Руководство Fuses and relay VW Golf 4 / VW Bora (1J) 1997 - 2005, предохранители и реле
Admin
Admin
Создатель сайта
Команда форума
Россия, Москва
VW Tiguan 2.0 DBGC 2018, VW Touran 1.6 BSE 2008
Position of relays and fuses VW Golf 4 / Bora
Volkswagen Golf 4 (model: 1J1) 1997 - 2004
Volkswagen Bora (model: 1J2) 1999 - 2005
Предохранители и реле Фольксваген Гольф 4 / Бора
Relay positions on relay plate VW Golf 4 / Bora:
1 - J4 - Dual tone horn relay (53)
2 - J59 - X-contact relief relay (18) J59 - X-contact relief relay (100)
3 - Vacant
4 - J17 - Fuel pump relay (167) J52 - Glow plug relay (103)
V - J31 - Automatic intermittent wash and wipe relay
VI - without headlight washer system (377), - with headlight washer system (378), - with rain sensor (192)
Relay arrangements on the relay panel (USA):
1 − Dual Horn Relay (53)
2 − Load Reduction Relay (18)/ (100)
3 − open
4 − Fuel Pump (FP) Relay (409)
V − Wiper/Washer Intermittent Relay,
VI − Vehicles without headlight washer system (377), − Vehicles with headlight washer system (389), − Vehicles with rain sensor (192)
Fuse locations on relay plate:
A - Seat adjustment fuse
B - Vacant
C - Window regulator fuse, central locking and heated exterior mirror (only models with convenience system and window regulator)
Fuse placement on the relay panel (USA):
A − Power (Memory) Seat Circuit Breaker (30 Amp.)
B − open
C − Fuse for power windows (circuit breaker) (30 Amp.) central locking system, heated power mirrors, (vehicles with Comfort System and power windows only)
Relay locations on the 13 position additional relay carrier above the relay plate, left-handdrive VW Golf 4 / Bora:
1 - Fog light relay (53)
2 - Rear lid remote release relay (79)
3 - Starter inhibitor relay (185)
4 - Vacant
5 - Vacant
6 - Telephone D-network relay (147)
7 - Electronic rev. counter relay (EPC) (94)
8 - Daytime running lights relay (173)
9 - Taxi alarm system control unit, fuel pump relay, syncro-diesel (53)
10 - Taxi alarm system control unit, glow plug relay TDI (OBDII), for USA only (180)
11 - Starter inhibitor and reversing light relay (175)
12 - Terminal 30 voltage supply relay (109)
13 - Radiator fan relay (53) radiator fan run-on relay (181)
Fuse locations on 13 position additional relay carrier, left-handdrive VW Golf 4 / Bora:
D - Vacant
E - Rear window regulator fuse
F - ATA turn signal fuse, 15A
G - ATA horn fuse, 15 A
Fuse arrangements on the thirteenfold auxiliary relay panel (USA):
D − Open
E − Open
F − Fuse for central locking/anti−theft warning system (15 Amp.)
G − Fuse for central locking/anti−theft warning system (15 Amp.)
Fuse colours
30 A - green
25 A - white
20 A - yellow
15 A - blue
10 A - red
7,5 A - brown
5 A - beige
3 A - purple
Notes:
- Fuses from S 23 are designated with an additional 2 in the Current Flow Diagram.
- Example: S 40 is designated as S 240.
Fuses in fuse holder VW Golf 4 / Bora:
No.Current Flow Diagram designationNominal valueFunction/componentTerminal
1S1 - Fuse 1 in fuse holder10 AHeated washer jetsX
2S2 - Fuse 2 in fuse holder10 ATurn signal system and hazard warning lights system75x
3S3 - Fuse 3 in fuse holder5 AGlove compartment light58a
4S4 - Fuse 4 in fuse holder5 AX - Number plate light58a
5S5 - Fuse 5 in fuse holder7.5 AConvenience electrics, cruise control system (GND)
Climatronic
heated driver seat control unit
heated front passenger seat control unit
15a
6S6 - Fuse 6 in fuse holder5 ACentral locking15a
7S7 - Fuse 7 in fuse holder10 AReversing light15a
8S8 - Fuse 8 in fuse holder5 ATelephone aerial15a
9S9 - Fuse 9 in fuse holder5 AAnti-lock brake system (ABS)15a
10S10 - Fuse 10 in fuse holder5 AEngine management petrol engines30a
11S11 - Fuse 11 in fuse holder10 ADash panel insert, selector lever lock solenoid15a
12S12 - Fuse 12 in fuse holder10 ASelf-diagnosis connection voltage supply, telephone system30a
13S13 - Fuse 13 in fuse holder10 ABrake lights
14S14 - Fuse 14 in fuse holder10 AInterior illumination, central locking30a
15S15 - Fuse 15 in fuse holder5 ADash panel insert, automatic gearbox30a
16S16 - Fuse 16 in fuse holder10 AMagnetic clutch, radiator fan run-on30a
17S17 - Fuse 17 in fuse holder-Vacant
18S18 - Fuse 18 in fuse holder10 ALeft headlight main beam56a
19S19 - Fuse 19 in fuse holder10 ARight headlight main beam56a
20S20 - Fuse 20 in fuse holder10 ARight headlight dipped beam, headlight range control56b
21S21 - Fuse 21 in fuse holder10 ALeft headlight dipped beam56b
22S22 - Fuse 22 in fuse holder5 ASide light right58R
23S23 - Fuse 23 in fuse holder5 ASide light left58L
24S24 - Fuse 24 in fuse holder20 AWindscreen wiper system75x
25S25 - Fuse 25 in fuse holder25 AFresh air blower
air conditioning system, Climatronic
75x
26S26 - Fuse 26 in fuse holder20 AHeated rear window
heated exterior mirror (for models without electric window regulator)
75x
27S27 - Fuse 27 in fuse holder10 ARear window wiper system75x
28S28 - Fuse 28 in fuse holder15 AFuel pump / pre-supply pump75x
29S29 - Fuse 29 in fuse holder15 A
10 A
engine management diesel engines
15a
30S30 - Fuse 30 in fuse holder20 ASliding/tilting sunroof30a
31S31 - Fuse 31 in fuse holder20 AAutomatic gearbox15a
32S32 - Fuse 32 in fuse holder20 AEngine management, injectors
87
33S33 - Fuse 33 in fuse holder20 AHeadlight washer system (HWS)30a
34S34 - Fuse 34 in fuse holder10 AEngine management87
35S35 - Fuse 35 in fuse holder30 ATrailer socket30a
36S35 - Fuse 36 in fuse holder15 AFog light and rear fog lightX
37S37 - Fuse 37 in fuse holder10 AS-contact86s
38S38 - Fuse 38 in fuse holder15 ALuggage compartment light, central locking30a
39S39 - Fuse 39 in fuse holder15 AHazard warning lights system30a
40S40 - Fuse 40 in fuse holder20 ADual tone horn30a
41S41 - Fuse 41 in fuse holder15 ACigarette lighter30a
42S42 - Fuse 42 in fuse holder25 ARadio system30a
43S43 - Fuse 43 in fuse holder10 AEngine management87
44S44 - Fuse 44 in fuse holder10 ASeat heating30a
Position of fuses in fuse holder/battery (VW Golf 4 / Bora up to August 2000):
S162 - Heated pin heating 50 A
S163 - Engine management 50 A
S164 - Radiator fan 30 A
S176 - Interior 110 A
S177 - Alternator (90 A), 110 A
- Alternator (120 A), 150 A
S178 - ABS (pump) 30 A
S179 - ABS 30 A
S180 - Radiator fan 30 A
Position of fuses in fuse holder/battery (VW Golf 4 / Bora from September 2000):
S164 - Radiator fan 40 A
S179 - ABS 30 A
Volkswagen Golf Variant 4 (model: 1J5) 1998- 2006
Volkswagen Bora Variant (model: 1J6) 1999 - 2006
Relay positions on relay plate:
3 - Vacant
4 - J17 - Fuel pump relay (409) J52 - Glow plug relay (103)
V / VI - J31 - Automatic intermittent wash and wipe relay, without headlight washer system (377), -with headlight washer system (389), -with rain sensor (192)
B - Fuses for V192 - Vacuum pump for brakes (from May 2002)
Relay locations on the 13 position additional relay carrier above the relay plate, left-handdrive vehicles:
1 - Vacant
2 - J398 - Rear lid remote release relay (79) J546 - Rear lid remote release control unit (407)
3 - Vacant
4 - J5 - Fog light relay (53)
5 - J453 - Multifunction steering wheel control unit (450)
6 - J453 - Multifunction steering wheel control unit (450)
7 - J508 - Brake light suppression relay (206)
8 - J99 - Heated exterior mirror relay (53) J541 - Coolant shut-off valve relay (53)
9 - J17 - Fuel pump relay, four-wheel-diesel, (53)
10 - J17 - Fuel pump relay (pre-supply pump) (167)
11 - J226 - Starter inhibitor and reversing light relay (175)
12 - J317 - Terminal 30 voltage supply relay (109)
13 - J151 - Continued coolant circulation relay (53)
Fuse locations on 13 position additional relay carrier, left-handdrive vehicles:
D - Vacant
E - Vacant
F - S30 - Rear window wiper single fuse 15A (from December 2005), S144 - Anti-theft alarm system central locking fuse (ATA turn signal) 15A
G - S111 - Anti-theft alarm system fuse (ATA horn), 15A
Fuse colours
30 A - green
25 A - white
20 A - yellow
15 A - blue
10 A - red
7,5 A - brown
5 A - beige
3 A - purple
Notes:
Fuses in fuse holder VW Golf Variant 4 / VW Bora Variant:
1S1 - Fuse 1 in fuse holder5 AZ4 - Driver side heated exterior mirror (models without ohne electric window regulator)
Z5 - Front passenger side heated exterior mirror (models without ohne electric window regulator)
Z20 - Left washer jet heater element
Z21 - Right washer jet heater element
X
2S2 - Fuse 2 in fuse holder5 AE3 - Hazard warning light switch
J1 - Turn signal relay
M5 - Front left turn signal bulb
M6 - Rear left turn signal bulb
M7 - Front right turn signal bulb
M8 - Rear right turn signal bulb
J567 - Left gas discharge light control unit
J568 - gas discharge light control unit with headlight range control right
75x
3S3 - Fuse 3 in fuse holder5 AJ5 - Fog light relay
E20 - Switches and instruments illumination regulator
58a
4S4 - Fuse 4 in fuse holder5 AX - Number plate lights58a
5S5 - Fuse 5 in fuse holder7.5 AE45 - Cruise control system switch
E221 - Operating unit in steering wheel
E227 - Cruise control system button (CCS) SET button
G65 - High pressure sender (air conditioning system)
J131 - Heated driver seat control unit
J132 - Heated front passenger seat control unit
J245 - Sliding sunroof adjustment control unit (models without central locking)
J255 - Climatronic
G266 - Oil level and oil temperature sender
J293 - Radiator fan control unit, multifunction steering wheel
J393 - Convenience system (E231 - Exterior mirror heater button),
J446 - Parking aid control unit
J503 - Control unit with display for radio and navigation system
N147 - 2-way valve for coolant shut-off valve (above F269 - temperature flap position switch)
V154 - Fresh air/recirculated air flap control motor
15a
5 A
Up to April 2001:
J379 - Central locking and anti-theft alarm system control unit
from September 2002:
J651 - Shut-off valve relay 1 (engine code BEH)
15a
7S7 - Fuse 7 in fuse holder10 AK142 - Selector lever position P/N warning lamp
M16 - Left reversing light bulb
M17 - Right reversing light bulb
15a
8S8 - Fuse 8 in fuse holder5 AJ412 - Mobile telephone operating electronics control unit15a
9S9 - Fuse 9 in fuse holder5 AE256 - TCS and ESP button
G85 -Steering angle sender
J104 - ABS/ABS control unit with EDL/ ASR/ ESP
15a
10S10 - Fuse 10 in fuse holder15 A
5 A
10 A
up to October 2001:
Engine management: Petrol
Engine management: Diesel
from November 2001:
R - Radio (S-contact)
J285 - Display in dash panel insert
30a
86s
11S11 - Fuse 11 in fuse holder5 AJ285 - Control unit with display in dash panel insert
N110 - Selector lever lock solenoid
15a
12S12 - Fuse 12 in fuse holder7.5 AJ412 - Mobile telephone operating electronics control unit
G273 - Interior monitoring sensor
G274 - Interior monitoring sender
T16 - 16-pin connector, (in centre dash panel, self-diagnosis connection)
W11 - Rear left reading light (models with interior monitor)
W12 - Rear right reading light (models with interior monitor)
30a
13S13 - Fuse 13 in fuse holder10 AF - Brake light switch
M9 - Left brake light bulb (only Golf/Bora)
J.....-.Engine control units
M10 - Right brake light bulb (only Golf/Bora)
M21 - Left brake and tail light bulb (only Golf Variant/Bora Variant)
M25 - High level brake light bulb
30a
54
14S14 - Fuse 14 in fuse holder10 AJ393 - Convenience system central control unit (models without central lock)
models without central lock:
M27 - Left door warning lamp
M28 - Right door warning lamp
W - Front interior light
W3 - Luggage compartment light
W12- Rear right reading light
W14 - Illuminated vanity mirror (front passenger side)
W18 - Luggage compartment light on left
W19 - Reading light/driver side
W20 - Illuminated vanity mirror (driver side)
30a
15S15 - Fuse 15 in fuse holder5 AG85 - Steering angle sender
J217 - Automatic gearbox control unit
30a
16S16 - Fuse 16 in fuse holder10 AJ255 - Climatronic
30a
17Vacant---
18S18 - Fuse 18 in fuse holder10 AJ285 - Control unit with display in dash panel insert
L2 - Right twin filament bulb (only Bora)
M32 - Right main beam bulb (only Golf)
56a
19S19 - Fuse 19 in fuse holder10 AL1 - Left twin filament bulb (only Bora)
M30 - Left headlight main beam bulb (only Golf)
56a
20S20 - Fuse 20 in fuse holder15 AE102 - Headlight range control regulator
J427 - Right headlight starter for gaseous discharge light
J568 - Gas discharge light control unit with headlight range control right
M31 - Right headlight dipped beam bulb (only Golf)
V48 - Left headlight range control motor
V49 - Right headlight range control motor
56b
21S21 - Fuse 21 in fuse holder15 AL1 - Left twin filament bulb (only Bora),
M29 - Left headlight dipped beam bulb (only Golf)
J426 - Left headlight starter for gaseous discharge light,
J567 - Gas discharge light control unit with headlight range control left
56b
22S22 - Fuse 22 in fuse holder5 AJ285 - Control unit with display in dash panel insert
M3 - Right side light bulb
58R
23S223 - Fuse 23 in fuse holder5 AJ285 - Control unit with display in dash panel insert
M1 - Left side light bulb
58L
24S224 - Fuse 24 in fuse holder20 AE22 - Intermittent wiper switch, windscreen wiper motor
V - Windscreen wiper motor
V59 - Windscreen and rear window washer pump
75x
25S225 - Fuse 25 in fuse holder20 AE9 - Fresh air blower switch
E35 - Air conditioning system switch
N24 - Fresh air blower series resistor with overheating fuse
V2 - Fresh air blower
J255 - Climatronic
J... -Engine control units
75x
26S226 - Fuse 26 in fuse holder25 AZ1 - Heated rear window75x
27S227 - Fuse 27 in fuse holder15 A
15 A
up to November 2005:
V12 - Rear window wiper motor
from December 2005:
U1 - Cigarette lighter
U5 - 12 V socket, on left in luggage compartment
75x
75x
28S228 - Fuse 28 in fuse holder15 AG6 - Fuel pump (pre-supply pump)75x
29S229 - Fuse 29 in fuse holder15 A
20 A
10 A
Petrol (not for engine code BDE)
Engine management: Engine code BDE
15a
30S230 - Fuse 30 in fuse holder20 AJ245 - Sliding sunroof adjustment control unit
V1 - Sliding sunroof motor
30a
31S231 - Fuse 31 in fuse holder20 A
5 A
F125 - Multifunction switch
J542 - Brake servo control unit
J492 - Four-wheel drive control unit (4 Motion)
15a
32S232 - Fuse 32 in fuse holder10 A
30 A
Injectors: Petrol
87
33S233 - Fuse 33 on fuse holder20 AJ31 - Automatic intermittent wash and wipe relay
V11 - Headlight washer system pump
30a
34S234 - Fuse 34 on fuse holder10 AEngine management87
35S235 - Fuse 35 on fuse holder30 AU10 - Trailer socket
U5-12 V socket, on left in luggage compartment
30a
36S236 - Fuse 36 on fuse holder15 AJ5 - Fog light relay
L22 - Left fog light bulb
L23 - Right fog light bulb
L46 - Rear left fog light bulb
X
37S237 - Fuse 37 in fuse holder15 A
5 A
10 A
up to October 2001:
R - Radio, S-contact
from November 2001:
30a
86s
38S238 - Fuse 38 in fuse holder15 AE204 - Tank filler flap remote release switch
J386 - Driver door control unit
J387 - Front passenger door control unit
J388 - Rear left door control unit
J389 - Rear right door control unit
V155- Tank filler flap locking motor
30a
39S223 - Fuse 39 in fuse holder15 AE3 - Hazard warning light switch
J567 - Gas discharge light control unit with headlight range control right
30a
40S240 - Fuse 40 in fuse holder20 AH1 - Dual tone horn30a
41S241 - Fuse 41 in fuse holder15 Aup to November 2005:
U1-Cigarette lighter
30a
42S242 - Fuse 42 in fuse holder25 AR - Radio
R12 - Amplifier
J415 - Navigation system tuner for TV
J559 - Traffic information control unit
30a
43S243 - Fuse 43 in fuse holder10 AEngine management87
44S244 - Fuse 44 on fuse holder15 AJ131 -Heated driver seat control unit
J132 -Heated front passenger seat control unit
30a
Position of fuses in fuse holder/battery (VW Golf Variant 4 / VW Bora Variant up to August 2000):
S179 - ABS 30 A
Position of fuses in fuse holder/battery (VW Golf Variant 4 / VW Bora Variant from September 2000):
S179 - ABS 30 A
