Эти ?
VAG-COM Measuring Block Labels file.
; Module 1 -- Engine
; from USA 1998 Audi A4 2.8L/5V
; ECU p/n 4D0-907-551-A, 2.8L V6/5V MOTR AT D04
; Modification history
; created: Paolo Sechi, 8 April 2001
; edited line 33,4 Keith Jurena, 08-15-2001
; Group 0 labels don't display (yet?) -- included for completeness
0,0,Engine Status
0,1,ECT,170-204
0,2,Load,20-50
0,3,RPM,62-86
0,4,T-ang,0-12
0,5,I-air,118-138
0,6,I-lrn,118-138
0,7,O2S1,77-179
0,8,O2S2,77-179
0,9,IO2S1,115-141
0,10,IO2S2,115-141
1,0,Engine Idle Speed (specified values listed) [A=AWD F=FWD]
1,1,Idle Speed,620-740A/+120F
1,2,Coolant Temp,80-105C
1,3,O2 Sens Bank1,+/-10%(>2% flct)
1,4,O2 Sens Bank2,+/-10%(>2% flct)
2,0,Load Measurement (specified values for idle/2520 RPM)
2,1,Engine speed,RPM
2,2,Engine load,1-2.5/.8-2.5ms
2,3,Injection time,2-5/1.6-5ms
2,4,Mass air flow,2.8-5.6/10-15g/s
3,0,Throttle Position Sensor check (ign on && eng off -> monitor angle as varied)
3,1,Engine speed,0 RPM
3,2,Mass air flow,g/s
3,3,Throttle angle,0-5deg closed
3,4,Ign timing,0deg
4,0,General Engine Data
4,1,Engine speed,RPM
4,2,Battery voltage,10-14.5V
4,3,Coolant temp,deg C
4,4,Intake air temp,deg C
5,0,Engine operating conditions (engine oil temp >80C) [A=AWD F=FWD]
5,1,Idle Speed,620-740A/+120F
5,2,Engine Load,1-2.5ms@idle
5,3,Vehicle Speed,km/h
5,4,Op condition,idl/prt/fl/dcl/erch
6,0,Undocumented
10,0,Undocumented
11,0,Undocumented
12,0,Undocumented
14,0,Misfire recognition (@idle) [A=AWD F=FWD]
14,1,Engine Speed,620-740A/+120F
14,2,Engine Load,1-2.5ms
14,3,Total misfires,0-30
14,4,Misfire status,activated
15,0,Misfire recognition cylinders 1-3 (@idle)
15,1,Cyl 1,0-5
15,2,Cyl 2,0-5
15,3,Cyl 3,0-5
15,4,Misfire status,activated
16,0,Misfire recognition cylinders 4-6 (@idle)
16,1,Cyl 4,0-5
16,2,Cyl 5,0-5
16,3,Cyl 6,0-5
16,4,Misfire status,activated
18,0,Undocumented
20,0,Undocumented
21,0,Undocumented
22,0,Knock control Cyl 1&&2 (must road test: RPM>2600 && load>3ms)
22,1,Engine speed,RPM
22,2,Engine load,ms
22,3,Ign ang corr 1,0-10deg
22,4,Ign ang corr 2,0-10deg
23,0,Knock control Cyl 3&&4 (must road test: RPM>2600 && load>3ms)
23,1,Engine speed,RPM
23,2,Engine load,ms
23,3,Ign ang corr 3,0-10deg
23,4,Ign ang corr 4,0-10deg
24,0,Knock control Cyl 5&&6 (must road test: RPM>2600 && load>3ms)
24,1,Engine speed,RPM
24,2,Engine load,ms
24,3,Ign ang corr 5,0-10deg
24,4,Ign ang corr 6,0-10deg
26,0,Undocumented
27,0,Undocumented
30,0,O2S ctrl op. condition [B=Bank S=Sensor] Fields:[heater on][oper.][ctrl active]
30,1,Status B1S1,111=OK
30,2,Status B1S2,111=OK
30,3,Status B2S1,111=OK
30,4,Status B2S2,111=OK
31,0,Undocumented
32,0,O2S control learning values (before Cat. Conv.) [B=Bank S=Sensor]
32,1,@idle B1S1,+/-10%
32,2,@part B1S1,+/-10%
32,3,@idle B2S1,+/-10%
32,4,@part B2S1,+/-10%
33,0,O2S control (before Cat. Conv.) [B=Bank S=Sensor]
33,1,Control B1S1,+/-10%(>2% flct)
33,2,Voltage B1S1,0-1V(>0.3V@30Hz)
33,3,Control B2S1,+/-10%(>2% flct)
33,4,Voltage B2S1,0-1V(>0.3V@30Hz)
34,0,O2S aging B1S1 (Coolant Temp >80C && engine 1800-2200 RPM until "OK")
34,1,Engine RPM,1800-2200
34,2,Engine Load,0.8-2.5ms
34,3,Time Period,0.2-2.1s
34,4,Diag Status,TestON/OFF|OK
35,0,O2S aging B2S1 (Coolant Temp >80C && engine 1800-2200 RPM until "OK")
35,1,Engine RPM,1800-2200
35,2,Engine Load,0.8-2.5ms
35,3,Time Period,0.2-2.1s
35,4,Diag Status,TestON/OFF|OK
36,0,O2S (beyond Cat. Conv.) [B=Bank S=Sensor]
36,1,Volt Supply B1S2,0-1V
36,2,Diag Status B1S2,TestON/OFF|OK
36,3,Volt Supply B2S2,0-1V
36,4,Diag Status B2S2,TestON/OFF|OK
37,0,[Undoc for 2.8/5V->data for 2.7T] Diag O2S ctrl Bank 1 (road test >10 min)
37,1,Engine Load,15-25%
37,2,O2S Volt S2,0-1V
37,3,Corr val S1-S2,-500-500ms
37,4,Diag Status,TestON/OFF|OK
38,0,[Undoc for 2.8/5V->data for 2.7T] Diag O2S ctrl Bank 2 (road test >10 min)
38,1,Engine Load,15-25%
38,2,O2S Volt S2,0-1V
38,3,Corr val S1-S2,-500-500ms
38,4,Diag Status,TestON/OFF|OK
40,0,Oxygen sensor heater [B=Bank S=Sensor]
40,1,Resistance B12S1,2.4-9.2ohm
40,2,Status B12S1,ON/OFF
40,3,Resistance B12S2,2.4-9.2ohm
40,4,Status B12S2,ON/OFF
41,0,Undocumented
46,0,Cat. Converter B1 diagnosis (engine 1800-2200 RPM until "Cat B1 OK")
46,1,Amplitude ratio,0.00-0.26
46,2,Exceed diag range,0-2
46,3,Test time, 0-60s
46,4,Status,TestON/OFF|OK
47,0,Cat. Converter B2 diagnosis (engine 1800-2200 RPM until "Cat B2 OK")
47,1,Amplitude ratio,0.00-0.26
47,2,Exceed diag range,0-2
47,3,Test time, 0-60s
47,4,Status,TestON/OFF|OK
50,0,Signals to Engine Control Module (@idle) [A=AWD F=FWD]
50,1,Engine speed,620-740A/+120F
50,2,Spec eng spd,680A/800F
50,3,A/C idle boost,Lo=A/Hi=F
50,4,A/C compressor,ON/OFF
51,0,Undocumented
54,0,Undocumented
55,0,Idle control (@idle) [A=AWD F=FWD]
55,1,Idle Speed,620-740A/+120F
55,2,Idle air ctrl,-1.39-+1.39g/s
55,3,Learn value,-1.39-+1.39g/s
55,4,Op condition,0000=A/0100=F
56,0,[Undoc for 2.8/5V->data for 2.7T] Idle speed stabilization (@idle)
56,1,Engine speed,750-850
56,2,RPM spec,800
56,3,Ctrl Torque Chg,%
56,4,Op condition,00000=OK
60,0,Adaptation of throttle valve control module (ignition on && engine off)
60,1,TV angle,0-5deg
60,2,TV angle,0-5deg
60,3,Op condition,idl/prt/fl/dcl/erch
60,4,Adapt status,RUN/OK/ERROR
61,0,Undocumented
70,0,Evaporative emissions canister purge valve diagnosis (@idle)
70,1,Purge vlv open,0-93%
70,2,O2S deviation,+/-15%
70,3,Idle air vlv dev,-1 to 0 g/s
70,4,Status,TestON/OFF|OK
71,0,Fuel tank leak detection (@idle)
71,1,Reed contact,OPEN
71,2,Error msg,
71,3,Sys Status,Test/check/end
71,4,Diag Status,TestON/OFF|OK
77,0,Secondary Air Injection system diagnosis (@idle)
77,1,O2S ctrl dev,%
77,2,O2S ctrl dev,%
77,3,Coolant temp,>70C
77,4,Diag Status,TestON/OFF|OK
78,0,Undocumented
86,0,OBD-II Readiness Code
86,1,Readiness Code,00000000=OK
86,2,Undocumented
86,3,Undocumented
86,4,Undocumented
87,0,Undocumented
88,0,Undocumented
90,0,Camshaft adjustment (values are for idle && road test: accel in 2nd gear)
90,1,Engine speed,RPM
90,2,Adj ON/OFF,idle=OFF/rt=ON
90,3,Adj resp Bank1,-3-6/16-25degKW
90,4,Adj resp Bank2,-3-6/16-25degKW
91,0,Undocumented
92,0,Undocumented
93,0,Undocumented
95,0,Undocumented
98,0,Undocumented
99,0,O2S Control (ON in read mode && OFF for diagnosis in Basic Setting)
99,1,Engine speed,RPM
99,2,Engine load,%
99,3,Coolant temp,deg C
99,4,O2S control,ON/OFF
100,0,Undocumented
101,0,Undocumented
102,0,Undocumented
110,0,Undocumented
111,0,Undocumented
112,0,Undocumented
120,0,Undocumented
122,0,[Undoc 2.8/5V->data from 1.8T] Engine torque red. during shifting (road test)
122,1,Engine speed,0-6800RPM
122,2,Req. torque,-100-410Nm
122,3,Act. torque,-100-310Nm
122,4,Timing retard,act/mtr eng
131,0,Undocumented
132,0,Undocumented
133,0,Undocumented
134,0,Undocumented
135,0,Undocumented
136,0,Undocumented
137,0,Undocumented
138,0,Undocumented
139,0,Undocumented
140,0,Undocumented
141,0,Undocumented
144,0,Undocumented
145,0,Undocumented
146,0,Undocumented
147,0,Undocumented
; readiness
O,078-907-551-AHA
