Руководство Bosch Motronic ME 7, ME 7.1, ME 7.1.1, ME 7.5 System Strategy
Admin
Admin
Создатель сайта
Команда форума
Россия, Москва
VW Tiguan 2.0 DBGC 2018, VW Touran 1.6 BSE 2008
Table Of Contents
01.00.00 Catalyst Monitoring
01.01.00 Passive Measurement Of Amplitude Ratio
01.01.01 General Description
01.01.02 Monitoring Structure
01.01.03 Flow Chart Catalyst Monitoring
01.02.00 Active Measurement Of Osc
01.02.01 General Description
01.02.02 Monitoring Structure.
01.02.03 Flow Chart Catalyst Monitoring
02.00.00 Heated Catalyst Monitoring
03.00.00 Misfire Monitoring
03.00.01 General Description
03.01.02 Monitoring Function Description
03.00.03 Chart(S) And Flow Chart(S)
04.00.00 Evaporative System Diagnosis
04.01.00 Leakage Check
04.01.01 General Description
04.01.02 Monitoring Function Description
04.01.03 Chart(S) And Flow Chart(S).
04.02.00 Purge Check.
04.02.01 General Description
04.02,02 Monitoring Function Description
04.02.03 Chart(S) And Flow Chart(S).
05.00.00 Secondary Air System Monitoring
05.01.00 Via Lambda Deviation
05.01.01 General Description
05.01.02 Monitoring Structure.
05.01.03 Chart(S) And Flow Chart(S)
05.02.00 Via Exhaust Temperature Sensor
05.02.01 General Description
05.02.02 Monitor Function Description
05.02.03 Chart(S) And Flow Chart(S)
06.00.00 Fuel System Monitoring
06.00.01 General Description
06.00.02 Monitoring Function Description
06.00.03 Chart(S) And Flow Chart(S)
07.00.00 Oxygen Sensor Monitoring
07.01.00 Calibrations With Asic Cj 110
07.01.01 General Description
07.01.02 Monitoring Function Description
07.01.03 Chart(S) And Flow Chart(S)
07.02.00 Oxygen Sensor Heater Monitoring
07.03.01 General Description (Asic Cj 110)
07.02.02 Monitor Function Description
07.02.03 Chart(S) And Flow Chart(S)
07.03.02 Monitor Function Description
07.03.03 Chart(S) And Flow Chart(S)
07.04.00 Oxygen Sensor Heater Monitoring (Asic Cj 125/120)
07.04.01 General Description
07.04.02 Monitor Function Description
07.04.03 Chart(S) And Flow Chart(S)
07.05.00 Sulev Applications
07.05.01 General Description
07.05.02 Monitor Function Description
07.05.03 Chart(S) And Flow Chart(S).
07.06.00 Oxygen Sensor Heater Monitoring (Sulev)
07.06.01 General Description
07.06.02 Monitor Function Description)
07.06.03 Chart(S) And Flow Chart(S)
08.00.00 Egr Monitoring
09.00.00 Pcv Monitoring
10.00.00 Engine Coolant System Monitoring
10.01.00 General Description
10.01.02 Monitor Functional Description
10.03.00 Charts And Flow Charts
11.00.00 Cold Start Emission Reduction Strategy Monitoring
12.00.00 Air Conditioning (A/C) System Component Monitoring
13.00.00 Variable Valve Timing And/Or Control (Vvt) System Monitoring
14.00.00 Direct Ozon Reduction (Dor) System Monitoring
15.00.00 Particulate Mater (Pm) Trap Monitoring
16.00.00 Comprehensive Components Monitoring
16.01.00 Injection Valve
16.02.00 Fuel Pump Relay
16.03.00 Idle Controller
16.04.00 Engine Speed Sensor:
16.05.00 Warm-Up Bypass Valve:
16.06.00 Signal Range Check For Different Sensor
16.07.00 Rationality Mass Air Flow Sensor (Maf)
16.08.00 Vehicle Speed Sensor (Vss)
16.09.00 Throttle Position Sensor (Throttle Unit With E-Gas Actuator)
16.10.00 Accelerator Pedal Position Sensor (Apps)
16.11.00 Camshaft Position Sensor
16.12.00 Boost Pressure Control Valve.
16.13.00 Engine Start Delay Relay (Sulev)
16.14.00 Exhaust Temperature Sensor (Sulev)
16.14.01 General Monitoring Description
16.14.02 Monitor Function Description
16.14.03 Chart(S) And Flow Chart (S)
16.15.00 Reserved
16.16.00 Reserved
16.17.00 Reserved
16.18.00 Reserved
16.19.00 Reserved
16.20.00 Automatic Transmission Monitor
16.21.00 Output Stage Check
17.00.00 Other Emission Control Or Source System Monitoring
18.00.00 Exemptions To Monitor Requirements
19.00.00 Reserved
20.00.00 Parameters And Conditions For Closed Loop Operation
21.00.00 Parameters / Conditions For 2nd Closed Loop Operation
22.00.00 Parameters / Conditions For Closed Loop Operation On Sulev
  • Bosch-Motronic-ME-7-System-Strategy-eng.pdf
    551,7 КБ · Просмотры: 4 616
