| Code | 1st | 2nd | 3rd | 4th | 5th | Final | Closeness Index | Speedometer Gear | Axle | Upshift Light | Application | Input Shaft | Family | Notes |
| EQ | 2.55 | 1.45 | 1 | - | - | 3.76 | 196.55 | - | 90mm | No | A1 | ? | 010 | Automatic |
| TB | 2.55 | 1.45 | 1 | - | - | 3.57 | 168.23 | - | 90mm | No | A1 | ? | 010 | Automatic |
| TC | 2.55 | 1.45 | 1 | - | - | 3.13 | 113.38 | - | 90mm | No | A1 | ? | 010 | 1982-1983 TD Automatic |
| TC | 2.55 | 1.45 | 1 | - | - | 3.51 | 159.89 | - | 90mm | No | A1 | ? | 010 | 1982-1983 gas Automatic |
| TCA | 2.55 | 1.45 | 1 | - | - | 3.57 | 168.23 | - | 90mm | No | A1 | ? | 010 | Automatic |
| TD | 2.55 | 1.45 | 1 | - | - | 3.13 | 113.38 | - | 90mm | No | A1 | ? | 010 | 1982-1983 TD Automatic |
| TD | 2.55 | 1.45 | 1 | - | - | 3.51 | 159.89 | - | 90mm | No | A1 | ? | 010 | 1982-1983 gas Automatic |
| TF | 2.71 | 1.5 | 1 | - | - | 3.41 | 161.19 | - | 90mm | No | A1 | ? | 010 | Automatic |
| TG | 2.71 | 1.5 | 1 | - | - | 3.13 | 124.65 | - | 90mm | No | A1 | ? | 010 | 1983-1984 TD Automatic |
| TG | 2.71 | 1.5 | 1 | - | - | 3.51 | 175.79 | - | 90mm | No | A1 | ? | 010 | 1983-1984 gas Automatic |
| TH | 2.71 | 1.5 | 1 | - | - | 3.51 | 175.79 | - | 90mm | No | A1 | ? | 010 | 1983-1984 gas Automatic |
| TJ | 2.71 | 1.5 | 1 | - | - | 3.12 | 123.46 | - | 90mm | No | A2 | ? | 010 | 1985-1987 Low Power Gas Automatic |
| TK | 2.71 | 1.5 | 1 | - | - | 3.41 | 161.19 | - | 90mm | No | A1 | ? | 010 | Automatic |
| TL | 2.71 | 1.5 | 1 | - | - | 3.41 | 161.19 | - | 90mm | No | A2 | ? | 010 | 1985-1987 Diesel Automatic |
| TN | 2.71 | 1.5 | 1 | - | - | 3.41 | 161.19 | - | 90mm | No | A2 | ? | 010 | 1988 Automatic |
| TNA | 2.71 | 1.5 | 1 | - | - | 3.41 | 161.19 | - | 90mm, 100mm (89-92) | No | A2 | ? | 010 | 1985-1992 Automatic |
| YH | 2.71 | 1.5 | 1 | - | - | 3.13 | 124.65 | - | 90mm | No | A1 | ? | 010 | 1983-1984 TD Automatic |
| - | 2.72 | 2.06 | 1.68 | 1.43 | 1.26 | 3.32 | 6841.36 | - | 100mm | No | A2 | 24mm | 020 | VW Motorsport |
| - | 2.5 | 1.79 | 1.42 | 1.17 | 1.03 | 4.2 | 10008.08 | - | 100mm | No | A2 | 22mm | 020 | VW Motorsport |
| - | 2.5 | 1.79 | 1.42 | 1.17 | 1.03 | 4.46 | 13513.84 | - | 100mm | No | A2 | 22mm | 020 | VW Motorsport |
| - | 2.5 | 1.79 | 1.42 | 1.17 | 1.03 | 4.64 | 16470.03 | - | 100mm | No | A2 | 22mm | 020 | VW Motorsport |
| - | 2.5 | 1.79 | 1.42 | 1.17 | 1.03 | 4.81 | 19716.5 | - | 100mm | No | A2 | 22mm | 020 | VW Motorsport |
| - | 2.72 | 2.06 | 1.68 | 1.43 | 1.26 | 4.2 | 22166.57 | - | 100mm | No | A2 | 24mm | 020 | VW Motorsport |
| - | 2.5 | 1.79 | 1.42 | 1.17 | 1.03 | 5.07 | 25653.36 | - | 100mm | No | A2 | 22mm | 020 | VW Motorsport |
| - | 2.72 | 2.06 | 1.68 | 1.43 | 1.26 | 4.46 | 29931.35 | - | 100mm | No | A2 | 24mm | 020 | VW Motorsport |
| - | 2.72 | 2.06 | 1.68 | 1.43 | 1.26 | 4.64 | 36478.91 | - | 100mm | No | A2 | 24mm | 020 | VW Motorsport |
| - | 2.72 | 2.06 | 1.68 | 1.43 | 1.26 | 4.81 | 43669.42 | - | 100mm | No | A2 | 24mm | 020 | VW Motorsport |
| - | 2.72 | 2.06 | 1.68 | 1.43 | 1.26 | 5.07 | 56818.76 | - | 100mm | No | A2 | 24mm | 020 | VW Motorsport |
| 2H | 3.46 | 2.12 | 1.44 | 1.13 | 0.91 | 3.94 | 10343.37 | White (16 tooth) | 100mm? | Yes | A1 | 22mm | 020 | Close Ratio '83 GTI |
| 2Y | 3.46 | 2.12 | 1.44 | 1.13 | 0.91 | 3.67 | 7214.14 | Red (15 tooth) | 100mm | No | A2 | 24mm | 020 | 1988-1992 Close Ratio 16v |
| 4A? | 3.46 | 1.75 | 1.07 | 0.71 | - | 3.94 | 1102.86 | White (16 tooth) | 90mm | Yes | A1 | ? | 020 | ? |
| 4K | 3.46 | 2.12 | 1.44 | 1.13 | 0.89 | 3.94 | 10139.23 | White (16 tooth) | 90mm | Yes | A1 | 22mm | 020 | Close Ratio |
| 4S | 3.46 | 1.94 | 1.29 | 0.91 | 0.75 | 3.94 | 5560.8 | White (16 tooth) | 90mm | Yes | A2 | 22mm | 020 | 1988-1992 Diesel |
| 4T | 3.46 | 1.94 | 1.29 | 0.91 | 0.75 | 3.67 | 3878.47 | Red (15 tooth) | 90mm | Yes | A1 | 22mm | 020 | Euro From 8/83 |
| 4Y | 3.46 | 2.12 | 1.44 | 1.13 | 0.89 | 3.67 | 7071.76 | Red (15 tooth) | 90mm | Yes | A1 | 22mm | 020 | Close Ratio 1.8 8v |
| 6G | 3.46 | 1.94 | 1.29 | 0.91 | 0.71 | 3.65 | 3596.55 | Red (15 tooth) | 90mm | Yes | A1 | 22mm | 020 | Euro 8/82-7/83 |
| 7A | 3.46 | 1.94 | 1.29 | 0.91 | 0.71 | 3.94 | 5307.02 | White (16 tooth) | 90mm | Yes | A1 | 22mm | 020 | From 8/83 |
| 7D? | 3.46 | 1.94 | 1.25 | 0.91 | 0.71 | 3.94 | 5158.46 | White (16 tooth) | ? | ? | T3 | ? | 020 | 82-83? |
| 7G | 3.46 | 2.12 | 1.44 | 1.13 | 0.91 | 3.65 | 7019.54 | Red (15 tooth) | 100mm? | Yes | A1 | 22mm | 020 | Close Ratio, Euro 8/82-7/83 |
| 8A | 3.46 | 1.94 | 1.29 | 0.91 | 0.75 | 3.67 | 3878.47 | Red (15 tooth) | 90mm | Yes | A1 | 22mm | 020 | Euro From 8/83 |
| 9A | 3.46 | 2.12 | 1.44 | 1.13 | 0.89 | 3.67 | 7071.76 | Red (15 tooth) | 100mm | Yes | A2 | 22mm | 020 | 1985-1988 Close Ratio |
| ACD | 3.46 | 2.12 | 1.44 | 1.13 | 0.89 | 3.67 | 7071.76 | Red (15 tooth) | 100mm | No | A2 | 22mm | 020 | 1988 Close Ratio |
| ACH | 3.46 | 1.94 | 1.37 | 1.03 | 0.75 | 3.94 | 6725.63 | White (16 tooth) | 90mm | Yes | A2 | 22mm | 020 | 1985-1988 Diesel |
| ACL | 3.46 | 1.94 | 1.37 | 1.03 | 0.75 | 3.67 | 4690.89 | Red (15 tooth) | 100mm | Yes | A2 | 22mm | 020 | 1988 1.8 8v |
| ACN | 3.46 | 1.94 | 1.37 | 1.03 | 0.75 | 3.67 | 4690.89 | Red (15 tooth) | 100mm, 90mm? | Yes | A2 | 22mm | 020 | 1985-1988 1.8 8v |
| AEN | 3.46 | 2.12 | 1.44 | 1.13 | 0.89 | 3.67 | 7071.76 | Red (15 tooth) | 100mm, 90mm? | No | A2 | 22mm | 020 | 1988 Close Ratio |
| AGB | 3.46 | 2.12 | 1.44 | 1.13 | 0.91 | 3.67 | 7214.14 | Red (15 tooth) | 100mm | Yes | A2 | 24mm | 020 | 1987-1988 Close Ratio 16v |
| AGS | 3.46 | 1.94 | 1.29 | 0.91 | 0.75 | 3.94 | 5560.8 | White (16 tooth) | 90mm | No | A2 | 22mm | 020 | 1987 1.6 Diesel |
| AMC | 3.46 | 1.94 | 1.28 | 0.97 | 0.81 | 3.67 | 4446.6 | Red (15 tooth) | 100mm | No | A3 | 24mm | 020 | 1993-1997 2.0 8v and 1.9 Diesel |
| AON | 3.46 | 1.94 | 1.37 | 1.03 | 0.75 | 3.67 | 4690.89 | Red (15 tooth) | 100mm | No | A2 | 22mm | 020 | 1988-1989 1.8 8v |
| AOP | 3.46 | 1.94 | 1.29 | 0.91 | 0.75 | 3.94 | 5560.8 | White (16 tooth) | 90mm | No | A2 | 22mm | 020 | 1988-1989 Diesel |
| APW | 3.46 | 1.94 | 1.37 | 1.03 | 0.85 | 3.67 | 5370.66 | Red (15 tooth) | 90mm | No | A3 | ? | 020 | 1992 1.8, Europe |
| ASF | 3.46 | 1.94 | 1.37 | 1.03 | 0.75 | 3.67 | 4690.89 | Red (15 tooth) | 100mm, 90mm? | No | A2 | 22mm | 020 | 1988-1989 1.8 8v |
| ATH | 3.46 | 1.94 | 1.28 | 0.91 | 0.75 | 3.67 | 3860.37 | Red (15 tooth) | 100mm | No | A3 | ? | 020 | 1992 1.9 Diesel, Europe |
| AUG | 3.46 | 1.94 | 1.44 | 1.13 | 0.89 | 3.67 | 6490.79 | Red (15 tooth) | 100mm | No | A2 | 22mm | 020 | 1989-1992 1.8 8v |
| AVX | 3.46 | 1.94 | 1.29 | 0.91 | 0.75 | 4.25 | 8110.55 | Green (17 tooth) | 90mm | No | A2 | 22mm | 020 | 1991-1992 ECODiesel |
| AWY | 3.46 | 1.94 | 1.44 | 1.13 | 0.89 | 3.94 | 9306.26 | White (16 tooth) | 90mm | No | A2 | 22mm | 020 | 1989-1992 Diesel |
| CHB | 3.46 | 1.94 | 1.37 | 1.03 | 0.85 | 3.67 | 5352.02 | Red (15 tooth) | 100mm | No | A3 | ? | 020 | 1993-1996 1.8 8v |
| CHD | 3.46 | 1.94 | 1.28 | 0.91 | 0.75 | 3.67 | 3860.37 | Red (15 tooth) | 100mm | No | A3 | ? | 020 | 1993-1996 1.9 Diesel |
| CHE | 3.46 | 1.94 | 1.28 | 0.97 | 0.81 | 3.67 | 4446.6 | Red (15 tooth) | 100mm | No | A3 | 24mm | 020 | 1993-1997 2.0 8v |
| DFN | 3.46 | 1.94 | 1.37 | 1.03 | 0.85 | 3.67 | 5352.02 | Red (15 tooth) | 100mm | No | A3 | ? | 020 | 1996-1999 1.8 and 2.0 8v |
| DFP | 3.46 | 1.94 | 1.28 | 0.91 | 0.75 | 3.67 | 3860.37 | Red (15 tooth) | 100mm | No | A3 | ? | 020 | 1996-1997 1.9 Diesel |
| DFQ | 3.46 | 1.94 | 1.28 | 0.97 | 0.81 | 3.67 | 4446.6 | Red (15 tooth) | 100mm | No | A3 | 24mm | 020 | 1996-1999 2.0 8v |
| DGD | 3.46 | 1.94 | 1.28 | 0.97 | 0.81 | 3.67 | 4446.6 | Red (15 tooth) | 100mm | No | A3 | 24mm | 020 | 1997-1999 2.0 8v |
| DGF | 3.46 | 1.94 | 1.44 | 1.13 | 0.89 | 3.67 | 6490.79 | Red (15 tooth) | 100mm | No | A3 | ? | 020 | 1.8 8v '90-'93 |
| DGT | 3.46 | 1.94 | 1.44 | 1.13 | 0.89 | 3.67 | 6490.79 | Red (15 tooth) | 100mm | No | A3 | ? | 020 | 1.8 8v '90-'93 |
| FD | 3.46 | 2.12 | 1.44 | 1.13 | 0.91 | 3.89 | 9741.14 | White (16 tooth) | 90mm | Yes | A1 | 22mm | 020 | Close Ratio |
| FF | 3.46 | 1.94 | 1.29 | 0.91 | 0.71 | 3.89 | 4998.03 | White (16 tooth) | 90mm | Yes | A1 | 22mm | 020 | From '81 |
| FF | 3.46 | 1.94 | 1.29 | 0.97 | 0.76 | 3.89 | 5687.62 | White (16 tooth) | 90mm | Yes | A1 | 22mm | 020 | Up to 07/80 |
| FH | 3.46 | 1.94 | 1.29 | 0.91 | 0.71 | 3.89 | 4998.03 | White (16 tooth) | 90mm | Yes | A1 | 22mm | 020 | From '81 |
| FH | 3.46 | 1.94 | 1.29 | 0.97 | 0.76 | 3.89 | 5687.62 | White (16 tooth) | 90mm | Yes | A1 | 22mm | 020 | Up to 07/80 |
| FJ | 3.46 | 1.94 | 1.29 | 0.91 | 0.71 | 3.89 | 4998.03 | White (16 tooth) | 90mm | Yes | A1 | 22mm | 020 | From '81 |
| FK | 3.46 | 2.12 | 1.44 | 1.13 | 0.91 | 3.89 | 9741.14 | White (16 tooth) | 90mm | Yes | A1 | 22mm | 020 | Close Ratio |
| FM | 3.46 | 2.12 | 1.44 | 1.13 | 0.91 | 3.89 | 9741.14 | White (16 tooth) | 90mm | Yes | A1 | 22mm | 020 | Close Ratio |
| FN | 3.46 | 1.94 | 1.29 | 0.91 | 0.71 | 3.89 | 4998.03 | White (16 tooth) | 90mm | Yes | A1 | 22mm | 020 | From '81 |
| FN | 3.46 | 1.94 | 1.29 | 0.97 | 0.76 | 3.89 | 5687.62 | White (16 tooth) | 90mm | Yes | A1 | 22mm | 020 | Up to 07/80 |
| FO | 3.46 | 1.94 | 1.29 | 0.97 | 0.76 | 3.89 | 5687.62 | White (16 tooth) | 90mm | Yes | A1 | 22mm | 020 | 11/78-5/79 |
| GC | 3.46 | 1.94 | 1.28 | 0.91 | - | 3.89 | 1796.81 | White (16 tooth) | 90mm | Yes | A1 | 22mm | 020 | 4 speed from '81 (Pickup) |
| GC | 3.46 | 1.94 | 1.29 | 0.97 | - | 3.89 | 1924.39 | White (16 tooth) | 90mm | Yes | A1 | 22mm | 020 | 4 speed to '80 (Rabbit) |
| GL | 3.46 | 1.75 | 1.07 | 0.71 | - | 3.89 | 1051.18 | White (16 tooth) | 90mm | Yes | A1 | 22mm | 020 | 3+E from '81 |
| GN | 3.46 | 1.94 | 1.28 | 0.91 | - | 3.89 | 1796.81 | White (16 tooth) | 90mm | Yes | A1 | 22mm | 020 | 4 speed from '81 |
| GP | 3.46 | 1.75 | 1.07 | 0.71 | - | 3.89 | 1051.18 | White (16 tooth) | 90mm | Yes | A1 | 22mm | 020 | 3+E from '81 |
| GY | 3.46 | 1.75 | 1.07 | 0.71 | - | 4.17 | 1382.41 | ? | 90mm | Yes | A1 | 22mm | 020 | 3+E Pickup |
| ? | ? | ? | ? | 0.85 | - | 5.43 | 0 | - | ? | ? | T3 | ? | 091 | Diesel |
| ? | ? | ? | ? | 0.85 | - | 5.86 | 0 | - | ? | ? | T3 | ? | 091 | Diesel |
| ? | 3.78 | 2.06 | 1.26 | 0.85 | - | 4.57 | 3637.59 | - | ? | ? | T3 | ? | 091 | Vanagon Aircooled |
| ABD | 3.78 | 2.06 | 1.23 | 0.85 | - | 4.83 | 4430.69 | - | ? | ? | T3 | ? | 091 | Vanagon Waterboxer |
| DU | 3.78 | 2.06 | 1.26 | 0.85 | - | 4.86 | 4652.58 | - | ? | ? | T3 | ? | 091 | Vanagon Waterboxer |
| APB | 2.71 | 1.55 | 1 | 0.68 | - | 4.22 | 908.16 | - | 100mm | No | A2 | ? | 096 | 1992 Corrado VR6 Automatic |
| APC | 2.71 | 1.55 | 1 | 0.68 | - | 4.22 | 908.16 | - | 100mm | No | A2 | ? | 096 | Corrado G60 Automatic |
| APE | 2.71 | 1.55 | 1 | 0.68 | - | 4.22 | 908.16 | - | 100mm | No | B3 | ? | 096 | Passat 16v Automatic |
| CFA | 2.71 | 1.55 | 1 | 0.68 | - | 3.7 | 535.67 | - | 100mm | No | A2, A3 | ? | 096 | Corrado, Golf, Jetta 3, VR6 Automatic |
| CFC | 2.71 | 1.55 | 1 | 0.68 | - | 4.22 | 908.16 | - | 100mm | No | A3 | ? | 096 | Golf, Jetta 3 2.0l Automatic |
| CFD | 2.71 | 1.55 | 1 | 0.68 | - | 4.53 | 1202.54 | - | 100mm | No | A3 | ? | 096 | Golf, Jetta 3 1.8l Automatic |
| CFF | 2.71 | 1.44 | 1 | 0.74 | - | 3.7 | 544.59 | - | 100mm | No | A2, A3, B3 | ? | 096 | Corrado, Passat, Golf, Jetta 3, VR6 Automatic |
| CFH | 2.71 | 1.44 | 1 | 0.74 | - | 4.22 | 923.29 | - | 100mm | No | A3 | ? | 096 | Golf, Jetta 3 2.0l Automatic |
| CFK | 2.71 | 1.44 | 1 | 0.74 | - | 4.53 | 1222.57 | - | 100mm | No | A3 | ? | 096 | Golf, Jetta 3 1.8l Automatic |
| CNK | 2.71 | 1.44 | 1 | 0.74 | - | 4.22 | 923.29 | - | 100mm | No | A3, B4 | ? | 096 | 1995-up Golf, Jetta 3, Passat 2.0l Automatic |
| CRR | 2.71 | 1.44 | 1 | 0.74 | - | 4.53 | 1222.57 | - | 100mm | No | A3 | ? | 096 | Golf, Jetta 3 1.8l Automatic |
| PSA | 3.45 | 1.79 | 1.13 | 0.83 | 0.68 | 4.11 | 4618.99 | - | ? | No | BX | ? | ? | Fox |
| PW | 3.45 | 1.7 | 1.06 | 0.78 | - | 3.89 | 1110.37 | - | ? | No | BX | ? | ? | Fox |
| XH | 3.45 | 2.05 | 1.29 | 0.88 | - | 4.11 | 2290.93 | - | ? | No | BX | ? | ? | 1976 Dasher |
| XK | 3.45 | 2.05 | 1.29 | 0.88 | - | 4.11 | 2290.93 | - | ? | No | BX | ? | ? | 1977-1978 Dasher |
| YZ | 3.45 | 1.95 | 1.37 | 0.94 | - | 4.11 | 2472.12 | - | ? | No | BX | ? | ? | 1975 Dasher to trans #30094 |
| YZ | 3.45 | 2.05 | 1.37 | 0.94 | - | 4.11 | 2598.9 | - | ? | No | BX | ? | ? | 1975 Dasher to trans #01104 |
| YZ | 3.45 | 2.05 | 1.37 | 0.97 | - | 4.11 | 2681.84 | - | ? | No | B1 | ? | ? | 1974 Dasher |
| CKX | 2.71 | 1.44 | 1 | 0.74 | - | 4.53 | 1222.57 | - | ? | No | B4 | ? | 01M | 1995-up Passat 1.8l Automatic |
| CKY | 2.71 | 1.44 | 1 | 0.74 | - | 4.53 | 1222.57 | - | ? | No | A3, B4 | ? | 01M | 1995-up Passat, Golf, Jetta 3 1.8l Automatic |
| CKZ | 2.71 | 1.44 | 1 | 0.74 | - | 3.27 | 333.46 | - | ? | No | A3, B4 | ? | 01M | 1995-up Passat, Golf, Jetta 3 TDI Automatic |
| CLB | 2.71 | 1.44 | 1 | 0.74 | - | 3.7 | 544.59 | - | ? | No | A3, B4 | ? | 01M | 1995-up Passat, Golf, Jetta 3 VR6 Automatic |
| CLK | 2.71 | 1.44 | 1 | 0.74 | - | 4.22 | 923.29 | - | ? | No | A3, B4 | ? | 01M | 1995-up Passat, Golf, Jetta 3 2.0l Automatic |
| DMP | 2.71 | 1.44 | 1 | 0.74 | - | 3.7 | 543.86 | - | ? | No | A4 | ? | 01M | Beetle, Golf, Jetta 4 TDI Automatic |
| DVH | 2.71 | 1.44 | 1 | 0.74 | - | 4.53 | 1225.24 | - | ? | No | A4 | ? | 01M | Golf, Jetta 4 1.8T Automatic |
| DYG | 2.71 | 1.55 | 1 | 0.68 | - | 4.88 | 1614.32 | - | ? | No | A4 | ? | 01M | Golf, Jetta 4 2.0l Automatic |
| DYQ | 2.71 | 1.55 | 1 | 0.68 | - | 4.88 | 1614.32 | - | ? | No | A4 | ? | 01M | Beetle 2.0L Automatic |
| EBP | 2.71 | 1.44 | 1 | 0.74 | - | 3.7 | 543.86 | - | ? | No | A4 | ? | 01M | Golf, Jetta 4 TDI Automatic |
| ECM | 2.71 | 1.44 | 1 | 0.74 | - | 4.27 | 961.99 | - | ? | No | A4 | ? | 01M | Golf, Jetta 4 VR6 Automatic |
| ECN | 2.71 | 1.44 | 1 | 0.74 | - | 3.7 | 543.86 | - | ? | No | A4 | ? | 01M | Golf, Jetta 4 TDI Automatic |
| ECP | 2.71 | 1.44 | 1 | 0.74 | - | 4.53 | 1225.24 | - | ? | No | A4 | ? | 01M | Beetle, Golf, Jetta 4 1.8T Automatic |
| ECV | 2.71 | 1.55 | 1 | 0.68 | - | 4.88 | 1614.32 | - | ? | No | A4 | ? | 01M | Golf, Jetta 4 2.0l Automatic |
| EFB | 2.71 | 1.44 | 1 | 0.74 | - | 3.7 | 543.86 | - | ? | No | A4 | ? | 01M | Golf, Jetta 4 2.0l Automatic |
| ELT | 2.71 | 1.44 | 1 | 0.74 | - | 3.7 | 543.86 | - | ? | No | A4 | ? | 01M | Golf, Jetta 4 TDI Automatic |
| ELU | 2.71 | 1.44 | 1 | 0.74 | - | 4.53 | 1225.24 | - | ? | No | A4 | ? | 01M | Golf, Jetta 4 1.8T Automatic |
| ELY | 2.71 | 1.55 | 1 | 0.68 | - | 4.88 | 1614.32 | - | ? | No | A4 | ? | 01M | Golf, Jetta 4 2.0l Automatic |
| ELZ | 2.71 | 1.44 | 1 | 0.74 | - | 3.7 | 543.86 | - | ? | No | A4 | ? | 01M | Golf, Jetta 4 2.0l Automatic |
| ENZ | 2.71 | 1.44 | 1 | 0.74 | - | 4.27 | 961.99 | - | ? | No | A4 | ? | 01M | Golf, Jetta 4 VR6 Automatic |
| EPC | 2.71 | 1.44 | 1 | 0.74 | - | 4.53 | 1225.24 | - | ? | No | A4 | ? | 01M | Beetle, Golf, Jetta 4 1.8T Automatic |
| EPG | 2.71 | 1.55 | 1 | 0.68 | - | 4.88 | 1614.32 | - | ? | No | A4 | ? | 01M | Golf, Jetta 4 2.0l Automatic |
| EPH | 2.71 | 1.44 | 1 | 0.74 | - | 3.7 | 543.86 | - | ? | No | A4 | ? | 01M | Golf, Jetta 4 2.0l Automatic |
| EPJ | 2.71 | 1.44 | 1 | 0.74 | - | 4.27 | 961.99 | - | ? | No | A4 | ? | 01M | Golf, Jetta 4 VR6 Automatic |
| EPL | 2.71 | 1.44 | 1 | 0.74 | - | 4.53 | 1225.24 | - | ? | No | A4 | ? | 01M | Beetle, Golf, Jetta 4 1.8T Automatic |
| FCZ | 2.71 | 1.44 | 1 | 0.74 | - | 4.27 | 961.99 | - | ? | No | A4 | ? | 01M | Golf, Jetta 4 VR6 Automatic |
| FDB | 2.71 | 1.44 | 1 | 0.74 | - | 3.7 | 543.86 | - | ? | No | A4 | ? | 01M | Golf, Jetta 4 TDI Automatic |
| FDC | 2.71 | 1.44 | 1 | 0.74 | - | 4.53 | 1225.24 | - | ? | No | A4 | ? | 01M | Golf, Jetta 4 1.8T Automatic |
| FDG | 2.71 | 1.44 | 1 | 0.74 | - | 3.7 | 543.86 | - | ? | No | A4 | ? | 01M | Golf, Jetta 4 2.0l Automatic |
| ACG | 3.78 | 2.11 | 1.35 | 0.97 | 0.8 | 3.94 | 7879.66 | - | ? | No | B3 | ? | 02A | Passat 16v |
| ASD | 3.3 | 1.94 | 1.31 | 0.97 | 0.72 | 3.94 | 5574.95 | - | ? | No | B3 | ? | 02A | Passat 16v |
| ATA | 3.78 | 2.11 | 1.35 | 0.97 | 0.8 | 3.68 | 5603 | - | ? | No | A2 | ? | 02A | Corrado G60 |
| AYK | 3.78 | 2.12 | 1.43 | 1.03 | 0.84 | 3.68 | 6682.81 | - | ? | No | A2, B3 | ? | 02A | Corrado G60, Passat 16v |
| AYL | 3.78 | 2.12 | 1.43 | 1.03 | 0.84 | 3.68 | 6682.81 | - | ? | No | A2, B3 | ? | 02A | Corrado G60, Passat 16v |
| CAW | 3.78 | 2.12 | 1.46 | 1.03 | 0.84 | 3.65 | 6522.12 | - | ? | No | A2 | ? | 02A | Corrado |
| CCM | 3.3 | 1.94 | 1.31 | 1.03 | 0.84 | 3.39 | 3250.43 | - | ? | No | A3, B3 | ? | 02A | Passat, Golf, Jetta 3 VR6 |
| CDM | 3.3 | 1.94 | 1.31 | 1.03 | 0.84 | 3.65 | 4690.96 | - | ? | No | A2 | ? | 02A | Corrado VR6 |
| CES | 3.78 | 2.12 | 1.43 | 1.03 | 0.84 | 3.68 | 6682.81 | - | ? | No | B4 | ? | 02A | Passat |
| CGY | 3.78 | 2.12 | 1.46 | 1.03 | 0.84 | 3.68 | 6818.43 | - | ? | No | B4 | ? | 02A | Passat |
| CHA | 3.78 | 2.12 | 1.36 | 0.92 | 0.72 | 3.94 | 6828.1 | - | ? | No | B4 | ? | 02A | Passat TDI |
| CHN | 3.3 | 1.94 | 1.31 | 1.03 | 0.84 | 3.39 | 3250.43 | - | ? | No | A3, B3 | ? | 02A | Passat, Golf, Jetta 3 VR6 |
| CNL | 3.78 | 2.12 | 1.46 | 1.03 | 0.84 | 3.68 | 6818.43 | - | ? | No | B4 | ? | 02A | Passat 2.0l |
| AYR | 3.78 | 2.12 | 1.35 | 0.97 | 0.76 | 3.94 | 7539.38 | - | ? | No | B3 | ? | 02C | Passat syncro 16v |
| CBC | 3.78 | 2.12 | 1.36 | 0.97 | 0.77 | 3.94 | 7664.05 | - | ? | No | B3 | ? | 02C | Passat syncro 16v |
| CHD | 3.78 | 2.12 | 1.36 | 0.97 | 0.77 | 3.94 | 7664.05 | - | ? | No | B3 | ? | 02C | Passat syncro 16v |
| CZM | 3.3 | 1.94 | 1.31 | 1.03 | 0.84 | 4.24 | 9845.23 | - | ? | No | A4 | ? | 02J | 1998 Beetle 2.0l |
| DQY | 3.78 | 2.12 | 1.36 | 0.97 | 0.76 | 3.39 | 3571.3 | - | ? | No | A4 | ? | 02J | Beetle, Golf, Jetta 4 TDI |
| DZC | 3.63 | 2.07 | 1.47 | 1.04 | 0.84 | 3.39 | 4333.94 | - | ? | No | A4 | ? | 02J | Golf , Jetta 4 VR6 |
| DZQ | 3.78 | 2.12 | 1.36 | 1.03 | 0.84 | 4.24 | 12768.35 | - | ? | No | A4 | ? | 02J | Beetle, Golf, Jetta 4 2.0l |
| EBJ | 3.78 | 2.12 | 1.36 | 0.97 | 0.76 | 3.39 | 3571.3 | - | ? | No | A4 | ? | 02J | Beetle, Golf, Jetta 4 TDI |
| EBP | 3.78 | 2.12 | 1.36 | 1.03 | 0.84 | 4.24 | 12768.35 | - | ? | No | A4 | ? | 02J | Beetle, Golf, Jetta 4 2.0l |
| EBQ | 3.3 | 1.94 | 1.31 | 1.03 | 0.84 | 3.94 | 6844.43 | - | ? | No | A4 | ? | 02J | Beetle, Golf, Jetta 4 1.8T |
| EGD | 3.3 | 1.94 | 1.31 | 1.03 | 0.84 | 3.94 | 6844.43 | - | ? | No | A4 | ? | 02J | 1999 Beetle 1.8T |
| EGF | 3.63 | 2.07 | 1.47 | 1.04 | 0.84 | 3.39 | 4333.94 | - | ? | No | A4 | ? | 02J | Golf , Jetta 4 VR6 |
| EGQ | 3.3 | 1.94 | 1.31 | 1.03 | 0.84 | 3.94 | 6844.43 | - | ? | No | A4 | ? | 02J | 2000-up Golf, Jetta 4 1.8T |
| EGR | 3.78 | 2.12 | 1.36 | 0.97 | 0.76 | 3.39 | 3571.3 | - | ? | No | A4 | ? | 02J | Beetle, Golf, Jetta 4 TDI |
| EGT | 3.78 | 2.12 | 1.36 | 1.03 | 0.84 | 4.24 | 12768.35 | - | ? | No | A4 | ? | 02J | Beetle, Golf, Jetta 4 2.0l |
| EHC | 3.63 | 2.07 | 1.47 | 1.04 | 0.84 | 3.39 | 4333.94 | - | ? | No | A4 | ? | 02J | Golf , Jetta 4 VR6 |
| EKG | 3.78 | 2.12 | 1.36 | 1.03 | 0.84 | 4.24 | 12768.35 | - | ? | No | A4 | ? | 02J | Beetle, Golf, Jetta 4 2.0l |
| EKH | 3.78 | 2.12 | 1.36 | 1.03 | 0.84 | 4.24 | 12768.35 | - | ? | No | A4 | ? | 02J | Beetle, Golf, Jetta 4 2.0l |
| EMS | 3.78 | 2.12 | 1.36 | 1.03 | 0.84 | 4.24 | 12768.35 | - | ? | No | A4 | ? | 02J | Beetle, Golf, Jetta 4 2.0l |
| EMT | 3.3 | 1.94 | 1.31 | 1.03 | 0.84 | 3.94 | 6844.43 | - | ? | No | A4 | ? | 02J | Beetle, Golf, Jetta 4 1.8T |
| EWW | 3.63 | 2.07 | 1.47 | 1.04 | 0.84 | 3.39 | 4333.94 | - | ? | No | A4 | ? | 02J | Golf , Jetta 4 VR6 |
| EZK | 3.78 | 2.12 | 1.36 | 1.03 | 0.84 | 4.24 | 12768.35 | - | ? | No | A4 | ? | 02J | Beetle, Golf, Jetta 4 2.0l |
| FBV | 3.78 | 2.12 | 1.36 | 1.03 | 0.84 | 4.24 | 12768.35 | - | ? | No | A4 | ? | 02J | Beetle, Golf, Jetta 4 2.0l |
| FBW | 3.3 | 1.94 | 1.31 | 1.03 | 0.84 | 3.94 | 6844.43 | - | ? | No | A4 | ? | 02J | 2000-up Golf, Jetta 4 1.8T |
| FBY | 3.63 | 2.07 | 1.47 | 1.04 | 0.84 | 3.39 | 4333.94 | - | ? | No | A4 | ? | 02J | Golf , Jetta 4 VR6 |
| FCF | 3.63 | 2.07 | 1.47 | 1.04 | 0.84 | 3.39 | 4333.94 | - | ? | No | A4 | ? | 02J | Golf , Jetta 4 VR6 |
