Как подобрать датчик бокового удара в VW Passat B5 GP
  • Автор темы gpetrv
  • Ответы 6
    vw passat b5
gpetrv
Беларусь, Брест
VW Passat B5 1.9 AVB 2004г
VW Passat B5 2004г
1.9TD
Может кто в курсе как подобрать датчик бокового удара в B5GP
На мой старый ошибка 01222 - Crash Sensor Side Airbag; Passenger Side (G180)
30-00 - Open or Short to Plus
Установил с тем же номером б/у
Ошибка уже 01222 - Crash Sensor Side Airbag; Passenger Side (G180)
62-00 - No or Incorrect Adjustment
была такая фигня с тоураном ,купил со шротта, он не подошел не подошел к блоку
01222 - Crash Sensor Side Airbag; Passenger Side (G180): No or Incorrect Basic Setting / Adaptation
Possible Symptoms
  • Airbag Warning Light ON
Possible Causes
  • Wrong Crash Sensor Side Airbag; Passenger Side (G180) installed
  • Newly Installed Airbag Module is Not Compatible With Crash Sensor(s)
Possible Solutions
  • Install correct Crash Sensor Side Airbag; Passenger Side (G180)
  • Install Airbag Module that is Compatible With Crash Sensor(s)
Special Notes
  • The US Market (9M) Jettahas a common Airbag Control Module replacement conflict with the existing Crash Sensors. This is mentioned in TSB # 69-08-04 (TPI-2011170) with the following example:
    • When control module 1C0-909-605-F-004 (coded to 12340) is replaced with 1C0-909-605-F-01E the original Crash Sensors are not compatible. The new module will refuse coding if DTCs 01221, 01222, 01738, or 1739 are stored. This is also noted here: Airbag Coding
The Crash Sensors can be checked by using the control module identification and the measuring blocks.
Address 15: Airbags
Controller: 1T0 909 605
Component: 05 AIRBAG VW62 0506 2112
Coding: 0012341
The 0506 in this example stands for the required Crash Sensor ID, the first 2 digits (05) apply for the front crash sensors, while the second 2 digits (06) apply for the rear crash sensors. The ID of the currently installed Crash Sensors can be determined by checking Measuring Value Block (MVB) 009.
поехал на фаве аутохауз и заказал по vin
А номер на наклейке белой совпал со старым? Интересно как узнать тайну подбора, или их шьют специально под блок
не помню прошло больше полгода, только фото остались
Шьют под блок. Просто заменой нового или со шрота тут не обойдёшься.
Возможно ли перешить старый со шрота и как? Есть шанс подобрать со шрота подходящий если найти такую же по году/кузову машину?
Не знаю, сам я не прошиваю. У нас есть те, что занимаются чисто "хлопушками", они знают, что да как.
