Подскажите код регенерации сажевого фильтра на Tiguan 2,0D 2
  • Автор темы odin12
  • Ответы 3
    vw tiguan
odin12
Киев
caddy 2.0 SDI
Подскажите код регенерации сажевого фильтра на Tiguan 2.0D 2009 и в каких блоках что смотреть??
1.4l/1.9l/2.0l R4 & 2.5l R5 PD/PPD-TDI
Prerequisites (General):
Ignition ON
Engine ON (Idle)
Coolant Temperature above 50 °C (see MVB 002.4)
Particle Filter Load below Specification (see MVB 075.3, VAG-COM should give the specified value)
If the Particle Filter Load is above Specification the Particle Filter needs to be replaced since the car may burn down when regenerating.
Power Consumers ON (Light, Seat Heating, Front/Rear Window Heater, Climate Control)
Conditions (Driving Cycle):
Vehicle Speed between 30-60 km/h (18-37 MPH)
Engine Speed between 1500-2500 RPM (4th or 5th Gear, Automatic Transmission in Tiptronic)
Duration approx. 15-20 Minutes
Exhaust Gas Temperature before Turbo Charger above 700 °C
Drive the car based on the above conditions until the Particle Filter Load is as low as possible (close to 0 %). In case the regeneration fails there can either be problems with the Driving Cycle Conditions or with the Engine Hardware.
[Select]
[01 - Engine]
[Coding-II - 11]
Enable Regeneration by Entering 21295.
[Do It!]
[Meas. Blocks - 08]
Select both Groups at once 070 and 075.
[Go!]
MVB 070.1: Regeneration Status (xxxxxxx1 = Normal Regeneration active, xxxxxx1x = Forced Regeneration active)
MVB 070.3: Regeneration Counter/Timer
MVB 075.1: Exhaust Gas Temperature before Turbo Charger
MVB 075.2: Exhaust Gas Temperature before Particle Filter
MVB 075.3: Particle Filter Load
MVB 075.4: Exhaust Gas Temperature after Particle Filter
Now Start the Driving Cycle and keep watching the Measuring Blocks (2nd Person required).
[Done, Go Back]
[Close Controller, Go Back - 06]
Код 21295 регенерацию не запускает и блоки не соответствуют этому автомобилю. Ошибок блокирующих регенерацию нет.
Р242F (09236)
P2002
Писать нужно буковки двигателя.
Пробуй так:
Particle Filter Emergency Regeneration
Prerequisites:
Ignition ON
Engine ON (Idle)
Oil Temperature above 70 °C (see MVB 007.2)
Particle Filter Load below 68g (see MVB 104.3)
If the Particle Filter Load is above 68g the Particle Filter needs to be replaced since the car may burn down when regenerating.
Engine Hood CLOSED
Parking Brake ENGAGED
Transmission in (P)ARK
Temperatures at the Exhaust System may rise up to 300 °C!!!
No Fault Codes Stored
The Regeneration may take up to 40 minutes, the engine speed automatically increases to about 1500 RPM.
[Select]
[01 - Engine]
[Coding-II - 11]
Start Regeneration by Entering 10016.
[Do It!]
[Meas. Blocks - 08]
Select all 3 Groups at once 100, 101 and 102
[Go!]
MVB 100.1: Engine Speed
MVB 100.3: Regeneration Counter/Timer
MVB 100.4: Regeneration Abort recognized (0 = No Abort/1 = Abort recognized)
MVB 101.4: Regeneration Status (001 = Heating Up, 010 = Regeneration, 100 = Cooling Down)
MVB 102.1: Temperature before Catalyst
MVB 102.2: Temperature before Particle Filter
[Done, Go Back]
