| Slot | Current Flow Diagram designation | Nominal value | Function/component | Terminal |
SC1 | Fuse 1 on fuse holder C -SC1- | 40 A | Onboard supply control unit -J519- | 30 |
SC2 | Fuse 2 on fuse holder C -SC2- | 40 A | Onboard supply control unit -J519- | 30 |
SC3 | Fuse 3 on fuse holder C -SC3- | 30 A | Onboard supply control unit -J519- | 30 |
SC4 | Fuse 4 on fuse holder C -SC4- | 50 A | Low heat output relay -J359-1) | 30 |
SC5 | Fuse 5 on fuse holder C -SC5- | 30 A | Driver door control unit -J386- | 30 |
SC6 | Fuse 6 on fuse holder C -SC6- | 30 A | Rear left door control unit -J388- | 30 |
SC7 | Fuse 7 on fuse holder C -SC7- | 20 A | Onboard supply control unit -J519-
- Treble horn -H2-
- Bass horn -H7- | 30 |
SC8 | Fuse 8 on fuse holder C -SC8- | 30 A | Mechatronic unit for dual clutch gearbox -J743- | 30 |
SC9 | Fuse 9 on fuse holder C -SC9- | 30 A | Sliding sunroof motor -V1- | 30 |
SC10 | Fuse 10 on fuse holder C -SC10- | 7.5 A | Electronically controlled damping control unit -J250- | 30 |
SC11 | Fuse 11 on fuse holder C -SC11- | 30 A | Headlight washer system relay -J39- | 30 |
SC12 | Fuse 12 on fuse holder C -SC12- | 5 A/
10 A | Two-way signal amplifier for mobile telephone/data services -J984-
Storage compartment with interface for mobile telephone -R265-
Multimedia system operating unit -E380-
Supply for fuse 18 on fuse holder C -SC18- and fuse 19 on fuse holder C -SC19- | 30 |
SC13 | Fuse 13 on fuse holder C -SC13- | 30 A | Terminal 15 relay -J940- | 30 |
SC14 | Fuse 14 on fuse holder C -SC14- | 7.5 A | Diagnostic connection -U31-
Ignition key withdrawal lock solenoid -N376-
Steering column combination switch -E595-
Light switch -E1- | 30 |
SC15 | Fuse 15 on fuse holder C -SC15- | 7.5 A | Air conditioning system control unit -J301-
Gearbox switch -E206-
Heater control unit -J65-
Selector lever -E313- | 30 |
SC16 | Fuse 16 on fuse holder C -SC16- | 5 A | Dash panel insert -K- | 30 |
SC17 | Fuse 17 on fuse holder C -SC17- | 7.5 A | Anti-theft alarm sensor -G578-
Anti-theft alarm system horn -H8- | 30 |
SC18 | Fuse 18 on fuse holder C -SC18- | 5 A | Multimedia system operating unit -E380- | 30 |
SC19 | Fuse 19 on fuse holder C -SC19- | 5 A | Two-way signal amplifier for mobile telephone/data services -J984-
Storage compartment with interface for mobile telephone -R265- | 30 |
SC20 | Not assigned | | | |
SC21 | Not assigned | | | |
SC22 | Not assigned | | | |
SC23 | Fuse 23 on fuse holder C -SC23- | 7.5 A | Washer pump -V5- | 30 |
SC24 | Fuse 24 on fuse holder C -SC24- | 30 A | Fresh air blower control unit -J126-
Fresh air blower isolation relay -J487-
Heater control unit -J65- | 75 |
SC25 | Not assigned | | | |
SC26 | Fuse 26 on fuse holder C -SC26- | 5 A | Heated driver seat regulator -E94-
Heated front passenger seat regulator -E95- | 75 |
SC27 | Fuse 27 on fuse holder C -SC27- | 15 A | Rear window wiper motor -V12- | 75 |
SC28 | Fuse 28 on fuse holder C -SC28- | 20 A | Cigarette lighter -U1- | 75 |
SC29 | Fuse 29 on fuse holder C -SC29- | 7.5 A | Airbag control unit -J234-
Front passenger side airbag deactivated warning lamp -K145- | 15 |
SC30 | Fuse 30 on fuse holder C -SC30- | 7.5 A | Tyre Pressure Loss Indicator button -E492-
TCS and ESP button -E256-
Reversing light switch -F4-
Automatic anti-dazzle interior mirror -Y7-
Mirror adjustment switch -E43-
Refrigerant circuit pressure sender -G805-
Light switch -E1-
Parking aid control unit -J446-
Heater control unit -J65- | 15 |
SC31 | Fuse 31 on fuse holder C -SC31- | 5 A | Washer pump relay -J576-
Fuel pump control unit -J538- | 15 |
SC32 | Fuse 32 on fuse holder C -SC32- | 7.5 A | Diagnostic connection -U31-
Headlight range control unit -J431-
Headlight range control and instrument illumination regulator -EX14-
Front left headlight -MX1-
Alarm horn relay -J641-
Front right headlight -MX2- | 15 |
SC33 | Fuse 33 on fuse holder C -SC33- | 5 A | Clutch position sender -G476-
Starter relay 1 -J906-
Starter relay 2 -J907-
Control unit for structure-borne sound -J869- 4) | 15 |
SC34 | Fuse 34 on fuse holder C -SC34- | 5 A | Left washer jet heater element -Z20-
Right washer jet heater element -Z21- | 15 |
SC35 | Not assigned | | | |
SC36 | Fuse 36 on fuse holder C -SC36- | 10 A | Heated front seats control unit -J774- | 15 |
SC37 | Fuse 37 on fuse holder C -SC37- | 5 A | Adaptive cruise control unit -J428-
Radiator fan control unit -J293-
Steering column combination switch -E595- | 15 |
SC38 | Fuse 38 on fuse holder C -SC38- | 40 A | Onboard supply control unit -J519- | 30 |
SC39 | Fuse 39 on fuse holder C -SC39- | 40 A | ABS control unit -J104-4) | 30 |
SC40 | Fuse 40 on fuse holder C -SC40- | 40 A | Supply for fuses:
-SD1- …-SD4- | 30 |
SC41 | Fuse 41 on fuse holder C -SC41- | 30 A | Onboard supply control unit -J519- | 30 |
SC42 | Fuse 42 on fuse holder C -SC42- | 30 A | Front passenger door control unit -J387- | 30 |
SC43 | Fuse 43 on fuse holder C -SC43- | 30 A | Rear right door control unit -J389- | 30 |
SC44 | Not assigned | | | 30 |
SC45 | Fuse 45 on fuse holder C -SC45- | 10 A | Steering column combination switch -E595- | 30 |
SC46 | Fuse 46 on fuse holder C -SC46- | 15 A | Reversing camera -R189- | 30 |
SC47 | Fuse 47 on fuse holder C -SC47- | 30 A | ABS control unit -J104- 4) | 30 |
SC48 | Not assigned | | | |
SC49 | Fuse 49 on fuse holder C -SC49- | 15 A 3)
/20 A 2)
/30 A 3) | Fuel pump control unit -J538- 3)
Fuel pump relay -J17- 1), 2) | 30 |
SC50 | Fuse 50 on fuse holder C -SC50- | 20 A | Control unit 1 for information electronics -J794- | 30 |
SC51 | Fuse 51 on fuse holder C -SC51- | 10 A | Onboard supply control unit -J519- | 30 |
SC52 | Not assigned | | | |
SC53 | Fuse 53 on fuse holder C -SC53- | 5 A | Rain and light sensor -G397- | 30 |
SC54 | Fuse 54 on fuse holder C -SC54- | 5 A | Steering column combination switch -E595-
- Ignition/starter switch -D- | 30 |
SC55 | Fuse 55 on fuse holder C -SC55- | 10 A | Heated front seats control unit -J774- | 30 |
SC56 | Not assigned | | | |
SC57 | Not assigned | | | |
SC58 | Not assigned | | | |
SC59 | Not assigned | | | |
