01222 - Crash Sensor Side Airbag; Passenger Side (G180): No or Incorrect Basic Setting / Adaptation
Possible Symptoms
Possible Causes
- Wrong Crash Sensor Side Airbag; Passenger Side (G180) installed
- Newly Installed Airbag Module is Not Compatible With Crash Sensor(s)
Possible Solutions
- Install correct Crash Sensor Side Airbag; Passenger Side (G180)
- Install Airbag Module that is Compatible With Crash Sensor(s)
Special Notes
- The US Market (9M) Jettahas a common Airbag Control Module replacement conflict with the existing Crash Sensors. This is mentioned in TSB # 69-08-04 (TPI-2011170) with the following example:
- When control module 1C0-909-605-F-004 (coded to 12340) is replaced with 1C0-909-605-F-01E the original Crash Sensors are not compatible. The new module will refuse coding if DTCs 01221, 01222, 01738, or 1739 are stored. This is also noted here: Airbag Coding
The Crash Sensors can be checked by using the control module identification and the measuring blocks.
Address 15: Airbags
Controller: 1T0 909 605
Component: 05 AIRBAG VW62
0506 2112
Coding: 0012341
The 0506 in this example stands for the required Crash Sensor ID, the first 2 digits (05) apply for the front crash sensors, while the second 2 digits (06) apply for the rear crash sensors. The ID of the currently installed Crash Sensors can be determined by checking Measuring Value Block (MVB) 009.
