Сегей написал(а):VW t4 2003 acv 2,5 td vag-com выдал ошибку 17971. Куда лезть что делать ?
17971/P1563/005475 - Quantity Adjuster (N146): Lower Limit Reached
Possible Symptoms
Malfunction Indicator Light (MIL) ON
Reduced Power
Engine jerking
Possible Causes
Fuse(s) faulty
Wiring and/or Connector(s) from/to Quantity Adjuster (N146) faulty
Quantity Adjuster (N146) not adjusted
Quantity Adjuster (N146) blocked/faulty
Possible Solutions
Check Fuse(s)
Check Wiring and/or Connector(s) from/to Quantity Adjuster (N146)
Check/Adjust Quantity Adjuster (N146)
Check/Replace Injection Pump
