Руководство Fuses VW ID.4 / ID.5 (E21, E39) 2020 -, предохранители и реле
Admin
Admin
Создатель сайта
Команда форума
Россия, Москва
VW Tiguan 2.0 DBGC 2018, VW Touran 1.6 BSE 2008
Volkswagen ID.4 (model: E21) 2020 -
Volkswagen ID.5 (model: E39) 2021 -
ComponentChapter
Fuse holder A -SA-Holder A -SA-, from May 2020
Fuse holder B -SB-Holder B -SB- , from May 2020
Fuse holder C -SC-Holder C -SC- , from May 2020
Fuse holder C -SC-Holder C -SC-, from June 2021
Fuse carrier 1 -ST1-Fuses, from May 2020
Fuse carrier 2 -ST2-Fuses, from May 2020
Fuse carrier 8 -ST8-Fuses, from May 2020
Relays VW ID.4 / ID.5
Heated rear window relay -J9- on fuse holder C -SC-, left-hand drive VW ID.4 / ID.5, from May 2020
Air conditioning system relay -J32- on fuse holder B -SB-, VW ID.4 / ID.5 from May 2020
Heated windscreen relay -J47- on fuse holder B -SB-, VW ID.4 / ID.5 from May 2020
Main relay -J271- on fuse holder B -SB-, VW ID.4 / ID.5 from May 2020
Terminal 15 voltage supply relay -J329- on fuse holder C -SC-, left-hand drive VW ID.4 / ID.5, from May 2020
Horn relay -J413- on fuse holder B -SB-, VW ID.4 / ID.5 from May 2020
Relay for power sockets -J807- on fuse holder C -SC-, left-hand drive VW ID.4 / ID.5, from May 2020
Fuse holder A -SA- , VW ID.4 / ID.5 from May 2020
Fitting location of fuse holder A -SA-, from May 2020
1 - Fuse holder A -SA-
Multifuse strip fuse
Fuse assignment for fuse holder A -SA-, VW ID.4 / ID.5 from May 2020
SlotCurrent flow diagram designationNominal
value
Function / componentTerminal
508508 Threaded connection (30), on E-box-Battery -A-30
SA1Fuse 1 on fuse holder A -SA1-350 AVoltage converter -A19-30
SA2Fuse 2 on fuse holder A -SA2-80 ABattery monitor control unit -J367-
Power steering control unit -J500-
30
SA3Fuse 3 on fuse holder A -SA3-100 AFuse holder C -SC-30
SA4Fuse 4 on fuse holder A -SA4-100 AFuse holder C -SC-30
SA5not assigned--
SA6Fuse 6 on fuse holder A -SA6-125 AFuse holder B -SB-30
  • Спасибо!
Реакции: tume
Fuse holder B -SB- , VW ID.4 / ID.5 from May 2020
Fitting location of fuse holder B -SB-, from May 2020
1 - Fuse holder B -SB
Fuse colours for J-Case fuse:
50 A - red
40 A - green
30 A - pink
Fuse colours for ATO flat fuse:
40 A - orange
30 A - light green
25 A - natural (white)
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
Fuse colours, for mini fuses:
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
Fuse assignment for fuse holder B -SB-, VW ID.4 / ID.5 from May 2020
value
SB1not assigned--
SB2Fuse 2 on fuse holder B -SB2-7.5 AABS control unit -J104-30
SB3Fuse 3 on fuse holder B -SB3-10 ACharging unit 1 for high-voltage battery -AX4-
Power and control electronics for electric drive -JX1-
Power and control electronics 2 for electric drive -JX4-
30
SB4Fuse 4 on fuse holder B -SB4-30 AFront left headlight -MX1-30
SB5Fuse 5 on fuse holder B -SB5-30 AFront right headlight -MX2-30
SB6Fuse 6 on fuse holder B -SB6-7.5 AAdaptive cruise control unit -J428-30
SB7not assigned--
SB8not assigned--
SB9Fuse 9 on fuse holder B -SB9-15 AOnboard supply control unit -J519-30
SB10Fuse 10 on fuse holder B -SB10-30 AWiper motor control unit -J400-30
SB11Fuse 11 on fuse holder B -SB11-7.5 AAir conditioning system relay -J32-30
SB12Fuse 12 on fuse holder B -SB12-7.5 AEngine sound generator module 1 -RX21-30
SB13Fuse 13 on fuse holder B -SB13-25 AABS control unit -J104-30
SB14not assigned--
SB15Fuse 15 on fuse holder B -SB15-40 AABS control unit -J104-30
SB16Fuse 16 on fuse holder B -SB16-50 ARadiator fan -VX57-30
SB17Fuse 17 on fuse holder B -SB17-40 AHeated windscreen -Z2-30
SB18not assigned--
SB19not assigned--
SB20not assigned--
SB21not assigned--
SB22not assigned--
SB23Fuse 23 on fuse holder B -SB23-10 AEngine/motor control unit -J623-87A
SB24Fuse 24 on fuse holder B -SB24-5 ARadiator fan -VX57-87A
SB25Fuse 25 on fuse holder B -SB25-10 ACoolant pump for high-voltage battery -V590-
PTC heater element 3 -Z132-
87A
SB26Fuse 26 on fuse holder B -SB26-10 ACoolant pump for low-temperature circuit -V468-
Control motor for radiator roller blind -V711-
87A
SB27not assigned--
SB28not assigned--
SB29not assigned--
SB30not assigned--
SB31not assigned--
SB32Fuse 32 on fuse holder B -SB32-50 ABrake servo -NX6-30
Fuse holder C -SC- , VW ID.4 / ID.5 from May 2020
Fitting location of fuse holder C -SC-, left-hand drive models, from May 2020
1 - Fuse holder C -SC
50 A - red
40 A - green
30 A - pink
40 A - orange
30 A - light green
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
Fuse assignment for fuse holder C -SC-, VW ID.4 / ID.5 from May 2020
value
SC1not assigned--
SC2Fuse 2 on fuse holder C -SC2-15 AAirbag control unit -J234-30
SC3Fuse 3 on fuse holder C -SC3-25 ATrailer detector control unit -J345-30
SC4Fuse 4 on fuse holder C -SC4-7.5 AFront camera for driver assist systems -R242-30
SC5Fuse 5 on fuse holder C -SC5-25 AOnboard supply control unit -J519-30
SC6Fuse 6 on fuse holder C -SC6-30 AOnboard supply control unit -J519-30
SC7Fuse 7 on fuse holder C -SC7-30 AHeater and air conditioning system control unit -J979-30
SC8Fuse 8 on fuse holder C -SC8-15 ASliding sunroof adjustment control unit -J245-30
SC9Fuse 9 on fuse holder C -SC9-30 ADriver door control unit -J386- 1)
Front passenger door control unit -J387- 2)
Rear driver side door control unit -J926- 1)
Passenger side rear door control unit -J927- 2)
30
SC10Fuse 10 on fuse holder C -SC10-10 ALeft tail light cluster -MX3-
Centre tail light cluster -MX13-
30
SC11Fuse 11 on fuse holder C -SC11-15 ATrailer detector control unit -J345-30
SC12not assigned--
SC13Fuse 13 on fuse holder C -SC13-40 AOnboard supply control unit -J519-30
SC14Fuse 14 on fuse holder C -SC14-30 ADigital sound package control unit -J525-30
SC15not assigned--
SC16not assigned--
SC17Fuse 17 on fuse holder C -SC17-5 AParking aid control unit -J446-
Lane change assist control unit -J769-
Lane change assist control unit 2 -J770-
30
SC18Fuse 18 on fuse holder C -SC18-5 AControl unit for electronic steering column lock -J764-
Rear lid power opening control unit -J938-
Interface for entry and start system -J965-
Control unit 2 for break-in protection -J1192-
Control unit 3 for break-in protection -J1193-
Control unit 4 for break-in protection -J1194-
Control unit 5 for break-in protection -J1195-
Control unit for mobile-controlled entry and start authorisation system -J1308-
Engine sound generator module 2 -RX22-
30
SC19Fuse 19 on fuse holder C -SC19-5 AEmergency call module control unit and communication unit -J949-
Control unit with display unit for driver information system -J1254-
30
SC20Fuse 20 on fuse holder C -SC20-10 ATelephone bracket -R126-
Transmission and reception stabilisation control unit -R308-
USB connection 1 -U41-
30
SC21Fuse 21 on fuse holder C -SC21-7.5 ARear lid handle -EX37-
Control unit for overhead view camera -J928-
30
SC22Fuse 22 on fuse holder C -SC22-10 AEngine/motor control unit -J623-30
SC23Fuse 23 on fuse holder C -SC23-5 AInternet access control unit -J666-30
SC24Fuse 24 on fuse holder C -SC24-10 ARight tail light cluster -MX4-
30
SC25Fuse 25 on fuse holder C -SC25-25 AFront left seat belt -NX10-30
SC26Fuse 26 on fuse holder C -SC26-30 ADriver door control unit -J386- 2)
Front passenger door control unit -J387-1)
Rear driver side door control unit -J926-2)
Passenger side rear door control unit -J927-1)
30
SC27Fuse 27 on fuse holder C -SC27-25 AFront right seat belt -NX11-30
SC28Fuse 28 on fuse holder C -SC28-10 ABattery regulation control unit -J840-
Maintenance connector for high-voltage system -TW
30
SC29Fuse 29 on fuse holder C -SC29-15 ATrailer detector control unit -J345-30
SC30Fuse 30 on fuse holder C -SC30-20 AControl unit 1 for information electronics -J794-30
SC31Fuse 31 on fuse holder C -SC31-25 ATrailer detector control unit -J345-30
SC32Fuse 32 on fuse holder C -SC32-25 AOnboard supply control unit -J519-30
SC33not assigned--
SC34Fuse 34 on fuse holder C -SC34-15 AHeater and air conditioning system control unit -J979-30
SC35not assigned--
SC36Fuse 36 on fuse holder C -SC36-40 AFresh air blower control unit -J126-30
SC37Fuse 37 on fuse holder C -SC37-30 ARear lid control unit -J605-30
SC38Fuse 38 on fuse holder C -SC38-7.5 AControl unit for front left massage seat -J803-
Control unit for front right massage seat -J804-
30
SC39Fuse 39 on fuse holder C -SC39-15 ASteering column electronics control unit -J527-30
SC40Fuse 40 on fuse holder C -SC40-10 AAlarm horn -H12-30
SC41Fuse 41 on fuse holder C -SC41-5 AData bus diagnostic interface -J533-30
SC42not assigned--
SC43Fuse 43 on fuse holder C -SC43-7.5 AOperating and display unit for rear air conditioning system -E265-
Sensor for interior carbon dioxide concentration -G929-
Vehicle interior temperature sensor -G1090-
30
SC44Fuse 44 on fuse holder C -SC44-7.5 AOperating unit for window regulator in driver door -EX36-
Diagnostic connection -U31-
30
SC45Fuse 45 on fuse holder C -SC45-5 ASteering column electronics control unit -J527-30
SC46Fuse 46 on fuse holder C -SC46-10 ADisplay unit for front information display and operating unit control unit -J685-
Control unit for Head-up Display -J898-
30
SC47Fuse 47 on fuse holder C -SC47-10 AElectronically controlled damping control unit -J250-30
SC48Fuse 48 on fuse holder C -SC48-10 AUSB charging socket 1 -U37-15
SC49not assigned--
SC50not assigned--
SC51not assigned--
SC52Fuse 52 on fuse holder C -SC52-20 A12 V socket 3 -U19-15
SC53not assigned--
SC54not assigned--
SC55not assigned--
SC56not assigned--
SC57not assigned--
SC58Fuse 58 on fuse holder C -SC58-7.5 AControl unit for mobile-controlled entry and start authorisation system -J1308-15
SC59Fuse 59 on fuse holder C -SC59-7.5 ASeat occupied recognition control unit -J706-
Automatic anti-dazzle interior mirror -Y7-
15
SC60Fuse 60 on fuse holder C -SC60-7.5 ADiagnostic connection -U31-15
SC61Fuse 61 on fuse holder C -SC61-5 APower and control electronics for electric drive -JX1-
15
SC62not assigned--
SC63not assigned--
SC64not assigned--
SC65not assigned--
SC66Fuse 66 on fuse holder C -SC66-15 ARear window wiper motor -V12-15
SC67Fuse 67 on fuse holder C -SC67-30 AFrequency modulation (FM) frequency filter in positive wire -R179-30
1) For left-hand drive models
2) For right-hand drive models
Fuse holder C -SC-, VW ID.4 / ID.5 from June 2021
Fitting location of fuse holder C -SC-, LHD models, from June 2021
95406
Fuse assignment for fuse holder C -SC-, VW ID.4 / ID.5 from June 2021
value
SC1not assigned--
30
30
SC12not assigned--
SC15not assigned--
SC16not assigned--
30
30
30
SC20Fuse 20 on fuse holder C -SC20-7.5 ATelephone bracket -R126-
30
30
30
30
30
SC30Fuse 30 on fuse holder C -SC30-25 AControl unit 1 for information electronics -J794-30
SC33not assigned--
SC35not assigned--
30
SC40Fuse 40 on fuse holder C -SC40-7.5 AAlarm horn -H12-30
SC42not assigned--
30
30
SC46Fuse 46 on fuse holder C -SC46-7.5 ADisplay unit for front information display and operating unit control unit -J685-
30
SC48Fuse 48 on fuse holder C -SC48-7.5 AUSB charging socket 1 -U37-15
SC49not assigned--
SC50not assigned--
SC51not assigned--
SC53not assigned--
SC54not assigned--
SC55not assigned--
SC56not assigned--
SC57not assigned--
15
15
SC62not assigned--
SC63not assigned--
SC64not assigned--
SC65not assigned--
Individual fuses, Volkswagen ID.4 / ID.5 from May 2020
Fitting location of individual fuses, left-hand drive models, from May 2020
1 - Holder
2 - Fuse carrier 8 -ST8-
3 - not assigned
4 - Fuse carrier 1 -ST1-
5 - Fuse carrier 2 -ST2-
Fuse assignment for individual fuses, left-hand drive models VW ID.4 / ID.5, from May 2020
Note: For left-hand drive models
value
ATrailer towing attachment thermal fuse -S87-30 APotentiometer for electric trailer brakes -G508- 1)30
Bnot assigned--
CDriver seat adjustment thermal fuse 1 -S44-15 ADriver seat adjustment control unit -J810-30
DDriver seat adjustment thermal fuse 2 -S45-15 AFront passenger seat adjustment control unit -J720-30
1) For American markets
Relays on fuse holder B -SB-, VW ID.4 / ID.5 from May 2020
Fuse holder B -SB-
R1 - Main relay -J271-
R2 - Heated windscreen relay -J47-
R3 - Horn relay -J413-
R4 - not assigned
R5 - not assigned
R6 - Air conditioning system relay -J32-
Relays on fuse holder C -SC-, VW ID.4 / ID.5 from May 2020
Relays on fuse holder C -SC-, left-hand drive models, from May 2020
1 - Fuse holder C -SC-
R1 - Relay for power sockets -J807-
R2 - Terminal 15 voltage supply relay -J329-
R3 - Heated rear window relay -J9-
