Руководство Fuses VW Polo 5 2015-2017 model (6C1) - предохранители и реле
Admin
Admin
Создатель сайта
Команда форума
Россия, Москва
VW Tiguan 2.0 DBGC 2018, VW Touran 1.6 BSE 2008
Автомобиль
VW Polo 5
Двигатель
all
Fuses Volkswagen Polo 5 restyling (model 6C1) 2015 - 2017
Fuses Volkswagen Polo 5 (model 6R1) 2010 - 2014
Предохранители Фольксваген Поло 5 рестайлинг 2015 - 2017 г.в.
Overview of fuse holder
1 - Fuse holder A -SA-
Fitting location
Fuse assignment, from January 2014
Fuse assignment from November 2014
2 - Fuse holder B -SB-
Fitting location
3 - Fuse holder C -SC-
Fitting location left-hand drive
4 - Fuse holder D -SD- / fuse holder F -SF-
Fuse assignment on fuse holder D -SD- , from January 2014
Fuse assignment on fuse holder F -SF- , from January 2014
Fuse assignment on fuse holder F -SF- , from November 2014
5 - Fuse holder H -SH-
Fitting location
Fitting location of fuse holder A -SA- VW Polo 5
508 Threaded connection (30) on E-box
Note:
The illustration shows fuse holder A -SA- for models with battery in engine compartment
In models with battery in luggage compartment, fuse holder A -SA- is fitted lengthways.
The fuse strip (multifuse) must be replaced as a complete unit.
For models with battery in engine compartment only, from November 2014, fuse 5 on fuse holder A -SA5- is not present. This connection is therefore bridged. In the line (16.0 mm², red), connected to -SA5- in the illustration, there is an inline fuse (single fuse in wiring harness coiled under the battery carrier), fuse 1 (30) - S204- (125 A).
Fuse 1 (30) - S204- can only be accessed when the battery and battery holder are removed.
Fuse assignment on fuse holder A -SA- , VW Polo 5 from January 2014
Screw locationCurrent Flow Diagram designationNominal valueFunction/componentTerminal
SA1​
Fuse 1 on fuse holder A -SA1-
125 A​
Supply for fuses:
-SC1- …-SC17-
30​
SA2​
Fuse 2 on fuse holder A -SA2-
150 A​
Alternator -C-
30​
SA3​
Fuse 3 on fuse holder A -SA3-
80 A​
Power steering control unit -J500-
30​
SA4​
Fuse 4 on fuse holder A -SA4-
80 A​
Supply for fuses:
-SC38- …-SC54-
30​
SA5​
Fuse 5 on fuse holder A -SA5-
50 A​
Terminal 75x voltage supply relay -J694-
30​
Fuse assignment on fuse holder A -SA- , VW Polo 5 from November 2014
SA1​
50 A​
30​
SA2​
150 A​
Alternator -C-1)
30​
SA3​
80 A​
Power steering control unit -J500-1)
30​
SA4​
80 A​
Supply for fuses:
-SC38- …-SC54-1)
30​
SA5​
Fuse 1 (30) -S204-1)2)
125 A​
Supply for fuses:
-SC1- …-SC17-1)
30​
1) Only models with battery in engine compartment
2) Inline fuse
Fitting location of fuse holder B -SB- VW Polo 5
Note:
The illustration shows fuse holder B -SB- for models with battery in engine compartment
In models with battery in luggage compartment, fuse holder B -SB- is fitted lengthways.
1 - Fuse holder B -SB-
Fuse colours for J-Case fuse:
50 A - red
40 A - green
30 A - pink
Fuse colours for ATO flat fuse:
40 A - orange
30 A - light-green
25 A - clear (transparent)
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light-brown
1A - black
Fuse colours for mini fuse:
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light-brown
1A - black
Fuse assignment on fuse holder B -SB- , VW Polo 5 from January 2014
SlotCurrent Flow Diagram designationNominal valueFunction/componentTerminal
SB1​
Fuse 1 on fuse holder B -SB1-
40 A​
Radiator fan thermal switch -F18-
Radiator fan control unit -J293-
30​
SB2​
Fuse 2 on fuse holder B -SB2-
50 A​
Automatic glow period control unit -J179-
30​
SB3​
Fuse 3 on fuse holder B -SB3-
40 A​
ABS control unit -J104-
30​
SB4​
Fuse 4 on fuse holder B -SB4-
50 A​
Auxiliary air heater element -Z35- 1)
75​
SB5​
Fuse 5 on fuse holder B -SB5-
50 A​
75​
SB6​
Fuse 6 on fuse holder B -SB6-
5 A​
Onboard supply control unit -J519- 5)
Battery monitor control unit -J367- 4)
30​
SB7​
Fuse 7 on fuse holder B -SB7-
7.5 A​
Engine control unit -J623-
30​
SB8​
Fuse 8 on fuse holder B -SB8-
30 A​
Windscreen wiper motor -V-
30​
SB9​
Fuse 9 on fuse holder B -SB9-
30 A​
Mechatronic unit for dual clutch gearbox -J743-
30​
SB10​
Fuse 10 on fuse holder B -SB10-
25 A​
30​
SB11​
Not assigned
SB12​
Fuse 12 on fuse holder B -SB12-
7.5 A 2) /10 A 1)​
Injector, cylinder 1 -N30- 2)
Injector, cylinder 2 -N31- 2)
Injector, cylinder 3 -N32- 2)
Fuel metering valve -N290-1)
87​
SB13​
Fuse 13 on fuse holder B -SB13-
5 A​
Brake light switch -F-
87​
SB14​
Fuse 14 on fuse holder B -SB14-
10 A​
Fuel pump relay -J17-
Coolant circulation pump -V50- 1)
Coolant circulation pump 2 -V178-1)
Coolant valve for cylinder head -N489- 1)
Valve for oil pressure control -N428- 1)
Charge air cooling pump -V188- 6)
Fuel pressure regulating valve -N276- 6)
87​
SB15​
Fuse 15 on fuse holder B -SB15-
5 A​
50​
SB16​
Fuse 16 on fuse holder B -SB16-
30 A​
Starter -B-
50​
SB17​
Fuse 17 on fuse holder B -SB17-
20 A​
87​
SB18​
Fuse 18 on fuse holder B -SB18-
10 A​
High heat output relay -J360- 1)
Low heat output relay -J359- 1)
Charge pressure positioner -V465- 1)
Charge pressure control solenoid valve -N75- 1)
Variable intake manifold position sender -G513- 1)
Oil level and oil temperature sender -G266-
Activated charcoal filter solenoid valve 1 -N80- 2), 3)
Camshaft control valve 1 -N205- 2), 3)
87​
SB19​
Fuse 19 on fuse holder B -SB19-
30 A​
Fuse holder F -SF-
87​
SB20​
Fuse 20 on fuse holder B -SB20-
5 A 1) / 20 A 2) 3)​
Ignition coil 1 with output stage -N70- 2), 3)
Ignition coil 2 with output stage -N127- 2), 3)
Ignition coil 3 with output stage -N291- 2), 3)
Automatic glow period control unit -J179- 1)
Intake manifold preheating heater element -N51- 1)
87​
1) Only models with diesel engine
2) Only models with petrol engine (without forced induction)
3) Only models with petrol engine (with forced induction)
4) Only models with start/stop system
5) Only models with no start/stop system
6) Only models with 1.2l engine
Fuse assignment on fuse holder B -SB- , VW Polo 5 from November 2014
SB1​
40 A
50 A 7)​
Suppression filter -C24-7)
30​
SB2​
50 A​
30​
SB3​
40 A
20 A 7)​
Engine component current supply relay -J757-7)
30​
SB4​
50 A​
Auxiliary air heater element -Z35-1)
75​
SB5​
50 A​
75​
SB6​
5 A​
Onboard supply control unit -J519-5)
Battery monitor control unit -J367-4)
30​
SB7​
7.5 A​
30​
SB8​
30 A​
t Windscreen wiper motor -V-
30​
SB9​
30 A​
30​
SB10​
25 A
5 A 7)​
30​
SB11​
Not assigned
SB12​
7.5 A 2) / 10 A 1) 7)​
Injector, cylinder 1 -N30- 2) 7)
Injector, cylinder 2 -N31- 2) 7)
Injector, cylinder 3 -N32- 2) 7)
Injector, cylinder 4 -N33- 7)
Fuel metering valve -N290- 1)
Actuator 1 for camshaft adjustment -F366- ...Actuator 8 for camshaft adjustment -F373- 7)
87​
SB13​
5 A​
87​
SB14​
10 A​
Coolant circulation pump 2 -V178- 1)
Coolant shut-off valve -N82- 7)
87​
SB15​
5 A​
50​
SB16​
30 A​
Starter -B-
50​
SB17​
20 A​
87​
SB18​
10 A​
Charge pressure control solenoid valve -N75-1)
Variable intake manifold position sender -G513-1)
Activated charcoal filter solenoid valve 1 -N80-2), 3)
Camshaft control valve 1 -N205-2) 3)
Intake manifold flap valve -N316-7)
Radiator fan -VX57-7)
Valve for oil pressure control -N428-7)
Oil pressure switch, stage 3 -F447-7)
Turbocharger air recirculation valve -N249-7)
87​
SB19​
30 A​
Fuse holder F -SF-
87​
SB20​
Ignition coil 1 with output stage -N70-2), 3)
Ignition coil 2 with output stage -N127-2), 3)
Ignition coil 3 with output stage -N291-2), 3)
Ignition coil 4 with output stage -N292-2), 3)
Automatic glow period control unit -J179-1)
Intake manifold preheating heater element -N51-1)
87​
7) Only models with battery in luggage compartment
Fitting location of fuse holder C -SC- , left-hand drive models VW Polo 5
1 - Fuse holder C -SC-
50 A - red
40 A - green
30 A - pink
40 A - orange
30 A - light-green
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light-brown
1A - black
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light-brown
1A - black
Fuse assignment on fuse holder C -SC- , VW Polo 5 from January 2014
SC1​
Fuse 1 on fuse holder C -SC1-
40 A​
30​
SC2​
Fuse 2 on fuse holder C -SC2-
40 A​
30​
SC3​
Fuse 3 on fuse holder C -SC3-
30 A​
30​
SC4​
Fuse 4 on fuse holder C -SC4-
50 A​
Low heat output relay -J359-1)
30​
SC5​
Fuse 5 on fuse holder C -SC5-
30 A​
Driver door control unit -J386-
30​
SC6​
Fuse 6 on fuse holder C -SC6-
30 A​
Rear left door control unit -J388-
30​
SC7​
Fuse 7 on fuse holder C -SC7-
20 A​
Treble horn -H2-
Bass horn -H7-
30​
SC8​
Fuse 8 on fuse holder C -SC8-
30 A​
Engine compartment electronics box pin 9A
30​
SC9​
Fuse 9 on fuse holder C -SC9-
30 A​
Sliding sunroof motor -V1-
30​
SC10​
Fuse 10 on fuse holder C -SC10-
7.5 A​
Electronically controlled damping control unit -J250-
30​
SC11​
Fuse 11 on fuse holder C -SC11-
30 A​
Headlight washer system relay -J39-
30​
SC12​
Fuse 12 on fuse holder C -SC12-
5 A / 10 A​
Multimedia control unit display
30​
SC13​
Fuse 13 on fuse holder C -SC13-
30 A​
Terminal 15 relay -J940-
30​
SC14​
Fuse 14 on fuse holder C -SC14-
7.5 A​
Diagnostic connection -U31-
Ignition key withdrawal lock solenoid -N376-
Steering column combination switch -E595-
Light switch -E1-
30​
SC15​
Fuse 15 on fuse holder C -SC15-
7.5 A​
Air conditioning system control unit -J301-
Gearbox switch -E206-
Heater control unit -J65-
Selector lever -E313-
30​
SC16​
Fuse 16 on fuse holder C -SC16-
5 A​
Dash panel insert -K-
30​
SC17​
Fuse 17 on fuse holder C -SC17-
7.5 A​
Anti-theft alarm sensor -G578-
Anti-theft alarm system horn -H8-
30​
SC18​
Fuse 18 on fuse holder C -SC18-
5 A​
Multimedia system operating unit -E380-
30​
SC19​
Fuse 19 on fuse holder C -SC19-
5 A​
30​
SC20​
Not assigned
SC21​
Not assigned
SC22​
Not assigned
SC23​
Fuse 23 on fuse holder C -SC23-
7.5 A​
Washer pump -V5-
30​
SC24​
Fuse 24 on fuse holder C -SC24-
30 A​
Fresh air blower control unit -J126-
Fresh air blower isolation relay -J487-
75​
SC25​
Not assigned
SC26​
Fuse 26 on fuse holder C -SC26-
5 A​
Heated driver seat regulator -E94-
Heated front passenger seat regulator -E95-
75​
SC27​
Fuse 27 on fuse holder C -SC27-
15 A​
Rear window wiper motor -V12-
75​
SC28​
Fuse 28 on fuse holder C -SC28-
20 A​
Cigarette lighter -U1-
75​
SC29​
Fuse 29 on fuse holder C -SC29-
7.5 A​
Airbag control unit -J234-
Front passenger side airbag deactivated warning lamp -K145-
15​
SC30​
Fuse 30 on fuse holder C -SC30-
7.5 A​
Tyre Pressure Loss Indicator button -E492-
TCS and ESP button -E256-
Reversing light switch -F4-
Automatic anti-dazzle interior mirror -Y7-
Refrigerant circuit pressure sender -G805-
Light switch -E1-
Parking aid control unit -J446-
15​
SC31​
Fuse 31 on fuse holder C -SC31-
5 A​
Washer pump relay -J576-
Fuel pump control unit -J538-
15​
SC32​
Fuse 32 on fuse holder C -SC32-
7.5 A​
Headlight range control unit -J431-
Headlight range control and instrument illumination regulator -EX14-
Headlight range control regulator -E102-
Front left headlight -MX1-
Front right headlight -MX2-
15​
SC33​
Fuse 33 on fuse holder C -SC33-
5 A​
Clutch position sender -G476-
Starter relay 1 -J906-
Starter relay 2 -J907-
15​
SC34​
Fuse 34 on fuse holder C -SC34-
5 A​
Left washer jet heater element -Z20-
Right washer jet heater element -Z21-
15​
SC35​
Fuse 35 on fuse holder C -SC35-
10 A​
15​
SC36​
Fuse 36 on fuse holder C -SC36-
10 A​
Heated front seats control unit -J774-
15​
SC37​
Fuse 37 on fuse holder C -SC37-
5 A​
Adaptive cruise control unit -J428-
15​
SC38​
Fuse 38 on fuse holder C -SC38-
40 A​
30​
SC39​
Not assigned
SC40​
Fuse 40 on fuse holder C -SC40-
40 A​
Supply for fuses:
-SD1- …-SD4-
30​
SC41​
Fuse 41 on fuse holder C -SC41-
30 A​
30​
SC42​
Fuse 42 on fuse holder C -SC42-
30 A​
Front passenger door control unit -J387-
30​
SC43​
Fuse 43 on fuse holder C -SC43-
30 A​
Rear right door control unit -J389-
30​
SC44​
Not assigned
30​
SC45​
Fuse 45 on fuse holder C -SC45-
10 A​
30​
SC46​
Fuse 46 on fuse holder C -SC46-
15 A​
Reversing camera -R189-
30​
SC47​
Not assigned
SC48​
Not assigned
SC49​
Fuse 49 on fuse holder C -SC49-
15 A 3) / 20 A 2) / 30 A 3)​
Fuel pump control unit -J538-3)
Fuel pump relay -J17-1), 2)
30​
SC50​
Fuse 50 on fuse holder C -SC50-
20 A​
Multimedia system -RX7-
30​
SC51​
Fuse 51 on fuse holder C -SC51-
10 A​
30​
SC52​
Not assigned
SC53​
Fuse 53 on fuse holder C -SC53-
5 A​
Rain and light sensor -G397-
30​
SC54​
Fuse 54 on fuse holder C -SC54-
5 A​
Ignition/starter switch -D-
30​
SC55​
Fuse 55 on fuse holder C -SC55-
10 A​
30​
SC56​
Not assigned
SC57​
Not assigned
SC58​
Not assigned
SC59​
Not assigned
Fuse assignment on fuse holder C -SC- , VW Polo 5 from November 2014
SC1​
40 A​
30​
SC2​
40 A​
30​
SC3​
30 A​
30​
SC4​
50 A​
30​
SC5​
30 A​
30​
SC6​
30 A​
30​
SC7​
20 A​
- Treble horn -H2-
- Bass horn -H7-
30​
SC8​
30 A​
30​
SC9​
30 A​
30​
SC10​
7.5 A​
30​
SC11​
30 A​
30​
SC12​
5 A/
10 A​
Two-way signal amplifier for mobile telephone/data services -J984-
Storage compartment with interface for mobile telephone -R265-
Supply for fuse 18 on fuse holder C -SC18- and fuse 19 on fuse holder C -SC19-
30​
SC13​
30 A​
30​
SC14​
7.5 A​
Light switch -E1-
30​
SC15​
7.5 A​
30​
SC16​
5 A​
30​
SC17​
7.5 A​
30​
SC18​
5 A​
30​
SC19​
5 A​
30​
SC20​
Not assigned
SC21​
Not assigned
SC22​
Not assigned
SC23​
7.5 A​
Washer pump -V5-
30​
SC24​
30 A​
75​
SC25​
Not assigned
SC26​
5 A​
75​
SC27​
15 A​
75​
SC28​
20 A​
75​
SC29​
7.5 A​
15​
SC30​
7.5 A​
Mirror adjustment switch -E43-
Light switch -E1-
15​
SC31​
5 A​
15​
SC32​
7.5 A​
Alarm horn relay -J641-
15​
SC33​
5 A​
Control unit for structure-borne sound -J869- 4)
15​
SC34​
5 A​
15​
SC35​
Not assigned
SC36​
10 A​
15​
SC37​
5 A​
15​
SC38​
40 A​
30​
SC39​
Fuse 39 on fuse holder C -SC39-
40 A​
ABS control unit -J104-4)
30​
SC40​
40 A​
Supply for fuses:
-SD1- …-SD4-
30​
SC41​
30 A​
30​
SC42​
30 A​
30​
SC43​
30 A​
30​
SC44​
Not assigned
30​
SC45​
10 A​
30​
SC46​
15 A​
30​
SC47​
Fuse 47 on fuse holder C -SC47-
30 A​
ABS control unit -J104- 4)
30​
SC48​
Not assigned
SC49​
15 A 3)
/20 A 2)
/30 A 3)​
Fuel pump control unit -J538- 3)
Fuel pump relay -J17- 1), 2)
30​
SC50​
20 A​
Control unit 1 for information electronics -J794-
30​
SC51​
10 A​
30​
SC52​
Not assigned
SC53​
5 A​
30​
SC54​
5 A​
- Ignition/starter switch -D-
30​
SC55​
10 A​
30​
SC56​
Not assigned
SC57​
Not assigned
SC58​
Not assigned
SC59​
Not assigned
4) Only models with battery in luggage compartment
Fitting location of fuse holder D -SD- / fuse holder F -SF- , left-hand drive models VW Polo 5
1 - Fuse holder D -SD- / fuse holder F -SF-
40 A - orange
30 A - light-green
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light-brown
1A - black
Fuse assignment on fuse holder D -SD- , VW Polo 5 from January 2014
SD1​
Fuse 1 on fuse holder D -SD1-
25 A​
Trailer detector control unit -J345-
30​
SD2​
Fuse 2 on fuse holder D -SD2-
25 A​
30​
SD3​
Fuse 3 on fuse holder D -SD3-
15 A​
30​
SD4​
Fuse 4 on fuse holder D -SD4-
15 A​
30​
Fuse assignment on fuse holder F -SF- , VW Polo 5 from January 2014
SF1​
Fuse 1 on fuse holder F -SF1-
15 A​
Lambda probe 1 before catalytic converter -GX10-
Lambda probe 1 before catalytic converter -GX7-
87a​
SF2​
Not assigned
SF3​
Not assigned
SF4​
Not assigned
Fuse assignment on fuse holder F -SF- , VW Polo 5 from November 2014
SF1​
15 A​
87a​
SF2​
Fuse 2 on fuse holder F -SF2-
10 A​
Camshaft control valve 1 -N205-1)
Exhaust camshaft control valve 1 -N318-1)
Activated charcoal filter solenoid valve 1 -N80-1)
Heater support pump -V488-1)
87a​
SF3​
Not assigned
SF4​
Not assigned
1) Only models with battery in luggage compartment
Fitting location of fuse holder H -SH- VW Polo 5
1 - Fuse holder H -SH-
SH1 - Fuse 1 on fuse holder H -SH1-
SH2 - Fuse 2 on fuse holder H -SH2-
SH3 - Fuse 3 on fuse holder H -SH3-
Fuse assignment on fuse holder H -SH- VW Polo 5
SH1​
80 A​
30​
SH2​
110 A​
Supply for fuses:
-SC1- …-SC17-
30​
SH3​
110 A​
Supply for fuses:
-SC38- …-SC54-
30​
