Руководство VW diagnostic trouble code DTC list: P-Codes and U-Codes
Admin
Admin
Создатель сайта
Команда форума
Россия, Москва
VW Tiguan 2.0 DBGC 2018, VW Touran 1.6 BSE 2008
Volkswagen diagnostic trouble code (DTC) list
Press Ctrl+F to find DTC code. (Нажмите Ctrl+F для поиска кода ошибки)
P-Codes:
DTCDTC Text
P000100Fuel Volume Regulator Control Circuit/Open
P000A00A Camshaft Position Slow Response (Bank 1)
P000B00B Camshaft Position Slow Response (Bank 1)
P000C00A Camshaft Position Slow Response (Bank 2)
P000D00B Camshaft Position Slow Response (Bank 2)
P001000A Camshaft Position Actuator Circuit/Open (Bank1)
P001100A Camshaft Position (Bank1) Timing over-advanced or System Performance
P001200A Camshaft Position (Bank1) Timing over-retarded
P001300B Camshaft Position Actuator Circuit/Open (Bank1)
P001400B Camshaft Position (Bank1) Timing over-advanced or System Performance
P001500B Camshaft Position (Bank1) Timing over-retarded
P001600Crankshaft Position-Camshaft Position Correlation Bank 1 Sensor A
P001700Crankshaft Position-Camshaft Position Correlation Bank 1 Sensor B
P001800Crankshaft Position-Camshaft Position Correlation Bank 2 Sensor A
P001900Crankshaft Position-Camshaft Position Correlation Bank 2 Sensor B
P002000A Camshaft Position ActuatorCircuit(Bank2)
P002100A Camshaft Position (Bank2) Timing over-advanced or System Performance
P002200A Camshaft Position (Bank2) Timing over-retarded
P002300B Camshaft Position Actuator Circuit(Bank2)
P002400B Camshaft Position (Bank2) Timing over-advanced or System Performance
P002500B Camshaft Position (Bank2) Timing over-retarded
P003000O2 Sensor Heater Contr. Circ.(Bank1(1)Sensor 1)
P003100O2 Sensor Heater Contr. Circ.(Bank1(1)Sensor 1) Low
P003200O2 Sensor Heater Contr. Circ.(Bank1(1)Sensor 1) High
P003300Turbo Charger Bypass Valve Control Circuit
P003400Turbo Charger Bypass Valve Control Circuit Low
P003500Turbo Charger Bypass Valve Control Circuit High
P003600O2 Sensor Heater Contr. Circ.(Bank1(1)Sensor 2)
P003700O2 Sensor Heater Contr. Circ.(Bank1(1)Sensor 2) Low
P003800O2 Sensor Heater Contr. Circ.(Bank1(1)Sensor 2) High
P003900Turbo/Super Charger Bypass Valve Control Circuit Range/Performance
P004000O2 Sensor Signals Swapped Bank 1 Sensor 1/ Bank 2 Sensor 1
P004100O2 Sensor Signals Swapped Bank 1 Sensor 2/ Bank 2 Sensor 2
P004200O2 Sensor Heater Contr. Circ.(Bank1(1)Sensor 3)
P004300O2 Sensor Heater Contr. Circ.(Bank1(1)Sensor 3) Low
P004400O2 Sensor Heater Contr. Circ.(Bank1(1)Sensor 3) High
P004500Turbocharger/Supercharger Boost Control Solenoid "A" Circuit/Open
P004700Turbocharger/Supercharger Boost Control Solenoid "A" Circuit Low
P004800Turbocharger/Supercharger Boost Control Solenoid "A" Circuit High
P004900Turbocharger/Supercharger Turbine Overspeed
P004A00Turbocharger/Supercharger Boost Control Solenoid "B" Circuit / Open
P004C00Turbocharger/Supercharger Boost Control Solenoid "B" Circuit Low
P004D00Turbocharger/Supercharger Boost Control Solenoid "B" Circuit High
P005000O2 Sensor Heater Contr. Circ.(Bank2 Sensor 1)
P005100O2 Sensor Heater Contr. Circ.(Bank2 Sensor 1) Low
P005200O2 Sensor Heater Contr. Circ.(Bank2 Sensor1) High
P005600O2 Sensor Heater Contr. Circ.(Bank2 Sensor 2)
P005700O2 Sensor Heater Contr. Circ.(Bank2 Sensor 2) Low
P005800O2 Sensor Heater Contr. Circ.(Bank2 Sensor2) High
P006200HO2S Heater Control Circuit
P006300HO2S Heater Control Circuit Low
P006400HO2S Heater Control Circuit High Bank2 Sensor3
P006500Air Assisted Injector Control Range/Performance
P006600Air Assisted Injector Control Circuit low
P006700Air Assisted Injector Control Circuit high
P006800MAP/MAF - Throttle Position Correlation
P006900Manifold Absolute Pressure - Barometric Pressure Correlation
P007000Ambient Air Temperature Sensor Circuit
P007100Ambient Air Temperature Sensor Circuit Range/Performance
P007200Ambient Air Temperature Sensor Circuit Low
P007300Ambient Air Temperature Sensor Circuit High
P007400Ambient Air Temperature Sensor Circuit Intermittent
P007C00Charge Air Cooler Temperature Sensor Circuit Low Bank 1
P007D00Charge Air Cooler Temperature Sensor Circuit High Bank 1
P008700Fuel Rail/System Pressure - Too Low
P008800Fuel Rail/System Pressure - Too High
P008900Fuel Pressure Regulator 1 Performance
P008A00Low Pressure Fuel System Pressure - Too Low
P008B00Low Pressure Fuel System Pressure - Too High
P009000Fuel Pressure Regulator 1Control Circuit
P009100Fuel Pressure Regulator 1 Control Circuit Low
P009200Fuel Pressure Regulator 1 Control Circuit High
P009500Intake Air Temperature Sensor 2 Circuit
P009600Intake Air Temperature Sensor 2 Circuit Bank 1 Range/Performance
P009700Intake Air Temperature Sensor 2 Circuit Low
P009800Intake Air Temperature Sensor 2 Circuit High
P009900Intake Air Temperature Sensor 2 Circuit Intermittent/Erratic
P009B00Fuel Pressure Relief Control Circuit/Open
P009C00Fuel Pressure Relief Control Circuit Low
P009D00Fuel Pressure Relief Control Circuit High
P009E00Fuel Pressure Relief Control Performance/Stuck Off
P009F00Fuel Pressure Relief Control Stuck on
P00A200Charge Air Cooler Temperature Sensor Circuit Low Bank 2
P00A300Charge Air Cooler Temperature Sensor Circuit High Bank 2
P00A600Intake Air Temperature Sensor 2 Circuit Bank 2 Range/Performance
P00AF00Turbocharger/Supercharger Boost Control "A" Module Performance
P00B000Turbocharger/Supercharger Boost Control "B" Module Performance
P00C600Fuel Rail Pressure Too Low - Engine Cranking
P010000Mass or Volume Air Flow Circuit
P010100Mass or Volume Air Flow Circ. Range/Performance
P010200Mass or Volume Air Flow Circ. Low Input
P010300Mass or Volume Air Flow Circ. High Input
P010400Mass or Volume Air Flow Circuit Intermittent
P010500Manifolt Absolut Pressure/Barometic Pressure Circuit
P010600Manifold Abs.Pressure or Bar.Pressure Range/Performance
P010700Manifold Abs.Pressure or Bar.Pressure Low Input
P010800Manifold Abs.Pressure or Bar.Pressure High Input
P010A00Mass or Volume Air Flow "B" Circuit
P010B00Mass or Volume Air Flow "B" Circuit Range/Performance
P010C00Mass or Volume Air Flow "B" Circuit Low Input
P010D00Mass or Volume Air Flow "B" Circuit High Input
P010E00Mass or Volume Air Flow "B" Circuit Intermittent/Erratic
P010F00Mass or Volume Air Flow Sensor A/B Correlation
P011000Intake Air Temperature Sensor 1 Circuit
P011100Intake Air Temp.Circ. Range/Performance
P011200Intake Air Temp.Circ. Low Input
P011300Intake Air Temp.Circ. High Input
P011400Intake Air Temp.Circ. Intermittend
P011500Engine Coolant Temperature Sensor 1 Circuit
P011600Engine Coolant Temperature Sensor 1 Circuit Range/Performance
P011700Engine Coolant Temperature Sensor 1 Circuit Low
P011800Engine Coolant Temperature Sensor 1 Circuit High
P011A00Engine Coolant Temperature Sensor 1/2 Correlation
P012000Throttle/Pedal Pos.Sensor A Circ. Malfunction
P012100Throttle/Pedal Pos.Sensor A Circ. Range/Performance
P012200Throttle/Pedal Pos.Sensor A Circ. Low Input
P012300Throttle/Pedal Pos.Sensor A Circ. High Input
P012500Insufficient Coolant Temp.for Closed Loop Fuel Control
P012800Coolant Termostat ( Coolant Temperature Below Thermostat Regulating Temperature)
P012A00Turbocharger/Supercharger Inlet Pressure Sensor Circuit
P012B00Turbocharger/Supercharger Inlet Pressure Sensor Circuit Range/Performance
P012C00Turbocharger/Supercharger Inlet Pressure Sensor Circuit Low
P012D00Turbocharger/Supercharger Inlet Pressure Sensor Circuit High
P013000O2 Sensor Circ.,Bank1-Sensor1 Malfunction
P013100O2 Sensor Circ.,Bank1-Sensor1 Low Voltage
P013200O2 Sensor Circ.,Bank1-Sensor1 High Voltage
P013300O2 Sensor Circ.,Bank1-Sensor1 Slow Response
P013400O2 Sensor Circ.,Bank1-Sensor1 No Activity Detected
P013500O2 Sensor Heater Circ.,Bank1-Sensor1 Malfunction
P013600O2 Sensor Circ.,Bank1-Sensor2 Malfunction
P013700O2 Sensor Circ.,Bank1-Sensor2 Low Voltage
P013800O2 Sensor Circ.,Bank1-Sensor2 High Voltage
P013900O2 Sensor Circ.,Bank1-Sensor2 Slow Response
P014000O2 Sensor Circ.,Bank1-Sensor2 No Activity Detected
P014100O2 Sensor Heater Circ.,Bank1-Sensor2 Malfunction
P014200O2 Sensor Circ.,Bank1-Sensor3
P014300O2 Sensor Circ.,Bank1-Sensor3 Low Voltage
P014400O2 Sensor Circ.,Bank1-Sensor3 High Voltage
P014500O2 Sensor Circ.,Bank1-Sensor3 Slow Response
P014600O2 Sensor Circ.,Bank1-Sensor3 No Activity Detected
P014700O2 Sensor Heater Circ.,Bank1-Sensor3
P014800Fuel Delivery Error
P014900Fuel Timing Error
P015000O2 Sensor Circ.,Bank2-Sensor1 Malfunction
P015100O2 Sensor Circ.,Bank2-Sensor1 Low Voltage
P015200O2 Sensor Circ.,Bank2-Sensor1 High Voltage
P015300O2 Sensor Circ.,Bank2-Sensor1 Slow Response
P015400O2 Sensor Circ.,Bank2-Sensor1 No Activity Detected
P015500O2 Sensor Heater Circ.,Bank2-Sensor1 Malfunction
P015600O2 Sensor Circ.,Bank2-Sensor2 Malfunction
P015700O2 Sensor Circ.,Bank2-Sensor2 Low Voltage
P015800O2 Sensor Circ.,Bank2-Sensor2 High Voltage
P015900O2 Sensor Circ.,Bank2-Sensor2 Slow Response
P016000O2 Sensor Circ.,Bank2-Sensor2 No Activity Detected
P016100O2 Sensor Heater Circ.,Bank2-Sensor2 Malfunction
P016200O2 Sensor Circ.,Bank2-Sensor3 Malfunction
P016300O2 Sensor Circ.,Bank2-Sensor3 Low Voltage
P016400O2 Sensor Circ.,Bank2-Sensor3 High Voltage
P016500O2 Sensor Circ.,Bank2-Sensor3 Slow Response
P016600O2 Sensor Circ.,Bank2-Sensor3 No Activity Detected
P016700O2 Sensor Heater Circ.,Bank2-Sensor3 Malfunction
P016900Incorrect Fuel Composition
P017000Fuel Trim,Bank1 Malfunction
P017100Fuel Trim,Bank1 System too Lean
P017200Fuel Trim,Bank1 System too Rich
P017300Fuel Trim,Bank2 Malfunction
P017400Fuel Trim,Bank2 System too Lean
P017500Fuel Trim,Bank2 System too Rich
P017700Fuel Composition Sensor Circuit Range/Performance
P017800Fuel Composition Sensor Circuit Low
P017900Fuel Composition Sensor Circuit High
P018100Fuel Temperature Sensor A Circuit Range/Performance
P018200Fuel Temperature Sensor A Circuit Low Input
P018300Fuel Temperature Sensor A Circuit High Input
P018600Fuel Temperature Sensor B Circuit Range/Performance
P018700Fuel Temperature Sensor B Circuit Low
P018800Fuel Temperature Sensor B Circuit High
P018A00Fuel Pressure Sensor "B" Circuit
P018B00Fuel Pressure Sensor "B" Circuit Range/Performance
P018C00Fuel Pressure Sensor "B" Circuit Low
P019000Fuel Rail Pressure Sensor "A" Circuit
P019100Fuel Rail Pressure Sensor "A" Circuit Range/Performance
P019200Fuel Rail Pressure Sensor "A" Circuit Low Input
P019300Fuel Rail Pressure Sensor "A" Circuit High Input
P019400Fuel Rail Pressure Sensor "A" Circuit intermittent
P019500Engine Oil Temperature Sensor Circuit
P019600Engine Oil Temperature Sensor Circuit range/performance
P019700Engine Oil Temperature Sensor Circuit low
P019800Engine Oil Temperature Sensor Circuit high
P019900Engine Oil Temperature Sensor Circuit Intermittent/Erratic
P020000Injector Circuit open
P020100Cylinder 1- Injector Circuit
P020200Cylinder 2- Injector Circuit
P020300Cylinder 3- Injector Circuit
P020400Cylinder 4- Injector Circuit
P020500Cylinder 5- Injector Circuit
P020600Cylinder 6- Injector Circuit
P020700Cylinder 7- Injector Circuit
P020800Cylinder 8- Injector Circuit
P020900Cylinder 9- Injector Circuit
P020A00Cylinder 1 Injection Timing
P020B00Cylinder 2 Injection Timing
P020C00Cylinder 3 Injection Timing
P020D00Cylinder 4 Injection Timing
P020E00Cylinder 5 Injection Timing
P020F00Cylinder 6 Injection Timing
P021000Cylinder 10- Injector Circuit
P021100Cylinder 11- Injector Circuit
P021200Cylinder 12- Injector Circuit
P021500Engine Shutoff Solenoid
P021600Injection Timing Control Circuit
P021800Transmission Fluid Over Temperature Condition
P021900Engine Overspeed Condition
P021A00Cylinder 7 Injection Timing
P021B00Cylinder 8 Injection Timing
P021C00Cylinder 9 Injection Timing
P021D00Cylinder 10 Injection Timing
P021E00Cylinder 11 Injection Timing
P021F00Cylinder 12 Injection Timing
P022100Throttle/Pedal Position Sensor/Switch B Range/Performance
P022200Throttle/Pedal Position Sensor/Switch B Low Input
P022300Throttle/Pedal Position Sensor/Switch B High Input
P022500Throttle/Pedal Position Sensor/Switch C
P022600Throttle/Pedal Position Sensor/Switch C Circuit Range/Performance
P022700Throttle/Pedal Position Sensor/Switch C Circuit Low Input
P022800Throttle/Pedal Position Sensor/Switch C Circuit High Input
P022A00Charge Air Cooler Bypass Control "A" Circuit /Open
P022B00Charge Air Cooler Bypass Control "A" Circuit Low
P022C00Charge Air Cooler Bypass Control "A" Circuit High
P023000Fuel Pump Primary Circuit
P023400Turbo/Super Charger Overboost Condition
P023500Turbo/Super Charger Boost Sensor A Circ.
P023600Turbocharger Boost Sensor (A) Circ. Range/Performance
P023700Turbocharger Boost Sensor (A) Circ. Low Input
P023800Turbocharger Boost Sensor (A) Circ. High Input
P023F00Fuel Pump Secondary Circuit/Open
P024000Turbo/Super Charger Boost Sensor "B" Circuit Range/Performance
P024100Turbo/Super Charger Boost Sensor "B" Circuit Low
P024200Turbo/Super Charger Boost Sensor "B" Circuit High
P024300Turbo/Super Charger Wastegate Solonoid A
P024500Turbo/Super Charger Wasteg.Solonoid A Low
P024600Turbo/Sup.Charger Wasteg.Solonoid A High
P024900Turbo/Super Charger Wastegate Solenoid "B" Low
P024A00Charge Air Cooler Bypass Control "A" Range/Performance
P024B00Charge Air Cooler Bypass Control "A" Stuck
P025000Turbo/Super Charger Wastegate Solenoid "B" High
P025100Injection Pump Fuel Metering Control "A" (Cam/Rotor/Injector)
P025200Injection Pump Fuel Metering Control A Range/Performance (Cam/Rotor/Injector)
P025A00Fuel Pump Module Control Circuit/Open
P025B00Fuel Pump Module Control Circuit Range/Performance
P025C00Fuel Pump Module Control Circuit Low
P025D00Fuel Pump Module Control Circuit High
P026100Cylinder 1- Injector Circuit Low
P026200Cylinder 1- Injector Circuit High
P026300Cylinder 1 Contribution/Balance
P026400Cylinder 2- Injector Circuit Low
P026500Cylinder 2- Injector Circuit High
P026600Cylinder 2 Contribution/Balance
P026700Cylinder 3- Injector Circuit Low
P026800Cylinder 3- Injector Circuit High
P026900Cylinder 3 Contribution/Balance
P027000Cylinder 4- Injector Circuit Low
P027100Cylinder 4- Injector Circuit High
P027200Cylinder 4 Contribution/Balance
P027300Cylinder 5- Injector Circuit Low
P027400Cylinder 5- Injector Circuit High
P027500Cylinder 5 Contribution/Balance
P027600Cylinder 6- Injector Circuit Low
P027700Cylinder 6- Injector Circuit High
P027800Cylinder 6 Contribution/Balance
P027900Cylinder 7- Injector Circuit Low
P028000Cylinder 7- Injector Circuit High
P028100Cylinder 7 Contribution/Balance
P028200Cylinder 8- Injector Circuit Low
P028300Cylinder 8- Injector Circuit High
P028400Cylinder 8 Contribution/Balance
P028500Cylinder 9- Injector Circuit Low
P028600Cylinder 9- Injector Circuit High
P028700Cylinder 9 Contribution/Balance
P028800Cylinder 10- Injector Circuit Low
P028900Cylinder 10- Injector Circuit High
P029000Cylinder 10 Contribution/Balance
P029100Cylinder 11- Injector Circuit Low
P029200Cylinder 11- Injector Circuit High
P029300Cylinder 11 Contribution/Balance
P029400Cylinder 12- Injector Circuit Low
P029500Cylinder 12- Injector Circuit High
P029600Cylinder 12 Contribution/Balance
P029900Turbo/Super Charger Underboost
P02CA00Turbocharger/Supercharger "B" Overboost Condition
P02CB00Turbocharger/Supercharger "B" Underboost Condition
P02CD00Cylinder 1 Fuel Injector Offset Learning At Max Limit
P02CF00Cylinder 2 Fuel Injector Offset Learning At Max Limit
P02D100Cylinder 3 Fuel Injector Offset Learning At Max Limit
P02D300Cylinder 4 Fuel Injector Offset Learning At Max Limit
P030000Random/Multiple Cylinder Misfire Detected
P030100Cyl.1 Misfire Detected
P030200Cyl.2 Misfire Detected
P030300Cyl.3 Misfire Detected
P030400Cyl.4 Misfire Detected
P030500Cyl.5 Misfire Detected
P030600Cyl.6 Misfire Detected
P030700Cyl.7 Misfire Detected
P030800Cyl.8 Misfire Detected
P030900Cyl.9 Misfire Detected
P031000Cyl.10 Misfire Detected
P031100Cyl.11 Misfire Detected
P031200Cyl.12 Misfire Detected
P031300Misfire Detected with Low Fuel
P031400Single Cylinder Misfire
P031800Rough Road Sensor "A" Signal Circuit
P032100Ign./Distributor Eng.Speed Inp.Circ. Range/Performance
P032200Ign./Distributor Eng.Speed Inp.Circ. No Signal
P032400Knock Control System Error
P032500Knock Sensor 1 Circuit Malfunktion
P032600Knock Sensor 1 Circuit Range/Performance
P032700Knock Sensor 1 Circ. Low Input
P032800Knock Sensor 1 Circ. High Input
P033000Knock Sensor 2 Circuit
P033100Knock Sensor 2 Circuit Range/Performance
P033200Knock Sensor 2 Circ. Low Input
P033300Knock Sensor 2 Circ. High Input
P033500Crankshaft Position Sensor A Circuit
P033600Crankshaft Position Sensor A Circuit Range/Performance
P033700Crankshaft Pos.Sensor (A) Circ. Low Input
P033900Crankshaft Position Sensor "A" Circuit Intermittent
P034000Camshaft Position Sensor Circuit
P034100Camshaft Pos.Sensor Circ. Range/Performance
P034200Camshaft Pos.Sensor Circ. Low Input
P034300Camshaft Pos.Sensor Circ. High Input
P034500Camshaft Position Sensor Circuit Bank2
P034600Camshaft Pos.Sensor Circ. (Bank2) Range/Performance
P034700Camshaft Pos.Sensor "A" Circ. (Bank2) Low
P034800Camshaft Pos.Sensor "A" Circ. (Bank2) High
P035100Ignition Coil A Primary/secondary Circuit
P035200Ignition Coil B Primary/secondary Circuit
P035300Ignition Coil C Primary/secondary Circuit
P035400Ignition Coil D Primary/secondary Circuit
P035500Ignition Coil E Primary/secondary Circuit
P035600Ignition Coil F Primary/secondary Circuit
P035700Ignition Coil G Primary/secondary Circuit
P035800Ignition Coil H Primary/secondary Circuit
P035900Ignition Coil I Primary/secondary Circuit
P036000Ignition Coil J Primary/secondary Circuit
P036100Ignition Coil K Primary/secondary Circuit
P036200Ignition Coil L Primary/secondary Circuit
P036300Misfire Detected - Fueling Disabled
P036500Camshaft Position Sensor "B" Circuit (Bank 1)
P036600Camshaft Pos.Sensor "B" Circ. (Bank 1) Range/Performance
P036700Camshaft Pos.Sensor "B" Circ. (Bank 1) Low Input
P036800Camshaft Pos.Sensor "B" Circ. (Bank 1) High Input
P038000Glow Plug/Heater Circuit "A"
P038100Glow Plug/Heater Indicator Circuit
P038300Glow Plug Control Module Control Circuit Low
P038400Glow Plug Control Module Control Circuit High
P039000Camshaft Position Sensor "B" Circuit (Bank 2)
P039100Camshaft Pos.Sensor "B" Circ. (Bank 2) Range/Performance
P039200Camshaft Pos.Sensor "B" Circ. (Bank 2) Low Input
P039300Camshaft Pos.Sensor "B" Circ. (Bank 2) High Input
P039B00Cylinder 1 Pressure Too High
P03A500Cylinder 2 Pressure Too High
P03AF00Cylinder 3 Pressure Too High
P03B900Cylinder 4 Pressure Too High
P03C300Cylinder 5 Pressure Too High
P03CD00Cylinder 6 Pressure Too High
P040000Exhaust Gas Recirc."A" Flow
P040100Exhaust Gas Recirc.Flow Insufficient Detected
P040200Exhaust Gas Recirc.Flow Excessive Detected
P040300Exhaust Gas Recirculation Circuit
P040400Exhaust Gas Recirculation Circuit Range/Performance
P040500Exhaust Gas Recirculat.Sensor A Circuit Low
P040600Exhaust Gas Recirculat.Sensor A Circuit High
P040700Exhaust Gas Recirculat.Sensor B Circuit Low
P040800Exhaust Gas Recirculat.Sensor B Circuit High
P040B00Exhaust Gas Recirculation Temperature Sensor "A" Circuit Range/Performance
P040C00Exhaust Gas Recirculation Temperature Sensor "A" Circuit Low
P040D00Exhaust Gas Recirculation Temperature Sensor "A" Circuit High
P041000Sec.Air Inj.Sys. Malfunction
P041100Sec.Air Inj.Sys. Incorrect Flow Detected
P041200Sec.Air Inj.Sys.Switching Valve A Circ. Malfunction
P041300Sec.Air Inj.Sys.Switching Valve A Circ. Open
P041400Sec.Air Inj.Sys.Switching Valve A Circ. Shorted
P041500Sec.Air Inj.Sys.Switching Valve B Circ. Malfunction
P041600Sec.Air Inj.Sys.Switching Valve B Circ. Open
P041700Sec.Air Inj.Sys.Switching Valve B Circ. Shorted
P041800Sec. Air Injection System Relay A Circuit
P041900Sec. Air Injection System Relay B Circuit
P042000Catalyst System,Bank1 Efficiency Below Threshold
P042100Warm Up Catalyst, Bank1 Efficiency Below Threshold
P042200Main Catalyst,Bank1 Efficiency Below Threshold
P042500Catalyst Temperature Sensor Circuit
P042600Catalyst Temperature Sensor Circuit Range/Performance
P042700Catalyst Temperature Sensor Bank1 Low Input
P042800Catalyst Temperature Sensor Bank1 High Input
P043000Catalyst System, Bank2 Efficiency Below Threshold
P043100Warm Up Catalyst, Bank2 Efficiency Below Threshold
P043200Main Catalyst,Bank2 Efficiency Below Threshold
P043600Catalyst Temperature Sensor Bank2 Range/performance
P043700Catalyst Temperature Sensor Bank2 Low Input
P043800Catalyst Temperature Sensor Bank2 High Input
P044000EVAP Emission Contr.Sys. Malfunction
P044100EVAP Emission Contr.Sys.Incorrect Purge Flow
P044200EVAP Emission Contr.Sys.(Small Leak) Leak Detected
P044300Evaporativ Emiss.System Purge Control Valve Circ.
P044400Evaporativ Emiss.System Purge Control Valve Circ. Open
P044500Evaporativ Emiss.System Purge Control Valve Circ. Shorted
P044900Evaporativ Emiss.System Vent Valve/Solenoid Circ.
P045000Evaporative Emission System Pressure Sensor/Switch
P045100Evaporative Emission System Pressure Sensor/Switch Range/Performance
P045200EVAP Emission Contr.Sys.Press.Sensor Low Input
P045300EVAP Emission Contr.Sys.Press.Sensor High Input
P045500EVAP Emission Contr.Sys.(Gross Leak) Leak Detected
P045600EVAP Emission Contr. Sys. (very small Leak) Leak Detected
P045800Evaporative Emission System Purge Control Valve Circuit Low
P045900Evaporative Emission System Purge Control Valve Circuit High
P045A00Exhaust Gas Recirculation "B" Control Circuit
P045B00Exhaust Gas Recirculation "B" Control Circuit Range/Performance
P045C00Exhaust Gas Recirculation "B" Control Circuit Low
P045D00Exhaust Gas Recirculation "B" Control Circuit High
P045E00Exhaust Gas Recirculation "B" Control Stuck Open
P045F00Exhaust Gas Recirculation "B" Control Stuck Closed
P046100Fuel Level Sensor Circ. Range/Performance
P046200Fuel Lever Sensor Circuit Low Input
P046300Fuel Lever Sensor Circuit High Input
P046C00Exhaust Gas Recirculation Sensor "A" Circuit Range/Performance
P046E00Exhaust Gas Recirculation Sensor "B" Circuit Range/Performance
P047000Exhaust Pressure Sensor "A"
P047100Exhaust Pressure Sensor "A" Range/Performance
P047200Exhaust Pressure Sensor "A"Low
P047300Exhaust Pressure Sensor "A" High
P047500Exhaust Pressure Control Valve "A"
P047600Exhaust Pressure Control Valve "A" Range/Performance
P047700Exhaust Pressure Control Valve "A" Low
P047800Exhaust Pressure Control Valve "A" High
P047A00Exhaust Pressure Sensor "B"
P047B00Exhaust Pressure Sensor "B" Range/Performance
P047C00Exhaust Pressure Sensor "B" Low
P047D00Exhaust Pressure Sensor "B" High
P047F00Exhaust Pressure Control Valve "A" Stuck Open
P048000Cooling Fan 1 Control Circuit
P048100Cooling Fan 2 Control Circuit
P048600Exhaust Gas Recirculation Sensor "B" Circuit
P048900Exhaust Gas Recirculation Control Circuit Low
P048A00Exhaust Pressure Control Valve "A" Stuck Closed
P048B00Exhaust Pressure Control Valve Position Sensor/Switch Circuit
P048C00Exhaust Pressure Control Valve Pos. Sensor/Switch Circuit Range/Performance
P048E00Exhaust Pressure Control Valve Pos. Sensor/Switch Circuit High
P049000Exhaust Gas Recirculation Control Circuit High
P049100Secondary Air Injection System (Bank 1) insufficient flow
P049200Secondary Air Injection System (Bank 2)
P049800Evaporative Emission System Vent Valve Control Circuit Low
P049900Evaporative Emission System Vent Valve Control Circuit High
P049A00Exhaust Gas Recirc."B" Flow
P049D00Exhaust Gas Recirculation "A" Control Position Exceeded Learning Limit
P049E00Exhaust Gas Recirculation "B" Control Position Exceeded Learning Limit
P050100Vehicle Speed Sensor "A" Range/Performance
P050200Vehicle Speed Sensor "A" Circuit Low Input
P050300Vehicle Speed Sensor "A" Intermittend/Erratic/High
P050500Idle Control System
P050600Idle Control System RPM Lower than Expected
P050700Idle Control System RPM Higher than Expected
P050A00Cold Start Idle Air Control System Performance
P050B00Cold Start Ignition Timing Performance
P051000Closed Throttle Pos.Switch Malfunction
P051300Incorrect Immobilizer Key
P053100A/C Refrigerant Pressure Sensor Circuit Range/Performance
P053200A/C Refrigerant Pressure Sensor Circuit low Input
P053300A/C Refrigerant Pressure Sensor Circuit high Input
P053700A/C Evaporator Temperature Sensor Circuit Low
P053800A/C Evaporator Temperature Sensor Circuit High
P053A00Positive Crankcase Ventilation Heater Control Circuit /Open
P053B00Positive Crankcase Ventilation Heater Control Circuit Low
P053C00Positive Crankcase Ventilation Heater Control Circuit High
P054400Exhaust Gas Temperatur Sensor Circuit - Bank 1
P054500Exhaust Gas Temperatur Sensor Circuit - Bank 1 Low
P054600Exhaust Gas Temperatur Sensor Circuit - Bank 1 High
P054700Exhaust Gas Temperatur Sensor Circuit - Bank 2
P054800Exhaust Gas Temperatur Sensor Circuit - Bank 2 Low
P054900Exhaust Gas Temperatur Sensor Circuit - Bank 2 High
P055000Power Steering Pressure Circuit
P055100Power Steering Pressure Sensor Circuit Range/Performance
P056000System Voltage Malfunction
P056100System Voltage Unstable
P056200System Voltage Low Voltage
P056300System Voltage High Voltage
P056800Cruise Control Set Signal
P057100Cruise/Brake Switch (A) Circ. Malfunction
P059700Thermostat Heater Control Circuit Open
P059800Thermostat Heater Control Circuit Low
P059900Thermostat Heater Control Circuit High
P060000Serial Link Communication
P060100Internal Contr.Module Memory Check Sum Error
P060200Control Modul Programming Error
P060300Internal Contr.Module (KAM) Error
P060400Internal Contr.Module Random Access Memory (RAM) Error
P060500Internal Contr.Module ROM Test Error
P060600ECM/PCM Processor
P060700Control Module Performance
P060800Control Module VSS Output "A"
P060900Control Module VSS Output "B"
P060A00Internal Control Module Monitoring Processor Performance
P061000Control Module Vehicle Options Error
P061300TCM Processor
P061400ECM/TCM Incompatible
P061500Starter Relay Circuit
P061600Starter Relay Circuit Low
P061700Starter Relay Circuit High
P062700Fuel Pump "A" Control Circuit/Open
P062800Fuel Pump "A" Control Circuit Low
P062900Fuel Pump "A" Control Circuit High
P062B00Internal Control Module Fuel Injector Control Performance
P062F00Internal Control Module EEPROM Error
P063400PCM/ECM/TCM Internal Temperature Too High
P063800Throttle Actuator Control (Bank1) Range/Performance
P063900Throttle Actuator Control (Bank2) Range/Performance
P064100Sensor Reference Voltage "A" Circuit Open
P064200Sensor Reference Voltage "A" Circuit Low
P064300Sensor Reference Voltage "A" Circuit High
P064500AC clutch relais circuit
P064C00Glow Plug Control Module
P065000Malfunction Indicator Lamp Control Circ.
P065100Sensor Reference Voltage "B" Circuit Open
P065200Sensor Reference Voltage "B" Circuit Low
P065300Sensor Reference Voltage "B" Circuit High
P065400Engine RPM Output Circuit
P065600Fuel Level Output Circuit
P065700Actuator Supply Voltage "A" Circuit/Open
P065800Actuator Supply Voltage "A" Circuit Low
P065900Actuator Supply Voltage "A" Circuit High
P066000Intake Manifold Tuning Control Circuit - Bank1
P066100Intake Manifold Tuning Control Circuit - Bank1 Low
P066200Intake Manifold Tuning Control Circuit - Bank1 High
P066600PCM/ECM/TCM Internal Temperature Sensor "A" Circuit
P066700PCM/ECM/TCM Internal Temperature Sensor "A" Range/Performance
P066800PCM/ECM/TCM Internal Temperature Sensor "A" Circuit Low
P066900PCM/ECM/TCM Internal Temperature Sensor "A" Circuit High
P066A00Cylinder 1 Glow Plug Control Circuit Low
P066C00Cylinder 2 Glow Plug Control Circuit Low
P066E00Cylinder 3 Glow Plug Control Circuit Low
P067000Glow Plug Module Control Circuit
P067100Cylinder 1 Glow Plug Circuit
P067200Cylinder 2 Glow Plug Circuit
P067300Cylinder 3 Glow Plug Circuit
P067400Cylinder 4 Glow Plug Circuit
P067500Cylinder 5 Glow Plug Circuit
P067600Cylinder 6 Glow Plug Circuit
P067700Cylinder 7 Glow Plug Circuit
P067800Cylinder 8 Glow Plug Circuit
P067900Cylinder 9 Glow Plug Circuit
P067A00Cylinder 4 Glow Plug Control Circuit Low
P067C00Cylinder 5 Glow Plug Control Circuit Low
P067E00Cylinder 6 Glow Plug Control Circuit Low
P068000Cylinder 10 Glow Plug Circuit
P068100Cylinder 11 Glow Plug Circuit
P068200Cylinder 12 Glow Plug Circuit
P068400Glow Plug Control Module to PCM Comm.Circuit Range/Performance
P068500EMC/PCM Power Relay Control Circuit Open
P068600EMC/PCM Power Relay Control Circuit Low
P068700EMC/PCM Power Relay Control Circuit High
P068800EMC/PCM Power Relay Sense Circuit Open
P068A00ECM/PCM Power Relay De-Energized Performance - Too Early
P068B00ECM/PCM Power Relay De-Energized Performance - Too Late
P068C00Cylinder 7 Glow Plug Control Circuit Low
P068E00Cylinder 8 Glow Plug Control Circuit Low
P069100Cooling Fan 1 Control Circuit Low
P069200Cooling Fan 1 Control Circuit High
P069300Cooling Fan 2 Control Circuit Low
P069400Cooling Fan 2 Control Circuit High
P069700Sensor Reference Voltage "C" Circuit Open
P069800Sensor Reference Voltage "C" Circuit Low
P069900Sensor Reference Voltage "C" Circuit High
P069A00Cylinder 9 Glow Plug Control Circuit Low
P069C00Cylinder 10 Glow Plug Control Circuit Low
P06A300Sensor Reference Voltage "D" Circuit/Open
P06B900Cylinder 1 Glow Plug Circuit Range/Performance
P06BA00Cylinder 2 Glow Plug Circuit Range/Performance
P06BB00Cylinder 3 Glow Plug Circuit Range/Performance
P06BC00Cylinder 4 Glow Plug Circuit Range/Performance
P06BD00Cylinder 5 Glow Plug Circuit Range/Performance
P06BE00Cylinder 6 Glow Plug Circuit Range/Performance
P06BF00Cylinder 7 Glow Plug Circuit Range/Performance
P06C000Cylinder 8 Glow Plug Circuit Range/Performance
P06C100Cylinder 9 Glow Plug Circuit Range/Performance
P06C200Cylinder 10 Glow Plug Circuit Range/Performance
P06C300Cylinder 11 Glow Plug Circuit Range/Performance
P06C400Cylinder 12 Glow Plug Circuit Range/Performance
P06C500Cylinder 1 Glow Plug Incorrect
P06C600Cylinder 2 Glow Plug Incorrect
P06C700Cylinder 3 Glow Plug Incorrect
P06C800Cylinder 4 Glow Plug Incorrect
P06C900Cylinder 5 Glow Plug Incorrect
P06CA00Cylinder 6 Glow Plug Incorrect
P06CB00Cylinder 7 Glow Plug Incorrect
P06CC00Cylinder 8 Glow Plug Incorrect
P06CD00Cylinder 9 Glow Plug Incorrect
P06CE00Cylinder 10 Glow Plug Incorrect
P06CF00Cylinder 11 Glow Plug Incorrect
P06D000Cylinder 12 Glow Plug Incorrect
P06D200Sensor Reference Voltage "E" Circuit/Open
P06E000Cylinder 11 Glow Plug Control Circuit Low
P06E200Cylinder 12 Glow Plug Control Circuit Low
P070000Transm.Contr.System Malfunction
P070100Transm.Contr.System Range/Performance
P070200Transm.Contr.System Electrical
P070300Torque Converter/Brake Switch B Circ. Malfunction
P070400Clutch Switch Input Circuit
P070500Transm.Range Sensor "A" Circ.(PRNDL Inp.) Malfunction
P070600Transm.Range Sensor "A" Circ. Range/Performance
P070700Transm.Range Sensor "A" Circ. Low Input
P070800Transm.Range Sensor "A" Circ. High Input
P071000Transm.Fluid Temp.Sensor Circ. Malfunction
P071100Transm.Fluid Temp.Sensor Circ. Range/Performance
P071200Transm.Fluid Temp.Sensor Circ. Low Input
P071300Transm.Fluid Temp.Sensor Circ. High Input
P071400Transm.Fluid Temp.Sensor Circ. Intermittent
P071500Input Turbine/Speed Sensor "A" Circ.
P071600Input Turbine/Speed Sensor "A"Circ. Range/Performance
P071700Input Turbine/Speed Sensor "A"Circ. No Signal
P072000Output Speed Sensor Circ. Malfunction
P072100Output Speed Sensor Circ. Range/Performance
P072200Output Speed Sensor Circ. No Signal
P072500Engine Speed Input Ciruit
P072600Engine Speed Inp.Circ. Range/Performance
P072700Engine Speed Inp.Circ. No Signal
P072900Gear 6 Incorrect Ratio
P072B00Stuck in Reverse
P072C00Stuck in Gear 1
P072D00Stuck in Gear 2
P072E00Stuck in Gear 3
P072F00Stuck in Gear 4
P073000Gear Incorrect Ratio
P073100Gear 1 Incorrect Ratio
P073200Gear 2 Incorrect Ratio
P073300Gear 3 Incorrect Ratio
P073400Gear 4 Incorrect Ratio
P073500Gear 5 Incorrect Ratio
P073600Reverse Incorrect Ratio
P073A00Stuck in Gear 5
P073B00Stuck in Gear 6
P073C00Stuck in Gear 7
P073E00Unable to Engage Reverse
P073F00Unable to Engage Gear 1
P074000Torque Converter Clutch Circ. Malfunction
P074100Torque Converter Clutch Circ. Performance or Stuck Off
P074300Torque Converter Clutch Circ. Electrical
P074600Pressure Contr.Solenoid A Performance or Stuck Off
P074700Pressure Contr.Solenoid A Stuck On
P074800Pressure Contr.Solenoid A Electrical
P074900Pressure Contr.Solenoid A Intermittent
P074A00Unable to Engage Gear 2
P074B00Unable to Engage Gear 3
P074C00Unable to Engage Gear 4
P074D00Unable to Engage Gear 5
P074E00Unable to Engage Gear 6
P074F00Unable to Engage Gear 7
P075000Shift Solenoid A Malfunction
P075100Shift Solenoid A Performance or Stuck Off
P075200Shift Solenoid A Stuck On
P075300Shift Solenoid A Electrical
P075400Shift Solenoid "A" Intermittent
P075600Shift Solenoid B Performance or Stuck Off
P075700Shift Solenoid B Stuck On
P075800Shift Solenoid B Electrical
P076100Shift Solenoid C Performance or Stuck Off
P076200Shift Solenoid C Stuck On
P076300Shift Solenoid C Electrical
P076400Shift Solenoid "C" Intermittent
P076600Shift Solenoid D Performance or Stuck Off
P076800Shift Solenoid D Electrical
P077100Shift Solenoid E Performance or Stuck Off
P077300Shift Solenoid E Electrical
P077600Pressure Contr.Solenoid B Performance or Stuck Off
P077700Pressure Contr.Solenoid B Stuck On
P077800Pressure Contr.Solenoid B Electrical
P077900Pressure Contr.Solenoid B Intermittent
P078000Shift
P0781001-2 Shift
P0782002-3 Shift
P0783003-4 Shift
P0784004-5 Shift
P078500Shift/Timing Solenoid
P079000Normal/Performance Switch Circ. Malfunction
P079100Intermediate Shaft Speed Sensor "A" Circuit
P079600Pressure Contr.Solenoid C Performance or Stuck Off
P079700Pressure Contr.Solenoid C Stuck On
P079800Pressure Contr.Solenoid C Electrical
P079900Pressure Contr.Solenoid C Intermittent
P080500Clutch Position Sensor Circuit
P080700Clutch Position Sensor Circuit Low
P080800Clutch Position Sensor Circuit High
P081000Clutch Position Control Error
P081100Excessive Clutch Slippage
P081500Upshift Switch Circuit
P081600Downshift Switch Circuit
P081700Starter Disable Circuit
P082000Gear Lever X-Y Position Sensor Circuit
P082600Up and Down Shift Switch Circuit
P0829005-6 Shift
P084000Transmission Fluid Pressure Sensor/Switch A
P084100Transmission Fluid Pressure Sensor/Switch A Range/Performance
P084200Transmission Fluid Pressure Sensor/Switch "A" Circuit Low
P084300Transmission Fluid Pressure Sensor/Switch "A" Circuit High
P084400Transmission Fluid Pressure Sensor/Switch "A" Intermittend
P084500Transmission Fluid Pressure Sensor/Switch B
P084600Transmission Fluid Pressure Sensor/Switch B Range/Performance
P084700Transmission Fluid Pressure Sensor/Switch "B" Circuit Low
P084800Transmission Fluid Pressure Sensor/Switch "B" Circuit High
P084900Transmission Fluid Pressure Sensor/Switch "B" Intermittend
P085000Park/Neutral Switch Input Circuit
P085100Park/Neutral Switch Input Circuit Low
P085200Park/Neutral Switch Input Circuit High
P086300TCM Communication Circuit
P086400TCM Communication Circuit Range/Performance
P086500TCM Communication Circuit Low
P086800Transmission Fluid Pressure Low
P088400TCM Power Input Signal Intermittent
P088600TCM Power Relay Control Circuit Low
P088700TCM Power Relay Control Circuit High
P088900TCM Power Relay Sense Circuit Range/Performance
P089000TCM Power Relay Sense Circuit Low
P089100TCM Power Relay Sense Circuit High
P089200TCM Power Relay Sense Circuit Intermittent
P089700Transmission Fluid Deteriorated
P090400Gate Select Position Circuit
P090500Gate Select Position Circuit Range/Performance
P090600Gate Select Position Low
P090700Gate Select Position Circuit High
P091400Gear Shift Position Circuit
P091600Gear Shift Position Circuit Low
P091700Gear Shift Position Circuit High
P091900Gear Shift Position Control Error
P092800Gear Shift Lock Solenoid Control Circuit/Open
P092900Gear Shift Lock Solenoid Control Circuit Range/Performance
P093000Gear Shift Lock Solenoid Control Circuit Low
P093100Gear Shift Lock Solenoid Control Circuit High
P094400Hydraulic Pressure Unit Loss of Pressure
P094500Hydraulic Pump Relay Circuit/Open
P094700Hydraulic Pump Relay Circuit Low
P094800Hydraulic Pump Relay Circuit High
P0A0900DC/DC Converter Status Circuit Low
P0A0A00High Voltage System Inter-Lock Circuit
DTCDTC Text
P0A1F00Battery Energy Control Module
P0A2A00Drive Motor "A" Temperature Sensor Circuit
P0A2B00Drive Motor "A" Temperature Sensor Circuit Range/Performance
P0A2C00Drive Motor "A" Temperature Sensor Circuit Low
P0A2D00Drive Motor "A" Temperature Sensor Circuit High
P0A4000Drive Motor "A" Position Sensor Circuit Range/Performance
P0A4100Drive Motor "A" Position Sensor Circuit Low
P0A4200Drive Motor "A" Position Sensor Circuit High
P0A4400Drive Motor "A" Position Sensor Circuit Overspeed
P0A5200Drive Motor "A" Current Sensor Circuit Range/Performance
P0A5300Drive Motor "A" Current Sensor Circuit Low
P0A5400Drive Motor "A" Current Sensor Circuit High
P0A5D00Drive Motor "A" Phase U Current
P0A5E00Drive Motor "A" Phase U Current Low
P0A5F00Drive Motor "A" Phase U Current High
P0A6000Drive Motor "A" Phase V Current
P0A6100Drive Motor "A" Phase V Current Low
P0A6200Drive Motor "A" Phase V Current High
P0A7E00Hybrid Battery Pack Over Temperature
P0A7F00Hybrid Battery Pack Deterioration
P0A8000Replace Hybrid Battery Pack
P0A8B0014 Volt Power Module System Voltage
P0A8D0014 Volt Power Module System Voltage Low
P0A8E0014 Volt Power Module System Voltage High
P0A9000Drive Motor "A" Performance
P0A9500High Voltage Fuse
P0A9D00Hybrid Battery Temperature Sensor "A" Circuit Low
P0A9E00Hybrid Battery Temperature Sensor "A" Circuit High
P0AA600Hybrid Battery Voltage System Isolation Fault
P0AAE00Hybrid Battery Pack Air Temperature Sensor "A" Circuit Low
P0AAF00Hybrid Battery Pack Air Temperature Sensor "A" Circuit High
P0AB300Hybrid Battery Pack Air Temperature Sensor "B" Circuit Low
P0AB400Hybrid Battery Pack Air Temperature Sensor "B" Circuit High
P0ABB00Hybrid Battery Pack Voltage Sense "A" Circuit Range/Performance
P0ABC00Hybrid Battery Pack Voltage Sense "A" Circuit Low
P0ABD00Hybrid Battery Pack Voltage Sense "A" Circuit High
P0ABF00Hybrid Battery Pack Current Sensor "A" Circuit
P0AC000Hybrid Battery Pack Current Sensor "A" Circuit Range/Performance
P0AC100Hybrid Battery Pack Current Sensor "A" Circuit Low
P0AC200Hybrid Battery Pack Current Sensor "A" Circuit High
P0AC700Hybrid Battery Temperature Sensor "B" Circuit Low
P0AC800Hybrid Battery Temperature Sensor "B" Circuit High
P0AED00Drive Motor Inverter Temperature Sensor "A" Circuit
P0AEE00Drive Motor Inverter Temperature Sensor "A" Circuit Range/Performance
P0AEF00Drive Motor Inverter Temperature Sensor "A" Circuit Low
P0AF000Drive Motor Inverter Temperature Sensor "A" Circuit High
P0AF800Hybrid Battery System Voltage
P0AFA00Hybrid Battery System Voltage Low
P0AFB00Hybrid Battery System Voltage High
P0AFC00Hybrid Battery Pack Sensor Module
P0AFD00Hybrid Battery Pack Temperature Too Low
P0B1500Hybrid Battery Pack Voltage Sense "B" Circuit Range/Performance
P0B1600Hybrid Battery Pack Voltage Sense "B" Circuit Low
P0B1700Hybrid Battery Pack Voltage Sense "B" Circuit High
P0B2400Hybrid Battery "A" Voltage Unstable
P0B2500Hybrid Battery "A" Voltage Low
P0B2600Hybrid Battery "A" Voltage High
P0B2900Hybrid Battery "B" Voltage Low
P0B2A00Hybrid Battery "B" Voltage High
P100000Cyl.9-Fuel Inj.Circ. -N299 Malfunction
P100100Cyl.10-Fuel Inj.Circ. -N300 Malfunction
P100200Cyl.11-Fuel Inj.Circ. -N301 Malfunction
P100300Cyl.12-Fuel Inj.Circ. -N302 Malfunction
P100400Torque difference cylinder 1 Limiting value exceeded
P100500Torque difference cylinder 2 Limiting value exceeded
P100600Torque difference cylinder 3 Limiting value exceeded
P100700Torque difference cylinder 4 Limiting value exceeded
P100800Air mass meter 1/2 Implausible signal
P100900Air mass meter 1/2 implausible signal from load detection
P100A00Recirculating valve for turbocharger bank 2 Electrical malfunction
P100B00Recirculating valve for turbocharger bank 2 Short-circuit to ground
P100C00Recirculating valve for turbocharger bank 2 Short circuit to B+
P100D00Turbocharger Adjustment difficulty of movement or blocked
P100E00Torque intervention due to turbocharger protection
P100F00Fuel injector Mechanical malfunction
P101000Cyl.9-Fuel Inj.Circ. -N299 Open circuit
P101100Cyl.10-Fuel Inj.Circ. -N300 Open circuit
P101200Cyl.11-Fuel Inj.Circ. -N301 Open circuit
P101300Cyl.12-Fuel Inj.Circ. -N302 Open circuit
P101400Bypass Flap Filter Valve -N275- Short circuit to B+
P101500Bypass Flap Filter Valve -N275- Short-circuit to ground
P101600Bypass Flap Filter Valve -N275- Open circuit
P101700Intake Manifold Runner Bank 2 Upper stop not reached
P101800Intake Manifold Runner Bank 2 lower limit not reached
P101900NOX Sensor -G295 Slow Response
P101A00Activation of turbocharger adjustment Short circuit to ground/open circuit
P101B00Activation of turbocharger adjustment Short circuit to B+
P101C00Activation of turbocharger adjustment bank 2 Short circuit to ground/open circuit
P101D00Activation of turbocharger adjustment bank 2 Short circuit to B+
P101E00Rpm limit due to excess temperature
P101F00Fuel high pressure Maximum exceeded
P102000Fuel Pressure Regulation Value above upper control limit
P102100'A' Camshaft Position (Bank 1) Timing Over-Advanced or System Performance
P102200'A' Camshaft Position (Bank 1) Timing Over-Advanced or System Performance
P102300Fuel Pressure Regulator Valve Short-circuit to ground
P102400Fuel Pressure Regulator Valve Open circuit
P102500Fuel Pressure Regulator Valve Mechanical malfunction
P102600Intake manifold Runner Control (IMRC) Short circuit to B+
P102700Intake manifold Runner Control (IMRC) Short-circuit to ground
P102800Intake manifold Runner Control (IMRC) Open circuit
P102900Intake Manifold Runner Control (IMRC) Valve -N316- Upper stop not reached
P102A00Torque limitation due to coolant temperature
P102B00Torque limitation due to engine oil temperature
P102C00Torque limitation due to fuel temperature
P102D00Torque limitation due to intake air temperature
P102E00Torque limitation due to exhaust temperature
P103000Intake Manifold Runner Control (IMRC) Valve -N316- lower limit not reached
P103100Intake Manifold Runner Control (IMRC) Valve -N316- Target value not reached
P103200NOX Sensor Signal too high
P103300NOX Sensor Signal too low
P103400NOX Sensor Signal outside tolerance
P103500NOX Sensor Implausible signal
P103600Heater activation sensor for NOX Short circuit to B+
P103700Heater activation sensor for NOX Short-circuit to ground
P103800Heater activation sensor for NOX Open circuit
P103900Fuel Injector Group "A" Supply Voltage Circuit Short circuit
P104000Fuel Injector Group "A" Supply Voltage Circuit Malfunction
P104100Fuel Injector Group "B" Supply Voltage Circuit Short circuit
P104200Fuel Injector Group "B" Supply Voltage Circuit Malfunction
P104300Fuel Injector Group -C- Supply Voltage Circuit Short circuit
P104400Fuel Injector Group C - Supply voltage circuit Malfunction
P104500Fuel Injector Group -D- Supply Voltage Circuit Short circuit
P104600Fuel Injector Group -D- Supply Voltage Circuit Malfunction
P104700Bank1, Camshaft Adjustment Valve 1 (exhaust) -N318- Malfunction
P104800Bank1, Camshaft Adjustment Valve 1 (exhaust) -N318- Short circuit to B+
P104900Bank1, Camshaft Adjustment Valve 1 (exhaust) -N318- Short-circuit to ground
P105000Bank1, Camshaft Adjustment Valve 1 (exhaust) -N318- Open circuit
P105100Bank2, Camshaft Adjustment Valve2 (exhaust) -N319- Malfunction
P105200Bank2, Camshaft Adjustment Valve2 (exhaust) -N319- Short circuit to B+
P105300Bank2, Camshaft Adjustment Valve2 (exhaust) -N319- Short-circuit to ground
P105400Bank2, Camshaft Adjustment Valve2 (exhaust) -N319- Open circuit
P105500Bank 1, camshaft adjustment, exhaust Short circuit to B+
P105600Bank 1, camshaft adjustment, exhaust Short-circuit to ground
P105700Bank 1, camshaft adjustment, exhaust Open circuit
P105800Bank2, camshaft adjustment, exhaust Short circuit to B+
P105900Bank2, camshaft adjustment, exhaust Short-circuit to ground
P106000Bank2, camshaft adjustment, exhaust Open circuit
P106100'A' Camshaft Position (Bank 2) Timing Over-Advanced or System Performance
P106200'A' Camshaft Position (Bank 2) Timing Over-Advanced or System Performance
P106300Fuel Pressure Regulation Value below lower control limit
P106400Fuel pressure system Mechanical malfunction
P106500Fuel Pressure Regulation Control difference
P106600Intake Air Switch-over valve -N335- Short circuit to B+
P106700Intake Air Switch-over valve -N335- Short-circuit to ground
P106800Intake Air Switch-over valve -N335- Open circuit
P106900NOX Sensor -G295- heating control signal Short-circuit to ground
P106A00Bank 2 Intake manifold press/air mass <-> throttle valve angle deviation
P106B00Throttle valve difficulty of movement or blocked
P106C00Throttle valve 2 difficulty of movement or blocked
P107000NOX Sensor -G295- heating control signal Short circuit to B+
P107100NOX Sensor -G295- heating control signal Implausible signal
P107200NOX Sensor -G295- heating control signal Electrical malfunction in circuit
P107300Mass Air Flow (MAF) Sensor 2 -G246 Signal too low
P107400Mass Air Flow (MAF) Sensor 2 -G246 Signal too high
P107500Oxygen sensor control, emissions bank 3 System too lean
P107600Oxygen sensor control, emissions bank 3 System too rich
P107700Oxygen sensor control, emissions bank 4 System too lean
P107800Oxygen sensor control, emissions bank 4 System too rich
P107900Oxygen sensor control, emissions bank 3 Implausible control value
P108000Oxygen sensor control, emissions bank 4 Implausible control value
P108100Exhaust bank3, mixture adaptation range 1 System too lean
P108200Exhaust bank3, mixture adaptation range 2 System too lean
P108300Exhaust bank3, mixture adaptation range 1 System too rich
P108400Exhaust bank3, mixture adaptation range 2 System too rich
P108500Exhaust bank4, mixture adaptation range 1 System too lean
P108600Exhaust bank4, mixture adaptation range 2 System too lean
P108700Exhaust bank4, mixture adaptation range 1 System too rich
P108800Exhaust bank4, mixture adaptation range 2 System too rich
P108900Bank2, mixture adaptation range 1 System too lean
P109000Bank2, mixture adaptation range 2 System too lean
P109100Bank2, mixture adaptation range 1 System too rich
P109200Bank2, mixture adaptation range 2 System too rich
P109300Bank1, fuel measuring system 2 Malfunction
P109400Bank2, fuel measuring system 2 Malfunction
P109500Intake Manifold Runner Position Sensor -G336 Short circuit to B+
P109600Intake Manifold Runner Position Sensor -G336 Short-circuit to ground
P109700Intake Manifold Runner Position Sensor -G336 Open circuit
P109800Intake Manifold Runner Position Sensor -G336 Open circuit/short circuit to B+
P109900Intake manifold Runner Control (IMRC) Electrical malfunction
P10A000Actuation regulating flap for intake air Electrical malfunction
P10A100Actuation regulating flap for intake air Short circuit to B+
P10A200Actuation regulating flap for intake air Short-circuit to ground
P10A300Actuation regulating flap for intake air Open circuit
P10A400Regulating flap for intake air Mechanical malfunction
P10A500Potentiometer regulating flap for intake air Signal too high
P10A600Potentiometer regulating flap for intake air Signal too low
P10A700Adaptation regulating flap for intake air soiled
P10A800Adaptation regulating flap for intake air lower limit not reached
P10A900Magnetic clutch for mechanical charger does not open
P10AA00Magnetic clutch for mechanical charger does not close
P10AB00Magnetic clutch for mechanical charger excessive wear
P10AC00Magnetic clutch for mechanical charger Short-circuit to ground
P10AD00Magnetic clutch for mechanical charger Open circuit
P10AE00Current sensor for magnetic clutch for mechanical charger Electrical malfunction
P10AF00Magnetic clutch for mechanical charger Malfunction
P10B000Magnetic clutch for mechanical charger Short circuit to B+
P10B100Monitoring of fuel injector for cylinder 1 failure detected
P10B200Monitoring of fuel injector for cylinder 2 failure detected
P10B300Monitoring of fuel injector for cylinder 3 failure detected
P10B400Monitoring of fuel injector for cylinder 4 failure detected
P110000O2 Sensor Heater Circ.,Bank1-Sensor2 Performance too low
P110100O2 Sensor Circuit,Bank1-Sensor1 Voltage too low/air leak
P110200O2 Sensor Heater Circ.,Bank1-Sensor1 Short circuit to B+
P110300O2 Sensor Heater Circ.,Bank1-Sensor1 Performance too low
P110400O2 Sensor Circuit,Bank1-Sensor2 Voltage too low/air leak
P110500O2 Sensor Heater Circ.,Bank1-Sensor2 Short circuit to B+
P110600O2 Sensor Circuit,Bank2-Sensor1 Voltage too low/air leak
P110700O2 Sensor Heater Circ.,Bank2-Sensor1 Short circuit to B+
P110800O2 Sensor Heater Circ.,Bank2-Sensor1 Performance too low
P110900O2 Sensor Circuit,Bank2-Sensor2 Voltage too low/air leak
P110A00Fuel Pressure Regulator Valve Short-circuit to ground
P110B00Fuel Pressure Regulator Valve Open circuit
P110C00Fuel Pressure Regulator Valve Mechanical malfunction
P110D00Intake manifold Runner Control (IMRC) Short circuit to B+
P110E00Intake manifold Runner Control (IMRC) Short-circuit to ground
P110F00Intake manifold Runner Control (IMRC) Open circuit
P111000O2 Sensor Heater Circ.,Bank2-Sensor2 Short circuit to B+
P111100Oxygen sensor control (Bank 1) System too lean
P111200Oxygen sensor control (Bank 1) System too rich
P111300Bank 1, sensor 1 Internal resistance too Large
P111400Bank 1, sensor 2 Internal resistance too Large
P111500O2 Sensor Heater Circ.,Bank1-Sensor1 Short-circuit to ground
P111600O2 Sensor Heater Circ.,Bank1-Sensor1 Open circuit
P111700O2 Sensor Heater Circ.,Bank1-Sensor2 Short-circuit to ground
P111800O2 Sensor Heater Circ.,Bank1-Sensor2 Open circuit
P111900O2 Sensor Heater Circ.,Bank2-Sensor1 Short-circuit to ground
P111A00NOX Sensor -G295 Signal too low
P111B00NOX Sensor -G295 Signal outside tolerance
P111C00NOX Sensor -G295 Implausible signal
P111D00Heater activation sensor for NOX Short circuit to B+
P111E00Heater activation sensor for NOX Short-circuit to ground
P111F00Heater activation sensor for NOX Open circuit
P112000O2 Sensor Heater Circ.,Bank2-Sensor1 Open circuit
P112100O2 Sensor Heater Circ.,Bank2-Sensor2 Short-circuit to ground
P112200O2 Sensor Heater Circ.,Bank2-Sensor2 Open circuit
P112300Long Term Fuel Trim Add.Air.,Bank1 System too rich
P112400Long Term Fuel Trim Add.Air.,Bank1 System too lean
P112500Long Term Fuel Trim Add.Air.,Bank2 System too rich
P112600Long Term Fuel Trim Add.Air.,Bank2 System too lean
P112700Long Term Fuel Trim mult.,Bank1 System too rich
P112800Long Term Fuel Trim mult.,Bank1 System too lean
P112900Long Term Fuel Trim mult.,Bank2 System too rich
P113000Long Term Fuel Trim mult.,Bank2 System too lean
P113100Bank 2, sensor 1 Internal resistance too Large
P113200O2 Sensor Heating Circ.,Bank1+2-Sensor1 Short circuit to B+
P113300O2 Sensor Heating Circ.,Bank1+2-Sensor1 Malfunction
P113400O2 Sensor Heating Circ.,Bank1+2-Sensor2 Short circuit to B+
P113500O2 Sensor Heating Circ.,Bank1+2-Sensor2 Malfunction
P113600Long Term Fuel Trim Add.Fuel,Bank1 System too lean
P113700Long Term Fuel Trim Add.Fuel,Bank1 System too rich
P113800Long Term Fuel Trim Add.Fuel,Bank2 System too lean
P113900Long Term Fuel Trim Add.Fuel,Bank2 System too rich
P114000Bank 2, sensor 2 Internal resistance too Large
P114100Load detection implausible value
P114200Load detection value below lower limit
P114300Load detection value above upper limit
P114400Mass Air Flow (MAF) Sensor -G70- Open circuit/short circuit to ground
P114500Mass Air Flow (MAF) Sensor -G70- Short circuit to B+
P114600Mass Air Flow (MAF) Sensor -G70- Supply voltage
P114700Oxygen sensor control, Bank 2 System too lean
P114800Oxygen sensor control, Bank 2 System too rich
P114900Oxygen sensor control, Bank 1 Implausible control value
P115000Oxygen sensor control, Bank 2 Implausible control value
P115100Bank1, mixture adaptation, range 1 System too lean
P115200Bank1, mixture adaptation, range 2 System too lean
P115300Oxygen sensors behind catalytic converter Swapped
P115400Two-path intake manifold Malfunction
P115500Manifold Absolute Pressure (MAP) Sensor -G71 Short circuit to B+
P115600Manifold Absolute Pressure (MAP) Sensor -G71 Open circuit/short circuit to ground
P115700Manifold Absolute Pressure (MAP) Sensor -G71 Supply voltage
P115800Manifold Absolute Pressure (MAP) Sensor -G71 Implausible signal
P115900Signal of Mass Air Flow (MAF) sensor 1/2 Implausible relation
P115A00Manifold Absolute Pressure (MAP) Sensor 2 Implausible signal
P115B00Manifold Absolute Pressure (MAP) Sensor 2 Signal too low
P115C00Manifold Absolute Pressure (MAP) Sensor 2 Signal too high
P115D00Sensor 2 for air pressure Implausible signal
P115E00Sensor 2 for air pressure Signal too low
P115F00Sensor 2 for air pressure Signal too high
P116000Manifold Temp.Sensor Circ. -G72 Short-circuit to ground
P116100Manifold Temp.Sensor Circ. -G72 Open circuit/short circuit to B+
P116200Fuel Temperature Sensor A Circuit Low Input -G81 Short-circuit to ground
P116300Fuel Temperature Sensor A Circuit Low Input -G81 Open circuit/short circuit to B+
P116400Fuel Temperature Sensor A Circuit Low Input -G81 Implausible signal
P116500Bank1, mixture adaptation, range 1 System too rich
P116600Bank1, mixture adaptation, range 2 System too rich
P116700Mass Air Flow (MAF) Sensor 2 -G246 Implausible signal
P116800Mass Air Flow (MAF) Sensor 2 -G246 Open circuit/short circuit to ground
P116900Mass Air Flow (MAF) Sensor 2 -G246 Short circuit to B+
P116A00Intake manifold press./air press. - Throttle valve pos. bank 2 Correlation at idle
P116B00Intake manifold press./air press. - Throttle valve pos. bank 2 Correlation in partial throttle
P116C00Leaking air in intake system, bank 2
P116F00Mass air flow sensor interrupted signal
P117000Mass Air Flow (MAF) Sensor 2 -G246 Supply voltage
P117100Throttle/Pedal Position Sensor/Switch -B- Circuit -G188 Implausible signal
P117200Throttle/Pedal Position Sensor/Switch -B- Circuit -G188 Signal too low
P117300Throttle/Pedal Position Sensor/Switch -B- Circuit -G188 Signal too high
P117400Bank 1, fuel calculation system Injection Timing Deviation
P117500Pre-injection switched off
P117600O2 Correction Behind Catalyst,B1 Control limit reached
P117700O2 Correction Behind Catalyst,B2 Control limit reached
P117800Linear oxygen sensor/pump current Open circuit
P117900Linear oxygen sensor/pump current Short-circuit to ground
P117A00Bank1, Lambda correction center sensor Control limit reached
P117B00Bank2, Lambda correction center sensor Control limit reached
P117C00Bank3,oxygen sensor correction behind cat Lean control limit exceeded
P117D00Bank3,oxygen sensor correction behind cat Rich control limit exceeded
P117E00Bank4,oxygen sensor correction behind cat Lean control limit exceeded
P117F00Bank4,oxygen sensor correction behind cat Rich control limit exceeded
P118000Linear oxygen sensor/pump current Short circuit to B+
P118100Linear oxygen sensor/reference voltage Open circuit
P118200Linear oxygen sensor/reference voltage Short-circuit to ground
P118300Linear oxygen sensor/reference voltage Short circuit to B+
P118400linear Lambda probe / common ground wire Open circuit
P118500linear Lambda probe / common ground wire Short-circuit to ground
P118600linear Lambda probe / common ground wire Short circuit to B+
P118700linear Lambda probe/compensat. resistor Open circuit
P118800linear Lambda probe/compensat. resistor Short-circuit to ground
P118900linear Lambda probe/compensat. resistor Short circuit to B+
P118A00Bank3-sensor1 Voltage too low/air leak
P118B00Bank4-sensor1 Voltage too low/air leak
P119000Linear oxygen sensor/reference voltage Implausible
P119100linear Lambda probe before catalyst swapped
P119200Fuel Pressure Sensor -G247- Supply voltage
P119300Fuel Pressure Sensor -G247- Open circuit/short circuit to B+
P119400Fuel Pressure Regulator Valve Short circuit to B+
P119500Fuel Pressure Regulator Valve Open circuit/short circuit to ground
P119600O2 Sensor Heater Circ.,Bank1-Sensor1 Malfunction
P119700O2 Sensor Heater Circ.,Bank2-Sensor1 Malfunction
P119800O2 Sensor Heater Circ.,Bank1-Sensor2 Malfunction
P119900O2 Sensor Heater Circ.,Bank2-Sensor2 Malfunction
P119A00Fuel Pressure Sensor -G247- Malfunction
P119B00Fuel pressure sensor 2 Malfunction
P119C00Fuel Volume Regulator Control Exceeded Learning lower Limit
P119D00Fuel Volume Regulator Control Exceeded Learning upper Limit
P11A100Cam Shift Actuator "A" Cylinder 1 Circuit/Open
P11A200Cam Shift Actuator "A" Cylinder 1 Range/Performance
P11A300Cam Shift Actuator "B" Cylinder 1 Circuit/Open
P11A400Cam Shift Actuator "B" Cylinder 1 Range/Performance
P11A500Cam Shift Actuator "A" Cylinder 2 Circuit/Open
P11A600Cam Shift Actuator "A" Cylinder 2 Range/Performance
P11A700Cam Shift Actuator "B" Cylinder 2 Circuit/Open
P11A800Cam Shift Actuator "B" Cylinder 2 Range/Performance
P11A900Cam Shift Actuator "A" Cylinder 3 Circuit/Open
P11AA00Cam Shift Actuator "A" Cylinder 3 Range/Performance
P11AB00Cam Shift Actuator "B" Cylinder 3 Circuit/Open
P11AC00Cam Shift Actuator "B" Cylinder 3 Range/Performance
P11AD00Cam Shift Actuator "A" Cylinder 4 Circuit/Open
P11AE00Cam Shift Actuator "A" Cylinder 4 Range/Performance
P11AF00Cam Shift Actuator "B" Cylinder 4 Circuit/Open
P11B000Cam Shift Actuator "B" Cylinder 4 Range/Performance
P11B100Cam Shift Actuator "A" Cylinder 5 Circuit/Open
P11B200Cam Shift Actuator "A" Cylinder 5 Range/Performance
P11B300Cam Shift Actuator "B" Cylinder 5 Circuit/Open
P11B400Cam Shift Actuator "B" Cylinder 5 Range/Performance
P11B500Cam Shift Actuator "A" Cylinder 6 Circuit/Open
P11B600Cam Shift Actuator "A" Cylinder 6 Range/Performance
P11B700Cam Shift Actuator "B" Cylinder 6 Circuit/Open
P11B800Cam Shift Actuator "B" Cylinder 6 Range/Performance
P11B900Camshaft adjustment bank 1 Supply voltage
P11BA00Camshaft adjustment bank 2 Supply voltage
P120000Recirculating valve for turbocharger -N249, Mechanical malfunction
P120100Cylinder 1 Fuel Injector -N30- electrical malfunction in circuit
P120200Cylinder 2 Fuel Injector -N31- electrical malfunction in circuit
P120300Cylinder 3 Fuel Injector -N32- electrical malfunction in circuit
P120400Cylinder 4 Fuel Injector -N33- electrical malfunction in circuit
P120500Cylinder 5 Fuel Injector -N83- electrical malfunction in circuit
P120600Cylinder 6 Fuel Injector -N84- electrical malfunction in circuit
P120700Cylinder 7 Fuel Injector -N85- electrical malfunction in circuit
P120800Cylinder 8 Fuel Injector -N86- electrical malfunction in circuit
P120900Cylinder Shut-off, Intake Deactivation Valves Short-circuit to ground
P120A00Injectors control module 1 Electrical malfunction in circuit
P120B00Injectors control module 2 Electrical malfunction in circuit
P120C00Injectors control module 1 Short circuit between activation wires, Low-Side
P120D00Injectors control module 2 Short circuit between activation wires, Low-Side
P121000Cylinder Shut-off, Intake Deactivation Valves Short circuit to B+
P121100Cylinder Shut-off, Intake Deactivation Valves Open circuit
P121200Cylinder shut-off, bank 1
P121300Cylinder 1 Fuel Injector -N30- Short circuit to B+
P121400Cylinder 2 Fuel Injector -N31- Short circuit to B+
P121500Cylinder 3 Fuel Injector -N32- Short circuit to B+
P121600Cylinder 4 Fuel Injector -N33- Short circuit to B+
P121700Cylinder 5 Fuel Injector -N83- Short circuit to B+
P121800Cylinder 6 Fuel Injector -N84- Short circuit to B+
P121900Cylinder 7 Fuel Injector -N85- Short circuit to B+
P122000Cylinder 8 Fuel Injector -N86- Short circuit to B+
P122100Cylinder Shut-off, Exhaust Deactivation Valves Short-circuit to ground
P122200Cylinder Shut-off, Exhaust Deactivation Valves Short circuit to B+
P122300Cylinder Shut-off, Exhaust Deactivation Valves Open circuit
P122400Cylinder shut-off, bank 2
P122500Cylinder 1 Fuel Injector -N30- Short-circuit to ground
P122600Cylinder 2 Fuel Injector -N31- Short-circuit to ground
P122700Cylinder 3 Fuel Injector -N32- Short-circuit to ground
P122800Cylinder 4 Fuel Injector -N33- Short-circuit to ground
P122900Cylinder 5 Fuel Injector -N83- Short-circuit to ground
P123000Cylinder 6 Fuel Injector -N84- Short-circuit to ground
P123100Cylinder 7 Fuel Injector -N85- Short-circuit to ground
P123200Cylinder 8 Fuel Injector -N86- Short-circuit to ground
P123300Load detection Malfunction
P123400fuel lead missing
P123500O2 Correction Behind Catalyst, exhaust gas bank 3 Control limit reached
P123600O2 Correction Behind Catalyst, exhaust gas bank 4 Control limit reached
P123700Cylinder 1 Fuel Injector -N30- Open circuit
P123800Cylinder 2 Fuel Injector -N31- Open circuit
P123900Cylinder 3 Fuel Injector -N32- Open circuit
P124000Cylinder 4 Fuel Injector -N33- Open circuit
P124100Cylinder 5 Fuel Injector -N83- Open circuit
P124200Cylinder 6 Fuel Injector -N84- Open circuit
P124300Cylinder 7 Fuel Injector -N85- Open circuit
P124400Cylinder 8 Fuel Injector -N86- Open circuit
P124500Needle Lift Sensor -G80 Short-circuit to ground
P124600Needle Lift Sensor -G80 Implausible signal
P124700Needle Lift Sensor -G80 Open circuit/short circuit to B+
P124800Commencement of injection regulation Control difference
P124900Fuel consumption signal Electrical malfunction in circuit
P125000Fuel level too low
P125100Commencement of injection valve -N108 Short circuit to B+
P125200Commencement of injection valve -N108 Open circuit/short circuit to ground
P125300Fuel consumption signal Short-circuit to ground
P125400Fuel consumption signal Short circuit to B+
P125500Engine Coolant Temperature (ECT) Sensor -G62 Short-circuit to ground
P125600Engine Coolant Temperature (ECT) Sensor -G62 Open circuit/short circuit to B+
P125700Coolant Thermostat/Valve. Open circuit
P125800Coolant Thermostat/Valve. Short circuit to B+
P125900Coolant Thermostat/Valve. Short-circuit to ground
P125E00Valve for pump/injector Short circuit control wire
P125F00Valve for pump/injector not completely discharged
P126000Unit injector solenoid valve - cylinder 1-N240 Implausible signal
P126100Unit injector solenoid valve - cylinder 1-N240 Value above upper control limit
P126200Unit injector solenoid valve - cylinder 1-N240 Value below lower control limit
P126300Unit injector solenoid valve - cylinder 2-N241 Implausible signal
P126400Unit injector solenoid valve - cylinder 2-N241 Value above upper control limit
P126500Unit injector solenoid valve - cylinder 2-N241 Value below lower control limit
P126600Unit injector solenoid valve - cylinder 3-N242 Implausible signal
P126700Unit injector solenoid valve - cylinder 3-N242 Value above upper control limit
P126800Unit injector solenoid valve - cylinder 3-N242 Value below lower control limit
P126900Unit injector solenoid valve - cylinder 4-N243 Implausible signal
P127000Unit injector solenoid valve - cylinder 4-N243 Value above upper control limit
P127100Unit injector solenoid valve - cylinder 4-N243 Value below lower control limit
P127200Unit injector solenoid valve - cylinder 5-N244 Implausible signal
P127300Unit injector solenoid valve - cylinder 5-N244 Value above upper control limit
P127400Unit injector solenoid valve - cylinder 5-N244 Value below lower control limit
P127500Unit injector solenoid valve - cylinder 6-N245 Implausible signal
P127600Unit injector solenoid valve - cylinder 6-N245 Value above upper control limit
P127700Unit injector solenoid valve - cylinder 6-N245 Value below lower control limit
P127800Fuel Metering Valve Short circuit to B+
P127900Fuel Metering Valve Open circuit/short circuit to ground
P128000Fuel Inj.Air Contr.Valve Circ. -N212 Flow too Low
P128100Fuel Metering Valve Short-circuit to ground
P128200Fuel Metering Valve Open circuit
P128300Fuel Inj.Air Contr.Valve Circ. -N212 electrical malfunction in circuit
P128400Fuel Inj.Air Contr.Valve Circ. -N212 Open circuit
P128500Fuel Inj.Air Contr.Valve Circ. -N212 Short-circuit to ground
P128600Fuel Inj.Air Contr.Valve Circ. -N212 Short circuit to B+
P128700Recirculating valve for turbocharger -N249, Open circuit
P128800Recirculating valve for turbocharger -N249, Short circuit to B+
P128900Recirculating valve for turbocharger -N249, Short-circuit to ground
P128F00A/C Engine Coolant Temperature (ECT) Sensor -Radiator Outlet Electrical malfunction
P129000Engine Coolant Temperature (ECT) Sensor (on Radiator) -G83- Signal too high
P129100Engine Coolant Temperature (ECT) Sensor (on Radiator) -G83- Signal too low
P129200Map Controlled Engine Cooling Thermostat -F265- Open circuit
P129300Map Controlled Engine Cooling Thermostat -F265- Short circuit to B+
P129400Map Controlled Engine Cooling Thermostat -F265- Short-circuit to ground
P129500Bypass turbocharger Throughput faulty
P129600Malfunction in cooling system
P129700Connection charger-throttle valve Pressure drop
P129800Engine Coolant Temperature (ECT) Sensor (on Radiator) -G83- Implausible signal
P129900Fuel Metering Valve Malfunction
P129A00Fuel Pressure Regulator Valve -N276, Bank 2 Mechanical malfunction
P129B00Fuel Pressure Regulator Valve -N276, Bank 2 Open circuit
P129C00Fuel Pressure Regulator Valve -N276, Bank 2 Short-circuit to ground
P129D00Fuel Pressure Regulator Valve -N276, Bank 2 Short circuit to B+
P129E00Low Pressure Fuel System Pressure Too Low
P129F00Low Pressure Fuel System Pressure Too High
P12A000Low Pressure Fuel System Performance
P130000Random/Multiple Cylinder. Misfire Detected Reason: Low fuel
P130100Cyl.9-Knock Contr Control limit reached
P130200Cyl.10-Knock Contr Control limit reached
P130300Cyl.11-Knock Contr Control limit reached
P130400Cyl.12-Knock Contr Control limit reached
P130500Ignition control cylinder 9 Open circuit
P130600Ignition control cylinder 9 Short circuit to B+
P130700Ignition control cylinder 9 Short-circuit to ground
P130800Ignition control cylinder 10 Open circuit
P130900Ignition control cylinder 10 Short circuit to B+
P130A00Hide cylinder
P131000Ignition control cylinder 10 Short-circuit to ground
P131100Ignition control cylinder 11 Open circuit
P131200Ignition control cylinder 11 Short circuit to B+
P131300Ignition control cylinder 11 Short-circuit to ground
P131400Ignition control cylinder 12 Open circuit
P131500Ignition control cylinder 12 Short circuit to B+
P131600Ignition control cylinder 12 Short-circuit to ground
P131700Cyl.13-Knock Contr Control limit reached
P131800Cyl.14-Knock Contr Control limit reached
P131900Knock Sensor (KS) 1 -G61 Short-circuit to ground
P132000Knock Sensor (KS) 2 -G66 Short-circuit to ground
P132100Knock Sensor (KS) 3 -G198 Signal too low
P132200Knock Sensor (KS) 3 -G198 Signal too high
P132300Knock Sensor (KS) 4 -G199 Signal too low
P132400Knock Sensor (KS) 4 -G199 Signal too high
P132500Cyl.1-Knock Contr Control limit reached
P132600Cyl.2-Knock Contr Control limit reached
P132700Cyl.3-Knock Contr Control limit reached
P132800Cyl.4-Knock Contr Control limit reached
P132900Cyl.5-Knock Contr Control limit reached
P132A00Knock Sensor (KS) 3 Electrical malfunction in circuit
P132B00Knock Sensor (KS) 4 Electrical malfunction in circuit
P133000Cyl.6-Knock Contr Control limit reached
P133100Cyl.7-Knock Contr Control limit reached
P133200Cyl.8-Knock Contr Control limit reached
P133300Cyl.15-Knock Contr Control limit reached
P133400Cyl.16-Knock Contr Control limit reached
P133500Engine torque monitoring 2 Value above upper control limit
P133600Engine torque monitoring Value above upper control limit
P133700Camshaft Pos. (CMP) Sensor, Bank1=>-G40 Short-circuit to ground
P133800Camshaft Pos. (CMP) Sensor, Bank1=>-G40 Open circuit/short circuit to B+
P133900Crankshaft Pos./Engine Speed Sensor swapped
P134000Camshaft Position Sensor-G40,Engine Speed Sensor-G28 Incorrect allocation
P134100Ignition output 1 Short-circuit to ground
P134200Ignition output 1 Short circuit to B+
P134300Ignition output 2 Short-circuit to ground
P134400Ignition output 2 Short circuit to B+
P134500Ignition output 3 Short-circuit to ground
P134600Ignition output 3 Short circuit to B+
P134700Camshaft Position Sensor 2-G163/Engine Speed (RPM) Sensor -G28 Incorrect allocation
P134800Ignition output 1 Open circuit
P134900Ignition output 2 Open circuit
P135000Ignition output 3 Open circuit
P135100Camshaft Pos. (CMP) Sensor, Bank1=>-G40 Implausible signal during start
P135200Bank1, camshaft adjustment Specification not reached
P135300Engine Coolant Temperature/Intake Air Temperature Correlation
P135400Modulating piston movement sender -G149 electrical malfunction in circuit
P135500Ignition control cylinder 1 Open circuit
P135600Ignition control cylinder 1 Short circuit to B+
P135700Ignition control cylinder 1 Short-circuit to ground
P135800Ignition control cylinder 2 Open circuit
P135900Ignition control cylinder 2 Short circuit to B+
P136000Ignition control cylinder 2 Short-circuit to ground
P136100Ignition control cylinder 3 Open circuit
P136200Ignition control cylinder 3 Short circuit to B+
P136300Ignition control cylinder 3 Short-circuit to ground
P136400Ignition control cylinder 4 Open circuit
P136500Ignition control cylinder 4 Short circuit to B+
P136600Ignition control cylinder 4 Short-circuit to ground
P136700Ignition control cylinder 5 Open circuit
P136800Ignition control cylinder 5 Short circuit to B+
P136900Ignition control cylinder 5 Short-circuit to ground
P137000Ignition control cylinder 6 Open circuit
P137100Ignition control cylinder 6 Short circuit to B+
P137200Ignition control cylinder 6 Short-circuit to ground
P137300Ignition control cylinder 7 Open circuit
P137400Ignition control cylinder 7 Short circuit to B+
P137500Ignition control cylinder 7 Short-circuit to ground
P137600Ignition control cylinder 8 Open circuit
P137700Ignition control cylinder 8 Short circuit to B+
P137800Ignition control cylinder 8 Short-circuit to ground
P137900Cylinder 13 Random/Multiple Cylinder. Misfire Detected
P138000Cylinder 14 Random/Multiple Cylinder. Misfire Detected
P138100Cylinder 15 Random/Multiple Cylinder. Misfire Detected
P138200Cylinder 16 Random/Multiple Cylinder. Misfire Detected
P138300Portion of alternative fuels not adapted
P138400Engine control module 2 faulty
P138500Control module defective
P138600Control module defective
P138700Control module defective
P138800Control module defective
P138900Diesel Direct Fuel Injection (DFI) Engine ECM 2 -J494- Defective
P139100Camshaft Pos. (CMP) Sensor, Bank2=>-G163 Short-circuit to ground
P139200Camshaft Pos. (CMP) Sensor, Bank2=>-G163 Open circuit/short circuit to B+
P139300Ignition output 1 electrical malfunction in circuit
P139400Ignition output 2 electrical malfunction in circuit
P139500Ignition output 3 electrical malfunction in circuit
P139600Engine speed sender -G28 Range/Performance
P139700Sensor Wheel for Engine Speed adaptation limit reached
P139800Engine speed signal, TD Short-circuit to ground
P139900Engine speed signal, TD Short circuit to B+
P139A00Engine speed (RPM) validation
P13A000Signal wire 1 ion current system bank 1 Short circuit to B+
P13A100Signal wire 2 ion current system bank 1 Short circuit to B+
P13A200Signal wire 1 ion current system bank 1 Short-circuit to ground
P13A300Signal wire 2 ion current system bank 1 Short-circuit to ground
P13A400Signal wire 1 ion current system bank 2 Short circuit to B+
P13A500Signal wire 2 ion current system bank 2 Short circuit to B+
P13A600Signal wire 1 ion current system bank 2 Short-circuit to ground
P13A700Signal wire 2 ion current system bank 2 Short-circuit to ground
P13A800Ion current system cylinder 1 Trouble code detected?
P13A900Ion current system cylinder 1 Implausible signal
P13AA00Ion current system cylinder 2 Trouble code detected?
P13AB00Ion current system cylinder 2 Implausible signal
P13AC00Ion current system cylinder 3 Trouble code detected?
P13AD00Ion current system cylinder 3 Implausible signal
P13AE00Ion current system cylinder 4 Trouble code detected?
P13AF00Ion current system cylinder 4 Implausible signal
P13B000Ion current system cylinder 5 Trouble code detected?
P13B100Ion current system cylinder 5 Implausible signal
P13B200Ion current system cylinder 6 Trouble code detected?
P13B300Ion current system cylinder 6 Implausible signal
P13B400Ion current system cylinder 7 Trouble code detected?
P13B500Ion current system cylinder 7 Implausible signal
P13B600Ion current system cylinder 8 Trouble code detected?
P13B700Ion current system cylinder 8 Implausible signal
P13B800Ion current system cylinder 9 Trouble code detected?
P13B900Ion current system cylinder 9 Implausible signal
P13BA00Ion current system cylinder 10 Trouble code detected?
P13BB00Ion current system cylinder 10 Implausible signal
P13BC00Ion current system cylinder 11 Trouble code detected?
P13BD00Ion current system cylinder 11 Implausible signal
P13BE00Ion current system cylinder 12 Trouble code detected?
P13BF00Ion current system cylinder 12 Implausible signal
P13C000Ion current system cylinder 13 Trouble code detected?
P13C100Ion current system cylinder 13 Implausible signal
P13C200Ion current system cylinder 14 Trouble code detected?
P13C300Ion current system cylinder 14 Implausible signal
P13C400Ion current system cylinder 15 Trouble code detected?
P13C500Ion current system cylinder 15 Implausible signal
P13C600Ion current system cylinder 16 Trouble code detected?
P13C700Ion current system cylinder 16 Implausible signal
P13C800Ion current system bank 1, Initialization error channel 1
P13C900Ion current system bank 1, Initialization error channel 2
P13CA00Ion current system bank 1, Initialization error channel 1/2
P13CB00Ion current system bank 2, Initialization error channel 1
P13CC00Ion current system bank 2, Initialization error channel 2
P13CD00Ion current system bank 2, Initialization error channel 1/2
P13CE00Sensor for internal pressure of cylinder 1 Electrical malfunction
P13CF00Sensor for internal pressure of cylinder 1 Short circuit to ground
P13D000Sensor for internal pressure of cylinder 1 Implausible signal
P13D100Sensor for internal pressure of cylinder 2 Electrical malfunction
P13D200Sensor for internal pressure of cylinder 2 Short circuit to ground
P13D300Sensor for internal pressure of cylinder 2 Implausible signal
P13D400Sensor for internal pressure of cylinder 3 Electrical malfunction
P13D500Sensor for internal pressure of cylinder 3 Short circuit to ground
P13D600Sensor for internal pressure of cylinder 3 Implausible signal
P13D700Sensor for internal pressure of cylinder 4 Electrical malfunction
P13D800Sensor for internal pressure of cylinder 4 Short circuit to ground
P13D900Sensor for internal pressure of cylinder 4 Implausible signal
P13DA00Sensor for internal pressure of cylinder 5 Electrical malfunction
P13DB00Sensor for internal pressure of cylinder 5 Short circuit to ground
P13DC00Sensor for internal pressure of cylinder 5 Implausible signal
P13DD00Sensor for internal pressure of cylinder 6 Electrical malfunction
P13DE00Sensor for internal pressure of cylinder 6 Short circuit to ground
P13DF00Sensor for internal pressure of cylinder 6 Implausible signal
P13E000Sensor for internal pressure of cylinder 1 Malfunction
P13E100Sensor for internal pressure of cylinder 2 Malfunction
P13E200Sensor for internal pressure of cylinder 3 Malfunction
P13E300Sensor for internal pressure of cylinder 4 Malfunction
P13E400Sensor for internal pressure of cylinder 5 Malfunction
P13E500Sensor for internal pressure of cylinder 6 Malfunction
P13EA00Cold Start Ignition Timing Performance Off Idle
P140000EGR Vacuum Regulator Solenoid Valve electrical malfunction in circuit
P140100EGR Vacuum Regulator Solenoid Valve Short-circuit to ground
P140200EGR Vacuum Regulator Solenoid Valve Short circuit to B+
P140300Exhaust gas recirculation system Control difference
P140400Exhaust gas recirculation system Basic settings not carried out
P140500Exhaust gas recirculation valve 2 -N213 Malfunction
P140600EGR Temp.Sensor -G98 Implausible signal
P140700EGR Temp.Sensor -G98 Signal too low
P140800EGR Temp.Sensor -G98 Signal too high
P140900Evaporative Emission (EVAP) Canister Purge Regulator Valve -N80 electrical malfunction in circuit
P140A00EGR system 2 bank 1 Control difference
P140B00EGR system 2 bank 2 Control difference
P140C00EGR sensor 2 bank 1 Signal too low
P140D00EGR sensor 2 bank 2 Signal too low
P140E00EGR sensor 2 bank 1 Signal too high
P140F00EGR sensor 2 bank 2 Signal too high
P141000Evaporative Emission (EVAP) Canister Purge Regulator Valve -N80 Short circuit to B+
P141100Bank2, secondary air system Flow too Low
P141200Pressure sensor for exhaust gas recirculation Signal too low
P141300Pressure sensor for exhaust gas recirculation Signal too high
P141400Bank2, secondary air system leak detected
P141500EGR valve, curve adaptation characteristic curve adaptation Lower limit exceeded
P141600EGR valve, curve adaptation Upper limit exceeded
P141700Fuel Level Sensor (A) Circuit Signal too low
P141800Fuel Level Sensor (A) Circuit Signal too high
P141900Exhaust Gas Recirculation (EGR) Cool Switch-over Valve 2 -N381 Short circuit to B+
P141A00Exhaust temperature sensor 3 bank 2 Electrical malfunction
P141B00Exhaust temperature sensor 3 bank 2 Implausible signal
P141C00Exhaust temperature sensor 3 bank 2 Short-circuit to ground
P141D00Exhaust temperature sensor 3 bank 2 Short circuit to B+
P141E00Exhaust Gas Recirculation Contr. Circuit Bank 2 Control difference
P141F00Exhaust gas temperature sensors Implausible
P142000Secondary air inlet valve-N112 electrical malfunction in circuit
P142100Secondary air inlet valve-N112 Short-circuit to ground
P142200Secondary air inlet valve-N112 Short circuit to B+
P142300Bank1, secondary air system Flow too Low
P142400Bank1, secondary air system leak detected
P142500Evaporative Emission (EVAP) Canister Purge Regulator Valve -N80 Short-circuit to ground
P142600Evaporative Emission (EVAP) Canister Purge Regulator Valve -N80 Open circuit
P142700Brake vacuum pump activation Short circuit to B+
P142800Brake vacuum pump activation Short-circuit to ground
P142900Brake vacuum pump activation Open circuit
P142A00Exhaust Gas Temperature Sensor 2 and 3 Circuit - Bank 1 deviation
P142B00Exhaust Gas Temperature Sensor 2 and 3 Circuit - Bank 2 deviation
P142C00Exhaust Gas Temperature Sensor 2 Circuit - Bank 1 and 2 deviation
P142D00Exhaust Gas Temperature Sensor 3 Circuit - Bank 1 and 2 deviation
P142E00EGR valve 2 bank 1 electrical malfunction in circuit
P142F00EGR valve 2 bank 2 electrical malfunction in circuit
P143000Brake vacuum pump activation Open circuit/short circuit to B+
P143100Brake vacuum pump activation Open circuit/short circuit to ground
P143200Secondary air inlet valve-N112 Open circuit
P143300Secondary Air Injection (AIR) Pump Relay -J299 Open circuit
P143400Secondary Air Injection (AIR) Pump Relay -J299 Short circuit to B+
P143500Secondary Air Injection (AIR) Pump Relay -J299 Short-circuit to ground
P143600Secondary Air Injection (AIR) Pump Relay -J299 electrical malfunction in circuit
P143700EGR Vacuum Regulator Solenoid Valve 2 Short circuit to B+
P143800EGR Vacuum Regulator Solenoid Valve 2 Open circuit/short circuit to ground
P143900Exhaust gas recirculation potentiometer -G212 Malfunction in basic settings
P143A00Bank 2 Particle Filter Post-Injection Metering Pump -V337- Short circuit to B+
P143B00Bank 2 Particle Filter Post-Injection Metering Pump -V337- Short circuit to ground/open circuit
P143C00Bank 1 Particle Filter Post-Injection Metering Pump -V336- Short circuit to B+
P143D00Bank 1 Particle Filter Post-Injection Metering Pump -V336- Short circuit to ground/open circuit
P143E00Particle Filter Post-Injection Metering Pump -V335- Short circuit to B+
P143F00Particle Filter Post-Injection Metering Pump -V335- Short circuit to ground/open circuit
P144000EGR Vacuum Regulator Solenoid Valve Open circuit
P144100EGR Vacuum Regulator Solenoid Valve Open circuit/short circuit to ground
P144200Exhaust gas recirculation potentiometer -G212 Signal too high
P144300Exhaust gas recirculation potentiometer -G212 Signal too low
P144400Exhaust gas recirculation potentiometer -G212 Implausible signal
P144500Catalyst Temp.Sensor 2 Circ. -G132 Implausible signal
P144600Catalyst Temp.Sensor 1 Circ. -G20 Short-circuit to ground
P144700Catalyst Temp.Sensor 1 Circ. -G20 Open circuit/short circuit to B+
P144800Catalyst Temp.Sensor 2 Circ. -G132 Short-circuit to ground
P144900Catalyst Temp.Sensor 2 Circ. -G132 Open circuit/short circuit to B+
P144A00EGR system 2 bank 1 Malfunction
P144B00EGR system 2 bank 2 Malfunction
P144C00EGR sensor 2 bank 1 Malfunction in basic settings
P144D00EGR sensor 2 bank 2 Malfunction in basic settings
P144E00EGR Vacuum Regulator Solenoid Valve 2 Electrical malfunction
P144F00EGR Vacuum Regulator Solenoid Valve 2 Open circuit
P145000Secondary air system Short circuit to B+
P145100Secondary air system Short-circuit to ground
P145200Secondary air system Open circuit
P145300Exhaust Gas Temperature Sensor 1 Circuit, Bank 1 -G235- Open circuit/short circuit to B+
P145400Exhaust Gas Temperature Sensor 1 Circuit, Bank 1 -G235- Short-circuit to ground
P145500Exhaust Gas Temperature Sensor 1 Circuit, Bank 1 -G235- Implausible signal
P145600Exhaust Gas Temperature Control Bank 1 Control limit reached
P145700Exhaust temperature sensor 1 bank 2 - G236 Open circuit/short circuit to B+
P145800Exhaust temperature sensor 1 bank 2 - G236 Short-circuit to ground
P145900Exhaust temperature sensor 1 bank 2 - G236 Implausible signal
P145A00Exhaust Gas Temperature Sensor 3 Circuit Electrical malfunction
P145B00Exhaust Gas Temperature Sensor 3 Circuit Implausible signal
P145C00Exhaust Gas Temperature Sensor 3 Circuit Short-circuit to ground
P145D00Exhaust Gas Temperature Sensor 3 Circuit Short circuit to B+
P145E00Air mass throughput in regeneration operation is too low
P145F00Mass air flow in regeneration operation too high
P146000Exhaust Gas Temperature Control Bank 2 Control limit reached
P146100Exhaust Gas Temperature Control Bank 1 Implausible signal
P146200Exhaust Gas Temperature Control Bank 2 Implausible signal
P146300Sec.Air Inj.Sys., Bank 3 Malfunction
P146400Sec.Air Inj.Sys., Bank 4 Malfunction
P146500Metering pump for cleaning solution Short circuit to B+
P146600Metering pump for cleaning solution Open circuit/short circuit to ground
P146700Evaporative Emission (EVAP) Canister Purge Solenoid -N115 Short circuit to B+
P146800Evaporative Emission (EVAP) Canister Purge Solenoid -N115 Short-circuit to ground
P146900Evaporative Emission (EVAP) Canister Purge Solenoid -N115 Open circuit
P146A00Malfunction Diesel particle filter bank 1 Temperature increase too low
P146B00Malfunction Diesel particle filter bank 2 Temperature increase too low
P146C00Acknowledgement of heating 1 for reducing agent Electrical malfunction
P146D00Acknowledgement of heating 1 for reducing agent Short circuit to B+
P146E00Acknowledgement of heating 2 for reducing agent Electrical malfunction
P146F00Acknowledgement of heating 2 for reducing agent Short circuit to B+
P147000Leak diagnosis pump - tank breather system electrical malfunction in circuit
P147100Leak diagnosis pump - tank breather system Short circuit to B+
P147200Leak diagnosis pump - tank breather system Short-circuit to ground
P147300Leak diagnosis pump - tank breather system Open circuit
P147400Evaporative Emission (EVAP) Canister Purge Solenoid -N115 Electrical malfunction in circuit
P147500Leak diagnosis pump - tank breather system malfunction/no signal
P147600Leak diagnosis pump - tank breather system malfunction/vacuum to low
P147700Leak diagnosis pump - tank breather system Malfunction
P147800Leak diagnosis pump - tank breather system blocked pipe detected
P147900Brake vacuum system Mechanical malfunction
P147A00Brake vacuum pump activation Electrical malfunction
P148000Brake vacuum pump
P148100Secondary Air Injection (AIR) Pump Relay 2 -J545- Open circuit
P148200Secondary Air Injection (AIR) Pump Relay 2 -J545- Short circuit to B+
P148300Secondary Air Injection (AIR) Pump Relay 2 -J545- Short-circuit to ground
P148400Secondary Air Injection (AIR) Pump Relay 2 -J545- electrical malfunction in circuit
P148500Secondary Air Injection (AIR) Solenoid Valve 2 -N320- Open circuit
P148600Secondary Air Injection (AIR) Solenoid Valve 2 -N320- electrical malfunction in circuit
P148700Secondary Air Injection (AIR) Solenoid Valve 2 -N320- Short-circuit to ground
P148800Secondary Air Injection (AIR) Solenoid Valve 2 -N320- Short circuit to B+
P148900Evaporative Emission (EVAP) Canister Purge Regulator -N333 Short circuit to B+
P148A00Sensor for reducing agent fill level Implausible fill level
P148B00End stage for reducing agent heating Defective
P148C00End stage 2 for reducing agent heating Defective
P148F00Exhaust Gas Recirculation (EGR) Cool Switch-Over Valve 2 Electrical malfunction
P149000Evaporative Emission (EVAP) Canister Purge Regulator -N333 Short-circuit to ground
P149100Evaporative Emission (EVAP) Canister Purge Regulator -N333 Open circuit
P149200Evaporative Emission (EVAP) Canister Purge Regulator -N333 electrical malfunction in circuit
P149300Brake vacuum pump Performance too low
P149400EVAP Emission Control System 2 Throughput faulty
P149500Radiator Exhaust Gas Recirculation Switch-over Valve -N345 Open circuit/short circuit to ground
P149600Radiator Exhaust Gas Recirculation Switch-over Valve -N345 Short circuit to B+
P149700Sec.Air Inj.Sys., Bank 3 Incorrect Flow Detected
P149800Sec.Air Inj.Sys., Bank 4 Incorrect Flow Detected
P149900Exhaust Gas Recirculation (EGR) Cool Switch-over Valve 2 -N381 Open circuit/short circuit to ground
P149A00EGR Coolant pump Short-circuit to ground
P149B00EGR Coolant pump Short circuit to B+
P149C00EGR Coolant pump Open circuit
DTCDTC Text
P149D00Transfer pump for reducing agent Open circuit
P149E00Transfer pump for reducing agent Short-circuit to ground
P149F00Transfer pump for reducing agent Short circuit to B+
P14A000Exhaust temperature sensor 1 bank 3 Implausible signal
P14A100Exhaust temperature sensor 1 bank 3 Short-circuit to ground
P14A200Exhaust temperature sensor 1 bank 3 Short circuit to B+
P14A300Exhaust temperature sensor 1 bank 4 Implausible signal
P14A400Exhaust temperature sensor 1 bank 4 Short-circuit to ground
P14A500Exhaust temperature sensor 1 bank 4 Short circuit to B+
P14A600Sensor 3a for exhaust temperature bank 1 Electrical malfunction
P14A700Sensor 3a for exhaust temperature bank 1 Implausible signal
P14A800Sensor 3a for exhaust temperature bank 1 Short-circuit to ground
P14A900Sensor 3a for exhaust temperature bank 1 Short circuit to B+
P150000Fuel pump relay -J17 electrical malfunction in circuit
P150100Fuel pump relay -J17 Short-circuit to ground
P150200Fuel pump relay -J17 Short circuit to B+
P150300Load signal from generator DF Implausible signal
P150400Air intake system leak detected
P150500Closed Throttle Position (CTP) Switch -F60 does not close/open circuit
P150600Closed Throttle Position (CTP) Switch -F60 does not open/short circuit to Ground (GND)
P150700Idling system learnt value - lower limit reached
P150800Idling system learnt value - upper limit reached
P150900Idling speed stabilization valve -N71 electrical malfunction in circuit
P150A00Engine Off Timer Performance
P150B00Acceleration monitoring Value above upper control limit
P150C00RPM request from transmission cannot be performed
P150D00Chain elongation
P150E00Vehicle Speed Sensor (A) Implausible to ABS Control Module
P150F00External control module incorrect code
P151000Idling speed stabilization valve -N71 Short circuit to B+
P151100Intake manifold change-over valve -N156 electrical malfunction in circuit
P151200Intake manifold change-over valve -N156 Short circuit to B+
P151300Intake Manifold Changover Valve 2 circuit -N261 Short circuit to B+
P151400Intake Manifold Changover Valve 2 circuit -N261 Short-circuit to ground
P151500Intake Manifold Changover Valve circuit -N156 Short-circuit to ground
P151600Intake Manifold Changover Valve circuit -N156 Open circuit
P151700Main relay electrical malfunction in circuit
P151800Main relay Short circuit to B+
P151900Bank1, camshaft adjustment Malfunction
P152000Intake Manifold Changover Valve 2 circuit -N261 Open circuit
P152100Intake Manifold Changover Valve 2 circuit -N261 Electrical malfunction in circuit
P152200A Camshaft Position Actuator Control Circuit(Bank2) Malfunction
P152300Crash Signal from Airbag Control Unit Implausible signal
P152400Fuel pump relay -J17 Open circuit/short circuit to ground
P152500Bank1, camshaft adjustment=>-N205 electrical malfunction in circuit
P152600Bank1, camshaft adjustment=>-N205 Short circuit to B+
P152700Bank1, camshaft adjustment=>-N205 Short-circuit to ground
P152800Bank1, camshaft adjustment=>-N205 Open circuit
P152900Intake camshaft control circuit Short circuit to B+
P153000Intake camshaft control circuit Short-circuit to ground
P153100Intake camshaft control circuit Open circuit
P153200Idle regulation lean operation RPM below specified value
P153300Bank2, camshaft adjustment=>-N208 electrical malfunction in circuit
P153400Bank2, camshaft adjustment=>-N208 Short circuit to B+
P153500Bank2, camshaft adjustment=>-N208 Short-circuit to ground
P153600Bank2, camshaft adjustment=>-N208 Open circuit
P153700Fuel Cut-Off Valve -N109- Malfunction
P153800Fuel Cut-Off Valve -N109- Open circuit/short circuit to ground
P153900Clutch pedal switch -F36 Implausible signal
P154000Vehicle Speed Sensor (A) Signal too high
P154100Fuel pump relay -J17 Open circuit
P154200Angle sender 1 for throttle valve drive -G187 Implausible signal
P154300Angle sender 1 for throttle valve drive -G187 Signal too low
P154400Angle sender 1 for throttle valve drive -G187 Signal too high
P154500Throttle valve control system Malfunction
P154600Wastegate Bypass Regulator Valve -N75 Short circuit to B+
P154700Wastegate Bypass Regulator Valve -N75 Short-circuit to ground
P154800Wastegate Bypass Regulator Valve -N75 Open circuit
P154900Wastegate Bypass Regulator Valve -N75 Open circuit/short circuit to ground
P154E00Charge pressure regulation bank 2 Malfunction
P154F00Turbo/Super Charger Boost Sensor (A) Circuit Malfunction
P155000Charging pressure Control difference
P155100Altitude sender-F96 Short circuit to B+
P155200Altitude sender-F96 Open circuit/short circuit to ground
P155300Barometric pressure sensor/manifold absolute pressure Implausible relation
P155400Throttle valve control part-J338- Conditions f. basic setting not met
P155500value above maximum charge pressure
P155600Turbo/Super Charger Boost Sensor (A) Circuit Value below lower control limit
P155700Turbo/Super Charger Boost Sensor (A) Circuit Value above upper control limit
P155800Throttle Drive (for Electronic Power Control (EPC)) -G186 electrical malfunction in circuit
P155900Throttle valve control part-J338- Malfunction in basic settings
P155A00Turbo/Super Charger Boost Sensor (A) Circuit Charge air pressure not reached
P156000Engine Overspeed Condition
P156100Quantity adjuster-N146 Control difference
P156200Quantity adjuster-N146 upper limit stop value
P156300Quantity adjuster-N146 lower limit stop value
P156400Throttle valve control part-J338- insufficient voltage during basic settings
P156500Throttle valve control part-J338- lower stop not reached
P156600A/C Refrigerant Pressure Sensor (A) Circuit Implausible signal
P156700A/C Refrigerant Pressure Sensor (A) Circuit No signal
P156800Throttle valve control part-J338- Mechanical malfunction
P156900Cruise control system switch -E45 Implausible signal
P156A00Filling/throttle valve position Validation
P156B00Lower mechanical stop of throttle valve Implausible signal
P157000Engine Control Module (ECM) disabled
P157100Left Electro-Hydraulic Engine Mount Solenoid Valve -N144- Short circuit to B+
P157200Left Electro-Hydraulic Engine Mount Solenoid Valve -N144- Short-circuit to ground
P157300Left Electro-Hydraulic Engine Mount Solenoid Valve -N144- Open circuit
P157400Left Electro-Hydraulic Engine Mount Solenoid Valve -N144- Electrical malfunction in circuit
P157500Right Electro-Hydraulic Engine Mount Solenoid Valve -N145- Short circuit to B+
P157600Right Electro-Hydraulic Engine Mount Solenoid Valve -N145- Short-circuit to ground
P157700Right Electro-Hydraulic Engine Mount Solenoid Valve -N145- Open circuit
P157800Right Electro-Hydraulic Engine Mount Solenoid Valve -N145- Electrical malfunction in circuit
P157900Throttle valve control part-J338- Adaptation not initiated
P158000Throttle valve drive - bank 1 Malfunction
P158100Throttle valve control part-J338- Basic settings not carried out
P158200Idle speed control adaptation limit reached
P158300Transmission Mount Valve -1-/-2- -N262-/-N263- Short circuit to B+
P158400Transmission Mount Valve -1-/-2- -N262-/-N263- Short-circuit to ground
P158500Transmission Mount Valve -1-/-2- -N262-/-N263- Open circuit
P158600L/R Electr-Hydr Eng. Mount Sol Valve -N144/N145 Short circuit to B+
P158700L/R Electr-Hydr Eng. Mount Sol Valve -N144/N145 Short-circuit to ground
P158800L/R Electr-Hydr Eng. Mount Sol Valve -N144/N145 Open circuit
P158900Temperature Selector Knob Potentiometer -G267- Short circuit to Ground (GND)
P159000Temperature Selector Knob Potentiometer -G267- Open circuit
P159100Wastegate Bypass Regulator Valve -N75 No function
P159200Height sensor/charge pressure sensor Implausible relation
P159300Altitude adaptation Signal outside tolerance
P159400Engine Oil Temperature Sensor Circuit,Camshaft Control -G277 Short circuit to B+
P159500Engine Oil Temperature Sensor Circuit,Camshaft Control -G277 Open circuit/short circuit to ground
P159600Databus drivetrain Implausible message from level control system control module
P159700Databus drivetrain missing message from level controls system control module
P159800Engine Oil Temperature Sensor Circuit,Camshaft Control -G277 Implausible signal
P159900Idle regulation lean operation RPM above specified value
P159B00Oil Level Thermal Sensor Short circuit to B+
P159C00Oil Level Thermal Sensor Short-circuit to ground
P159D00Oil Level Thermal Sensor Implausible signal
P159E00Oil Level Thermal Sensor No signal
P159F00Function restriction by Transmission Control Module
P15A000Neutral gear sensor Electrical malfunction
P15A100Neutral gear sensor Implausible signal
P15A200Neutral gear sensor Short-circuit to ground
P15A300Neutral gear sensor Short circuit to B+
P15A400vehicle shutdown activated
P160000Voltage supply terminal 15 Low Voltage
P160100Relay for Power Supply (B+) Terminal 30 -J317 Implausible signal
P160200Power Supply (B+) Terminal 30 Low Voltage
P160300Control module defective
P160400Control module defective
P160500Uneven road surface /acceleration sensor electrical malfunction in circuit
P160600Rough Road Spec Engine Torque ABS-ECU electrical malfunction in circuit
P160700Speed signal Malfunction message from instrument cluster
P160800Steering angle signal Malfunction indication from steering angle sensor
P160900Crash shut-off was triggered
P160A00Control module defective
P160B00See literature
P160C00Coolant pump 2 Open circuit
P160D00Coolant pump 2 Implausible signal
P160E00Coolant pump 2 Short-circuit to ground
P160F00Coolant pump 2 Short circuit to B+
P161000Control module defective
P161100Requirement - malfunction lamp on Short-circuit to ground
P161200Engine Control Module (ECM) incorrect coding
P161300Requirement - malfunction lamp on Open circuit/short circuit to B+
P161400Requirement - malfunction lamp on Implausible signal
P161500Engine Oil Temperature Sensor Circuit Implausible signal
P161600Glow Plug Indicator Light -K29- Short circuit to B+
P161700Glow Plug Indicator Light -K29- Open circuit/short circuit to ground
P161800Glow plug relay -J52 Short circuit to B+
P161900Glow plug relay -J52 Open circuit/short circuit to ground
P161A00Glow plug cylinder 1 -Q10 Open circuit
P161B00Glow plug cylinder 2 -Q11 Open circuit
P161C00Glow plug cylinder 3 -Q12 Open circuit
P161D00Glow plug cylinder 4 -Q13 Open circuit
P161E00Glow plug cylinder 5 -Q14 Open circuit
P161F00Glow plug cylinder 6 -Q15 Open circuit
P162000Signal for coolant temperature Open/Short to B+
P162100Signal for coolant temperature Short-circuit to ground
P162200Signal for coolant temperature Implausible signal
P162300Databus drivetrain No communication
P162400Requirement - malfunction lamp on active
P162500Databus drivetrain Implausible Message from Transm.Contr.
P162600Databus drivetrain Missing Message from Transm.Contr.
P162700Databus drivetrain missing message from fuel injection pump
P162800Databus drivetrain missing message from steering sensor
P162900Databus drivetrain Missing message from ADR control module
P162A00Glow plug cylinder 7 -Q16 Open circuit
P162B00Glow plug cylinder 8 -Q17 Open circuit
P162C00Glow/Time Control Module - voltage supply Load circuit open circuit
P162D00Diesel Particle Filter Indicator Lamp -K231 Malfunction
P162E00Glow plug cylinder 9 -Q18 Open circuit
P162F00Glow plug cylinder 10 -Q19 Open circuit
P163000Accelerator position sender-G79 Signal too low
P163100Accelerator position sender-G79 Signal too high
P163200Accelerator position sender-G79 Supply voltage
P163300Accelerator pedal position sender 2 -G185 Signal too low
P163400Accelerator pedal position sender 2 -G185 Signal too high
P163500Databus drivetrain missing message f.air condition control
P163600Databus drivetrain missing message from Airbag control
P163700Databus drivetrain Missing message f.central electr. control
P163800Databus drivetrain missing message from clutch control module
P163900Throttle/Pedal Position Sensor/Switch -C- Circuit Implausible signal
P163A00Glow/Time Control Module 2 - voltage supply Load circuit open circuit
P163B00Wakeup request constantly detected
P163C00Wakeup request not detected
P163D00Indicator lamp for driving program Electrical malfunction in circuit
P163E00Control module defective
P163F00Glow timing control module 2
P164000Control module defective
P164100Read DTC memory of Air Condition ECU
P164200Read DTC memory of Airbag ECU
P164300Read DTC memory of read out select central control
P164400Read DTC memory of clutch ECU
P164500Databus drivetrain missing message f.all wheel drive contr
P164600Read DTC memory of four wheel drive electronics
P164700Checking coding/versions of control modules in CAN-bus
P164800Databus drivetrain Defective
P164900Databus drivetrain missing message from break ECU
P164A00Oil pressure switch Implausible signal
P164B00Oil pressure switch Malfunction
P164C00Oil pressure switch for reduced oil pressure Implausible signal
P164D00Oil pressure switch for reduced oil pressure Malfunction
P164E00Oil pressure regulation valve Electrical malfunction
P164F00Torque withdrawal
P165000Databus drivetrain missing message from instrument panel ECU
P165100Databus drivetrain missing messages
P165200Read DTC memory of transmission ECU
P165300Read DTC memory of break ECU
P165400Read DTC memory of instrument cluster
P165500Read DTC memory of distance control ECU
P165600AC Clutch Relay Control Circuit Short-circuit to ground
P165700AC Clutch Relay Control Circuit Short circuit to B+
P165800Databus drivetrain range/performance from distance control
P165900Fan 1 control circuit Short circuit to B+
P165A00Temperature sensor - fresh air intake duct Short circuit to B+
P165B00Temperature sensor - fresh air intake duct Short-circuit to ground
P165C00Temperature sensor - fresh air intake duct Electrical malfunction
P165D00Refrigerant pressure too high
P165E00Refrigerant pressure too low
P165F00Oil pressure regulation valve Short-circuit to ground
P166000Fan 1 control circuit Short-circuit to ground
P166100Fan 2 control circuit Short circuit to B+
P166200Fan 2 control circuit Short-circuit to ground
P166300Activation of unit injectors Short circuit to B+
P166400Activation of unit injectors Electrical malfunction in circuit
P166500Activation of unit injectors Mechanical malfunction
P166600Unit injector solenoid valve - cylinder 1-N240 Electrical malfunction in circuit
P166700Unit injector solenoid valve - cylinder 2-N241 Electrical malfunction in circuit
P166800Unit injector solenoid valve - cylinder 3-N242 Electrical malfunction in circuit
P166900Unit injector solenoid valve - cylinder 4-N243 Electrical malfunction in circuit
P166A00Oil temperature sensor 2 Electrical malfunction
P166B00Oil temperature sensor 2 Short-circuit to ground
P166C00Oil temperature sensor 2 Implausible signal
P166D00Engine control module incorrect installation
P167000Unit injector solenoid valve - cylinder 5-N244 Electrical malfunction in circuit
P167100Unit injector solenoid valve - cylinder 6-N245 Electrical malfunction in circuit
P167200Fan 1 control circuit Open circuit/short circuit to ground
P167300Speed signal Malfunction message from ABS control module
P167400Databus drivetrain implausible message from instrument panel ECU
P167500Databus drivetrain fuel pump control module
P167600Drive by Wire-MIL Circ. -K132 electrical malfunction in circuit
P167700Drive by Wire-MIL Circ. -K132 Short circuit to B+
P167800Drive by Wire-MIL Circ. -K132 Short-circuit to ground
P167900Drive by Wire-MIL Circ. -K132 Open circuit
P167A00Indicator light start/stop Electrical malfunction
P167B00Driver's belt buckle Malfunction
P167C00Driving program switch Electrical malfunction
P167D00Switch for start/stop Electrical malfunction
P167F00Injection system initialization error or impermissible operating condition
P168000Reset-resistant emergency running
P168100Control unit programming programming not finished
P168200Databus drivetrain Implausible message from ABS control module
P168300Databus drivetrain Implausible message from airbag control module
P168400Control unit programming Malfunction in data transfer
P168500Databus drivetrain implausible message from steering angle sensor
P168600Control module defective Programming error
P168700Databus drivetrain Implausible message from climate control module
P168800Databus drivetrain implausible message from all wheel drive electronic
P168900Databus drivetrain implausible message f.central electr. control
P169000Malfunction Indicator Lamp (MIL) -K83- electrical malfunction in circuit
P169100Malfunction Indicator Lamp (MIL) -K83- Open circuit
P169200Malfunction Indicator Lamp (MIL) -K83- Short-circuit to ground
P169300Malfunction Indicator Lamp (MIL) -K83- Short circuit to B+
P169400Malfunction Indicator Lamp (MIL) -K83- Open circuit/short circuit to ground
P169500Databus drivetrain implausible message from clutch control ECU
P169600Databus drivetrain implausible signal from Steering Column Electronic
P169700Steering angle sensors please read DTC
P169800Steering Column Electronic Systems please read DTC
P169900Databus drivetrain missing message from Steering Column Electronic
P169A00Loading mode active
P169B00Glow plug cylinder 1 Implausible signal
P169C00Glow plug cylinder 2 Implausible signal
P169D00Glow plug cylinder 3 Implausible signal
P169E00Glow plug cylinder 4 Implausible signal
P169F00Glow plug cylinder 5 Implausible signal
P16A000Glow plug cylinder 6 Implausible signal
P16A100Glow plug cylinder 7 Implausible signal
P16A200Glow plug cylinder 8 Implausible signal
P16A300Glow plug cylinder 9 Implausible signal
P16A400Glow plug cylinder 10 Implausible signal
P16A500Glow plug cylinder 11 Implausible signal
P16A600Glow plug cylinder 12 Implausible signal
P16A700Glow plug cylinder 1 Incorrect installation
P16A800Glow plug cylinder 2 Incorrect installation
P16A900Glow plug cylinder 3 Incorrect installation
P16AA00Glow plug cylinder 4 Incorrect installation
P16AB00Glow plug cylinder 5 Incorrect installation
P16AC00Glow plug cylinder 6 Incorrect installation
P16AD00Glow plug cylinder 7 Incorrect installation
P16AE00Glow plug cylinder 8 Incorrect installation
P16AF00Glow plug cylinder 9 Incorrect installation
P16B000Glow plug cylinder 10 Incorrect installation
P16B100Glow plug cylinder 11 Incorrect installation
P16B200Glow plug cylinder 12 Incorrect installation
P170000Brake Pressure Switch -F270- Implausible signal
P170100Transmission control unit locked
P170200Malfunction cannot activate contr. mod. replacem. func., since another malfunction with equal priority is present
P170300Emergency running, control unit reset
P170400Kick Down Switch -F8- electrical malfunction in circuit
P170500Gear Ratio adaptation limit reached
P170600Gearbox faulty
P170700Interference in Mechatronic unit
P170800Engine Control Modules (ECM) exchanged
P170900Gear position switch 1-3 High Voltage
P170A00Hill holder Incline limit exceeded
P170B00Hill holder Malfunction
P170C00Gear position switch 5-7 High Voltage
P170D00Gear position switch 5-7 Low Voltage
P170E00Gear position switch 5-7 Signal error
P170F00Gear position switch 6-4 High Voltage
P171000Gear position switch 6-4 Low Voltage
P171100Wheel speed signal 1=>Left Front ABS Wheel Speed Sensor -G47 Implausible signal
P171200Gear position switch R-2 High Voltage
P171300Gear position switch R-2 Low Voltage
P171400Gear position switch R-2 Signal error
P171500Gear position switch 6-4 Signal error
P171600Wheel speed signal 2=>Right Front ABS Wheel Speed Sensor -G45 Implausible signal
P171700Gear position switch 1-3 Low Voltage
P171800Gear position switch 1-3 Signal error
P171900Function restriction by Engine Control Module
P171A00Ignition key removal lock Open circuit
P171B00Ignition key removal lock Short circuit to B+
P171C00Ignition key removal lock Short-circuit to ground
P171D00Ignition key removal lock Electrical malfunction
P171E00Transmission Input Speed (RPM) Sensor 2 No signal
P171F00Transmission Input Speed (RPM) Sensor 2 Implausible signal
P172000Transmission output speed 1 Implausible signal
P172100Wheel speed signal 3=>Left Rear ABS Wheel Speed Sensor -G46 Implausible signal
P172200Transmission output speed 2 Implausible signal
P172300Signal for starter lock Open circuit
P172400Signal for starter lock Short-circuit to ground
P172500Compare transmission output speeds 1 + 2 Implausible signal
P172600Wheel speed signal 4=>Right Rear ABS Wheel Speed Sensor -G44 Implausible signal
P172700Transmission Driving direction implausible
P172800Differing wheel speeds Implausible signal
P172900Signal for starter lock Short circuit to B+
P172A00Clutch adjuster valve Open circuit
P172B00Clutch adjuster valve Short-circuit to ground
P172C00Clutch adjuster valve Short circuit to B+
P172D00Clutch adjuster valve Electrical malfunction
P172E00Switch actuator Mechanical malfunction
P172F00Gear Position Distance Sensor 1 for gear selector Electrical malfunction
P173000Gear Position Distance Sensor 2 for gear selector Electrical malfunction
P173100Gear Position Distance Sensor 3 for gear selector Electrical malfunction
P173200Gear Position Distance Sensor 4 for gear selector Electrical malfunction
P173300Tiptronic Switch -F189-, down Short-circuit to ground
P173400Starter release from the selector lever sensor system
P173500Position sensor for clutch 1 Electrical malfunction
P173600Position sensor for clutch 2 Electrical malfunction
P173700Transmission hydraulic pressure sensor 1 Open circuit/short circuit to B+
P173800Transmission hydraulic pressure sensor 2 Open circuit/short circuit to B+
P173900Tiptronic Switch -F189-, up Short-circuit to ground
P173A00Gear Position Distance Sensor 1 for gear selector Implausible signal
P173B00Gear Position Distance Sensor 2 for gear selector Implausible signal
P173C00Gear Position Distance Sensor 3 for gear selector Implausible signal
P173D00Gear Position Distance Sensor 4 for gear selector Implausible signal
P173E00Valve 1 in partial transmission 1 Electrical malfunction
P173F00Valve 2 in partial transmission 1 Electrical malfunction
P174000Clutch temperature monitoring
P174100Clutch pressure adaptation at limit
P174200Clutch torque adaptation, adaptation limit reached
P174300Clutch slip monitoring Signal too high
P174400Tiptronic Switch -F189-, recognition Short-circuit to ground
P174500Transm.Contr.Unit Relay Short circuit to B+
P174600Transm.Contr.Unit Relay electrical malfunction in circuit
P174700Transm.Contr.Unit Relay Open circuit/short circuit to ground
P174800Control module defective
P174900Automatic gearbox control unit incorrect code
P174A00Valve 3 in separate transmission 1 Electrical malfunction
P174B00Valve 4 in partial transmission 1 Electrical malfunction
P174C00Valve 1 in partial transmission 2 Electrical malfunction
P174D00Valve 2 in partial transmission 2 Electrical malfunction
P174E00Valve 3 in separate transmission 2 Electrical malfunction
P174F00Valve 4 in partial transmission 2 Electrical malfunction
P175000Voltage supply Low Voltage
P175100Voltage supply High Voltage
P175200Voltage supply Implausible signal
P175300Tiptronic Switch -F189- Implausible signal
P175400Tiptronic Switch, up F189 Open circuit/short circuit to B+
P175500Tiptronic Switch, return F189 Open circuit/short circuit to B+
P175600Tiptronic Switch -F189-, recognition Open circuit/short circuit to B+
P175700Voltage supply Open circuit
P175800Voltage supply terminal 15 Open circuit
P175900Transmission fluid temperature Exceeded multiple times
P175A00Actuator gear control unit separate transmission 1 Tolerance limit reached
P175B00Actuator gear control unit separate transmission 2 Tolerance limit reached
P175C00Actuator double clutch Tolerance limits reached
P175D00Clutch 1 opens unintentionally
P175E00Clutch 1 closes unintentionally
P175F00Transmission system Basic settings not carried out
P176000Shift lock solenoid =>solenoid -N110 electrical malfunction in circuit
P176100Shift lock solenoid =>solenoid -N110 Short-circuit to ground
P176200Shift lock solenoid =>solenoid -N110 Short circuit to B+
P176300Shift lock solenoid =>solenoid -N110 Open circuit
P176400Transmission temperature monitoring
P176500Hydraulic pressure sender 2 -G194 adaptation limit reached
P176600Throttle Angel Signal Open circuit/short circuit to B+
P176700Throttle Angel Signal Short-circuit to ground
P176800Hydraulic pressure sender 2 -G194 Signal too high
P176900Hydraulic pressure sender 2 -G194 Signal too low
P176A00Gear selector 1 cannot be regulated
P176B00Gear selector 2 cannot be regulated
P176C00Gear selector 3 cannot be regulated
P176D00Gear selector 4 cannot be regulated
P176E00Clutch 2 opens unintentionally
P176F00Clutch 2 closes unintentionally
P177000Load Signal Implausible signal
P177100Load Signal Open circuit/short circuit to B+
P177200Load Signal Short-circuit to ground
P177300Hydraulic pressure sender 1 -G193 Signal too high
P177400Hydraulic pressure sender 1 -G193 Signal too low
P177500Hydraulic pressure sender 1 -G193 adaptation limit reached
P177600Hydraulic pressure sender 1 -G193 Implausible signal
P177700Hydraulic pressure sender 2 -G194 Implausible signal
P177800Valve 7 electrical malfunction in circuit
P177900Transmission input shaft 1 Overspeed
P177A00Transmission input shaft 2 Overspeed
P177B00Coupling 1 Tolerance limit reached
P177C00Coupling 2 Tolerance limit reached
P177D00Double clutch Torque too high
P177E00Function restriction due to pressure drop
P177F00Hydraulic pump motor Insuff. voltage
P178000Torque withdrawal faulty
P178100Torque reduction signal Open circuit/short circuit to ground
P178200Torque reduction signal Short circuit to B+
P178300Clutch torque adaptation 2 adaptation limit reached
P178400Up/down shift wire Open circuit/short circuit to ground
P178500Up/down shift wire Short circuit to B+
P178600Reversing light signal Open circuit
P178700Reversing light signal Short-circuit to ground
P178800Reversing light signal Short circuit to B+
P178900Idling speed adjustment Error Message from Engine Contr.
P178A00Hydraulic pump Electrical malfunction
P178B00Hydraulic pump Implausible behavior
P178C00Clutch 1 to clutch 2 Implausible
P178D00Synchronizer ring Wear
P178E00Function limitation due to excessive temperature
P178F00Pressure control valve soiled
P179000Signal for selector range display Open circuit
P179100Signal for selector range display Short-circuit to ground
P179200Signal for selector range display Short circuit to B+
P179300Output Speed Sensor 2 Circ. No signal
P179500Signal for driving speed Open circuit
P179600Signal for driving speed Short-circuit to ground
P179700Signal for driving speed Short circuit to B+
P179800Output Speed Sensor 2 Circ. Implausible signal
P179900Output Speed Sensor 2 Circ. Rpm too High
P179A00Solenoid valve Electrical malfunction
P179B00Separate transmission valve Electrical malfunction
P179C00Main pressure valve Electrical malfunction
P179D00Cooling oil valve Electrical malfunction
P179E00Sensor for transmission range Electrical malfunction
P179F00Sensor for transmission range Malfunction
P17A000Accumulator 1 temperature monitoring
P17A100Accumulator 2 temperature monitoring
P17A200Differential fluid pressure monitoring
P17A300Differential fluid temperature monitoring
P17A400Transverse acceleration monitoring
P17A500Longitudinal acceleration monitoring
P17A600Selector lever position P position1
P17A700Selector lever position P position2
P17A800Shift Lever Forward Valve 1 Open circuit
P17A900Shift Lever Forward Valve 1 Short-circuit to ground
P17AA00Shift Lever Forward Valve 1 Short circuit to B+
P17AB00Shift Lever Forward Valve 1 Electrical malfunction
P17AC00Shift Lever Forward Valve 2 Open circuit
P17AD00Shift Lever Forward Valve 2 Short-circuit to ground
P17AE00Shift Lever Forward Valve 2 Short circuit to B+
P17AF00Shift Lever Forward Valve 2 Electrical malfunction
P17B000Shift Lever Forward Valve 3 Open circuit
P17B100Shift Lever Forward Valve 3 Short-circuit to ground
P17B200Shift Lever Forward Valve 3 Short circuit to B+
P17B300Shift Lever Forward Valve 3 Electrical malfunction
P17B400Shift Lever Forward Valve 4 Open circuit
P17B500Shift Lever Forward Valve 4 Short-circuit to ground
P17B600Shift Lever Forward Valve 4 Short circuit to B+
P17B700Shift Lever Forward Valve 4 Electrical malfunction
P17B800Gear Recognition Potentiometer 1 Implausible signal
P17B900Gear Recognition Potentiometer 1 Signal too low
P17BA00Gear Recognition Potentiometer 1 Signal too high
P17BB00Gear Recognition Potentiometer 2 Implausible signal
P17BC00Gear Recognition Potentiometer 2 Signal too low
P17BD00Gear Recognition Potentiometer 2 Signal too high
P17BE00Hydraulic pump Excess temperature
P17BF00Hydraulic pump Play protection
P17C000Sport program button Open circuit
P17C100Selector lever position display unit Electrical malfunction
P17C200Selector lever position display unit Supply voltage
P17C300Selector lever Defective
P17C400Selector lever position display unit Defective
P17C500Selector lever Implausible signal
P17C600Clutch valve Electrical malfunction
P17C700Transmission Input Speed (RPM) Sensor 3 electrical malfunction in circuit
P17C800Transmission Input Speed (RPM) Sensor 3 Implausible signal
P17C900Transmission Input Speed (RPM) Sensor 3 No signal
P17CA00Basic calibration Data implausible
P17CB00Clutch valve Defective
P17CC00Clutch valve 2 Defective
P17CD00Coupling 1 Drag torque too high
P17CE00Coupling 2 Drag torque too high
P17CF00Coupling 1 Slip too great
P17D000Coupling 2 Slip too great
P17D100Coupling 1 Pressure upper limit exceeded
P17D200Coupling 2 Pressure upper limit exceeded
P17D300Electrohydraulic control unit Characteristic curve deviation
P17D400Valve 3 in separate transmission 1 Mechanical malfunction
P17D500Valve 3 in separate transmission 2 Mechanical malfunction
P17D600Coupling 1 Pressure too high
P17D700Coupling 2 Pressure too high
P17D800Torque limitation due to clutch temperature
P17D900Gear selector sensor Characteristic curve deviation
P17DA00Gear position sensor 1 Implausible
P17DB00Gear position sensor 2 Implausible
P17DC00Gear position sensor 3 Implausible
P17DD00Gear position sensor 4 Implausible
P17DE00Gear Position Distance Sensors 1 and 3 Electrical malfunction
P17DF00Gear Position Distance Sensors 2 and 4 Electrical malfunction
P17E000Gear selector 1 Mechanical malfunction
P17E100Gear selector 2 Mechanical malfunction
P17E200Gear selector 3 Mechanical malfunction
P17E300Gear selector 4 Mechanical malfunction
P17E400Selector lever position display unit Short circuit to B+
P17E500Selector lever position sensor Mechanical malfunction
P17E600Selector lever position sensor Implausible signal
P17E700Selector lever position sensor Defective
P17E800Locking solenoid Electrical malfunction
P17E900Locking solenoid Short circuit to B+
P17EA00Locking solenoid Defective
P17EB00Unlock button Short-circuit to ground
P17EC00Unlock button Electrical malfunction
P17ED00Unlock button sticks
P17EE00Unlock button Implausible signal
P17EF00Solenoid for pressure accumulator Short circuit to B+
P17F000Solenoid for pressure accumulator Short-circuit to ground
P17F100Solenoid for pressure accumulator Open circuit
P17F200Solenoid for pressure accumulator Electrical malfunction
P17F300Solenoid for parking lock Short circuit to B+
P17F400Solenoid for parking lock Short-circuit to ground
P17F500Solenoid for parking lock Open circuit
P17F600Solenoid for parking lock Electrical malfunction
P17F700Sensor for parking lock Implausible signal
P17F800Sensor for parking lock Electrical malfunction
P17F900Parking lock Mechanical malfunction
P17FA00Pressure control valve 8 electrical malfunction in circuit
P17FB00Pressure control valve 8 Open circuit
P17FC00Pressure control valve 8 Open circuit/short circuit to ground
P17FD00Pressure control valve 8 Short circuit to B+
P180000Hydraulic Actuator Valve -N331- Electrical malfunction in circuit
P180100Signal buzzer activation Short circuit to B+
P180200Clutch pedal switch -F194 Implausible signal
P180300Planetary post-switch stage Mechanical malfunction
P180400Hydraulic Actuator Range Sender -G302- Electrical malfunction in circuit
P180500Hydraulic Actuator Range Sender -G302- Upper limit exceeded
P180600Hydraulic Actuator Range Sender -G302- Lower limit not reached
P180700Hydraulic Actuator Range Sender -G302- no or incorrect basic setting/adaptation
P180800Hydraulic Actuator Range Sender -G302- Implausible signal
P1809004-Low Range Hydraulic Pump -V190- Electrical malfunction in circuit
P180A00Gear selector 1 Leaving Neutral not allowed
P180B00Gear selector 2 Leaving Neutral not allowed
P180C00Gear selector 3 Leaving Neutral not allowed
P180D00Gear selector 4 Leaving Neutral not allowed
P180E00Position sensor for clutch 1 Implausible signal
P180F00Position sensor for clutch 2 Implausible signal
P181300Pressure control valve 1 -N215 electrical malfunction in circuit
P181400Pressure control valve 1 -N215 Open circuit/short circuit to ground
P181500Pressure control valve 1 -N215 Short circuit to B+
P181800Pressure control valve 2 -N216 electrical malfunction in circuit
P181900Pressure control valve 2 -N216 Open circuit/short circuit to ground
P182000Pressure control valve 2 -N216 Short circuit to B+
P182300Pressure control valve 3 -N217 electrical malfunction in circuit
P182400Pressure control valve 3 -N217 Open circuit/short circuit to ground
P182500Pressure control valve 3 -N217 Short circuit to B+
P182800Pressure control valve 4 -N218 electrical malfunction in circuit
P182900Pressure control valve 4 -N218 Open circuit/short circuit to ground
P183000Pressure control valve 4 -N218 Short circuit to B+
P183300Pressure regulating valve -5- for automatic transmission electrical malfunction in circuit
P183400Pressure regulating valve -5- for automatic transmission Open circuit/short circuit to ground
P183500Pressure regulating valve -5- for automatic transmission Short circuit to B+
P183800Pressure Regulating Valve 6-N371 Electrical malfunction in circuit
P183900Pressure Regulating Valve 6-N371 Open circuit/short circuit to ground
P184000Pressure Regulating Valve 6-N371 Short circuit to B+
P184100Engine control module/Transmission Control Module (TCM) Versions not compatible
P184200Read DTC memory of instrument cluster
P184300Read DTC memory of distance control ECU
P184400Read DTC memory of read out select central control
P184500Read DTC memory of Steering Column Electronic Systems Control Module -J527-
P184700Read DTC memory of break ECU
P184800Read DTC memory of engine ECU
P184900Read DTC memory of transmission ECU
P184A00Main pressure adaptation Offset upper limit exceeded
P184B00Main pressure adaptation Malfunction
P185000Databus drivetrain Missing Message from Engine Contr
P185100Databus drivetrain missing message from break ECU
P185200Databus drivetrain Implausible Message from Engine Contr.
P185300Databus drivetrain Implausible message from ABS control module
P185400Databus drivetrain Defective
P185500Databus drivetrain Software version monitoring
P185600Throttle valve potentiometer -G69- Error Message from Engine Contr.
P185700Load Signal Error Message from Engine Contr.
P185800Engine Speed Input Circ. Error Message from Engine Contr.
P185900Brake Light Switch -F Error Message from Engine Contr.
P186000Kick Down Switch -F8- Error Message from Engine Contr.
P186100Accelerator position sender-G79 Malfunction indication from Engine Control Module (ECM)
P186200Databus drivetrain missing message from instrument panel ECU
P186300Databus drivetrain missing message from steering angle sensor
P186400Databus drivetrain Missing message from ADR control module
P186500Databus drivetrain missing message f.central electr. control
P186600Databus drivetrain missing messages
P186700Databus drivetrain missing message from -J527-
P186800Transmission Mount Valve -1- -N262- Short circuit to B+
P186900Transmission Mount Valve -1- -N262- Short-circuit to ground
P187000Transmission Mount Valve -1- -N262- Open circuit
P187100Transmission Mount Valve -2- -N263- Short circuit to B+
P187200Transmission Mount Valve -2- -N263- Short-circuit to ground
P187300Transmission Mount Valve -2- -N263- Open circuit
P187400Valve for torque support mount Short circuit to B+
P187500Valve for torque support mount Short-circuit to ground
P187600Valve for torque support mount Open circuit
P187700Control Coolant System Gearbox intermittent Open circuit
P187800Control Coolant System Gearbox intermittent Short circuit to B+
P187900Control Coolant System Gearbox intermittent Short-circuit to ground
P188000Databus missing message from Diagnostic Interface ECU
P188100Data Bus missing message
P188200Databus drivetrain missing message from electrical brake system ECU
P188300Park/Neutral Switch Input Circuit Implausible signal
P188400Reversing light signal Short-circuit to ground
P188500Reversing light signal Short circuit to B+
P188600Reversing light signal Open circuit
P188700Vehicle Speed Signal wheel speed from brake control module Implausible signal
P188800valve for coolant system circuit Short circuit to B+
P188900valve for coolant system circuit Short circuit to ground/open circuit
P188A00Coolant shut-off valve Electrical malfunction
P189000Signal wire for Tiptronic Electrical malfunction
P189100Signal wire for Tiptronic Implausible signal
P189200Selector lever position detection Defective
P189300Signal wire for gear display in selector lever Electrical malfunction
P189400Signal wire for gear display in selector lever Implausible signal
P189500Function restriction due to pressure drop
P189600Coupling 1 Temperature shock
P189700Coupling 2 Temperature shock
P189800Coupling 1 Function restriction
P189900Coupling 2 Function restriction
P189A00Coupling 1 Clearance too small
P189B00Coupling 2 Clearance too small
P189C00Function restriction due to insufficient pressure build-up
P190000Fan 2 control circuit Open circuit/short circuit to ground
P190100After-Run Coolant Fan Control (FC) Control Module -J138- Short circuit to B+
P190200After-Run Coolant Fan Control (FC) Control Module -J138- Open circuit/short circuit to ground
P190300Coolant Fan Valve -N313- Short circuit to B+
P190400Coolant Fan Valve -N313- Open circuit/short circuit to ground
P190500Charge Air Cooling Pump Relay -J536- Short circuit to B+
P190600Charge Air Cooling Pump Relay -J536- Open circuit/short circuit to ground
P190700Engine databus/engine Defective
P190800Engine databus/engine Software version monitoring
P190900Engine databus/engine Missing message from Engine Control Module (ECM) 1
P190A00Coolant pump for charge pressure cooler Electrical malfunction
P190B00Coolant pump for charge pressure cooler Temperature shut-off
P190C00Coolant pump for charge pressure cooler No signal
P190D00Coolant pump for charge pressure cooler Mechanical malfunction
P190E00Coolant pump for charge pressure cooler Supply voltage
P190F00Coolant pump for charge pressure cooler Electrical malfunction in load circuit
P191000Engine databus/engine Missing message from Engine Control Module (ECM) 2
P191100Synchronization wire engine/engine Electrical malfunction in circuit
P191200Pressure sensor for brake booster Open circuit/short circuit to B+
P191300Pressure sensor for brake booster Short-circuit to ground
P191400Pressure sensor for brake booster Implausible signal
P191500Coolant Circulation Pump Relay -J151 Short circuit to B+
P191600Coolant Circulation Pump Relay -J151 Short-circuit to ground
P191700Coolant Circulation Pump Relay -J151 Open circuit
P191800Load signal from generator DF Open circuit/short circuit to B+
P191900Load signal from generator DF Short-circuit to ground
P191A00Loss of crankshaft synchronization
P191B00Coolant Fan Control (FC) Control Module Implausible signal
P191C00Control module 2 for cooling fan Implausible signal
P191D00Coolant pump for charge pressure cooler Implausible signal
P191E00Actuator for structure-borne noise
P191F00Pressure sensor for brake booster Electrical malfunction
P192000L/R Electr-Hydr Eng. Mount Sol Valve -N144/N145 Open circuit/short circuit to ground
P192100Outside Air Temperature Sensor 2 -G249- Short-circuit to ground
P192200Outside Air Temperature Sensor 2 -G249- Open circuit/short circuit to B+
P192300Check DTC memory of Engine Control Module (ECM) 2
P192400Control module pin coding Implausible signal
P192500Auxiliary Engine Coolant (EC) Pump Relay Short circuit to B+
P192600Auxiliary Engine Coolant (EC) Pump Relay Short-circuit to ground
P192700Auxiliary Engine Coolant (EC) Pump Relay Open circuit
P192800Immobilizer inquiry not yet performed
P192900Radiator fan -V7 Open circuit
P193000Coolant Fan -2- Open circuit
P193100Coolant Fan Control (FC) Control Module -J293 Malfunction
P193200Databus drivetrain implausible message from ctrl. for access start authorization
P193300Throttle plate control 2 Malfunction
P193400Drive Circuit Cooling Fan Temperature Sensor -G382- Signal too low
P193500Drive Circuit Cooling Fan Temperature Sensor -G382- Signal too high
P193600Generator switch off Open circuit/short circuit to ground
P193700Generator switch off Short circuit to B+
P193800Auxiliary Engine Coolant (EC) Pump Relay -J496 Open circuit/short circuit to ground
P193900Databus drivetrain missing message from ctrl. for access start authorization
P194000Databus drivetrain missing message f. battery monitoring control module
P194100Databus drivetrain implausible message f. battery monitoring control module
P194200Databus drivetrain missing message from level control system control module
P194300Databus drivetrain implausible message from level control system control module
P194400Control module 1 for cooling fan Excess temperature
P194500Coolant Fan Control (FC) Control Module 1, fan activation Short circuit
P194600Control module 1 for cooling fan Faulty/open circuit in voltage supply
P194700Control module 2 for cooling fan Excess temperature
P194800Coolant Fan Control (FC) Control Module 2, fan activation Short circuit
P194900Control module 2 for cooling fan Faulty/open circuit in voltage supply
P195000Radiator fan -V7 difficulty of movement/blocked
P195100Coolant Fan -2- difficulty of movement/blocked
P195200Turbocharger (TC) control module 1 Defective
P195300Turbocharger (TC) control module 2 Defective
P195400Glow Plug Module 2, Control Circuit Electrical malfunction in circuit
P195500Glow Plug Control Module 2 to PCM Comm.Circuit Implausible signal
P195600Exhaust temperature sensor 2 bank 1 Electrical malfunction
P195700Exhaust temperature sensor 2 bank 1 Short-circuit to ground
P195800Exhaust temperature sensor 2 bank 1 Short circuit to B+
P195900Exhaust temperature sensor 2 bank 1 Implausible signal
P196000Exhaust temperature control circuit exhaust bank 3 Value above upper control limit
P196100Exhaust temperature sensor 2 bank 2 - G449 Electrical malfunction
P196200Exhaust temperature sensor 2 bank 2 - G449 Short-circuit to ground
P196300Exhaust temperature sensor 2 bank 2 - G449 Short circuit to B+
P196400Exhaust temperature sensor 2 bank 2 - G449 Implausible signal
P196500Exhaust temperature control circuit exhaust bank 4 Value above upper control limit
P196600Sec.Air Inj.Sys.Pump C Relay Circ Open circuit
P196700Sec.Air Inj.Sys.Pump C Relay Circ Short circuit to B+
P196800Sec.Air Inj.Sys.Pump C Relay Circ Short-circuit to ground
P196900Sec.Air Inj.Sys.Pump C Relay Circ electrical malfunction in circuit
P197000Sec.Air Inj.Sys.Pump D Relay Circ Open circuit
P197100Sec.Air Inj.Sys.Pump D Relay Circ Short circuit to B+
P197200Sec.Air Inj.Sys.Pump D Relay Circ Short-circuit to ground
P197300Sec.Air Inj.Sys.Pump D Relay Circ electrical malfunction in circuit
P197400Sec.Air Inj.Valve 3 Circ electrical malfunction in circuit
P197500Sec.Air Inj.Valve 3 Circ Short-circuit to ground
P197600Sec.Air Inj.Valve 3 Circ Short circuit to B+
P197700Sec.Air Inj.Valve 3 Circ Open circuit
P197800Sec.Air Inj.Valve 4 Circ electrical malfunction in circuit
P197900Sec.Air Inj.Valve 4 Circ Short-circuit to ground
P197A00Sec.Air Inj.Valve 3 Circ Mechanical malfunction
P197B00Sec.Air Inj.Valve 4 Circ Mechanical malfunction
P197C00Secondary air injection bank 1 and bank 2 swapped
P198000Sec.Air Inj.Valve 4 Circ Short circuit to B+
P198100Sec.Air Inj.Valve 4 Circ Open circuit
P198200Exhaust temperature control circuit exhaust bank 3 Implausible
P198300Exhaust temperature control circuit exhaust bank 4 Implausible
P198400Coolant fan 3 difficulty of movement/blocked
P198500Coolant FC (Fan Control) Control Module 2 Malfunction
P198600Coolant Fan Control (FC) Control Module 3, fan activation Short circuit
P198700Function restriction due to brake temperature
P198800Coolant Fan 3 Relay -J752- Open circuit
P198900Coolant Fan 3 Relay -J752- Short circuit to B+
P199000Coolant Fan 3 Relay -J752- Short-circuit to ground
P199100Control module defective
P199200Potentiometer 2 for EGR -G466- Malfunction in basic settings
P199300Potentiometer 2 for EGR -G466- Signal too high
P199400Potentiometer 2 for EGR -G466- Signal too low
P199500Door open signal not recognized
P199600Friction too high Code E1
P199700Friction too high Code A1
P199800Friction too high Code E2
P199900Friction too high Code E2
P199A00Temperature sensor for engine temperature management Signal too high
P199B00Temperature sensor for engine temperature management Signal too low
P199C00Thermostat for cylinder head Short-circuit to B+
P199D00Thermostat for cylinder head Short circuit to ground
P199E00Thermostat for cylinder head Open circuit
P199F00Thermostat control for cylinder head Excess temperature
P19A000Thermostat for transmission Short-circuit to B+
P19A100Thermostat for transmission Short circuit to ground
P19A200Thermostat for transmission Open circuit
P19A300Thermostat control for transmission Excess temperature
P19A400Actuator for engine temperature regulation Short-circuit to B+
P19A500Actuator for engine temperature regulation Short circuit to ground
P19A600Actuator for engine temperature regulation Open circuit
P1A0100Crash signal monitoring failed
P1A0200Hybrid battery system Insulation malfunction warning 1
P1A0300Hybrid battery system Insulation malfunction warning 2
P1AFE00Next output Diagnostic Test Mode (DTM) --> confirmation
P1AFF00Actuator test end
P1B0000Generator Mechanical malfunction
P1B0100Generator Electrical malfunction
P1B0200Control unit for battery monitoring Defective
P1B0300Locking electronics solenoid Short-circuit to ground
P1B0400Locking electronics solenoid Short circuit to B+
P1B0500Locking electronics solenoid Open circuit
P1B0600Locking electronics solenoid Resistance too small
P1B0700Locking electronics solenoid Short circuit between coil A and B
P1B0800Locking electronics switch Short-circuit to ground
P1B0900Locking electronics sensor Short circuit to ground
P1B0A00Locking electronics sensor Defective
P1B0B00Locking electronics sensor Open circuit/short circuit to B+
P1B0C00Lock hardware Mechanical malfunction
P200000NOx Adsorber Efficiency Bank 1 Below Threshold
P200200Particulate Trap Bank 1 Efficiency Below Threshold
P200300Particulate Trap Bank 2 Efficiency Below Threshold
P200400Intake Manifold Runner Control Bank 1 Stuck Open
P200500Intake Manifold Runner Control Bank 2 Stuck Open
P200600Intake Manifold Runner Control Bank 1 Stuck Closed
P200700Intake Manifold Runner Control Bank 2 Stuck Closed
P200800Intake Manifold Runner Bank 1 Control Circuit/Open
P200900Intake Manifold Runner Bank 1 Control Circuit Low
P200A00Intake Manifold Runner Bank 1 Performance
P200B00Intake Manifold Runner Bank 2 Performance
P201000Intake Manifold Runner Bank 1 Control Circuit High
P201100Intake Manifold Runner Bank 2 Control Circuit/Open
P201200Intake Manifold Runner Bank 2 Control Circuit Low
P201300Intake Manifold Runner Bank 2 Control Circuit High
P201400Intake Manifold Runner Position Sensor/Switch Circuit
P201500Intake Manifold Runner Position Sensor/Switch Circuit Range/Performance
P201600Intake Manifold Runner Position Sensor/Switch Circuit Low
P201700Intake Manifold Runner Position Sensor/Switch Circuit High
P201900Intake Manifold Runner Position Sensor/Switch Circuit Bank 2
P202000Intake Manifold Runner Pos. Sen./Switch Circuit Bank 2 Range/Performance
P202100Intake Manifold Runner Pos. Sen./Switch Circuit Bank 2 Low
P202200Intake Manifold Runner Pos. Sen./Switch Circuit Bank 2 High
P202400Evaporative Emissions (EVAP) Fuel Vapor Temperature Sensor Circuit
P202500Evaporative Emissions (EVAP) Fuel Vapor Temperature Sensor Performance
P202600Evaporative Emissions (EVAP) Fuel Vapor Temperature Sensor Circuit Low Voltage
P202700Evaporative Emissions (EVAP) Fuel Vapor Temperature Sensor Circuit High Voltage
P202A00Reductant Tank Heater Control Circuit/Open
P202B00Reductant Tank Heater Control Circuit Low
P202C00Reductant Tank Heater Control Circuit High
P203100Exhaust Gas Temperature Sensor 2, Bank 1 Circuit
P203200Exhaust Gas Temperature Sensor 2, Bank 1 Circuit Low
P203300Exhaust Gas Temperature Sensor 2, Bank 1 Circuit High
P203400Exhaust Gas Temperature Sensor 2 Bank 2 Circuit
P203500Exhaust Gas Temperature Sensor 2 Bank 2 Circuit Low
P203600Exhaust Gas Temperature Sensor 2 Bank 2 Circuit High
P203A00Reductant Level Sensor Circuit
P203B00Reductant Level Sensor Circuit Range/Performance
P203C00Reductant Level Sensor Circuit Low
P203D00Reductant Level Sensor Circuit High
P204700Reductant Injection Valve Circuit/Open Bank 1 Unit 1
P204800Reductant Injection Valve Circuit Low Bank 1 Unit 1
P204900Reductant Injection Valve Circuit High Bank 1 Unit 1
P204A00Reductant Pressure Sensor Circuit
P204B00Reductant Pressure Sensor Circuit Range/Performance
P204D00Reductant Pressure Sensor Circuit High
P205A00Reductant Tank Temperature Sensor Circuit
P205B00Reductant Tank Temperature Sensor Circuit Range/Performance
P205C00Reductant Tank Temperature Sensor Circuit Low
P207000Intake Manifold Tuning (IMT) Valve Stuck Open
P207100Intake Manifold Tuning (IMT) Valve Stuck Closed
P207300Manifold Absolute Pressure/Mass Air Flow - Throttle Position Correlation at Idle
P207400Manifold Absolute Pressure/Mass Air Flow - Throttle Position Correlation at Higher Load
P207500Intake Manifold Tuning (IMT) Valve Position Sensor/Switch Circuit
P207600Intake Manifold Tuning (IMT) Valve Position Sensor/Switch Circuit Range/Performance
P207700Intake Manifold Tuning (IMT) Valve Position Sensor/Switch Circuit Low
P207800Intake Manifold Tuning (IMT) Valve Position Sensor/Switch Circuit High
P207900Intake Manifold Tuning (IMT) Valve Position Sensor/Switch Circuit Intermittent
P207F00Reductant Quality Performance
P208000Exhaust Gas Temperature Sensor Circuit Bank1 Range/Performance
P208200Exhaust Gas Temperature Sensor Circuit Bank2 Range/Performance
P208400Exhaust Gas Temperature Sensor 2 Circuit Range/Performance
P208600Exhaust Gas Temperature Sensor 2 Circuit Bank 2 Range/Performance
P208800A Camshaft Position Actuator Control Circuit Low - Bank 1
P208900A Camshaft Position Actuator Control Circuit High - Bank 1
P208A00Reductant Pump "A" Control Circuit/Open
P208B00Reductant Pump "A" Control Range/Performance
P208C00Reductant Pump "A" Control Circuit Low
P208D00Reductant Pump "A" Control Circuit High
P208E00Reductant Injection Valve Stuck Closed Bank 1 Unit 1
P209000B Camshaft Position Actuator Control Circuit(Bank1) Low
P209100B Camshaft Position Actuator Control Circuit(Bank1) High
P209200A Camshaft Position Actuator Control Circuit(Bank2) Low
P209300A Camshaft Position Actuator Control Circuit(Bank2) High
P209400B Camshaft Position Actuator Control Circuit(Bank2) Low
P209500B Camshaft Position Actuator Control Circuit(Bank2) High
P209600Post Catalyst Fuel Trim System Bank1 Too Lean
P209700Post Catalyst Fuel Trim System Bank 1 Too Rich
P209800Post Catalyst Fuel Trim System Bank 2 Too Lean
P209900Post Catalyst Fuel Trim System Bank2 Too Rich
P209F00Reductant Tank Heater Control Circuit Performance
P20A000Reductant Purge Control Valve Circuit /Open
P20A200Reductant Purge Control Valve Circuit Low
P20A300Reductant Purge Control Valve Circuit High
P20A500Reductant Purge Control Valve Stuck Closed
P20B500Reductant Metering Unit Heater Control Circuit/Open
P20B700Reductant Metering Unit Heater Control Circuit Low
P20B800Reductant Metering Unit Heater Control Circuit High
P20B900Reductant Heater "A" Control Circuit/Open
P20BB00Reductant Heater "A" Control Circuit Low
P20BC00Reductant Heater "A" Control Circuit High
P20BD00Reductant Heater "B" Control Circuit/Open
P20BF00Reductant Heater "B" Control Circuit Low
P20C000Reductant Heater "B" Control Circuit High
P20D800Exhaust Aftertreatment Fuel Supply Control Performance
P20E800Reductant Pressure Too Low
P20E900Reductant Pressure Too High
P20EE00SCR NOx Catalyst Efficiency Below Threshold Bank 1
P20F400Reductant Consumption Too Low
P20F500Reductant Consumption Too High
P210000Throttle Actuator Control Motor Circuit/Open
P210100Throttle Actuator Control Motor Circuit Range/performance
P210200Throttle Actuator Control Motor Circuit Low
P210300Throttle Actuator "A" Control Motor Circuit High
P210600Throttle Actuator Control System Forced Limited Power
P210800Throttle Actuator Control Module Performance
P210A00Throttle Actuator "B" Control Motor Circuit/Open
P210B00Throttle Actuator "B" Control Motor Circuit Range/Performance
P210C00Throttle Actuator "B" Control Motor Circuit Low
P210D00Throttle Actuator "B" Control Motor Circuit High
P211000Throttle Actuator Control System - Forced Limited RPM
DTCDTC Text
P211100Throttle Actuator Control System - Stuck Open
P211200Throttle Actuator Control System - Stuck closed
P211900Throttle Actuator Control Throttle Body Range/Performance
P212200Throttle/Pedal Pos. Sens./Switch D Circuit Low Input
P212300Throttle/Pedal Pos. Sens./Switch D Circuit High Input
P212700Throttle/Pedal Pos. Sens./Switch E Circuit Low Input
P212800Throttle/Pedal Pos. Sens./Switch E Circuit High Input
P212B00Throttle Position Sensor/Switch "G" Circuit Range/Performance
P212C00Throttle Position Sensor/Switch "G" Circuit Low
P212D00Throttle Position Sensor/Switch "G" Circuit High
P213100Throttle/Pedal Position Sensor/Switch "F" Circuit Range/Performance
P213200Throttle/Pedal Position Sensor/Switch "F" Circuit Low
P213300Throttle/Pedal Position Sensor/Switch "F" Circuit High
P213500Throttle/Pedal Position Sensor/Switch "A"/"B" Voltage Correlation
P213800Throttle/Pedal Position Sensor/Switch D/E Voltage Correlation
P214600Fuel Injector Group "A" Supply Voltage Circuit Open
P214700Fuel Injector Group "A" Supply Voltage Circuit Low
P214800Fuel Injector Group "A" Supply Voltage Circuit High
P214900Fuel Injector Group "B" Supply Voltage Circuit Open
P215000Fuel Injector Group "B" Supply Voltage Circuit Low
P215100Fuel Injector Group "B" Supply Voltage Circuit High
P215200Fuel Injector Group "C" Supply Voltage Circuit/Open
P215300Fuel Injector Group "C" Supply Voltage Circuit Low
P215400Fuel Injector Group "C" Supply Voltage Circuit High
P215500Fuel Injector Group "D" Supply Voltage Circuit/Open
P215600Fuel Injector Group "D" Supply Voltage Circuit Low
P215700Fuel Injector Group "D" Supply Voltage Circuit High
P215900Vehicle Speed Sensor "B" Range/Performance
P216A00Fuel Injector Group "E" Supply Voltage Circuit/Open
P216B00Fuel Injector Group "E" Supply Voltage Circuit/Low
P216C00Fuel Injector Group "E" Supply Voltage Circuit/High
P216D00Fuel Injector Group "F" Supply Voltage Circuit/Open
P216E00Fuel Injector Group "F" Supply Voltage Circuit/Low
P216F00Fuel Injector Group "F" Supply Voltage Circuit/High
P217300Throttle Actuator Control System - High Airflow Detected
P217500Throttle Actuator Control System - Low Airflow Detected
P217700System too lean off idle, Bank 1
P217800System too rich off idle, Bank 1
P217900System too lean off idle, Bank 2
P218000System too rich off idle, Bank 2
P218100Cooling System Performance
P218300Engine Coolant Temperature Sensor 2 Circuit Range/Performance
P218400Engine Coolant Temperature Sensor 2 Circuit Low
P218500Engine Coolant Temperature Sensor 2 Circuit High
P218700System too lean at idle, Bank 1
P218800System too rich at idle, Bank 1
P218900System too lean at idle, Bank 2
P219000System too rich at idle, Bank 2
P219100System Too Lean at Higher Load; Bank 1
P219200System Too Rich at Higher Load; Bank 1
P219300System Too Lean at Higher Load; Bank 2
P219400System Too Rich at Higher Load; Bank 2
P219500O2 Sensor Signal Stuck Lean Bank 1 Sensor 1
P219600O2 Sensor Signal Stuck Rich Bank 1 Sensor 1
P219700O2 Sensor Signal Stuck Lean Bank 2 Sensor 1
P219800O2 Sensor Signal Stuck Rich Bank 2 Sensor 1
P219900Intake Air Temperature Sensor 1/2 Correlation
P219A00Bank 1 Air-Fuel Ratio Imbalance
P219B00Bank 2 Air-Fuel Ratio Imbalance
P219C00Cylinder 1 Air-Fuel Ratio Imbalance
P219D00Cylinder 2 Air-Fuel Ratio Imbalance
P219E00Cylinder 3 Air-Fuel Ratio Imbalance
P219F00Cylinder 4 Air-Fuel Ratio Imbalance
P21A000Cylinder 5 Air-Fuel Ratio Imbalance
P21A100Cylinder 6 Air-Fuel Ratio Imbalance
P21A200Cylinder 7 Air-Fuel Ratio Imbalance
P21A300Cylinder 8 Air-Fuel Ratio Imbalance
P21A400Cylinder 9 Air-Fuel Ratio Imbalance
P21A500Cylinder 10 Air-Fuel Ratio Imbalance
P21A600Cylinder 11 Air-Fuel Ratio Imbalance
P21A700Cylinder 12 Air-Fuel Ratio Imbalance
P220000NOx Sensor Bank 1 Sensor 1 Circuit
P220100NOx Sensor Circuit Range/Performance Bank 1 Sensor 1
P220200NOx Sensor Bank 1 Sensor 1 Circuit Low
P220300NOx Sensor Bank 1 Sensor 1 Circuit High
P220900NOx Sensor Heater Sense Bank 1 Sensor 1 Circuit Range/Performance
P220A00NOx Sensor Supply Voltage Bank 1 Sensor 1 Circuit
P220B00NOx Sensor Supply Voltage Bank 1 Sensor 2 Circuit
P222700Barometric Pressure Circuit Range/Performance
P222800Barometric Pressure Circuit Low
P222900Barometric Pressure Circuit high
P223100O2 Sensor Bank 1 Sensor 1 Signal Circuit Shorted to Heater Circuit
P223200O2 Sensor Bank 1 Sensor 2 Signal Circuit Shorted to Heater Circuit
P223300O2 Sensor Bank 1 Sensor 3 Signal Circuit Shorted to Heater Circuit
P223400O2 Sensor Bank 2 Sensor 1 Signal Circuit Shorted to Heater Circuit
P223500O2 Sensor Bank 2 Sensor 2 Signal Circuit Shorted to Heater Circuit
P223600O2 Sensor Bank 2 Sensor 3 Signal Circuit Shorted to Heater Circuit
P223700O2 Sensor Positive Current Control Circuit Bank 1 Sensor 1 Open
P223800O2 Sensor Positive Current Control Circuit Bank 1 Sensor 1 Low
P223900O2 Sensor Positive Current Control Circuit Bank 1 Sensor 1 High
P224000O2 Sensor Positive Current Control Circuit Bank 2 Sensor 1 Open
P224100O2 Sensor Positive Current Control Circuit Bank 2 Sensor 1 Low
P224200O2 Sensor Positive Current Control Circuit Bank 2 Sensor 1 High
P224300O2 Sensor Reference Voltage Circuit Bank 1 Sensor 1 Open
P224400O2 Sensor Reference Voltage Bank 1 Sensor 1 Performance
P224500O2 Sensor Reference Voltage Circuit Bank 1 Sensor 1 Low
P224600O2 Sensor Reference Voltage Circuit Bank 1 Sensor 1 High
P224700O2 Sensor Reference Voltage Circuit Bank 2 Sensor 1 Open
P224800O2 Sensor Reference Voltage Bank 2 Sensor 1 Performance
P224900O2 Sensor Reference Voltage Circuit Bank 2 Sensor 1 Low
P225000O2 Sensor Reference Voltage Circuit Bank 2 Sensor 1 High
P225100O2 Sensor Negative Current Control Circuit Bank 1 Sensor 1 open
P225200O2 Sensor Negative Current Control Circuit Bank 1 Sensor 1 Low
P225300O2 Sensor Negative Current Control Circuit Bank 1 Sensor 1 High
P225400O2 Sensor Negative Current Control Circuit Bank 2 Sensor 1 open
P225500O2 Sensor Negative Current Control Circuit Bank 2 Sensor 1 Low
P225600O2 Sensor Negative Current Control Circuit Bank 2 Sensor 1 High
P225700Secondary air injektion System Control "A" Circuit low
P225800Secondary air injektion System Control "A" Circuit high
P226100Turbo Boost Pressure Not Detected Mechanical
P226200Turbocharger/Supercharger Boost Pressure Not Detected Mechanical
P226300Turbocharger/Supercharger Boost System Performance
P227000O2 Sensor Signal Stuck Lean; Bank 1 Sensor 2
P227100O2 Sensor Signal Stuck Rich; Bank 1 Sensor 2
P227200O2 Sensor Signal Stuck Lean; Bank 2 Sensor 2
P227300O2 Sensor Signal Stuck Rich; Bank 2 Sensor 2
P227400O2 Sensor Signal Stuck Lean; Bank 1 Sensor 3
P227500O2 Sensor Signal Stuck Rich; Bank 1 Sensor 3
P227600O2 Sensor Signal Stuck Lean; Bank 2 Sensor 3
P227700O2 Sensor Signal Stuck Rich; Bank 2 Sensor 3
P227800O2 Sensor Signals Swapped Bank 1 Sensor 3 / Bank 2 Sensor 3
P227900Intake Air System Leak
P228C00Fuel Pressure Regulator 1 Exceeded Control Limits Pressure Too Low
P228D00Fuel Pressure Regulator 1 Exceeded Control Limits Pressure Too High
P228E00Fuel Pressure Regulator 1 Exceeded Learning Limits Too Low
P228F00Fuel Pressure Regulator 1 Exceeded Learning Limits Too High
P229300Fuel Pressure Regulator 2 Performance
P229400Fuel Pressure Regulator 2 Control Circuit
P229500Fuel Pressure Regulator 2 Control Circuit Low
P229600Fuel Pressure Regulator 2 Control Circuit High
P22970002 Sensor Bank 1 Sensor 1 Out of Range During Deceleration
P22980002 Sensor Bank 2 Sensor 1 Out of Range During Deceleration
P229A00Fuel Pressure Regulator 2 Exceeded Control Limits Pressure Too Low
P229B00Fuel Pressure Regulator 2 Exceeded Control Limits Pressure Too High
P229E00NOx Sensor Bank 1 Sensor 2 Circuit
P229F00NOx Sensor Circuit Range/Performance Bank 1 Sensor 2
P22A000NOx Sensor Bank 1 Sensor 2 Circuit Low
P22A100NOx Sensor Bank 1 Sensor 2 Circuit High
P22A700NOx Sensor Heater Sense Bank 1 Sensor 2 Circuit Range/Performance
P230000Ignition Coil "A" Primary Control Circuit Low
P230100Ignition Coil "A" Primary Control Circuit High
P230200Ignition Coil "A" Secondary Circuit
P230300Ignition Coil "B" Primary Control Circuit Low
P230400Ignition Coil "B" Primary Control Circuit High
P230500Ignition Coil "B" Secondary Circuit
P230600Ignition Coil "C" Primary Control Circuit Low
P230700Ignition Coil "C" Primary Control Circuit High
P230800Ignition Coil "C" Secondary Circuit
P230900Ignition Coil "D" Primary Control Circuit Low
P231000Ignition Coil "D" Primary Control Circuit High
P231100Ignition Coil "D" Secondary Circuit
P231200Ignition Coil "E" Primary Control Circuit Low
P231300Ignition Coil "E" Primary Control Circuit High
P231400Ignition Coil "E" Secondary Circuit
P231500Ignition Coil "F" Primary Control Circuit Low
P231600Ignition Coil "F" Primary Control Circuit High
P231700Ignition Coil "F" Secondary Circuit
P231800Ignition Coil "G" Primary Control Circuit Low
P231900Ignition Coil "G" Primary Control Circuit High
P232000Ignition Coil "G" Secondary Circuit
P232100Ignition Coil "H" Primary Control Circuit Low
P232200Ignition Coil "H" Primary Control Circuit High
P232300Ignition Coil "H" Secondary Circuit
P232400Ignition Coil "I" Primary Control Circuit Low
P232500Ignition Coil "I" Primary Control Circuit High
P232600Ignition Coil "I" Secondary Circuit
P232700Ignition Coil "J" Primary Control Circuit Low
P232800Ignition Coil "J" Primary Control Circuit High
P232900Ignition Coil "J" Secondary Circuit
P233000Ignition Coil "K" Primary Control Circuit Low
P233100Ignition Coil "K" Primary Control Circuit High
P233200Ignition Coil "K" Secondary Circuit
P233300Ignition Coil "L" Primary Control Circuit Low
P233400Ignition Coil "L" Primary Control Circuit High
P233500Ignition Coil "L" Secondary Circuit
P233600Cylinder #1 Above Knock Threshold
P233700Cylinder #2 Above Knock Threshold
P233800Cylinder #3 Above Knock Threshold
P233900Cylinder #4 Above Knock Threshold
P234000Cylinder #5 Above Knock Threshold
P234100Cylinder #6 Above Knock Threshold
P234200Cylinder #7 Above Knock Threshold
P234300Cylinder #8 Above Knock Threshold
P234400Cylinder #9 Above Knock Threshold
P234500Cylinder #10 Above Knock Threshold
P234600Cylinder #11 Above Knock Threshold
P234700Cylinder #12 Above Knock Threshold
P240000Evaporative Emission System Leak Detection Pump Control Circuit/Open
P240100Evaporative Emission System Leak Detection Pump Control Circuit Low
P240200Evaporative Emission System Leak Detection Pump Control Circuit High
P240300Evaporative Emission System Leak Detection Pump Sense Circuit/Open
P240400Evaporative Emission System Leak Detection Pumpe Sense Circuit Range/Performance
P241300Exhaust Gas Recirculation System Performance
P24140002 Sensor Exhaust Sample Error, Bank 1 Sensor 1
P24150002 Sensor Exhaust Sample Error, Bank 2 Sensor 1
P241600Oxygen Sensor Signals Swapped Bank 1 Sensor 2 / Bank 1 Sensor 3
P241700Oxygen Sensor Signals Swapped Bank 2 Sensor 2 / Bank 2 Sensor 3
P242100Evaporative Emission System Vent Valve Stuck Open
P242200Evaporative Emission System Vent Valve Stuck Closed
P242500Exhaust Gas Recirculation Cooling Valve Control Circuit Open
P242600Exhaust Gas Recirculation Cooling Valve Control Circuit Low
P242700Exhaust Gas Recirculation Cooling Valve Control Circuit High
P242800Exhaust Gas Temperature Too High Bank1
P242900Exhaust Gas Temperature Too High Bank2
P242A00Exhaust Gas Temperature Sensor Circuit Bank 1 Sensor 3
P242B00Exhaust Gas Temperature Sensor Circuit Bank 1 Sensor 3 Range/Performance
P242C00Exhaust Gas Temperature Sensor Circuit Low Bank 1 Sensor 3
P242D00Exhaust Gas Temperature Sensor Circuit High Bank 1 Sensor 3
P242F00Diesel Particulate Filter Restriction - Ash Accumulation
P243000Secondary Air Injection System Air Flow/Pressure Bank 1 Sensor Circuit
P243100Secondary Air Injection System Air Flow/Pressure Bank 1 Sensor Circuit Range/Performance
P243200Secondary Air Injection System Air Flow/Pressure Bank 1 Sensor Circuit Low
P243300Secondary Air Injection System Air Flow/Pressure Bank 1 Sensor Circuit High
P244000Secondary Air Injection System Switching Valve Stuck Open Bank1
P244200Secondary Air Injection System Switching Valve Stuck Open Bank2
P244C00Exhaust Temperature Too Low For Particulate Filter Regeneration Bank 1
P245200Diesel Particulate Filter Differential Pressure Sensor Circuit
P245300Diesel Particulate Filter Differential Pressure Sensor Circuit Range/Performance
P245400Diesel Particulate Filter Differential Pressure Sensor Circuit Low
P245500Diesel Particulate Filter Differential Pressure Sensor Circuit High
P245600Diesel Particulate Filter Pressure Sensor "A" Circuit Intermittent/Erratic
P245700Exhaust Gas Recirculation Cooling System Performance
P245B00Exhaust Gas Recirculation Cooler Bypass Control Circuit Range/Performance
P245E00Diesel Particulate Filter Pressure Sensor "B" Circuit
P246000Diesel Particulate Filter Pressure Sensor "B" Circuit Low
P246300Diesel Particulate Filter - Soot Accumulation
P246600Exhaust Gas Temperature Sensor Circuit Bank 2 Sensor 3
P246700Exhaust Gas Temperature Sensor Circuit Range/Performance Bank 2 Sensor 3
P246800Exhaust Gas Temperature Sensor Circuit Low Bank 2 Sensor 3
P246E00Exhaust Gas Temperature Sensor Circuit Bank 1 Sensor 4
P246F00Exhaust Gas Temperature Sensor Circuit Bank 1 Sensor 4 Range/Performance
P247000Exhaust Gas Temperature Sensor Circuit Low Bank 1 Sensor 4
P247100Exhaust Gas Temperature Sensor Circuit High Bank 1 Sensor 4
P247300Exhaust Gas Temperature Sensor Circuit Bank 2 Sensor 4
P247400Exhaust Gas Temperature Sensor Circuit Bank 2 Sensor 4 Range/Performance
P247500Exhaust Gas Temperature Sensor Circuit Low Bank 2 Sensor 4
P247600Exhaust Gas Temperature Sensor Circuit High Bank 2 Sensor 4
P247800Exhaust Gas Temperature Out of Range Bank 1 Sensor 1
P247A00Exhaust Gas Temperature Out of Range Bank 1 Sensor 3
P251000ECM/PCM Power Relay Sense Circuit Range/Performance
P251900A/C Request "A" Circuit
P252000A/C Request "A" Circuit Low
P252100A/C Request "A" Circuit High
P253300Ignition Switch Run/ Start Position Curciut
P253500Ignition Switch Run/ Start Position Curciut High
P253900Low Pressure Fuel System Sensor Circuit
P254000Low Pressure Fuel System Sensor Circuit Range/Performance
P254100Low Pressure Fuel System Sensor Circuit Low Input
P254200Low Pressure Fuel System Sensor Circuit High Input
P254300Low Pressure Fuel System Sensor Circuit Intermittent
P254500Torque Management Request Input Signal "A" Range/Performance
P256200Turbocharger Boost Control Position Sensor "A" Circuit
P256300Turbocharger Boost Control Position Sensor Circuit Range/Performance
P256400Turbocharger Boost Control Position Sensor Circuit Low
P256500Turbocharger Boost Control Position Sensor Circuit High
P256600Turbocharger Boost Control Position Sensor Circuit Intermittent
P256800Direct Ozone Reduction Catalyst Temperature Sensor Circuit Range/Performance
P256900Direct Ozone Reduction Catalyst Temperature Sensor Circuit Low
P257000Direct Ozone Reduction Catalyst Temperature Sensor Circuit High
P257800Turbocharger Speed Sensor "A" Circuit
P257900Turbocharger Speed Sensor "A" Circuit Range/Performance
P258000Turbocharger Speed Sensor "A" Circuit Low
P258100Turbocharger Speed Sensor "A" Circuit High
P258200Turbocharger Speed Sensor "A" Circuit Intermittent
P258800Turbocharger Boost Control Position Sensor "B" Circuit Low
P258900Turbocharger Boost Control Position Sensor "B" Circuit High
P259300Turbocharger Speed Sensor "B" Circuit
P259400Turbocharger Speed Sensor "B" Circuit Range/Performance
P259500Turbocharger Speed Sensor "B" Circuit Low
P259600Turbocharger Speed Sensor "B" Circuit High
P259700Turbocharger Speed Sensor "B" Circuit Intermittent
P260000Coolant Pump Control Circuit open
P260100Coolant Pump Control Circuit range/performance
P260200Coolant Pump Control Circuit low
P260300Coolant Pump Control Circuit high
P261000ECM/PCM Internal Engine Off Timer Performance
P261200A/C Refrigerant Distribution Valve Control Circuit Low
P261300A/C Refrigerant Distribution Valve Control Circuit High
P261A00Coolant Pump "B" Control Circuit/Open
P261B00Coolant Pump "B" Control Circuit Range/Performance
P261C00Coolant Pump "B" Control Circuit Low
P261D00Coolant Pump "B" Control Circuit High
P262600O2 Sensor Pumping Current Trim Circuit/Open Bank 1, Sensor 1
P262900O2 Sensor Pumping Current Trim Circuit/Open Bank 2, Sensor 1
P263200Fuel Pump "B" Control Circuit Open
P263300Fuel Pump "B" Control Circuit Low
P263400Fuel Pump "B" Control Circuit High
P263700Torque Management Feedback Signal "A"
P270000Transmission Friction Element "A" Apply Time Range/Performance
P270100Transmission Friction Element "B" Apply Time Range/Performance
P270200Transmission Friction Element "C" Apply Time Range/Performance
P270300Transmission Friction Element "D" Apply Time Range/Performance
P270400Transmission Friction Element "E" Apply Time Range/Performance
P270500Transmission Friction Element "F" Apply Time Range/Performance
P270800Shift Solenoid F Stuck On
P271100Unexpected Mechanical Gear Disengagement
P271400Pressure Control Solenoid "D" Performance or Stuck Off
P271500Pressure Control Solenoid "D" Stuck On
P271600Pressure Control Solenoid "D" Electrical
P271700Pressure Control Solenoid "D" Intermittent
P272300Pressure Control Solenoid "E" Performance or Stuck Off
P272400Pressure Control Solenoid "E" Stuck On
P272500Pressure Control Solenoid "E" Electrical
P272600Pressure Control Solenoid "E" Intermittent
P273200Pressure Control Solenoid "F" Performance or Stuck Off
P273300Pressure Control Solenoid "F" Stuck On
P273400Pressure Control Solenoid "F" Electrical
P273500Pressure Control Solenoid "F" Intermittent
P275300Transmission Fluid Cooler Control Circuit/Open
P275400Transmission Fluid Cooler Control Circuit Low
P275500Transmission Fluid Cooler Control Circuit High
P276500Input Turbine/Speed Sensor "B" Circuit
P276600Input Turbine/Speed Sensor "B" Circuit Range/Performance
P278700Clutch Temperature Too High
P278900Clutch Adaptive Learning at Limit
P278B00Kick Down Switch Circuit Range/Performance
P281000Pressure Control Solenoid "G" Electrical
P281200Pressure Control Solenoid "G" Control Circuit/Open
P281400Pressure Control Solenoid "G" Control Circuit Low
P281500Pressure Control Solenoid "G" Control Circuit High
P2BA700NOx Exceedence - Empty Reagent Tank
P300000Glow Plug Indicator Light -K29- Malfunction message from instrument cluster
P300100Operating RPM regulation Control difference
P300200Kick Down Switch -F8- Implausible signal
P300300Low heat output relay-J359 Short circuit to B+
P300400Low heat output relay-J359 Open circuit/short circuit to ground
P300500High heat output relay -J360 Short circuit to B+
P300600High heat output relay -J360 Open circuit/short circuit to ground
P300700Camshaft Position (CMP) Sensor -G40- No signal
P300800Camshaft Position (CMP) Sensor -G40- Signal outside tolerance
P300900Relay for pump, fuel cooling -J445- Short circuit to B+
P300A00Diesel Particulate Filter Differential Pressure Sensor Implausible signal
P300B00Diesel Particulate Filter Differential Pressure Sensor Short-circuit to ground
P300C00Diesel Particulate Filter Differential Pressure Sensor Short circuit to B+
P300D00Diesel Particulate Filter Differential Pressure Sensor Electrical malfunction
P300E00Particulate Trap Bank 2 restriction
P300F00Fuel bypass valve Open circuit
P301000Relay for pump, fuel cooling -J445- Open circuit/short circuit to ground
P301100Fuel Pump (FP) 2 Relay -J49- Short circuit to B+
P301200Fuel Pump (FP) 2 Relay -J49- Open circuit/short circuit to ground
P301300Wastegate Bypass Regulator Valve 2 -N274- Short circuit to B+
P301400Wastegate Bypass Regulator Valve 2 -N274- Open circuit/short circuit to ground
P301500Fuel Bypass Valve -N312- Short circuit to B+
P301600Fuel Bypass Valve -N312- Open circuit/short circuit to ground
P301700Exhaust Flap Valve 1 -N321- Short circuit to B+
P301800Exhaust Flap Valve 1 -N321- Short-circuit to ground
P301900Exhaust Flap Valve 1 -N321- Open circuit
P301A00Exhaust flap sensor bank 2 Electrical malfunction
P301B00Exhaust flap sensor bank 2 Implausible signal
P301C00Exhaust flap sensor bank 2 Short circuit to B+
P301D00Exhaust flap bank 2 Electrical malfunction
P301E00Exhaust flap bank 2 Control difference
P301F00Exhaust flap bank 2 Short circuit to B+
P302000Exhaust Flap Valve 1 -N321- Electrical malfunction in circuit
P302100Exhaust Flap Valve 2 -N322- Short circuit to B+
P302200Exhaust Flap Valve 2 -N322- Short-circuit to ground
P302300Exhaust Flap Valve 2 -N322- Open circuit
P302400Exhaust Flap Valve 2 -N322- Electrical malfunction in circuit
P302500Throttle Drive Angle Sensor 1 -G297 Implausible signal
P302600Throttle Drive Angle Sensor 1 -G297 Signal too low
P302700Throttle Drive Angle Sensor 1 -G297 Signal too high
P302800Throttle Drive Angle Sensor 2 -G298 Implausible signal
P302900Throttle Drive Angle Sensor 2 -G298 Signal too low
P302A00Low heat output relay Open circuit
P302B00Relay for Preheating Coolant, High Heat Output Open circuit
P302C00Low heat output relay Short-circuit to ground
P302D00Relay for Preheating Coolant, High Heat Output Short-circuit to ground
P302E00Relay for pump, fuel cooling Open circuit
P302F00Relay for pump, fuel cooling Short-circuit to ground
P303000Throttle Drive Angle Sensor 2 -G298 Signal too high
P303100Throttle Actuator 2 electrical malfunction in circuit
P303200Throttle Valve Control Module 2 -J544- Malfunction in basic settings
P303300Intake Air Temp.Circ.2 Signal too low
P303400Intake Air Temp.Circ.2 Signal too high
P303500Throttle Valve Control Module 2 -J544- Mechanical malfunction
P303600Throttle Valve Control Module 2 -J544- insufficient voltage during basic settings
P303700Throttle Valve Control Module 2 -J544- Adaptation not initiated
P303800Throttle Valve Control Module 2 -J544- lower stop not reached
P303900Transmission request torque reduction Implausible
P303A00Auxiliary Fuel Pump (FP) Relay Open circuit
P303B00Auxiliary Fuel Pump (FP) Relay Short-circuit to ground
P303C00Auxiliary Fuel Pump (FP) Relay Short circuit to B+
P303D00Cold start valve Open circuit
P303E00Cold start valve Short circuit to B+
P303F00Cold start valve Short-circuit to ground
P304000Transmission ratio Implausible
P304100Databus drivetrain implausible engine temperature message from instrument ECU
P304200Heater regulation Implausible signal
P304300Throttle Transfer Fuel Pump (FP) Mechanical malfunction
P304400Throttle Transfer Fuel Pump (FP) Short circuit
P304500Fuel pump electronics Defective
P304600Starter relay 1 Electrical malfunction in circuit (relay stuck/does not switch)
P304700Activation starter relay 2 Short circuit to B+
P304800Activation starter relay 2 Short-circuit to ground
P304900Activation starter relay 2 Open circuit
P304A00Starter relay 1 Short-circuit to ground
P304B00Potentiometer for heater control Electrical malfunction
P305000Starter relay 2 Electrical malfunction in circuit (relay stuck/does not switch)
P305100Starter activation, return message terminal 50 Implausible signal
P305200Starter activation, return message terminal 50 Short circuit to B+
P305300Starter activation, return message terminal 50 Short circuit to ground/open circuit
P305400Starter does not turn Mechanically blocked or electrical malfunction
P305500Exhaust Pressure Sensor 2 Open circuit
P305600Exhaust Pressure Sensor 2 Short-circuit to ground
P305700Exhaust Pressure Sensor 2 Short circuit to B+
P305800Exhaust Gas Recirc.Flow 2 Flow too Low
P305900Exhaust Gas Recirc.Flow 2 throughput too large
P305A00Gasoline operation Random/Multiple Cylinder. Misfire Detected
P306000Cooling Bypass Valve, Exhaust Gas Recirculation Flow Electrical malfunction
P306100Cooling Bypass Valve 2, Exhaust Gas Recirculation Flow Electrical malfunction
P306200Turbo/Super Charger 2 Overboost Condition
P306300Turbo/Super Charger 2 Underboost condition
P306400Boost Pressure Contr.Valve 3 Circuit Electrical malfunction
P306500Boost Pressure Contr.Valve 3 Circuit Short-circuit to ground
P306600Boost Pressure Contr.Valve 3 Circuit Short circuit to B+
P306700Boost Pressure Contr.Valve 4 Circuit Electrical malfunction
P306800Boost Pressure Contr.Valve 4 Circuit Short-circuit to ground
P306900Boost Pressure Contr.Valve 4 Circuit Short circuit to B+
P307000Metering pump for cleaning solution Defective
P307100Additive tank for particle filter empty
P307200Voltage supply relay Electrical malfunction in circuit
P307300Throttle Transfer Fuel Pump (FP) Electrical malfunction in circuit
P307400Fuel Pump 2 Electrical malfunction in circuit
P307500Turbo boost 1/2 Trim Adaptation Limit Attained
P307600Engine Control Module (ECM) Error during coding
P307700Fuel Pump Electronics, voltage supply Electrical malfunction
P307800Throttle Valve Control Module Air Flow at idle too Low
P307900Cold Start Fuel Pump (FP) Relay Short circuit to B+
P307A00Intake system Air flow too low
P307B00Activation Fuel pump module 2 Electrical malfunction/open
P307C00Activation Fuel pump module 2 Implausible signal
P307D00Activation Fuel pump module 2 Short-circuit to ground
P307E00Activation Fuel pump module 2 Short circuit to B+
P308000Cold Start Fuel Pump (FP) Relay -J748 Short circuit to ground/open circuit
P308100Engine temperature too low
P308200Clutch positioning sensor Implausible signal
P308300Fuel level sensor for additive tank particulate trap, Electrical malfunction in circuit
P308400Recirculating valve for turbocharger bank 2 Mechanical malfunction
P308500Activation Intake Manifold Runner Bank 2 Control Electrical malfunction
P308600Intake Manifold Runner Bank 2 Basic settings not carried out
P308700Supply relay for engine components Electrical malfunction in circuit
P308800Starter relay Electrical malfunction in circuit
P308900Fuel pump electronics signal wire Electrical malfunction
P308A00Fuel pump electronics NG operation signal wire Short circuit to B+
P308B00Fuel pump electronics NG operation signal wire Short-circuit to ground
P308C00Fuel pump electronics NG operation signal wire Open circuit
P308D00Throttle Transfer Fuel Pump (FP) Engine speed too low
P308E00Fuel pump electronics Excess temperature
P309000Auxiliary heater signal not recognized
P309100Auxiliary heater signal constant detected
P309200Control module defective
P309300Control module defective
P309400Control module defective
P309500Control module defective
P309600Control module defective
P309700Control module defective
P309800Control module defective
P309900Control module defective
P310000Intake Flap Motor -V157 Short circuit to B+
P310100Intake Flap Motor -V157 Open circuit/short circuit to ground
P310200Intake Flap Motor -V157 No signal
P310300Intake Flap Motor -V157 Defective
P310400Intake manifold flap change-over valve- N239 Short circuit to B+
P310500Intake manifold flap change-over valve- N239 Open circuit/short circuit to ground
P310600Cylinder 7 Pump/Injector -N303- Implausible signal
P310700Cylinder 7 Pump/Injector -N303- Value above upper control limit
P310800Cylinder 7 Pump/Injector -N303- Value below lower control limit
P310900Cylinder 7 Pump/Injector -N303- Electrical malfunction in circuit
P310A00Low Fuel Pressure regulation Fuel pressure fluctuates
P310B00Low Fuel Pressure regulation Fuel pressure outside specification
P310C00Low Fuel Pressure regulation Fuel pressure breaks down sporadically
P310D00Fuel Pressure Regulation Fuel pressure fluctuates
P310E00Exhaust gas recirculation cooler bypass valve 2 Implausible signal
P311000Cylinder 8 Pump/Injector -N304- Implausible signal
P311100Cylinder 8 Pump/Injector -N304- Value above upper control limit
P311200Cylinder 8 Pump/Injector -N304- Value below lower control limit
P311300Cylinder 8 Pump/Injector -N304- Electrical malfunction in circuit
P311400Cylinder 9 Pump/Injector -N305- Implausible signal
P311500Cylinder 9 Pump/Injector -N305- Value above upper control limit
P311600Cylinder 9 Pump/Injector -N305- Value below lower control limit
P311700Cylinder 9 Pump/Injector -N305- Electrical malfunction in circuit
P311800Cylinder 10 Pump/Injector -N306- Implausible signal
P311900Cylinder 10 Pump/Injector -N306- Value above upper control limit
P312000Cylinder 10 Pump/Injector -N306- Value below lower control limit
P312100Cylinder 10 Pump/Injector -N306- Electrical malfunction in circuit
P312200Cylinder 11 Pump/Injector -N307- Implausible signal
P312300Cylinder 11 Pump/Injector -N307- Value above upper control limit
P312400Cylinder 11 Pump/Injector -N307- Value below lower control limit
P312500Cylinder 11 Pump/Injector -N307- Electrical malfunction in circuit
P312600Cylinder 12 Pump/Injector -N308- Implausible signal
P312700Cylinder 12 Pump/Injector -N308- Value above upper control limit
P312800Cylinder 12 Pump/Injector -N308- Value below lower control limit
P312900Cylinder 12 Pump/Injector -N308- Electrical malfunction in circuit
P313000Exhaust Gas Recirculation (EGR) system Value above upper control limit
P313100Exhaust Gas Recirculation (EGR) system Value below lower control limit
P313200Glow Plug Module 2, Control Circuit Electrical malfunction in circuit
P313300Automatic Glow Time Control Relay 2-J609 Implausible signal
P313400Intake Manifold Runner Control (IMRC) Upper stop not reached
P313500Intake Manifold Runner Control (IMRC) lower limit not reached
P313600Intake Manifold Runner Control (IMRC) Target value not reached
P313700Intake Manifold Runner Control (IMRC) Basic settings not carried out
P313800Intake Manifold Runner Control (IMRC) Control difference
P313900Intake Manifold Runner Control (IMRC) Signal outside tolerance
P313A00Intake Manifold Runner Control (IMRC), bank 2 Signal outside tolerance
P313B00Intake Manifold Runner Control (IMRC), bank 2 Control difference
P313C00Intake Manifold Runner Control (IMRC), bank 2 difficulty of movement or blocked
P313D00Intake Manifold Runner Control (IMRC) difficulty of movement or blocked
P314000Valve for starting with empty tank -N349 Open circuit/short circuit to ground
P314100Valve for starting with empty tank -N349 Short circuit to B+
P314200Exhaust-bank2,sensor1,oxygen sensor signal implausible lean
P314300Exhaust-bank2,sensor1,oxygen sensor signal Implausible rich
P314400Exhaust-bank3,sensor1,oxygen sensor signal implausible lean
P314500Exhaust-bank3,sensor1,oxygen sensor signal Implausible rich
P314600Exhaust-bank4,sensor1,oxygen sensor signal implausible lean
P314700Exhaust-bank4,sensor1,oxygen sensor signal Implausible rich
P314800Exhaust bank 3, O2 sensor before cat. conv., heater circuit Regulation at upper impact
P314900Exhaust bank 3, O2 sensor before cat. conv., heater circuit Regulation at lower impact
P315000Exhaust bank 4, O2 sensor before cat. conv., heater circuit Regulation at upper impact
P315100Exhaust bank 4, O2 sensor before cat. conv., heater circuit Regulation at lower impact
P315200Exhaust gas bank3, sensor1 Internal resistance too Large
P315300Exhaust gas bank4, sensor1 Internal resistance too Large
P315400Exhaust-bank2-sensor1 Voltage too low/air leak
P315500Emissions-bank3-sensor1 Voltage too low/air leak
P315600Emissions-bank4-sensor1 Voltage too low/air leak
P315700Exhaust-bank1,sensor1,oxygen sensor signal Voltage too low during deceleration
P315800Exhaust-bank2,sensor1,oxygen sensor signal Voltage too low during deceleration
P315900Exhaust-bank3,sensor1,oxygen sensor signal Voltage too low during deceleration
P316000Exhaust-bank4,sensor1,oxygen sensor signal Voltage too low during deceleration
P316100Linear oxy. sensor,exh-bank1/compensat. wire pump current Open circuit
P316200Linear oxy. sensor,exh-bank2/compensat. wire pump current Open circuit
P316300Linear oxy. sensor,exh-bank3/compensat. wire pump current Open circuit
P316400Linear oxy. sensor,exh-bank4/compensat. wire pump current Open circuit
P316500Exhaust-bank3,oxygen sensor correction behind cat Lean control limit exceeded
P316600Exhaust-bank3,oxygen sensor correction behind cat Rich control limit exceeded
P316700Exhaust-bank4,oxygen sensor correction behind cat Lean control limit exceeded
P316800Exhaust-bank4,oxygen sensor correction behind cat Rich control limit exceeded
P316900Exhaust-bank3 main catalytic converter Efficiency below threshold
P317000Exhaust-bank4 main catalytic converter Efficiency below threshold
P317100Exhaust-bank1, mixture adaptation range 3 System too lean
P317200Exhaust-bank1, mixture adaptation range 3 System too rich
P317300Exhaust-bank2, mixture adaptation range 3 System too lean
P317400Exhaust-bank2, mixture adaptation range 3 System too rich
P317500Exhaust bank3, mixture adaptation range 3 System too lean
P317600Exhaust bank3, mixture adaptation range 3 System too rich
P317700Exhaust bank4, mixture adaptation range 3 System too lean
P317800Exhaust bank4, mixture adaptation range 3 System too rich
P317900Cyl.13-Fuel Inj.Circ. Short-circuit to ground
P318000Cyl.13-Fuel Inj.Circ. Short circuit to B+
P318100Cyl.13-Fuel Inj.Circ. Open circuit
P318200Cyl.14-Fuel Inj.Circ. Short-circuit to ground
P318300Cyl.14-Fuel Inj.Circ. Short circuit to B+
P318400Cyl.14-Fuel Inj.Circ. Open circuit
P318500Cyl.15-Fuel Inj.Circ. Short-circuit to ground
P318600Cyl.15-Fuel Inj.Circ. Short circuit to B+
P318700Cyl.15-Fuel Inj.Circ. Open circuit
P318800Cyl.16-Fuel Inj.Circ. Short-circuit to ground
P318900Cyl.16-Fuel Inj.Circ. Short circuit to B+
P319000Cyl.16-Fuel Inj.Circ. Open circuit
P319100Intake Manifold Runner Control (IMRC) Basic setting aborted with mechanical impact open
P319200Intake Manifold Runner Control (IMRC) Basic setting aborted with mechanical impact open
P319300Intake Manifold Runner Control (IMRC) open impact outside valid range
P319400Mass Air Flow (MAF) Sensor 3 -G456 Signal too low
P319500Mass Air Flow (MAF) Sensor 3 -G456 Signal too high
P319600Mass Air Flow (MAF) Sensor 4 -G457 Signal too low
P319700Mass Air Flow (MAF) Sensor 4 -G457 Signal too high
P319800Intake manifold Runner Control (IMRC) Implausible signal
P319900Activation Intake Manifold Runner Bank 2 Control Implausible signal
P319A00Air mass meter 3/4 Correlation
P319B00Mass Air Flow (MAF) Sensor 3 -G456 Implausible signal
P319C00Mass Air Flow (MAF) Sensor 4 -G457 Implausible signal
P319D00Activation Intake Manifold Runner Bank 2 Control Short circuit to B+
P319E00Activation Intake Manifold Runner Bank 2 Control Open circuit/short circuit to ground
P320000Exhaust-bank3 -sensor1, heating circuit Short-circuit to ground
P320100Exhaust-bank3 -sensor1, heating circuit Short circuit to B+
P320200Exhaust-bank3 -sensor1, heating circuit Open circuit
P320300Exhaust-bank3 -sensor1, heating circuit Malfunction
P320400Emissions-bank3-sensor1 Internal resistance too Large
P320500Emissions-bank3-sensor1 Low Voltage
P320600Emissions-bank3-sensor1 High Voltage
P320700Emissions-bank3-sensor1 electrical malfunction in circuit
P320800Emissions-bank3-sensor1 No Activity Detected
P320900Emissions-bank3-sensor1 Slow Response
P321000Exhaust-bank3 -sensor1, heating circuit Performance too low
P321100Exhaust-bank1-sensor1 Heater back-coupling
P321200Exhaust-bank2-sensor1 Heater back-coupling
P321300Emissions-bank3-sensor1 Heater back-coupling
P321400Emissions-bank4-sensor1 Heater back-coupling
P321500Emissions-bank3-sensor2,heater circuit Short-circuit to ground
P321600Emissions-bank3-sensor2,heater circuit Short circuit to B+
P321700Emissions-bank3-sensor2,heater circuit Open circuit
P321800Emissions-bank3-sensor2,heater circuit Malfunction
P321900Emissions-bank3-sensor2 Internal resistance too Large
P322000Emissions-bank3-sensor2 Low Voltage
P322100Emissions-bank3-sensor2 High Voltage
P322200Emissions-bank3-sensor2 electrical malfunction in circuit
P322300Emissions-bank3-sensor2 No Activity Detected
P322400Emissions-bank3-sensor2 Slow Response
P322500Exhaust-bank3,oxygen sensor correction behind cat Control limit reached
P322600Exhaust-bank4,oxygen sensor correction behind cat Control limit reached
P322700Exhaust-Bank1,Sensor1,Individual Cylinder Control Sensor dynamic to low
P322800Exhaust-bank1,sensor1,oxygen sensor signal implausible lean
P322900Exhaust-bank1,sensor1,oxygen sensor signal Implausible rich
P323000Exhaust-bank4 -sensor1, heating circuit Short-circuit to ground
P323100Exhaust-bank4 -sensor1, heating circuit Short circuit to B+
P323200Exhaust-bank4 -sensor1, heating circuit Open circuit
P323300Exhaust-bank4 -sensor1, heating circuit Malfunction
P323400Emissions-bank4-sensor1 Internal resistance too Large
P323500Emissions-bank4-sensor1 Low Voltage
P323600Emissions-bank4-sensor1 High Voltage
P323700Emissions-bank4-sensor1 electrical malfunction in circuit
P323800Emissions-bank4-sensor1 No Activity Detected
P323900Emissions-bank4-sensor1 Slow Response
P324000Exhaust-bank4 -sensor1, heating circuit Performance too low
P324100Intake Manifold Runner Control (IMRC) Temperature too high
P324200Intake Manifold Runner Bank 2 Temperature too high
P324300Idle Speed Contr.Throttle Pos. Electrical malfunction
P324400Idle Speed Control Throttle Position 2 Electrical malfunction
P324500Emissions-bank4-sensor2,heater circuit Short-circuit to ground
P324600Emissions-bank4-sensor2,heater circuit Short circuit to B+
P324700Emissions-bank4-sensor2,heater circuit Open circuit
P324800Emissions-bank4-sensor2,heater circuit Malfunction
P324900Emissions-bank4-sensor2 Internal resistance too Large
P325000Emissions-bank4-sensor2 Low Voltage
P325100Emissions-bank4-sensor2 High Voltage
P325200Emissions-bank4-sensor2 electrical malfunction in circuit
P325300Emissions-bank4-sensor2 No Activity Detected
P325400Emissions-bank4-sensor2 Slow Response
P325500Bank 1, O2 sensor before cat. conv., heater circuit Regulation at upper impact
P325600Bank 1, O2 sensor before cat. conv., heater circuit Regulation at lower impact
P325700Bank 2, O2 sensor before cat. conv., heater circuit Regulation at upper impact
P325800Bank 2, O2 sensor before cat. conv., heater circuit Regulation at lower impact
P325900Auxiliary fuel pump for engine start Malfunction
P326000Exhaust bank 1/2 oxygen sensors before catalytic converter swapped
P326100Exhaust bank 3/4 oxygen sensors before catalytic converter swapped
P326200Exhaust bank 1/2 oxygen sensors behind catalytic converter swapped
P326300Exhaust bank 3/4 oxygen sensors behind catalytic converter swapped
P326400Pre-catalytic converter, emissions bank 3 Efficiency below threshold
P326500Pre-catalytic converter, exhaust bank 4 Efficiency below threshold
P326600Bank 1, sensor 1 Internal resistance too Large
P326700Bank 2, sensor 1 Internal resistance too Large
P326800Linear Lambda probe, exhaust gas bank 2 / pump current Open circuit
P326900Linear Lambda probe, exhaust gas bank 2 / pump current Short-circuit to ground
P327000Linear Lambda probe, exhaust gas bank 2 / pump current Short circuit to B+
P327100Linear Lambda probe, exhaust gas bank 2 / reference voltage Open circuit
P327200Linear Lambda probe, exhaust gas bank 2 / reference voltage Short-circuit to ground
P327300Linear Lambda probe, exhaust gas bank 2 / reference voltage Short circuit to B+
P327400Linear Lambda probe, exhaust gas bank 2 / reference voltage Implausible
P327500Linear Lambda probe, exhaust bank 2 / common Ground (GND) wire Open circuit
P327600Linear Lambda probe, exhaust bank 2 / common Ground (GND) wire Short-circuit to ground
P327700Linear Lambda probe, exhaust bank 2 / common Ground (GND) wire Short circuit to B+
P327800Linear Lambda probe, exhaust gas bank 3 / pump current Open circuit
P327900Linear Lambda probe, exhaust gas bank 3 / pump current Short-circuit to ground
P328000Linear Lambda probe, exhaust gas bank 3 / pump current Short circuit to B+
P328100Linear Lambda probe, exhaust gas bank 3 / reference voltage Open circuit
P328200Linear Lambda probe, exhaust gas bank 3 / reference voltage Short-circuit to ground
P328300Linear Lambda probe, exhaust gas bank 3 / reference voltage Short circuit to B+
P328400Linear Lambda probe, exhaust gas bank 3 / reference voltage Implausible
P328500Linear Lambda probe, exhaust bank 3 / common Ground (GND) wire Open circuit
P328600Linear Lambda probe, exhaust bank 3 / common Ground (GND) wire Short-circuit to ground
P328700Linear Lambda probe, exhaust bank 3 / common Ground (GND) wire Short circuit to B+
P328800Linear Lambda probe, exhaust gas bank 4 / pump current Open circuit
P328900Linear Lambda probe, exhaust gas bank 4 / pump current Short-circuit to ground
P329000Linear Lambda probe, exhaust gas bank 4 / pump current Short circuit to B+
P329100Linear Lambda probe, exhaust gas bank 4 / reference voltage Open circuit
P329200Linear Lambda probe, exhaust gas bank 4 / reference voltage Short-circuit to ground
P329300Linear Lambda probe, exhaust gas bank 4 / reference voltage Short circuit to B+
P329400Linear Lambda probe, exhaust gas bank 4 / reference voltage Implausible
P329500Linear Lambda probe, exhaust bank 4 / common Ground (GND) wire Open circuit
P329600Linear Lambda probe, exhaust bank 4 / common Ground (GND) wire Short-circuit to ground
P329700Linear Lambda probe, exhaust bank 4 / common Ground (GND) wire Short circuit to B+
P329800Catalytic converter system, exhaust-bank 3 Efficiency below threshold
P329900Catalytic converter system, exhaust-bank 4 Efficiency below threshold
P330000Bank1, Camshaft Position (CMP) Sensor, exhaust =>-G300 Short-circuit to ground
P330100Bank1, Camshaft Position (CMP) Sensor, exhaust =>-G300 Open circuit/short circuit to B+
P330200Bank2, Camshaft Position (CMP), exhaust =>Sensor -G301- Short-circuit to ground
P330300Bank2, Camshaft Position (CMP), exhaust =>Sensor -G301- Open circuit/short circuit to B+
P330400Bank1,exhaust-Camshaft Position (CMP) Sensor-G300/-G28 Incorrect allocation
P330500Bank2, exhaust - Camshaft Position (CMP) Sensor-G301- / -G28- Incorrect allocation
P330600Ignition control cylinder 13 Short-circuit to ground
P330700Ignition control cylinder 13 Short circuit to B+
P330800Ignition control cylinder 13 Open circuit
P330900Ignition control cylinder 14 Short-circuit to ground
P331000Ignition control cylinder 14 Short circuit to B+
P331100Ignition control cylinder 14 Open circuit
P331200Ignition control cylinder 15 Short-circuit to ground
P331300Ignition control cylinder 15 Short circuit to B+
P331400Ignition control cylinder 15 Open circuit
P331500Ignition control cylinder 16 Short-circuit to ground
P331600Ignition control cylinder 16 Short circuit to B+
P331700Ignition control cylinder 16 Open circuit
P331800Glow Plug/Heater Relay 2 Circ. Short circuit to B+
P331900Glow Plug/Heater Relay 2 Circ. Open circuit/short circuit to ground
P332000Unit Injector Valve Control 2 Short circuit to B+
P332100Unit Injector Valve Control 2 Electrical malfunction in circuit
P332200Relay 2 for Power Supply (B+) Terminal 30 Implausible signal
P332300Voltage supply terminal 15 High Voltage
P332400Voltage supply terminal 15 Open circuit
P332500Voltage supply terminal 15 Implausible
P332600Change-over valve for intake manifold flap 2 Short circuit to B+
P332700Change-over valve for intake manifold flap 2 Open circuit/short circuit to ground
P332800Intake Flap Motor 2 Short circuit to B+
P332900Intake Flap Motor 2 Open circuit/short circuit to ground
P333000Intake Flap Motor 2 No signal
P333100Intake Flap Motor 2 Defective
P333200Combustion detection in deceleration mode
P333300Turbocharger (TC) control module 1 implausible message
P333400Turbocharger (TC) control module 2 implausible message
P333500Turbocharger (TC) control module 1 missing message
P333600Turbocharger (TC) control module 2 missing message
P333700Engine databus/engine implausible message
P333800Activation glow time control module 1 Electrical malfunction in circuit
P333900Activation glow time control module 2 Electrical malfunction in circuit
P334000Charge Pressure Cooler Fan Relay Short circuit to B+
P334100Charge Pressure Cooler Fan Relay Short-circuit to ground
P334200Charge Pressure Cooler Fan Relay Open circuit
P334300Exhaust turbocharger control module 1 Temperature too high
P334400Exhaust turbocharger control module 1 Voltage supply outside the permissible range
P334500Turbocharger 2 Control Module Temperature too high
P334600Turbocharger 2 Control Module Voltage supply outside the permissible range
P334700Glow Plug/Heater Relay Circ. Electrical malfunction
P334800Activation turbocharger control unit bank 1 Electrical malfunction in circuit
P334900Activation Turbocharger 2 Control Module Electrical malfunction in circuit
P334A00Charge pressure actuator position sensor Electrical malfunction
P335000Long Term Fuel Trim, NG Range 1 Too Lean
P335100Long Term Fuel Trim, NG Range 1 Too Rich
P335200Long Term Fuel Trim, NG Range 2 Too Lean
P335300Long Term Fuel Trim, NG Range 2 Too Rich
P335400Long Term Fuel Trim, NG Range 3 Too Lean
P335500Long Term Fuel Trim, NG Range 3 Too Rich
P335600Catalyst System,Bank1 during NG operation Efficiency below threshold
P335700O2 Correction during NG operation Control limit reached
P335800O2 Sensor Circ., exhaust gas Bank1-Sensor1 at NG operation Slow Response
P335900O2 Sensor Circ., exhaust gas Bank1-Sensor1 at NG operation Heater back-coupling
P335A00System too Lean at NG operation
P335B00System Too Rich at NG operation
P335C00Fuel tank pressure sensor high pressure Signal too high
P335D00Fuel tank pressure sensor high pressure Signal too low
P336000O2 Sensor Circ., exhaust gas Bank1-Sensor1 at NG operation No Activity Detected
P336100NG operation Random/Multiple Cylinder. Misfire Detected
P336200NG operation Cyl.1 Random/Multiple Cylinder. Misfire Detected
P336300NG operation Cyl.2 Random/Multiple Cylinder. Misfire Detected
P336400NG operation Cyl.3 Random/Multiple Cylinder. Misfire Detected
P336500NG operation Cyl.4 Random/Multiple Cylinder. Misfire Detected
P336600System pressure, NG too High
P336700System pressure, NG too Low
P336800O2 Sensor Signal Stuck Rich Bank 3 Sensor 1
P336900O2 Sensor Signal Stuck Rich Bank 2 Sensor 1
P336A00System pressure, NG Implausible signal
P336B00NG temperature sensor Short circuit to B+
P336C00NG temperature sensor Short-circuit to ground
P336D00NG temperature sensor Implausible signal
P336E00NG fuel pump relay Short circuit to B+
P336F00NG fuel pump relay Short-circuit to ground
P337000O2 Sensor Signal Stuck Rich Bank 3 Sensor 1
P337100O2 Sensor Signal Stuck Rich Bank 2 Sensor 1
P337200Intake Manifold Change-Over Valve Short circuit to B+
P337300Intake Manifold Change-Over Valve Open circuit/short circuit to ground
P337400Intake Manifold 2 Change-Over Valve Short circuit to B+
P337500Intake Manifold 2 Change-Over Valve Open circuit/short circuit to ground
P337600Intake Air Temperature Sensor 3 Signal too low
P337700Intake Air Temperature Sensor 3 Signal too high
P337800Intake Air Temperature Sensor 3 Implausible signal
P337900NG High Pressure Valve Open circuit
P337A00Voltage supply relay Short circuit to B+
P337B00Voltage supply relay Short-circuit to ground
P337C00Voltage supply relay Open circuit
P337D00Relay for shut-off valve for high pressure valve Short circuit to B+
P337E00Relay for shut-off valve for high pressure valve Short-circuit to ground
P337F00Relay for shut-off valve for high pressure valve Open circuit
P338000NG High Pressure Valve Short circuit to B+
P338100NG High Pressure Valve Short-circuit to ground
P338200Fuel Tank Pressure (FTP) Sensor -G400 Open circuit
P338300Fuel Tank Pressure (FTP) Sensor -G400 Short circuit to B+
P338400Fuel Tank Pressure (FTP) Sensor -G400 Short-circuit to ground
P338500Fuel Rail Sensor Open circuit
P338600Fuel Rail Sensor Short circuit to B+
P338700Fuel Rail Sensor Short-circuit to ground
P338800Fuel Injection Valve 1 Open circuit
P338900Fuel Injection Valve 1 Short circuit to B+
P338A00Fuel Tank Pressure (FTP) Sensor -G400 Implausible signal
P338B00Fuel Tank Level Sensor Short circuit to B+
P338C00Fuel Tank Level Sensor Short-circuit to ground
P338D00Fuel Tank Level Sensor Implausible signal
P338E00Indicator light for operating mode switch-over Short circuit to B+
P338F00Indicator light for operating mode switch-over Short-circuit to ground
P339000Fuel Injection Valve 1 Short-circuit to ground
P339100Fuel Injection Valve 2 Open circuit
P339200Fuel Injection Valve 2 Short circuit to B+
P339300Fuel Injection Valve 2 Short-circuit to ground
P339400Fuel Injection Valve 3 Open circuit
P339500Fuel Injection Valve 3 Short circuit to B+
P339600Fuel Injection Valve 3 Short-circuit to ground
P339700Fuel Injection Valve 4 Open circuit
P339800Fuel Injection Valve 4 Short circuit to B+
P339900Fuel Injection Valve 4 Short-circuit to ground
P339A00Shut-Off valve 1 for NG fuel tank Short circuit to B+
P339B00Shut-Off valve 1 for NG fuel tank Short-circuit to ground
P339C00Shut-Off valve 1 for NG fuel tank Open circuit
P339D00Shut-Off valve 2 for NG fuel tank Short circuit to B+
P339E00Shut-Off valve 2 for NG fuel tank Short-circuit to ground
P339F00Shut-Off valve 2 for NG fuel tank Open circuit
P33A000Shut-Off valve 3 for NG fuel tank Short circuit to B+
P33A100Shut-Off valve 3 for NG fuel tank Short-circuit to ground
P33A200Shut-Off valve 3 for NG fuel tank Open circuit
P33A300Shut-Off valve 4 for NG fuel tank Short circuit to B+
P33A400Shut-Off valve 4 for NG fuel tank Short-circuit to ground
P33A500Shut-Off valve 4 for NG fuel tank Open circuit
VW DTC List U-Codes
DTCDTC Text
U000100High Speed CAN Communication Bus
U000200High Speed CAN Communication Bus Performance
U000900High Speed CAN Communication Bus (-) shorted to Bus (+)
U001000Medium Speed CAN Communication Bus
U001100Medium Speed CAN Communication Bus Performance
U001800Medium Speed CAN Communication Bus (-) shorted to Bus (+)
U002800Vehicle Communication Bus A
U002900Vehicle Communication Bus A Performance
U003700Vehicle Communication Bus B
U003800Vehicle Communication Bus B Performance
U004600Vehicle Communication Bus C
U004700Vehicle Communication Bus C Performance
U005400Vehicle Communication Bus C (-) shorted to Bus C (+)
U005500Vehicle Communication Bus D
U005600Vehicle Communication Bus D Performance
U006300Vehicle Communication Bus D (-) shorted to Bus D (+)
U006400Vehicle Communication Bus E
U006500Vehicle Communication Bus E Performance
U007200Vehicle Communication Bus E (-) shorted to Bus E (+)
U010000Lost Communication with ECM/PCM
U010100Lost Communication with TCM
U010300Lost Communication with Gear Shift Module
U010500Lost Communication With Fuel Injector Control Module
U010900Lost Communication With Fuel Pump Control Module
U010C00Lost Communication With Turbocharger/Supercharger Control Module "A"
U010D00Lost Communication With Turbocharger/Supercharger Control Module "B"
U011000Lost Communication With Drive Motor Control Module "A"
U011100Lost Communication With Battery Energy Control Module "A"
U011200Lost Communication With Battery Energy Control Module "B"
U011400Lost Communication With Four-Wheel Drive Clutch Control Module
U011500Lost Communication With ECM/PCM "B"
U012100Lost Communication With Anti-Lock Brake System (ABS) Control Module
U012200Lost Communication With Vehicle Dynamics Control Module
U012300Lost Communication With Yaw Rate Sensor Module
U012500Lost Communication With Multi-axis Acceleration Sensor Module
U012600Lost Communication With Steering Angle Sensor Module
U012700Lost Communication With Tire Pressure Monitor Module
U012800Lost Communication With Brake System Control Module
U013000Lost Communication With Steering Effort Control Module
U013200Lost Communication With Suspension Control Module "A"
U013900Lost Communication With Suspension Control Module "B"
U014600Lost Communication With Gateway "A"
U015100Lost Communication With Restraints Control Module
U016700Lost Communication With Vehicle Immobilizer Control Module
U030100Software Incompatibility With ECM/PCM
U030200Software Incompatibility with Transmission Control Module
U030500Software Incompatibility With with Cruise Control Module
U031500Software Incompatibility with Anti-Lock Brake System Control Module
U031700Software Incompatibility with Park Brake Control Module
U032100Software Incompatibility with Suspension Control Module
U032200Software Incompatibility With Body Control Module
U032300Software Incompatibility With Instrument Panel Control Module
U040100Invalid Data Received From ECM/PCM "A"
U040200Invalid Data Received From Transmission Control Module
U040400Invalid Data Received From Gear Shift Control Module
U040500Invalid Data Received From Cruise Control Module
U040600Invalid Data Received From Fuel Injector Control Module
U040D00Invalid Data Received From Turbocharger/Supercharger Control Module "A"
U040E00Invalid Data Received From Turbocharger/Supercharger Control Module "B"
U041000Invalid Data Received From Fuel Pump Control Module
U041200Invalid Data Received From Battery Energy Control Module "A"
U041400Invalid Data Received From Four-Wheel Drive Clutch Control Module
U041500Invalid Data Received From Anti-Lock Brake System Control Module
U041600Invalid Data Received From Vehicle Dynamics Control Module
U042600Invalid Data Received From Vehicle Immobilizer Control Module
U044200Invalid Data Received From ECM/PCM
U044700Invalid Data Received From Gateway "A"
U100600NOX Sensor 1 Bank 1 No communication
U100700Control unit for battery monitoring please read DTC
U100800Diagnostic interface for databus -J533- please read DTC
U100900Diagnostic interface for databus -J533- implausible message
U100A00Access and start authorization No communication
U100B00Access and start authorization Implausible signal
U100C00ABS Control Module no communication due to low voltage.
U100D00Local databus for senders and sensors Defective
U101100Supply voltage Voltage too low
U101200Supply voltage Voltage too high
U101300Control module not coded
U101400Control unit incorrectly coded
U101800Control module for instrument panel insert Missing signal ambient temperature
U101900Control module for instrument panel insert Missing signal oil level/temperature
U101F00Engine Control Module (ECM) please read DTC
U102600Transmission ECU please read DTC
U102700Speedometer Vehicle Speed Sensor (VSS) Upper limit exceeded
U102800Lost Communication With Steering Column Control Module please read DTC
U102900Access/Start Control Module please read DTC
U102A00Vehicle Communication Bus 2 Defective
U102B00Vehicle Communication Bus 2 No communication
U102C00ESP please read DTC
U102E00Radiator Identification Sensor Implausible signal
U102F00Radiator Identification Sensor No Communication
U103000Local databus Electrical malfunction
U103400NOX Sensor 1 Bank 1 Implausible signal
U103500NOX Sensor 1 Bank 2 Implausible signal
U103600NOX Sensor 1 Bank 2 No Communication
U104000Differential Lock Control Module No communication
U104100Differential Lock Control Module Implausible signal
U104B00Local databus Implausible signal
U105000Control unit for battery monitoring No Communication
U105100Control unit for battery monitoring Implausible signal
U105200Generator No Communication
U105300Generator Implausible signal
U107600Local databus 2 Electrical malfunction
U108D00Sensor electronics control module Implausible signal
U108E00Control Module in Steering Wheel No Communication
U108F00Control Module in Steering Wheel Implausible signal
U109200Awakening wire from Access/Start Control Module Short circuit to B+
U109300Awakening wire from Access/Start Control Module Short-circuit to ground
U109400Clutch pedal switch 2 Implausible signal
U109500ESCL control module No communication
U10A200Sensor Electronics Control Module 2 No communication
U10BE00Control module for all-wheel drive on FlexRay data bus No communication
U10BF00Voltage stabilizer Implausible signal
U10C100NOX Sensor 2 Bank 1 Implausible signal
U10C200NOX Sensor 2 Bank 1 No Communication
U110000Component protection No basic setting
U110100Component protection active
U110200Local databus for senders and sensors No communication
U110300Production mode active
U110400Expanded bus operation active
U111000Function restriction due to communication interruption
U111100Function limitation due to missing message
U111200Function limitation due to implausible message
U111300Function limitation due to received malfunction value
U140000Function restriction due to insufficient voltage
U140100Function restriction due to excessive voltage
U140200Consumer disconnection active
U140300Function restriction due to high-volt undervoltage
U140400Function restriction due to high-volt overvoltage
U140500Terminal 15 Implausible signal
U140600Static current too high
U140700Terminal 30 Implausible signal
U140800Internal voltage measurement Implausible signal
U140900Internal temperature measurement Implausible signal
U140A00Terminal 30 Open circuit
