Вот ошибки
Chassis Type: 7L (6N0)
Scan: 01 02 03 05 06 08 09 15 16 17 18 19 22 28 34 36 37 46 55 56
68 6C 6D
VIN: WVGZZZ7LZ9D002482 Mileage: 114970km/71439miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Status: OK 0000
18-Aux. Heat -- Status: Cannot be reached 1100
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
68-Wiper Electr. -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CAS) Labels: 059-907-401-CAT1.clb
Part No SW: 7L0 907 401 AB HW: 7L0 907 401 H
Component: 3.0TDI EDC17G100AG 0040
Revision: --H02--- Serial number: VWX3Z0H3761324
Coding: 04210002591F0568
Shop #: WSC 00221 935 175937
VCID: 6BD5212749702B46511-5000
No fault code found.
Readiness: 0 0 0 0 1
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No SW: 09D 927 750 JK HW: 09D 927 750 JK
Component: AL 750 6A 1411
Revision: 00H75000 Serial number:
Coding: 0004456
Shop #: WSC 31414 790 00001
VCID: 800FE68BD0F6581E143-5000
Address 03: ABS Brakes Labels: 7L0-907-379-MK25E1.clb
Part No SW: 7L0 907 379 P HW: 7L0 614 517 C
Component: ESP ALLRAD MK25E1 0304
Revision: 00H53001
Coding: 0004482
VCID: 4683B0933552362EEEF-8013
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 137 F HW: 3D0 909 137 F
Component: 2G Kessy 6850
Revision: 00H22070 Serial number: VWX3Z0H3761324
Coding: 0147688
VCID: 2A5BE423810AF24EEA7-807F
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
1 Fault Found:
00457 - Control Module for Network (J519)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 3
Fault Frequency: 0
Reset counter: 146
Time Indication: 0
Date: 2015.09.22
Time: 22:01:14
Address 06: Seat Mem. Pass Labels: None
Part No: 7L0 959 760
Component: Sitzverstellung 0701
Shop #: WSC 00000 000 00000
VCID: F7FD8D5782381FA6259-80A2
Address 08: Auto HVAC Labels: 7L6-907-044.clb
Part No: 7L6 907 044 AJ
Component: CLIMAtronic 2+2 4334
Coding: 0001020
VCID: 7CF7127B3B1EBCFEC8B-8029
Subsystem 1 - Part No: 7L6 907 049 F
Component: CLIMAtronic FOND 0503
5 Faults Found:
00710 - Defroster Flap Positioning Motor (V107)
000 - -
02193 - Supply Voltage for Regulator for Fresh Air Blower
007 - Short to Ground - Intermittent
01592 - Air Quality Sensor (G238)
010 - Open or Short to Plus
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
01207 - Control Module for Auxiliary Heater (J364)
004 - No Signal/Communication
Address 09: Cent. Elect. Labels: 7Lx-937-049-V2.clb
Part No SW: 7L6 937 049 AF HW: 7L6 937 049 AF
Component: J519 2002
Revision: -0004--- Serial number: --------------
Coding: 600004003B221C000000000000000000
VCID: 800FE68BD7F6581E143-80D5
1 Fault Found:
00668 - Supply Voltage Terminal 30
008 - Implausible Signal
Address 15: Airbags Labels: 7L0-959-655.lbl
Part No SW: 7L0 959 655 HW: 7L0 959 655
Component: J234__36 VW8T 0250
Revision: 92012025 Serial number: 0039P00566JU
Coding: 0013110
VCID: FAFB9463B12A02CE5A7-80AF
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 G
Component: J527 3601
Coding: 0010212
VCID: 4385A98706600306C91-8016
Address 17: Instruments Labels: 7L6-920-xxx-7L6.lbl
Part No SW: 7L6 920 890 C HW: 7L6 920 890 C
Component: J285 KOMBI-INST. 8828
Revision: KHH06V35
Coding: 0007101
Shop #: WSC 18994 091 977344
VCID: 387FCE6B4BA650DE6C3-806D
Address 18: Aux. Heat
Cannot be reached
Address 19: CAN Gateway Labels: 6N0-909-901-7L.clb
Part No SW: 6N0 909 901 HW: 7L6 920 890 C
Component: J533 GW-K-CAN TP20 8828
Coding: 7FE26FFD48056002
VCID: F0EFB64BE356489EE43-80A5
1 Faults Found:
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 101
Mileage: 114819 km
Time Indication: 0
Date: 2015.09.22
Time: 22:51:43
Address 22: AWD Labels: None
Part No: 0AD 927 755 BG
Component: TRANSFERCASE 0126
VCID: 8109E38FDBFC51161BD-5072
Address 28: HVAC, Rear
Cannot be reached
Address 34: Level Control Labels: 7Lx-907-553-34.clb
Part No: 7L0 907 553 J
Component: LUFTFDR.-CDC- 3C3P1 3125
Coding: 0015521
Shop #: WSC 53788 001 1048576
VCID: 3A7BD46371AA42CE9A7-806F
Address 36: Seat Mem. Drvr Labels: None
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 7L6 035 680 B HW: 7L6 035 680 B
Component: RNS-MID H02 0802
Revision: AB001001 Serial number: VWZ6Z7H7135044
Coding: 000004000400002200
VCID: 3169F34F68DC81962BD-8064
Address 46: Central Conv. Labels: 7L0-959-933.lbl
Part No: 7L6 959 933 A
Component: 24 HSG 0601
Coding: 0000069
VCID: 408FA68B1076181ED43-4A3A
Subsystem 1 - Part No: 7L0 959 701 P
Component: Tuersteuergeraet FS 6303
Subsystem 2 - Part No: 7L0 959 702 P
Component: Tuersteuergeraet BF 6302
Subsystem 3 - Part No: 7L0 959 703 D
Component: Tuersteuergeraet HL 0201
Subsystem 4 - Part No: 7L0 959 704 D
Component: Tuersteuergeraet HR 0201
Subsystem 5 - Part No: 7L0 907 719 A
Component: Neigungssensor 0020
Subsystem 6 - Part No: 7L6 951 171 B
Component: Innenraumsensor 0020
Address 55: Xenon Range Labels: 7L6-907-357-A.lbl
Part No SW: 7L6 907 357 A HW: 7L6 907 357 A
Component: AFS-Steuergeraet 0001
Revision: H02 Serial number:
Coding: 1288323
VCID: 3979CB6F74AC49D693D-806C
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Address 68: Wiper Electr. Labels: 7L0-955-119-V2.clb
Part No: 7L6 955 119 B
Component: J400__ Front Wiper 5301
Coding: 0001397
VCID: 3979CB6F70AC49D693D-806C
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 090508 054 0402
Coding: 00208941
Shop #: WSC 31414
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 7L6 907 441 B HW: 7L6 907 441 B
Component: J772__Rearview 0033
Revision: 00H13000 Serial number: PA8 J850065
Coding: 0000001
VCID: 3467FA5B57CEB4BE40B-8061
Address 6D: Trunk Elect. Labels: None
Part No SW: 7L6 959 107 B HW: 7L6 959 107 B
Component: J605 HECKKLAPPE 1310
Revision: --H05--- Serial number: --------033160
Coding: 0122110
End ---------------------------------------------------------------------
