Кодирование Блока ABS
  • Автор темы greenmouse
  • Ответы 5
greenmouse
Ейск Краснодарский край
Toyota Corsa 1,5 TD
Доброго времени суток.
Автомобиль Шаран 1.8 турбо.
Такая проблема. После замены насоса АБС, ВагКом выдаёт ошибку 01044 Неправильно кодирован блок управления.
как его кодировать? VCDS 11.11.
Vag № 1G0 907 379 G
CODE: 03604 (Видимо старый или неактуальный)
Component: ABS 20IE CAN 0001
Мастерская WSC 01317
VW Sharan (7M) Brake Electronics (MK04)
Coding
02802 = Standard (ABS & ABS/EDS)
VW Sharan (7M) Brake Electronics (MK20)
Coding
ABS & ABS/EDS (< MY 2000)
12812 = Standard
ABS (MY 2001 >)
12502 = Standard
ABS/EDS/ASR/ESP (MY 2001 >)
18952 = Front-Wheel-Drive (FWD)
18443 = All-Wheel-Drive (AWD)
VW Sharan (7M) Brake Electronics (MK25)
Coding
ABS
07177 = Standard
ABS/EDS/ASR/ESP
06154 = Front-Wheel-Drive (FWD)
06667 = All-Wheel-Drive (AWD)
Basic Setting
Sensor for Steering Angle (G85)
Prerequisites:
Start the vehicle.
Turn the steering wheel one turn to the right and one turn to the left (at least ± 15 ° each side).
Drive in a short distance straight line on a level surface at a speed not higher than 20 km/h.
If the steering wheel is straight during the test drive then stop the vehicle with the wheels pointed straight.
Ensure that the steering wheel is not moved again.
Keep the engine running and do not switch off the ignition.
System voltage at least 12.0 V.
[Select]
[03 - Brake Electronics]
[Coding-II - 11]
Enter 40168, to enable the basic setting.
[Do it!]
[Basic Settings - 04]
Group 060
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
After a successful basic setting, field 2 should say "OK".
[Done, Go Back]
To make sure the basic setting was succesful, check the sensor again.
[Measuring Blocks - 08]
Group 004
[Go!]
Check field 1, the value has to be between -1.5 and +1.5 °.
[Done, Go Back]
[Close Controller, Go Back - 06]
Как узнать какое МК в моем случае? Где это пишеться? А ниже, как я понял, написано адаптация датчика поворота руля. А это имеет что то общее с абс?
Vag № 1G0 907 379 G
Component: ABS 20IE
