Fuse arrangements in fuse panel, under left instrument panel
No. Designation in Wiring Diagram Nominal Value Function/Component Terminal
1 - S1 - Fuse (on fuse/relay panel) 10A - J99 - Heated Outside Mirror Relay, only models with window regulator
Z20/ Z21 - Left and Right Washer Nozzle Heater X
2 - S2 - Fuse (on fuse/relay panel) 10A - J1 - Turn Signal Relay X
3 - S3 - Fuse (on fuse/relay panel) 5A - E1 - Light Switch
E20 - Instrument Panel Illumination Dimmer Switch 58
4 - S4 - Fuse (on fuse/relay panel) 5A - X - License Plate Light 58
5 - S5 - Fuse (on fuse/relay panel) 7,5 A - J393 - Comfort System Central Control Module 15
6 - S6 - Fuse (on fuse/relay panel) 5A - J393 - Comfort System Central Control Module 15
7 - S7 - Fuse (on fuse/relay panel) 10A - J226 - Starter Lock and Back-Up Light Relay (T9/5), only models with automatic transmission
K142 - Selector Lever Position P/N Indicator Lamp
M16 / M17 - Left and Right Back-Up Lamp 15
8 - S8 - Fuse (on fuse/relay panel) 5A - J412-Operating Electronics and Telephone Control Module 15
9 - S9 - Fuse (on fuse/relay panel) 5A - J104 - ABS Control Module (T25/4) 15
10 - S10 - Fuse (on fuse/relay panel) 10A - J220 - Motronic Engine Control Module (ECM) 86s
Beetle Component Locations No. 801 / 8
11 - S11 - Fuse (on fuse/relay panel) 5A - J285 - Instrument Cluster Control Module (T32a/1)
N110 - Shift Lock Solenoid, only models with automatic transmission 01M 15
12 - S12 - Fuse (on fuse/relay panel) 7,5A - T16 - 16-Pin Connector, under instrument panel, left, Data Link Connector (DLC) (T16/16)
J412 - Operating Electronics and Telephone Control Module (T18/11) 30
13 - S13 - Fuse (on fuse/relay panel) 10A - F - Brake Light Switch 30
14 - S14 - Fuse (on fuse/relay panel) 10A - W31 - Left Front Entry Light
W32 - Right Front Entry Light
J393 - Comfort System Central Control Module 30
15 - S15 - Fuse (on fuse/relay panel) 5A - J285 - Instrument Cluster Control Module (T32a/23)
J217 - Transmission Control Module (TCM), (T68/45), only models with automatic transmission 30
16 - S16 - Fuse (on fuse/relay panel) 10A - N25 - A/C System Magnetic Clutch
V36 - Coolant Pump 30
17 - S17 - Fuse (on fuse/relay panel) 7,5A - - Heated door lock 30
18 - S18 - Fuse (on fuse/relay panel) 10A - M32 - Right High Beam Headlamp 56a
19 - S19 - Fuse (on fuse/relay panel) 10A - M30 - Left High Beam Headlamp 56a
20 - S20 - Fuse (on fuse/relay panel) 10A - M31 - Right Low Beam Headlamp 56b
Beetle Component Locations No. 801 / 9
21 - S21 - Fuse (on fuse/relay panel) 10A - M29 - Left Low Beam Headlamp 56b
22 - S22 - Fuse (on fuse/relay panel) 5A - M22 - Right Brake/Taillamp 58r
23 - S223 - Fuse (on fuse panel) 5A - M21 - Left Brake/Taillamp 58l
24 - S224 - Fuse (on fuse panel) 20A - E22 - Windshield Wiper/Washer Switch (T8c/8)
J31 - Wiper/Washer Intermittent Relay X
25 - S225 - Fuse (on fuse panel) 25A - E9 - Fresh Air Blower Switch (T6d/2)
N24 - Fresh Air Blower Series Resistor With Fuse X
26 - S226 - Fuse (on fuse panel) 25A - Z1 - Heated Rear Window X
27 - S227 - Fuse (on fuse panel) 10A - J89 - Daytime Running Lamps Change-over Relay X
28 - S228 - Fuse (on fuse panel) 15A - G6 - Transfer Fuel Pump (FP), not for diesel engine 87
29 - S229 - Fuse (on fuse panel) 15A - J220 - Motronic Engine Control Module (ECM) (T121/3), only engine codes AVH/AZG with Cruise Control, from August 2000
J248 - Diesel Direct Fuel Injection (DFI) Engine Control Module (ECM) (T121/37) 30
30 - S230 - Fuse (on fuse panel) 20A - J245 - Power Sunroof Control Module (T6c/4) 30
31 - S231 - Fuse (on fuse panel) 20A - F125 - Multi-Function Transmission Range (TR) Switch (T8/7), only models with automatic transmission
J217 - Transmission Control Module (TCM) (T68/23) 15
Beetle Component Locations No. 801 / 10
32 - S232 - Fuse (on fuse panel) 10A
15A
- J220 - Motronic Engine Control Module (ECM) (T121/2)
N30/N31/N32/N33 - Cylinder Fuel Injectors, not for diesel engine
J248 - Diesel Direct Fuel Injection (DFI) Engine Control Module (ECM) (T121/2)
N146 - Quantity Adjuster 87
33 - S233 - Fuse (on fuse panel) 20A - Not used 30
34 - S234 - Fuse (on fuse panel) 10A - - Control Module 87
35 - S235 - Fuse (on fuse panel) 30A - U19 - 12V Socket -3- 30
36 - S236 - Fuse (on fuse panel) 15A - E23 - Fog Lamp and Rear Fog Lamp Switch X
37 - S237 - Fuse (on fuse panel) 10A - R - Radio, (T8a/4) (S-Contact) 30
38 - S238 - Fuse (on fuse panel) 15A - J393 - Comfort System Central Control Module (T29a/19)
W3 - Luggage Compartment Light 30
39 - S239 - Fuse (on fuse panel) 15A - E3 - Emergency Flasher Switch (T7/7) 30
40 - S240 - Fuse (on fuse panel) 20A - H1 - Dual Horn
J4 - Dual Horn Relay (3/30) 30
41 - S241 - Fuse (on fuse panel) 15A - U1 - Cigarette Lighter
U5 - 12 V Socket 30
42 - S242 - Fuse (on fuse panel) 25A - R - Radio (T8/5, T8/7) 30
43 - S243 - Fuse (on fuse panel) 10A - - Control Module 87
44 - S244 - Fuse (on fuse panel) 15A - J131 - Driver's Heated Seat Control Module (T6/4)
J132 - Front Passenger's Heated Seat Control Module (T6b/4) 30
