135,1,
135,2,Display Control,Front 1
135,3,Display Control,Rear 1
134,4,
136,0,
136,1,
136,2,Central,Locking
136,3,
136,4,
137,0,*This block not available. Next Available block is 140.
138,0,*This block not available. Next Available block is 140.
139,0,*This block not available. Next Available block is 140.
140,0,Optical Data Bus Status (1 = OK / 0 = not OK)
140,1,Optical Data Bus,Mode,
140,2,
140,3,Navigation,System
140,4,
141,0,CAN-BUS Status (1 = OK / 0 = not OK)
141,1,
141,2,
141,3,
141,4,Telematics
142,0,CAN-BUS Status (1 = OK / 0 = not OK)
142,1,Display Control,Front 1
142,2
142,3,
142,4,
143,0,CAN-BUS Status (1 = OK / 0 = not OK)
143,1,Digital Sound,Processor,
143,2,
143,3,
143,4,
144,0,*This block not available. No further blocks available between here and 254.
; coding
C00,Diagnostic Interface for Datenbus (J533) Coding
C01,+00001 = Automatic Transmission (through MY 2001 and all PQ24 | Polo/Fabia/Ibiza/Cordoba)
C02,+00002 = Brake Electronics
C03,+00004 = Airbags
C04,+00008 = Steering Aid (only PQ24 | Polo/Fabia/Ibiza/Cordoba)
C05,+00016 = All-Wheel-Drive (only Transporter/Multivan)
C05,
C06,Note: Recoding (even with the same value) results in refreshing the
C07,Gateway Installation List (e.g. useful/necessary after retrofits).
; long coding
LC,00,0,[01] Engine Electronics I
LC,00,1,[02] Transmission Electronics
LC,00,2,[03] Brake Electronics
LC,00,3,[34] Level Control
LC,00,4,[15] Airbags
LC,00,5,[55] Headlight Aim Control
LC,00,6,[22] All Wheel Electronics
LC,00,7,[13] Distance Regulation
LC,01,0,[64] Stabilizers
LC,01,1,[17] Instrument Cluster
LC,01,2,[3C] Lane Change Assist
LC,01,3,[32] Differential Locks
LC,01,4,[11] Engine Electronics II
LC,01,5,[04] Steering Angle
LC,01,6,[46] Comfort System
LC,01,7,[42] Door Electronics Driver
LC,02,0,[52] Door Electronics Passenger
LC,02,1,[62] Door Electronics Rear Left
LC,02,2,[72] Door Electronics Rear Right
LC,02,3,[36] Seat Memory (Driver)
LC,02,4,[65] Tire Pressure Monitoring
LC,02,5,[16] Steering Wheel Electronics
LC,02,6,[08] Heating/Air Conditioning (Front)
LC,02,7,[76] Parking Assist
LC,03,0,[05] Access/Start Authorization
LC,03,1,[69] Trailer Function
LC,03,2,[06] Seat Memory (Passenger)
LC,03,3,[09] Central Electronics
LC,03,4,[6D] Rear Lid Electronics
LC,03,5,[28] Heating/Air Conditioning (Rear)
LC,03,6,[6C] Rear View Camera
LC,03,7,[68] Wiper Electronics
LC,04,0,[6E] Control Head (Roof)
LC,04,1,[47] Sound System
LC,04,2,[75] Telematics
LC,04,3,[37] Navigation
LC,04,4,[57] TV-Tuner
LC,04,5,[0F] Radio (Digital)
LC,04,6,[56] Radio (Analog)
LC,04,7,[77] Telephone
LC,05,0,[18] Auxiliary Heating
LC,05,1,[1C] Compass/Position Sensing
LC,05,2,[19] CAN-Gateway
; {Manufacturer}
LC,06,0~3,00,Volkswagen
LC,06,0~3,01,Audi
LC,06,0~3,02,Seat
LC,06,0~3,03,Skoda
LC,06,0~3,04,VW Commercial Vehicles
LC,06,0~3,05,Bugatti
LC,06,0~3,06,Lamborghini
LC,06,0~3,07,Bentley
LC,06,0~3,08,Rolls Royce
LC,06,0~3,0E,Ford
LC,06,0~3,0F,Porsche
; {Model}
LC,06,4~7,00,Shortback/Hatchback
LC,06,4~7,01,Sedan/Limousine
LC,06,4~7,02,Variant/Station Wagon
LC,06,4~7,03,Fastback
LC,06,4~7,04,Coupe/Sports Car
LC,06,4~7,05,Cabriolet/Roadstar
LC,06,4~7,06,Offroad
LC,06,4~7,07,CityVan/PickUp
LC,06,4~7,08,Multi Purpose Vehicle (MPV)
LC,06,4~7,09,Other
; {Other}
LC,07,0,Right Hand Drive
LC,07,1,>= 4 Doors
vag com ищи, самый распространенный и задокументированный адаптер.
Из всего списка мне известен только vag can comander - тебе не подойдет, т.к. в нем все необходимые функции отключены.
Нашел адаптер VAG COM +CAN V-7..,результат тот же,видит только 6 контроллеров и + 7 -ой аэробэги, значит проблема не в адаптере.
Блок комфорта снимал,никаких признаков коррозии все чисто
А как можно прозвонить проводку от блока комфорта до диагностического разъема, когда от комфорта отходят 2 фишки с кучей проводов под переднюю панель, а на диагн. разъеме их всего 7 клемм из них клеммы №4,5 - земля,кл.№16- 12 V, кл.№7 -К-Line,кл.№6 и 14 - CAN, и кл.№1 -черн.-малин.- Х.З,?
сделай фотки диагностики - cangateway
Эту фотку я уже показывал - а фотки по входам в параметры Gateway обязательно на днях сделаю.
при попытке войти в" Измерения 08" всех группах пишет "Ошибка", "Вход 11" впускает и пишет кодирование 00006,код сервиса WSC 43621,но я не стал менять кодировку,пока неуверен,опыта пока мало, кроме сброса нескольких ошибок двигателя,изменил язык на панели приборов с немецкого на английский :unsure:
За время молчания на форуме провел некоторое время с авто:
снял ц.замок водителя,разобрал -плата чистая,микрики в норме,механизм замка в норме,смазал,поставил,все работает осмотрел жгут между дверью и стойкой внешне все в норме.
Еще раз поднял пол водителя,достал Блок Комфорта (БК) осмотрел плату сделал фото,осмотрел жгуты которые на полу и под панелью,все чисто и сухо,никаких окислений массы и контактов,прозвонил линию от диагн.разъема-зел.провод до клеммы БК контакт №11 провод зеленый с коричн.полосой-есть контакт.Еще раз запустил VAG-COM 3.11, нашел ошибки контр.№17 Панель приборов и №19 Gateway-K-Can -оба написали 1.Неисправность 01130 Ценральный блок упр.системами комфорта J393, 49-10 нет связи -Спорадическая, коды стер,возникли видимо из-за отключения БК,при повторном сканировании- ошибок нет.Раз десять подряд нажимал на поиск контроллера 46,где-то прочитал,что иногда с первого раза он может не определяться,но БК так и не обнаружил.Есть еще какие нибудь соображения как определить Бл. Комфорта?
Вопрос решился! Осталось только денег заплатить.Обратился к Viktor_M за помощью,он дап свой БК № 1С0 959 799В чтобы проверить,за что ему очень благодарен,а то еще бы пол машины разобрал.46 контроллер БК Vag-Com 311 открыл без проблем и пропало закрытие дверей при выкл.зажигания.Мой еще работает, основные функции выполняет правда с глюками, поэтому покупать пока не стал-4500р.,никак не входил он в планы расходов.А как насчет ремонта ?Можно его как то реанимировать,например перепрошить?или еще что-то...,внешне плата БК выглядит идеально...
