Admin
Создатель сайта
Команда форума
- Россия, Москва
- VW Tiguan 2.0 DBGC 2018, VW Touran 1.6 BSE 2008
The High-Voltage System in the Volkswagen ID.4
Self Study Program
Table of Contents
Introduction
High-voltage System Overview
Wiring and Connector Concept
High-voltage System Components
Thermal Management
High-voltage Safety Concept
Driving Mode Selection
Introduction
The VW ID.4 High-Voltage System
The high-voltage system in the Volkswagen ID.4 is completely redesigned to integrate seamlessly with the MEB platform architecture.
The battery is a part of the vehicle chassis, mounted low in the vehicle to provide a lower center of gravity.
The ID.4 will initially be offered with an 82 kWh (gross) battery and a rear-mounted motor with 201 horsepower and 228 pound-feet of torque.
Prior to launch, the Environmental Protection Agency (EPA) estimated 250 miles of range on VW ID.4 1st Edition and VW ID.4 Pro 82 kWh rear-wheel-drive models on a single battery charge.
An all-wheel-drive version with 302 hp will follow later in 2021.
At market introduction the Volkswagen ID.4 will be equipped with a 82 kWh battery. A 62 kWh variant will be available later.
The 82 kWh battery has 288 cells in 12 modules. It is housed in a lightweight aluminum structure that is bolted to the body of the VW ID.4, helping to improve rigidity.
The VW ID.4 can be charged with both alternating current (AC) and direct current (DC) fast-charging capability.
The onboard charger allows the ID.4 to charge the battery up to 33 miles in about one hour, and charges to full in around seven and a half hours at a home or public Level 2 charger.
At a DC fast-charging station, with 125 kW charging, the VW ID.4 can go from five to 80 percent charged in about 38 minutes.
Component Location and Information
High-Voltage Battery 1 AX2
AX2 Specifications:
Three-phase Current Drive VX54 with One-speed Transmission 0MH
VX54 Specifications:
UX4 Specifications:
AC
– Connector J1772
– Number of Phases 2-3
– Max. AC Charging capacity 7.2 kW - 11 kW
DC
– Connector CCS (Combined Charging System)
– Max. DC Charging capacity 50 kW - 125 kW
– Communication:
• PLC (Power Line Communication) communication with the charging station / charging cable
• HLC (High Level Communication) for communication with the vehicle
Charging Unit 1 for High-Voltage Battery AX4
Charging Unit 1 Specifications:
– Input 78 V to 272 V
16 A to 50 A
– Output 220 V to 470 V
– Number of Phases Two
– Efficiency 94%
– Operating Range -40° F to 149° F (- 40° C - 65° C)
Power and Control Electronics for Electric Drive JX1
JX1 Specifications:
– Voltage Range 150 V to 475 V
– Maximum Current 450 A
– Frequency 9 Hz to 10 Hz
This component has an integrated capacitor, which is why a secondary
voltage check is required when de-energizing the high-voltage system.
Air Conditioner Compressor VX81
VX181 Specifications:
– Type Scroll Compressor
– Voltage 195 V to 470 V
– Functional Engine Speed 600 to 8,600 rpm
– Max. Power Consumption 5.5 kW
– Ambient Temperature:
• Air Conditioning Mode 23° F to 158° F (-5° C to 70° C)
• Capable of Communication -40° F to 158° F (-40° C to 70° C)
– Refrigerant for USA R1234yf
– Refrigerant for Canada R744
PTC Heater Element 3 Z132
Z132 Specifications:
– Nominal Voltage 150 V to 475 V
– Activation 0 - 100 %
– Input Current Maximum 30 A
– Communication LIN-bus
Voltage Converter A19
A19 Specifications:
– Nominal Input Voltage 150 V to 475 V
– Charging Power 12 V 3 kW
– Diagnostic Address 8105
High-Voltage Heater (PTC) ZX17
ZX17 Specifications:
– Maximum Power Input 6 kW
– Input Current Maximum 21 A
– Weight 4 lb (1.9 kg)
– AC/DC Isolation > 10 MOhm
Self Study Program
Table of Contents
Introduction
Thermal Management
Introduction
AX2 Specifications:
| Weight | 842 - 1109 lb (382 - 503 kg) |
| Net Energy Content | 58 kWh to 77 kWh |
| Nominal Voltage | 400 V |
| Cell Technology Number of Modules Capacity | Li-ion prismatic/pouch 9 - 12 156 Ah to 234 Ah |
| Cooling System | Liquid Cooling |
| Operating Range | -18 to 140° F (-28° to 60° C) |
| Protection Range | IP6K7, IP6K9K |
| Weight | 198 lb (90 kg) including JX1 |
| Output | Maximum 201 hp (150 kW) |
| Torque Max. Engine Speed Transmission Ratio | Maximum 228 lb/ft (310 Nm) 0 - 16,000 rpm 12.976:1 |
| Drive Shafts | Inserted |
| Manufacturer | Volkswagen Kassel |
UX4 Specifications:
AC
– Connector J1772
DC
– Communication:
16 A to 50 A
– Efficiency 94%
JX1 Specifications:
A19 Specifications:
