001,0,General Values
001,1,Comprossor,Shut-Off,Specification: 0 = Compressor Running (See Label File for more Details)
; 0 = Compressor Running
; 1 = Compressor OFF by Pressure Switch (F129): Refrigerant Pressure too High
; 2 = Compressor OFF by Fresh Air Blower (V2) or Fresh Air Blower Control Module (J126) Malfunction
; 3 = Compressor OFF by Pressure Switch (F129): Refrigerant Pressure too Low
; 5 = Compressor OFF by Missing Engine Speed Signal
; 6 = Compressor OFF by ECON Button
; 7 = Compressor OFF by OFF Button (via Fresh Air Blower Speed Buttons)
; 8 = Compressor OFF by Ambient Temperature below 3 °C (37 °F)
; 10 = Compressor OFF by Voltage below 9.5 V
; 11 = Compressor OFF by Coolant Temperature too High
; 12 = Compressor OFF by Engine OR Transmission Control Module
; 13 = Compressor OFF by Voltage above 17 V
; 14 = Compressor OFF by Evaporator Temperature
; 15 = Compressor OFF by Control Module Coding incorrect
; 16 = Compressor OFF by Climate Control Module (J255) Malfunction
; 17 = Compressor OFF by Pressure Sensor Malfunction
