BVVIT
Пожалуйста, подскажите чего смотреть в первую очередь?
Friday,04,April,2014,20:46:09:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 8T0
Scan: 01 02 03 05 06 07 08 09 0E 10 14 15 16 17 19 1B 36 37 42 46
47 52 53 55 56 77
VIN: WAUZZZ8T58A039251 Mileage: 88180km/54792miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
14-Susp. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1B-Active Steering -- Status: OK 0000
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (------CABD) Labels: 06H-907-115-CAB.clb
Part No SW: 8T0 907 115 A HW: 8K1 907 115
Component: 1.8l R4/4V TF H07 0004
Revision: A5H07---
Coding: 0114000302070020
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_ECM18TFS8T0907115A A01004
ROD: EV_ECM18TFS8T0907115A.rod
VCID: 346D02099F204E9
2 Faults Found:
4660 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [047] - -
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 7
Mileage: 88146 km
Date: 2014.04.03
Time: 21:10:47
4737 - Signal Line for Fuel Pump Electronics
P3089 00 [096] - Electrical Malfunction
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 88151 km
Date: 2014.04.04
Time: 16:24:44
Readiness: 0010 0000
Address 02: Auto Trans (J217) Labels: 0AW-927-156.clb
Part No SW: 8K0 927 155 F HW: 0AW 927 156 E
Component: 0AW 18TFSIRdW H04 0002
Revision: --H04--- Serial number: 0000000204
Coding: 000001
ASAM Dataset: EV_TCMVL381 A01014
ROD: EV_TCMVL381_AU48.rod
VCID: 36693801895C5C9
1 Fault Found:
2225 - RPM Signal from ECU
P0727 00 [236] - No Signal
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 254
Mileage: 88147 km
Date: 2014.04.03
Time: 23:24:03
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 R HW: 8K0 907 379 R
Component: ESP8 front H04 0210
Revision: -------- Serial number: --------------
Coding: 052D00
VCID: 489546F9FBA8DA9
4 Faults Found:
03265 - Data Bus Chassis Sensors
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 137
Mileage: 88146 km
Time Indication: 0
Date: 2014.04.03
Time: 21:11:16
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4702
Hex Value: 0x001D
Hex Value: 0xB9B7
Hex Value: 0x00FF
03033 - ESP Sensor Unit 2 (G536)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 137
Mileage: 88146 km
Time Indication: 0
Date: 2014.04.03
Time: 21:11:16
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4702
Hex Value: 0x0022
Hex Value: 0xB8B7
Hex Value: 0x00FF
00493 - ESP-Sensor Unit (G419)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 137
Mileage: 88146 km
Time Indication: 0
Date: 2014.04.03
Time: 21:11:16
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4702
Hex Value: 0x0005
Hex Value: 0x54B7
Hex Value: 0x00FF
03159 - TPMS Functionality in ESP
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 137
Mileage: 88146 km
Time Indication: 0
Date: 2014.04.03
Time: 21:11:16
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4702
Hex Value: 0x001A
Hex Value: 0x0DB7
Hex Value: 0x00FF
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 AL HW: 8K0 907 064 AL
Component: BCM2 1.1 H71 0134
Revision: 00002001
Coding: 050000
VCID: 7AF1EC31F5C4789
Subsystem 1 - Part No SW: 8K0 905 852 C HW: 8K0 905 852 C
Component: ELVAUDIB8 H35 0039
2 Faults Found:
03285 - Sensor for Contact with Door Handle; Front Left
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 175
Mileage: 88147 km
Time Indication: 0
Date: 2014.04.03
Time: 21:46:52
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 2
Fault Frequency: 3
Reset counter: 137
Mileage: 88148 km
Time Indication: 0
Date: 2014.04.03
Time: 23:44:06
Address 06: Seat Mem. Pass (J521) Labels: None
Part No SW: 8T0 959 760 B HW: 8T0 959 760 B
Component: MEM-BFS H09 0043
Revision: AA000000 Serial number: 00001001074437
Coding: 08017025002444111000
VCID: 428154D1DD94F09
No fault code found.
Address 07: Control Head Labels: 8T0-035-7xx-07-H.clb
Part No SW: 8T0 035 729 G HW: 4E0 035 729
Component: Interfacebox H43 5530
Revision: 00000000 Serial number: 398AN087501033
Coding: 0005012
VCID: 3D7B272D646A8F1
Part No: 8T0 919 609 C
Component: E0380 BedienteilH08 0100
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 P HW: 8T1 820 043 P
Component: KLIMA 1 ZONE H05 0120
Revision: A1000000 Serial number: 0125.03.080165
Coding: 64020000
VCID: 3E792021A96C949
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Component: BCM1 1.0 H21 0253
Revision: 05021001 Serial number: 00000000111250
Coding: 2600D0914010AF311F09000300005D5D0F9CC3C800010101000000
VCID: 30650E196338729
Subsystem 1 - Part No SW: 8T1 955 119 C HW: 8J1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 120308 H13 0040
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 02532C
Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
Component: E1 - LDS H07 0070
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 8T1 035 110 C HW: 8T1 035 110 C
Component: MP3-Changer H41 0390
Revision: 00041001 Serial number: AUZ5ZBH8352153
Shop #: WSC 00000 000 00000
VCID: 2A511C7185E4089
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 B HW: 8K0 919 475
Component: PARKHILFE 4K H06 0010
Revision: 11001001 Serial number: 75330807802536
Coding: 000101
VCID: 387536398B48AA9
Address 14: Susp. Elect. (J250) Labels: None
Part No SW: 8K0 907 364 HW: 8K0 907 364
Component: DAEMPFUNGS-SG H08 0052
Revision: 00000000 Serial number: 27020800110002
Coding: 050181
Shop #: WSC 00340 935 87520
VCID: F0E54E1923B8B29
2 Faults Found:
01316 - ABS Control Module
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 135
Mileage: 88146 km
Time Indication: 0
Date: 2014.04.03
Time: 21:11:22
Freeze Frame:
Bin. Bits: 00000000 00000110
03264 - Functionalty Shut Off
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 6
Fault Frequency: 12
Reset counter: 137
Mileage: 88147 km
Time Indication: 0
Date: 2014.04.03
Time: 23:22:50
Freeze Frame:
Error Code: 9
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
Component: AirbagVW-AU10 H26 0410
Serial number: 0038JD13YN7P
Coding: 30313433363030303030554A304C38543053
ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 3C7D2A29B770869
Crash sensor for side airbag; driver side:
Serial number: 6334MSME3530460C6
Crash sensor for side airbag; passenger side:
Serial number: 6344MSME3510355EA
Crash sensor for side airbag; rear driver side:
Serial number: 6352QSME5B621F73R
Crash sensor for side airbag; rear passenger side:
Serial number: 6362QSME5A583929T
Crash sensor for front airbag; driver side:
Serial number: 63732SME5A0817670
Crash sensor for front airbag; passenger side:
Serial number: 63832SME56284051V
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 G HW: 8K0 953 568 G
Component: Lenks.Modul H10 0012
Revision: -------- Serial number: 90304HAR0002G
Coding: 000032
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8T0 920 931 HW: 8T0 920 931
Component: KOMBIINSTR. H28 0216
Revision: 00000000 Serial number: 71U1J9H38
Coding: 0F07000033000008010000
VCID: F4ED420957A08E9
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 F HW: 8T0 907 468 F
Component: GW-BEM 4CAN-M H07 0084
Revision: EB002032 Serial number: 3200E083128135
Coding: 000003
Shop #: WSC 00351 935 80186
VCID: 448D52C9C780FE9
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H03 0150
1 Fault Found:
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 7
Fault Frequency: 1
Reset counter: 177
Mileage: 88146 km
Time Indication: 0
Date: 2014.04.03
Time: 18:58:00
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8K0 907 144 A HW: 8K0 907 144 A
Component: DYNAMIKLENK. H05 0322
Revision: 50000003 Serial number: --------------
Coding: 040000
VCID: 2D5B176D740A1F1
Address 36: Seat Mem. Drvr (J136) Labels: None
Component: MEM-FS H09 0043
Revision: AA000000 Serial number: 00001001074798
1 Fault Found:
03327 - Switch for Headrest Adjustment: Down
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 4
Fault Frequency: 2
Reset counter: 177
Mileage: 88184 km
Time Indication: 0
Date: 2014.04.04
Time: 18:15:15
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 L HW: 4E0 919 887 M
Component: MNS ECE H51 2030
Revision: 00000000 Serial number: 381AK087501137
VCID: 377735054656A51
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 HW: 8K0 959 793
Component: TSG FA H09 0149
Revision: Serial number: 3Y’
Coding: 011C122240002201
VCID: FDFB672D64EACF1
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0110318802
Coding: 01000E8000390001013000
3 Faults Found:
02741 - Bulb for Tail Light 2; Right
012 - Electrical Fault in Circuit - MIL ON
Freeze Frame:
Fault Status: 11101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 135
Mileage: 88146 km
Time Indication: 0
Date: 2014.04.03
Time: 21:11:49
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 135
Mileage: 88147 km
Time Indication: 0
Date: 2014.04.03
Time: 21:45:50
02616 - Fuel Tank Cap; Unlock
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 135
Mileage: 88147 km
Time Indication: 0
Date: 2014.04.03
Time: 21:46:52
Address 47: Sound System (J525) Labels: 8T0-035-223-ASM.clb
Part No SW: 8T0 035 223 G HW: 8T0 035 223 G
Component: DSP STD H08 0290
Revision: S2500000
Coding: 010101
VCID: 326104116D34409
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 HW: 8K0 959 792
Component: TSG BF H09 0149
Revision: Serial number: hC”
VCID: FCFD6A297FF0C69
Address 53: Parking Brake (J540) Labels: 8K0-907-801.clb
Part No SW: 8K0 907 801 D HW: 8K0 907 801 D
Component: EPB Audi B8 H04 0050
Revision: 00000003 Serial number: 00000000096191
Address 55: Xenon Range Labels: 8K0-907-357.clb
Part No: 8K0 907 357 B
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000003
Shop #: WSC 06324 000 00000
VCID: 346D020957204E9
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4F0 035 541 L
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 336CV087545483
Coding: 0000001
VCID: 2E591061B90C649
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 K HW: 4E0 862 335
Component: Handyvorb2 H18 0950
Revision: 00000000 Serial number: 00000005119979
Coding: 0010900
End ---------------------------------------------------------------------
Chassis Type: 8T0
47 52 53 55 56 77
Revision: A5H07---
2 Faults Found:
U1017 00 [047] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 7
Mileage: 88146 km
Date: 2014.04.03
Time: 21:10:47
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 88151 km
Date: 2014.04.04
Time: 16:24:44
Coding: 000001
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Mileage: 88147 km
Date: 2014.04.03
Time: 23:24:03
Coding: 052D00
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 137
Mileage: 88146 km
Time Indication: 0
Date: 2014.04.03
Time: 21:11:16
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4702
Hex Value: 0x001D
Hex Value: 0xB9B7
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 137
Mileage: 88146 km
Time Indication: 0
Date: 2014.04.03
Time: 21:11:16
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4702
Hex Value: 0x0022
Hex Value: 0xB8B7
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 137
Mileage: 88146 km
Time Indication: 0
Date: 2014.04.03
Time: 21:11:16
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4702
Hex Value: 0x0005
Hex Value: 0x54B7
Hex Value: 0x00FF
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 137
Mileage: 88146 km
Time Indication: 0
Date: 2014.04.03
Time: 21:11:16
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4702
Hex Value: 0x001A
Hex Value: 0x0DB7
Hex Value: 0x00FF
Revision: 00002001
Coding: 050000
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 175
Mileage: 88147 km
Time Indication: 0
Date: 2014.04.03
Time: 21:46:52
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 137
Mileage: 88148 km
Time Indication: 0
Date: 2014.04.03
Time: 23:44:06
Coding: 0005012
Coding: 64020000
Coding: 00FD11
Coding: 02532C
Coding: 000101
Coding: 050181
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 135
Mileage: 88146 km
Time Indication: 0
Date: 2014.04.03
Time: 21:11:22
Freeze Frame:
000 - - - MIL ON
Freeze Frame:
Fault Priority: 6
Fault Frequency: 12
Reset counter: 137
Mileage: 88147 km
Time Indication: 0
Date: 2014.04.03
Time: 23:22:50
Freeze Frame:
Error Code: 9
Coding: 000032
Coding: 000003
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 177
Mileage: 88146 km
Time Indication: 0
Date: 2014.04.03
Time: 18:58:00
Coding: 040000
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 177
Mileage: 88184 km
Time Indication: 0
Date: 2014.04.04
Time: 18:15:15
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 135
Mileage: 88146 km
Time Indication: 0
Date: 2014.04.03
Time: 21:11:49
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 135
Mileage: 88147 km
Time Indication: 0
Date: 2014.04.03
Time: 21:45:50
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 135
Mileage: 88147 km
Time Indication: 0
Date: 2014.04.03
Time: 21:46:52
Revision: S2500000
Coding: 010101
Coding: 0000003
Coding: 0000001
Coding: 0010900
