Cable-Throttle Engines
(These are engines with a physical cable between the accelerator and the throttle, but WITHOUT an ISV.)
 Turn the key on but do not start the car.
##[Select]
##[01 - Engine]
##[Measuring Blocks - 08]
Enter Group 098 (Note: Some SIMOS or Marelli ECU's use Group 001 such as ADY & AEE engines)
##[Go!]
##[Switch to basic settings]
Once you do this you will see the top right display say ADP RUN. The TB adaptation is being done as soon as you switch to basic settings. You will see the values change and hear the TB cycle for the first few seconds then it will stop. Leave it in Basic Settings for about 30 seconds.
##Click the [Switch to Meas. Blocks] button and you're all set.
Be sure not to touch the accelerator and make sure the engine is NOT running when you do this!
