Fuse assignment:
1 - Heated washer jets 5 A
17 - Two-way radio for special vehicles, electric socket Telematics (USA) 10 A
15 A
2 - Turn signal system 10 A 18 - Right main beam 10 A
3 - Windscreen heater 5 A 19 - Left main beam 10 A
4 - Number plate light 5 A 20 - Right dipped beam 15 A
5 - Heated seats, air conditioning system, Telematics, multifunction steering wheel, solar roof, mirror, garage door opener 10 A
21 - Left dipped beam 15 A
6 - Convenience system central control unit 5 A
22 - Side light right 5 A
7 - ABS, brake light switch, cruise control system, engine control unit 10 A
23 - Side light left 5 A
8 - Automatic headlight range control 5 A
24 - Wiper system 25 A
9 - Parking aid 5 A
25 - Fresh air blower, recirculated air system, air conditioning system, solar roof 30 A
10 - CD changer, telephone, Telematics, multifunction steering wheel, navigation system, radio 5 A
26 - Heated rear window 30 A
11 - Seat adjustment with memory function 5 A
27 - Rear window wiper 15 A
12 - Self-diagnosis connection voltage supply 10 A
28 - Fuel pump, additional diesel pump 20 A
13 - Brake lights 10 A 29 - Engine control unit, radiator fan 20 A
14 - Convenience system central control unit 10 A
30 - Sliding/tilting sunroof 20 A
15 - Dash panel insert, air conditioning system, automatic gearbox 10 A
31 - Reversing lights, CCS, automatic gearbox, revolution boost, mirror, frequency valve, diagnostic socket, alarm control unit for special vehicles 15 A
16 - ABS, steering angle sender 5 A
32 - Engine control unit, CCS 20 A
33 - Cigarette lighter 15 A
34 - Engine control unit 15 A
35 - Trailer towing coupling socket 30 A
36 - Fog lights 15 A
37 - Radio system, navigation 20 A
38 - Convenience system central control unit, door control unit 15 A
39 - Hazard warning lights system 15 A
40 - Dual tone horn 25 A
41 - Telematics (USA) 25 A
42 - ABS with ESP 25 A
43 - Exhaust gas recirculation, coolant temperature sender, engine control unit 15 A
44 - Seat heating 30 A
lelik555 написал(а):Все видемые преды целые под рулем где стоит эбу и на торпеде есть ли какая нибудь реле которая отвечает за подачу плюса
годы выпуска и буковки двигателя...
Гарик 686 написал(а):Помогите разобратся......отказали дворники,ближний свет и отопитель салона. Предохранители все целые, но на них нет тока.
