Admin
Создатель сайта
Команда форума
- Россия, Москва
- VW Tiguan 2.0 DBGC 2018, VW Touran 1.6 BSE 2008
Electrical system
VW Tiguan 2016 ->
VW Tiguan RUS 2017 ->
Repair Group
00 - Technical data
27 - Starter, current supply, CCS
90 - Gauges, instruments
92 - Windscreen wash/wipe system
94 - Lights, bulbs, switches - exterior
96 - Lights, bulbs, switches - interior
97 - Wiring
00 - Technical data
1 Safety information
1.1 Safety measures when working on vehicles with a start/stop system
1.2 Safety precautions when using testers and measuring instruments during a road test
2 Repair instructions
2.1 Contact corrosion
2.2 Routing and attachment of lines
3 Battery
3.1 Battery - general notes
3.2 Types of battery
1 Battery
1.1 Assembly overview - battery
1.2 Removing and installing battery
1.3 Disconnecting and connecting battery
1.4 Removing and installing battery tray
1.5 Checking battery
1.6 Charging battery
1.7 Removing and installing earth wire with battery monitor control unit J367
1.8 Adapting battery monitor control unit J367
2 Alternator
2.1 Assembly overview - alternator
2.2 Removing and installing alternator
2.3 Checking alternator
2.4 Removing and installing poly V-belt pulley
2.5 Removing and installing voltage regulator
3 Starter motor
3.1 Assembly overview - starter
3.2 Removing and installing starter motor
4 Cruise control system (CCS)
5 Start/stop system
5.1 General description - start/stop system
5.2 Overview of fitting locations - start/stop system
6 Adaptive cruise control
6.1 Overview of fitting locations - adaptive cruise control
6.2 Removing and installing automatic distance control unit
6.3 Calibrating adaptive cruise control
1 Dash panel insert
1.1 Assembly overview - dash panel insert
1.2 Assembly overview - head-up display
1.3 Removing and installing dash panel insert KX2
1.4 Removing and installing control unit for head-up display
2 Horn
2.1 Assembly overview - horn
2.2 Removing and installing treble horn H2 and bass horn H7
2.3 Removing and installing bracket for horn H2 / H7
1 windscreen wiper system.
1.1 Assembly overview - windscreen wiper system
1.2 Moving wipers to service position
1.3 Removing and installing wiper blade
1.4 Removing and installing wiper arms
1.5 Adjusting wiper arms
1.6 Removing and installing wiper motor V
1.7 Renewing wiper motor
1.8 Deactivating APP function of wiper motor
1.9 Removing and installing rain and light sensor
2 Windscreen washer system
2.1 Assembly overview - windscreen washer system
2.2 Removing and installing washer fluid reservoir
2.3 Removing and installing windscreen washer fluid level sender
2.4 Removing and installing windscreen washer pump
2.5 Removing and installing washer jets
2.6 Adjusting spray jets
3 Rear window wiper system
3.1 Assembly overview - rear window wiper system
3.2 Removing and installing wiper blade
3.3 Removing and installing wiper arm
3.4 Adjusting wiper arm
3.5 Removing and installing rear window wiper motor V12
4 Rear window washer system
4.1 Assembly overview - rear window washer system
4.2 Removing and installing washer fluid reservoir
4.3 Removing and installing rear window washer pump
4.4 Removing and installing washer jet
4.5 Adjusting spray jet
5 Headlight washer system
5.1 Assembly overview - headlight washer system
5.2 Removing and installing washer fluid reservoir
5.3 Removing and installing headlight washer system pump V11
5.4 Removing and installing pop-up cylinder
5.5 Adjusting spray jets
6 Washer fluid lines
6.1 Repairing washer fluid lines
1 Headlights
1.1 Assembly overview - headlight
1.2 Removing and installing headlight
1.3 Adjusting headlights
1.4 Adjusting headlight installation position
1.5 Removing and installing front turn signal bulb M5 / M7
1.6 Installing repair kit for headlight housing
1.7 Converting headlights from driving on right to driving on left
1.8 Converting headlights from driving on left to driving on right
1.9 Removing and installing headlight range control motor V48 / V49
1.10 Removing and installing dipped beam bulb
1.11 Removing and installing headlight main beam bulb M30 / M32
1.12 Removing and installing side light bulb M1 / M3
1.13 Removing and installing daytime running light bulb L174 / L175
1.14 Removing and installing LED modules for daytime running light and side light L176 / L177
1.15 Removing and installing bulbs for cornering light L148 / L149
1.16 Removing and installing output module for headlight J667 / J668
1.17 Removing and installing output module 1 for LED headlight A27 / A31
1.18 Removing and installing swivel module position sensor G474 / G475
1.19 Removing and installing dynamic cornering light control motor V318 / V319
2 Fog lights
2.1 Assembly overview - fog lights
2.2 Removing and installing fog light
2.3 Removing and installing fog light bulb L22 / L23
3 Lights in exterior mirror
3.1 Assembly overview - lights in exterior mirror
3.2 Removing and installing turn signal
3.3 Removing and installing entry light in exterior mirror
4 Tail lights
4.1 Assembly overview - tail lights in body
4.2 Assembly overview - tail lights in rear lid
4.3 Removing and installing tail light in rear lid
4.4 Adjusting installation position of tail light
4.5 Removing and installing tail light cluster
4.6 Removing and installing tail light bulb M2 / M4
4.7 Removing and installing rear fog light bulb L46 / L47
4.8 Removing and installing brake and tail light bulb M21 / M22
4.9 Removing and installing reversing light bulb
4.10 Removing and installing turn signal bulb
5 High-level brake light
5.1 Assembly overview - high-level brake light
5.2 Removing and installing high-level brake light
6 Number plate light
6.1 Assembly overview – number plate lights
6.2 Removing and installing number plate light X4 / X5
6.3 Removing and installing bulb for number plate light X4 / X5
7 Entry and start authorisation system
7.1 Overview of fitting locations - entry and start authorisation system
7.2 Overview of fitting locations - keyless entry system
7.3 Removing and installing interface for entry and start system J965
7.4 Removing and installing door exterior handle contact sensor G415 / G416
7.5 Removing and installing interior aerial 1 for entry and start system R138
7.6 Removing and installing interior aerial 2 for entry and start system R139
7.7 Removing and installing driver side aerial for entry and start system R134
7.8 Removing and installing front passenger side aerial for entry and start system R135
7.9 Removing and installing rear bumper aerial for entry and start system R136
7.10 Removing and installing luggage compartment aerial for entry and start system R137
7.11 Removing and installing rear lid power opening control unit J938
7.12 Removing and installing rear lid power opening sender G750 / G760
8 Steering column switch module
8.1 Assembly overview - steering column switch module
8.2 Removing and installing lock cylinder
8.3 Removing and installing ignition key withdrawal lock solenoid N376
8.4 Removing and installing ignition/starter switch
8.5 Removing and installing steering column switch module
8.6 Removing and installing steering column electronics control unit J527
8.7 Removing and installing turn signal switch E2
8.8 Removing and installing intermittent wiper switch E22
8.9 Removing and installing immobiliser reader coil D2
8.10 Removing and installing base for steering column combination switch
8.11 Removing and installing steering lock housing
9 Parking aid
9.1 Assembly overview – parking aid
9.2 Removing and installing parking aid control unit J446
9.3 Removing and installing front parking aid warning buzzer H22
9.4 Removing and installing rear parking aid warning buzzer H15
9.5 Removing and installing front parking aid senders
9.6 Removing and installing rear parking aid senders
10 Park assist steering
10.1 Assembly overview - park assist steering
10.2 Removing and installing park assist steering control unit J791
10.3 Removing and installing front senders
10.4 Removing and installing rear senders
11 Automatic headlight range control
11.1 Assembly overview - automatic headlight range control
11.2 Removing and installing cornering light and headlight range control unit J745
12 Towing bracket
12.1 Assembly overview - towing bracket socket
12.2 Trailer socket U10
12.3 Removing and installing trailer detector control unit J345
1 Lights
1.1 Overview of fitting locations - lights in dash panel
1.2 Overview of fitting locations - lights in front doors
1.3 Overview of fitting locations - lights in rear doors
1.4 Overview of fitting locations - lights in centre console
1.5 Overview of fitting locations - lights in luggage compartment
1.6 Overview of fitting locations - lights in roof trim
1.7 Removing and installing glove compartment light W6
1.8 Replacing bulb for glove compartment light W6
1.9 Removing and installing front footwell light K268 / K269
1.10 Removing and installing front footwell illumination bulb L151 / L152
1.11 Removing and installing Central locking SAFELOCK function warning lamp K133
1.12 Removing and installing reflectors in door
1.13 Removing and installing entry light W92 / W93
1.14 Removing and installing interior door handle illumination bulb L146 / L147
1.15 Removing and installing rear interior door handle illumination bulb L133 / L134
1.16 Removing and installing light 1 for front door background lighting L199 / L200
1.17 Removing and installing light 1 for rear door background lighting L201 / L202
1.18 Removing and installing roof ambient lighting bulb W76 / W77
1.19 Removing and installing selector lever position display Y26
1.20 Removing and installing luggage compartment light W3
1.21 Removing and installing electric torch R280
1.22 Removing and installing surround lighting 1 in rear lid W61
1.23 Removing and installing illuminated vanity mirror W20 / W14
1.24 Removing and installing bulb for front interior light W1
1.25 Removing and installing bulb for rear interior light W43
1.26 Removing and installing bulb for front reading light W13 / W19
1.27 Removing and installing bulb for rear reading light W11 / W12
1.28 Renewing bulb of rear interior light W47 / W48
2 Controls
2.1 Overview of fitting locations - controls in dash panel
2.2 Overview of fitting locations - controls in front doors
2.3 Overview of fitting locations - controls in rear doors
2.4 Overview of fitting locations - controls in centre console
2.5 Overview of fitting locations - controls in luggage compartment
2.6 Overview of fitting locations - controls in roof trim
2.7 Removing and installing rotary light switch EX1
2.8 Removing and installing headlight range control regulator E102
2.9 Removing and installing switch for Head-up Display E736
2.10 Removing and installing TCS and ESP button E256
2.11 Removing and installing parking aid button E266
2.12 Removing and installing park assist steering button E581
2.13 Removing and installing Start/Stop operation button E693
2.14 Removing and installing button for Charisma E735
2.15 Removing and installing switch module in centre console EX23 / EX30
2.16 Removing and installing operating unit for driving mode selection E881
2.17 Removing and installing hazard warning light switch EX3
2.18 Removing and installing buttons for seat heating E653 / E654
2.19 Removing and installing glove compartment light switch E26
2.20 Removing and installing exterior mirror adjuster EX11
2.21 Removing and installing operating unit for window regulator in driver door E512
2.22 Removing and installing front passenger side window regulator button E716
2.23 Removing and installing driver side interior locking button for central locking system E308
2.24 Removing and installing rear lid remote release button E233
2.25 Removing and installing button for deactivating interior monitoring and vehicle inclination sensor E616
2.26 Removing and installing door contact switch F2 / F3
2.27 Removing and installing rear window regulator button E711 / E713
2.28 Removing and installing rear door contact switches F10 / F11
2.29 Removing and installing electromechanical parking brake button E538 / auto-hold button E540
2.30 Removing and installing the starter button E378
2.31 Removing and installing rear lid warning buzzer H32
2.32 Removing and installing rear lid contact switch
2.33 Removing and installing rear lid closure button E574
2.34 Removing and installing electric hinged tow coupling attachment button E474
2.35 Removing and installing vanity mirror contact switch F147 / F148
2.36 Removing and installing sunroof button E325
2.37 Removing and installing front interior light/reading light
2.38 Removing and installing rear interior light/reading light
2.39 Removing and installing front reading light button E633 / E634
3 Anti-theft alarm
3.1 Assembly overview - interior monitor
3.2 Removing and installing alarm horn H12
3.3 Removing and installing anti-theft alarm sensor G578
4 Lane change assist
4.1 Assembly overview - lane change assist
4.2 Removing and installing lane change assist warning lamp in exterior mirror K233 / K234
4.3 Removing and installing lane change assist control unit J769 / J770
4.4 Calibrating lane change assist
5 Front camera for assist systems
5.1 Removing and installing front camera for driver assist systems
6 Cigarette lighter, socket
6.1 Assembly overview - DC/AC converter with socket, 12 V-230 V
6.2 Removing and installing cigarette lighter U1
6.3 Removing and installing socket illumination bulb L42
6.4 Removing and installing rear cigarette lighter illumination bulb L32
6.5 Removing and installing electric socket U
6.6 Removing and installing DC/AC converter with socket, 12 V-230 V U13
97 - Wiring
1 Relay carriers, fuse holders, electronics boxes
1.1 Overview of fitting locations - relay carriers, fuse holders, E-boxes
1.2 Removing and installing electronics box (E-box)
1.3 Removing and installing relay and fuse holder in electronics box
1.4 Removing and installing relay and fuse carrier behind dash panel
1.5 Removing and installing main fuse carrier
2 Select Control units
2.1 Overview of fitting locations - control units
2.2 Assembly overview - onboard supply control unit
2.3 Assembly overview - data bus diagnostic interface
2.4 Removing and installing onboard supply control unit J519
2.5 Removing and installing data bus diagnostic interface J533
2.6 Removing and installing bracket for onboard supply control unit J519
2.7 Renewing bracket for onboard supply control unit J519
2.8 Removing and installing parking aid control unit J446 / park assist steering control unit J791
2.9 Removing and installing rear lid control unit J605
3 Connectors
3.1 Repairing electrical wiring harnesses and plug-in connections
4 Releasing and dismantling connector housings
5 Repairing aerial wires
6 Fibre optic cables
7 Vehicle diagnosis, testing and information systems
vwts.ru
VW Tiguan 2016 ->
Repair Group
00 - Technical data
97 - Wiring
00 - Technical data
3 Battery
1 Battery
2 Alternator
3 Starter motor
5 Start/stop system
1 Dash panel insert
2 Horn
1 Headlights
2 Fog lights
4 Tail lights
9 Parking aid
12 Towing bracket
1 Lights
2 Controls
3 Anti-theft alarm
97 - Wiring
3 Connectors
Скачивание файла -vw-tiguan-2-electrical-system-eng.pdf
Документация по ремонту VW Skoda Audi Seat - repair manual
