Блокировка дифференциала Двигатель 1,8 РП
http://store.phantomgrip.com/catalog/produ...products_id=185
вроде оно...
1985 - 2005 VW GOLF
[PGVW6432] $299.95
1985 - 2005 VW GOLF
Click to enlarge
The Phantom Grip Limited Slip conversion kits install into your non-lsd differential converting it into a proven and competitive limited slip differential that enhances your traction needs. Phantom Grips 2-way LSD will considerably improve handling in daily driven, street/strip warrior, or full race vehicle. Every Phantom Grip is constructed of only the highest-quality hand selected materials. With over 500,000 miles of vigorous professional performance testing (SCCA, drag, rally, hill climb, ice, rain, etc.), we have been able to fine tune each application through specific heat treating and rockwell testing to achieve maximum performance and reliability. Each Phantom Grip unit is assembled with pressure tested matched sets of progressive-rate springs to achieve equal load distribution to the disc plates, which dramatically enhances reliability and performance. With such a passion for perfection, we at Phantom Grip are confident that when you choose a Phantom Grip unit, you are choosing, by far, the best limited slip conversion kit on the market. "Disclaimer of Warranty"---WARNING: Installation of any Phantom Grip component or kit should be performed by persons experienced in the installation and proper operation of transmission and drivetrain products. Purchasers expressly affirm they are relying upon their own skill or judgment to select and purchase Phantom Grip limited Slip conversion kits. Warranties are void against incorrect installation, or modifications done to Phantom Grip units.
This product was added to our catalog on Friday 01 February, 2008.
Ну чем закончилось то? Кто-нибудь ставил? Я вот тоже себе хочу заказать...
krt написал(а):
EDS и есть притормаживание нужного колеса, работает от датчиков АБС
Есть ещё EDL (на моём авто, кстати, стоит).Это настоящая блокировка диффа.
Здесь
