Руководство Fuses VW Beetle 2012-2016 - предохранители и реле
Admin
Admin
Создатель сайта
Команда форума
Россия, Москва
VW Tiguan 2.0 DBGC 2018, VW Touran 1.6 BSE 2008
Автомобиль
VW Beetle
Двигатель
all
Fuses VW Beetle
Volkswagen Beetle (model 5C1) 2012 - 2016
Volkswagen NBL (model 5C1) 2012 - 2016
Volkswagen Beetle Cabrio (models 5C7, 5C8) 2012 - 2018
Overview of fuse holder
1 - Fuse holder A -SA-
Fitting location
Fuse assignment, VW Beetle from April 2011
2 - Fuse holder B -SB-
Fitting location
Fuse assignment VW Beetle from July 2012
Fuse assignment VW Beetle from July 2013
Fuse assignment VW Beetle from July 2014
3 - Fuse holder C -SC-
Fitting location
Fitting location fuse holder A -SA- VW Beetle
507 - Threaded connection (30), on battery fuse holder
Fuse assignment fuse holder A -SA- , VW Beetle from April 2011
Screw location​
Current Flow Diagram designation​
Nominal value​
Function/component​
Terminal​
B​
Fuse 1 on fuse holder A -SA1-
200 A​
Alternator -C-
30​
C​
Fuse 2 on fuse holder A -SA2-
Not assigned
D​
Fuse 3 on fuse holder A -SA3-
80 A​
Power steering control unit -J500-
30​
Electromechanical power steering motor -V187-
E​
Fuse 4 on fuse holder A -SA4-
80 A​
Supply for fuses:
30​
-SC3-
-SC6-
-SC17-
-SC20- …-SC24-
-SC36-
-SC39-
-SC43- …-SC53-
-SC55-
-SC57-
Fitting location fuse holder B -SB- VW Beetle
1 - Fuse holder B -SB-
Fuse colours for J-Case fuse:
50 A - red
40 A - green
30 A - pink
Fuse colours for ATO flat fuse:
40 A - orange
30 A - light green
25 A - natural (white)
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
Fuse assignment fuse holder B -SB- , VW Beetle from April 2011
Slot​
Nominal value​
Function/component
Terminal​
F1​
Not assigned
F2​
Fuse 2 on fuse holder B -SB2-
30 A​
Engine control unit -J623- (T94/5), (T94/3), (T94/6)1)
87a​
20 A 26), 19)​
F3​
Not assigned
F4​
Fuse 4 on fuse holder B -SB4-
15 A​
Lambda probe -G39- (T6w/4)2) (T6w/5) 3)
87a​
Lambda probe 3 after catalytic converter -G287- (T6af/4) 4)
Lambda probe -G39- (T6w/4)5) (T4am/1)6)
Lambda probe after catalytic converter -G130- (T4ao/1)7)
Lambda probe 2 after catalytic converter -G131- (T4ao/1)8)
Centre Lambda probe for bank 1 catalytic converter -G465- (T4v/1)9)
Secondary air pump relay -J299- (F71)9)
Charge pressure control solenoid valve -N75- (1)10)
F5​
Fuse 5 on fuse holder B -SB5-
10 A​
Activated charcoal filter solenoid valve 1 -N80- (1)11)
87a​
Secondary air inlet valve -N112- (1)12)
Camshaft control valve 1 -N205- (1)10)
Turbocharger air recirculation valve -N249- (1)10)
Charge pressure control solenoid valve 2 -N274- (1)10)
Coolant regulating valve -N515- (1)13)
Fuel system diagnostic pump -V144- (T4ay/4)
Circulation pump relay -J160- (2)14)
F6​
Fuse 6 on fuse holder B -SB6-
5 A 27)​
Throttle valve module -J338- (2)4)
87a​
30 A 26)​
Low heat output relay -J359- (F71)14)
Fuel pressure regulating valve -N276- (1)15)
Ignition coil 1 with output stage -N70- (T4af/1)16) (3)17)
Ignition coil 2 with output stage -N127- (T4ag/1)16) (3)17)
Ignition transformer -N152- (T4aa/2)13)
F7​
Fuse 7 on fuse holder B -SB7-
20 A​
Fuel pressure regulating valve -N276- (2)18)
87a​
Fuel metering valve -N290- (2)18)
Ignition coil 3 with output stage -N291- (T4ah/1)16) (3)17)
Ignition coil 4 with output stage -N292- (T4ai/1)16) (3)17)
Ignition coil 5 with output stage -N323- (T4aj/1)19)
Fuel pump relay -J17- (F51)19) (1A)14) (1B)4)
Electric fuel pump 2 relay -J49- (1A)4) (1B)14) (3B)14)
Continued coolant circulation relay -J151- (F41)10) (F43)10)
Secondary air pump relay -J299- (F71)8)
Engine component current supply relay -J757- (F51)10)
Automatic glow period control unit -J179- (T11b/6)18)
Radiator fan control unit -J293- (T4x/2)
F8​
Fuse 8 on fuse holder B -SB8-
10 A​
Glow plugs relay 2 -J495- (F43)15) (F41)15)
87a​
Idling speed control valve -N66- (2)19)
Charge pressure control solenoid valve -N75- (1)20)
Heater element for crankcase breather -N79- (1)4)
Activated charcoal filter solenoid valve 1 -N80- (1)21)
Camshaft control valve 1 -N205- (1)21)
Exhaust gas recirculation valve 2 -N213- (1)14)
Turbocharger air recirculation valve -N249- (1)17)
Magnetic clutch for supercharger -N421- (1)17)
4-pin connector, radiator fan -T4- (T4x/2)
F9​
Fuse 9 on fuse holder B -SB9-
5 A​
Brake light switch -F- (T4y/4)
87a​
F10​
Fuse 10 on fuse holder B -SB10-
5 A​
Clutch position sender -G476- (T5m/5)
87a​
F11​
Not assigned
F12​
Not assigned
Voltage stabiliser -J532- (T10aj/2)
F13​
Fuse 13 on fuse holder B -SB13-
30 A​
Control unit with display for radio and navigation -J503- (T16b/15), (T16b/16)
30a​
Control unit for navigation system -J856- (T10aa/2)
Radio -R- (T16b/15), (T16b/16)
Motronic current supply relay -J271- (F61)7)
F14​
Fuse 14 on fuse holder B -SB14-
10 A​
Terminal 30 voltage supply relay -J317- (F61)18)
30a​
Engine control unit -J623- (T94/92)
F15​
Fuse 15 on fuse holder B -SB15-
5 A27)​
Control unit in dash panel insert -J285- (T32c/32)27)
30a​
10 A26)​
Alarm horn relay -J641- (3A)26)
F16​
Fuse 16 on fuse holder B -SB16-
40 A​
ABS control unit -J104- (T47/32)
30a​
F17​
Fuse 17 on fuse holder B -SB17-
25 A​
Mechatronic unit for dual clutch gearbox -J743- (T20e/11)22) (T20e/18)22) (T25/9)23)
30a​
F18​
Fuse 18 on fuse holder B -SB18-
10 A​
Mechatronic unit for dual clutch gearbox -J743- (T25/25)23)
30a​
F19​
Fuse 19 on fuse holder B -SB19-
5 A​
Onboard supply control unit -J519- (T73b/59)
30ref​
F20​
Fuse 20 on fuse holder B -SB20-
25 A​
Onboard supply control unit -J519- (T73a/68)
30a​
F21​
Fuse 21 on fuse holder B -SB21-
40 A​
Auxiliary air heater element -Z35- (T3am/3)
10​
F22​
Fuse 22 on fuse holder B -SB22-
40 A​
Auxiliary air heater element -Z35- (T3am/1)
10​
F23​
Fuse 23 on fuse holder B -SB23-
40 A​
ABS control unit -J104- (T47/1)
30a​
Fuse 40 on fuse holder C -SC40-
F24​
Fuse 24 on fuse holder B -SB24-
40 A​
Fuse 41 on fuse holder C -SC41-
30a​
Fuse 41 on fuse holder C -SC42-
F25​
Fuse 25 on fuse holder B -SB25-
20 A​
Fuel pump relay -J17- (F53)19)
30a​
Engine component current supply relay -J757- (F53)10)
F26​
Fuse 26 on fuse holder B -SB26-
50 A​
Automatic glow period control unit -J179- (T11b/11)18)
30a​
F27​
Fuse 27 on fuse holder B -SB27-
50 A​
Radiator fan control unit -J293- (T4x/1)
30a​
F28​
Fuse 28 on fuse holder B -SB28-
25 A​
Onboard supply control unit -J519- (T73a/16)
30a​
F29​
Fuse 29 on fuse holder B -SB29-
40 A​
Terminal 15 voltage supply relay -J329- (T9i/3)
30a​
Terminal 15 voltage supply relay 2 -J681- (T9k/3)
F30​
Fuse 30 on fuse holder B -SB30-
40 A​
Terminal 75 voltage supply relay 1 -J680- (T9m/3)
30a​
F31​
Fuse 31 on fuse holder B -SB31-
40 A​
Amplifier -R12- (T38/2)
30a​
F32​
Fuse 32 on fuse holder B -SB32-
40 A​
Secondary air pump motor -V101- (2)25)
87a​
Auxiliary air heater element -Z35- (T3am/2)
1) Engine codes CAYC, CBFA, CCTA, CCZA, CJAA
2) Engine codes CBUA, CBTA, CJAA
3) Engine codes CBZB, CAYC
4) Engine code CJAA
5) Engine codes CAVD, CBFA, CCTA, CCZA
6) Engine code CCCA
7) Engine codes CAVD, CBFA, CBTA, CBUA, CBZB, CCCA, CCTA, CCZA
8) Engine codes CBFA
9) Engine codes CBTA, CBUA
10) Engine codes CBFA, CCTA, CCZA
11) Engine codes CBFA, CBZB, CCTA, CCZA
12) Engine codes CBFA, CBUA, CBTA, CCTA
13) Engine codes CBZB
14) Engine codes CAYC
15) Engine codes CAVD, CBZB
16) Engine codes CBFA, CBTA, CBUA, CCCA, CCTA, CCZA
17) Engine codes CAVD
18) Engine codes CAYC, CJAA
19) Engine codes CBTA, CBUA, CCCA
20) Engine codes CAVD, CAYC, CJAA
21) Engine codes CAVD, CBUA, CBTA, CCCA
22) Dual clutch gearbox 02E (DSG)
23) Dual clutch gearbox 0AM (DSG)
25) Engine codes CBFA, CBTA, CBUA
26) From December 2011
27) To December 2011
Fuse assignment fuse holder B -SB- , VW Beetle from July 2012
Slot​
Nominal value​
Function/component
Terminal​
F1​
Not assigned
F2​
30 A​
Engine control unit -J623- (T94/5), (T94/3), (T94/6)1) (T91/5)27) (T91/6)27)
87a​
20 A 15)​
F3​
Fuse 3 on fuse holder B -SB3-
5 A​
87a​
F4​
15 A​
Lambda probe -G39- (T6w/4)2) (T6w/5)3)
87a​
Lambda probe after catalytic converter -G130- (T6af/4)4)
Lambda probe -G39- (T6w/4)5) (T4am/1)6) (T5e/4)27)
Lambda probe after catalytic converter -G130- (T4ao/1)28)
Centre Lambda probe for bank 1 catalytic converter -G465- (T4v/1)11)
Electric fuel pump 2 relay -J49- (1B)17)
F5​
10 A​
Heater element relay -J925- (1B)7) (3B)7)
87a​
Charge pressure control solenoid valve -N75- (1)8)
Camshaft control valve 1 -N205- (1)27)
Turbocharger air recirculation valve -N249- (1)27)
Intake manifold flap valve -N316- (1)27)
Exhaust gas recirculation cooler changeover valve -N345- (1)7)
Fuel system diagnostic pump -V144- (T4ay/4)10)
Fuel pump relay -J17- (F51)15)
Secondary air pump relay -J299- (F71)9) (F81)26)
Engine component current supply relay -J757- (F51) 27)
Charge pressure control solenoid valve -N75- (1)29)
Activated charcoal filter solenoid valve 1 -N80- (1)29)
F6​
10 A​
Secondary air inlet valve -N112- (1)36)
87a​
Camshaft control valve 1 -N205- (1)13)
Turbocharger air recirculation valve -N249- (1)13)
Intake manifold flap valve -N316- (1)13)
Valve for oil pressure control -N428- (2)14)
Coolant circulation pump 2 -V178- (2)27)
Ignition coil 1 with output stage -N70- (T4af/1)25) (3)18)
Ignition coil 2 with output stage -N127- (T4ag/1)25) (3)18)
Ignition transformer -N152- (T4aa/2)16)
F7​
30 A​
Fuel pressure regulating valve -N276- (2)8)
87a​
20 A8)​
Fuel metering valve -N290- (2)8)
Ignition coil 3 with output stage -N291- (T4ah/1)25) (3)18)
Ignition coil 4 with output stage -N292- (T4ai/1)25) (3)18)
Ignition coil 5 with output stage -N323- (T4aj/1)15)
Air mass meter -G70- (T4j/1) 21)
Fuel pump relay -J17- (1A)8)
Charge pressure control solenoid valve -N75- (1)18)
Activated charcoal filter solenoid valve 1 -N80- (1)19)
Camshaft control valve 1 -N205- (1)20)
F8​
10 A​
Exhaust gas recirculation valve 2 -N213- (1)21)
87a​
Turbocharger air recirculation valve -N249- (1)18)
Magnetic clutch for supercharger -N421- (1)18)
Valve for oil pressure control -N428- (2)15)
Coolant regulating valve -N515- (1)16)
Coolant circulation pump 2 -V178- (2)21)
Continued coolant circulation relay -J151- (F41)12) (F43)12)
Automatic glow period control unit -J179- (T11b/6)8)
Low heat output relay -J359- (F71)23)
F9​
10 A​
High heat output relay -J360- (F81)23)
87a​
Additional coolant pump relay -J496- (F41)22) (F43)22)
Engine component current supply relay -J757- (F51)12)
Fuel pressure regulating valve -N276- (1)22)
Coolant circulation pump 2 -V178- (2)7)
F10​
5 A​
87a​
F11​
Not assigned
F12​
Not assigned
Voltage stabiliser -J532- (T12z/1)
F13​
30 A​
30a​
Motronic current supply relay -J271- (F61)24)
F14​
10 A​
Terminal 30 voltage supply relay -J317- (F61)8)
30a​
Engine control unit -J623- (T94/92), (T91/86)27)
F15​
10 A​
30a​
F16​
40A​
30a​
F17​
15 A 30)​
Mechatronic unit for dual clutch gearbox -J743- (T25/9)30)
30a​
30 A 31)​
Mechatronic unit for dual clutch gearbox -J743- (T20/11)31) (T20/18)31)
F18​
15 A​
Mechatronic unit for dual clutch gearbox -J743- (T25/25)30)
30a​
F19​
5 A​
30a​
Battery monitoring control unit -J367- (2)
F20​
30 A​
30a​
F21​
40 A​
Auxiliary air heater element -Z35- (T3am/1)23)
10​
50 A 26)​
Secondary air pump motor -V101- (2)26)
F22​
40 A​
Auxiliary air heater element -Z35- (T3am/3)23)
10​
F23​
Not assigned
F24​
40A​
30a​
50A 33)​
F25​
40 A​
30a​
F26​
50 A​
Automatic glow period control unit -J179- (T11b/11)8)
30a​
F27​
50 A​
30a​
F28​
20 A​
Fuel pump relay -J17- (F53)15)
30a​
30 A 13)​
Engine component current supply relay -J757- (F53)13)
F29​
Not assigned
F30​
40 A​
30a​
F31​
40 A​
30a​
F32​
40 A​
10​
Secondary air pump motor -V101- (2)9)
4) Engine code CJAA
5) Engine codes CAVD, CBFA, CCTA, CCZA, CNWA, CTHD
6) Engine code CCCA
7) Engine codes CAYC
8) Engine codes CAYC, CFFB, CJAA
9) Engine codes CBFA, CBUA
10) Engine codes CBFA, CBTA, CBUA, CPLA, CPPA
11) Engine code CBUA
12) Engine codes CCZA, CBFA, CCTA,
13) Engine codes CBFA, CCTA, CCZA
14) Engine code CCZA
15) Engine codes CBTA, CBUA, CCCA
16) Engine codes CBZB
17) Engine codes CFFB, CJAA
18) Engine codes CAVD, CNWA, CTHD
19) Engine codes CAVD, CBTA, CBUA, CBZB, CCCA, CNWA, CTHD
20) Engine codes CAVD, CBTA, CBUA, CCCA, CNWA, CTHD
21) Engine code CFFB
22) Engine codes CAVD, CBZB, CNWA, CTHD
23) Engine codes CAYC, CFFB, CJAA, CBZB
24) Engine codes CAVD, CBFA, CCTA, CCZA, CNWA, CTHD, CBTA, CBUA, CCCA
25) Engine codes CBFA, CCTA, CCZA, CBTA, CBUA, CCCA
26) Engine code CPPA
27) Engine codes CPLA, CPLB, CPPA
28) Engine codes CAVD, CNWA, CTHD, CPLA, CPLB, CPPA, CBZB, CBFA, CBTA, CBUA, CCCA
29) Engine codes CBFA, CCTA, CCZA, CPLA, CPLB, CPPA
30) For models with dual clutch gearbox 02E only
31) For models with dual clutch gearbox 0AM only
33) Only models with Climatronic
34) To December 2012
36) Engine codes CBUA, CPPA
Fuse assignment fuse holder B -SB- , VW Beetle from July 2013
Slot​
Nominal value​
Function/component
Terminal​
F1​
Not assigned
F2​
30 A
20 A1)​
87​
F3​
5 A​
87​
F4​
15 A​
Lambda probe -G39-
87​
F5​
10 A​
Lambda probe -G39-
87​
F6​
10 A​
87​
F7​
20 A 2)
30 A 3)​
87​
F8​
10 A​
87​
F9​
10 A​
87​
F10​
5 A​
87​
F11​
Not assigned
F12​
Not assigned
F13​
30 A​
30​
Radio -R-
F14​
10 A​
30​
F15​
10 A​
30​
F16​
40 A​
Amplifier -R12-
30​
F17​
15 A 4)
30 A 5)​
30​
F18​
15 A​
Mechatronic unit for dual clutch gearbox -J743-4)
30​
F19​
5 A​
30​
F20​
30 A​
30​
F21​
40 A​
87​
50 A 6)​
F22​
40 A​
87​
F23​
Not assigned
F24​
40 A​
30​
50 A 7)​
F25​
40 A​
30​
F26​
50 A​
30​
F27​
50 A​
30​
F28​
20 A​
30​
F29​
Not assigned
F30​
40 A​
30​
F31​
40 A​
30​
F32​
40 A​
87​
1) Only models with 2.5l petrol engine
2) Only models with diesel engine
3) Only models with petrol engine
4) For models with dual clutch gearbox 02E only
5) For models with dual clutch gearbox 0AM only
6) Only models with 2.0l petrol engine
7) Only models with Climatronic
Fuse assignment fuse holder B -SB- , VW Beetle from July 2014
Slot​
Nominal value​
Function/component
Terminal​
F1​
Not assigned
F2​
30 A
20 A 1)​
87​
F3​
5 A​
87​
F4​
15 A​
Lambda probe -G39-
87​
F5​
10 A​
Lambda probe -G39-
87​
F6​
10 A​
87​
F7​
20 A 2)
30 A 3)​
87​
F8​
10 A​
87​
F9​
10 A​
87​
F10​
5 A​
87​
F11​
Not assigned
F12​
Not assigned
F13​
30 A​
30​
Radio -R-
F14​
10 A​
30​
F15​
10 A​
30​
F16​
40 A​
Amplifier -R12-
30​
F17​
15 A 4)
30 A 5)​
30​
F18​
15 A​
30​
F19​
5 A​
30​
F20​
30 A​
30​
F21​
40 A​
87​
50 A 6)​
F22​
40 A​
87​
F23​
Not assigned
F24​
40 A​
30​
50 A 7)​
F25​
40 A​
30​
F26​
50 A​
30​
F27​
50 A​
30​
F28​
20 A
30 A​
30​
F29​
Not assigned
F30​
40 A​
30​
F31​
40 A​
30​
F32​
40 A​
87​
Fitting location fuse holder C -SC- VW Beetle
1 - Fuse holder C -SC-
40 A - orange
30 A - light green
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
Fuse colours for mini fuse:
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
Fuse assignment fuse holder C -SC- , VW Beetle from April 2011
Slot​
Nominal value​
Function/component
Terminal​
F1​
Not assigned
F2​
Fuse 2 on fuse holder C -SC2-
7.5 A​
Telephone transmitter and receiver unit -R36-
30a​
F3​
Fuse 3 on fuse holder C -SC3-
5 A​
Control unit in dash panel insert -J285-26)
30a​
F4​
Not assigned
F5​
Fuse 5 on fuse holder C -SC5-
5 A​
58a​
Rear left fog light bulb -L46-
F6​
Fuse 6 on fuse holder C -SC6-
5 A​
Left LED module for daytime running light and side light -L176-
TFL​
Right LED module for daytime running light and side light -L177-
Switch and instrument illumination regulator -E20-
F7​
Fuse 7 on fuse holder C -SC7-
5 A​
Left number plate light -X4-
58​
Right number plate light -X5-
F8​
Fuse 8 on fuse holder C -SC8-
7.5 A​
Washer pump -V5-
53c​
F9​
Fuse 9 on fuse holder C -SC9-
5 A​
Airbag control unit -J234-
15a​
Front passenger front airbag deactivated warning lamp -K145-
F10​
Fuse 10 on fuse holder C -SC10-
10 A​
Intermittent wiper switch -E22-
15a​
F11​
Fuse 11 on fuse holder C -SC11-
5 A​
Engine sound generator control unit -J943-10)
15a​
F12​
Fuse 12 on fuse holder C -SC12-
5 A​
Headlight range control unit -J431-
15a​
Fold-in mirror switch -E263-
Tyre Pressure Loss Indicator display button -E492-
Reversing light switch -F4-
High-pressure sender -G65-
F13​
Fuse 13 on fuse holder C -SC13-
5 A​
Air quality sensor -G238-
15a​
Parking aid control unit -J446-
Seat occupied recognition control unit -J706-
Automatic anti-dazzle interior mirror -Y7-
Left washer jet heater element -Z20-
Right washer jet heater element -Z21-
CCS switch -E45-
Air mass meter -G70-14)
Oil level and oil temperature sender -G266-
Steering column electronics control unit -J527-
F14​
Fuse 14 on fuse holder C -SC14-
5 A​
15a​
Fuel pump control unit -J538-
Selector lever sensors control unit -J587-
Engine control unit -J623- (T94/87)
Mechatronic unit for dual clutch gearbox -J743- (T20e/13)22) (T25/10)23)
Switch and instrument illumination regulator -E20- (T8e/1)
Main switch for stop/start system -E101- (T6bx/2), ((T6bx/4)
Tiptronic switch -F189- (T10s/9)
F15​
Fuse 15 on fuse holder C -SC15-
5 A​
Air mass meter -G70- (T5d/3)10) (T5d/5)4)
15a​
Voltage stabiliser -J532- (T10aj/3)
Interface for infotainment CAN bus -J885- (T20/14)
Left headlight range control motor -V48- (T10i/1)
Right headlight range control motor -V49- (T10j/1)
16-pin connector -T16- (T16/1)
F16​
Fuse 16 on fuse holder C -SC16-
5 A​
-GX22- (T10ak/3)
15a​
F17​
Fuse 17 on fuse holder C -SC17-
15 A​
Interior monitoring sensor -G273- (T3f/3)26)
30a​
Alarm horn -H12- (T4bz/4)26)
F18​
Fuse 18 on fuse holder C -SC18-
15 A​
Left headlight dipped beam bulb -M29-1)
56bl​
F19​
Fuse 19 on fuse holder C -SC19-
15 A​
Right headlight dipped beam bulb -M31-1)
56br​
Electronic ignition lock -D9- (T10d/10)
Heater/heat output switch -E16- (T20c/18)
Tiptronic switch -F189- (T10s/10)
F20​
Fuse 20 on fuse holder C -SC20-
5 A​
Automatic gearbox control unit -J217- (T52/3)
30a​
Climatronic control unit -J255- (T20c/20)
Air conditioning system control unit -J301- (T20c/19)
Selector lever sensors control unit -J587- (T10s/10)
Multimedia system control unit -J650- (T12m/7)
F21​
Fuse 21 on fuse holder C -SC21-
15 A​
Onboard supply control unit -J519- (T73b/68)
30a​
Ignition/starter switch -D- (T10d/1)
F22​
Fuse 22 on fuse holder C -SC22-
5 A​
Control module for vehicle location system -J895- (T16n/2)
30a​
Converter box -J935- (T10e/7)
Rain and light sensor -G397- (T3ae/1)
Onboard supply control unit -J519- (T73b/39), (T73a/66)
F23​
Fuse 23 on fuse holder C -SC23-
20 A​
Telephone transmitter and receiver unit -R36- (T54/1)
30a​
16-pin connector -T16- (T16/16)
-GX22- (T10ak/1)
Onboard supply control unit -J519- (T73a/64)
F24​
Fuse 24 on fuse holder C -SC24-
10 A​
Entry and start authorisation control unit -J518- (T32d/3)
30a​
Electronic steering column lock control unit -J764- (T16s/2)
Interface for infotainment CAN bus -J885- (T20/1)
F25​
Fuse 25 on fuse holder C -SC25-
15 A​
Multifunction switch -F125- (T10n/10)
Automatic gearbox control unit -J217- (T52/27), (T52/28)
F26​
Not assigned
F27​
Fuse 27 on fuse holder C -SC27-
1 A​
Steering column electronics control unit -J527- (T16p/1)
15a​
F28​
Not assigned
F29​
Fuse 29 on fuse holder C -SC29-
5 A​
Onboard supply control unit -J519- (T73b/51)
75​
Blocking diode -J29- (1)
F30​
Fuse 30 on fuse holder C -SC30-
25 A​
Cigarette lighter -U1- (T3g/2)
75a​
12 V socket -U5- (2)
F31​
Fuse 31 on fuse holder C -SC31-
25 A​
Light switch -E1- (T17d/1)
75​
F32​
Fuse 32 on fuse holder C -SC32-
15 A​
Fog light switch -E7- (T17d/2)
75a​
F33​
Fuse 33 on fuse holder C -SC33-
40 A​
Air conditioning system control unit -J301- (T5/5)
75a​
Control unit in dash panel insert -J285- (T32c/14)
Onboard supply control unit -J519- (T73a/62)
F34​
Fuse 34 on fuse holder C -SC34-
15 A 29)​
Left headlight main beam bulb -M30- (T10i/8)29)
56al​
10 A28)​
Right headlight main beam bulb -M32- (T10j/8)29)
Front left headlight -MX1- (T14c/11)28)
Front right headlight -MX2- (T14c/11)28)
F35​
Not assigned
F36​
Not assigned
F37​
Not assigned
F38​
Not assigned
F39​
Fuse 39 on fuse holder C -SC39-
25 A 27)​
Headlight dipper and flash relay -J- (T9a/3)
30​
30 A 26)​
F40​
Not assigned
F41​
Not assigned
F42​
Not assigned
F43​
Fuse 43 on fuse holder C -SC43-
25 A 27)​
Front passenger door control unit -J387- (T16d/16)
30a​
30 A 26)​
F44​
Fuse 44 on fuse holder C -SC44-
25 A​
Onboard supply control unit -J519- (T73b/67)
30a​
F45​
Fuse 45 on fuse holder C -SC45-
25 A 27)​
Driver door control unit -J386- (T16c/16)
30a​
30 A 26)​
F46​
Not assigned
Fuel pump relay -J17- (3A), (3B)4)
F47​
Fuse 47 on fuse holder C -SC47-
15 A 27)​
Electric fuel pump 2 relay -J49- (3A)
30a​
20 A26)​
Fuel pump control unit -J538- (T10v/1)
F48​
Fuse 48 on fuse holder C -SC48-
25 A27)​
Onboard supply control unit -J519- (T73b/13), (T73b/11)
30a​
30 A26)​
F49​
Fuse 49 on fuse holder C -SC49-
40 A​
Fresh air blower control unit -J126- (T6l/4)
30HNA​
F50​
Fuse 50 on fuse holder C -SC50-
25 A​
Heated front seats control unit -J774- (T8v/3), (T8v/6)
30a​
F51​
Fuse 51 on fuse holder C -SC51-
30 A​
Sliding sunroof adjustment control unit -J245- (T10f/10)
30a​
F52​
Fuse 52 on fuse holder C -SC52-
15 A​
Onboard supply control unit -J519- (T73a/63)
30a​
F53​
Fuse 53 on fuse holder C -SC53-
15 A 27), 44)​
Onboard supply control unit -J519- (T73a/73)
30a​
20 A​
F54​
Not assigned
F55​
Fuse 55 on fuse holder C -SC55-
25 A​
Light switch -E1- (T17d/15)
30​
Headlight dipper and flasher switch -E4- (T16j/10)
F56​
Fuse 56 on fuse holder C -SC56-
5 A​
30stab​
Interior monitoring sensor -G273- (T4bz/4)27)
F57​
Fuse 57 on fuse holder C -SC57-
10 A​
Alarm horn -H12- (T3f/3)27)
30a​
Alarm horn relay -J641- (3A)27)
F58​
Not assigned
F59​
Not assigned
F60​
Not assigned
1) Not for models with dual clutch gearbox
4) Engine code CJAA
28) From December 2011, for models with gas discharge headlights only (8IH)
29) For models with standard headlights only (8IA)
44) For models with treble horn only
Fuse assignment fuse holder C -SC- , VW Beetle from July 2012
Slot​
Nominal value​
Function/component
Terminal​
F1​
Not assigned
F2​
Not assigned
F3​
5 A​
30a​
F4​
Fuse 4 on fuse holder C -SC4-
5 A​
30a​
Control unit in dash panel insert -J285- (T32c/13)
F5​
10 A​
Onboard supply control unit -J519- (T73a/6)
55a​
Rear left fog light bulb -L46- (2)
F6​
10 A​
Rear lid handle release button -E234- (4)
30a​
Reversing camera -R189- (T4ak/1)
Switch and instrument illumination regulator -E20- (T8e/3)
F7​
5 A​
Left number plate light -X4- (2)
58​
Right number plate light -X5- (2)
F8​
7.5 A​
Washer pump -V5- (1)
53c​
F9​
5 A​
Airbag control unit -J234- (T75/1), (T75/26), (T50/1), (T50/26)
15a​
Front passenger front airbag deactivated warning lamp -K145- (T4g/3)
F10​
10 A​
Intermittent wiper switch -E22- (T10m/3)
15a​
F11​
Not assigned
F12​
5 A​
Headlight range control unit -J431- (T26c/23)
15a​
Main switch for stop/start system -E101- (T6bx/4), (T6bx/2)
Fold-in mirror switch -E263- (T10o/5)
Tyre Pressure Loss Indicator display button -E492- (T6an/4)
Reversing light switch -F4- (1)
High-pressure sender -G65- (T3c/3)
F13​
5 A​
Air quality sensor -G238- (T3an/1)
15a​
Heater control unit -J162- (T20c/19)
Parking aid control unit -J446- (T16m/1)
Control module for vehicle location system -J895- (T16n/1)
Automatic anti-dazzle interior mirror -Y7- (T6am/1)
Left washer jet heater element -Z20- (1)
Right washer jet heater element -Z21- (1)
Turn signal switch -E2- (T16j/1)
Oil level and oil temperature sender -G266- (1)
-GX22- (T10ak/3)
ABS control unit -J104- (T47/8)
F14​
10 A​
Control unit in dash panel insert -J285- (T32c/31)
15a​
Power steering control unit -J500- (T3ao/3)
Steering column electronics control unit -J527- (T16p/14)
Voltage stabiliser -J532- (T12z/3)
Data bus diagnostic interface -J533- (T20/14)
Fuel pump control unit -J538- (T10v/3)
Selector lever sensors control unit -J587- (T10s/9)
Engine control unit -J623- (T91/50) 27)
Heater element for crankcase breather -N79- (1)21)
Air mass meter -G70- (T5d/3)13) (T5d/5)4) (T3ar/2)7)
F15​
5 A​
Engine sound generator control unit -J943- (T12p/1)29)
15a​
16-pin connector -T16- (T16/1), Diagnostic connection
F16​
5 A​
15a​
F17​
10 A​
30a​
F18​
15 A​
56bl​
F19​
15 A​
56br​
Heater control unit -J162- (T20c/18)
F20​
5 A​
30a​
Ignition key withdrawal lock solenoid -N376- (T10d/10)
F21​
15 A​
30a​
F22​
5 A​
30a​
F23​
20 A​
30a​
16-pin connector -T16- (T16/16), Diagnostic connection
-GX22- (T10ak/1)
F24​
10 A​
30a​
Data bus diagnostic interface -J533- (T20/1)
F25​
25 A 32)​
Automatic gearbox control unit -J217- (T52/27)32) (T52/28)32)
15a​
10 A​
Mechatronic unit for dual clutch gearbox -J743- (T25/10)30) (T20/13)31)
F26​
Not assigned
F27​
Not assigned
F28​
Not assigned
F29​
5 A​
75​
F30​
20 A​
75a​
F31​
30 A​
75​
F32​
15 A​
75a​
F33​
40 A​
Heater control unit -J162- (T5/5)
75a​
F34​
10 A​
56al​
15 A 35)​
F35​
Fuse 35 on fuse holder C -SC35-
1 A​
15a​
F36​
Fuse 36 on fuse holder C -SC36-
30 A​
30a​
F37​
Fuse 37 on fuse holder C -SC37-
5 A​
Left daytime running light bulb -L174- (T10i/4)
TFL​
F38​
Fuse 38 on fuse holder C -SC38-
5 A​
Right daytime running light bulb -L175- (T10j/4)
TFL​
F39​
30 A​
30​
F40​
Not assigned
F41​
Not assigned
F42​
Not assigned
F43​
30 A​
30a​
F44​
30 A​
30a​
F45​
30 A​
30a​
F46​
Not assigned
F47​
20 A​
Electric fuel pump 2 relay -J49- (3B)17)
30a​
F48​
30 A​
30a​
F49​
40 A​
30a​
F50​
30 A​
30a​
F51​
30 A​
30a​
F52​
20 A​
30a​
F53​
20 A​
30a​
F54​
Not assigned
F55​
20 A​
30​
F56​
Not assigned
F57​
25 A​
30a​
F58​
Not assigned
F59​
Not assigned
F60​
Not assigned
4) Engine code CJAA
32) Only models with Tiptronic
35) Only models with automatic headlight range control
Fuse assignment fuse holder C -SC- , VW Beetle from July 2013
Slot​
Nominal value​
Function/component
Terminal​
F1​
Fuse 1 on fuse holder C -SC1-
Not assigned
F2​
10 A​
Emergency call module control unit and communication unit -J949-
30​
F3​
5 A​
30​
F4​
5 A​
30​
F5​
10 A​
55​
F6​
10 A​
30​
F7​
5 A​
58​
F8​
10 A​
Washer pump -V5-
53​
F9​
5 A​
15​
F10​
15 A​
15​
F11​
5 A​
Light switch -E1-
15​
F12​
5 A​
15​
F13​
5 A​
Start/Stop operation button -E693-
15​
F14​
10 A​
CCS switch -E45-
15​
Additional instruments -GX22-
F15​
5 A​
15​
Control unit for structure-borne sound -J869-
16-pin connector -T16- , Diagnostic connection
F16​
5 A​
15​
F17​
10 A​
30​
Vehicle inclination sender -G384-
Alarm horn -H12-
F18​
15 A​
56b​
F19​
15 A​
56b​
F20​
5 A​
30​
F21​
15 A​
30​
F22​
5 A​
30​
F23​
20 A​
30​
F24​
10 A​
30​
F25​
25 A 2)​
15​
10 A​
F26​
Fuse 26 on fuse holder C -SC26-
30 A​
Vacuum pump for brakes -V192-
15​
F27​
Not assigned
F28​
Not assigned
F29​
5 A​
75​
F30​
20 A​
75​
12 V socket -U5-
F31​
30 A​
Light switch -E1-
75​
F32​
15 A​
75​
F33​
40 A​
75​
F34​
10 A​
15 A 35)​
56a​
F35​
1 A​
15​
F36​
30 A​
30​
F37​
5 A​
TFL​
F38​
5 A​
TFL​
F39​
30 A​
30​
F40​
Not assigned
F41​
Not assigned
F42​
Not assigned
F43​
30 A​
30​
F44​
30 A​
30​
F45​
30 A​
30​
F46​
Not assigned
F47​
20 A​
30​
F48​
30 A​
30​
F49​
40 A​
30​
F50​
30 A​
30​
F51​
30 A​
30​
F52​
20 A​
30​
F53​
20 A​
30​
F54​
Not assigned
F55​
20 A​
Light switch -E1-
30​
F56​
Not assigned
F57​
25 A​
30​
Radio -R-
F58​
Not assigned
F59​
Not assigned
F60​
Not assigned
Fuse assignment fuse holder C -SC- , VW Beetle from July 2014
Slot​
Nominal value​
Function/component
Terminal​
F1​
5 A​
Blind spot monitor control unit 2 -J1087-
15​
F2​
10 A​
30​
F3​
5 A​
30​
F4​
5 A​
30​
F5​
10 A​
55​
F6​
10 A​
30​
F7​
5 A​
58​
F8​
10 A​
Washer pump -V5-
53​
F9​
5 A​
15​
F10​
15 A​
15​
F11​
5 A​
Light switch -E1-
15​
F12​
Not assigned
F13​
5 A​
15​
F14​
10 A​
CCS switch -E45-
15​
F15​
5 A​
15​
F16​
5 A​
15​
F17​
10 A​
30​
Alarm horn -H12-
F18​
15 A​
56bl​
F19​
15 A​
56br​
F20​
10 A​
30​
F21​
15 A​
30​
F22​
5 A​
30​
F23​
10 A​
30​
F24​
10 A​
30​
F25​
25 A 2)​
15​
10 A​
F26​
30 A​
F27​
Not assigned
F28​
Fuse 28 on fuse holder C -SC28-
25 A​
75​
F29​
5 A​
75​
F30​
20 A​
75​
12 V socket -U5-
F31​
30 A​
Light switch -E1-
75​
F32​
15 A​
75​
F33​
40 A​
75​
F34​
10 A 3)​
30​
15 A 4)​
56​
F35​
1 A​
15​
F36​
30 A​
30​
F37​
5 A​
TFL​
F38​
5 A​
TFL​
F39​
30 A​
30​
F40​
Not assigned
F41​
Not assigned
F42​
Not assigned
F43​
30 A​
30​
F44​
30 A​
30​
F45​
30 A​
30​
F46​
Not assigned
F47​
20 A​
30​
F48​
30 A​
30​
F49​
40 A​
30​
F50​
30 A​
30​
F51​
30 A​
30​
F52​
20 A​
30​
F53​
20 A​
30​
F54​
Not assigned
25 A​
30​
F55​
20 A​
Light switch -E1-
30​
F56​
20​
30​
F57​
25 A​
30​
Radio -R-
F58​
Fuse 58 on fuse holder C -SC58-
10 A​
Relay for reducing agent metering system -J963-
30​
F59​
Not assigned
F60​
Not assigned
3) Only models with xenon headlights
4) Only models with halogen headlights
