user написал(а):Опять горит лампачки ABS/ESP. И VAG-COM дал ошибку АБС 18265 Load Signal: Error Message from ECU P1837. АБС неработает. Горит тоже Check Engine и ошибки:
17833 - EVAP Purge Valve (N80): Short to Ground
P1425 - 35-00 - -
17955 - Shareware Version. To Decode all DTCs
P1547 - 35-00 - Please Register/Activate
17525 - Shareware Version. To Decode all DTCs
P1117 - 35-00 - Please Register/Activate
17843 - Secondary Air Pump Relay (J299): Short to Ground
P1435 - 35-00 - -
17829 - Shareware Version. To Decode all DTCs
P1421 - 35-00 - Please Register/Activate
17697 - Shareware Version. To Decode all DTCs
P1289 - 35-00 - Please Register/Activate
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-00 - -
17524 - Shareware Version. To Decode all DTCs
P1116 - 35-00 - Please Register/Activate
В чом проблема? WD-40 в АБС штекере непомогает.
