Saulius
Оракул
- Литва
- Audi A4 1999 2,5TDI Quatro AFB , VW Sharan 1997 2,8 ААА VR6 syncro
Тут lbl файлик на твой ЭБУ, конвертированный с clb :Так вот эти манипуляции как раз и не работают. А должны. Есть предложение как исправить?
Код:
001,0,Door Contact Switches
001,1,Driver Door,Door Contact (F2),Display Range: Door Closed/Door Open
001,2,Passenger Door,Door Contact (F3),Display Range: Door Closed/Door Open
001,3,Rear Left Door,Door Contact (F10),Display Range: Door Closed/Door Open
001,4,Rear Right Door,Door Contact (F11),Display Range: Door Closed/Door Open
002,0,Central Locking Units
002,1,Driver Door,Status (F220),Display Range: Locked/Unlocked/Safe/Implausible
002,2,Passenger Door,Status (F221),Display Range: Locked/Unlocked/Safe/Implausible
002,3,Rear Left Door,Status (F222),Display Range: Locked/Unlocked/Safe/Implausible
002,4,Rear Right Door,Status (F223),Display Range: Locked/Unlocked/Safe/Implausible
003,0,Key Switches && Interior Lock Buttons
003,1,Driver Door,Key Switch,Display Range: Not Oper./Open/Close/Implausible
003,2,Passenger Door,Key Switch,Display Range: Not Oper./Open/Close/Implausible
003,3,Driver Door,Lock Butt. (E308),Display Range: Not Oper./Locking/Unlocking/Implausible
003,4,Passenger Door,Lock Butt. (E308),Display Range: Not Oper./Locking/Unlocking/Implausible
004,0,Rear Lid
004,1,Rear Lid,Key Switch,Display Range: Open/Close/Not Oper.
004,2,Rear Lid Handle,Unlock Sw. (E234),Display Range: Not Oper./Operated
004,3,Rear Lid Lock Unit,(F256) Main Latch,Display Range: Open/Closed
004,4,Rear Lid Lock Unit,(F256) Pre-Latch,Display Range: Open/Closed
005,0,Power Supply
005,1,Voltage,(Terminal 30),Specification: 9.0...14.0 V
005,2,Voltage Status,,?x = Terminal 30\nx? = Terminal 30a
005,3,Terminal 15,Status,Display Range: Term 15 On/Term 15 Off
005,4,S-Contact,Status,Display Range: Activated/Inactive
006,1,Vehicle Speed
006,2,Crash Signal,,Display Range: Yes/No
006,3,Request to,Open Tank Lid,Display Range: Yes/No
007,1,Enabling Sunroof,,Display Range: Yes/No
007,2,Sunroof Control,,Display Range: Not Oper./Open/Closed
007,3,Comfort Function,,Display Range: Not Installed
008,1,Terminal 58d,Request,Display Range: 0.0...100.0 %
008,2,Terminal 58s,Signal,Display Range: 0.0...100.0 %
008,3,Door Handle,Illum. Request,Display Range: Not Installed
008,4,Door Handle,Illum. Signal,Display Range: Not Installed
009,1,Central Locking,Thermal Protection,Display Range: Yes/No
009,2,Signal:,Doors not Closed,Display Range: Open/Closed
009,3,Rear Left,Entry Light (W33),Display Range: ON/OFF/Not Installed
009,4,Rear Right,Entry Light (W34),Display Range: ON/OFF/Not Installed
010,0,Remote Control
010,1,Remote Control,Key Number,0 = No Key recognized\n1 = Key 1\n2 = Key 2\n3 = Key 3\n4 = Key 4
010,2,Remote Control,Buttons,Display Range: 0 = Not Operated / 1 = Operated\n\n?xxx = Open\nx?xx = Close\nxx?x = Rear Lid\nxxx? = Panic (USA only)
011,0,Immobilizer
011,1,Fixed Code,,Display Range: No Value/OK/Not OK
011,2,Code in,Catch Area,Display Range: No Value/OK/Not OK
011,3,Algorithm,,Display Range: No Value/OK/Not OK
012,1,Immobilizer,Key Recognition,Display Range: Yes/No
012,2,Rear Lid Remote,Lock Sw. (E233),Display Range: Not Oper./Operated
012,3,Rear Lid Handle,Unlock Sw. (E234),Display Range: Yes/No
012,4,Front Hood,Switch (F266),Display Range: Open/Closed
013,1,Telematics,,Display Range: Open/Closed/Not Oper./Not Installed
013,2,Interior Monitoring,Sensor (G273),Display Range: Not Installed
014,0,Interior Monitoring Sensor (G273)
014,1,Interior Monitoring,Status,Display Range: Active/Inactive/Not Installed
014,2,Interior Monitoring,Alarm Recognized,Display Range: Yes/No/Not Installed
014,3,Interior Monitoring,Output Active,Display Range: ON/OFF/Not Installed
014,4,Interior Monitoring,Output Active,Display Range: ON/OFF/Not Installed
015,0,Vehicle Inclination Sensor (G384)
015,1,Incl. Sensor (G384),Status,Display Range: Active/Inactive/Not Installed
015,2,Incl. Sensor (G384),Alarm Recognized,Display Range: Yes/No/Not Installed
015,3,Incl. Sensor (G384),Output Active,Display Range: ON/OFF/Not Installed
015,4,Incl. Sensor (G384),Indic. Lamp (K188),Display Range: Operated/Not Operated/Not Installed
016,0,Alarm Horn (H12)
016,1,Alarm Horn (H12),Status,Display Range: Active/Inactive/Not Installed
016,2,Alarm Horn (H12),Alarm Recognized,Display Range: Yes/No/Not Installed
016,3,Alarm Horn (H12),Output Active,Display Range: ON/OFF/Not Installed
017,0,Vehicle Inclination Sensor (G384)
017,1,X-Reference,Angle,Specification: -25.2...+25.4 °\nDisplay Range: No Value/Not Installed
017,2,Current,X-Delta Angle,Specification: -12.6...+12.7 °\nDisplay Range: No Value/Not Installed
017,3,Y-Reference,Angle,Specification: -25.2...+25.4 °\nDisplay Range: No Value/Not Installed
017,4,Current,Y-Delta Angle,Specification: -12.6...+12.7 °\nDisplay Range: No Value/Not Installed
018,0,Alarm Horn (H12) Trigger
018,1,Alarm Horn (H12),1st Alarm Trigger,0 = No Alarm triggered\n1 = Comfort Control Module\n2 = Open Circuit on Ground\n3 = Open Circuit on Plus\n4 = Intelligent Battery
018,2,Alarm Horn (H12),2nd Alarm Trigger,0 = No Alarm triggered\n1 = Comfort Control Module\n2 = Open Circuit on Ground\n3 = Open Circuit on Plus\n4 = Intelligent Battery
018,3,Alarm Horn (H12),3rd Alarm Trigger,0 = No Alarm triggered\n1 = Comfort Control Module\n2 = Open Circuit on Ground\n3 = Open Circuit on Plus\n4 = Intelligent Battery
018,4,Alarm Horn (H12),Trigger Counter
019,0,Interior Monitoring Sensor (G273) Trigger
019,1,Interior Monitoring,1st Alarm Trigger,0 = No Alarm triggered\n1 = Alarm while Vehicle closed\n2 = Alarm while Windows open\n3 = Alarm while Fan active
019,2,Interior Monitoring,2nd Alarm Trigger,0 = No Alarm triggered\n1 = Alarm while Vehicle closed\n2 = Alarm while Windows open\n3 = Alarm while Fan active
019,3,Interior Monitoring,3rd Alarm Trigger,0 = No Alarm triggered\n1 = Alarm while Vehicle closed\n2 = Alarm while Windows open\n3 = Alarm while Fan active
019,4,Interior Monitoring,4th Alarm Trigger,0 = No Alarm triggered\n1 = Alarm while Vehicle closed\n2 = Alarm while Windows open\n3 = Alarm while Fan active
020,0,Anti Theft System Alarm Sources
020,1,Anti Theft System,1st Alarm Source,0 = Drivers Door\n1 = Passenger Door\n2 = Rear Left Door\n3 = Rear Right Door\n4 = Rear Lid\n5 = Engine Hood\n6 = Rear Window Latch\n7 = Trailer\n8 = Rear Window Broken\n9 = Ignition\n10 = Interior Monitoring\n11 = Inclination Sensor\n12 = Intelligent Siren\n13 = Central Electronics Control Module\n14 = Door Control Module Drivers Door\n15 = Door Control Module Passenger Door\n16 = Door Control Module Rear Left Door\n17 = Door Control Module Rear Right Door\n18 = Gateway Control Module\n19 = Power-On-Reset (POR) Alarm\n255 = No Alarm
020,2,Anti Theft System,2nd Alarm Source,0 = Drivers Door\n1 = Passenger Door\n2 = Rear Left Door\n3 = Rear Right Door\n4 = Rear Lid\n5 = Engine Hood\n6 = Rear Window Latch\n7 = Trailer\n8 = Rear Window Broken\n9 = Ignition\n10 = Interior Monitoring\n11 = Inclination Sensor\n12 = Intelligent Siren\n13 = Central Electronics Control Module\n14 = Door Control Module Drivers Door\n15 = Door Control Module Passenger Door\n16 = Door Control Module Rear Left Door\n17 = Door Control Module Rear Right Door\n18 = Gateway Control Module\n19 = Power-On-Reset (POR) Alarm\n255 = No Alarm
020,3,Anti Theft System,3rd Alarm Source,0 = Drivers Door\n1 = Passenger Door\n2 = Rear Left Door\n3 = Rear Right Door\n4 = Rear Lid\n5 = Engine Hood\n6 = Rear Window Latch\n7 = Trailer\n8 = Rear Window Broken\n9 = Ignition\n10 = Interior Monitoring\n11 = Inclination Sensor\n12 = Intelligent Siren\n13 = Central Electronics Control Module\n14 = Door Control Module Drivers Door\n15 = Door Control Module Passenger Door\n16 = Door Control Module Rear Left Door\n17 = Door Control Module Rear Right Door\n18 = Gateway Control Module\n19 = Power-On-Reset (POR) Alarm\n255 = No Alarm
020,4,Anti Theft System,4th Alarm Source,0 = Drivers Door\n1 = Passenger Door\n2 = Rear Left Door\n3 = Rear Right Door\n4 = Rear Lid\n5 = Engine Hood\n6 = Rear Window Latch\n7 = Trailer\n8 = Rear Window Broken\n9 = Ignition\n10 = Interior Monitoring\n11 = Inclination Sensor\n12 = Intelligent Siren\n13 = Central Electronics Control Module\n14 = Door Control Module Drivers Door\n15 = Door Control Module Passenger Door\n16 = Door Control Module Rear Left Door\n17 = Door Control Module Rear Right Door\n18 = Gateway Control Module\n19 = Power-On-Reset (POR) Alarm\n255 = No Alarm
A000,0,Remote Control Erasing
A000,5,Remote Control Erasing
A000,6,0 - Erase all keys
A001,0,Remote Control Adaptation
A001,1,Key
A001,2,Adaptation
A001,3,Current Number,of Keys
A001,5,Remote Control Adaptation
A001,6,Enter the number of keys that should be adapted. Save.
A001,7,
A001,8,Now press button 1 or 2 on every remote that
A001,9,should be adapted for at least 1 second.
A001,10,
A001,11,Note #1: All keys must be adapted in one procedure.
A001,12,Note #2: Adaptation of all keys must not exceed 15 seconds.
A003,0,Selective (Single) Door Locking
A003,3,Current Status
A003,5,Selective (Single) Door Locking
A003,6,Display Range: 0 = OFF / 1 = ON
A004,0,Auto-Lock
A004,1,Auto-Lock
A004,3,Current Status
A004,5,Auto-Lock
A004,6,The doors will lock automatically when the
A004,7,vehicle reaches a speed of 15 km/h or 10 mph.
A004,8,
A004,9,Specification: 0 = OFF / 1 = ON
A005,0,Auto-Unlock
A005,1,Auto-Unlock
A005,3,Current Status
A005,5,Auto-Unlock
A005,6,The doors will unlock automatically when
A005,7,the key is removed from the ignition switch.
A005,8,
A005,9,Specification: 0 = OFF / 1 = ON
A007,0,Unlocking Confirmation (Remote Control)
A007,1,Unlocking,Confirmation
A007,2,via,Remote Control
A007,3,Current Status
A007,5,Unlocking Confirmation (Remote Control)
A007,6,Type of confirmation when unlocking
A007,7,the car via remote control.
A007,8,
A007,9,0 = OFF
A007,10,1 = Blink
A007,11,2 = Beep (Horn)
A007,12,3 = Beep (Horn) & Blink
A008,0,Unlocking Confirmation (Key Switch)
A008,1,Unlocking,Confirmation
A008,2,via,Key Switch
A008,3,Current Status
A008,5,Unlocking Confirmation (Key Switch)
A008,6,Type of confirmation when unlocking
A008,7,the car via key switch.
A008,8,
A008,9,0 = OFF
A008,10,1 = Blink
A008,11,2 = Beep (Horn)
A008,12,3 = Beep (Horn) & Blink
A010,0,Locking Confirmation (Remote Control)
A010,1,Locking,Confirmation
A010,2,via,Remote Control
A010,3,Current Status
A010,5,Locking Confirmation (Remote Control)
A010,6,Type of confirmation when locking
A010,7,the car via remote control.
A010,8,
A010,9,0 = OFF
A010,10,1 = Blink
A010,11,2 = Beep (Horn)
A010,12,3 = Beep (Horn) & Blink
A011,0,Locking Confirmation (Key Switch)
A011,1,Locking,Confirmation
A011,2,via,Key Switch
A011,3,Current Status
A011,5,Locking Confirmation (Key Switch)
A011,6,Type of confirmation when locking
A011,7,the car via key switch.
A011,8,
A011,9,0 = OFF
A011,10,1 = Blink
A011,11,2 = Beep (Horn)
A011,12,3 = Beep (Horn) & Blink
A012,0,Safe Confirmation
A012,1,Safe,Confirmation
A012,3,Current Status
A012,5,Safe Confirmation
A012,6,Type of confirmation when
A012,7,the car is beeing safed.
A012,8,
A012,9,0 = OFF
A012,10,1 = Blink
A012,11,2 = Beep (Horn)
A012,12,3 = Beep (Horn) & Blink
A013,0,Alarm Horn Adjustment
A013,5,Alarm Horn Adjustment
A013,6,Country setting for alarm horn. This changes length
A013,7,and volume of the alarm horn sounding.
A013,8,
A013,9,0 - Great Britain (Frequency Modulated - 10 Tamper Alarms)
A013,10,1 - Great Britain (Frequency Modulated - 1 Tamper Alarm)
A013,11,2 - Rest of World (Discontinuous - 10 Tamper Alarms)
A013,12,3 - Rest of World (Discontinuous - 1 Tamper Alarm)
A017,0,Comfort Function (Remote Control)
A017,1,Comfort Function
A017,2,Remote Control
A017,3,Current Status
A017,5,Comfort Function
A017,6,Display Range: 0 = OFF / 1 = ON
A017,7,
A017,8,NOTE: See long coding for more details/options.
A018,0,Alarm Delay
A018,1,Alarm Delay
A018,2,Driver Door
A018,3,Current Status
A018,5,Alarm Delay
A018,6,Deactivation of the anti theft warning delay
A018,7,when opening drivers door before the anti theft
A018,8,warning system is beeing activated.
A018,9,
A018,10,Display Range: 0 = OFF / 1 = ON
A019,0,Factory Mode
A019,3,Current Status
A019,5,Factory Mode
T94,Rear Left Central Locking Motor (V214)
T95,Rear Right Central Locking Motor (V215)
T327,Open Sliding Sunroof
T948,Close Sliding Roof
T379,Activate Terminal 58s
T1134,Alarm Horn (H12)
T1338,Signal: Doors Not Closed
T332,Open Tank Flap
T1699,Hatch/Trunk Central Locking Motor (V53)
T2483,Rear Lid Locking Module (F327)
LC,00,0,Selective Central Locking (Single Door Opening)
LC,00,3,Auto-Unlock (unlocking after removing key from ignition)
LC,00,4,Auto-Lock (automatic locking from 15 km/h)
LC,02,1,Central Locking (Rear Lid) "Security Lock"
LC,06,0,Comfort Function inactive
LC,06,1,Comfort Function Power Windows/Sunroof via Drivers Door Lock inactive
LC,06,2,Comfort Function Power Windows/Sunroof via Passengers Door Lock inactive
LC,06,3,Comfort Function Power Windows/Sunroof via Rear Lid Door Lock inactive
LC,06,4,Comfort Function Power Windows/Sunroof via Power Window Switch inactive
LC,06,5,Comfort Function Power Windows/Sunroof via Remote Control inactive
LC,06,6,Comfort Function automatic Closing
LC,06,7,Power Windows/Sunroof disabled after door Opening
LC,07,0,Comfort Opening Power Windows via Door Lock active
LC,07,1,Comfort Opening Power Windows via Power Window Switch active
LC,07,2,Comfort Opening Power Windows via Remote Control active
LC,07,3,Comfort Closing Power Windows via Door Lock active
LC,07,4,Comfort Closing Power Windows via Power Window Switch active
LC,07,5,Comfort Closing Power Windows via Remote Control active
LC,07,6,Comfort Function after authorized Access only for a limited Time
LC,08,0,Comfort Opening Sunroof via Door Lock active
LC,08,1,Comfort Opening Sunroof via Power Window Switch active
LC,08,2,Comfort Opening Sunroof via Remote Control active
LC,08,3,Comfort Closing Sunroof via Door Lock active
LC,08,4,Comfort Closing Sunroof via Power Window Switch active
LC,08,5,Comfort Closing Sunroof via Remote Control active
LC,08,6,Comfort Opening Type for Sunroof (0 = open/ 1 = lift)
LC,09,0,Comfort Opening only for Driver Side Power Window active
LC,09,1,Rain Closing (0 = nonrecurring / 1 = permanent)
LC,09,2,Comfort Function Power Windows/Sunroof via Rain Light Sensor (Rain Closing) inactive
LC,10,0,Unlocking Confirmation (Blink) via Door Locks
LC,10,1,Unlocking Confirmation (Horn) via Door Locks
LC,10,2,Unlocking Confirmation (Blink) via Remote Control
LC,10,3,Unlocking Confirmation (Horn) via Remote Control
LC,10,7,Horn Confirmation Configuration blocked
LC,11,0,Locking Confirmation (Blink) via Door Locks
LC,11,1,Locking Confirmation (Horn) via Door Locks
LC,11,2,Locking Confirmation (Blink) via Remote Control
LC,11,3,Locking Confirmation (Horn) via Remote Control
LC,12,4,Comfort Closing Abortion Confirmation (Horn) active
LC,12,5,Comfort Closing Confirmation (Blink) active
LC,12,6,Anti-Theft-System Activation Confirmation (Blink) active
LC,12,7,Anti-Theft-System Activation Confirmation (Horn) active
LC,13,0,Remote Control inactive
LC,13,1,Remote Control with "Terminal 15 ON" inactive
LC,13,2,Remote Control Range Limitation active
LC,13,3,Manual Remote Control learning/unlearning active
LC,14,0,Doors (0 = 2-doors / 1 = 4-doors)
LC,14,1,Front Power Windows installed
LC,14,2,Rear Power Windows installed
LC,14,3,Central Locking installed
LC,14,4,Model (0 = Left-Hand-Drive/ 1 = Right-Hand-Drive)
LC,14,6,Synchronised Mirror Adjustment
LC,14,7,Mirror Lowering with Reverse Rear (only with Memory Seats)
LC,15,0,Anti-Theft System deactivated
LC,15,1,Anti-Theft System disarming only via Remote Control or Immobilizer
LC,15,2,Anti-Theft active with intentional de-safe / Interior Monitoring inactive
LC,15,3,Anti-Theft Alarm Delay (15 sec) inactive (Thatcham)
LC,15,5,Anti-Theft System passive arming
LC,15,6,Inclination Sensor installed
LC,15,7,Interior Monitoring installed
LC,16,4,Siren installed
LC,16,5,Siren Tone Type (0 = frequency modulated / 1 = discontinuoud)
LC,16,6,Siren Alarm Type (0 = 10 Alarms (GB/Irland) / 1 = 1 Alarm (RoW))
LC,16,7,Siren Configuration blocked
LC,17,0,Rear Door Warning Lights installed
LC,17,1,Interior Door Handle Illumination installed
LC,17,2,Transmission Type (0 = Automatic Transmission / 1 = Manual Transmission)
LC,17,5,Tire Pressure Monitoring (TPMS - PR-7K3/7K4/7K5) not installed/inactive
LC,17,6,Rear Door Control Module via LIN active
LC,18,5,Comfort Menu inactive
LC,18,6,Comfort Menu fast scrolling active
LC,18,7,Personalization inactive
V,EA2
Попробуй в тестах ВАГ-КОМа подвигать люк компом, должен работать. Если так, то чтото намудрил с кодировкой блока комфорта. Нужные функции теста T327 T948, кодирования LC,08,2 LC,08.5 . но для начала всем блокам верни первоначальную кодировку.
