Admin
Создатель сайта
Команда форума
- Россия, Москва
Volkswagen diagnostic trouble code (DTC) list
Press Ctrl+F to find DTC code. (Нажмите Ctrl+F для поиска кода ошибки)
P-Codes:
P-Codes:
DTC | DTC Text |
P000100 | Fuel Volume Regulator Control Circuit/Open |
P000A00 | A Camshaft Position Slow Response (Bank 1) |
P000B00 | B Camshaft Position Slow Response (Bank 1) |
P000C00 | A Camshaft Position Slow Response (Bank 2) |
P000D00 | B Camshaft Position Slow Response (Bank 2) |
P001000 | A Camshaft Position Actuator Circuit/Open (Bank1) |
P001100 | A Camshaft Position (Bank1) Timing over-advanced or System Performance |
P001200 | A Camshaft Position (Bank1) Timing over-retarded |
P001300 | B Camshaft Position Actuator Circuit/Open (Bank1) |
P001400 | B Camshaft Position (Bank1) Timing over-advanced or System Performance |
P001500 | B Camshaft Position (Bank1) Timing over-retarded |
P001600 | Crankshaft Position-Camshaft Position Correlation Bank 1 Sensor A |
P001700 | Crankshaft Position-Camshaft Position Correlation Bank 1 Sensor B |
P001800 | Crankshaft Position-Camshaft Position Correlation Bank 2 Sensor A |
P001900 | Crankshaft Position-Camshaft Position Correlation Bank 2 Sensor B |
P002000 | A Camshaft Position ActuatorCircuit(Bank2) |
P002100 | A Camshaft Position (Bank2) Timing over-advanced or System Performance |
P002200 | A Camshaft Position (Bank2) Timing over-retarded |
P002300 | B Camshaft Position Actuator Circuit(Bank2) |
P002400 | B Camshaft Position (Bank2) Timing over-advanced or System Performance |
P002500 | B Camshaft Position (Bank2) Timing over-retarded |
P003000 | O2 Sensor Heater Contr. Circ.(Bank1(1)Sensor 1) |
P003100 | O2 Sensor Heater Contr. Circ.(Bank1(1)Sensor 1) Low |
P003200 | O2 Sensor Heater Contr. Circ.(Bank1(1)Sensor 1) High |
P003300 | Turbo Charger Bypass Valve Control Circuit |
P003400 | Turbo Charger Bypass Valve Control Circuit Low |
P003500 | Turbo Charger Bypass Valve Control Circuit High |
P003600 | O2 Sensor Heater Contr. Circ.(Bank1(1)Sensor 2) |
P003700 | O2 Sensor Heater Contr. Circ.(Bank1(1)Sensor 2) Low |
P003800 | O2 Sensor Heater Contr. Circ.(Bank1(1)Sensor 2) High |
P003900 | Turbo/Super Charger Bypass Valve Control Circuit Range/Performance |
P004000 | O2 Sensor Signals Swapped Bank 1 Sensor 1/ Bank 2 Sensor 1 |
P004100 | O2 Sensor Signals Swapped Bank 1 Sensor 2/ Bank 2 Sensor 2 |
P004200 | O2 Sensor Heater Contr. Circ.(Bank1(1)Sensor 3) |
P004300 | O2 Sensor Heater Contr. Circ.(Bank1(1)Sensor 3) Low |
P004400 | O2 Sensor Heater Contr. Circ.(Bank1(1)Sensor 3) High |
P004500 | Turbocharger/Supercharger Boost Control Solenoid "A" Circuit/Open |
P004700 | Turbocharger/Supercharger Boost Control Solenoid "A" Circuit Low |
P004800 | Turbocharger/Supercharger Boost Control Solenoid "A" Circuit High |
P004900 | Turbocharger/Supercharger Turbine Overspeed |
P004A00 | Turbocharger/Supercharger Boost Control Solenoid "B" Circuit / Open |
P004C00 | Turbocharger/Supercharger Boost Control Solenoid "B" Circuit Low |
P004D00 | Turbocharger/Supercharger Boost Control Solenoid "B" Circuit High |
P005000 | O2 Sensor Heater Contr. Circ.(Bank2 Sensor 1) |
P005100 | O2 Sensor Heater Contr. Circ.(Bank2 Sensor 1) Low |
P005200 | O2 Sensor Heater Contr. Circ.(Bank2 Sensor1) High |
P005600 | O2 Sensor Heater Contr. Circ.(Bank2 Sensor 2) |
P005700 | O2 Sensor Heater Contr. Circ.(Bank2 Sensor 2) Low |
P005800 | O2 Sensor Heater Contr. Circ.(Bank2 Sensor2) High |
P006200 | HO2S Heater Control Circuit |
P006300 | HO2S Heater Control Circuit Low |
P006400 | HO2S Heater Control Circuit High Bank2 Sensor3 |
P006500 | Air Assisted Injector Control Range/Performance |
P006600 | Air Assisted Injector Control Circuit low |
P006700 | Air Assisted Injector Control Circuit high |
P006800 | MAP/MAF - Throttle Position Correlation |
P006900 | Manifold Absolute Pressure - Barometric Pressure Correlation |
P007000 | Ambient Air Temperature Sensor Circuit |
P007100 | Ambient Air Temperature Sensor Circuit Range/Performance |
P007200 | Ambient Air Temperature Sensor Circuit Low |
P007300 | Ambient Air Temperature Sensor Circuit High |
P007400 | Ambient Air Temperature Sensor Circuit Intermittent |
P007C00 | Charge Air Cooler Temperature Sensor Circuit Low Bank 1 |
P007D00 | Charge Air Cooler Temperature Sensor Circuit High Bank 1 |
P008700 | Fuel Rail/System Pressure - Too Low |
P008800 | Fuel Rail/System Pressure - Too High |
P008900 | Fuel Pressure Regulator 1 Performance |
P008A00 | Low Pressure Fuel System Pressure - Too Low |
P008B00 | Low Pressure Fuel System Pressure - Too High |
P009000 | Fuel Pressure Regulator 1Control Circuit |
P009100 | Fuel Pressure Regulator 1 Control Circuit Low |
P009200 | Fuel Pressure Regulator 1 Control Circuit High |
P009500 | Intake Air Temperature Sensor 2 Circuit |
P009600 | Intake Air Temperature Sensor 2 Circuit Bank 1 Range/Performance |
P009700 | Intake Air Temperature Sensor 2 Circuit Low |
P009800 | Intake Air Temperature Sensor 2 Circuit High |
P009900 | Intake Air Temperature Sensor 2 Circuit Intermittent/Erratic |
P009B00 | Fuel Pressure Relief Control Circuit/Open |
P009C00 | Fuel Pressure Relief Control Circuit Low |
P009D00 | Fuel Pressure Relief Control Circuit High |
P009E00 | Fuel Pressure Relief Control Performance/Stuck Off |
P009F00 | Fuel Pressure Relief Control Stuck on |
P00A200 | Charge Air Cooler Temperature Sensor Circuit Low Bank 2 |
P00A300 | Charge Air Cooler Temperature Sensor Circuit High Bank 2 |
P00A600 | Intake Air Temperature Sensor 2 Circuit Bank 2 Range/Performance |
P00AF00 | Turbocharger/Supercharger Boost Control "A" Module Performance |
P00B000 | Turbocharger/Supercharger Boost Control "B" Module Performance |
P00C600 | Fuel Rail Pressure Too Low - Engine Cranking |
P010000 | Mass or Volume Air Flow Circuit |
P010100 | Mass or Volume Air Flow Circ. Range/Performance |
P010200 | Mass or Volume Air Flow Circ. Low Input |
P010300 | Mass or Volume Air Flow Circ. High Input |
P010400 | Mass or Volume Air Flow Circuit Intermittent |
P010500 | Manifolt Absolut Pressure/Barometic Pressure Circuit |
P010600 | Manifold Abs.Pressure or Bar.Pressure Range/Performance |
P010700 | Manifold Abs.Pressure or Bar.Pressure Low Input |
P010800 | Manifold Abs.Pressure or Bar.Pressure High Input |
P010A00 | Mass or Volume Air Flow "B" Circuit |
P010B00 | Mass or Volume Air Flow "B" Circuit Range/Performance |
P010C00 | Mass or Volume Air Flow "B" Circuit Low Input |
P010D00 | Mass or Volume Air Flow "B" Circuit High Input |
P010E00 | Mass or Volume Air Flow "B" Circuit Intermittent/Erratic |
P010F00 | Mass or Volume Air Flow Sensor A/B Correlation |
P011000 | Intake Air Temperature Sensor 1 Circuit |
P011100 | Intake Air Temp.Circ. Range/Performance |
P011200 | Intake Air Temp.Circ. Low Input |
P011300 | Intake Air Temp.Circ. High Input |
P011400 | Intake Air Temp.Circ. Intermittend |
P011500 | Engine Coolant Temperature Sensor 1 Circuit |
P011600 | Engine Coolant Temperature Sensor 1 Circuit Range/Performance |
P011700 | Engine Coolant Temperature Sensor 1 Circuit Low |
P011800 | Engine Coolant Temperature Sensor 1 Circuit High |
P011A00 | Engine Coolant Temperature Sensor 1/2 Correlation |
P012000 | Throttle/Pedal Pos.Sensor A Circ. Malfunction |
P012100 | Throttle/Pedal Pos.Sensor A Circ. Range/Performance |
P012200 | Throttle/Pedal Pos.Sensor A Circ. Low Input |
P012300 | Throttle/Pedal Pos.Sensor A Circ. High Input |
P012500 | Insufficient Coolant Temp.for Closed Loop Fuel Control |
P012800 | Coolant Termostat ( Coolant Temperature Below Thermostat Regulating Temperature) |
P012A00 | Turbocharger/Supercharger Inlet Pressure Sensor Circuit |
P012B00 | Turbocharger/Supercharger Inlet Pressure Sensor Circuit Range/Performance |
P012C00 | Turbocharger/Supercharger Inlet Pressure Sensor Circuit Low |
P012D00 | Turbocharger/Supercharger Inlet Pressure Sensor Circuit High |
P013000 | O2 Sensor Circ.,Bank1-Sensor1 Malfunction |
P013100 | O2 Sensor Circ.,Bank1-Sensor1 Low Voltage |
P013200 | O2 Sensor Circ.,Bank1-Sensor1 High Voltage |
P013300 | O2 Sensor Circ.,Bank1-Sensor1 Slow Response |
P013400 | O2 Sensor Circ.,Bank1-Sensor1 No Activity Detected |
P013500 | O2 Sensor Heater Circ.,Bank1-Sensor1 Malfunction |
P013600 | O2 Sensor Circ.,Bank1-Sensor2 Malfunction |
P013700 | O2 Sensor Circ.,Bank1-Sensor2 Low Voltage |
P013800 | O2 Sensor Circ.,Bank1-Sensor2 High Voltage |
P013900 | O2 Sensor Circ.,Bank1-Sensor2 Slow Response |
P014000 | O2 Sensor Circ.,Bank1-Sensor2 No Activity Detected |
P014100 | O2 Sensor Heater Circ.,Bank1-Sensor2 Malfunction |
P014200 | O2 Sensor Circ.,Bank1-Sensor3 |
P014300 | O2 Sensor Circ.,Bank1-Sensor3 Low Voltage |
P014400 | O2 Sensor Circ.,Bank1-Sensor3 High Voltage |
P014500 | O2 Sensor Circ.,Bank1-Sensor3 Slow Response |
P014600 | O2 Sensor Circ.,Bank1-Sensor3 No Activity Detected |
P014700 | O2 Sensor Heater Circ.,Bank1-Sensor3 |
P014800 | Fuel Delivery Error |
P014900 | Fuel Timing Error |
P015000 | O2 Sensor Circ.,Bank2-Sensor1 Malfunction |
P015100 | O2 Sensor Circ.,Bank2-Sensor1 Low Voltage |
P015200 | O2 Sensor Circ.,Bank2-Sensor1 High Voltage |
P015300 | O2 Sensor Circ.,Bank2-Sensor1 Slow Response |
P015400 | O2 Sensor Circ.,Bank2-Sensor1 No Activity Detected |
P015500 | O2 Sensor Heater Circ.,Bank2-Sensor1 Malfunction |
P015600 | O2 Sensor Circ.,Bank2-Sensor2 Malfunction |
P015700 | O2 Sensor Circ.,Bank2-Sensor2 Low Voltage |
P015800 | O2 Sensor Circ.,Bank2-Sensor2 High Voltage |
P015900 | O2 Sensor Circ.,Bank2-Sensor2 Slow Response |
P016000 | O2 Sensor Circ.,Bank2-Sensor2 No Activity Detected |
P016100 | O2 Sensor Heater Circ.,Bank2-Sensor2 Malfunction |
P016200 | O2 Sensor Circ.,Bank2-Sensor3 Malfunction |
P016300 | O2 Sensor Circ.,Bank2-Sensor3 Low Voltage |
P016400 | O2 Sensor Circ.,Bank2-Sensor3 High Voltage |
P016500 | O2 Sensor Circ.,Bank2-Sensor3 Slow Response |
P016600 | O2 Sensor Circ.,Bank2-Sensor3 No Activity Detected |
P016700 | O2 Sensor Heater Circ.,Bank2-Sensor3 Malfunction |
P016900 | Incorrect Fuel Composition |
P017000 | Fuel Trim,Bank1 Malfunction |
P017100 | Fuel Trim,Bank1 System too Lean |
P017200 | Fuel Trim,Bank1 System too Rich |
P017300 | Fuel Trim,Bank2 Malfunction |
P017400 | Fuel Trim,Bank2 System too Lean |
P017500 | Fuel Trim,Bank2 System too Rich |
P017700 | Fuel Composition Sensor Circuit Range/Performance |
P017800 | Fuel Composition Sensor Circuit Low |
P017900 | Fuel Composition Sensor Circuit High |
P018100 | Fuel Temperature Sensor A Circuit Range/Performance |
P018200 | Fuel Temperature Sensor A Circuit Low Input |
P018300 | Fuel Temperature Sensor A Circuit High Input |
P018600 | Fuel Temperature Sensor B Circuit Range/Performance |
P018700 | Fuel Temperature Sensor B Circuit Low |
P018800 | Fuel Temperature Sensor B Circuit High |
P018A00 | Fuel Pressure Sensor "B" Circuit |
P018B00 | Fuel Pressure Sensor "B" Circuit Range/Performance |
P018C00 | Fuel Pressure Sensor "B" Circuit Low |
P019000 | Fuel Rail Pressure Sensor "A" Circuit |
P019100 | Fuel Rail Pressure Sensor "A" Circuit Range/Performance |
P019200 | Fuel Rail Pressure Sensor "A" Circuit Low Input |
P019300 | Fuel Rail Pressure Sensor "A" Circuit High Input |
P019400 | Fuel Rail Pressure Sensor "A" Circuit intermittent |
P019500 | Engine Oil Temperature Sensor Circuit |
P019600 | Engine Oil Temperature Sensor Circuit range/performance |
P019700 | Engine Oil Temperature Sensor Circuit low |
P019800 | Engine Oil Temperature Sensor Circuit high |
P019900 | Engine Oil Temperature Sensor Circuit Intermittent/Erratic |
P020000 | Injector Circuit open |
P020100 | Cylinder 1- Injector Circuit |
P020200 | Cylinder 2- Injector Circuit |
P020300 | Cylinder 3- Injector Circuit |
P020400 | Cylinder 4- Injector Circuit |
P020500 | Cylinder 5- Injector Circuit |
P020600 | Cylinder 6- Injector Circuit |
P020700 | Cylinder 7- Injector Circuit |
P020800 | Cylinder 8- Injector Circuit |
P020900 | Cylinder 9- Injector Circuit |
P020A00 | Cylinder 1 Injection Timing |
P020B00 | Cylinder 2 Injection Timing |
P020C00 | Cylinder 3 Injection Timing |
P020D00 | Cylinder 4 Injection Timing |
P020E00 | Cylinder 5 Injection Timing |
P020F00 | Cylinder 6 Injection Timing |
P021000 | Cylinder 10- Injector Circuit |
P021100 | Cylinder 11- Injector Circuit |
P021200 | Cylinder 12- Injector Circuit |
P021500 | Engine Shutoff Solenoid |
P021600 | Injection Timing Control Circuit |
P021800 | Transmission Fluid Over Temperature Condition |
P021900 | Engine Overspeed Condition |
P021A00 | Cylinder 7 Injection Timing |
P021B00 | Cylinder 8 Injection Timing |
P021C00 | Cylinder 9 Injection Timing |
P021D00 | Cylinder 10 Injection Timing |
P021E00 | Cylinder 11 Injection Timing |
P021F00 | Cylinder 12 Injection Timing |
P022100 | Throttle/Pedal Position Sensor/Switch B Range/Performance |
P022200 | Throttle/Pedal Position Sensor/Switch B Low Input |
P022300 | Throttle/Pedal Position Sensor/Switch B High Input |
P022500 | Throttle/Pedal Position Sensor/Switch C |
P022600 | Throttle/Pedal Position Sensor/Switch C Circuit Range/Performance |
P022700 | Throttle/Pedal Position Sensor/Switch C Circuit Low Input |
P022800 | Throttle/Pedal Position Sensor/Switch C Circuit High Input |
P022A00 | Charge Air Cooler Bypass Control "A" Circuit /Open |
P022B00 | Charge Air Cooler Bypass Control "A" Circuit Low |
P022C00 | Charge Air Cooler Bypass Control "A" Circuit High |
P023000 | Fuel Pump Primary Circuit |
P023400 | Turbo/Super Charger Overboost Condition |
P023500 | Turbo/Super Charger Boost Sensor A Circ. |
P023600 | Turbocharger Boost Sensor (A) Circ. Range/Performance |
P023700 | Turbocharger Boost Sensor (A) Circ. Low Input |
P023800 | Turbocharger Boost Sensor (A) Circ. High Input |
P023F00 | Fuel Pump Secondary Circuit/Open |
P024000 | Turbo/Super Charger Boost Sensor "B" Circuit Range/Performance |
P024100 | Turbo/Super Charger Boost Sensor "B" Circuit Low |
P024200 | Turbo/Super Charger Boost Sensor "B" Circuit High |
P024300 | Turbo/Super Charger Wastegate Solonoid A |
P024500 | Turbo/Super Charger Wasteg.Solonoid A Low |
P024600 | Turbo/Sup.Charger Wasteg.Solonoid A High |
P024900 | Turbo/Super Charger Wastegate Solenoid "B" Low |
P024A00 | Charge Air Cooler Bypass Control "A" Range/Performance |
P024B00 | Charge Air Cooler Bypass Control "A" Stuck |
P025000 | Turbo/Super Charger Wastegate Solenoid "B" High |
P025100 | Injection Pump Fuel Metering Control "A" (Cam/Rotor/Injector) |
P025200 | Injection Pump Fuel Metering Control A Range/Performance (Cam/Rotor/Injector) |
P025A00 | Fuel Pump Module Control Circuit/Open |
P025B00 | Fuel Pump Module Control Circuit Range/Performance |
P025C00 | Fuel Pump Module Control Circuit Low |
P025D00 | Fuel Pump Module Control Circuit High |
P026100 | Cylinder 1- Injector Circuit Low |
P026200 | Cylinder 1- Injector Circuit High |
P026300 | Cylinder 1 Contribution/Balance |
P026400 | Cylinder 2- Injector Circuit Low |
P026500 | Cylinder 2- Injector Circuit High |
P026600 | Cylinder 2 Contribution/Balance |
P026700 | Cylinder 3- Injector Circuit Low |
P026800 | Cylinder 3- Injector Circuit High |
P026900 | Cylinder 3 Contribution/Balance |
P027000 | Cylinder 4- Injector Circuit Low |
P027100 | Cylinder 4- Injector Circuit High |
P027200 | Cylinder 4 Contribution/Balance |
P027300 | Cylinder 5- Injector Circuit Low |
P027400 | Cylinder 5- Injector Circuit High |
P027500 | Cylinder 5 Contribution/Balance |
P027600 | Cylinder 6- Injector Circuit Low |
P027700 | Cylinder 6- Injector Circuit High |
P027800 | Cylinder 6 Contribution/Balance |
P027900 | Cylinder 7- Injector Circuit Low |
P028000 | Cylinder 7- Injector Circuit High |
P028100 | Cylinder 7 Contribution/Balance |
P028200 | Cylinder 8- Injector Circuit Low |
P028300 | Cylinder 8- Injector Circuit High |
P028400 | Cylinder 8 Contribution/Balance |
P028500 | Cylinder 9- Injector Circuit Low |
P028600 | Cylinder 9- Injector Circuit High |
P028700 | Cylinder 9 Contribution/Balance |
P028800 | Cylinder 10- Injector Circuit Low |
P028900 | Cylinder 10- Injector Circuit High |
P029000 | Cylinder 10 Contribution/Balance |
P029100 | Cylinder 11- Injector Circuit Low |
P029200 | Cylinder 11- Injector Circuit High |
P029300 | Cylinder 11 Contribution/Balance |
P029400 | Cylinder 12- Injector Circuit Low |
P029500 | Cylinder 12- Injector Circuit High |
P029600 | Cylinder 12 Contribution/Balance |
P029900 | Turbo/Super Charger Underboost |
P02CA00 | Turbocharger/Supercharger "B" Overboost Condition |
P02CB00 | Turbocharger/Supercharger "B" Underboost Condition |
P02CD00 | Cylinder 1 Fuel Injector Offset Learning At Max Limit |
P02CF00 | Cylinder 2 Fuel Injector Offset Learning At Max Limit |
P02D100 | Cylinder 3 Fuel Injector Offset Learning At Max Limit |
P02D300 | Cylinder 4 Fuel Injector Offset Learning At Max Limit |
P030000 | Random/Multiple Cylinder Misfire Detected |
P030100 | Cyl.1 Misfire Detected |
P030200 | Cyl.2 Misfire Detected |
P030300 | Cyl.3 Misfire Detected |
P030400 | Cyl.4 Misfire Detected |
P030500 | Cyl.5 Misfire Detected |
P030600 | Cyl.6 Misfire Detected |
P030700 | Cyl.7 Misfire Detected |
P030800 | Cyl.8 Misfire Detected |
P030900 | Cyl.9 Misfire Detected |
P031000 | Cyl.10 Misfire Detected |
P031100 | Cyl.11 Misfire Detected |
P031200 | Cyl.12 Misfire Detected |
P031300 | Misfire Detected with Low Fuel |
P031400 | Single Cylinder Misfire |
P031800 | Rough Road Sensor "A" Signal Circuit |
P032100 | Ign./Distributor Eng.Speed Inp.Circ. Range/Performance |
P032200 | Ign./Distributor Eng.Speed Inp.Circ. No Signal |
P032400 | Knock Control System Error |
P032500 | Knock Sensor 1 Circuit Malfunktion |
P032600 | Knock Sensor 1 Circuit Range/Performance |
P032700 | Knock Sensor 1 Circ. Low Input |
P032800 | Knock Sensor 1 Circ. High Input |
P033000 | Knock Sensor 2 Circuit |
P033100 | Knock Sensor 2 Circuit Range/Performance |
P033200 | Knock Sensor 2 Circ. Low Input |
P033300 | Knock Sensor 2 Circ. High Input |
P033500 | Crankshaft Position Sensor A Circuit |
P033600 | Crankshaft Position Sensor A Circuit Range/Performance |
P033700 | Crankshaft Pos.Sensor (A) Circ. Low Input |
P033900 | Crankshaft Position Sensor "A" Circuit Intermittent |
P034000 | Camshaft Position Sensor Circuit |
P034100 | Camshaft Pos.Sensor Circ. Range/Performance |
P034200 | Camshaft Pos.Sensor Circ. Low Input |
P034300 | Camshaft Pos.Sensor Circ. High Input |
P034500 | Camshaft Position Sensor Circuit Bank2 |
P034600 | Camshaft Pos.Sensor Circ. (Bank2) Range/Performance |
P034700 | Camshaft Pos.Sensor "A" Circ. (Bank2) Low |
P034800 | Camshaft Pos.Sensor "A" Circ. (Bank2) High |
P035100 | Ignition Coil A Primary/secondary Circuit |
P035200 | Ignition Coil B Primary/secondary Circuit |
P035300 | Ignition Coil C Primary/secondary Circuit |
P035400 | Ignition Coil D Primary/secondary Circuit |
P035500 | Ignition Coil E Primary/secondary Circuit |
P035600 | Ignition Coil F Primary/secondary Circuit |
P035700 | Ignition Coil G Primary/secondary Circuit |
P035800 | Ignition Coil H Primary/secondary Circuit |
P035900 | Ignition Coil I Primary/secondary Circuit |
P036000 | Ignition Coil J Primary/secondary Circuit |
P036100 | Ignition Coil K Primary/secondary Circuit |
P036200 | Ignition Coil L Primary/secondary Circuit |
P036300 | Misfire Detected - Fueling Disabled |
P036500 | Camshaft Position Sensor "B" Circuit (Bank 1) |
P036600 | Camshaft Pos.Sensor "B" Circ. (Bank 1) Range/Performance |
P036700 | Camshaft Pos.Sensor "B" Circ. (Bank 1) Low Input |
P036800 | Camshaft Pos.Sensor "B" Circ. (Bank 1) High Input |
P038000 | Glow Plug/Heater Circuit "A" |
P038100 | Glow Plug/Heater Indicator Circuit |
P038300 | Glow Plug Control Module Control Circuit Low |
P038400 | Glow Plug Control Module Control Circuit High |
P039000 | Camshaft Position Sensor "B" Circuit (Bank 2) |
P039100 | Camshaft Pos.Sensor "B" Circ. (Bank 2) Range/Performance |
P039200 | Camshaft Pos.Sensor "B" Circ. (Bank 2) Low Input |
P039300 | Camshaft Pos.Sensor "B" Circ. (Bank 2) High Input |
P039B00 | Cylinder 1 Pressure Too High |
P03A500 | Cylinder 2 Pressure Too High |
P03AF00 | Cylinder 3 Pressure Too High |
P03B900 | Cylinder 4 Pressure Too High |
P03C300 | Cylinder 5 Pressure Too High |
P03CD00 | Cylinder 6 Pressure Too High |
P040000 | Exhaust Gas Recirc."A" Flow |
P040100 | Exhaust Gas Recirc.Flow Insufficient Detected |
P040200 | Exhaust Gas Recirc.Flow Excessive Detected |
P040300 | Exhaust Gas Recirculation Circuit |
P040400 | Exhaust Gas Recirculation Circuit Range/Performance |
P040500 | Exhaust Gas Recirculat.Sensor A Circuit Low |
P040600 | Exhaust Gas Recirculat.Sensor A Circuit High |
P040700 | Exhaust Gas Recirculat.Sensor B Circuit Low |
P040800 | Exhaust Gas Recirculat.Sensor B Circuit High |
P040B00 | Exhaust Gas Recirculation Temperature Sensor "A" Circuit Range/Performance |
P040C00 | Exhaust Gas Recirculation Temperature Sensor "A" Circuit Low |
P040D00 | Exhaust Gas Recirculation Temperature Sensor "A" Circuit High |
P041000 | Sec.Air Inj.Sys. Malfunction |
P041100 | Sec.Air Inj.Sys. Incorrect Flow Detected |
P041200 | Sec.Air Inj.Sys.Switching Valve A Circ. Malfunction |
P041300 | Sec.Air Inj.Sys.Switching Valve A Circ. Open |
P041400 | Sec.Air Inj.Sys.Switching Valve A Circ. Shorted |
P041500 | Sec.Air Inj.Sys.Switching Valve B Circ. Malfunction |
P041600 | Sec.Air Inj.Sys.Switching Valve B Circ. Open |
P041700 | Sec.Air Inj.Sys.Switching Valve B Circ. Shorted |
P041800 | Sec. Air Injection System Relay A Circuit |
P041900 | Sec. Air Injection System Relay B Circuit |
P042000 | Catalyst System,Bank1 Efficiency Below Threshold |
P042100 | Warm Up Catalyst, Bank1 Efficiency Below Threshold |
P042200 | Main Catalyst,Bank1 Efficiency Below Threshold |
P042500 | Catalyst Temperature Sensor Circuit |
P042600 | Catalyst Temperature Sensor Circuit Range/Performance |
P042700 | Catalyst Temperature Sensor Bank1 Low Input |
P042800 | Catalyst Temperature Sensor Bank1 High Input |
P043000 | Catalyst System, Bank2 Efficiency Below Threshold |
P043100 | Warm Up Catalyst, Bank2 Efficiency Below Threshold |
P043200 | Main Catalyst,Bank2 Efficiency Below Threshold |
P043600 | Catalyst Temperature Sensor Bank2 Range/performance |
P043700 | Catalyst Temperature Sensor Bank2 Low Input |
P043800 | Catalyst Temperature Sensor Bank2 High Input |
P044000 | EVAP Emission Contr.Sys. Malfunction |
P044100 | EVAP Emission Contr.Sys.Incorrect Purge Flow |
P044200 | EVAP Emission Contr.Sys.(Small Leak) Leak Detected |
P044300 | Evaporativ Emiss.System Purge Control Valve Circ. |
P044400 | Evaporativ Emiss.System Purge Control Valve Circ. Open |
P044500 | Evaporativ Emiss.System Purge Control Valve Circ. Shorted |
P044900 | Evaporativ Emiss.System Vent Valve/Solenoid Circ. |
P045000 | Evaporative Emission System Pressure Sensor/Switch |
P045100 | Evaporative Emission System Pressure Sensor/Switch Range/Performance |
P045200 | EVAP Emission Contr.Sys.Press.Sensor Low Input |
P045300 | EVAP Emission Contr.Sys.Press.Sensor High Input |
P045500 | EVAP Emission Contr.Sys.(Gross Leak) Leak Detected |
P045600 | EVAP Emission Contr. Sys. (very small Leak) Leak Detected |
P045800 | Evaporative Emission System Purge Control Valve Circuit Low |
P045900 | Evaporative Emission System Purge Control Valve Circuit High |
P045A00 | Exhaust Gas Recirculation "B" Control Circuit |
P045B00 | Exhaust Gas Recirculation "B" Control Circuit Range/Performance |
P045C00 | Exhaust Gas Recirculation "B" Control Circuit Low |
P045D00 | Exhaust Gas Recirculation "B" Control Circuit High |
P045E00 | Exhaust Gas Recirculation "B" Control Stuck Open |
P045F00 | Exhaust Gas Recirculation "B" Control Stuck Closed |
P046100 | Fuel Level Sensor Circ. Range/Performance |
P046200 | Fuel Lever Sensor Circuit Low Input |
P046300 | Fuel Lever Sensor Circuit High Input |
P046C00 | Exhaust Gas Recirculation Sensor "A" Circuit Range/Performance |
P046E00 | Exhaust Gas Recirculation Sensor "B" Circuit Range/Performance |
P047000 | Exhaust Pressure Sensor "A" |
P047100 | Exhaust Pressure Sensor "A" Range/Performance |
P047200 | Exhaust Pressure Sensor "A"Low |
P047300 | Exhaust Pressure Sensor "A" High |
P047500 | Exhaust Pressure Control Valve "A" |
P047600 | Exhaust Pressure Control Valve "A" Range/Performance |
P047700 | Exhaust Pressure Control Valve "A" Low |
P047800 | Exhaust Pressure Control Valve "A" High |
P047A00 | Exhaust Pressure Sensor "B" |
P047B00 | Exhaust Pressure Sensor "B" Range/Performance |
P047C00 | Exhaust Pressure Sensor "B" Low |
P047D00 | Exhaust Pressure Sensor "B" High |
P047F00 | Exhaust Pressure Control Valve "A" Stuck Open |
P048000 | Cooling Fan 1 Control Circuit |
P048100 | Cooling Fan 2 Control Circuit |
P048600 | Exhaust Gas Recirculation Sensor "B" Circuit |
P048900 | Exhaust Gas Recirculation Control Circuit Low |
P048A00 | Exhaust Pressure Control Valve "A" Stuck Closed |
P048B00 | Exhaust Pressure Control Valve Position Sensor/Switch Circuit |
P048C00 | Exhaust Pressure Control Valve Pos. Sensor/Switch Circuit Range/Performance |
P048E00 | Exhaust Pressure Control Valve Pos. Sensor/Switch Circuit High |
P049000 | Exhaust Gas Recirculation Control Circuit High |
P049100 | Secondary Air Injection System (Bank 1) insufficient flow |
P049200 | Secondary Air Injection System (Bank 2) |
P049800 | Evaporative Emission System Vent Valve Control Circuit Low |
P049900 | Evaporative Emission System Vent Valve Control Circuit High |
P049A00 | Exhaust Gas Recirc."B" Flow |
P049D00 | Exhaust Gas Recirculation "A" Control Position Exceeded Learning Limit |
P049E00 | Exhaust Gas Recirculation "B" Control Position Exceeded Learning Limit |
P050100 | Vehicle Speed Sensor "A" Range/Performance |
P050200 | Vehicle Speed Sensor "A" Circuit Low Input |
P050300 | Vehicle Speed Sensor "A" Intermittend/Erratic/High |
P050500 | Idle Control System |
P050600 | Idle Control System RPM Lower than Expected |
P050700 | Idle Control System RPM Higher than Expected |
P050A00 | Cold Start Idle Air Control System Performance |
P050B00 | Cold Start Ignition Timing Performance |
P051000 | Closed Throttle Pos.Switch Malfunction |
P051300 | Incorrect Immobilizer Key |
P053100 | A/C Refrigerant Pressure Sensor Circuit Range/Performance |
P053200 | A/C Refrigerant Pressure Sensor Circuit low Input |
P053300 | A/C Refrigerant Pressure Sensor Circuit high Input |
P053700 | A/C Evaporator Temperature Sensor Circuit Low |
P053800 | A/C Evaporator Temperature Sensor Circuit High |
P053A00 | Positive Crankcase Ventilation Heater Control Circuit /Open |
P053B00 | Positive Crankcase Ventilation Heater Control Circuit Low |
P053C00 | Positive Crankcase Ventilation Heater Control Circuit High |
P054400 | Exhaust Gas Temperatur Sensor Circuit - Bank 1 |
P054500 | Exhaust Gas Temperatur Sensor Circuit - Bank 1 Low |
P054600 | Exhaust Gas Temperatur Sensor Circuit - Bank 1 High |
P054700 | Exhaust Gas Temperatur Sensor Circuit - Bank 2 |
P054800 | Exhaust Gas Temperatur Sensor Circuit - Bank 2 Low |
P054900 | Exhaust Gas Temperatur Sensor Circuit - Bank 2 High |
P055000 | Power Steering Pressure Circuit |
P055100 | Power Steering Pressure Sensor Circuit Range/Performance |
P056000 | System Voltage Malfunction |
P056100 | System Voltage Unstable |
P056200 | System Voltage Low Voltage |
P056300 | System Voltage High Voltage |
P056800 | Cruise Control Set Signal |
P057100 | Cruise/Brake Switch (A) Circ. Malfunction |
P059700 | Thermostat Heater Control Circuit Open |
P059800 | Thermostat Heater Control Circuit Low |
P059900 | Thermostat Heater Control Circuit High |
P060000 | Serial Link Communication |
P060100 | Internal Contr.Module Memory Check Sum Error |
P060200 | Control Modul Programming Error |
P060300 | Internal Contr.Module (KAM) Error |
P060400 | Internal Contr.Module Random Access Memory (RAM) Error |
P060500 | Internal Contr.Module ROM Test Error |
P060600 | ECM/PCM Processor |
P060700 | Control Module Performance |
P060800 | Control Module VSS Output "A" |
P060900 | Control Module VSS Output "B" |
P060A00 | Internal Control Module Monitoring Processor Performance |
P061000 | Control Module Vehicle Options Error |
P061300 | TCM Processor |
P061400 | ECM/TCM Incompatible |
P061500 | Starter Relay Circuit |
P061600 | Starter Relay Circuit Low |
P061700 | Starter Relay Circuit High |
P062700 | Fuel Pump "A" Control Circuit/Open |
P062800 | Fuel Pump "A" Control Circuit Low |
P062900 | Fuel Pump "A" Control Circuit High |
P062B00 | Internal Control Module Fuel Injector Control Performance |
P062F00 | Internal Control Module EEPROM Error |
P063400 | PCM/ECM/TCM Internal Temperature Too High |
P063800 | Throttle Actuator Control (Bank1) Range/Performance |
P063900 | Throttle Actuator Control (Bank2) Range/Performance |
P064100 | Sensor Reference Voltage "A" Circuit Open |
P064200 | Sensor Reference Voltage "A" Circuit Low |
P064300 | Sensor Reference Voltage "A" Circuit High |
P064500 | AC clutch relais circuit |
P064C00 | Glow Plug Control Module |
P065000 | Malfunction Indicator Lamp Control Circ. |
P065100 | Sensor Reference Voltage "B" Circuit Open |
P065200 | Sensor Reference Voltage "B" Circuit Low |
P065300 | Sensor Reference Voltage "B" Circuit High |
P065400 | Engine RPM Output Circuit |
P065600 | Fuel Level Output Circuit |
P065700 | Actuator Supply Voltage "A" Circuit/Open |
P065800 | Actuator Supply Voltage "A" Circuit Low |
P065900 | Actuator Supply Voltage "A" Circuit High |
P066000 | Intake Manifold Tuning Control Circuit - Bank1 |
P066100 | Intake Manifold Tuning Control Circuit - Bank1 Low |
P066200 | Intake Manifold Tuning Control Circuit - Bank1 High |
P066600 | PCM/ECM/TCM Internal Temperature Sensor "A" Circuit |
P066700 | PCM/ECM/TCM Internal Temperature Sensor "A" Range/Performance |
P066800 | PCM/ECM/TCM Internal Temperature Sensor "A" Circuit Low |
P066900 | PCM/ECM/TCM Internal Temperature Sensor "A" Circuit High |
P066A00 | Cylinder 1 Glow Plug Control Circuit Low |
P066C00 | Cylinder 2 Glow Plug Control Circuit Low |
P066E00 | Cylinder 3 Glow Plug Control Circuit Low |
P067000 | Glow Plug Module Control Circuit |
P067100 | Cylinder 1 Glow Plug Circuit |
P067200 | Cylinder 2 Glow Plug Circuit |
P067300 | Cylinder 3 Glow Plug Circuit |
P067400 | Cylinder 4 Glow Plug Circuit |
P067500 | Cylinder 5 Glow Plug Circuit |
P067600 | Cylinder 6 Glow Plug Circuit |
P067700 | Cylinder 7 Glow Plug Circuit |
P067800 | Cylinder 8 Glow Plug Circuit |
P067900 | Cylinder 9 Glow Plug Circuit |
P067A00 | Cylinder 4 Glow Plug Control Circuit Low |
P067C00 | Cylinder 5 Glow Plug Control Circuit Low |
P067E00 | Cylinder 6 Glow Plug Control Circuit Low |
P068000 | Cylinder 10 Glow Plug Circuit |
P068100 | Cylinder 11 Glow Plug Circuit |
P068200 | Cylinder 12 Glow Plug Circuit |
P068400 | Glow Plug Control Module to PCM Comm.Circuit Range/Performance |
P068500 | EMC/PCM Power Relay Control Circuit Open |
P068600 | EMC/PCM Power Relay Control Circuit Low |
P068700 | EMC/PCM Power Relay Control Circuit High |
P068800 | EMC/PCM Power Relay Sense Circuit Open |
P068A00 | ECM/PCM Power Relay De-Energized Performance - Too Early |
P068B00 | ECM/PCM Power Relay De-Energized Performance - Too Late |
P068C00 | Cylinder 7 Glow Plug Control Circuit Low |
P068E00 | Cylinder 8 Glow Plug Control Circuit Low |
P069100 | Cooling Fan 1 Control Circuit Low |
P069200 | Cooling Fan 1 Control Circuit High |
P069300 | Cooling Fan 2 Control Circuit Low |
P069400 | Cooling Fan 2 Control Circuit High |
P069700 | Sensor Reference Voltage "C" Circuit Open |
P069800 | Sensor Reference Voltage "C" Circuit Low |
P069900 | Sensor Reference Voltage "C" Circuit High |
P069A00 | Cylinder 9 Glow Plug Control Circuit Low |
P069C00 | Cylinder 10 Glow Plug Control Circuit Low |
P06A300 | Sensor Reference Voltage "D" Circuit/Open |
P06B900 | Cylinder 1 Glow Plug Circuit Range/Performance |
P06BA00 | Cylinder 2 Glow Plug Circuit Range/Performance |
P06BB00 | Cylinder 3 Glow Plug Circuit Range/Performance |
P06BC00 | Cylinder 4 Glow Plug Circuit Range/Performance |
P06BD00 | Cylinder 5 Glow Plug Circuit Range/Performance |
P06BE00 | Cylinder 6 Glow Plug Circuit Range/Performance |
P06BF00 | Cylinder 7 Glow Plug Circuit Range/Performance |
P06C000 | Cylinder 8 Glow Plug Circuit Range/Performance |
P06C100 | Cylinder 9 Glow Plug Circuit Range/Performance |
P06C200 | Cylinder 10 Glow Plug Circuit Range/Performance |
P06C300 | Cylinder 11 Glow Plug Circuit Range/Performance |
P06C400 | Cylinder 12 Glow Plug Circuit Range/Performance |
P06C500 | Cylinder 1 Glow Plug Incorrect |
P06C600 | Cylinder 2 Glow Plug Incorrect |
P06C700 | Cylinder 3 Glow Plug Incorrect |
P06C800 | Cylinder 4 Glow Plug Incorrect |
P06C900 | Cylinder 5 Glow Plug Incorrect |
P06CA00 | Cylinder 6 Glow Plug Incorrect |
P06CB00 | Cylinder 7 Glow Plug Incorrect |
P06CC00 | Cylinder 8 Glow Plug Incorrect |
P06CD00 | Cylinder 9 Glow Plug Incorrect |
P06CE00 | Cylinder 10 Glow Plug Incorrect |
P06CF00 | Cylinder 11 Glow Plug Incorrect |
P06D000 | Cylinder 12 Glow Plug Incorrect |
P06D200 | Sensor Reference Voltage "E" Circuit/Open |
P06E000 | Cylinder 11 Glow Plug Control Circuit Low |
P06E200 | Cylinder 12 Glow Plug Control Circuit Low |
P070000 | Transm.Contr.System Malfunction |
P070100 | Transm.Contr.System Range/Performance |
P070200 | Transm.Contr.System Electrical |
P070300 | Torque Converter/Brake Switch B Circ. Malfunction |
P070400 | Clutch Switch Input Circuit |
P070500 | Transm.Range Sensor "A" Circ.(PRNDL Inp.) Malfunction |
P070600 | Transm.Range Sensor "A" Circ. Range/Performance |
P070700 | Transm.Range Sensor "A" Circ. Low Input |
P070800 | Transm.Range Sensor "A" Circ. High Input |
P071000 | Transm.Fluid Temp.Sensor Circ. Malfunction |
P071100 | Transm.Fluid Temp.Sensor Circ. Range/Performance |
P071200 | Transm.Fluid Temp.Sensor Circ. Low Input |
P071300 | Transm.Fluid Temp.Sensor Circ. High Input |
P071400 | Transm.Fluid Temp.Sensor Circ. Intermittent |
P071500 | Input Turbine/Speed Sensor "A" Circ. |
P071600 | Input Turbine/Speed Sensor "A"Circ. Range/Performance |
P071700 | Input Turbine/Speed Sensor "A"Circ. No Signal |
P072000 | Output Speed Sensor Circ. Malfunction |
P072100 | Output Speed Sensor Circ. Range/Performance |
P072200 | Output Speed Sensor Circ. No Signal |
P072500 | Engine Speed Input Ciruit |
P072600 | Engine Speed Inp.Circ. Range/Performance |
P072700 | Engine Speed Inp.Circ. No Signal |
P072900 | Gear 6 Incorrect Ratio |
P072B00 | Stuck in Reverse |
P072C00 | Stuck in Gear 1 |
P072D00 | Stuck in Gear 2 |
P072E00 | Stuck in Gear 3 |
P072F00 | Stuck in Gear 4 |
P073000 | Gear Incorrect Ratio |
P073100 | Gear 1 Incorrect Ratio |
P073200 | Gear 2 Incorrect Ratio |
P073300 | Gear 3 Incorrect Ratio |
P073400 | Gear 4 Incorrect Ratio |
P073500 | Gear 5 Incorrect Ratio |
P073600 | Reverse Incorrect Ratio |
P073A00 | Stuck in Gear 5 |
P073B00 | Stuck in Gear 6 |
P073C00 | Stuck in Gear 7 |
P073E00 | Unable to Engage Reverse |
P073F00 | Unable to Engage Gear 1 |
P074000 | Torque Converter Clutch Circ. Malfunction |
P074100 | Torque Converter Clutch Circ. Performance or Stuck Off |
P074300 | Torque Converter Clutch Circ. Electrical |
P074600 | Pressure Contr.Solenoid A Performance or Stuck Off |
P074700 | Pressure Contr.Solenoid A Stuck On |
P074800 | Pressure Contr.Solenoid A Electrical |
P074900 | Pressure Contr.Solenoid A Intermittent |
P074A00 | Unable to Engage Gear 2 |
P074B00 | Unable to Engage Gear 3 |
P074C00 | Unable to Engage Gear 4 |
P074D00 | Unable to Engage Gear 5 |
P074E00 | Unable to Engage Gear 6 |
P074F00 | Unable to Engage Gear 7 |
P075000 | Shift Solenoid A Malfunction |
P075100 | Shift Solenoid A Performance or Stuck Off |
P075200 | Shift Solenoid A Stuck On |
P075300 | Shift Solenoid A Electrical |
P075400 | Shift Solenoid "A" Intermittent |
P075600 | Shift Solenoid B Performance or Stuck Off |
P075700 | Shift Solenoid B Stuck On |
P075800 | Shift Solenoid B Electrical |
P076100 | Shift Solenoid C Performance or Stuck Off |
P076200 | Shift Solenoid C Stuck On |
P076300 | Shift Solenoid C Electrical |
P076400 | Shift Solenoid "C" Intermittent |
P076600 | Shift Solenoid D Performance or Stuck Off |
P076800 | Shift Solenoid D Electrical |
P077100 | Shift Solenoid E Performance or Stuck Off |
P077300 | Shift Solenoid E Electrical |
P077600 | Pressure Contr.Solenoid B Performance or Stuck Off |
P077700 | Pressure Contr.Solenoid B Stuck On |
P077800 | Pressure Contr.Solenoid B Electrical |
P077900 | Pressure Contr.Solenoid B Intermittent |
P078000 | Shift |
P078100 | 1-2 Shift |
P078200 | 2-3 Shift |
P078300 | 3-4 Shift |
P078400 | 4-5 Shift |
P078500 | Shift/Timing Solenoid |
P079000 | Normal/Performance Switch Circ. Malfunction |
P079100 | Intermediate Shaft Speed Sensor "A" Circuit |
P079600 | Pressure Contr.Solenoid C Performance or Stuck Off |
P079700 | Pressure Contr.Solenoid C Stuck On |
P079800 | Pressure Contr.Solenoid C Electrical |
P079900 | Pressure Contr.Solenoid C Intermittent |
P080500 | Clutch Position Sensor Circuit |
P080700 | Clutch Position Sensor Circuit Low |
P080800 | Clutch Position Sensor Circuit High |
P081000 | Clutch Position Control Error |
P081100 | Excessive Clutch Slippage |
P081500 | Upshift Switch Circuit |
P081600 | Downshift Switch Circuit |
P081700 | Starter Disable Circuit |
P082000 | Gear Lever X-Y Position Sensor Circuit |
P082600 | Up and Down Shift Switch Circuit |
P082900 | 5-6 Shift |
P084000 | Transmission Fluid Pressure Sensor/Switch A |
P084100 | Transmission Fluid Pressure Sensor/Switch A Range/Performance |
P084200 | Transmission Fluid Pressure Sensor/Switch "A" Circuit Low |
P084300 | Transmission Fluid Pressure Sensor/Switch "A" Circuit High |
P084400 | Transmission Fluid Pressure Sensor/Switch "A" Intermittend |
P084500 | Transmission Fluid Pressure Sensor/Switch B |
P084600 | Transmission Fluid Pressure Sensor/Switch B Range/Performance |
P084700 | Transmission Fluid Pressure Sensor/Switch "B" Circuit Low |
P084800 | Transmission Fluid Pressure Sensor/Switch "B" Circuit High |
P084900 | Transmission Fluid Pressure Sensor/Switch "B" Intermittend |
P085000 | Park/Neutral Switch Input Circuit |
P085100 | Park/Neutral Switch Input Circuit Low |
P085200 | Park/Neutral Switch Input Circuit High |
P086300 | TCM Communication Circuit |
P086400 | TCM Communication Circuit Range/Performance |
P086500 | TCM Communication Circuit Low |
P086800 | Transmission Fluid Pressure Low |
P088400 | TCM Power Input Signal Intermittent |
P088600 | TCM Power Relay Control Circuit Low |
P088700 | TCM Power Relay Control Circuit High |
P088900 | TCM Power Relay Sense Circuit Range/Performance |
P089000 | TCM Power Relay Sense Circuit Low |
P089100 | TCM Power Relay Sense Circuit High |
P089200 | TCM Power Relay Sense Circuit Intermittent |
P089700 | Transmission Fluid Deteriorated |
P090400 | Gate Select Position Circuit |
P090500 | Gate Select Position Circuit Range/Performance |
P090600 | Gate Select Position Low |
P090700 | Gate Select Position Circuit High |
P091400 | Gear Shift Position Circuit |
P091600 | Gear Shift Position Circuit Low |
P091700 | Gear Shift Position Circuit High |
P091900 | Gear Shift Position Control Error |
P092800 | Gear Shift Lock Solenoid Control Circuit/Open |
P092900 | Gear Shift Lock Solenoid Control Circuit Range/Performance |
P093000 | Gear Shift Lock Solenoid Control Circuit Low |
P093100 | Gear Shift Lock Solenoid Control Circuit High |
P094400 | Hydraulic Pressure Unit Loss of Pressure |
P094500 | Hydraulic Pump Relay Circuit/Open |
P094700 | Hydraulic Pump Relay Circuit Low |
P094800 | Hydraulic Pump Relay Circuit High |
P0A0900 | DC/DC Converter Status Circuit Low |
P0A0A00 | High Voltage System Inter-Lock Circuit |
